RTEMS 5.2
cpustdatomic.h
1
7/*
8 * COPYRIGHT (c) 2013 Deng Hengyi.
9 * Copyright (c) 2015 embedded brains GmbH.
10 *
11 * The license and distribution terms for this file may be
12 * found in the file LICENSE in this distribution or at
13 * http://www.rtems.org/license/LICENSE.
14 */
15
16#ifndef _RTEMS_SCORE_CPUSTDATOMIC_H
17#define _RTEMS_SCORE_CPUSTDATOMIC_H
18
20
31#ifdef RTEMS_SMP
32 #if defined(__cplusplus) \
33 && (__GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 9))
34 /*
35 * The GCC 4.9 ships its own <stdatomic.h> which is not C++ compatible. The
36 * suggested solution was to include <atomic> in case C++ is used. This works
37 * at least with GCC 4.9. See also:
38 *
39 * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60932
40 * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60940
41 */
42 #include <atomic>
43 #define _RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC
44 #else
45 #include <stdatomic.h>
46 #define _RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC
47 #endif
48#else
49 #include <rtems/score/isrlevel.h>
50#endif
51
52#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
53
54typedef std::atomic_uint CPU_atomic_Uint;
55
56typedef std::atomic_ulong CPU_atomic_Ulong;
57
58typedef std::atomic_uintptr_t CPU_atomic_Uintptr;
59
60typedef std::atomic_flag CPU_atomic_Flag;
61
62typedef std::memory_order CPU_atomic_Order;
63
64#define CPU_ATOMIC_ORDER_RELAXED std::memory_order_relaxed
65
66#define CPU_ATOMIC_ORDER_ACQUIRE std::memory_order_acquire
67
68#define CPU_ATOMIC_ORDER_RELEASE std::memory_order_release
69
70#define CPU_ATOMIC_ORDER_ACQ_REL std::memory_order_acq_rel
71
72#define CPU_ATOMIC_ORDER_SEQ_CST std::memory_order_seq_cst
73
74#define CPU_ATOMIC_INITIALIZER_UINT( value ) ATOMIC_VAR_INIT( value )
75
76#define CPU_ATOMIC_INITIALIZER_ULONG( value ) ATOMIC_VAR_INIT( value )
77
78#define CPU_ATOMIC_INITIALIZER_UINTPTR( value ) ATOMIC_VAR_INIT( value )
79
80#define CPU_ATOMIC_INITIALIZER_FLAG ATOMIC_FLAG_INIT
81
82#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
83
84typedef atomic_uint CPU_atomic_Uint;
85
86typedef atomic_ulong CPU_atomic_Ulong;
87
88typedef atomic_uintptr_t CPU_atomic_Uintptr;
89
90typedef atomic_flag CPU_atomic_Flag;
91
92typedef memory_order CPU_atomic_Order;
93
94#define CPU_ATOMIC_ORDER_RELAXED memory_order_relaxed
95
96#define CPU_ATOMIC_ORDER_ACQUIRE memory_order_acquire
97
98#define CPU_ATOMIC_ORDER_RELEASE memory_order_release
99
100#define CPU_ATOMIC_ORDER_ACQ_REL memory_order_acq_rel
101
102#define CPU_ATOMIC_ORDER_SEQ_CST memory_order_seq_cst
103
104#define CPU_ATOMIC_INITIALIZER_UINT( value ) ATOMIC_VAR_INIT( value )
105
106#define CPU_ATOMIC_INITIALIZER_ULONG( value ) ATOMIC_VAR_INIT( value )
107
108#define CPU_ATOMIC_INITIALIZER_UINTPTR( value ) ATOMIC_VAR_INIT( value )
109
110#define CPU_ATOMIC_INITIALIZER_FLAG ATOMIC_FLAG_INIT
111
112#else
113
114typedef unsigned int CPU_atomic_Uint;
115
116typedef unsigned long CPU_atomic_Ulong;
117
118typedef uintptr_t CPU_atomic_Uintptr;
119
120typedef bool CPU_atomic_Flag;
121
122typedef int CPU_atomic_Order;
123
124#define CPU_ATOMIC_ORDER_RELAXED 0
125
126#define CPU_ATOMIC_ORDER_ACQUIRE 2
127
128#define CPU_ATOMIC_ORDER_RELEASE 3
129
130#define CPU_ATOMIC_ORDER_ACQ_REL 4
131
132#define CPU_ATOMIC_ORDER_SEQ_CST 5
133
134#define CPU_ATOMIC_INITIALIZER_UINT( value ) ( value )
135
136#define CPU_ATOMIC_INITIALIZER_ULONG( value ) ( value )
137
138#define CPU_ATOMIC_INITIALIZER_UINTPTR( value ) ( value )
139
140#define CPU_ATOMIC_INITIALIZER_FLAG false
141
142#endif
143
149static inline void _CPU_atomic_Fence( CPU_atomic_Order order )
150{
151#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
152 std::atomic_thread_fence( order );
153#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
154 atomic_thread_fence( order );
155#else
156 (void) order;
158#endif
159}
160
167static inline void _CPU_atomic_Init_uint( CPU_atomic_Uint *obj, unsigned int desired )
168{
169#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
170 obj->store( desired );
171#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
172 atomic_init( obj, desired );
173#else
174 *obj = desired;
175#endif
176}
177
184static inline void _CPU_atomic_Init_ulong( CPU_atomic_Ulong *obj, unsigned long desired )
185{
186#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
187 obj->store( desired );
188#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
189 atomic_init( obj, desired );
190#else
191 *obj = desired;
192#endif
193}
194
201static inline void _CPU_atomic_Init_uintptr( CPU_atomic_Uintptr *obj, uintptr_t desired )
202{
203#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
204 obj->store( desired );
205#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
206 atomic_init( obj, desired );
207#else
208 *obj = desired;
209#endif
210}
211
220static inline unsigned int _CPU_atomic_Load_uint( const CPU_atomic_Uint *obj, CPU_atomic_Order order )
221{
222#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
223 return obj->load( order );
224#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
225 return atomic_load_explicit( obj, order );
226#else
227 unsigned int val;
228
229 (void) order;
230 val = *obj;
232
233 return val;
234#endif
235}
236
245static inline unsigned long _CPU_atomic_Load_ulong( const CPU_atomic_Ulong *obj, CPU_atomic_Order order )
246{
247#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
248 return obj->load( order );
249#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
250 return atomic_load_explicit( obj, order );
251#else
252 unsigned long val;
253
254 (void) order;
255 val = *obj;
257
258 return val;
259#endif
260}
261
270static inline uintptr_t _CPU_atomic_Load_uintptr( const CPU_atomic_Uintptr *obj, CPU_atomic_Order order )
271{
272#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
273 return obj->load( order );
274#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
275 return atomic_load_explicit( obj, order );
276#else
277 uintptr_t val;
278
279 (void) order;
280 val = *obj;
282
283 return val;
284#endif
285}
286
294static inline void _CPU_atomic_Store_uint( CPU_atomic_Uint *obj, unsigned int desired, CPU_atomic_Order order )
295{
296#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
297 obj->store( desired, order );
298#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
299 atomic_store_explicit( obj, desired, order );
300#else
301 (void) order;
303 *obj = desired;
304#endif
305}
306
314static inline void _CPU_atomic_Store_ulong( CPU_atomic_Ulong *obj, unsigned long desired, CPU_atomic_Order order )
315{
316#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
317 obj->store( desired, order );
318#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
319 atomic_store_explicit( obj, desired, order );
320#else
321 (void) order;
323 *obj = desired;
324#endif
325}
326
334static inline void _CPU_atomic_Store_uintptr( CPU_atomic_Uintptr *obj, uintptr_t desired, CPU_atomic_Order order )
335{
336#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
337 obj->store( desired, order );
338#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
339 atomic_store_explicit( obj, desired, order );
340#else
341 (void) order;
343 *obj = desired;
344#endif
345}
346
356static inline unsigned int _CPU_atomic_Fetch_add_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
357{
358#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
359 return obj->fetch_add( arg, order );
360#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
361 return atomic_fetch_add_explicit( obj, arg, order );
362#else
363 unsigned int val;
364 ISR_Level level;
365
366 (void) order;
367 _ISR_Local_disable( level );
368 val = *obj;
369 *obj = val + arg;
370 _ISR_Local_enable( level );
371
372 return val;
373#endif
374}
375
385static inline unsigned long _CPU_atomic_Fetch_add_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
386{
387#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
388 return obj->fetch_add( arg, order );
389#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
390 return atomic_fetch_add_explicit( obj, arg, order );
391#else
392 unsigned long val;
393 ISR_Level level;
394
395 (void) order;
396 _ISR_Local_disable( level );
397 val = *obj;
398 *obj = val + arg;
399 _ISR_Local_enable( level );
400
401 return val;
402#endif
403}
404
414static inline uintptr_t _CPU_atomic_Fetch_add_uintptr( CPU_atomic_Uintptr *obj, uintptr_t arg, CPU_atomic_Order order )
415{
416#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
417 return obj->fetch_add( arg, order );
418#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
419 return atomic_fetch_add_explicit( obj, arg, order );
420#else
421 uintptr_t val;
422 ISR_Level level;
423
424 (void) order;
425 _ISR_Local_disable( level );
426 val = *obj;
427 *obj = val + arg;
428 _ISR_Local_enable( level );
429
430 return val;
431#endif
432}
433
443static inline unsigned int _CPU_atomic_Fetch_sub_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
444{
445#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
446 return obj->fetch_sub( arg, order );
447#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
448 return atomic_fetch_sub_explicit( obj, arg, order );
449#else
450 unsigned int val;
451 ISR_Level level;
452
453 (void) order;
454 _ISR_Local_disable( level );
455 val = *obj;
456 *obj = val - arg;
457 _ISR_Local_enable( level );
458
459 return val;
460#endif
461}
462
472static inline unsigned long _CPU_atomic_Fetch_sub_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
473{
474#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
475 return obj->fetch_sub( arg, order );
476#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
477 return atomic_fetch_sub_explicit( obj, arg, order );
478#else
479 unsigned long val;
480 ISR_Level level;
481
482 (void) order;
483 _ISR_Local_disable( level );
484 val = *obj;
485 *obj = val - arg;
486 _ISR_Local_enable( level );
487
488 return val;
489#endif
490}
491
501static inline uintptr_t _CPU_atomic_Fetch_sub_uintptr( CPU_atomic_Uintptr *obj, uintptr_t arg, CPU_atomic_Order order )
502{
503#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
504 return obj->fetch_sub( arg, order );
505#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
506 return atomic_fetch_sub_explicit( obj, arg, order );
507#else
508 uintptr_t val;
509 ISR_Level level;
510
511 (void) order;
512 _ISR_Local_disable( level );
513 val = *obj;
514 *obj = val - arg;
515 _ISR_Local_enable( level );
516
517 return val;
518#endif
519}
520
530static inline unsigned int _CPU_atomic_Fetch_or_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
531{
532#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
533 return obj->fetch_or( arg, order );
534#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
535 return atomic_fetch_or_explicit( obj, arg, order );
536#else
537 unsigned int val;
538 ISR_Level level;
539
540 (void) order;
541 _ISR_Local_disable( level );
542 val = *obj;
543 *obj = val | arg;
544 _ISR_Local_enable( level );
545
546 return val;
547#endif
548}
549
559static inline unsigned long _CPU_atomic_Fetch_or_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
560{
561#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
562 return obj->fetch_or( arg, order );
563#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
564 return atomic_fetch_or_explicit( obj, arg, order );
565#else
566 unsigned long val;
567 ISR_Level level;
568
569 (void) order;
570 _ISR_Local_disable( level );
571 val = *obj;
572 *obj = val | arg;
573 _ISR_Local_enable( level );
574
575 return val;
576#endif
577}
578
588static inline uintptr_t _CPU_atomic_Fetch_or_uintptr( CPU_atomic_Uintptr *obj, uintptr_t arg, CPU_atomic_Order order )
589{
590#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
591 return obj->fetch_or( arg, order );
592#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
593 return atomic_fetch_or_explicit( obj, arg, order );
594#else
595 uintptr_t val;
596 ISR_Level level;
597
598 (void) order;
599 _ISR_Local_disable( level );
600 val = *obj;
601 *obj = val | arg;
602 _ISR_Local_enable( level );
603
604 return val;
605#endif
606}
607
617static inline unsigned int _CPU_atomic_Fetch_and_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
618{
619#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
620 return obj->fetch_and( arg, order );
621#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
622 return atomic_fetch_and_explicit( obj, arg, order );
623#else
624 unsigned int val;
625 ISR_Level level;
626
627 (void) order;
628 _ISR_Local_disable( level );
629 val = *obj;
630 *obj = val & arg;
631 _ISR_Local_enable( level );
632
633 return val;
634#endif
635}
636
646static inline unsigned long _CPU_atomic_Fetch_and_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
647{
648#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
649 return obj->fetch_and( arg, order );
650#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
651 return atomic_fetch_and_explicit( obj, arg, order );
652#else
653 unsigned long val;
654 ISR_Level level;
655
656 (void) order;
657 _ISR_Local_disable( level );
658 val = *obj;
659 *obj = val & arg;
660 _ISR_Local_enable( level );
661
662 return val;
663#endif
664}
665
675static inline uintptr_t _CPU_atomic_Fetch_and_uintptr( CPU_atomic_Uintptr *obj, uintptr_t arg, CPU_atomic_Order order )
676{
677#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
678 return obj->fetch_and( arg, order );
679#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
680 return atomic_fetch_and_explicit( obj, arg, order );
681#else
682 uintptr_t val;
683 ISR_Level level;
684
685 (void) order;
686 _ISR_Local_disable( level );
687 val = *obj;
688 *obj = val & arg;
689 _ISR_Local_enable( level );
690
691 return val;
692#endif
693}
694
704static inline unsigned int _CPU_atomic_Exchange_uint( CPU_atomic_Uint *obj, unsigned int desired, CPU_atomic_Order order )
705{
706#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
707 return obj->exchange( desired, order );
708#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
709 return atomic_exchange_explicit( obj, desired, order );
710#else
711 unsigned int val;
712 ISR_Level level;
713
714 (void) order;
715 _ISR_Local_disable( level );
716 val = *obj;
717 *obj = desired;
718 _ISR_Local_enable( level );
719
720 return val;
721#endif
722}
723
733static inline unsigned long _CPU_atomic_Exchange_ulong( CPU_atomic_Ulong *obj, unsigned long desired, CPU_atomic_Order order )
734{
735#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
736 return obj->exchange( desired, order );
737#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
738 return atomic_exchange_explicit( obj, desired, order );
739#else
740 unsigned long val;
741 ISR_Level level;
742
743 (void) order;
744 _ISR_Local_disable( level );
745 val = *obj;
746 *obj = desired;
747 _ISR_Local_enable( level );
748
749 return val;
750#endif
751}
752
762static inline uintptr_t _CPU_atomic_Exchange_uintptr( CPU_atomic_Uintptr *obj, uintptr_t desired, CPU_atomic_Order order )
763{
764#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
765 return obj->exchange( desired, order );
766#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
767 return atomic_exchange_explicit( obj, desired, order );
768#else
769 uintptr_t val;
770 ISR_Level level;
771
772 (void) order;
773 _ISR_Local_disable( level );
774 val = *obj;
775 *obj = desired;
776 _ISR_Local_enable( level );
777
778 return val;
779#endif
780}
781
799static inline bool _CPU_atomic_Compare_exchange_uint( CPU_atomic_Uint *obj, unsigned int *expected, unsigned int desired, CPU_atomic_Order succ, CPU_atomic_Order fail )
800{
801#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
802 return obj->compare_exchange_strong( *expected, desired, succ, fail );
803#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
804 return atomic_compare_exchange_strong_explicit( obj, expected, desired, succ, fail );
805#else
806 bool success;
807 ISR_Level level;
808 unsigned int actual;
809
810 (void) succ;
811 (void) fail;
812 _ISR_Local_disable( level );
813 actual = *obj;
814 success = ( actual == *expected );
815 if ( success ) {
816 *obj = desired;
817 } else {
818 *expected = actual;
819 }
820 _ISR_Local_enable( level );
821
822 return success;
823#endif
824}
825
843static inline bool _CPU_atomic_Compare_exchange_ulong( CPU_atomic_Ulong *obj, unsigned long *expected, unsigned long desired, CPU_atomic_Order succ, CPU_atomic_Order fail )
844{
845#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
846 return obj->compare_exchange_strong( *expected, desired, succ, fail );
847#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
848 return atomic_compare_exchange_strong_explicit( obj, expected, desired, succ, fail );
849#else
850 bool success;
851 ISR_Level level;
852 unsigned long actual;
853
854 (void) succ;
855 (void) fail;
856 _ISR_Local_disable( level );
857 actual = *obj;
858 success = ( actual == *expected );
859 if ( success ) {
860 *obj = desired;
861 } else {
862 *expected = actual;
863 }
864 _ISR_Local_enable( level );
865
866 return success;
867#endif
868}
869
887static inline bool _CPU_atomic_Compare_exchange_uintptr( CPU_atomic_Uintptr *obj, uintptr_t *expected, uintptr_t desired, CPU_atomic_Order succ, CPU_atomic_Order fail )
888{
889#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
890 return obj->compare_exchange_strong( *expected, desired, succ, fail );
891#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
892 return atomic_compare_exchange_strong_explicit( obj, expected, desired, succ, fail );
893#else
894 bool success;
895 ISR_Level level;
896 uintptr_t actual;
897
898 (void) succ;
899 (void) fail;
900 _ISR_Local_disable( level );
901 actual = *obj;
902 success = ( actual == *expected );
903 if ( success ) {
904 *obj = desired;
905 } else {
906 *expected = actual;
907 }
908 _ISR_Local_enable( level );
909
910 return success;
911#endif
912}
913
920static inline void _CPU_atomic_Flag_clear( CPU_atomic_Flag *obj, CPU_atomic_Order order )
921{
922#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
923 obj->clear( order );
924#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
925 atomic_flag_clear_explicit( obj, order );
926#else
927 (void) order;
928 *obj = false;
929#endif
930}
931
941static inline bool _CPU_atomic_Flag_test_and_set( CPU_atomic_Flag *obj, CPU_atomic_Order order )
942{
943#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
944 return obj->test_and_set( order );
945#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
946 return atomic_flag_test_and_set_explicit( obj, order );
947#else
948 bool flag;
949 ISR_Level level;
950
951 (void) order;
952 _ISR_Local_disable( level );
953 flag = *obj;
954 *obj = true;
955 _ISR_Local_enable( level );
956
957 return flag;
958#endif
959}
960
963#endif /* _RTEMS_SCORE_CPUSTDATOMIC_H */
Basic Definitions.
#define RTEMS_COMPILER_MEMORY_BARRIER()
Definition: basedefs.h:77
#define _ISR_Local_disable(_level)
Disables interrupts on this processor.
Definition: isrlevel.h:57
#define _ISR_Local_enable(_level)
Enables interrupts on this processor.
Definition: isrlevel.h:74
uint32_t ISR_Level
Definition: isrlevel.h:41
ISR Level Type.
