#define | RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT RTEMS_EVENT_24 |
| | Reserved system event for network SBWAIT usage.
#define | RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP RTEMS_EVENT_25 |
| | Reserved system event for network SOSLEEP usage.
#define | RTEMS_EVENT_SYSTEM_NETWORK_CLOSE RTEMS_EVENT_26 |
| | Reserved system event for network socket close.
#define | RTEMS_EVENT_SYSTEM_SERVER_RESUME RTEMS_EVENT_29 |
| | Reserved system event to resume server threads, e.g timer or interrupt server.
#define | RTEMS_EVENT_SYSTEM_SERVER RTEMS_EVENT_30 |
| | Reserved system event for the server threads, e.g timer or interrupt server.
#define | RTEMS_EVENT_SYSTEM_TRANSIENT RTEMS_EVENT_31 |
| | Reserved system event for transient usage.
System events are similar to normal events. They offer a second set of events. These events are intended for internal RTEMS use and should not be used by applications (with the exception of the transient system event).
The event RTEMS_EVENT_SYSTEM_TRANSIENT is used for transient usage. See also Transient Event. This event may be used by every entity that fulfils its usage pattern.
