RTEMS 5.2
bsp.h
1
9/*
10 *
11 * Copyright (c) 2015 University of York.
12 * Hesham Almatary <hesham@alumni.york.ac.uk>
13 *
14 * COPYRIGHT (c) 1989-1999.
15 * On-Line Applications Research Corporation (OAR).
16 *
17 * Redistribution and use in source and binary forms, with or without
18 * modification, are permitted provided that the following conditions
19 * are met:
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in the
24 * documentation and/or other materials provided with the distribution.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
27 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
30 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
31 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
32 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
33 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
34 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
35 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
36 * SUCH DAMAGE.
37 */
38
39#ifndef LIBBSP_RISCV_GRISCV_H
40#define LIBBSP_RISCV_GRISCV_H
41
53#include <rtems.h>
54#include <rtems/clockdrv.h>
55#include <rtems/console.h>
56#include <rtems/irq-extension.h>
57
58#include <bspopts.h>
60
61#include <rtems/devnull.h>
62
63#ifdef __cplusplus
64extern "C" {
65#endif
66
67#define BSP_FEATURE_IRQ_EXTENSION
68
69/* Maximum supported APBUARTs by BSP */
70#define BSP_NUMBER_OF_TERMIOS_PORTS 8
71
72/* GRLIB driver functions */
73
74extern void BSP_shared_interrupt_mask(int irq);
75extern void BSP_shared_interrupt_clear(int irq);
76extern void BSP_shared_interrupt_unmask(int irq);
77
78#ifdef __cplusplus
79}
80#endif
81
84#endif /* LIBBSP_RISCV_GRISCV_H */
Clock Driver API.
Console Driver for all Boards.
DEFAULT_INITIAL_EXTENSION Support.
RTEMS /dev/null Device Driver.
Header file for the Interrupt Manager Extension.
