RTEMS 5.2
Files | Macros | Functions | Variables
MRM332 Board Support Package. More...
file  bsp.h
 Global BSP definitions.
#define CONSOLE_SCI
#define STACK_SIZE   0x800
#define RAW_PUTS(str)
#define RAW_PUTI(n)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler. More...
void Spurious_Initialize (void)
void _UART_flush (void)
void outbyte (char)
char _etext []
char _copy_start []
char _edata []
char _clear_start []
char end []
bool _copy_data_from_rom
rtems_isr_entry M68Kvec []
int stack_size
int stack_start
◆ RAW_PUTI
#define RAW_PUTI (   n)
Value:
register int i, j; \
RAW_PUTS("0x"); \
for (i=28;i>=0;i -= 4) { \
j = (n>>i) & 0xf; \
SCI_output_char( (j>9 ? j-10+'a' : j+'0') ); \
◆ RAW_PUTS
#define RAW_PUTS (   str)
Value:
{ register char *ptr = str; \
while (*ptr) SCI_output_char(*ptr++); \
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
