RTEMS 5.2
Files | Macros
LatticeMico32 TSMAC (Tri-Speed MAC) definitions. More...
file  dp83848phy.h
file  tsmac.h
#define LM32_TSMAC_RX_LEN_FIFO   (0x000)
#define LM32_TSMAC_RX_DATA_FIFO   (0x004)
#define LM32_TSMAC_TX_LEN_FIFO   (0x008)
#define LM32_TSMAC_TX_DATA_FIFO   (0x00C)
#define LM32_TSMAC_VERID   (0x100)
#define LM32_TSMAC_INTR_SRC   (0x104)
#define INTR_RX_SMRY   (0x00020000)
#define INTR_TX_SMRY   (0x00010000)
#define INTR_RX_FIFO_FULL   (0x00001000)
#define INTR_RX_ERROR   (0x00000800)
#define INTR_RX_FIFO_ERROR   (0x00000400)
#define INTR_RX_FIFO_ALMOST_FULL   (0x00000200)
#define INTR_RX_PKT_RDY   (0x00000100)
#define INTR_TX_FIFO_FULL   (0x00000010)
#define INTR_TX_DISCFRM   (0x00000008)
#define INTR_TX_FIFO_ALMOST_EMPTY   (0x00000004)
#define INTR_TX_FIFO_ALMOST_FULL   (0x00000002)
#define INTR_TX_PKT_SENT   (0x00000001)
#define LM32_TSMAC_INTR_ENB   (0x108)
#define INTR_ENB   (0x00040000)
#define LM32_TSMAC_RX_STATUS   (0x10C)
#define STAT_RX_FIFO_FULL   (0x00000010)
#define STAT_RX_ERROR   (0x00000008)
#define STAT_RX_FIFO_ERROR   (0x00000004)
#define STAT_RX_FIFO_ALMOST_FULL   (0x00000002)
#define STAT_RX_PKT_RDY   (0x00000001)
#define LM32_TSMAC_TX_STATUS   (0x110)
#define STAT_TX_FIFO_FULL   (0x00000010)
#define STAT_TX_DISCFRM   (0x00000008)
#define STAT_TX_FIFO_ALMOST_EMPTY   (0x00000004)
#define STAT_TX_FIFO_ALMOST_FULL   (0x00000002)
#define STAT_TX_PKT_SENT   (0x00000001)
#define LM32_TSMAC_RX_FRAMES_CNT   (0x114)
#define LM32_TSMAC_TX_FRAMES_CNT   (0x118)
#define LM32_TSMAC_RX_FIFO_TH   (0x11C)
#define LM32_TSMAC_TX_FIFO_TH   (0x120)
#define LM32_TSMAC_SYS_CTL   (0x124)
#define SYS_CTL_TX_FIFO_FLUSH   (0x00000010)
#define SYS_CTL_RX_FIFO_FLUSH   (0x00000008)
#define SYS_CTL_TX_SNDPAUSREQ   (0x00000004)
#define SYS_CTL_TX_FIFOCTRL   (0x00000002)
#define SYS_CTL_IGNORE_NEXT_PKT   (0x00000001)
#define LM32_TSMAC_PAUSE_TMR   (0x128)
#define LM32_TSMAC_MAC_REGS_DATA   (0x200)
#define LM32_TSMAC_MAC_REGS_ADDR_RW   (0x204)
#define REGS_ADDR_WRITE   (0x80000000)
#define LM32_TSMAC_MODE_BYTE0   (0x000)
#define MODE_TX_EN   (1<<3)
#define MODE_RX_EN   (1<<2)
#define MODE_FC_EN   (1<<1)
#define MODE_GBIT_EN   (1<<0)
#define LM32_TSMAC_TX_RX_CTL_BYTE0   (0x002)
#define TX_RX_CTL_RECEIVE_SHORT   (1<<8)
#define TX_RX_CTL_RECEIVE_BRDCST   (1<<7)
#define TX_RX_CTL_DIS_RTRY   (1<<6)
#define TX_RX_CTL_HDEN   (1<<5)
#define TX_RX_CTL_RECEIVE_MLTCST   (1<<4)
#define TX_RX_CTL_RECEIVE_PAUSE   (1<<3)
#define TX_RX_CTL_TX_DIS_FCS   (1<<2)
#define TX_RX_CTL_DISCARD_FCS   (1<<1)
#define TX_RX_CTL_PRMS   (1<<0)
#define LM32_TSMAC_MAX_PKT_SIZE_BYTE0   (0x004)
#define LM32_TSMAC_IPG_VAL_BYTE0   (0x008)
#define LM32_TSMAC_MAC_ADDR_0_BYTE0   (0x00A)
#define LM32_TSMAC_MAC_ADDR_1_BYTE0   (0x00C)
#define LM32_TSMAC_MAC_ADDR_2_BYTE0   (0x00E)
#define LM32_TSMAC_TX_RX_STS_BYTE0   (0x012)
#define TX_RX_STS_RX_IDLE   (1<<10)
#define TX_RX_STS_TAGGED_FRAME   (1<<9)
#define TX_RX_STS_BRDCST_FRAME   (1<<8)
#define TX_RX_STS_MULTCST_FRAME   (1<<7)
#define TX_RX_STS_IPG_SHRINK   (1<<6)
#define TX_RX_STS_SHORT_FRAME   (1<<5)
#define TX_RX_STS_LONG_FRAME   (1<<4)
#define TX_RX_STS_ERROR_FRAME   (1<<3)
#define TX_RX_STS_CRC   (1<<2)
#define TX_RX_STS_PAUSE_FRAME   (1<<1)
#define TX_RX_STS_TX_IDLE   (1<<0)
#define LM32_TSMAC_GMII_MNG_CTL_BYTE0   (0x014)
#define GMII_MNG_CTL_CMD_FIN   (1<<14)
#define GMII_MNG_CTL_READ_PHYREG   (0)
#define GMII_MNG_CTL_WRITE_PHYREG   (1<<13)
#define GMII_MNG_CTL_PHY_ADD_MASK   (0x001f)
#define GMII_MNG_CTL_PHY_ADD_SHIFT   (8)
#define GMII_MNG_CTL_REG_ADD_MASK   (0x001f)
#define GMII_MNG_CTL_REG_ADD_SHIFT   (0)
#define LM32_TSMAC_GMII_MNG_DAT_BYTE0   (0x016)
#define LM32_TSMAC_MLT_TAB_0_BYTE0   (0x022)
#define LM32_TSMAC_MLT_TAB_1_BYTE0   (0x024)
#define LM32_TSMAC_MLT_TAB_2_BYTE0   (0x026)
#define LM32_TSMAC_MLT_TAB_3_BYTE0   (0x028)
#define LM32_TSMAC_MLT_TAB_4_BYTE0   (0x02A)
#define LM32_TSMAC_MLT_TAB_5_BYTE0   (0x02C)
#define LM32_TSMAC_MLT_TAB_6_BYTE0   (0x02E)
#define LM32_TSMAC_MLT_TAB_7_BYTE0   (0x030)
#define LM32_TSMAC_VLAN_TAG_BYTE0   (0x032)
#define LM32_TSMAC_PAUS_OP_BYTE0   (0x034)
#define LM32_TSMAC_RX_PKT_IGNR_CNT   (0x300)
#define LM32_TSMAC_RX_LEN_CHK_ERR_CNT   (0x304)
#define LM32_TSMAC_RX_LNG_FRM_CNT   (0x308)
#define LM32_TSMAC_RX_SHRT_FRM_CNT   (0x30C)
#define LM32_TSMAC_RX_IPG_VIOL_CNT   (0x310)
#define LM32_TSMAC_RX_CRC_ERR_CNT   (0x314)
#define LM32_TSMAC_RX_OK_PKT_CNT   (0x318)
#define LM32_TSMAC_RX_CTL_FRM_CNT   (0x31C)
#define LM32_TSMAC_RX_PAUSE_FRM_CNT   (0x320)
#define LM32_TSMAC_RX_MULTICAST_CNT   (0x324)
#define LM32_TSMAC_RX_BRDCAST_CNT   (0x328)
#define LM32_TSMAC_RX_VLAN_TAG_CNT   (0x32C)
#define LM32_TSMAC_RX_PRE_SHRINK_CNT   (0x330)
#define LM32_TSMAC_RX_DRIB_NIB_CNT   (0x334)
#define LM32_TSMAC_RX_UNSUP_OPCD_CNT   (0x338)
#define LM32_TSMAC_RX_BYTE_CNT   (0x33C)
#define LM32_TSMAC_TX_UNICAST_CNT   (0x400)
#define LM32_TSMAC_TX_PAUSE_FRM_CNT   (0x404)
#define LM32_TSMAC_TX_MULTICAST_CNT   (0x408)
#define LM32_TSMAC_TX_BRDCAST_CNT   (0x40C)
#define LM32_TSMAC_TX_VLAN_TAG_CNT   (0x410)
#define LM32_TSMAC_TX_BAD_FCS_CNT   (0x414)
#define LM32_TSMAC_TX_JUMBO_CNT   (0x418)
#define LM32_TSMAC_TX_BYTE_CNT   (0x41C)
