RTEMS 5.2
Macros | Functions
flashd.c File Reference
#include "chip.h"
#include <assert.h>
#define GPNVM_NUM_MAX   9
void FLASHD_Initialize (uint32_t dwMCk, uint32_t dwUseIAP)
 Initializes the flash driver. More...
uint32_t FLASHD_Erase (uint32_t dwAddress)
 Erases the entire flash. More...
uint32_t FLASHD_EraseSector (uint32_t dwAddress)
 Erases flash by sector. More...
uint32_t FLASHD_ErasePages (uint32_t dwAddress, uint32_t dwPageNum)
 Erases flash by pages. More...
uint32_t FLASHD_Write (uint32_t dwAddress, const void *pvBuffer, uint32_t dwSize)
 Writes a data buffer in the internal flash. More...
uint32_t FLASHD_Lock (uint32_t start, uint32_t end, uint32_t *pActualStart, uint32_t *pActualEnd)
 Locks all the regions in the given address range. The actual lock range is reported through two output parameters. More...
uint32_t FLASHD_Unlock (uint32_t start, uint32_t end, uint32_t *pActualStart, uint32_t *pActualEnd)
 Unlocks all the regions in the given address range. The actual unlock range is reported through two output parameters. More...
uint32_t FLASHD_IsLocked (uint32_t start, uint32_t end)
 Returns the number of locked regions inside the given address range. More...
uint32_t FLASHD_IsGPNVMSet (uint8_t ucGPNVM)
 Check if the given GPNVM bit is set or not. More...
uint32_t FLASHD_SetGPNVM (uint8_t ucGPNVM)
 Sets the selected GPNVM bit. More...
uint32_t FLASHD_ClearGPNVM (uint8_t ucGPNVM)
 Clears the selected GPNVM bit. More...
 __attribute__ ((section(".ramfunc")))
 Read the unique ID. More...
The flash driver provides the unified interface for flash program operations.
◆ __attribute__()
__attribute__ ( (section(".ramfunc"))  )
Read the unique ID.
Parameters
pdwUniqueIDpointer on a 4bytes char containing the unique ID value.
Returns
0 if successful; otherwise returns an error code.
◆ FLASHD_ClearGPNVM()
uint32_t FLASHD_ClearGPNVM ( uint8_t  ucGPNVM)
Parameters
gpnvmGPNVM bit index.
Returns
◆ FLASHD_Erase()
uint32_t FLASHD_Erase ( uint32_t  dwAddress)
Parameters
dwAddressFlash start address.
Returns
◆ FLASHD_ErasePages()
uint32_t FLASHD_ErasePages ( uint32_t  dwAddress,
uint32_t  dwPageNum
Parameters
dwAddressStart address of be erased pages.
dwPageNumNumber of pages to be erased with EPA command (4, 8, 16, 32)
Returns
◆ FLASHD_EraseSector()
uint32_t FLASHD_EraseSector ( uint32_t  dwAddress)
Parameters
dwAddressStart address of be erased sector.
Returns
◆ FLASHD_Initialize()
void FLASHD_Initialize ( uint32_t  dwMCk,
uint32_t  dwUseIAP
Parameters
dwMCkMaster clock frequency in Hz.
dwUseIAP0: use EEFC controller interface, 1: use IAP interface. dwUseIAP should be set to 1 when running out of flash.
◆ FLASHD_IsGPNVMSet()
uint32_t FLASHD_IsGPNVMSet ( uint8_t  ucGPNVM)
Parameters
Returns
1 if the given GPNVM bit is currently set; otherwise returns 0.
◆ FLASHD_IsLocked()
uint32_t FLASHD_IsLocked ( uint32_t  start,
uint32_t  end
Parameters
startStart address of range
endEnd address of range.
◆ FLASHD_Lock()
uint32_t FLASHD_Lock ( uint32_t  start,
uint32_t  end,
uint32_t *  pActualStart,
uint32_t *  pActualEnd
Parameters
startStart address of lock range.
endEnd address of lock range.
pActualStartStart address of the actual lock range (optional).
pActualEndEnd address of the actual lock range (optional).
Returns
0 if successful, otherwise returns an error code.
◆ FLASHD_SetGPNVM()
uint32_t FLASHD_SetGPNVM ( uint8_t  ucGPNVM)
Parameters
Returns
◆ FLASHD_Unlock()
uint32_t FLASHD_Unlock ( uint32_t  start,
uint32_t  end,
Parameters
startStart address of unlock range.
endEnd address of unlock range.
pActualStartStart address of the actual unlock range (optional).
pActualEndEnd address of the actual unlock range (optional).
Returns
◆ FLASHD_Write()
uint32_t FLASHD_Write ( uint32_t  dwAddress,
const void *  pvBuffer,
uint32_t  dwSize
Note
This function works in polling mode, and thus only returns when the data has been effectively written.
Parameters
addressWrite address.
pBufferData buffer.
sizeSize of data buffer in bytes.
Returns
