RTEMS 5.2
Files | Macros | Typedefs
ASR Support
file  asr.h
#define RTEMS_SIGNAL_0   0x00000001
#define RTEMS_SIGNAL_1   0x00000002
#define RTEMS_SIGNAL_2   0x00000004
#define RTEMS_SIGNAL_3   0x00000008
#define RTEMS_SIGNAL_4   0x00000010
#define RTEMS_SIGNAL_5   0x00000020
#define RTEMS_SIGNAL_6   0x00000040
#define RTEMS_SIGNAL_7   0x00000080
#define RTEMS_SIGNAL_8   0x00000100
#define RTEMS_SIGNAL_9   0x00000200
#define RTEMS_SIGNAL_10   0x00000400
#define RTEMS_SIGNAL_11   0x00000800
#define RTEMS_SIGNAL_12   0x00001000
#define RTEMS_SIGNAL_13   0x00002000
#define RTEMS_SIGNAL_14   0x00004000
#define RTEMS_SIGNAL_15   0x00008000
#define RTEMS_SIGNAL_16   0x00010000
#define RTEMS_SIGNAL_17   0x00020000
#define RTEMS_SIGNAL_18   0x00040000
#define RTEMS_SIGNAL_19   0x00080000
#define RTEMS_SIGNAL_20   0x00100000
#define RTEMS_SIGNAL_21   0x00200000
#define RTEMS_SIGNAL_22   0x00400000
#define RTEMS_SIGNAL_23   0x00800000
#define RTEMS_SIGNAL_24   0x01000000
#define RTEMS_SIGNAL_25   0x02000000
#define RTEMS_SIGNAL_26   0x04000000
#define RTEMS_SIGNAL_27   0x08000000
#define RTEMS_SIGNAL_28   0x10000000
#define RTEMS_SIGNAL_29   0x20000000
#define RTEMS_SIGNAL_30   0x40000000
#define RTEMS_SIGNAL_31   0x80000000
typedef uint32_t rtems_signal_set
typedef void rtems_asr
typedef rtems_asr(* rtems_asr_entry) (rtems_signal_set)
This encapsulates functionality related to the Classic API Signal Manager.
◆ RTEMS_SIGNAL_0
This defines the bit in the signal set associated with signal 0.
◆ RTEMS_SIGNAL_1
This defines the bit in the signal set associated with signal 1.
◆ RTEMS_SIGNAL_10
This defines the bit in the signal set associated with signal 10.
◆ RTEMS_SIGNAL_11
This defines the bit in the signal set associated with signal 11.
◆ RTEMS_SIGNAL_12
This defines the bit in the signal set associated with signal 12.
◆ RTEMS_SIGNAL_13
This defines the bit in the signal set associated with signal 13.
◆ RTEMS_SIGNAL_14
This defines the bit in the signal set associated with signal 14.
◆ RTEMS_SIGNAL_15
This defines the bit in the signal set associated with signal 15.
◆ RTEMS_SIGNAL_16
This defines the bit in the signal set associated with signal 16.
◆ RTEMS_SIGNAL_17
This defines the bit in the signal set associated with signal 17.
◆ RTEMS_SIGNAL_18
This defines the bit in the signal set associated with signal 18.
◆ RTEMS_SIGNAL_19
This defines the bit in the signal set associated with signal 19.
◆ RTEMS_SIGNAL_2
This defines the bit in the signal set associated with signal 2.
◆ RTEMS_SIGNAL_20
This defines the bit in the signal set associated with signal 20.
◆ RTEMS_SIGNAL_21
This defines the bit in the signal set associated with signal 21.
◆ RTEMS_SIGNAL_22
This defines the bit in the signal set associated with signal 22.
◆ RTEMS_SIGNAL_23
This defines the bit in the signal set associated with signal 23.
◆ RTEMS_SIGNAL_24
This defines the bit in the signal set associated with signal 24.
◆ RTEMS_SIGNAL_25
This defines the bit in the signal set associated with signal 25.
◆ RTEMS_SIGNAL_26
This defines the bit in the signal set associated with signal 26.
◆ RTEMS_SIGNAL_27
This defines the bit in the signal set associated with signal 27.
◆ RTEMS_SIGNAL_28
This defines the bit in the signal set associated with signal 28.
◆ RTEMS_SIGNAL_29
This defines the bit in the signal set associated with signal 29.
◆ RTEMS_SIGNAL_3
This defines the bit in the signal set associated with signal 3.
◆ RTEMS_SIGNAL_30
This defines the bit in the signal set associated with signal 30.
◆ RTEMS_SIGNAL_31
This defines the bit in the signal set associated with signal 31.
◆ RTEMS_SIGNAL_4
This defines the bit in the signal set associated with signal 4.
◆ RTEMS_SIGNAL_5
This defines the bit in the signal set associated with signal 5.
◆ RTEMS_SIGNAL_6
This defines the bit in the signal set associated with signal 6.
◆ RTEMS_SIGNAL_7
This defines the bit in the signal set associated with signal 7.
◆ RTEMS_SIGNAL_8
This defines the bit in the signal set associated with signal 8.
◆ RTEMS_SIGNAL_9
This defines the bit in the signal set associated with signal 9.
Typedef Documentation
◆ rtems_asr
Return type for ASR Handler
◆ rtems_asr_entry
The following type corresponds to the applications asynchronous signal processing routine.
◆ rtems_signal_set
The following type defines the control block used to manage each signal set.
