RTEMS 5.2
fatal.h
1/*
2 * Copyright (c) 2012, 2018 embedded brains GmbH. All rights reserved.
3 *
4 * embedded brains GmbH
5 * Dornierstr. 4
6 * 82178 Puchheim
7 * Germany
8 * <rtems@embedded-brains.de>
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef LIBBSP_SHARED_BSP_FATAL_H
16#define LIBBSP_SHARED_BSP_FATAL_H
17
18#include <rtems.h>
19
20#ifdef __cplusplus
21extern "C" {
22#endif /* __cplusplus */
23
24#define BSP_FATAL_CODE_BLOCK(idx) ((unsigned long) (idx) * 256UL)
25
29typedef enum {
30 /* Generic BSP fatal codes */
31 BSP_FATAL_INTERRUPT_INITIALIZATION = BSP_FATAL_CODE_BLOCK(0),
32 BSP_FATAL_SPURIOUS_INTERRUPT,
33 BSP_FATAL_CONSOLE_MULTI_INIT,
34 BSP_FATAL_CONSOLE_NO_MEMORY_0,
35 BSP_FATAL_CONSOLE_NO_MEMORY_1,
36 BSP_FATAL_CONSOLE_NO_MEMORY_2,
37 BSP_FATAL_CONSOLE_NO_MEMORY_3,
38 BSP_FATAL_CONSOLE_REGISTER_DEV_0,
39 BSP_FATAL_CONSOLE_REGISTER_DEV_1,
40 BSP_FATAL_CONSOLE_NO_DEV,
41 BSP_FATAL_CONSOLE_INSTALL_0,
42 BSP_FATAL_CONSOLE_INSTALL_1,
43 BSP_FATAL_CONSOLE_REGISTER_DEV_2,
44
45 /* ARM fatal codes */
46 BSP_ARM_A9MPCORE_FATAL_CLOCK_IRQ_INSTALL = BSP_FATAL_CODE_BLOCK(1),
47 BSP_ARM_A9MPCORE_FATAL_CLOCK_IRQ_REMOVE,
48 BSP_ARM_PL111_FATAL_REGISTER_DEV,
49 BSP_ARM_PL111_FATAL_SEM_CREATE,
50 BSP_ARM_PL111_FATAL_SEM_RELEASE,
51 BSP_ARM_A9MPCORE_FATAL_CLOCK_SMP_INIT,
52 BSP_ARM_ARMV7M_CPU_COUNTER_INIT,
53 BSP_ARM_FATAL_GENERIC_TIMER_CLOCK_IRQ_INSTALL,
54
55 /* LEON3 fatal codes */
56 LEON3_FATAL_NO_IRQMP_CONTROLLER = BSP_FATAL_CODE_BLOCK(2),
57 LEON3_FATAL_CONSOLE_REGISTER_DEV,
58 LEON3_FATAL_CLOCK_INITIALIZATION,
59 LEON3_FATAL_INVALID_CACHE_CONFIG_MAIN_PROCESSOR,
60 LEON3_FATAL_INVALID_CACHE_CONFIG_SECONDARY_PROCESSOR,
61 LEON3_FATAL_CLOCK_NO_IRQMP_TIMESTAMP_SUPPORT,
62
63 /* LPC24XX fatal codes */
64 LPC24XX_FATAL_PL111_SET_UP = BSP_FATAL_CODE_BLOCK(3),
65 LPC24XX_FATAL_PL111_PINS_SET_UP,
66 LPC24XX_FATAL_PL111_PINS_TEAR_DOWN,
67 LPC24XX_FATAL_PL111_TEAR_DOWN,
68
69 /* MPC5200 fatal codes */
70 MPC5200_FATAL_PCF8563_INVALID_YEAR = BSP_FATAL_CODE_BLOCK(4),
71 MPC5200_FATAL_SLICETIMER_0_IRQ_INSTALL,
72 MPC5200_FATAL_SLICETIMER_1_IRQ_INSTALL,
73 MPC5200_FATAL_TM27_IRQ_INSTALL,
74 MPC5200_FATAL_MSCAN_A_INIT,
75 MPC5200_FATAL_MSCAN_B_INIT,
76 MPC5200_FATAL_MSCAN_A_SET_MODE,
77 MPC5200_FATAL_MSCAN_B_SET_MODE,
78 MPC5200_FATAL_ATA_DISK_IO_INIT,
79 MPC5200_FATAL_ATA_DISK_CREATE,
80 MPC5200_FATAL_ATA_DMA_SINGLE_IRQ_INSTALL,
81 MPC5200_FATAL_ATA_LOCK_CREATE,
82 MPC5200_FATAL_ATA_LOCK_DESTROY,
83
84 /* MPC55XX fatal codes */
85 MPC55XX_FATAL_FMPLL_LOCK = BSP_FATAL_CODE_BLOCK(5),
86 MPC55XX_FATAL_CLOCK_EMIOS_IRQ_INSTALL,
87 MPC55XX_FATAL_CLOCK_EMIOS_PRESCALER,
88 MPC55XX_FATAL_CLOCK_EMIOS_INTERVAL,
89 MPC55XX_FATAL_CLOCK_PIT_IRQ_INSTALL,
90 MPC55XX_FATAL_CONSOLE_GENERIC_COUNT,
91 MPC55XX_FATAL_CONSOLE_GENERIC_REGISTER,
92 MPC55XX_FATAL_CONSOLE_GENERIC_REGISTER_CONSOLE,
93 MPC55XX_FATAL_CONSOLE_ESCI_BAUD,
94 MPC55XX_FATAL_CONSOLE_ESCI_ATTRIBUTES,
95 MPC55XX_FATAL_CONSOLE_ESCI_IRQ_INSTALL,
96 MPC55XX_FATAL_CONSOLE_LINFLEX_BAUD,
97 MPC55XX_FATAL_CONSOLE_LINFLEX_ATTRIBUTES,
98 MPC55XX_FATAL_CONSOLE_LINFLEX_RX_IRQ_INSTALL,
99 MPC55XX_FATAL_CONSOLE_LINFLEX_TX_IRQ_INSTALL,
100 MPC55XX_FATAL_CONSOLE_LINFLEX_ERR_IRQ_INSTALL,
101 MPC55XX_FATAL_CONSOLE_LINFLEX_RX_IRQ_REMOVE,
102 MPC55XX_FATAL_CONSOLE_LINFLEX_TX_IRQ_REMOVE,
103 MPC55XX_FATAL_CONSOLE_LINFLEX_ERR_IRQ_REMOVE,
104 MPC55XX_FATAL_EDMA_IRQ_INSTALL,
105 MPC55XX_FATAL_EDMA_IRQ_REMOVE,
106
107 /* MRM332 fatal codes */
108 MRM332_FATAL_SPURIOUS_INTERRUPT = BSP_FATAL_CODE_BLOCK(6),
109
110 /* PowerPC fatal codes */
111 PPC_FATAL_EXCEPTION_INITIALIZATION = BSP_FATAL_CODE_BLOCK(7),
112
113 /* Libchip fatal codes */
114 DWMAC_FATAL_TOO_MANY_RBUFS_CONFIGURED = BSP_FATAL_CODE_BLOCK(8),
115
116 /* ARM fatal codes */
117 ARM_FATAL_L2C_310_UNEXPECTED_ID = BSP_FATAL_CODE_BLOCK(9),
118 ARM_FATAL_L2C_310_UNEXPECTED_NUM_WAYS,
119 ARM_FATAL_L2C_310_EXCLUSIVE_CONFIG,
120
121 /* QorIQ fatal codes */
122 QORIQ_FATAL_SMP_IPI_HANDLER_INSTALL = BSP_FATAL_CODE_BLOCK(10),
123 QORIQ_FATAL_FDT_NO_BUS_FREQUENCY,
124 QORIQ_FATAL_FDT_NO_CLOCK_FREQUENCY,
125 QORIQ_FATAL_FDT_NO_TIMEBASE_FREQUENCY,
126 QORIQ_FATAL_RESTART_FAILED,
127 QORIQ_FATAL_RESTART_INSTALL_INTERRUPT,
128 QORIQ_FATAL_RESTART_INTERRUPT_FAILED,
129
130 /* ATSAM fatal codes */
131 ATSAM_FATAL_XDMA_IRQ_INSTALL = BSP_FATAL_CODE_BLOCK(11),
132 ATSAM_FATAL_PIO_IRQ_A,
133 ATSAM_FATAL_PIO_IRQ_B,
134 ATSAM_FATAL_PIO_IRQ_C,
135 ATSAM_FATAL_PIO_IRQ_D,
136 ATSAM_FATAL_PIO_IRQ_E,
137 ATSAM_FATAL_PIO_CONFIGURE_IT,
138
139 /* i.MX fatal codes */
140 IMX_FATAL_GENERIC_TIMER_FREQUENCY = BSP_FATAL_CODE_BLOCK(12),
141
142 /* RISC-V fatal codes */
143 RISCV_FATAL_NO_TIMEBASE_FREQUENCY_IN_DEVICE_TREE = BSP_FATAL_CODE_BLOCK(13),
144 RISCV_FATAL_NO_NS16550_REG_IN_DEVICE_TREE,
145 RISCV_FATAL_NO_NS16550_CLOCK_FREQUENCY_IN_DEVICE_TREE,
146 RISCV_FATAL_UNEXPECTED_INTERRUPT_EXCEPTION,
147 RISCV_FATAL_CLOCK_IRQ_INSTALL,
148 RISCV_FATAL_NO_CLINT_REG_IN_DEVICE_TREE,
149 RISCV_FATAL_INVALID_HART_REG_IN_DEVICE_TREE,
150 RISCV_FATAL_INVALID_CLINT_IRQS_EXTENDED_IN_DEVICE_TREE,
151 RISCV_FATAL_NO_PLIC_REG_IN_DEVICE_TREE,
152 RISCV_FATAL_INVALID_PLIC_NDEV_IN_DEVICE_TREE,
153 RISCV_FATAL_TOO_LARGE_PLIC_NDEV_IN_DEVICE_TREE,
154 RISCV_FATAL_INVALID_INTERRUPT_AFFINITY,
155 RISCV_FATAL_NO_NS16550_INTERRUPTS_IN_DEVICE_TREE,
156 RISCV_FATAL_NO_TLCLOCK_FREQUENCY_IN_DEVICE_TREE
157} bsp_fatal_code;
158
159RTEMS_NO_RETURN static inline void
160bsp_fatal( bsp_fatal_code code )
161{
162 rtems_fatal( RTEMS_FATAL_SOURCE_BSP, (rtems_fatal_code) code );
163}
164
165#ifdef __cplusplus
166}
167#endif /* __cplusplus */
168
169#endif /* LIBBSP_SHARED_BSP_FATAL_H */
RTEMS_NO_RETURN RTEMS_INLINE_ROUTINE void rtems_fatal(rtems_fatal_source fatal_source, rtems_fatal_code error_code)
Terminates the system.
Definition: fatal.h:83
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
@ RTEMS_FATAL_SOURCE_BSP
Fatal source for BSP errors.
Definition: interr.h:94
Definition: inftrees.h:24
