RTEMS 5.2
Macros | Enumerations | Functions
File Transfer Protocol File System
The FTP file system (FTP client) can be used to transfer files from or to remote hosts. More...
#define RTEMS_FTPFS_CTRL_PORT   21
 Well-known port number for FTP control connection.
#define RTEMS_FTPFS_MOUNT_POINT_DEFAULT   "/FTP"
 Default mount point for FTP file system.
enum  rtems_ftpfs_ioctl_numbers { RTEMS_FTPFS_IOCTL_GET_VERBOSE = _IOR( 'd', 1, bool *) , RTEMS_FTPFS_IOCTL_SET_VERBOSE = _IOW( 'd', 1, bool *) , RTEMS_FTPFS_IOCTL_GET_TIMEOUT = _IOR( 'd', 2, struct timeval *) , RTEMS_FTPFS_IOCTL_SET_TIMEOUT = _IOW( 'd', 2, struct timeval *) }
 FTP file system IO control requests.
rtems_status_code rtems_ftpfs_get_verbose (const char *mount_point, bool *verbose)
 Returns in verbose if the verbose mode is enabled or disabled for the file system at mount_point. More...
rtems_status_code rtems_ftpfs_set_verbose (const char *mount_point, bool verbose)
 Enables or disables the verbose mode if verbose is true or false respectively for the file system at mount_point. More...
rtems_status_code rtems_ftpfs_get_timeout (const char *mount_point, struct timeval *timeout)
 Returns the current timeout value in timeout for the file system at mount_point. More...
rtems_status_code rtems_ftpfs_set_timeout (const char *mount_point, const struct timeval *timeout)
 Sets the timeout value to timeout for the file system at mount_point. More...
You can mount the FTP file system with a call to mount() or mount_and_make_target_path() with the RTEMS_FILESYSTEM_TYPE_FTPFS file system type.
You have to add CONFIGURE_FILESYSTEM_FTPFS to your application configuration.
You can open files either read-only or write-only. A seek is not allowed. A close terminates the control and data connections.
To open a file file.txt in the directory dir (relative to home directory of the server) on a server named host using the user name user and the password pw you must specify the following path: /FTP/user:pw@host/dir/file.txt.
If the server is the default server specified in BOOTP, it can be ommitted: /FTP/user:pw/dir/file.txt.
The user name will be used for the password if it is ommitted: /FTP/user@host/dir/file.txt.
For the data transfer passive (= default) and active (= fallback) mode are supported.
◆ rtems_ftpfs_get_timeout()
rtems_status_code rtems_ftpfs_get_timeout ( const char *  mount_point,
struct timeval *  timeout
If mount_point is NULL the default mount point RTEMS_FTPFS_MOUNT_POINT_DEFAULT will be used.
◆ rtems_ftpfs_get_verbose()
rtems_status_code rtems_ftpfs_get_verbose ( const char *  mount_point,
bool *  verbose
◆ rtems_ftpfs_set_timeout()
rtems_status_code rtems_ftpfs_set_timeout ( const char *  mount_point,
const struct timeval *  timeout
The timeout value will be used during connection establishment of active data connections. It will be also used for send and receive operations on data and control connections.
◆ rtems_ftpfs_set_verbose()
rtems_status_code rtems_ftpfs_set_verbose ( const char *  mount_point,
bool  verbose
In the enabled verbose mode the commands and replies of the FTP control connections will be printed to standard error.
