RTEMS 5.2
armv4.h
1/*
2 * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
3 *
4 * embedded brains GmbH
5 * Dornierstr. 4
6 * 82178 Puchheim
7 * Germany
8 * <rtems@embedded-brains.de>
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef RTEMS_SCORE_ARMV4_H
16#define RTEMS_SCORE_ARMV4_H
17
18#include <rtems/score/cpu.h>
19
20#ifdef __cplusplus
21extern "C" {
22#endif /* __cplusplus */
23
24#ifdef ARM_MULTILIB_ARCH_V4
25
26void bsp_interrupt_dispatch( void );
27
28void _ARMV4_Exception_interrupt( void );
29
30typedef void ARMV4_Exception_abort_handler( CPU_Exception_frame *frame );
31
32void _ARMV4_Exception_data_abort_set_handler(
33 ARMV4_Exception_abort_handler handler
34);
35
36void _ARMV4_Exception_data_abort( void );
37
38void _ARMV4_Exception_prefetch_abort_set_handler(
39 ARMV4_Exception_abort_handler handler
40);
41
42void _ARMV4_Exception_prefetch_abort( void );
43
44void _ARMV4_Exception_undef_default( void );
45
46void _ARMV4_Exception_swi_default( void );
47
48void _ARMV4_Exception_data_abort_default( void );
49
50void _ARMV4_Exception_pref_abort_default( void );
51
52void _ARMV4_Exception_reserved_default( void );
53
54void _ARMV4_Exception_irq_default( void );
55
56void _ARMV4_Exception_fiq_default( void );
57
58static inline uint32_t _ARMV4_Status_irq_enable( void )
59{
60 uint32_t arm_switch_reg;
61 uint32_t psr;
62
64
65 __asm__ volatile (
66 ARM_SWITCH_TO_ARM
67 "mrs %[psr], cpsr\n"
68 "bic %[arm_switch_reg], %[psr], #0x80\n"
69 "msr cpsr, %[arm_switch_reg]\n"
70 ARM_SWITCH_BACK
71 : [arm_switch_reg] "=&r" (arm_switch_reg), [psr] "=&r" (psr)
72 );
73
74 return psr;
75}
76
77static inline void _ARMV4_Status_restore( uint32_t psr )
78{
79 ARM_SWITCH_REGISTERS;
80
81 __asm__ volatile (
82 ARM_SWITCH_TO_ARM
83 "msr cpsr, %[psr]\n"
84 ARM_SWITCH_BACK
85 : ARM_SWITCH_OUTPUT
86 : [psr] "r" (psr)
87 );
88
90}
91
92#endif /* ARM_MULTILIB_ARCH_V4 */
93
94#ifdef __cplusplus
95}
96#endif /* __cplusplus */
97
98#endif /* RTEMS_SCORE_ARMV4_H */
void bsp_interrupt_dispatch(void)
Interrupt dispatch.
Definition: irq.c:83
#define RTEMS_COMPILER_MEMORY_BARRIER()
Definition: basedefs.h:77
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
