Functionality for Foundation Barrier Services.
More...
| void | _CORE_barrier_Initialize (CORE_barrier_Control *the_barrier, CORE_barrier_Attributes *the_barrier_attributes) |
| | Initializes the core barrier. More...
| RTEMS_INLINE_ROUTINE void | _CORE_barrier_Destroy (CORE_barrier_Control *the_barrier) |
| | Destroys the core barrier. More...
| RTEMS_INLINE_ROUTINE void | _CORE_barrier_Acquire_critical (CORE_barrier_Control *the_barrier, Thread_queue_Context *queue_context) |
| | Acquires critical core barrier. More...
| RTEMS_INLINE_ROUTINE void | _CORE_barrier_Release (CORE_barrier_Control *the_barrier, Thread_queue_Context *queue_context) |
| | Releases core barrier. More...
| Status_Control | _CORE_barrier_Seize (CORE_barrier_Control *the_barrier, Thread_Control *executing, bool wait, Thread_queue_Context *queue_context) |
| | Waits for the barrier. More...
| uint32_t | _CORE_barrier_Do_flush (CORE_barrier_Control *the_barrier, Thread_queue_Flush_filter filter, Thread_queue_Context *queue_context) |
| | Flushes the barrier. More...
| RTEMS_INLINE_ROUTINE uint32_t | _CORE_barrier_Surrender (CORE_barrier_Control *the_barrier, Thread_queue_Context *queue_context) |
| | Manually releases the barrier. More...
| RTEMS_INLINE_ROUTINE void | _CORE_barrier_Flush (CORE_barrier_Control *the_barrier, Thread_queue_Context *queue_context) |
| | Flushes the barrier using _CORE_barrier_Do_flush(). More...
| RTEMS_INLINE_ROUTINE bool | _CORE_barrier_Is_automatic (CORE_barrier_Attributes *the_attribute) |
| | Checks if the barrier is automatic. More...
| RTEMS_INLINE_ROUTINE uint32_t | _CORE_barrier_Get_number_of_waiting_threads (CORE_barrier_Control *the_barrier) |
| | Returns the number of currently waiting threads. More...
This handler encapsulates functionality which provides the foundation Barrier services used in all of the APIs supported by RTEMS.
◆ CORE_barrier_Disciplines
Flavors of barriers.
| Enumerator |
| CORE_BARRIER_AUTOMATIC_RELEASE | This specifies that the barrier will automatically release when the user specified number of threads have arrived at the barrier.
| CORE_BARRIER_MANUAL_RELEASE | This specifies that the user will have to manually release the barrier in order to release the waiting threads.
◆ _CORE_barrier_Acquire_critical()
- Parameters
| [in,out] | the_barrier | The barrier to acquire. |
| queue_context | The thread queue context. |
◆ _CORE_barrier_Destroy()
This routine destroys the barrier.
- Parameters
| [out] | the_barrier | The barrier to destroy. |
◆ _CORE_barrier_Do_flush()
- Parameters
| [in,out] | the_barrier | The barrier to flush. |
| [out] | filter | The filter for flushing. |
| [out] | queue_context | The thread queue context. |
◆ _CORE_barrier_Flush()
- Parameters
◆ _CORE_barrier_Get_number_of_waiting_threads()
This routine returns the number of threads currently waiting at the barrier.
- Parameters
| [in] | the_barrier | The barrier to obtain the number of blocked threads of. |
- Returns
- the current count of waiting threads of this barrier.
◆ _CORE_barrier_Initialize()
This routine initializes the barrier based on the parameters passed.
- Parameters
| [out] | the_barrier | The barrier to initialize. |
| [out] | the_barrier_attributes | The attributes which define the behavior of this instance. |
◆ _CORE_barrier_Is_automatic()
This function returns true if the automatic release attribute is enabled in the attribute_set and false otherwise.
- Parameters
| the_attribute | The attribute set to test. |
- Return values
| true | The automatic release attribute is enabled. |
| false | The automatic release attribute is not enabled. |
◆ _CORE_barrier_Release()
- Parameters
| [in,out] | the_barrier | The barrier to release. |
◆ _CORE_barrier_Seize()
This routine waits for the barrier to be released. If the barrier is set to automatic and this is the appropriate thread, then it returns immediately. Otherwise, the calling thread is blocked until the barrier is released.
- Parameters
| [in,out] | the_barrier | The barrier to wait for. |
| [in,out] | executing | The currently executing thread. |
| wait | This parameter is true if the calling thread is willing to wait. |
- Returns
- The method status.
◆ _CORE_barrier_Surrender()
This routine manually releases the barrier. All of the threads waiting for the barrier will be readied.
- Parameters
| [in,out] | the_barrier | The barrier to surrender. |
- Returns
- The number of unblocked threads.
◆ _CORE_barrier_Thread_queue_operations
