RTEMS 5.2
Files | Data Structures | Macros | Typedefs | Functions | Variables
User Environment
Provides a POSIX like user environment for tasks. More...
file  userenv.h
 User Environment Support.
file  privateenv.c
 Instantiate a Private User Environment.
struct  rtems_user_env_t
 User environment. More...
#define LOGIN_NAME_MAX   9
#define rtems_current_user_env   rtems_current_user_env_get()
#define rtems_filesystem_current   (rtems_current_user_env->current_directory)
#define rtems_filesystem_root   (rtems_current_user_env->root_directory)
#define rtems_filesystem_umask   (rtems_current_user_env->umask)
#define _POSIX_types_Uid   (rtems_current_user_env->uid)
#define _POSIX_types_Gid   (rtems_current_user_env->gid)
#define _POSIX_types_Euid   (rtems_current_user_env->euid)
#define _POSIX_types_Egid   (rtems_current_user_env->egid)
#define _POSIX_types_Getlogin_buffer   (rtems_current_user_env->login_buffer)
typedef struct rtems_user_env_t rtems_user_env_t
rtems_user_env_trtems_current_user_env_get (void)
 Fetch the pointer to the current user environment. More...
rtems_status_code rtems_libio_set_private_env (void)
 Creates a private environment. More...
void rtems_libio_use_global_env (void)
 Use the global environment. More...
void rtems_current_user_env_getgroups (void)
 Gets the supplementary group IDs using the current user ID and updates the table of supplementary group IDs in the current user environment. More...
rtems_user_env_t rtems_global_user_env
◆ rtems_current_user_env_get()
rtems_user_env_t * rtems_current_user_env_get ( void  )
If the task has a private user environment the pointer to it will be returned. Otherwise the pointer to rtems_global_user_env will be returned.
◆ rtems_current_user_env_getgroups()
void rtems_current_user_env_getgroups ( void  )
In case of an error, the count of supplementary group IDs is set to zero.
◆ rtems_libio_set_private_env()
rtems_status_code rtems_libio_set_private_env ( void  )
If the task has already a private environment nothing will be changed. This function must be called from normal thread context and may block on a mutex. Thread dispatching is disabled to protect some critical sections.
The private environment internally uses a POSIX key. The key is added to the configuration implicitly. But for each thread that uses a private environment a key value pair has to be configured by the application. If only the global environment is used there is no need to configure a key value pair.
Return values
RTEMS_SUCCESSFULSuccessful operation.
RTEMS_NO_MEMORYNot enough memory.
RTEMS_UNSATISFIEDCloning of the current environment failed.
RTEMS_TOO_MANYCannot register the private environment.
◆ rtems_libio_use_global_env()
void rtems_libio_use_global_env ( void  )
A private environment will be released. This function may be called from every thread context. Thread dispatching is disabled to protect the critical sections.
