RTEMS 5.2
Definition of the interface between the stub and gdb,. More...
Files | |
| file | gdb_if.h |
| definition of the interface between the stub and gdb | |
| struct | rtems_gdb_stub_thread_info |
Enumerations | |
| enum | lm32_regnames { LM32_REG_R0 , LM32_REG_R1 , LM32_REG_R2 , LM32_REG_R3 , LM32_REG_R4 , LM32_REG_R5 , LM32_REG_R6 , LM32_REG_R7 , LM32_REG_R8 , LM32_REG_R9 , LM32_REG_R10 , LM32_REG_R11 , LM32_REG_R12 , LM32_REG_R13 , LM32_REG_R14 , LM32_REG_R15 , LM32_REG_R16 , LM32_REG_R17 , LM32_REG_R18 , LM32_REG_R19 , LM32_REG_R20 , LM32_REG_R21 , LM32_REG_R22 , LM32_REG_R23 , LM32_REG_R24 , LM32_REG_R25 , LM32_REG_GP , LM32_REG_FP , LM32_REG_SP , LM32_REG_RA , LM32_REG_EA , LM32_REG_BA , LM32_REG_PC , LM32_REG_EID , LM32_REG_EBA , LM32_REG_DEBA , LM32_REG_IE , NUM_REGS } |
| This numbering must be consistant with GDBs numbering in gdb/lm32-tdep.c. | |
| enum | lm32_int_regnames { LM32_INT_REG_R1 , LM32_INT_REG_R2 , LM32_INT_REG_R3 , LM32_INT_REG_R4 , LM32_INT_REG_R5 , LM32_INT_REG_R6 , LM32_INT_REG_R7 , LM32_INT_REG_R8 , LM32_INT_REG_R9 , LM32_INT_REG_R10 , LM32_INT_REG_RA , LM32_INT_REG_EA , LM32_INT_REG_BA , LM32_INT_REG_R11 , LM32_INT_REG_R12 , LM32_INT_REG_R13 , LM32_INT_REG_R14 , LM32_INT_REG_R15 , LM32_INT_REG_R16 , LM32_INT_REG_R17 , LM32_INT_REG_R18 , LM32_INT_REG_R19 , LM32_INT_REG_R20 , LM32_INT_REG_R21 , LM32_INT_REG_R22 , LM32_INT_REG_R23 , LM32_INT_REG_R24 , LM32_INT_REG_R25 , LM32_INT_REG_GP , LM32_INT_REG_FP , LM32_INT_REG_SP , LM32_INT_REG_PC , LM32_INT_REG_EID , LM32_INT_REG_EBA , LM32_INT_REG_DEBA , LM32_INT_REG_IE } |
| int | parse_zbreak (const char *in, int *type, unsigned char **addr, int *len) |
| char * | mem2hstr (char *buf, const unsigned char *mem, int count) |
| int | hstr2mem (unsigned char *mem, const char *buf, int count) |
| void | set_mem_err (void) |
| unsigned char | get_byte (const unsigned char *ptr) |
| void | set_byte (unsigned char *ptr, int val) |
| char * | thread2vhstr (char *buf, int thread) |
| char * | thread2fhstr (char *buf, int thread) |
| const char * | fhstr2thread (const char *buf, int *thread) |
| const char * | vhstr2thread (const char *buf, int *thread) |
| char * | int2fhstr (char *buf, int val) |
| char * | int2vhstr (char *buf, int vali) |
| const char * | fhstr2int (const char *buf, int *ival) |
| const char * | vhstr2int (const char *buf, int *ival) |
| int | hstr2byte (const char *buf, int *bval) |
| int | hstr2nibble (const char *buf, int *nibble) |
| Thread_Control * | rtems_gdb_index_to_stub_id (int) |
| int | rtems_gdb_stub_thread_support_ok (void) |
| int | rtems_gdb_stub_get_current_thread (void) |
| int | rtems_gdb_stub_get_next_thread (int) |
| int | rtems_gdb_stub_get_offsets (unsigned char **text_addr, unsigned char **data_addr, unsigned char **bss_addr) |
| int | rtems_gdb_stub_get_thread_regs (int thread, unsigned int *registers) |
| int | rtems_gdb_stub_set_thread_regs (int thread, unsigned int *registers) |
| void | rtems_gdb_process_query (char *inbuffer, char *outbuffer, int do_threads, int thread) |
