RTEMS 5.2
spi.h File Reference
Raspberry Pi specific SPI definitions. More...
#include <rtems/libi2c.h>
SPI constants.
#define GPU_CORE_CLOCK_RATE   250000000
 GPU processor core clock rate in Hz. More...
SPI directives.
int rpi_spi_init (bool bidirectional_mode)
 Setups the Raspberry Pi SPI bus (located on the GPIO header) on the "/dev/spi" device file, and registers the bus on the libi2c API. More...
◆ GPU_CORE_CLOCK_RATE
Unless configured otherwise on a "config.txt" file present on the SD card the GPU defaults to 250 MHz. Currently only 250 MHz is supported.
◆ rpi_spi_init()
int rpi_spi_init ( bool  bidirectional_mode)
Parameters
[in]bidirectional_modeIf TRUE sets the SPI bus to use 2-wire SPI, where the MOSI data line doubles as the slave out (SO) and slave in (SI) data lines. If FALSE the bus defaults to the usual 3-wire SPI, with 2 separate data lines (MOSI and MISO).
Return values
Returnslibi2c bus number.
<0Could not register the bus. See
See also
rtems_libi2c_register_bus().
