RTEMS 5.2
| #define | L2_CACHE_ADDR_FILTERING_START_OFST 0xC00 |
| #define | L2_CACHE_ADDR_FILTERING_START_ADDR (ALT_MPUL2_OFST + L2_CACHE_ADDR_FILTERING_START_OFST) |
| #define | L2_CACHE_ADDR_FILTERING_START_ADDR_MASK 0xFFF00000 |
| #define | L2_CACHE_ADDR_FILTERING_START_RESET 0x100000 |
| #define | L2_CACHE_ADDR_FILTERING_ENABLE_MASK 0x00000001 |
| #define | L2_CACHE_ADDR_FILTERING_ENABLE_RESET 0x1 |
| #define | L2_CACHE_ADDR_FILTERING_END_OFST 0xC04 |
| #define | L2_CACHE_ADDR_FILTERING_END_ADDR (ALT_MPUL2_OFST + L2_CACHE_ADDR_FILTERING_END_OFST) |
| #define | L2_CACHE_ADDR_FILTERING_END_ADDR_MASK 0xFFF00000 |
| #define | L2_CACHE_ADDR_FILTERING_END_RESET 0xC0000000 |
External Master ID Macros | |
These macros define the HPS external master identifiers that are 12-bit input IDs to the ACP ID Mapper. Some of the masters have a range of identifier values assigned to them and are distinguished by taking a (var)</em> argument. | |
| #define | ALT_ACP_ID_MAP_MASTER_ID_MASK 0xfff |
| #define | ALT_ACP_ID_MAP_MASTER_ID_L2M0(var) (0x00000002 | (0x000007f8 & (var))) |
| #define | ALT_ACP_ID_MAP_MASTER_ID_DMA(var) (0x00000001 | (0x00000078 & (var))) |
| #define | ALT_ACP_ID_MAP_MASTER_ID_EMAC0(var) (0x00000801 | (0x00000878 & (var))) |
| #define | ALT_ACP_ID_MAP_MASTER_ID_EMAC1(var) (0x00000802 | (0x00000878 & (var))) |
| #define | ALT_ACP_ID_MAP_MASTER_ID_USB0 0x00000803 |
| #define | ALT_ACP_ID_MAP_MASTER_ID_USB1 0x00000806 |
| #define | ALT_ACP_ID_MAP_MASTER_ID_NAND(var) (0x00000804 | (0x00000ff8 & (var))) |
| #define | ALT_ACP_ID_MAP_MASTER_ID_TMC 0x00000800 |
| #define | ALT_ACP_ID_MAP_MASTER_ID_DAP 0x00000004 |
| #define | ALT_ACP_ID_MAP_MASTER_ID_SDMMC 0x00000805 |
| #define | ALT_ACP_ID_MAP_MASTER_ID_F2H(var) (0x00000000 | (0x000007f8 & (var))) |
Typedefs | |
| typedef enum ALT_ADDR_SPACE_MPU_ATTR_e | ALT_ADDR_SPACE_MPU_ATTR_t |
| typedef enum ALT_ADDR_SPACE_NONMPU_ATTR_e | ALT_ADDR_SPACE_NONMPU_ATTR_t |
| typedef enum ALT_ADDR_SPACE_H2F_BRIDGE_ATTR_e | ALT_ADDR_SPACE_H2F_BRIDGE_ATTR_t |
| typedef enum ALT_ADDR_SPACE_LWH2F_BRIDGE_ATTR_e | ALT_ADDR_SPACE_LWH2F_BRIDGE_ATTR_t |
| typedef enum ALT_ACP_ID_OUTPUT_ID_e | ALT_ACP_ID_OUTPUT_ID_t |
| typedef enum ALT_ACP_ID_MAP_PAGE_e | ALT_ACP_ID_MAP_PAGE_t |
Altera - SoC FPGA Address Space Manager
