RTEMS 5.2
void | USART_SetBaudrate (Usart *pUsart, uint8_t OverSamp, uint32_t baudrate, uint32_t masterClock) |
Configures an USART baudrate. More... | |
void | USART_Configure (Usart *pUsart, uint32_t mode, uint32_t baudrate, uint32_t masterClock) |
Configures an USART peripheral with the specified parameters. More... | |
void | USART_SetTransmitterEnabled (Usart *pUsart, uint8_t enabled) |
Enables or disables the transmitter of an USART peripheral. More... | |
void | USART_DisableRx (Usart *pUsart) |
Disables the Receiver of an USART peripheral. More... | |
void | USART_DisableTx (Usart *pUsart) |
Disables the transmitter of an USART peripheral. More... | |
void | USART_EnableRx (Usart *pUsart) |
Enables the Receiver of an USART peripheral. More... | |
void | USART_EnableTx (Usart *pUsart) |
Enables the transmitter of an USART peripheral. More... | |
void | USART_ResetRx (Usart *pUsart) |
Resets or disables the Receiver of an USART peripheral. More... | |
void | USART_ResetTx (Usart *pUsart) |
resets and disables the transmitter of an USART peripheral. More... | |
void | USART_SetReceiverEnabled (Usart *pUsart, uint8_t enabled) |
Enables or disables the receiver of an USART peripheral. More... | |
void | USART_SetRTSEnabled (Usart *pUsart, uint8_t enabled) |
Enables or disables the Request To Send (RTS) of an USART peripheral. More... | |
void | USART_Write (Usart *pUsart, uint16_t data, volatile uint32_t timeOut) |
Sends one packet of data through the specified USART peripheral. This function operates synchronously, so it only returns when the data has been actually sent. More... | |
uint16_t | USART_Read (Usart *pUsart, volatile uint32_t timeOut) |
Reads and return a packet of data on the specified USART peripheral. This function operates asynchronously, so it waits until some data has been received. More... | |
uint8_t | USART_IsDataAvailable (Usart *pUsart) |
Returns 1 if some data has been received and can be read from an USART; otherwise returns 0. More... | |
void | USART_PutChar (Usart *pUsart, uint8_t c) |
uint32_t | USART_IsRxReady (Usart *pUsart) |
Return 1 if a character can be read in USART. More... | |
uint32_t | USART_GetStatus (Usart *pUsart) |
Get present status. More... | |
void | USART_EnableIt (Usart *pUsart, uint32_t mode) |
Enable interrupt. More... | |
void | USART_DisableIt (Usart *pUsart, uint32_t mode) |
Disable interrupt. More... | |
uint32_t | USART_GetItMask (Usart *pUsart) |
Return interrupt mask. More... | |
uint8_t | USART_GetChar (Usart *pUsart) |
Reads and returns a character from the USART. More... | |
void | USART_EnableRecvTimeOut (Usart *pUsart, uint32_t Timeout) |
Enable Rx Timeout for USART. More... | |
void | USART_EnableTxTimeGaurd (Usart *pUsart, uint32_t TimeGaurd) |
Enable Tx Timeout for USART. More... | |
void | USART_AcknowledgeRxTimeOut (Usart *pUsart, uint8_t Periodic) |
Acknowledge Rx timeout and sets to Idle or periodic repetitive state. More... | |
Implementation of USART (Universal Synchronous Asynchronous Receiver Transmitter) controller.
void USART_AcknowledgeRxTimeOut | ( | Usart * | pUsart, |
uint8_t | Periodic | ||
pUsart | Pointer to an USART peripheral. |
Periodic | If timeout is periodic or should wait for new char |
void USART_Configure | ( | Usart * | pUsart, |
uint32_t | mode, | ||
uint32_t | baudrate, | ||
uint32_t | masterClock | ||
pUsart | Pointer to the USART peripheral to configure. |
mode | Desired value for the USART mode register (see the datasheet). |
baudrate | Baudrate at which the USART should operate (in Hz). |
masterClock | Frequency of the system master clock (in Hz). |
void USART_DisableIt | ( | Usart * | pUsart, |
uint32_t | mode | ||
Disable interrupt.
mode | Interrupt mode. |
void USART_DisableRx | ( | Usart * | pUsart | ) |
pUsart | Pointer to an USART peripheral |
void USART_DisableTx | ( | Usart * | pUsart | ) |
void USART_EnableIt | ( | Usart * | pUsart, |
Enable interrupt.
void USART_EnableRecvTimeOut | ( | Usart * | pUsart, |
uint32_t | Timeout | ||
Timeout | Timeout value |
void USART_EnableRx | ( | Usart * | pUsart | ) |
void USART_EnableTx | ( | Usart * | pUsart | ) |
void USART_EnableTxTimeGaurd | ( | Usart * | pUsart, |
uint32_t | TimeGaurd | ||
TimeGaurd | TimeGaurd value |
uint8_t USART_GetChar | ( | Usart * | pUsart | ) |
uint32_t USART_GetItMask | ( | Usart * | pUsart | ) |
uint32_t USART_GetStatus | ( | Usart * | pUsart | ) |
Get present status.
uint8_t USART_IsDataAvailable | ( | Usart * | pUsart | ) |
pUsart | Pointer to an USART instance. |
uint32_t USART_IsRxReady | ( | Usart * | pUsart | ) |
void USART_PutChar | ( | Usart * | pUsart, |
uint8_t | c | ||
c | Character to send |
uint16_t USART_Read | ( | Usart * | pUsart, |
volatile uint32_t | timeOut | ||
timeOut | Time out value (0 -> no timeout). |
void USART_ResetRx | ( | Usart * | pUsart | ) |
void USART_ResetTx | ( | Usart * | pUsart | ) |
void USART_SetBaudrate | ( | Usart * | pUsart, |
uint8_t | OverSamp, | ||
void USART_SetReceiverEnabled | ( | Usart * | pUsart, |
uint8_t | enabled | ||
enabled | If true, the receiver is enabled; otherwise it is disabled. |
void USART_SetRTSEnabled | ( | Usart * | pUsart, |
enabled | If true, the RTS is enabled (0); otherwise it is disabled. |
void USART_SetTransmitterEnabled | ( | Usart * | pUsart, |
enabled | If true, the transmitter is enabled; otherwise it is disabled. |
void USART_Write | ( | Usart * | pUsart, |
uint16_t | data, | ||
data | Data to send including 9nth bit and sync field if necessary (in the same format as the US_THR register in the datasheet). |
timeOut | Time out value (0 = no timeout). |
