RTEMS 5.2
bspVmeDmaListP.h
1
9#ifndef BSP_VME_DMA_LIST_P_H
10#define BSP_VME_DMA_LIST_P_H
11
12#include <bsp/bspVmeDmaList.h>
13
14/*
15 * This is used by chip drivers to implement the
16 * 'class' members so that 'bspVmeDmaList' can access
17 * the device in an abstract manner.
18 */
19
20/*
21 * Authorship
22 * ----------
23 * This software was created by
24 * Till Straumann <strauman@slac.stanford.edu>, 2006, 2007
25 * Stanford Linear Accelerator Center, Stanford University.
26 *
27 * Acknowledgement of sponsorship
28 * ------------------------------
29 * This software was produced by
30 * the Stanford Linear Accelerator Center, Stanford University,
31 * under Contract DE-AC03-76SFO0515 with the Department of Energy.
32 *
33 * Government disclaimer of liability
34 * ----------------------------------
35 * Neither the United States nor the United States Department of Energy,
36 * nor any of their employees, makes any warranty, express or implied, or
37 * assumes any legal liability or responsibility for the accuracy,
38 * completeness, or usefulness of any data, apparatus, product, or process
39 * disclosed, or represents that its use would not infringe privately owned
40 * rights.
41 *
42 * Stanford disclaimer of liability
43 * --------------------------------
44 * Stanford University makes no representations or warranties, express or
45 * implied, nor assumes any liability for the use of this software.
46 *
47 * Stanford disclaimer of copyright
48 * --------------------------------
49 * Stanford University, owner of the copyright, hereby disclaims its
50 * copyright and all other rights in this software. Hence, anyone may
51 * freely use it for any purpose without restriction.
52 *
53 * Maintenance of notices
54 * ----------------------
55 * In the interest of clarity regarding the origin and status of this
56 * SLAC software, this and all the preceding Stanford University notices
57 * are to remain affixed to any copy or derivative of this software made
58 * or distributed by the recipient and are to be affixed to any copy of
59 * software made or distributed by the recipient that contains a copy or
60 * derivative of this software.
61 *
62 * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
63 */
64#ifdef __cplusplus
65extern "C" {
66#endif
67
68typedef void *DmaDescriptor;
69
78typedef DmaDescriptor (*DmaDescriptorAlloc)(void);
79typedef void (*DmaDescriptorFree) (DmaDescriptor d);
80typedef void (*DmaDescriptorInit) (DmaDescriptor d);
81/* Setup takes the parameters declared in VMEDMA.h */
82typedef int (*DmaDescriptorSetup)(DmaDescriptor d, uint32_t, uint32_t, uint32_t, uint32_t, uint32_t);
83typedef void (*DmaDescriptorSetNxt)(DmaDescriptor d, DmaDescriptor next);
84typedef int (*DmaDescriptorStart)(volatile void *controller_addr, int channel, DmaDescriptor);
85typedef int (*DmaDescriptorRefr) (DmaDescriptor);
86typedef void (*DmaDescriptorDump) (DmaDescriptor);
87
88
89typedef struct VMEDmaListClassRec_ {
90 int desc_size; /* size of a descritor */
91 int desc_align; /* alignment of a descriptor */
92 VMEDmaListNode freeList; /* list of free descriptors of this class, MUST be initialized to NULL */
93 DmaDescriptorAlloc desc_alloc; /* [optional, may be NULL] allocator for one descriptor */
94 DmaDescriptorFree desc_free; /* [optional, may be NULL] destructor for one descriptor */
95 DmaDescriptorInit desc_init; /* [optional, may be NULL] set stuff that don't change during lifetime */
96 DmaDescriptorSetNxt desc_setnxt;/* set 'NEXT' pointer in descriptor; mark as LAST if next == 0 */
97 DmaDescriptorSetup desc_setup; /* setup a descriptor */
98 DmaDescriptorStart desc_start; /* start list at a descriptor */
99 DmaDescriptorRefr desc_refr; /* refresh a descriptor */
100 DmaDescriptorDump desc_dump; /* dump a descriptor (for debugging) */
102
103#ifdef __cplusplus
104}
105#endif
106
107#endif
This header should only be used inside a BSP chosing to use bspVmeDmaList for implementing VMEDMA....
Definition: bspVmeDmaListP.h:89
Definition: bspVmeDmaList.c:61
