RTEMS 5.2
coremsgimpl.h
1
12/*
13 * COPYRIGHT (c) 1989-2009.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21#ifndef _RTEMS_SCORE_COREMSGIMPL_H
22#define _RTEMS_SCORE_COREMSGIMPL_H
23
24#include <rtems/score/coremsg.h>
25#include <rtems/score/status.h>
29
30#include <limits.h>
31#include <string.h>
32
33#ifdef __cplusplus
34extern "C" {
35#endif
36
49#define CORE_MESSAGE_QUEUE_SEND_REQUEST INT_MAX
50
57#define CORE_MESSAGE_QUEUE_URGENT_REQUEST INT_MIN
58
70
92 CORE_message_queue_Control *the_message_queue,
94 uint32_t maximum_pending_messages,
95 size_t maximum_message_size
96);
97
113 CORE_message_queue_Control *the_message_queue,
114 Thread_queue_Context *queue_context
115);
116
133 CORE_message_queue_Control *the_message_queue,
134 Thread_queue_Context *queue_context
135);
136
137#if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API)
150 void _CORE_message_queue_Flush_waiting_threads(
151 CORE_message_queue_Control *the_message_queue
152 );
153#endif
154
176Status_Control _CORE_message_queue_Broadcast(
177 CORE_message_queue_Control *the_message_queue,
178 const void *buffer,
179 size_t size,
180 uint32_t *count,
181 Thread_queue_Context *queue_context
182);
183
211Status_Control _CORE_message_queue_Submit(
212 CORE_message_queue_Control *the_message_queue,
213 Thread_Control *executing,
214 const void *buffer,
215 size_t size,
217 bool wait,
218 Thread_queue_Context *queue_context
219);
220
254Status_Control _CORE_message_queue_Seize(
255 CORE_message_queue_Control *the_message_queue,
256 Thread_Control *executing,
257 void *buffer,
258 size_t *size_p,
259 bool wait,
260 Thread_queue_Context *queue_context
261);
262
277 CORE_message_queue_Control *the_message_queue,
279 const void *content_source,
280 size_t content_size,
282);
283
302 CORE_message_queue_Control *the_message_queue,
303 const void *buffer,
304 size_t size,
305 bool wait,
306 Thread_queue_Context *queue_context
307)
308{
310 the_message_queue,
311 _Thread_Executing,
312 buffer,
313 size,
315 wait,
316 queue_context
317 );
318}
319
338 CORE_message_queue_Control *the_message_queue,
339 const void *buffer,
340 size_t size,
341 bool wait,
342 Thread_queue_Context *queue_context
343)
344{
346 the_message_queue,
347 _Thread_Executing,
348 buffer,
349 size,
351 wait,
352 queue_context
353 );
354}
355
363 CORE_message_queue_Control *the_message_queue,
364 Thread_queue_Context *queue_context
365)
366{
367 _Thread_queue_Acquire( &the_message_queue->Wait_queue, queue_context );
368}
369
377 CORE_message_queue_Control *the_message_queue,
378 Thread_queue_Context *queue_context
379)
380{
381 _Thread_queue_Acquire_critical( &the_message_queue->Wait_queue, queue_context );
382}
383
391 CORE_message_queue_Control *the_message_queue,
392 Thread_queue_Context *queue_context
393)
394{
395 _Thread_queue_Release( &the_message_queue->Wait_queue, queue_context );
396}
397
409 const void *source,
410 void *destination,
411 size_t size
412)
413{
414 memcpy(destination, source, size);
415}
416
430 CORE_message_queue_Control *the_message_queue
431)
432{
434 _Chain_Get_unprotected( &the_message_queue->Inactive_messages );
435}
436
447 CORE_message_queue_Control *the_message_queue,
449)
450{
451 _Chain_Append_unprotected( &the_message_queue->Inactive_messages, &the_message->Node );
452}
453
468 const CORE_message_queue_Buffer_control *the_message
469)
470{
471 #if defined(RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY)
472 return the_message->priority;
473 #else
474 return 0;
475 #endif
476}
477
491 CORE_message_queue_Control *the_message_queue
492)
493{
495 _Chain_Get_unprotected( &the_message_queue->Pending_messages );
496}
497
498#if defined(RTEMS_SCORE_COREMSG_ENABLE_NOTIFICATION)
510 RTEMS_INLINE_ROUTINE bool _CORE_message_queue_Is_notify_enabled (
511 CORE_message_queue_Control *the_message_queue
512 )
513 {
514 return (the_message_queue->notify_handler != NULL);
515 }
516#endif
517
527#if defined(RTEMS_SCORE_COREMSG_ENABLE_NOTIFICATION)
529 CORE_message_queue_Control *the_message_queue,
530 CORE_message_queue_Notify_Handler the_handler
531 )
532 {
533 the_message_queue->notify_handler = the_handler;
534 }
535#else
536 /* turn it into nothing if not enabled */
537 #define _CORE_message_queue_Set_notify( the_message_queue, the_handler ) \
538 do { } while ( 0 )
539#endif
540
557 CORE_message_queue_Control *the_message_queue,
558 const void *buffer,
559 size_t size,
561 Thread_queue_Context *queue_context
562)
563{
564 Thread_Control *the_thread;
565
566 /*
567 * If there are pending messages, then there can't be threads
568 * waiting for us to send them a message.
569 *
570 * NOTE: This check is critical because threads can block on
571 * send and receive and this ensures that we are broadcasting
572 * the message to threads waiting to receive -- not to send.
573 */
574 if ( the_message_queue->number_of_pending_messages != 0 ) {
575 return NULL;
576 }
577
578 /*
579 * There must be no pending messages if there is a thread waiting to
580 * receive a message.
581 */
582 the_thread = _Thread_queue_First_locked(
583 &the_message_queue->Wait_queue,
584 the_message_queue->operations
585 );
586 if ( the_thread == NULL ) {
587 return NULL;
588 }
589
590 *(size_t *) the_thread->Wait.return_argument = size;
591 the_thread->Wait.count = (uint32_t) submit_type;
592
594 buffer,
595 the_thread->Wait.return_argument_second.mutable_object,
596 size
597 );
598
600 &the_message_queue->Wait_queue.Queue,
601 the_message_queue->operations,
602 the_thread,
603 queue_context
604 );
605
606 return the_thread;
607}
608
611#ifdef __cplusplus
612}
613#endif
614
615#endif
616/* end of include file */
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
Chain Handler API.
Constants and Structures Associated with the Message Queue Handler.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Get_unprotected(Chain_Control *the_chain)
Gets the first node (unprotected).
Definition: chainimpl.h:630
RTEMS_INLINE_ROUTINE void _Chain_Append_unprotected(Chain_Control *the_chain, Chain_Node *the_node)
Appends a node (unprotected).
Definition: chainimpl.h:680
void _CORE_message_queue_Insert_message(CORE_message_queue_Control *the_message_queue, CORE_message_queue_Buffer_control *the_message, const void *content_source, size_t content_size, CORE_message_queue_Submit_types submit_type)
Inserts a message into the message queue.
Definition: coremsginsert.c:41
Used when prepending messages onto a message queue.
Definition: coremsgimpl.h:57
int CORE_message_queue_Submit_types
The modes in which a message may be submitted to a message queue.
Definition: coremsgimpl.h:69
RTEMS_INLINE_ROUTINE int _CORE_message_queue_Get_message_priority(const CORE_message_queue_Buffer_control *the_message)
Gets message priority.
Definition: coremsgimpl.h:467
RTEMS_INLINE_ROUTINE Status_Control _CORE_message_queue_Urgent(CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, bool wait, Thread_queue_Context *queue_context)
Sends an urgent message to the message queue.
Definition: coremsgimpl.h:337
Status_Control _CORE_message_queue_Submit(CORE_message_queue_Control *the_message_queue, Thread_Control *executing, const void *buffer, size_t size, CORE_message_queue_Submit_types submit_type, bool wait, Thread_queue_Context *queue_context)
Submits a message to the message queue.
Definition: coremsgsubmit.c:29
bool _CORE_message_queue_Initialize(CORE_message_queue_Control *the_message_queue, CORE_message_queue_Disciplines discipline, uint32_t maximum_pending_messages, size_t maximum_message_size)
Initializes a message queue.
Definition: coremsg.c:45
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Acquire_critical(CORE_message_queue_Control *the_message_queue, Thread_queue_Context *queue_context)
Acquires the message queue critical.
Definition: coremsgimpl.h:376
Used when appending messages onto a message queue.
Definition: coremsgimpl.h:49
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Free_message_buffer(CORE_message_queue_Control *the_message_queue, CORE_message_queue_Buffer_control *the_message)
Frees a message buffer to inactive message buffer chain.
Definition: coremsgimpl.h:446
Status_Control _CORE_message_queue_Seize(CORE_message_queue_Control *the_message_queue, Thread_Control *executing, void *buffer, size_t *size_p, bool wait, Thread_queue_Context *queue_context)
Seizes a message from the message queue.
Definition: coremsgseize.c:27
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Acquire(CORE_message_queue_Control *the_message_queue, Thread_queue_Context *queue_context)
Acquires the message queue.
Definition: coremsgimpl.h:362
RTEMS_INLINE_ROUTINE CORE_message_queue_Buffer_control * _CORE_message_queue_Allocate_message_buffer(CORE_message_queue_Control *the_message_queue)
Allocates a message buffer from the inactive message buffer chain.
Definition: coremsgimpl.h:429
void _CORE_message_queue_Close(CORE_message_queue_Control *the_message_queue, Thread_queue_Context *queue_context)
Closes a message queue.
Definition: coremsgclose.c:35
#define _CORE_message_queue_Set_notify(the_message_queue, the_handler)
Initializes notification information.
Definition: coremsgimpl.h:537
RTEMS_INLINE_ROUTINE CORE_message_queue_Buffer_control * _CORE_message_queue_Get_pending_message(CORE_message_queue_Control *the_message_queue)
Gets first message of message queue and removes it.
Definition: coremsgimpl.h:490
RTEMS_INLINE_ROUTINE Thread_Control * _CORE_message_queue_Dequeue_receiver(CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, CORE_message_queue_Submit_types submit_type, Thread_queue_Context *queue_context)
Gets the first locked thread waiting to receive and dequeues it.
Definition: coremsgimpl.h:556
The possible blocking disciplines for a message queue.
Definition: coremsg.h:109
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Release(CORE_message_queue_Control *the_message_queue, Thread_queue_Context *queue_context)
Releases the message queue.
Definition: coremsgimpl.h:390
uint32_t _CORE_message_queue_Flush(CORE_message_queue_Control *the_message_queue, Thread_queue_Context *queue_context)
Flushes pending messages.
Definition: coremsgflush.c:24
RTEMS_INLINE_ROUTINE Status_Control _CORE_message_queue_Send(CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, bool wait, Thread_queue_Context *queue_context)
Sends a message to the message queue.
Definition: coremsgimpl.h:301
Status_Control _CORE_message_queue_Broadcast(CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, uint32_t *count, Thread_queue_Context *queue_context)
Broadcasts a message to the message queue.
Definition: coremsgbroadcast.c:24
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Copy_buffer(const void *source, void *destination, size_t size)
Copies the source message buffer to the destination message buffer.
Definition: coremsgimpl.h:408
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_queue_First_locked(Thread_queue_Control *the_thread_queue, const Thread_queue_Operations *operations)
Returns the first thread on the thread queue if it exists, otherwise NULL.
Definition: threadqimpl.h:1173
RTEMS_INLINE_ROUTINE void _Thread_queue_Release(Thread_queue_Control *the_thread_queue, Thread_queue_Context *queue_context)
Releases the thread queue control and enables interrupts.
Definition: threadqimpl.h:787
RTEMS_INLINE_ROUTINE void _Thread_queue_Acquire_critical(Thread_queue_Control *the_thread_queue, Thread_queue_Context *queue_context)
Acquires the thread queue control in a critical section.
Definition: threadqimpl.h:681
RTEMS_INLINE_ROUTINE void _Thread_queue_Acquire(Thread_queue_Control *the_thread_queue, Thread_queue_Context *queue_context)
Definition: threadqimpl.h:704
void _Thread_queue_Extract_critical(Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context)
Extracts the thread from the thread queue and unblocks it.
Definition: threadqenqueue.c:600
The organization of a message buffer.
Definition: coremsg.h:92
Chain_Node Node
Definition: coremsg.h:94
int priority
Definition: coremsg.h:97
Control block used to manage each message queue.
Definition: coremsg.h:136
Chain_Control Inactive_messages
Definition: coremsg.h:176
const Thread_queue_Operations * operations
The thread queue operations according to the blocking discipline.
Definition: coremsg.h:145
uint32_t number_of_pending_messages
Definition: coremsg.h:153
Thread_queue_Control Wait_queue
Definition: coremsg.h:140
Chain_Control Pending_messages
Definition: coremsg.h:161
uint32_t count
Definition: thread.h:407
Thread_Wait_information_Object_argument_type return_argument_second
Definition: thread.h:412
void * return_argument
Definition: thread.h:409
Thread queue context for the thread queue methods.
Definition: threadq.h:198
Thread_queue_Queue Queue
The actual thread queue.
Definition: threadq.h:584
Definition: thread.h:732
Thread_Wait_information Wait
Definition: thread.h:774
unsigned size
Definition: tte.h:1
Constants and Structures Related with Thread Dispatch.
Constants and Structures Associated with the Manipulation of Objects.
