RTEMS 5.2
Data Structures | Typedefs | Functions | Variables
Console driver for Termios devices. More...
struct  console_device
 Console device information. More...
typedef bool(* console_device_probe) (rtems_termios_device_context *context)
 Console device probe function type. More...
bool console_device_probe_default (rtems_termios_device_context *context)
 Returns true and does nothing else.
const char * console_device::device_file
 The device file path. More...
console_device_probe console_device::probe
 The device probe function.
const rtems_termios_device_handlerconsole_device::handler
 The Termios device handler.
const rtems_termios_device_flowconsole_device::flow
 The Termios device flow control handler.
rtems_termios_device_contextconsole_device::context
 The Termios device context.
const console_device console_device_table []
 Table for console devices installed via console_initialize() during system initialization. More...
const size_t console_device_count
 Count of entries in the console_device_table. More...
In order to use this driver add the following lines to the Makefile.am of the BSP:
libbsp_a_SOURCES += ../../shared/console-termios-init.c
libbsp_a_SOURCES += ../../shared/console-termios.c
libbsp_a_SOURCES += console/console-config.c
Definition: deflate.c:115
Define the console_device_table and console_device_count in the console-config.c file of the BSP.
Typedef Documentation
◆ console_device_probe
Parameters
[in]contextThe Termios device context.
Return values
trueInstall this device.
falseOtherwise.
Variable Documentation
◆ console_device_count
extern
It must be provided by the BSP.
◆ console_device_table
const console_device console_device_table[]
extern
See also
console_device_count.
◆ device_file
const char* console_device::device_file
The "/dev/console" device will be automatically installed as the first device of console_device_table with a successful probe.
