RTEMS 5.2
Modules | Files | Macros | Functions
Xilinx Zynq UltraScale+ MPSoC
Xilinx Zynq UltraScale+ MPSoC Board Support Package. More...
 Interrupt Support
 Interrupt Support.
 TM27 Test Support
 Interrupt Mechanisms for tm27 test.
file  bsp.h
 Global BSP definitions.
#define BSP_FEATURE_IRQ_EXTENSION
#define BSP_ARM_GIC_CPUIF_BASE   0xf9020000
#define BSP_ARM_GIC_DIST_BASE   0xf9010000
#define BSP_ARM_A9MPCORE_SCU_BASE   0
#define BSP_ARM_A9MPCORE_GT_BASE   0
BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache (void)
 Zynq UltraScale+ MPSoC specific set up of the MMU. More...
void arm_generic_timer_get_config (uint32_t *frequency, uint32_t *irq)
void zynqmp_debug_console_flush (void)
◆ zynqmp_setup_mmu_and_cache()
BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache ( void  )
Provide in the application to override the defaults in the BSP.
