RTEMS 5.2
Files | Data Structures | Macros | Typedefs | Enumerations | Functions
Timers
file  timer.h
 Classic Timer Manager API.
file  rtemstimer.c
 Classic Timer Information with Zero Objects.
file  timercreate.c
 RTEMS Create Timer.
file  timerdelete.c
 RTEMS Delete Timer.
file  timerfireafter.c
 RTEMS Timer Fire After.
file  timerfirewhen.c
 RTEMS Timer Fire When.
file  timergetinfo.c
 RTEMS Get Timer Information.
file  timerident.c
 RTEMS Timer Name to Id.
file  timerreset.c
 RTEMS Timer Reset.
file  timerserverfireafter.c
 RTEMS Timer Server Fire After.
file  timerserverfirewhen.c
 RTEMS Timer Server Fire When Directive.
struct  rtems_timer_information
#define TIMER_CLASS_BIT_TIME_OF_DAY   0x1
#define TIMER_CLASS_BIT_ON_TASK   0x2
#define TIMER_CLASS_BIT_NOT_DORMANT   0x4
#define RTEMS_TIMER_SERVER_DEFAULT_PRIORITY   (uint32_t) -1
typedef void rtems_timer_service_routine
typedef rtems_timer_service_routine(* rtems_timer_service_routine_entry) (rtems_id, void *)
enum  Timer_Classes {
  TIMER_DORMANT , TIMER_INTERVAL = TIMER_CLASS_BIT_NOT_DORMANT , TIMER_INTERVAL_ON_TASK , TIMER_TIME_OF_DAY ,
  TIMER_TIME_OF_DAY_ON_TASK
rtems_status_code rtems_timer_create (rtems_name name, rtems_id *id)
 RTEMS Create Timer. More...
rtems_status_code rtems_timer_ident (rtems_name name, rtems_id *id)
 RTEMS Timer Name to Id. More...
rtems_status_code rtems_timer_cancel (rtems_id id)
 rtems_timer_cancel More...
rtems_status_code rtems_timer_delete (rtems_id id)
 RTEMS Delete Timer. More...
rtems_status_code rtems_timer_fire_after (rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data)
 RTEMS Timer Fire After. More...
rtems_status_code rtems_timer_server_fire_after (rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data)
 RTEMS Timer Server Fire After. More...
rtems_status_code rtems_timer_fire_when (rtems_id id, rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data)
 RTEMS Timer Fire When. More...
rtems_status_code rtems_timer_server_fire_when (rtems_id id, rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data)
 RTEMS Timer Server Fire When Directive. More...
rtems_status_code rtems_timer_reset (rtems_id id)
 RTEMS Timer Reset. More...
rtems_status_code rtems_timer_initiate_server (rtems_task_priority priority, size_t stack_size, rtems_attribute attribute_set)
 Initiates the timer server. More...
rtems_status_code rtems_timer_get_information (rtems_id id, rtems_timer_information *the_info)
 RTEMS Get Timer Information. More...
This encapsulates functionality related to the Classic API Timer Manager. This manager provides functionality which allows the application to schedule the execution of methods at a specified time in the future. These methods may be scheduled based upon interval or wall time and may be executed in either the clock tick ISR or in a special dedicated timer server task.
◆ RTEMS_TIMER_SERVER_DEFAULT_PRIORITY
This is the default value for the priority of the Timer Server. When given this priority, a special high priority not accessible via the Classic API is used.
Typedef Documentation
◆ rtems_timer_service_routine
The following types define a pointer to a timer service routine.
◆ rtems_timer_service_routine_entry
This type defines the type used to manage and indirectly invoke Timer Service Routines (TSRs). This defines the prototype and interface for a function which is to be used as a TSR.
◆ Timer_Classes
The following enumerated type details the classes to which a timer may belong.
TIMER_DORMANT
This value indicates the timer is currently not in use.
TIMER_INTERVAL
This value indicates the timer is currently in use as an interval timer which will fire in the clock tick ISR.
This value indicates the timer is currently in use as an interval timer which will fire in the timer server task.
TIMER_TIME_OF_DAY
This value indicates the timer is currently in use as an time of day timer which will fire in the clock tick ISR.
This value indicates the timer is currently in use as an time of day timer which will fire in the timer server task.
◆ rtems_timer_cancel()
rtems_status_code rtems_timer_cancel ( rtems_id  id)
rtems_timer_cancel
This routine implements the rtems_timer_cancel directive. It is used to stop the timer associated with ID from firing.
◆ rtems_timer_create()
rtems_status_code rtems_timer_create ( rtems_name  name,
rtems_id id
RTEMS Create Timer.
This routine implements the rtems_timer_create directive. The timer will have the name name. It returns the id of the created timer in ID.
Parameters
[in]nameis the timer name
[out]idis the pointer to timer id
Return values
RTEMS_SUCCESSFULif successful or error code if unsuccessful
◆ rtems_timer_delete()
rtems_status_code rtems_timer_delete ( rtems_id  id)
RTEMS Delete Timer.
This routine implements the rtems_timer_delete directive. The timer indicated by ID is deleted.
Parameters
[in]idis the timer id
Return values
Thismethod returns RTEMS_SUCCESSFUL if there was not an error. Otherwise, a status code is returned indicating the source of the error.
◆ rtems_timer_fire_after()
rtems_status_code rtems_timer_fire_after ( rtems_id  id,
void *  user_data
This routine implements the rtems_timer_fire_after directive. It initiates the timer associated with ID to fire in ticks clock ticks. When the timer fires, the routine will be invoked in the context of the rtems_clock_tick directive which is normally invoked as part of servicing a periodic interupt.
Parameters
[in]ticksis the interval until routine is fired
[in]routineis the routine to schedule
[in]user_datais the passed as argument to routine when it is fired
Return values
◆ rtems_timer_fire_when()
rtems_status_code rtems_timer_fire_when ( rtems_id  id,
rtems_time_of_day wall_time,
void *  user_data
This routine implements the rtems_timer_fire_when directive. It initiates the timer associated with ID to fire at wall_time When the timer fires, the routine will be invoked in the context of the rtems_clock_tick directive which is normally invoked as part of servicing a periodic interupt.
Parameters
[in]wall_timeis the time of day to fire timer
Return values
◆ rtems_timer_get_information()
rtems_status_code rtems_timer_get_information ( rtems_id  id,
rtems_timer_information the_info
This routine implements the rtems_timer_get_information directive. This directive returns information about the timer.
Parameters
[in]the_infois the pointer to timer information block
Return values
RTEMS_SUCCESSFULif successful or error code if unsuccessful and *the_info region information block filled in
◆ rtems_timer_ident()
rtems_status_code rtems_timer_ident ( rtems_name  name,
rtems_id id
This routine implements the rtems_timer_ident directive. This directive returns the timer ID associated with name. If more than one timer is named name, then the timer to which the ID belongs is arbitrary.
Parameters
[in]nameis the user defined message queue name
[in]idis the pointer to timer id
Return values
RTEMS_SUCCESSFULif successful or error code if unsuccessful and id filled with the message queue id
◆ rtems_timer_initiate_server()
rtems_status_code rtems_timer_initiate_server ( rtems_task_priority  priority,
size_t  stack_size,
This directive creates and starts the server for task-based timers. It must be invoked before any task-based timers can be initiated.
Parameters
priorityThe timer server task priority.
stack_sizeThe stack size in bytes for the timer server task.
attribute_setThe timer server task attributes.
Returns
This method returns RTEMS_SUCCESSFUL if successful and an error code otherwise.
◆ rtems_timer_reset()
rtems_status_code rtems_timer_reset ( rtems_id  id)
RTEMS Timer Reset.
Timer Manager - RTEMS Timer Reset
This routine implements the rtems_timer_reset directive. It is used to reinitialize the interval timer associated with ID just as if rtems_timer_fire_after were re-invoked with the same arguments that were used to initiate this timer.
◆ rtems_timer_server_fire_after()
rtems_status_code rtems_timer_server_fire_after ( rtems_id  id,
void *  user_data
This routine implements the rtems_timer_server_fire_after directive. It initiates the timer associated with ID to fire in ticks clock ticks. When the timer fires, the routine will be invoked by the Timer Server in the context of a task NOT IN THE CONTEXT of the clock tick interrupt.
Parameters
Return values
◆ rtems_timer_server_fire_when()
rtems_status_code rtems_timer_server_fire_when ( rtems_id  id,
void *  user_data
Timer Manager - RTEMS Timer Server Fire When Directive
This routine implements the rtems_timer_server_fire_when directive. It initiates the timer associated with ID to fire at wall_time When the timer fires, the routine will be invoked by the Timer Server in the context of a task NOT IN THE CONTEXT of the clock tick interrupt.
