RTEMS 5.2
SoCAL Memory Bit Set/Clr/XOR/Replace Utilities
#define alt_setbits_byte(dest, bits)   (alt_write_byte(dest, alt_read_byte(dest) | (bits)))
#define alt_clrbits_byte(dest, bits)   (alt_write_byte(dest, alt_read_byte(dest) & ~(bits)))
#define alt_xorbits_byte(dest, bits)   (alt_write_byte(dest, alt_read_byte(dest) ^ (bits)))
#define alt_replbits_byte(dest, msk, src)   (alt_write_byte(dest,(alt_read_byte(dest) & ~(msk)) | ((src) & (msk))))
#define alt_setbits_hword(dest, bits)   (alt_write_hword(dest, alt_read_hword(dest) | (bits)))
#define alt_clrbits_hword(dest, bits)   (alt_write_hword(dest, alt_read_hword(dest) & ~(bits)))
#define alt_xorbits_hword(dest, bits)   (alt_write_hword(dest, alt_read_hword(dest) ^ (bits)))
#define alt_replbits_hword(dest, msk, src)   (alt_write_hword(dest,(alt_read_hword(dest) & ~(msk)) | ((src) & (msk))))
#define alt_setbits_word(dest, bits)   (alt_write_word(dest, alt_read_word(dest) | (bits)))
#define alt_clrbits_word(dest, bits)   (alt_write_word(dest, alt_read_word(dest) & ~(bits)))
#define alt_xorbits_word(dest, bits)   (alt_write_word(dest, alt_read_word(dest) ^ (bits)))
#define alt_replbits_word(dest, msk, src)   (alt_write_word(dest,(alt_read_word(dest) & ~(msk)) | ((src) & (msk))))
#define alt_setbits_dword(dest, bits)   (alt_write_dword(dest, alt_read_dword(dest) | (bits)))
#define alt_clrbits_dword(dest, bits)   (alt_write_dword(dest, alt_read_dword(dest) & ~(bits)))
#define alt_xorbits_dword(dest, bits)   (alt_write_dword(dest, alt_read_dword(dest) ^ (bits)))
#define alt_replbits_dword(dest, msk, src)   (alt_write_dword(dest,(alt_read_dword(dest) & ~(msk)) | ((src) & (msk))))
This section implements useful macros to set, clear, change, and replace selected bits within a word in memory or a memory-mapped register.
◆ alt_clrbits_byte
#define alt_clrbits_byte (   dest,
  bits
Clear selected bits in the 8 bit byte at the destination address in device memory.
Parameters
dest- Destination pointer address
bits- Bits to clear in destination byte
◆ alt_clrbits_dword
#define alt_clrbits_dword (   dest,
  bits
Clear selected bits in the 64 bit doubleword at the destination address in device memory.
Parameters
bits- Bits to clear in destination doubleword
◆ alt_clrbits_hword
#define alt_clrbits_hword (   dest,
  bits
Clear selected bits in the 16 bit halfword at the destination address in device memory.
Parameters
bits- Bits to clear in destination halfword
◆ alt_clrbits_word
#define alt_clrbits_word (   dest,
  bits
Clear selected bits in the 32 bit word at the destination address in device memory.
Parameters
bits- Bits to clear in destination word
◆ alt_replbits_byte
#define alt_replbits_byte (   dest,
  msk,
  src
Replace selected bits in the 8 bit byte at the destination address in device memory.
Parameters
msk- Bits to replace in destination byte
src- Source bits to write to cleared bits in destination byte
◆ alt_replbits_dword
#define alt_replbits_dword (   dest,
  msk,
  src
Replace selected bits in the 64 bit doubleword at the destination address in device memory.
Parameters
msk- Bits to replace in destination doubleword
src- Source bits to write to cleared bits in destination word
◆ alt_replbits_hword
#define alt_replbits_hword (   dest,
  msk,
  src
Replace selected bits in the 16 bit halfword at the destination address in device memory.
Parameters
msk- Bits to replace in destination halfword
src- Source bits to write to cleared bits in destination halfword
◆ alt_replbits_word
#define alt_replbits_word (   dest,
  msk,
  src
Replace selected bits in the 32 bit word at the destination address in device memory.
Parameters
msk- Bits to replace in destination word
◆ alt_setbits_byte
#define alt_setbits_byte (   dest,
  bits
Set selected bits in the 8 bit byte at the destination address in device memory.
Parameters
bits- Bits to set in destination byte
◆ alt_setbits_dword
#define alt_setbits_dword (   dest,
  bits
Set selected bits in the 64 bit doubleword at the destination address in device memory.
Parameters
bits- Bits to set in destination doubleword
◆ alt_setbits_hword
#define alt_setbits_hword (   dest,
  bits
Set selected bits in the 16 bit halfword at the destination address in device memory.
Parameters
bits- Bits to set in destination halfword
◆ alt_setbits_word
#define alt_setbits_word (   dest,
  bits
Set selected bits in the 32 bit word at the destination address in device memory.
Parameters
bits- Bits to set in destination word
◆ alt_xorbits_byte
#define alt_xorbits_byte (   dest,
  bits
Change or toggle selected bits in the 8 bit byte at the destination address in device memory.
Parameters
bits- Bits to change in destination byte
◆ alt_xorbits_dword
#define alt_xorbits_dword (   dest,
  bits
Change or toggle selected bits in the 64 bit doubleword at the destination address in device memory.
Parameters
bits- Bits to change in destination doubleword
◆ alt_xorbits_hword
#define alt_xorbits_hword (   dest,
  bits
Change or toggle selected bits in the 16 bit halfword at the destination address in device memory.
Parameters
bits- Bits to change in destination halfword
◆ alt_xorbits_word
#define alt_xorbits_word (   dest,
  bits
Change or toggle selected bits in the 32 bit word at the destination address in device memory.
Parameters
bits- Bits to change in destination word
