RTEMS 5.2
Modules | Data Structures | Macros | Enumerator | Functions | Variables
 GMAC Data Structs
union  _GmacRxDescriptor::_GmacRxAddr
struct  _GmacRxDescriptor::_GmacRxAddr::_GmacRxAddrBM
union  _GmacRxDescriptor::_GmacRxStatus
struct  _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM
union  _GmacTxDescriptor::_GmacTxStatus
struct  _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM
#define NUM_GMAC_QUEUES   3
#define GMAC_DUPLEX_HALF   0
 Board GMAC base address.
#define GMAC_DUPLEX_FULL   1
#define GMAC_SPEED_10M   0
#define GMAC_SPEED_100M   1
#define GMAC_SPEED_1000M   2
#define GMAC_ADDRESS_MASK   ((unsigned int)0xFFFFFFFC)
#define GMAC_LENGTH_FRAME   ((unsigned int)0x3FFF)
#define GMAC_RX_OWNERSHIP_BIT   (1u << 0)
#define GMAC_RX_WRAP_BIT   (1u << 1)
#define GMAC_RX_SOF_BIT   (1u << 14)
#define GMAC_RX_EOF_BIT   (1u << 15)
#define GMAC_TX_LAST_BUFFER_BIT   (1u << 15)
#define GMAC_TX_WRAP_BIT   (1u << 30)
#define GMAC_TX_USED_BIT   (1u << 31)
#define GMAC_TX_RLE_BIT   (1u << 29)
#define GMAC_TX_UND_BIT   (1u << 28)
#define GMAC_TX_ERR_BIT   (1u << 27)
#define GMAC_TX_ERR_BITS    (GMAC_TX_RLE_BIT | GMAC_TX_UND_BIT | GMAC_TX_ERR_BIT)
#define GMAC_INT_RX_BITS    (GMAC_IER_RCOMP | GMAC_IER_RXUBR | GMAC_IER_ROVR)
#define GMAC_INT_TX_ERR_BITS    (GMAC_IER_TUR | GMAC_IER_RLEX | GMAC_IER_TFC | GMAC_IER_HRESP)
#define GMAC_INT_TX_BITS    (GMAC_INT_TX_ERR_BITS | GMAC_IER_TCOMP)
#define GMAC_INT_RX_STATUS_BITS    (GMAC_ISR_RCOMP | GMAC_ISR_RXUBR | GMAC_ISR_ROVR)
#define GMAC_INT_TX_STATUS_ERR_BITS    (GMAC_ISR_TUR | GMAC_ISR_RLEX | GMAC_ISR_TFC | GMAC_ISR_HRESP)
#define GMAC_RXDESC_ST_CKSUM_RESULT_NOT_CHECKED   (0)
#define GMAC_RXDESC_ST_CKSUM_RESULT_IP_CHECKED   (1)
#define GMAC_RXDESC_ST_CKSUM_RESULT_IP_AND_TCP_CHECKED   (2)
#define GMAC_RXDESC_ST_CKSUM_RESULT_IP_AND_UDP_CHECKED   (3)
uint8_t GMAC_IsIdle (Gmac *pGmac)
void GMAC_PHYMaintain (Gmac *pGmac, uint8_t bPhyAddr, uint8_t bRegAddr, uint8_t bRW, uint16_t wData)
uint16_t GMAC_PHYData (Gmac *pGmac)
void GMAC_ClearStatistics (Gmac *pGmac)
void GMAC_IncreaseStatistics (Gmac *pGmac)
void GMAC_StatisticsWriteEnable (Gmac *pGmac, uint8_t bEnaDis)
uint8_t GMAC_SetMdcClock (Gmac *pGmac, uint32_t mck)
 Set MDC clock according to current board clock. Per 802.3, MDC should be less then 2.5MHz. More...
void GMAC_EnableMdio (Gmac *pGmac)
 Enable MDI with PHY. More...
void GMAC_DisableMdio (Gmac *pGmac)
void GMAC_EnableMII (Gmac *pGmac)
 Enable MII mode for GMAC, called once after auto negotiate. More...
void GMAC_EnableRMII (Gmac *pGmac)
void GMAC_EnableGMII (Gmac *pGmac)
 Enable GMII mode for GMAC, called once after auto negotiate. More...
void GMAC_SetLinkSpeed (Gmac *pGmac, uint8_t speed, uint8_t fullduplex)
 Setup the GMAC for the link : speed 100M/10M and Full/Half duplex. More...
void GMAC_EnableIt (Gmac *pGmac, uint32_t dwSources, gmacQueList_t queueIdx)
void GMAC_EnableAllQueueIt (Gmac *pGmac, uint32_t dwSources)
void GMAC_DisableIt (Gmac *pGmac, uint32_t dwSources, gmacQueList_t queueIdx)
void GMAC_DisableAllQueueIt (Gmac *pGmac, uint32_t dwSources)
uint32_t GMAC_GetItStatus (Gmac *pGmac, gmacQueList_t queueIdx)
uint32_t GMAC_GetItMask (Gmac *pGmac, gmacQueList_t queueIdx)
uint32_t GMAC_GetTxStatus (Gmac *pGmac)
void GMAC_ClearTxStatus (Gmac *pGmac, uint32_t dwStatus)
uint32_t GMAC_GetRxStatus (Gmac *pGmac)
void GMAC_ClearRxStatus (Gmac *pGmac, uint32_t dwStatus)
void GMAC_ReceiveEnable (Gmac *pGmac, uint8_t bEnaDis)
void GMAC_TransmitEnable (Gmac *pGmac, uint8_t bEnaDis)
uint32_t GMAC_SetLocalLoopBack (Gmac *pGmac)
 set local loop back More...
void GMAC_SetRxQueue (Gmac *pGmac, uint32_t dwAddr, gmacQueList_t queueIdx)
uint32_t GMAC_GetRxQueue (Gmac *pGmac, gmacQueList_t queueIdx)
void GMAC_SetTxQueue (Gmac *pGmac, uint32_t dwAddr, gmacQueList_t queueIdx)
uint32_t GMAC_GetTxQueue (Gmac *pGmac, gmacQueList_t queueIdx)
void GMAC_NetworkControl (Gmac *pGmac, uint32_t bmNCR)
uint32_t GMAC_GetNetworkControl (Gmac *pGmac)
void GMAC_SetAddress (Gmac *pGmac, uint8_t bIndex, uint8_t *pMacAddr)
void GMAC_SetAddress32 (Gmac *pGmac, uint8_t bIndex, uint32_t dwMacT, uint32_t dwMacB)
void GMAC_SetAddress64 (Gmac *pGmac, uint8_t bIndex, uint64_t ddwMac)
void GMAC_Configure (Gmac *pGmac, uint32_t dwCfg)
void GMAC_SetDMAConfig (Gmac *pGmac, uint32_t dwDmaCfg, gmacQueList_t queueIdx)
uint32_t GMAC_GetDMAConfig (Gmac *pGmac, gmacQueList_t queueIdx)
uint32_t GMAC_GetConfigure (Gmac *pGmac)
void GMAC_TransmissionStart (Gmac *pGmac)
void GMAC_TransmissionHalt (Gmac *pGmac)
void GMAC_EnableRGMII (Gmac *pGmac, uint32_t duplex, uint32_t speed)
 Enable RGMII mode for GMAC, called once after auto negotiate. More...
void GMAC_ClearScreener1Reg (Gmac *pGmac, gmacQueList_t queueIdx)
void GMAC_WriteScreener1Reg (Gmac *pGmac, gmacQueList_t queueIdx, uint32_t regVal)
void GMAC_ClearScreener2Reg (Gmac *pGmac, gmacQueList_t queueIdx)
void GMAC_WriteScreener2Reg (Gmac *pGmac, gmacQueList_t queueIdx, uint32_t regVal)
void GMAC_WriteEthTypeReg (Gmac *pGmac, gmacQueList_t queueIdx, uint16_t etherType)
void GMAC_WriteCompareReg (Gmac *pGmac, gmacQueList_t queueIdx, uint32_t c0Reg, uint16_t c1Reg)
void GMAC_EnableCbsQueA (Gmac *pGmac)
void GMAC_DisableCbsQueA (Gmac *pGmac)
void GMAC_EnableCbsQueB (Gmac *pGmac)
void GMAC_DisableCbsQueB (Gmac *pGmac)
void GMAC_ConfigIdleSlopeA (Gmac *pGmac, uint32_t idleSlopeA)
void GMAC_ConfigIdleSlopeB (Gmac *pGmac, uint32_t idleSlopeB)
void GMAC_SetTsuTmrIncReg (Gmac *pGmac, uint32_t nanoSec)
uint16_t GMAC_GetPtpEvtMsgRxdMsbSec (Gmac *pGmac)
uint32_t GMAC_GetPtpEvtMsgRxdLsbSec (Gmac *pGmac)
uint32_t GMAC_GetPtpEvtMsgRxdNanoSec (Gmac *pGmac)
void GMAC_SetTsuCompare (Gmac *pGmac, uint32_t seconds47, uint32_t seconds31, uint32_t nanosec)
void GMAC_SetTsuCompareNanoSec (Gmac *pGmac, uint32_t nanosec)
void GMAC_SetTsuCompareSec31 (Gmac *pGmac, uint32_t seconds31)
void GMAC_SetTsuCompareSec47 (Gmac *pGmac, uint16_t seconds47)
uint32_t GMAC_GetRxEvtFrameSec (Gmac *pGmac)
uint32_t GMAC_GetRxEvtFrameNsec (Gmac *pGmac)
uint32_t GMAC_GetRxPeerEvtFrameSec (Gmac *pGmac)
uint32_t GMAC_GetRxPeerEvtFrameNsec (Gmac *pGmac)
uint32_t GMAC_GetTxEvtFrameSec (Gmac *pGmac)
uint32_t GMAC_GetTxEvtFrameNsec (Gmac *pGmac)
uint32_t GMAC_GetTxPeerEvtFrameSec (Gmac *pGmac)
uint32_t GMAC_GetTxPeerEvtFrameNsec (Gmac *pGmac)
uint32_t _GmacRxDescriptor::_GmacRxAddr::val
uint32_t _GmacRxDescriptor::_GmacRxAddr::_GmacRxAddrBM::bOwnership: 1
uint32_t _GmacRxDescriptor::_GmacRxAddr::_GmacRxAddrBM::bWrap: 1
uint32_t _GmacRxDescriptor::_GmacRxAddr::_GmacRxAddrBM::addrDW: 30
struct _GmacRxDescriptor::_GmacRxAddr::_GmacRxAddrBM _GmacRxDescriptor::_GmacRxAddr::bm
union _GmacRxDescriptor::_GmacRxAddr _GmacRxDescriptor::addr
uint32_t _GmacRxDescriptor::_GmacRxStatus::val
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::len: 12
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::offset: 2
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::bSof: 1
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::bEof: 1
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::bCFI: 1
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::vlanPriority: 3
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::bPriorityDetected: 1
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::bVlanDetected: 1
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::typeIDMatchOrCksumResult: 2
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::bTypeIDMatchFoundOrCksumSNAPState: 1
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::specAddrMatchRegister: 2
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::bSpecAddrMatchFound: 1
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::reserved: 1
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::bUniHashMatch: 1
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::bMultiHashMatch: 1
uint32_t _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM::bBroadcastDetected: 1
struct _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM _GmacRxDescriptor::_GmacRxStatus::bm
union _GmacRxDescriptor::_GmacRxStatus _GmacRxDescriptor::status
uint32_t _GmacTxDescriptor::addr
uint32_t _GmacTxDescriptor::_GmacTxStatus::val
uint32_t _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM::len: 11
uint32_t _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM::reserved: 4
uint32_t _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM::bLastBuffer: 1
uint32_t _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM::bNoCRC: 1
uint32_t _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM::reserved1: 10
uint32_t _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM::bExhausted: 1
uint32_t _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM::bUnderrun: 1
uint32_t _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM::bError: 1
uint32_t _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM::bWrap: 1
uint32_t _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM::bUsed: 1
struct _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM _GmacTxDescriptor::_GmacTxStatus::bm
union _GmacTxDescriptor::_GmacTxStatus _GmacTxDescriptor::status
◆ GMAC_ADDRESS_MASK
The buffer addresses written into the descriptors must be aligned so the last few bits are zero. These bits have special meaning for the GMAC peripheral and cannot be used as part of the address.
◆ GMAC_ClearRxStatus()
void GMAC_ClearRxStatus ( Gmac pGmac,
uint32_t  dwStatus
Clear receive status
◆ GMAC_ClearStatistics()
void GMAC_ClearStatistics ( Gmac pGmac)
Clear all statistics registers
◆ GMAC_ClearTxStatus()
void GMAC_ClearTxStatus ( Gmac pGmac,
uint32_t  dwStatus
Clear transmit status
◆ GMAC_Configure()
void GMAC_Configure ( Gmac pGmac,
uint32_t  dwCfg
Setup network configuration register
◆ GMAC_DisableAllQueueIt()
void GMAC_DisableAllQueueIt ( Gmac pGmac,
uint32_t  dwSources
Disable interrupt(s).
◆ GMAC_DisableIt()
void GMAC_DisableIt ( Gmac pGmac,
uint32_t  dwSources,
◆ GMAC_DisableMdio()
void GMAC_DisableMdio ( Gmac pGmac)
Parameters
pGmacPointer to an Gmac instance.
◆ GMAC_EnableAllQueueIt()
void GMAC_EnableAllQueueIt ( Gmac pGmac,
uint32_t  dwSources
◆ GMAC_EnableGMII()
void GMAC_EnableGMII ( Gmac pGmac)
Parameters
◆ GMAC_EnableIt()
void GMAC_EnableIt ( Gmac pGmac,
uint32_t  dwSources,
Enable interrupt(s).
◆ GMAC_EnableMdio()
void GMAC_EnableMdio ( Gmac pGmac)
Parameters
◆ GMAC_EnableMII()
void GMAC_EnableMII ( Gmac pGmac)
Parameters
◆ GMAC_EnableRGMII()
void GMAC_EnableRGMII ( Gmac pGmac,
uint32_t  duplex,
uint32_t  speed
Parameters
duplex1 full duplex 0 half duplex
speed0 10M 1 100M
◆ GMAC_GetConfigure()
uint32_t GMAC_GetConfigure ( Gmac pGmac)
Return network configuration.
◆ GMAC_GetDMAConfig()
uint32_t GMAC_GetDMAConfig ( Gmac pGmac,
Return DMA configuration register
◆ GMAC_GetItMask()
uint32_t GMAC_GetItMask ( Gmac pGmac,
Return interrupt mask.
◆ GMAC_GetItStatus()
uint32_t GMAC_GetItStatus ( Gmac pGmac,
Return interrupt status.
◆ GMAC_GetNetworkControl()
uint32_t GMAC_GetNetworkControl ( Gmac pGmac)
Get control value
◆ GMAC_GetRxQueue()
uint32_t GMAC_GetRxQueue ( Gmac pGmac,
Get Rx Queue Address
◆ GMAC_GetRxStatus()
uint32_t GMAC_GetRxStatus ( Gmac pGmac)
Return receive status
◆ GMAC_GetTxQueue()
uint32_t GMAC_GetTxQueue ( Gmac pGmac,
Get Tx Queue
◆ GMAC_GetTxStatus()
uint32_t GMAC_GetTxStatus ( Gmac pGmac)
Return transmit status
◆ GMAC_IncreaseStatistics()
void GMAC_IncreaseStatistics ( Gmac pGmac)
Increase all statistics registers
◆ GMAC_IsIdle()
uint8_t GMAC_IsIdle ( Gmac pGmac)
Return 1 if PHY is idle
◆ GMAC_NetworkControl()
void GMAC_NetworkControl ( Gmac pGmac,
uint32_t  bmNCR
Write control value
◆ GMAC_PHYData()
uint16_t GMAC_PHYData ( Gmac pGmac)
Return PHY maintenance data returned
◆ GMAC_PHYMaintain()
void GMAC_PHYMaintain ( Gmac pGmac,
uint8_t  bPhyAddr,
uint8_t  bRegAddr,
uint8_t  bRW,
uint16_t  wData
Execute PHY maintenance command
◆ GMAC_ReceiveEnable()
void GMAC_ReceiveEnable ( Gmac pGmac,
uint8_t  bEnaDis
Enable/Disable GMAC receive.
◆ GMAC_SetAddress()
void GMAC_SetAddress ( Gmac pGmac,
uint8_t  bIndex,
uint8_t *  pMacAddr
Set MAC Address
◆ GMAC_SetAddress32()
void GMAC_SetAddress32 ( Gmac pGmac,
uint8_t  bIndex,
uint32_t  dwMacT,
uint32_t  dwMacB
Set MAC Address via 2 DW
◆ GMAC_SetAddress64()
void GMAC_SetAddress64 ( Gmac pGmac,
uint8_t  bIndex,
uint64_t  ddwMac
Set MAC Address via int64
◆ GMAC_SetDMAConfig()
void GMAC_SetDMAConfig ( Gmac pGmac,
uint32_t  dwDmaCfg,
Setup DMA configuration register
◆ GMAC_SetLinkSpeed()
void GMAC_SetLinkSpeed ( Gmac pGmac,
uint8_t  speed,
uint8_t  fullduplex
Parameters
speedLink speed, 0 for 10M, 1 for 100M
fullduplex1 for Full Duplex mode
◆ GMAC_SetLocalLoopBack()
uint32_t GMAC_SetLocalLoopBack ( Gmac pGmac)
set local loop back
Parameters
◆ GMAC_SetMdcClock()
uint8_t GMAC_SetMdcClock ( Gmac pGmac,
uint32_t  mck
Parameters
mckMdc clock
Returns
1 if successfully, 0 if MDC clock not found.
◆ GMAC_SetRxQueue()
void GMAC_SetRxQueue ( Gmac pGmac,
uint32_t  dwAddr,
Set Rx Queue
◆ GMAC_SetTxQueue()
void GMAC_SetTxQueue ( Gmac pGmac,
uint32_t  dwAddr,
Set Tx Queue
◆ GMAC_StatisticsWriteEnable()
void GMAC_StatisticsWriteEnable ( Gmac pGmac,
uint8_t  bEnaDis
Enable/Disable statistics registers writing.
◆ GMAC_TransmissionHalt()
void GMAC_TransmissionHalt ( Gmac pGmac)
Halt transmission
◆ GMAC_TransmissionStart()
void GMAC_TransmissionStart ( Gmac pGmac)
Start transmission
◆ GMAC_TransmitEnable()
void GMAC_TransmitEnable ( Gmac pGmac,
uint8_t  bEnaDis
Enable/Disable GMAC transmit.
Variable Documentation
◆ addr
Address, Wrap & Ownership
◆ addrDW
Address in number of DW
◆ bBroadcastDetected
Global all ones broadcast address detected
◆ bCFI
End of frame
◆ bEof
Start of frame
◆ bError
Retry limit exceeded, error detected
◆ bExhausted
Buffer exhausted in mid frame
◆ bLastBuffer
Last buffer (in the current frame)
◆ bMultiHashMatch
Multicast hash match
◆ bNoCRC
No CRC
◆ bOwnership
User clear, GMAC set this to one once it has successfully written a frame to memory
◆ bPriorityDetected
VLAN priority (if VLAN detected)
◆ bSof
Receive buffer offset, bits 13:12 of frame length for jumbo frame
◆ bUnderrun
Transmit under run
◆ bUniHashMatch
Unicast hash match
◆ bUsed
User clear, GMAC sets this once a frame has been successfully transmitted
◆ bVlanDetected
Priority tag detected VLAN tag detected
◆ bWrap [1/2]
Marks last descriptor in receive buffer
◆ bWrap [2/2]
Marks last descriptor in TD list
◆ len
Length of buffer
◆ offset
Length of frame including FCS
◆ vlanPriority
Concatenation Format Indicator
