RTEMS 5.2
Data Structures | Macros | Typedefs | Enumerations | Functions
gmac.h File Reference
#include "chip.h"
#include <stdint.h>
struct  _GmacRxDescriptor
union  _GmacRxDescriptor::_GmacRxAddr
struct  _GmacRxDescriptor::_GmacRxAddr::_GmacRxAddrBM
union  _GmacRxDescriptor::_GmacRxStatus
struct  _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM
struct  _GmacTxDescriptor
union  _GmacTxDescriptor::_GmacTxStatus
struct  _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM
#define NUM_GMAC_QUEUES   3
#define GMAC_DUPLEX_HALF   0
 Board GMAC base address.
#define GMAC_DUPLEX_FULL   1
#define GMAC_SPEED_10M   0
#define GMAC_SPEED_100M   1
#define GMAC_SPEED_1000M   2
#define GMAC_ADDRESS_MASK   ((unsigned int)0xFFFFFFFC)
#define GMAC_LENGTH_FRAME   ((unsigned int)0x3FFF)
#define GMAC_RX_OWNERSHIP_BIT   (1u << 0)
#define GMAC_RX_WRAP_BIT   (1u << 1)
#define GMAC_RX_SOF_BIT   (1u << 14)
#define GMAC_RX_EOF_BIT   (1u << 15)
#define GMAC_TX_LAST_BUFFER_BIT   (1u << 15)
#define GMAC_TX_WRAP_BIT   (1u << 30)
#define GMAC_TX_USED_BIT   (1u << 31)
#define GMAC_TX_RLE_BIT   (1u << 29)
#define GMAC_TX_UND_BIT   (1u << 28)
#define GMAC_TX_ERR_BIT   (1u << 27)
#define GMAC_TX_ERR_BITS    (GMAC_TX_RLE_BIT | GMAC_TX_UND_BIT | GMAC_TX_ERR_BIT)
#define GMAC_INT_RX_BITS    (GMAC_IER_RCOMP | GMAC_IER_RXUBR | GMAC_IER_ROVR)
#define GMAC_INT_TX_ERR_BITS    (GMAC_IER_TUR | GMAC_IER_RLEX | GMAC_IER_TFC | GMAC_IER_HRESP)
#define GMAC_INT_TX_BITS    (GMAC_INT_TX_ERR_BITS | GMAC_IER_TCOMP)
#define GMAC_INT_RX_STATUS_BITS    (GMAC_ISR_RCOMP | GMAC_ISR_RXUBR | GMAC_ISR_ROVR)
#define GMAC_INT_TX_STATUS_ERR_BITS    (GMAC_ISR_TUR | GMAC_ISR_RLEX | GMAC_ISR_TFC | GMAC_ISR_HRESP)
#define GMAC_RXDESC_ST_CKSUM_RESULT_NOT_CHECKED   (0)
#define GMAC_RXDESC_ST_CKSUM_RESULT_IP_CHECKED   (1)
#define GMAC_RXDESC_ST_CKSUM_RESULT_IP_AND_TCP_CHECKED   (2)
#define GMAC_RXDESC_ST_CKSUM_RESULT_IP_AND_UDP_CHECKED   (3)
typedef struct _GmacRxDescriptor sGmacRxDescriptor
typedef struct _GmacTxDescriptor sGmacTxDescriptor
enum  gmacQueList_t { GMAC_QUE_0 = 0 , GMAC_QUE_1 = 1 , GMAC_QUE_2 = 2 }
uint8_t GMAC_IsIdle (Gmac *pGmac)
void GMAC_PHYMaintain (Gmac *pGmac, uint8_t bPhyAddr, uint8_t bRegAddr, uint8_t bRW, uint16_t wData)
uint16_t GMAC_PHYData (Gmac *pGmac)
void GMAC_ClearStatistics (Gmac *pGmac)
void GMAC_IncreaseStatistics (Gmac *pGmac)
void GMAC_StatisticsWriteEnable (Gmac *pGmac, uint8_t bEnaDis)
uint8_t GMAC_SetMdcClock (Gmac *pGmac, uint32_t mck)
 Set MDC clock according to current board clock. Per 802.3, MDC should be less then 2.5MHz. More...
void GMAC_EnableMdio (Gmac *pGmac)
 Enable MDI with PHY. More...
void GMAC_DisableMdio (Gmac *pGmac)
void GMAC_EnableMII (Gmac *pGmac)
 Enable MII mode for GMAC, called once after auto negotiate. More...
void GMAC_EnableRMII (Gmac *pGmac)
void GMAC_EnableGMII (Gmac *pGmac)
 Enable GMII mode for GMAC, called once after auto negotiate. More...
void GMAC_SetLinkSpeed (Gmac *pGmac, uint8_t speed, uint8_t fullduplex)
 Setup the GMAC for the link : speed 100M/10M and Full/Half duplex. More...
void GMAC_EnableIt (Gmac *pGmac, uint32_t dwSources, gmacQueList_t queueIdx)
void GMAC_EnableAllQueueIt (Gmac *pGmac, uint32_t dwSources)
void GMAC_DisableIt (Gmac *pGmac, uint32_t dwSources, gmacQueList_t queueIdx)
void GMAC_DisableAllQueueIt (Gmac *pGmac, uint32_t dwSources)
uint32_t GMAC_GetItStatus (Gmac *pGmac, gmacQueList_t queueIdx)
uint32_t GMAC_GetItMask (Gmac *pGmac, gmacQueList_t queueIdx)
uint32_t GMAC_GetTxStatus (Gmac *pGmac)
void GMAC_ClearTxStatus (Gmac *pGmac, uint32_t dwStatus)
uint32_t GMAC_GetRxStatus (Gmac *pGmac)
void GMAC_ClearRxStatus (Gmac *pGmac, uint32_t dwStatus)
void GMAC_ReceiveEnable (Gmac *pGmac, uint8_t bEnaDis)
void GMAC_TransmitEnable (Gmac *pGmac, uint8_t bEnaDis)
uint32_t GMAC_SetLocalLoopBack (Gmac *pGmac)
 set local loop back More...
void GMAC_SetRxQueue (Gmac *pGmac, uint32_t dwAddr, gmacQueList_t queueIdx)
uint32_t GMAC_GetRxQueue (Gmac *pGmac, gmacQueList_t queueIdx)
void GMAC_SetTxQueue (Gmac *pGmac, uint32_t dwAddr, gmacQueList_t queueIdx)
uint32_t GMAC_GetTxQueue (Gmac *pGmac, gmacQueList_t queueIdx)
void GMAC_NetworkControl (Gmac *pGmac, uint32_t bmNCR)
uint32_t GMAC_GetNetworkControl (Gmac *pGmac)
void GMAC_SetAddress (Gmac *pGmac, uint8_t bIndex, uint8_t *pMacAddr)
void GMAC_SetAddress32 (Gmac *pGmac, uint8_t bIndex, uint32_t dwMacT, uint32_t dwMacB)
void GMAC_SetAddress64 (Gmac *pGmac, uint8_t bIndex, uint64_t ddwMac)
void GMAC_Configure (Gmac *pGmac, uint32_t dwCfg)
void GMAC_SetDMAConfig (Gmac *pGmac, uint32_t dwDmaCfg, gmacQueList_t queueIdx)
uint32_t GMAC_GetDMAConfig (Gmac *pGmac, gmacQueList_t queueIdx)
uint32_t GMAC_GetConfigure (Gmac *pGmac)
void GMAC_TransmissionStart (Gmac *pGmac)
void GMAC_TransmissionHalt (Gmac *pGmac)
void GMAC_EnableRGMII (Gmac *pGmac, uint32_t duplex, uint32_t speed)
 Enable RGMII mode for GMAC, called once after auto negotiate. More...
void GMAC_ClearScreener1Reg (Gmac *pGmac, gmacQueList_t queueIdx)
void GMAC_WriteScreener1Reg (Gmac *pGmac, gmacQueList_t queueIdx, uint32_t regVal)
void GMAC_ClearScreener2Reg (Gmac *pGmac, gmacQueList_t queueIdx)
void GMAC_WriteScreener2Reg (Gmac *pGmac, gmacQueList_t queueIdx, uint32_t regVal)
void GMAC_WriteEthTypeReg (Gmac *pGmac, gmacQueList_t queueIdx, uint16_t etherType)
void GMAC_WriteCompareReg (Gmac *pGmac, gmacQueList_t queueIdx, uint32_t c0Reg, uint16_t c1Reg)
void GMAC_EnableCbsQueA (Gmac *pGmac)
void GMAC_DisableCbsQueA (Gmac *pGmac)
void GMAC_EnableCbsQueB (Gmac *pGmac)
void GMAC_DisableCbsQueB (Gmac *pGmac)
void GMAC_ConfigIdleSlopeA (Gmac *pGmac, uint32_t idleSlopeA)
void GMAC_ConfigIdleSlopeB (Gmac *pGmac, uint32_t idleSlopeB)
void GMAC_SetTsuTmrIncReg (Gmac *pGmac, uint32_t nanoSec)
uint16_t GMAC_GetPtpEvtMsgRxdMsbSec (Gmac *pGmac)
uint32_t GMAC_GetPtpEvtMsgRxdLsbSec (Gmac *pGmac)
uint32_t GMAC_GetPtpEvtMsgRxdNanoSec (Gmac *pGmac)
void GMAC_SetTsuCompare (Gmac *pGmac, uint32_t seconds47, uint32_t seconds31, uint32_t nanosec)
void GMAC_SetTsuCompareNanoSec (Gmac *pGmac, uint32_t nanosec)
void GMAC_SetTsuCompareSec31 (Gmac *pGmac, uint32_t seconds31)
void GMAC_SetTsuCompareSec47 (Gmac *pGmac, uint16_t seconds47)
uint32_t GMAC_GetRxEvtFrameSec (Gmac *pGmac)
uint32_t GMAC_GetRxEvtFrameNsec (Gmac *pGmac)
uint32_t GMAC_GetRxPeerEvtFrameSec (Gmac *pGmac)
uint32_t GMAC_GetRxPeerEvtFrameNsec (Gmac *pGmac)
uint32_t GMAC_GetTxEvtFrameSec (Gmac *pGmac)
uint32_t GMAC_GetTxEvtFrameNsec (Gmac *pGmac)
uint32_t GMAC_GetTxPeerEvtFrameSec (Gmac *pGmac)
uint32_t GMAC_GetTxPeerEvtFrameNsec (Gmac *pGmac)
