RTEMS 5.2
This header should only be used inside a BSP chosing to use bspVmeDmaList for implementing VMEDMA.h. More...
Typedefs | |
| typedef struct VMEDmaListNodeRec_ * | VMEDmaListNode |
| typedef struct VMEDmaListClassRec_ * | VMEDmaListClass |
| VMEDmaListNode | BSP_VMEDmaListDescriptorNewTool (VMEDmaListClass pc, uint32_t attr_mask, uint32_t xfer_mode, uint32_t pci_addr, uint32_t vme_addr, uint32_t n_bytes) |
| VMEDmaListNode | BSP_VMEDmaListDescriptorSetupTool (VMEDmaListNode n, uint32_t attr_mask, uint32_t xfer_mode, uint32_t pci_addr, uint32_t vme_addr, uint32_t n_bytes) |
| int | BSP_VMEDmaListDescriptorStartTool (volatile void *controller, int channel, VMEDmaListNode n) |
