RTEMS 5.2
Files | Data Structures | Macros | Functions
EDF Priority SMP Scheduler
EDF Priority SMP Scheduler. More...
file  scheduleredfsmp.h
 EDF SMP Scheduler API.
file  scheduleredfsmp.c
 EDF SMP Scheduler Implementation.
struct  Scheduler_EDF_SMP_Node
struct  Scheduler_EDF_SMP_Ready_queue
struct  Scheduler_EDF_SMP_Context
#define SCHEDULER_EDF_SMP_ENTRY_POINTS
void _Scheduler_EDF_SMP_Initialize (const Scheduler_Control *scheduler)
 Initializes the context of the scheduler control. More...
void _Scheduler_EDF_SMP_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
 Initializes the node with the given priority. More...
void _Scheduler_EDF_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Blocks the thread. More...
void _Scheduler_EDF_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Unblocks the thread. More...
void _Scheduler_EDF_SMP_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Updates the priority of the node. More...
bool _Scheduler_EDF_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Asks for help operation. More...
void _Scheduler_EDF_SMP_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Reconsiders help operation. More...
void _Scheduler_EDF_SMP_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
 Withdraws node operation. More...
void _Scheduler_EDF_SMP_Pin (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, struct Per_CPU_Control *cpu)
 Pin thread operation. More...
void _Scheduler_EDF_SMP_Unpin (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, struct Per_CPU_Control *cpu)
 Unpin thread operation. More...
void _Scheduler_EDF_SMP_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle)
 Adds processor. More...
Thread_Control_Scheduler_EDF_SMP_Remove_processor (const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu)
 Removes an idle thread from the given cpu. More...
void _Scheduler_EDF_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Performs the yield of a thread. More...
void _Scheduler_EDF_SMP_Start_idle (const Scheduler_Control *scheduler, Thread_Control *idle, struct Per_CPU_Control *cpu)
 Starts an idle thread. More...
bool _Scheduler_EDF_SMP_Set_affinity (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node, const Processor_mask *affinity)
 Checks if the processor set of the scheduler is the subset of the affinity set. More...
◆ SCHEDULER_EDF_SMP_ENTRY_POINTS
Value:
_Scheduler_EDF_SMP_Initialize, \
_Scheduler_default_Schedule, \
_Scheduler_EDF_SMP_Yield, \
_Scheduler_EDF_SMP_Block, \
_Scheduler_EDF_SMP_Unblock, \
_Scheduler_EDF_SMP_Update_priority, \
_Scheduler_EDF_Map_priority, \
_Scheduler_EDF_Unmap_priority, \
_Scheduler_EDF_SMP_Ask_for_help, \
_Scheduler_EDF_SMP_Reconsider_help_request, \
_Scheduler_EDF_SMP_Withdraw_node, \
_Scheduler_EDF_SMP_Pin, \
_Scheduler_EDF_SMP_Unpin, \
_Scheduler_EDF_SMP_Add_processor, \
_Scheduler_EDF_SMP_Remove_processor, \
_Scheduler_EDF_SMP_Node_initialize, \
_Scheduler_default_Node_destroy, \
_Scheduler_EDF_Release_job, \
_Scheduler_EDF_Cancel_job, \
_Scheduler_default_Tick, \
_Scheduler_EDF_SMP_Start_idle, \
_Scheduler_EDF_SMP_Set_affinity \
◆ _Scheduler_EDF_SMP_Add_processor()
void _Scheduler_EDF_SMP_Add_processor ( const Scheduler_Control scheduler,
Thread_Control idle
Adds processor.
Parameters
[in,out]schedulerThe scheduler instance to add the processor to.
idleThe idle thread of the processor to add.
◆ _Scheduler_EDF_SMP_Ask_for_help()
bool _Scheduler_EDF_SMP_Ask_for_help ( const Scheduler_Control scheduler,
Thread_Control the_thread,
Scheduler_Node node
Parameters
schedulerThe scheduler instance to ask for help.
the_threadThe thread needing help.
nodeThe scheduler node.
Return values
trueAsk for help was successful.
falseAsk for help was not successful.
◆ _Scheduler_EDF_SMP_Block()
void _Scheduler_EDF_SMP_Block ( const Scheduler_Control scheduler,
Thread_Control thread,
Scheduler_Node node
Blocks the thread.
Parameters
schedulerThe scheduler instance.
[in,out]the_threadThe thread to block.
[in,out]nodeThe thread's scheduler node.
◆ _Scheduler_EDF_SMP_Initialize()
void _Scheduler_EDF_SMP_Initialize ( const Scheduler_Control scheduler)
Parameters
schedulerThe scheduler control.
◆ _Scheduler_EDF_SMP_Node_initialize()
void _Scheduler_EDF_SMP_Node_initialize ( const Scheduler_Control scheduler,
Scheduler_Node node,
Parameters
[out]nodeThe node to initialize.
the_threadThe thread of the scheduler node.
priorityThe priority for the initialization.
◆ _Scheduler_EDF_SMP_Pin()
void _Scheduler_EDF_SMP_Pin ( const Scheduler_Control scheduler,
struct Per_CPU_Control cpu
Parameters
schedulerThe scheduler instance of the specified processor.
the_threadThe thread to pin.
nodeThe scheduler node of the thread.
cpuThe processor to pin the thread.
◆ _Scheduler_EDF_SMP_Reconsider_help_request()
void _Scheduler_EDF_SMP_Reconsider_help_request ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
schedulerThe scheduler instance to reconsider the help request.
the_threadThe thread reconsidering a help request.
◆ _Scheduler_EDF_SMP_Remove_processor()
Thread_Control * _Scheduler_EDF_SMP_Remove_processor ( const Scheduler_Control scheduler,
Parameters
cpuThe cpu control to remove from scheduler.
Returns
The idle thread of the processor.
◆ _Scheduler_EDF_SMP_Set_affinity()
bool _Scheduler_EDF_SMP_Set_affinity ( const Scheduler_Control scheduler,
const Processor_mask *  affinity
Default implementation of the set affinity scheduler operation.
Parameters
schedulerThis parameter is unused.
threadThis parameter is unused.
nodeThis parameter is unused.
affinityThe new processor affinity set for the thread.
Return values
trueThe processor set of the scheduler is a subset of the affinity set.
falseThe processor set of the scheduler is not a subset of the affinity set.
◆ _Scheduler_EDF_SMP_Start_idle()
void _Scheduler_EDF_SMP_Start_idle ( const Scheduler_Control scheduler,
Thread_Control idle,
Parameters
[in,out]the_threadAn idle thread.
cpuThe cpu for the operation.
◆ _Scheduler_EDF_SMP_Unblock()
void _Scheduler_EDF_SMP_Unblock ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
[in,out]the_threadThe thread to unblock.
◆ _Scheduler_EDF_SMP_Unpin()
void _Scheduler_EDF_SMP_Unpin ( const Scheduler_Control scheduler,
Parameters
the_threadThe thread to unpin.
cpuThe processor to unpin the thread.
◆ _Scheduler_EDF_SMP_Update_priority()
void _Scheduler_EDF_SMP_Update_priority ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
the_threadThe thread for the operation.
◆ _Scheduler_EDF_SMP_Withdraw_node()
void _Scheduler_EDF_SMP_Withdraw_node ( const Scheduler_Control scheduler,
Parameters
schedulerThe scheduler instance to withdraw the node.
the_threadThe thread using the node.
nodeThe scheduler node to withdraw.
next_stateThe next thread scheduler state in case the node is scheduled.
◆ _Scheduler_EDF_SMP_Yield()
void _Scheduler_EDF_SMP_Yield ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
[in,out]the_threadThe thread that performed the yield operation.
nodeThe scheduler node of the_thread.
