RTEMS 5.2
coremutex.h
1
14/*
15 * COPYRIGHT (c) 1989-2011.
16 * On-Line Applications Research Corporation (OAR).
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef _RTEMS_SCORE_COREMUTEX_H
24#define _RTEMS_SCORE_COREMUTEX_H
25
26#include <rtems/score/thread.h>
27#include <rtems/score/threadq.h>
30#include <rtems/score/interr.h>
31
33
34#ifdef __cplusplus
35extern "C" {
36#endif
37
56typedef struct {
64
68typedef struct {
73
77 unsigned int nest_level;
79
83typedef struct {
88
93
94#if defined(RTEMS_SMP)
98 const struct _Scheduler_Control *scheduler;
99#endif
101
104#ifdef __cplusplus
105}
106#endif
107
108#endif
109/* end of include file */
Constants and Structures Associated with Watchdog Timers.
Constants and Prototypes Related to the Internal Error Handler.
Priority Handler API.
Constants and Structures Related with the Thread Control Block.
The recursive mutex control with priority ceiling protocol support.
Definition: coremutex.h:83
Priority_Node Priority_ceiling
The priority ceiling node for the mutex owner.
Definition: coremutex.h:92
CORE_recursive_mutex_Control Recursive
The plain recursive mutex.
Definition: coremutex.h:87
Control block used to manage each mutex.
Definition: coremutex.h:56
Thread_queue_Control Wait_queue
The thread queue of this mutex.
Definition: coremutex.h:62
The recursive mutex control.
Definition: coremutex.h:68
The nest level in case of a recursive seize.
Definition: coremutex.h:77
CORE_mutex_Control Mutex
The plain non-recursive mutex.
Definition: coremutex.h:72
The priority node to build up a priority aggregation.
Definition: priority.h:98
Definition: threadq.h:553
Scheduler control.
Definition: scheduler.h:269
Constants and Structures Needed to Declare a Thread Queue.
