RTEMS 5.2
DP8390 Ethernet Controller Support. More...
Controller DP8390. | |
#define | DATAPORT 0x10 |
Port Window. | |
#define | RESET 0x1f |
Issue a read for reset. | |
#define | W83CREG 0x00 |
I/O port definition. | |
#define | ADDROM 0x08 |
page 0 read or read/write registers | |
#define | CMDR 0x00+RO |
#define | CLDA0 0x01+RO |
current local dma addr 0 for read | |
#define | CLDA1 0x02+RO |
current local dma addr 1 for read | |
#define | BNRY 0x03+RO |
boundary reg for rd and wr | |
#define | TSR 0x04+RO |
tx status reg for rd | |
#define | NCR 0x05+RO |
number of collision reg for rd | |
#define | FIFO 0x06+RO |
#define | ISR 0x07+RO |
interrupt status reg for rd and wr | |
#define | CRDA0 0x08+RO |
current remote dma address 0 for rd | |
#define | CRDA1 0x09+RO |
current remote dma address 1 for rd | |
#define | RSR 0x0C+RO |
rx status reg for rd | |
#define | CNTR0 0x0D+RO |
tally cnt 0 for frm alg err for rd | |
#define | CNTR1 RO+0x0E |
tally cnt 1 for crc err for rd | |
#define | CNTR2 0x0F+RO |
tally cnt 2 for missed pkt for rd | |
page 0 write registers | |
#define | PSTART 0x01+RO |
page start register | |
#define | PSTOP 0x02+RO |
page stop register | |
#define | TPSR 0x04+RO |
#define | TBCR0 0x05+RO |
tx byte count 0 reg | |
#define | TBCR1 0x06+RO |
tx byte count 1 reg | |
#define | RSAR0 0x08+RO |
remote start address reg 0 | |
#define | RSAR1 0x09+RO |
remote start address reg 1 | |
#define | RBCR0 0x0A+RO |
remote byte count reg 0 | |
#define | RBCR1 0x0B+RO |
remote byte count reg 1 | |
#define | RCR 0x0C+RO |
rx configuration reg | |
#define | TCR 0x0D+RO |
tx configuration reg | |
#define | DCR RO+0x0E |
data configuration reg | |
#define | IMR 0x0F+RO |
interrupt mask reg | |
page 1 registers | |
#define | PAR 0x01+RO |
physical addr reg base for rd and wr | |
#define | CURR 0x07+RO |
current page reg for rd and wr | |
#define | MAR 0x08+RO |
multicast addr reg base fro rd and WR | |
#define | MARsize 8 |
size of multicast addr space | |
W83CREG command bits | |
#define | MSK_RESET 0x80 |
W83CREG masks. | |
#define | MSK_ENASH 0x40 |
#define | MSK_DECOD 0x3F |
memory decode bits, corresponding | |
CMDR command bits | |
#define | MSK_STP 0x01 |
stop the chip | |
#define | MSK_STA 0x02 |
start the chip | |
#define | MSK_TXP 0x04 |
initial txing of a frm | |
#define | MSK_RRE 0x08 |
remote read | |
#define | MSK_RWR 0x10 |
remote write | |
#define | MSK_RD2 0x20 |
no DMA used | |
#define | MSK_PG0 0x00 |
select register page 0 | |
#define | MSK_PG1 0x40 |
select register page 1 | |
#define | MSK_PG2 0x80 |
select register page 2 | |
ISR and TSR status bits | |
#define | MSK_PRX 0x01 |
#define | MSK_PTX 0x02 |
#define | MSK_RXE 0x04 |
#define | MSK_TXE 0x08 |
#define | MSK_OVW 0x10 |
#define | MSK_CNT 0x20 |
#define | MSK_RDC 0x40 |
#define | MSK_RST 0x80 |
DCR command bits | |
#define | MSK_WTS 0x01 |
word transfer mode selection | |
#define | MSK_BOS 0x02 |
byte order selection | |
#define | MSK_LAS 0x04 |
long addr selection | |
#define | MSK_BMS 0x08 |
burst mode selection | |
#define | MSK_ARM 0x10 |
autoinitialize remote | |
#define | MSK_FT00 0x00 |
burst lrngth selection | |
#define | MSK_FT01 0x20 |
#define | MSK_FT10 0x40 |
#define | MSK_FT11 0x60 |
RCR command bits | |
#define | MSK_SEP 0x01 |
save error pkts | |
#define | MSK_AR 0x02 |
accept runt pkt | |
#define | MSK_AB 0x04 |
8390 RCR | |
#define | MSK_AM 0x08 |
accept multicast | |
#define | MSK_PRO 0x10 |
accept all pkt with physical adr | |
#define | MSK_MON 0x20 |
monitor mode | |
TCR command bits | |
#define | MSK_CRC 0x01 |
inhibit CRC, do not append crc | |
#define | MSK_LOOP 0x02 |
set loopback mode | |
#define | MSK_BCST 0x04 |
Accept broadcasts. | |
#define | MSK_LB01 0x06 |
encoded loopback control | |
#define | MSK_ATD 0x08 |
auto tx disable | |
#define | MSK_OFST 0x10 |
collision offset enable | |
receive status bits | |
#define | SMK_PRX 0x01 |
rx without error | |
#define | SMK_CRC 0x02 |
CRC error. | |
#define | SMK_FAE 0x04 |
frame alignment error | |
#define | SMK_FO 0x08 |
FIFO overrun. | |
#define | SMK_MPA 0x10 |
missed pkt | |
#define | SMK_PHY 0x20 |
physical/multicase address | |
#define | SMK_DIS 0x40 |
receiver disable. set in monitor mode | |
#define | SMK_DEF 0x80 |
deferring | |
transmit status bits | |
#define | SMK_PTX 0x01 |
tx without error | |
#define | SMK_DFR 0x02 |
non deferred tx | |
#define | SMK_COL 0x04 |
tx collided | |
#define | SMK_ABT 0x08 |
tx abort because of excessive collisions | |
#define | SMK_CRS 0x10 |
carrier sense lost | |
#define | SMK_FU 0x20 |
FIFO underrun. | |
#define | SMK_CDH 0x40 |
collision detect heartbeat | |
#define | SMK_OWC 0x80 |
out of window collision | |
