RTEMS 5.2
irq.h
1
9/*
10 * Copyright (c) 2014 Premysl Houdek <kom541000@gmail.com>
11 *
12 * Google Summer of Code 2014 at
13 * Czech Technical University in Prague
14 * Zikova 1903/4
15 * 166 36 Praha 6
16 * Czech Republic
17 *
18 * Based on LPC24xx and LPC1768 BSP
19 * by embedded brains GmbH and others
20 *
21 * The license and distribution terms for this file may be
22 * found in the file LICENSE in this distribution or at
23 * http://www.rtems.org/license/LICENSE.
24 */
25
26#ifndef LIBBSP_ARM_TMS570_IRQ_H
27#define LIBBSP_ARM_TMS570_IRQ_H
28
29#ifndef ASM
30#include <rtems.h>
31#include <rtems/irq.h>
32#include <rtems/irq-extension.h>
33#endif
34
35#define BSP_INTERRUPT_VECTOR_MIN 0U
36#define TMS570_IRQ_ESM_HIGH 0
37#define TMS570_IRQ_RESERVED 1
38#define TMS570_IRQ_TIMER_0 2
39#define TMS570_IRQ_TIMER_1 3
40#define TMS570_IRQ_TIMER_2 4
41#define TMS570_IRQ_TIMER_3 5
42#define TMS570_IRQ_RTI_OVERFLOW_0 6
43#define TMS570_IRQ_RTI_OVERFLOW_1 7
44#define TMS570_IRQ_RTI_TIMEBASE 8
45#define TMS570_IRQ_GIO_HIGH 9
46#define TMS570_IRQ_HET_HIGH 10
47#define TMS570_IRQ_HET_TU_HIGH 11
48#define TMS570_IRQ_MIBSPI1_HIGH 12
49#define TMS570_IRQ_SCI_LEVEL_0 13
50#define TMS570_IRQ_ADC1_EVENT 14
51#define TMS570_IRQ_ADC1_GROUP_1 15
52#define TMS570_IRQ_CAN1_HIGH 16
53#define TMS570_IRQ_RESERVED 17
54#define TMS570_IRQ_FLEXRAY_HIGH 18
55#define TMS570_IRQ_CRC_1 19
56#define TMS570_IRQ_ESM_LOW 20
57#define TMS570_IRQ_SSI 21
58#define TMS570_IRQ_PMU 22
59#define TMS570_IRQ_GIO_LOW 23
60#define TMS570_IRQ_HET_LOW 24
61#define TMS570_IRQ_HET_TU_LOW 25
62#define TMS570_IRQ_MIBSPI1_LOW 26
63#define TMS570_IRQ_SCI_LEVEL_1 27
64#define TMS570_IRQ_ADC1_GROUP_2 28
65#define TMS570_IRQ_CAN1_LOW 29
66#define TMS570_IRQ_RESERVED
67#define TMS570_IRQ_ADC1_MAG 31
68#define TMS570_IRQ_FLEXRAY_LOW 32
69#define TMS570_IRQ_DMA_FTCA 33
70#define TMS570_IRQ_DMA_LFSA 34
71#define TMS570_IRQ_CAN2_HIGH 35
72#define TMS570_IRQ_DMM_HIGH 36
73#define TMS570_IRQ_MIBSPI3_HIGH 37
74#define TMS570_IRQ_MIBSPI3_LOW 38
75#define TMS570_IRQ_DMA_HBCA 39
76#define TMS570_IRQ_DMA_BTCA 40
77#define TMS570_IRQ_DMA_BERA 41
78#define TMS570_IRQ_CAN2_LOW 42
79#define TMS570_IRQ_DMM_LOW 43
80#define TMS570_IRQ_CAN1_IF3 44
81#define TMS570_IRQ_CAN3_HIGH 45
82#define TMS570_IRQ_CAN2_IF3 46
83#define TMS570_IRQ_FPU 47
84#define TMS570_IRQ_FLEXRAY_TU 48
85#define TMS570_IRQ_SPI4_HIGH 49
86#define TMS570_IRQ_ADC2_EVENT 50
87#define TMS570_IRQ_ADC2_GROUP_1 51
88#define TMS570_IRQ_FLEXRAY_T0C 52
89#define TMS570_IRQ_MIBSPIP5_HIGH 53
90#define TMS570_IRQ_SPI4_LOW 54
91#define TMS570_IRQ_CAN3_LOW 55
92#define TMS570_IRQ_MIBSPIP5_LOW 56
93#define TMS570_IRQ_ADC2_GROUP_2 57
94#define TMS570_IRQ_FLEXRAY_TU_ERROR 58
95#define TMS570_IRQ_ADC2_MAG 59
96#define TMS570_IRQ_CAN3_IF3 60
97#define TMS570_IRQ_FSM_DONE 61
98#define TMS570_IRQ_FLEXRAY_T1C 62
99#define TMS570_IRQ_HET2_LEVEL_0 63
100#define TMS570_IRQ_SCI2_LEVEL_0 64
101#define TMS570_IRQ_HET_TU2_LEVEL_0 65
102#define TMS570_IRQ_IC2_INTERRUPT 66
103#define TMS570_IRQ_HET2_LEVEL_1 73
104#define TMS570_IRQ_SCI2_LEVEL_1 74
105#define TMS570_IRQ_HET_TU2_LEVEL_1 75
106#define TMS570_IRQ_EMAC_MISC 76
107#define TMS570_IRQ_EMAC_TX 77
108#define TMS570_IRQ_EMAC_THRESH 78
109#define TMS570_IRQ_EMAC_RX 79
110#define TMS570_IRQ_HWA_INT_REQ_H 80
111#define TMS570_IRQ_HWA_INT_REQ_H 81
112#define TMS570_IRQ_DCC_DONE_INTERRUPT 82
113#define TMS570_IRQ_DCC2_DONE_INTERRUPT 83
114#define TMS570_IRQ_HWAG1_INT_REQ_L 88
115#define TMS570_IRQ_HWAG2_INT_REQ_L 89
116#define BSP_INTERRUPT_VECTOR_MAX 94
117
118#define TMS570_IRQ_PRIORITY_VALUE_MIN 0U
119#define TMS570_IRQ_PRIORITY_VALUE_MAX 0U
120
121#define TMS570_IRQ_PRIORITY_COUNT ( TMS570_IRQ_PRIORITY_VALUE_MAX + 1U )
122#define TMS570_IRQ_PRIORITY_HIGHEST TMS570_IRQ_PRIORITY_VALUE_MIN
123#define TMS570_IRQ_PRIORITY_LOWEST TMS570_IRQ_PRIORITY_VALUE_MAX
124
125#ifndef ASM
126
139 rtems_vector_number vector,
140 unsigned priority
141);
142
155
156#endif /* ASM */
157
160#endif /* LIBBSP_ARM_TMS570_IRQ_H */
unsigned tms570_irq_get_priority(rtems_vector_number vector)
Gets priority of the interrupt vector.
Definition: irq.c:65
void tms570_irq_set_priority(rtems_vector_number vector, unsigned priority)
Set priority of the interrupt vector.
Definition: irq.c:44
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Header file for the Interrupt Manager Extension.
