RTEMS 5.2
Information About the Thread Stack Handler. More...
#include <rtems/score/basedefs.h>Go to the source code of this file.
| struct | Stack_Control |
| #define | STACK_MINIMUM_SIZE CPU_STACK_MINIMUM_SIZE |
Typedefs | |
| typedef void(* | Stack_Allocator_initialize) (size_t stack_space_size) |
| The stack allocator initialization handler. More... | |
| typedef void *(* | Stack_Allocator_allocate) (size_t stack_size) |
| Stack allocator allocate handler. More... | |
| typedef void(* | Stack_Allocator_free) (void *addr) |
| Stack allocator free handler. More... | |
| typedef void *(* | Stack_Allocator_allocate_for_idle) (uint32_t cpu, size_t stack_size) |
| Stack allocator allocate for idle handler. More... | |
| uint32_t | rtems_minimum_stack_size |
| The minimum stack size. More... | |
| const uintptr_t | _Stack_Space_size |
| The configured stack space size. More... | |
| const bool | _Stack_Allocator_avoids_workspace |
| Indicates if the stack allocator avoids the workspace. More... | |
| const Stack_Allocator_initialize | _Stack_Allocator_initialize |
| const Stack_Allocator_allocate | _Stack_Allocator_allocate |
| The stack allocator allocate handler. More... | |
| const Stack_Allocator_free | _Stack_Allocator_free |
| The stack allocator free handler. More... | |
| const Stack_Allocator_allocate_for_idle | _Stack_Allocator_allocate_for_idle |
| The stack allocator allocate stack for idle thread handler. More... | |
This include file contains all information about the thread Stack Handler. This Handler provides mechanisms which can be used to initialize and utilize stacks.
extern |
Application provided via <rtems/confdefs.h>.
