RTEMS 5.2
Files | Data Structures | Macros | Functions
Associativity Routines
file  assoc.h
 RTEMS Associativity Routines.
struct  rtems_assoc_t
struct  rtems_assoc_32_pair
#define RTEMS_ASSOC_DEFAULT_NAME   "(default)"
const rtems_assoc_trtems_assoc_ptr_by_name (const rtems_assoc_t *, const char *)
 RTEMS Associate Pointer by Name.
const rtems_assoc_trtems_assoc_ptr_by_remote (const rtems_assoc_t *, uint32_t)
 RTEMS Associate Pointer by Remote.
uint32_t rtems_assoc_remote_by_local (const rtems_assoc_t *, uint32_t)
uint32_t rtems_assoc_local_by_remote (const rtems_assoc_t *, uint32_t)
 RTEMS Associate Local by Remote.
uint32_t rtems_assoc_remote_by_name (const rtems_assoc_t *, const char *)
 RTEMS Associate Remote by Name.
uint32_t rtems_assoc_local_by_name (const rtems_assoc_t *, const char *)
 RTEMS Associate Local by Name.
const char * rtems_assoc_name_by_local (const rtems_assoc_t *, uint32_t)
 RTEMS Associate Name by Local.
const char * rtems_assoc_name_by_remote (const rtems_assoc_t *, uint32_t)
 RTEMS Associate Name by Remote.
uint32_t rtems_assoc_remote_by_local_bitfield (const rtems_assoc_t *, uint32_t)
 RTEMS Assoc Routines.
char * rtems_assoc_name_by_local_bitfield (const rtems_assoc_t *, uint32_t, char *)
 RTEMS Associate Name by Local Bitfield.
char * rtems_assoc_name_by_remote_bitfield (const rtems_assoc_t *, uint32_t, char *)
 RTEMS Associate Name by Remote Bitfield.
uint32_t rtems_assoc_local_by_remote_bitfield (const rtems_assoc_t *, uint32_t)
const rtems_assoc_trtems_assoc_ptr_by_local (const rtems_assoc_t *ap, uint32_t local_value)
 RTEMS Associate Pointer by Local.
size_t rtems_assoc_32_to_string (uint32_t value, char *buffer, size_t buffer_size, const rtems_assoc_32_pair *pairs, size_t pair_count, const char *separator, const char *fallback)
 Converts the specified value into a text representation. More...
size_t rtems_assoc_thread_states_to_string (uint32_t states, char *buffer, size_t buffer_size)
 Converts the specified thread states into a text representation. More...
RTEMS associativity routines. Mainly used to convert a value from one space to another (eg: our errno's to host errno's and vice-versa)
◆ rtems_assoc_32_to_string()
size_t rtems_assoc_32_to_string ( uint32_t  value,
char *  buffer,
size_t  buffer_size,
const rtems_assoc_32_pair pairs,
size_t  pair_count,
const char *  separator,
const char *  fallback
Parameters
[in]valueThe value to convert.
[in]bufferThe buffer for the text representation.
[in]buffer_sizeThe buffer size in characters.
[in]pairsNames for particular bits.
[in]pair_countCount of pairs.
[in]separatorSeparator between individual names.
[in]fallbackFallback value in case no bits contained in the pairs are set in the value.
Return values
Thelength of the text representation. May be greater than or equal to the buffer size if truncation occurred.
◆ rtems_assoc_thread_states_to_string()
size_t rtems_assoc_thread_states_to_string ( uint32_t  states,
char *  buffer,
size_t  buffer_size
Parameters
[in]statesThe thread states to convert.
Return values
