RTEMS 5.2
Macros | Functions
cs2100.h File Reference
#include "board.h"
#define CS2100_SLAVE_ADDRESS   0x4E
#define CS2100_REG_ID   0x01
#define CS2100_REG_CTRL   0x02
#define CS2100_REG_DEV_CFG1   0x03
#define CS2100_REG_CFG   0x05
#define CS2100_REG_32_BIT_RATIO_1   0x06
#define CS2100_REG_32_BIT_RATIO_2   0x07
#define CS2100_REG_32_BIT_RATIO_3   0x08
#define CS2100_REG_32_BIT_RATIO_4   0x09
#define CS2100_REG_FUNC_CFG1   0x16
#define CS2100_REG_FUNC_CFG2   0x17
#define CS2100_REG_FUNC_CFG3   0x1E
uint16_t CS2100_Read (Twid *pTwid, uint32_t device, uint32_t regAddr)
void CS2100_Write (Twid *pTwid, uint32_t device, uint32_t regAddr, uint16_t data)
uint8_t CS2100_Init (Twid *pTwid, uint32_t device, uint32_t PCK)
Implementation WM8904 driver.
◆ CS2100_REG_32_BIT_RATIO_1
Power management control 0 register
◆ CS2100_REG_32_BIT_RATIO_2
◆ CS2100_REG_32_BIT_RATIO_3
◆ CS2100_REG_32_BIT_RATIO_4
◆ CS2100_REG_CFG
Bias control 1 register
◆ CS2100_REG_CTRL
VMID control 0 register
◆ CS2100_REG_DEV_CFG1
MIC Bias control 0 register
◆ CS2100_REG_FUNC_CFG1
Power management control 2 register
◆ CS2100_REG_FUNC_CFG2
Power management control 3 register
◆ CS2100_REG_FUNC_CFG3
◆ CS2100_REG_ID
ID and Rev register
