The Freechain Handler.
More...
typedef void *(* | Freechain_Allocator) (size_t size) |
| | Allocator function.
| RTEMS_INLINE_ROUTINE void | _Freechain_Initialize (Freechain_Control *freechain, void *initial_nodes, size_t number_nodes, size_t node_size) |
| | Initializes a freechain. More...
| RTEMS_INLINE_ROUTINE bool | _Freechain_Is_empty (const Freechain_Control *freechain) |
| | Return true if the freechain is empty, otherwise false. More...
| RTEMS_INLINE_ROUTINE void * | _Freechain_Pop (Freechain_Control *freechain) |
| | Pop an item from the freechain. More...
| void * | _Freechain_Extend (Freechain_Control *freechain, Freechain_Allocator allocator, size_t number_nodes_to_extend, size_t node_size) |
| | Extend the freechain with new nodes. More...
| void * | _Freechain_Get (Freechain_Control *freechain, Freechain_Allocator allocator, size_t number_nodes_to_extend, size_t node_size) |
| | Gets a node from the freechain. More...
| void | _Freechain_Put (Freechain_Control *freechain, void *node) |
| | Puts a node back onto the freechain. More...
The Freechain Handler is used to manage a chain of nodes, of which size can automatically increase when there is no free node left. This handler provides one data structure: Freechain_Control.
◆ _Freechain_Extend()
- Parameters
| freechain | The freechain control. |
| allocator | The allocator function. |
| number_nodes_to_extend | The number of nodes to extend. |
| node_size | The node size. |
- Return values
| NULL | The extend operation failed. |
| nodes | Pointer to the new nodes. |
◆ _Freechain_Get()
- Parameters
| [in,out] | freechain | The freechain control. |
| number_nodes_to_extend | The number of nodes in the case an extend is necessary due to an empty freechain. |
| [in] | node_size | The node size. |
- Return values
| NULL | The freechain is empty and the extend operation failed. |
| pointer | Pointer to a node. The node ownership passes to the caller. |
◆ _Freechain_Initialize()
This routine initializes the freechain control structure to manage a chain of nodes. In the case the freechain is empty the extend handler is called to get more nodes.
- Parameters
| [out] | freechain | The freechain control to initialize. |
| [out] | initial_nodes | Array with the initial nodes. |
| number_nodes | The initial number of nodes. |
◆ _Freechain_Is_empty()
- Parameters
◆ _Freechain_Pop()
The freechain must not be empty.
- Parameters
◆ _Freechain_Put()
- Parameters
| [out] | node | The node to put back. The node may be NULL, in this case the function does nothing. |
