RTEMS 5.2
irq.h
1/*
2 * SPDX-License-Identifier: BSD-2-Clause
3 *
4 * Copyright (C) 2019 DornerWorks
5 * Written by Jeff Kubascik <jeff.kubascik@dornerworks.com>
6 *
7 * Redistribution and use in source and binary forms, with or without
8 * modification, are permitted provided that the following conditions
9 * are met:
10 * 1. Redistributions of source code must retain the above copyright
11 * notice, this list of conditions and the following disclaimer.
12 * 2. Redistributions in binary form must reproduce the above copyright
13 * notice, this list of conditions and the following disclaimer in the
14 * documentation and/or other materials provided with the distribution.
15 *
16 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
17 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
18 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
19 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
20 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
21 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
22 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
23 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
24 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
25 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
26 * POSSIBILITY OF SUCH DAMAGE.
27 */
28
29#ifndef LIBBSP_ARM_XEN_IRQ_H
30#define LIBBSP_ARM_XEN_IRQ_H
31
32#ifndef ASM
33
34#include <rtems/irq.h>
35#include <rtems/irq-extension.h>
36
37#include <bsp/arm-gic-irq.h>
38
39#ifdef __cplusplus
40extern "C" {
41#endif /* __cplusplus */
42
43#define BSP_INTERRUPT_VECTOR_MIN 0
44#define BSP_INTERRUPT_VECTOR_MAX 1023
45
46/* Xen guest interrupts */
47#define GUEST_TIMER_VIRT_PPI 27
48#define GUEST_TIMER_PHYS_S_PPI 29
49#define GUEST_TIMER_PHYS_NS_PPI 30
50#define GUEST_EVTCHN_PPI 31
51
52#define GUEST_VPL011_SPI 32
53
56#ifdef __cplusplus
57}
58#endif /* __cplusplus */
59
60#endif /* ASM */
61
62#endif /* LIBBSP_ARM_XEN_IRQ_H */
ARM GIC IRQ.
Header file for the Interrupt Manager Extension.
