RTEMS 5.2
LatticeMico32 TSMAC (Tri-Speed MAC) definitions. More...
#define DEFAULT_PHY_ADDRESS   (0x01)
#define PHY_BMCR   (0x00)
#define PHY_BMCR_RESET   (1<<15)
#define PHY_BMCR_LOOPBACK   (1<<14)
#define PHY_BMCR_SPEEDSEL   (1<<13)
#define PHY_BMCR_AN_ENA   (1<<12)
#define PHY_BMCR_PWRDWN   (1<<11)
#define PHY_BMCR_ISOLATE   (1<<10)
#define PHY_BMCR_RESTART_AN   (1<<9)
#define PHY_BMCR_DUPLEX_MODE   (1<<8)
#define PHY_BMCR_COLL_TEST   (1<<7)
#define PHY_BMSR   (0x01)
#define PHY_BMSR_100_T4   (1<<15)
#define PHY_BMSR_100_TX_FD   (1<<14)
#define PHY_BMSR_100_TX_HD   (1<<13)
#define PHY_BMSR_10_T_FD   (1<<12)
#define PHY_BMSR_10_T_HD   (1<<11)
#define PHY_BMSR_PRESUP   (1<<6)
#define PHY_BMSR_AN_CMPL   (1<<5)
#define PHY_BMSR_REM_FLT   (1<<4)
#define PHY_BMSR_AN_AB   (1<<3)
#define PHY_BMSR_LINK_STAT   (1<<2)
#define PHY_BMSR_JABBDET   (1<<1)
#define PHY_BMSR_EXT_CAP   (1<<0)
#define PHY_PHYIDR1   (0x02)
#define DEFAULT_PHYIDR1   (0x2000)
#define PHY_PHYIDR2   (0x03)
#define DEFAULT_PHYIDR2   (0x5C90)
#define PHY_ANAR   (0x04)
#define PHY_ANAR_NP   (1<<15)
#define PHY_ANAR_RF   (1<<13)
#define PHY_ANAR_ASM_DIR   (1<<11)
#define PHY_ANAR_PAUSE   (1<<10)
#define PHY_ANAR_T4   (1<<9)
#define PHY_ANAR_TX_FD   (1<<8)
#define PHY_ANAR_TX   (1<<7)
#define PHY_ANAR_10_FD   (1<<6)
#define PHY_ANAR_10   (1<<5)
#define PHY_ANAR_SEL_MASK   (0x0f)
#define PHY_ANAR_SEL_SHIFT   (0)
#define PHY_ANAR_SEL_DEF   (1)
#define PHY_ANLPAR   (0x05)
#define PHY_ANLPAR_NP   (1<<15)
#define PHY_ANLPAR_ACK   (1<<14)
#define PHY_ANLPAR_RF   (1<<13)
#define PHY_ANLPAR_ASM_DIR   (1<<11)
#define PHY_ANLPAR_PAUSE   (1<<10)
#define PHY_ANLPAR_T4   (1<<9)
#define PHY_ANLPAR_TX_FD   (1<<8)
#define PHY_ANLPAR_TX   (1<<7)
#define PHY_ANLPAR_10_FD   (1<<6)
#define PHY_ANLPAR_10   (1<<5)
#define PHY_ANLPAR_SEL_MASK   (0x0f)
#define PHY_ANLPAR_SEL_SHIFT   (0)
#define PHY_ANLPARNP   (0x05)
#define PHY_ANLPARNP_NP   (1<<15)
#define PHY_ANLPARNP_ACK   (1<<14)
#define PHY_ANLPARNP_MP   (1<<13)
#define PHY_ANLPARNP_ACK2   (1<<12)
#define PHY_ANLPARNP_TOGGLE   (1<<11)
#define PHY_ANLPARNP_CDE_MASK   (0x03ff)
#define PHY_ANER   (0x06)
#define PHY_ANER_PDF   (1<<4)
#define PHY_ANER_LP_NP_ABLE   (1<<3)
#define PHY_ANER_NP_ABLE   (1<<2)
#define PHY_ANER_PAGE_RX   (1<<1)
#define PHY_ANER_LP_AN_ABLE   (1<<0)
#define PHY_ANNPTR   (0x07)
#define PHY_ANNPTR_NP   (1<<15)
#define PHY_ANNPTR_MP   (1<<13)
#define PHY_ANNPTR_ACK2   (1<<12)
#define PHY_ANNPTR_TOG_TX   (1<<11)
#define PHY_ANNPTR_CDE_MASK   (0x03ff)
#define PHY_PHYSTS   (0x10)
#define PHY_PHYSTS_MDIX_MDE   (1<<14)
#define PHY_PHYSTS_RCV_ERRL   (1<<13)
#define PHY_PHYSTS_POLSTAT   (1<<12)
#define PHY_PHYSTS_FCSL   (1<<11)
#define PHY_PHYSTS_SD   (1<<10)
#define PHY_PHYSTS_DESCL   (1<<9)
#define PHY_PHYSTS_PGREC   (1<<8)
#define PHY_PHYSTS_MIIIRQ   (1<<7)
#define PHY_PHYSTS_REM_FLT   (1<<6)
#define PHY_PHYSTS_JABBDET   (1<<5)
#define PHY_PHYSTS_AN_CMP   (1<<4)
#define PHY_PHYSTS_LOOPBACK   (1<<3)
#define PHY_PHYSTS_DUPLEX   (1<<2)
#define PHY_PHYSTS_SPEED   (1<<1)
#define PHY_PHYSTS_LINK   (1<<0)
#define PHY_MICR   (0x11)
#define PHY_MICR_TINT   (1<<2)
#define PHY_MICR_INTEN   (1<<1)
#define PHY_MICR_INT_OE   (1<<0)
#define PHY_MISR   (0x12)
#define PHY_MISR_ED_INT   (1<<14)
#define PHY_MISR_LINK_INT   (1<<13)
#define PHY_MISR_SPD_INT   (1<<12)
#define PHY_MISR_DUP_INT   (1<<11)
#define PHY_MISR_ANC_INT   (1<<10)
#define PHY_MISR_FHF_INT   (1<<9)
#define PHY_MISR_RHF_INT   (1<<8)
#define PHY_MISR_ED_INT_EN   (1<<6)
#define PHY_MISR_LINK_INT_EN   (1<<5)
#define PHY_MISR_SPD_INT_EN   (1<<4)
#define PHY_MISR_DUP_INT_EN   (1<<3)
#define PHY_MISR_ANC_INT_EN   (1<<2)
#define PHY_MISR_FHF_INT_EN   (1<<1)
#define PHY_MISR_RHF_INT_EN   (1<<0)
#define PHY_FCSCR   (0x14)
#define PHY_RECR   (0x15)
#define PHY_PCSR   (0x16)
#define PHY_PCSR_TQ_EN   (1<<10)
#define PHY_PCSR_SDFPMA   (1<<9)
#define PHY_PCSR_SD_OPT   (1<<8)
#define PHY_PCSR_DESC_TIME   (1<<7)
#define PHY_PCSR_F_100_OK   (1<<5)
#define PHY_PCSR_NRZI_BYPASS   (1<<2)
#define PHY_RBR   (0x17)
#define PHY_RBR_RMII_MODE   (1<<5)
#define PHY_RBR_RMII_REV1_0   (1<<4)
#define PHY_RBR_RX_OVF_STS   (1<<3)
#define PHY_RBR_RX_UNF_STS   (1<<2)
#define PHY_RBR_ELAST_BUF1   (1<<1)
#define PHY_RBR_ELAST_BUF0   (1<<0)
#define PHY_LEDCR   (0x18)
#define PHY_LEDCR_DRV_SPDLED   (1<<5)
#define PHY_LEDCR_DRV_LNKLED   (1<<4)
#define PHY_LEDCR_DRV_ACTLED   (1<<3)
#define PHY_LEDCR_SPDLED   (1<<2)
#define PHY_LEDCR_LNKLED   (1<<1)
#define PHY_LEDCR_ACTLED   (1<<0)
#define PHY_PHYCR   (0x19)
#define PHY_PHYCR_MDIX_EN   (1<<15)
#define PHY_PHYCR_FORCE_MDIX   (1<<14)
#define PHY_PHYCR_PAUSE_RX   (1<<13)
#define PHY_PHYCR_PAUSE_TX   (1<<12)
#define PHY_PHYCR_BIST_FE   (1<<11)
#define PHY_PHYCR_PSR_15   (1<<10)
#define PHY_PHYCR_BIST_STATUS   (1<<9)
#define PHY_PHYCR_BIST_START   (1<<8)
#define PHY_PHYCR_BP_STRETCH   (1<<7)
#define PHY_PHYCR_LED_CNFG1   (1<<6)
#define PHY_PHYCR_LED_CNFG0   (1<<5)
#define PHY_PHYCR_ADDR4   (1<<4)
#define PHY_PHYCR_ADDR3   (1<<3)
#define PHY_PHYCR_ADDR2   (1<<2)
#define PHY_PHYCR_ADDR1   (1<<1)
#define PHY_PHYCR_ADDR0   (1<<0)
#define PHY_10BTSCR   (0x1A)
#define PHY_10BTSCR_SERIAL   (1<<15)
#define PHY_10BTSCR_SQ_MASK   (0x07)
#define PHY_10BTSCR_SQ_SHIFT   (9)
#define PHY_10BTSCR_LP_10_DIS   (1<<8)
#define PHY_10BTSCR_LP_DIS   (1<<7)
#define PHY_10BTSCR_FLINK_10   (1<<1)
#define PHY_10BTSCR_POL   (1<<4)
#define PHY_10BTSCR_HB_DIS   (1<<1)
#define PHY_10BTSCR_JAB_DIS   (1<<0)
#define PHY_CDCTRL1   (0x1B)
#define PHY_EDCR   (0x1D)
