RTEMS 5.2
Modules | Data Structures | Macros | Typedefs | Enumerations | Functions
DMA Controller Programming API
 Support for DMAMOV CCR
struct  ALT_DMA_PROGRAM_s
#define ALT_DMA_PROGRAM_CACHE_LINE_SIZE   (32)
#define ALT_DMA_PROGRAM_CACHE_LINE_COUNT   (16)
#define ALT_DMA_PROGRAM_PROVISION_BUFFER_SIZE   (ALT_DMA_PROGRAM_CACHE_LINE_SIZE * ALT_DMA_PROGRAM_CACHE_LINE_COUNT)
typedef struct ALT_DMA_PROGRAM_s ALT_DMA_PROGRAM_t
typedef enum ALT_DMA_PROGRAM_REG_e ALT_DMA_PROGRAM_REG_t
typedef enum ALT_DMA_PROGRAM_INST_MOD_e ALT_DMA_PROGRAM_INST_MOD_t
enum  ALT_DMA_PROGRAM_REG_e { ALT_DMA_PROGRAM_REG_SAR = 0x0 , ALT_DMA_PROGRAM_REG_DAR = 0x2 , ALT_DMA_PROGRAM_REG_CCR = 0x1 }
enum  ALT_DMA_PROGRAM_INST_MOD_e { ALT_DMA_PROGRAM_INST_MOD_NONE , ALT_DMA_PROGRAM_INST_MOD_SINGLE , ALT_DMA_PROGRAM_INST_MOD_BURST , ALT_DMA_PROGRAM_INST_MOD_PERIPH }
ALT_STATUS_CODE alt_dma_program_init (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_uninit (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_clear (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_validate (const ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_progress_reg (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t reg, uint32_t current, uint32_t *progress)
ALT_STATUS_CODE alt_dma_program_update_reg (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t reg, uint32_t val)
ALT_STATUS_CODE alt_dma_program_DMAADDH (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t addr_reg, uint16_t val)
ALT_STATUS_CODE alt_dma_program_DMAADNH (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t addr_reg, uint16_t val)
ALT_STATUS_CODE alt_dma_program_DMAEND (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_DMAFLUSHP (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PERIPH_t periph)
ALT_STATUS_CODE alt_dma_program_DMAGO (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_CHANNEL_t channel, uint32_t val, ALT_DMA_SECURITY_t sec)
ALT_STATUS_CODE alt_dma_program_DMAKILL (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_DMALD (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod)
ALT_STATUS_CODE alt_dma_program_DMALDP (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod, ALT_DMA_PERIPH_t periph)
ALT_STATUS_CODE alt_dma_program_DMALP (ALT_DMA_PROGRAM_t *pgm, uint32_t iterations)
ALT_STATUS_CODE alt_dma_program_DMALPEND (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod)
ALT_STATUS_CODE alt_dma_program_DMALPFE (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_DMAMOV (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t chan_reg, uint32_t val)
ALT_STATUS_CODE alt_dma_program_DMANOP (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_DMARMB (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_DMASEV (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_EVENT_t evt)
ALT_STATUS_CODE alt_dma_program_DMAST (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod)
ALT_STATUS_CODE alt_dma_program_DMASTP (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod, ALT_DMA_PERIPH_t periph)
ALT_STATUS_CODE alt_dma_program_DMASTZ (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_DMAWFE (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_EVENT_t evt, bool invalid)
ALT_STATUS_CODE alt_dma_program_DMAWFP (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PERIPH_t periph, ALT_DMA_PROGRAM_INST_MOD_t mod)
ALT_STATUS_CODE alt_dma_program_DMAWMB (ALT_DMA_PROGRAM_t *pgm)
This API provides functions for dynamically defining and assembling microcode programs for execution on the DMA controller.
The microcode program assembly API provides users with the ability to develop highly optimized and tailored algorithms for data transfer between SoC FPGA IP blocks and/or system memory.
The same microcode program assembly facilities are also used to implement the functions found in the HWLIB Common DMA Operations functional API.
An ALT_DMA_PROGRAM_t structure is used to contain and assemble a DMA microcode program. The storage for an ALT_DMA_PROGRAM_t stucture is allocated from used specified system memory. Once a microcode program has been assembled in a ALT_DMA_PROGRAM_t it may be excecuted on a designated DMA channel thread. The microcode program may be rerun on any DMA channel thread whenever required as long as the integrity of the ALT_DMA_PROGRAM_t containing the program is maintained.
◆ ALT_DMA_PROGRAM_CACHE_LINE_COUNT
This preprocessor declares the DMA channel thread microcode instruction cache line count. Thus the total size of the cache is the cache line size multipled by the cache line count. Programs larger than the cache size risk having a cache miss while executing.
◆ ALT_DMA_PROGRAM_CACHE_LINE_SIZE
This preprocessor declares the DMA channel thread microcode instruction cache line width in bytes. It is recommended that the program buffers be sized to a multiple of the cache line size. This will allow for the most efficient microcode speed and space utilization.
◆ ALT_DMA_PROGRAM_PROVISION_BUFFER_SIZE
This preprocessor definition determines the size of the program buffer within the ALT_DMA_PROGRAM_t structure. This size should provide adequate size for most DMA microcode programs. If calls within this API are reporting out of memory response codes, consider increasing the provisioned program buffersize.
To specify another DMA microcode program buffer size, redefine the macro below by defining ALT_DMA_PROGRAM_PROVISION_BUFFER_SIZE to another size in your Makefile. It is recommended that the size be a multiple of the microcode engine cache line size. See ALT_DMA_PROGRAM_CACHE_LINE_SIZE for more information. The largest supported buffer size is 65536 bytes.
Typedef Documentation
◆ ALT_DMA_PROGRAM_INST_MOD_t
This type definition enumerates the instruction modifier options available for use with selected DMA microcode instructions.
The enumerations values are context dependent upon the instruction being modified.
For the DMALD[S|B], DMALDP<S|B>, DMAST[S|B], and DMASTP<S|B> microcode instructions, the enumeration ALT_DMA_PROGRAM_INST_MOD_SINGLE specifies the S option modifier while the enumeration ALT_DMA_PROGRAM_INST_MOD_BURST specifies the B option modifier. The enumeration ALT_DMA_PROGRAM_INST_MOD_NONE specifies that no modifier is present for instructions where use of [S|B] is optional.
For the DMAWFP microcode instruction, the enumerations ALT_DMA_PROGRAM_INST_MOD_SINGLE, ALT_DMA_PROGRAM_INST_MOD_BURST, or ALT_DMA_PROGRAM_INST_MOD_PERIPH each specify one of the corresponding options <single|burst|periph>.
◆ ALT_DMA_PROGRAM_REG_t
This type definition enumerates the DMA controller register names for use in microcode program definition.
◆ ALT_DMA_PROGRAM_t
This type defines the structure used to assemble and contain a microcode program which can be executed by the DMA controller. The internal members are undocumented and should not be altered outside of this API.
◆ ALT_DMA_PROGRAM_INST_MOD_e
This DMA instruction modifier specifies that no special modifier is added to the instruction.
Depending on the DMA microcode instruction modified, this modifier specifies S case for a [S|B] or a <single> for a <single|burst|periph>.
Depending on the DMA microcode instruction modified, this modifier specifies B case for a [S|B] or a <burst> for a <single|burst|periph>.
This DMA instruction modifier specifies a <periph> for a <single|burst|periph>.
◆ ALT_DMA_PROGRAM_REG_e
Source Address Register
Destination Address Register
Channel Control Register
◆ alt_dma_program_clear()
ALT_STATUS_CODE alt_dma_program_clear ( ALT_DMA_PROGRAM_t pgm)
This function clears the existing DMA microcode program in the given program buffer.
Parameters
pgmA pointer to a DMA program buffer structure.
Return values
ALT_E_SUCCESSThe operation was successful.
ALT_E_ERRORDetails about error status code.
◆ alt_dma_program_DMAADDH()
ALT_STATUS_CODE alt_dma_program_DMAADDH ( ALT_DMA_PROGRAM_t pgm,
uint16_t  val
Assembles a DMAADDH (Add Halfword) instruction into the microcode program buffer. This instruction uses 3 bytes of buffer space.
Parameters
pgmThe DMA program buffer to contain the assembled instruction.
addr_regThe channel address register (ALT_DMA_PROGRAM_REG_DAR or ALT_DMA_PROGRAM_REG_SAR) to add the value to.
valThe 16-bit unsigned value to add to the channel address register.
Return values
ALT_E_SUCCESSSuccessful instruction assembly status.
ALT_E_DMA_BUF_OVFDMA program buffer overflow.
ALT_E_BAD_ARGInvalid channel register specified.
◆ alt_dma_program_DMAADNH()
ALT_STATUS_CODE alt_dma_program_DMAADNH ( ALT_DMA_PROGRAM_t pgm,
uint16_t  val
Assembles a DMAADNH (Add Negative Halfword) instruction into the microcode program buffer. This instruction uses 3 bytes of buffer space.
Parameters
pgmThe DMA programm buffer to contain the assembled instruction.
Return values
◆ alt_dma_program_DMAEND()
ALT_STATUS_CODE alt_dma_program_DMAEND ( ALT_DMA_PROGRAM_t pgm)
Assembles a DMAEND (End) instruction into the microcode program buffer. This instruction uses 1 byte of buffer space.
Parameters
Return values
◆ alt_dma_program_DMAFLUSHP()
ALT_STATUS_CODE alt_dma_program_DMAFLUSHP ( ALT_DMA_PROGRAM_t pgm,
Assembles a DMAFLUSHP (Flush Peripheral) instruction into the microcode program buffer. This instruction uses 2 bytes of buffer space.
Parameters
periphThe peripheral to flush.
Return values
ALT_E_BAD_ARGInvalid peripheral specified.
◆ alt_dma_program_DMAGO()
ALT_STATUS_CODE alt_dma_program_DMAGO ( ALT_DMA_PROGRAM_t pgm,
uint32_t  val,
Assembles a DMAGO (Go) instruction into the microcode program buffer. This instruction uses 6 bytes of buffer space.
Parameters
channelThe stopped channel to act upon.
valThe value to write to the channel program counter register.
secThe security state for the operation.
Return values
ALT_E_BAD_ARGInvalid channel or security specified.
◆ alt_dma_program_DMAKILL()
ALT_STATUS_CODE alt_dma_program_DMAKILL ( ALT_DMA_PROGRAM_t pgm)
Assembles a DMAKILL (Kill) instruction into the microcode program buffer. This instruction uses 1 byte of buffer space.
Parameters
Return values
◆ alt_dma_program_DMALD()
ALT_STATUS_CODE alt_dma_program_DMALD ( ALT_DMA_PROGRAM_t pgm,
Assembles a DMALD (Load) instruction into the microcode program buffer. This instruction uses 1 byte of buffer space.
Parameters
modThe program instruction modifier for the type of transfer. Only ALT_DMA_PROGRAM_INST_MOD_SINGLE and ALT_DMA_PROGRAM_INST_MOD_BURST are valid options.
Return values
ALT_E_BAD_ARGInvalid instruction modifier specified.
◆ alt_dma_program_DMALDP()
ALT_STATUS_CODE alt_dma_program_DMALDP ( ALT_DMA_PROGRAM_t pgm,
Assembles a DMALDP (Load and notify Peripheral) instruction into the microcode program buffer. This instruction uses 2 bytes of buffer space.
Parameters
periphThe peripheral to notify.
Return values
ALT_E_BAD_ARGInvalid instruction modifier or peripheral specified.
◆ alt_dma_program_DMALP()
ALT_STATUS_CODE alt_dma_program_DMALP ( ALT_DMA_PROGRAM_t pgm,
uint32_t  iterations
Assembles a DMALP (Loop) instruction into the microcode program buffer. This instruction uses 2 bytes of buffer space.
Parameters
iterationsThe number of iterations to run for. Valid values are 1 - 256.
Return values
ALT_E_BAD_ARGInvalid iterations specified.
ALT_E_BAD_OPERATIONAll loop registers are in use.
◆ alt_dma_program_DMALPEND()
ALT_STATUS_CODE alt_dma_program_DMALPEND ( ALT_DMA_PROGRAM_t pgm,
Assembles a DMALPEND (Loop End) instruction into the microcode program buffer. This instruction uses 2 bytes of buffer space.
Parameters
modThe program instruction modifier for the loop terminator. Only ALT_DMA_PROGRAM_INST_MOD_NONE, ALT_DMA_PROGRAM_INST_MOD_SINGLE and ALT_DMA_PROGRAM_INST_MOD_BURST are valid options.
Return values
ALT_E_ARG_RANGELoop size is too large to be supported.
ALT_E_BAD_OPERATIONA valid DMALP or DMALPFE was not added to the program buffer before adding this DMALPEND instruction.
◆ alt_dma_program_DMALPFE()
ALT_STATUS_CODE alt_dma_program_DMALPFE ( ALT_DMA_PROGRAM_t pgm)
Assembles a DMALPFE (Loop Forever) instruction into the microcode program buffer. No instruction is added to the buffer but a previous DMALPEND to create an infinite loop.
Parameters
Return values
◆ alt_dma_program_DMAMOV()
ALT_STATUS_CODE alt_dma_program_DMAMOV ( ALT_DMA_PROGRAM_t pgm,
uint32_t  val
Assembles a DMAMOV (Move) instruction into the microcode program buffer. This instruction uses 6 bytes of buffer space.
Parameters
chan_regThe channel non-looping register (ALT_DMA_PROGRAM_REG_SAR, ALT_DMA_PROGRAM_REG_DAR or ALT_DMA_PROGRAM_REG_CCR) to copy the value to.
valThe value to write to the specified register.
Return values
◆ alt_dma_program_DMANOP()
ALT_STATUS_CODE alt_dma_program_DMANOP ( ALT_DMA_PROGRAM_t pgm)
Assembles a DMANOP (No Operation) instruction into the microcode program buffer. This instruction uses 1 byte of buffer space.
Parameters
Return values
◆ alt_dma_program_DMARMB()
ALT_STATUS_CODE alt_dma_program_DMARMB ( ALT_DMA_PROGRAM_t pgm)
Assembles a DMARMB (Read Memory Barrier) instruction into the microcode program buffer. This instruction uses 1 byte of buffer space.
Parameters
Return values
◆ alt_dma_program_DMASEV()
ALT_STATUS_CODE alt_dma_program_DMASEV ( ALT_DMA_PROGRAM_t pgm,
ALT_DMA_EVENT_t  evt
Assembles a DMASEV (Send Event) instruction into the microcode program buffer. This instruction uses 2 byte of buffer space.
Parameters
evtThe event to send.
Return values
ALT_E_BAD_ARGInvalid event specified.
◆ alt_dma_program_DMAST()
ALT_STATUS_CODE alt_dma_program_DMAST ( ALT_DMA_PROGRAM_t pgm,
Assembles a DMAST (Store) instruction into the microcode program buffer. This instruction uses 1 byte of buffer space.
Parameters
Return values
◆ alt_dma_program_DMASTP()
ALT_STATUS_CODE alt_dma_program_DMASTP ( ALT_DMA_PROGRAM_t pgm,
Assembles a DMASTP (Store and notify Peripheral) instruction into the microcode program buffer. This instruction uses 2 bytes of buffer space.
Parameters
Return values
◆ alt_dma_program_DMASTZ()
ALT_STATUS_CODE alt_dma_program_DMASTZ ( ALT_DMA_PROGRAM_t pgm)
Assembles a DMASTZ (Store Zero) instruction into the microcode program buffer. This instruction uses 1 byte of buffer space.
Parameters
Return values
◆ alt_dma_program_DMAWFE()
ALT_STATUS_CODE alt_dma_program_DMAWFE ( ALT_DMA_PROGRAM_t pgm,
bool  invalid
Assembles a DMAWFE (Wait For Event) instruction into the microcode program buffer. This instruction uses 2 byte of buffer space.
Parameters
evtThe event to wait for.
invalidIf invalid is set to true, the instruction will be configured to invalidate the instruction cache for the current DMA thread.
Return values
◆ alt_dma_program_DMAWFP()
ALT_STATUS_CODE alt_dma_program_DMAWFP ( ALT_DMA_PROGRAM_t pgm,
Assembles a DMAWFP (Wait for Peripheral) instruction into the microcode program buffer. This instruction uses 2 bytes of buffer space.
Parameters
periphThe peripheral to wait on.
modThe program instruction modifier for the type of transfer. Only ALT_DMA_PROGRAM_INST_MOD_SINGLE, ALT_DMA_PROGRAM_INST_MOD_BURST, or ALT_DMA_PROGRAM_INST_MOD_PERIPH are valid options.
Return values
ALT_E_BAD_ARGInvalid peripheral or instruction modifier specified.
◆ alt_dma_program_DMAWMB()
ALT_STATUS_CODE alt_dma_program_DMAWMB ( ALT_DMA_PROGRAM_t pgm)
Assembles a DMAWMB (Write Memory Barrier) instruction into the microcode program buffer. This instruction uses 1 byte of buffer space.
Parameters
Return values
◆ alt_dma_program_init()
ALT_STATUS_CODE alt_dma_program_init ( ALT_DMA_PROGRAM_t pgm)
This function initializes a system memory buffer for use as a DMA microcode program buffer. This should be the first API call made on the program buffer type.
Parameters
Return values
◆ alt_dma_program_progress_reg()
ALT_STATUS_CODE alt_dma_program_progress_reg ( ALT_DMA_PROGRAM_t pgm,
uint32_t  current,
uint32_t *  progress
This function reports the number bytes incremented for the register specified. The purpose is to determine the progress of an ongoing DMA transfer.
It is implemented by calculating the difference of the programmed SAR or DAR with the current channel SAR or DAR register value.
Parameters
channelThe channel that the program is running on.
regRegister to change the value for. Valid for only ALT_DMA_PROGRAM_REG_SAR and ALT_DMA_PROGRAM_REG_DAR.
currentThe current snapshot value of the register read from the DMA channel.
progress[out] A pointer to a memory location that will be used to store the number of bytes transfered.
Return values
ALT_E_BAD_ARGThe specified channel is invalid, the specified register is invalid, or the DMAMOV for the specified register has not yet been assembled in the current program buffer.
◆ alt_dma_program_uninit()
ALT_STATUS_CODE alt_dma_program_uninit ( ALT_DMA_PROGRAM_t pgm)
This function verifies that the DMA microcode program buffer is no longer in use and performs any needed uninitialization steps.
Parameters
Return values
◆ alt_dma_program_update_reg()
ALT_STATUS_CODE alt_dma_program_update_reg ( ALT_DMA_PROGRAM_t pgm,
uint32_t  val
This function updates a pre-existing DMAMOV value affecting the SAR or DAR registers. This allows for pre-assembled programs that can be used on different source and destination addresses.
Parameters
valThe value to update to.
Return values
ALT_E_BAD_ARGThe specified register is invalid or the DMAMOV for the specified register has not yet been assembled in the current program buffer.
◆ alt_dma_program_validate()
ALT_STATUS_CODE alt_dma_program_validate ( const ALT_DMA_PROGRAM_t pgm)
This function validate that the given DMA microcode program buffer contains a well formed program. If caches are enabled, the program buffer contents will be cleaned to RAM.
Parameters
Return values
ALT_E_SUCCESSThe given program is well formed.
ALT_E_ERRORThe given program is not well formed.
ALT_E_TMOThe cache operation timed out.
