RTEMS_DEPRECATED rtems_device_driver | rtems_blkdev_generic_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
RTEMS_DEPRECATED rtems_device_driver | rtems_blkdev_generic_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
RTEMS_DEPRECATED rtems_device_driver | rtems_blkdev_generic_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
RTEMS_DEPRECATED rtems_device_driver | rtems_blkdev_generic_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
RTEMS_DEPRECATED rtems_device_driver | rtems_blkdev_generic_ioctl (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Generic disk device operations for standard RTEMS IO drivers.
◆ RTEMS_GENERIC_BLOCK_DEVICE_DRIVER_ENTRIES
| #define RTEMS_GENERIC_BLOCK_DEVICE_DRIVER_ENTRIES |
Value: rtems_blkdev_generic_open, \
rtems_blkdev_generic_close, \
rtems_blkdev_generic_read, \
rtems_blkdev_generic_write, \
The device driver interface conventions suppose that a driver may contain an initialize, open, close, read, write and IO control entry points. These primitives (except initialize) can be implemented in a generic fashion based upon the supplied block device driver IO control handler. Every block device driver should provide an initialize entry point, which registers the appropriate IO control handler.
