RTEMS 5.2
hps.h
1
7/*******************************************************************************
8* *
9* Copyright 2013 Altera Corporation. All Rights Reserved. *
10* *
11* Redistribution and use in source and binary forms, with or without *
12* modification, are permitted provided that the following conditions are met: *
13* *
14* 1. Redistributions of source code must retain the above copyright notice, *
15* this list of conditions and the following disclaimer. *
16* *
17* 2. Redistributions in binary form must reproduce the above copyright notice, *
18* this list of conditions and the following disclaimer in the documentation *
19* and/or other materials provided with the distribution. *
20* *
21* 3. The name of the author may not be used to endorse or promote products *
22* derived from this software without specific prior written permission. *
23* *
24* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
25* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
26* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO *
27* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, *
28* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
29* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
30* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, *
31* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR *
32* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF *
33* ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *
34* *
35*******************************************************************************/
36
37/* Altera - hps */
38
39#ifndef __ALTERA_HPS_H__
40#define __ALTERA_HPS_H__
41
42#ifdef __cplusplus
43extern "C"
44{
45#endif /* __cplusplus */
46
47#define ALT_HPS_ADDR 0
48/*
49 * Address Space : ALT_HPS
50 *
51 */
52/*
53 * Component Instance : stm
54 *
55 * Instance stm of component ALT_STM.
56 *
57 *
58 */
59/* The address of the ALT_STM_REG register for the ALT_STM instance. */
60#define ALT_STM_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_STM_ADDR) + ALT_STM_REG_OFST))
61/* The base address byte offset for the start of the ALT_STM component. */
62#define ALT_STM_OFST 0xfc000000
63/* The start address of the ALT_STM component. */
64#define ALT_STM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_STM_OFST))
65/* The lower bound address range of the ALT_STM component. */
66#define ALT_STM_LB_ADDR ALT_STM_ADDR
67/* The upper bound address range of the ALT_STM component. */
68#define ALT_STM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_STM_ADDR) + 0x4) - 1))
69
70
71/*
72 * Component Instance : dap
73 *
74 * Instance dap of component ALT_DAP.
75 *
76 *
77 */
78/* The address of the ALT_DAP_REG register for the ALT_DAP instance. */
79#define ALT_DAP_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_DAP_ADDR) + ALT_DAP_REG_OFST))
80/* The base address byte offset for the start of the ALT_DAP component. */
81#define ALT_DAP_OFST 0xff000000
82/* The start address of the ALT_DAP component. */
83#define ALT_DAP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_DAP_OFST))
84/* The lower bound address range of the ALT_DAP component. */
85#define ALT_DAP_LB_ADDR ALT_DAP_ADDR
86/* The upper bound address range of the ALT_DAP component. */
87#define ALT_DAP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_DAP_ADDR) + 0x4) - 1))
88
89
90/*
91 * Component Instance : lwfpgaslaves
92 *
93 * Instance lwfpgaslaves of component ALT_LWFPGASLVS.
94 *
95 *
96 */
97/* The base address byte offset for the start of the ALT_LWFPGASLVS component. */
98#define ALT_LWFPGASLVS_OFST 0xff200000
99/* The start address of the ALT_LWFPGASLVS component. */
100#define ALT_LWFPGASLVS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_LWFPGASLVS_OFST))
101/* The lower bound address range of the ALT_LWFPGASLVS component. */
102#define ALT_LWFPGASLVS_LB_ADDR ALT_LWFPGASLVS_ADDR
103/* The upper bound address range of the ALT_LWFPGASLVS component. */
104#define ALT_LWFPGASLVS_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWFPGASLVS_ADDR) + 0x200000) - 1))
105
106
107/*
108 * Component Instance : lwhps2fpgaregs
109 *
110 * Instance lwhps2fpgaregs of component ALT_LWH2F.
111 *
112 *
113 */
114/*
115 * Register Group Instance : idgrp
116 *
117 * Instance idgrp of register group ALT_LWH2F_ID.
118 *
119 *
120 */
121/* The address of the ALT_LWH2F_ID_PERIPH_ID_4 register for the ALT_LWH2F_ID instance. */
122#define ALT_LWH2F_ID_PERIPH_ID_4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_PERIPH_ID_4_OFST))
123/* The address of the ALT_LWH2F_ID_PERIPH_ID_0 register for the ALT_LWH2F_ID instance. */
124#define ALT_LWH2F_ID_PERIPH_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_PERIPH_ID_0_OFST))
125/* The address of the ALT_LWH2F_ID_PERIPH_ID_1 register for the ALT_LWH2F_ID instance. */
126#define ALT_LWH2F_ID_PERIPH_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_PERIPH_ID_1_OFST))
127/* The address of the ALT_LWH2F_ID_PERIPH_ID_2 register for the ALT_LWH2F_ID instance. */
128#define ALT_LWH2F_ID_PERIPH_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_PERIPH_ID_2_OFST))
129/* The address of the ALT_LWH2F_ID_PERIPH_ID_3 register for the ALT_LWH2F_ID instance. */
130#define ALT_LWH2F_ID_PERIPH_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_PERIPH_ID_3_OFST))
131/* The address of the ALT_LWH2F_ID_COMP_ID_0 register for the ALT_LWH2F_ID instance. */
132#define ALT_LWH2F_ID_COMP_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_COMP_ID_0_OFST))
133/* The address of the ALT_LWH2F_ID_COMP_ID_1 register for the ALT_LWH2F_ID instance. */
134#define ALT_LWH2F_ID_COMP_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_COMP_ID_1_OFST))
135/* The address of the ALT_LWH2F_ID_COMP_ID_2 register for the ALT_LWH2F_ID instance. */
136#define ALT_LWH2F_ID_COMP_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_COMP_ID_2_OFST))
137/* The address of the ALT_LWH2F_ID_COMP_ID_3 register for the ALT_LWH2F_ID instance. */
138#define ALT_LWH2F_ID_COMP_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_COMP_ID_3_OFST))
139/* The base address byte offset for the start of the ALT_LWH2F_ID component. */
140#define ALT_LWH2F_ID_OFST 0x1000
141/* The start address of the ALT_LWH2F_ID component. */
142#define ALT_LWH2F_ID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ADDR) + ALT_LWH2F_ID_OFST))
143/* The lower bound address range of the ALT_LWH2F_ID component. */
144#define ALT_LWH2F_ID_LB_ADDR ALT_LWH2F_ID_ADDR
145/* The upper bound address range of the ALT_LWH2F_ID component. */
146#define ALT_LWH2F_ID_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + 0x1000) - 1))
147
148
149/*
150 * Register Group Instance : mastergrp
151 *
152 * Instance mastergrp of register group ALT_LWH2F_MST.
153 *
154 *
155 */
156/*
157 * Register Group Instance : mastergrp_fpga2hpsregs
158 *
159 * Instance mastergrp_fpga2hpsregs of register group ALT_LWH2F_MST_F2H.
160 *
161 *
162 */
163/* The address of the ALT_LWH2F_FN_MOD_BM_ISS register for the ALT_LWH2F_MST_MST_F2H instance. */
164#define ALT_LWH2F_MST_MST_F2H_FN_MOD_BM_ISS_ADDR ALT_LWH2F_FN_MOD_BM_ISS_ADDR(ALT_LWH2F_MST_MST_F2H_ADDR)
165/* The address of the ALT_LWH2F_AHB_CNTL register for the ALT_LWH2F_MST_MST_F2H instance. */
166#define ALT_LWH2F_MST_MST_F2H_AHB_CNTL_ADDR ALT_LWH2F_AHB_CNTL_ADDR(ALT_LWH2F_MST_MST_F2H_ADDR)
167/* The base address byte offset for the start of the ALT_LWH2F_MST_MST_F2H component. */
168#define ALT_LWH2F_MST_MST_F2H_OFST 0x0
169/* The start address of the ALT_LWH2F_MST_MST_F2H component. */
170#define ALT_LWH2F_MST_MST_F2H_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_MST_ADDR) + ALT_LWH2F_MST_MST_F2H_OFST))
171/* The lower bound address range of the ALT_LWH2F_MST_MST_F2H component. */
172#define ALT_LWH2F_MST_MST_F2H_LB_ADDR ALT_LWH2F_MST_MST_F2H_ADDR
173/* The upper bound address range of the ALT_LWH2F_MST_MST_F2H component. */
174#define ALT_LWH2F_MST_MST_F2H_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_MST_MST_F2H_ADDR) + 0x48) - 1))
175
176
177/*
178 * Register Group Instance : mastergrp_hps2fpgaregs
179 *
180 * Instance mastergrp_hps2fpgaregs of register group ALT_LWH2F_MST_H2F.
181 *
182 *
183 */
184/* The address of the ALT_LWH2F_FN_MOD_BM_ISS register for the ALT_LWH2F_MST_MST_H2F instance. */
185#define ALT_LWH2F_MST_MST_H2F_FN_MOD_BM_ISS_ADDR ALT_LWH2F_FN_MOD_BM_ISS_ADDR(ALT_LWH2F_MST_MST_H2F_ADDR)
186/* The address of the ALT_LWH2F_AHB_CNTL register for the ALT_LWH2F_MST_MST_H2F instance. */
187#define ALT_LWH2F_MST_MST_H2F_AHB_CNTL_ADDR ALT_LWH2F_AHB_CNTL_ADDR(ALT_LWH2F_MST_MST_H2F_ADDR)
188/* The base address byte offset for the start of the ALT_LWH2F_MST_MST_H2F component. */
189#define ALT_LWH2F_MST_MST_H2F_OFST 0x1000
190/* The start address of the ALT_LWH2F_MST_MST_H2F component. */
191#define ALT_LWH2F_MST_MST_H2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_MST_ADDR) + ALT_LWH2F_MST_MST_H2F_OFST))
192/* The lower bound address range of the ALT_LWH2F_MST_MST_H2F component. */
193#define ALT_LWH2F_MST_MST_H2F_LB_ADDR ALT_LWH2F_MST_MST_H2F_ADDR
194/* The upper bound address range of the ALT_LWH2F_MST_MST_H2F component. */
195#define ALT_LWH2F_MST_MST_H2F_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_MST_MST_H2F_ADDR) + 0x48) - 1))
196
197
198/*
199 * Register Group Instance : mastergrp_b32
200 *
201 * Instance mastergrp_b32 of register group ALT_LWH2F_MST_B32.
202 *
203 *
204 */
205/* The address of the ALT_LWH2F_FN_MOD_BM_ISS register for the ALT_LWH2F_MST_MST_B32 instance. */
206#define ALT_LWH2F_MST_MST_B32_FN_MOD_BM_ISS_ADDR ALT_LWH2F_FN_MOD_BM_ISS_ADDR(ALT_LWH2F_MST_MST_B32_ADDR)
207/* The address of the ALT_LWH2F_WR_TIDEMARK register for the ALT_LWH2F_MST_MST_B32 instance. */
208#define ALT_LWH2F_MST_MST_B32_WR_TIDEMARK_ADDR ALT_LWH2F_WR_TIDEMARK_ADDR(ALT_LWH2F_MST_MST_B32_ADDR)
209/* The address of the ALT_LWH2F_FN_MOD register for the ALT_LWH2F_MST_MST_B32 instance. */
210#define ALT_LWH2F_MST_MST_B32_FN_MOD_ADDR ALT_LWH2F_FN_MOD_ADDR(ALT_LWH2F_MST_MST_B32_ADDR)
211/* The base address byte offset for the start of the ALT_LWH2F_MST_MST_B32 component. */
212#define ALT_LWH2F_MST_MST_B32_OFST 0x3000
213/* The start address of the ALT_LWH2F_MST_MST_B32 component. */
214#define ALT_LWH2F_MST_MST_B32_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_MST_ADDR) + ALT_LWH2F_MST_MST_B32_OFST))
215/* The lower bound address range of the ALT_LWH2F_MST_MST_B32 component. */
216#define ALT_LWH2F_MST_MST_B32_LB_ADDR ALT_LWH2F_MST_MST_B32_ADDR
217/* The upper bound address range of the ALT_LWH2F_MST_MST_B32 component. */
218#define ALT_LWH2F_MST_MST_B32_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_MST_MST_B32_ADDR) + 0x10c) - 1))
219
220
221/* The base address byte offset for the start of the ALT_LWH2F_MST component. */
222#define ALT_LWH2F_MST_OFST 0x2000
223/* The start address of the ALT_LWH2F_MST component. */
224#define ALT_LWH2F_MST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ADDR) + ALT_LWH2F_MST_OFST))
225/* The lower bound address range of the ALT_LWH2F_MST component. */
226#define ALT_LWH2F_MST_LB_ADDR ALT_LWH2F_MST_ADDR
227/* The upper bound address range of the ALT_LWH2F_MST component. */
228#define ALT_LWH2F_MST_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_MST_ADDR) + 0x310c) - 1))
229
230
231/*
232 * Register Group Instance : slavegrp
233 *
234 * Instance slavegrp of register group ALT_LWH2F_SLV.
235 *
236 *
237 */
238/*
239 * Register Group Instance : slavegrp_b32
240 *
241 * Instance slavegrp_b32 of register group ALT_LWH2F_SLV_B32.
242 *
243 *
244 */
245/* The address of the ALT_LWH2F_FN_MOD register for the ALT_LWH2F_SLV_SLV_B32 instance. */
246#define ALT_LWH2F_SLV_SLV_B32_FN_MOD_ADDR ALT_LWH2F_FN_MOD_ADDR(ALT_LWH2F_SLV_SLV_B32_ADDR)
247/* The base address byte offset for the start of the ALT_LWH2F_SLV_SLV_B32 component. */
248#define ALT_LWH2F_SLV_SLV_B32_OFST 0x3000
249/* The start address of the ALT_LWH2F_SLV_SLV_B32 component. */
250#define ALT_LWH2F_SLV_SLV_B32_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_SLV_ADDR) + ALT_LWH2F_SLV_SLV_B32_OFST))
251/* The lower bound address range of the ALT_LWH2F_SLV_SLV_B32 component. */
252#define ALT_LWH2F_SLV_SLV_B32_LB_ADDR ALT_LWH2F_SLV_SLV_B32_ADDR
253/* The upper bound address range of the ALT_LWH2F_SLV_SLV_B32 component. */
254#define ALT_LWH2F_SLV_SLV_B32_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_SLV_SLV_B32_ADDR) + 0x10c) - 1))
255
256
257/* The base address byte offset for the start of the ALT_LWH2F_SLV component. */
258#define ALT_LWH2F_SLV_OFST 0x42000
259/* The start address of the ALT_LWH2F_SLV component. */
260#define ALT_LWH2F_SLV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ADDR) + ALT_LWH2F_SLV_OFST))
261/* The lower bound address range of the ALT_LWH2F_SLV component. */
262#define ALT_LWH2F_SLV_LB_ADDR ALT_LWH2F_SLV_ADDR
263/* The upper bound address range of the ALT_LWH2F_SLV component. */
264#define ALT_LWH2F_SLV_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_SLV_ADDR) + 0x310c) - 1))
265
266
267/* The base address byte offset for the start of the ALT_LWH2F component. */
268#define ALT_LWH2F_OFST 0xff400000
269/* The start address of the ALT_LWH2F component. */
270#define ALT_LWH2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_LWH2F_OFST))
271/* The lower bound address range of the ALT_LWH2F component. */
272#define ALT_LWH2F_LB_ADDR ALT_LWH2F_ADDR
273/* The upper bound address range of the ALT_LWH2F component. */
274#define ALT_LWH2F_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_ADDR) + 0x80000) - 1))
275
276
277/*
278 * Component Instance : hps2fpgaregs
279 *
280 * Instance hps2fpgaregs of component ALT_H2F.
281 *
282 *
283 */
284/*
285 * Register Group Instance : idgrp
286 *
287 * Instance idgrp of register group ALT_H2F_IDGRP.
288 *
289 *
290 */
291/* The address of the ALT_H2F_ID_PERIPH_ID_4 register for the ALT_H2F_IDGRP instance. */
292#define ALT_H2F_ID_PERIPH_ID_4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_PERIPH_ID_4_OFST))
293/* The address of the ALT_H2F_ID_PERIPH_ID_0 register for the ALT_H2F_IDGRP instance. */
294#define ALT_H2F_ID_PERIPH_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_PERIPH_ID_0_OFST))
295/* The address of the ALT_H2F_ID_PERIPH_ID_1 register for the ALT_H2F_IDGRP instance. */
296#define ALT_H2F_ID_PERIPH_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_PERIPH_ID_1_OFST))
297/* The address of the ALT_H2F_ID_PERIPH_ID_2 register for the ALT_H2F_IDGRP instance. */
298#define ALT_H2F_ID_PERIPH_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_PERIPH_ID_2_OFST))
299/* The address of the ALT_H2F_ID_PERIPH_ID_3 register for the ALT_H2F_IDGRP instance. */
300#define ALT_H2F_ID_PERIPH_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_PERIPH_ID_3_OFST))
301/* The address of the ALT_H2F_ID_COMP_ID_0 register for the ALT_H2F_IDGRP instance. */
302#define ALT_H2F_ID_COMP_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_COMP_ID_0_OFST))
303/* The address of the ALT_H2F_ID_COMP_ID_1 register for the ALT_H2F_IDGRP instance. */
304#define ALT_H2F_ID_COMP_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_COMP_ID_1_OFST))
305/* The address of the ALT_H2F_ID_COMP_ID_2 register for the ALT_H2F_IDGRP instance. */
306#define ALT_H2F_ID_COMP_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_COMP_ID_2_OFST))
307/* The address of the ALT_H2F_ID_COMP_ID_3 register for the ALT_H2F_IDGRP instance. */
308#define ALT_H2F_ID_COMP_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_COMP_ID_3_OFST))
309/* The base address byte offset for the start of the ALT_H2F_IDGRP component. */
310#define ALT_H2F_IDGRP_OFST 0x1000
311/* The start address of the ALT_H2F_IDGRP component. */
312#define ALT_H2F_IDGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_ADDR) + ALT_H2F_IDGRP_OFST))
313/* The lower bound address range of the ALT_H2F_IDGRP component. */
314#define ALT_H2F_IDGRP_LB_ADDR ALT_H2F_IDGRP_ADDR
315/* The upper bound address range of the ALT_H2F_IDGRP component. */
316#define ALT_H2F_IDGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + 0x1000) - 1))
317
318
319/*
320 * Register Group Instance : mastergrp
321 *
322 * Instance mastergrp of register group ALT_H2F_MSTGRP.
323 *
324 *
325 */
326/*
327 * Register Group Instance : mastergrp_b32
328 *
329 * Instance mastergrp_b32 of register group ALT_H2F_MST_B32.
330 *
331 *
332 */
333/* The address of the ALT_H2F_FN_MOD2 register for the ALT_H2F_MST_MST_B32 instance. */
334#define ALT_H2F_MST_MST_B32_FN_MOD2_ADDR ALT_H2F_FN_MOD2_ADDR(ALT_H2F_MST_MST_B32_ADDR)
335/* The address of the ALT_H2F_FN_MOD register for the ALT_H2F_MST_MST_B32 instance. */
336#define ALT_H2F_MST_MST_B32_FN_MOD_ADDR ALT_H2F_FN_MOD_ADDR(ALT_H2F_MST_MST_B32_ADDR)
337/* The base address byte offset for the start of the ALT_H2F_MST_MST_B32 component. */
338#define ALT_H2F_MST_MST_B32_OFST 0x0
339/* The start address of the ALT_H2F_MST_MST_B32 component. */
340#define ALT_H2F_MST_MST_B32_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_MSTGRP_ADDR) + ALT_H2F_MST_MST_B32_OFST))
341/* The lower bound address range of the ALT_H2F_MST_MST_B32 component. */
342#define ALT_H2F_MST_MST_B32_LB_ADDR ALT_H2F_MST_MST_B32_ADDR
343/* The upper bound address range of the ALT_H2F_MST_MST_B32 component. */
344#define ALT_H2F_MST_MST_B32_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_H2F_MST_MST_B32_ADDR) + 0x10c) - 1))
345
346
347/*
348 * Register Group Instance : mastergrp_b128
349 *
350 * Instance mastergrp_b128 of register group ALT_H2F_MST_B128.
351 *
352 *
353 */
354/* The address of the ALT_H2F_FN_MOD2 register for the ALT_H2F_MST_MST_B128 instance. */
355#define ALT_H2F_MST_MST_B128_FN_MOD2_ADDR ALT_H2F_FN_MOD2_ADDR(ALT_H2F_MST_MST_B128_ADDR)
356/* The address of the ALT_H2F_FN_MOD register for the ALT_H2F_MST_MST_B128 instance. */
357#define ALT_H2F_MST_MST_B128_FN_MOD_ADDR ALT_H2F_FN_MOD_ADDR(ALT_H2F_MST_MST_B128_ADDR)
358/* The base address byte offset for the start of the ALT_H2F_MST_MST_B128 component. */
359#define ALT_H2F_MST_MST_B128_OFST 0x2000
360/* The start address of the ALT_H2F_MST_MST_B128 component. */
361#define ALT_H2F_MST_MST_B128_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_MSTGRP_ADDR) + ALT_H2F_MST_MST_B128_OFST))
362/* The lower bound address range of the ALT_H2F_MST_MST_B128 component. */
363#define ALT_H2F_MST_MST_B128_LB_ADDR ALT_H2F_MST_MST_B128_ADDR
364/* The upper bound address range of the ALT_H2F_MST_MST_B128 component. */
365#define ALT_H2F_MST_MST_B128_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_H2F_MST_MST_B128_ADDR) + 0x10c) - 1))
366
367
368/* The base address byte offset for the start of the ALT_H2F_MSTGRP component. */
369#define ALT_H2F_MSTGRP_OFST 0x2000
370/* The start address of the ALT_H2F_MSTGRP component. */
371#define ALT_H2F_MSTGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_ADDR) + ALT_H2F_MSTGRP_OFST))
372/* The lower bound address range of the ALT_H2F_MSTGRP component. */
373#define ALT_H2F_MSTGRP_LB_ADDR ALT_H2F_MSTGRP_ADDR
374/* The upper bound address range of the ALT_H2F_MSTGRP component. */
375#define ALT_H2F_MSTGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_H2F_MSTGRP_ADDR) + 0x210c) - 1))
376
377
378/* The base address byte offset for the start of the ALT_H2F component. */
379#define ALT_H2F_OFST 0xff500000
380/* The start address of the ALT_H2F component. */
381#define ALT_H2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_H2F_OFST))
382/* The lower bound address range of the ALT_H2F component. */
383#define ALT_H2F_LB_ADDR ALT_H2F_ADDR
384/* The upper bound address range of the ALT_H2F component. */
385#define ALT_H2F_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_H2F_ADDR) + 0x8000) - 1))
386
387
388/*
389 * Component Instance : fpga2hpsregs
390 *
391 * Instance fpga2hpsregs of component ALT_F2H.
392 *
393 *
394 */
395/*
396 * Register Group Instance : idgrp
397 *
398 * Instance idgrp of register group ALT_F2H_IDGRP.
399 *
400 *
401 */
402/* The address of the ALT_F2H_ID_PERIPH_ID_4 register for the ALT_F2H_IDGRP instance. */
403#define ALT_F2H_ID_PERIPH_ID_4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_PERIPH_ID_4_OFST))
404/* The address of the ALT_F2H_ID_PERIPH_ID_0 register for the ALT_F2H_IDGRP instance. */
405#define ALT_F2H_ID_PERIPH_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_PERIPH_ID_0_OFST))
406/* The address of the ALT_F2H_ID_PERIPH_ID_1 register for the ALT_F2H_IDGRP instance. */
407#define ALT_F2H_ID_PERIPH_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_PERIPH_ID_1_OFST))
408/* The address of the ALT_F2H_ID_PERIPH_ID_2 register for the ALT_F2H_IDGRP instance. */
409#define ALT_F2H_ID_PERIPH_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_PERIPH_ID_2_OFST))
410/* The address of the ALT_F2H_ID_PERIPH_ID_3 register for the ALT_F2H_IDGRP instance. */
411#define ALT_F2H_ID_PERIPH_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_PERIPH_ID_3_OFST))
412/* The address of the ALT_F2H_ID_COMP_ID_0 register for the ALT_F2H_IDGRP instance. */
413#define ALT_F2H_ID_COMP_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_COMP_ID_0_OFST))
414/* The address of the ALT_F2H_ID_COMP_ID_1 register for the ALT_F2H_IDGRP instance. */
415#define ALT_F2H_ID_COMP_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_COMP_ID_1_OFST))
416/* The address of the ALT_F2H_ID_COMP_ID_2 register for the ALT_F2H_IDGRP instance. */
417#define ALT_F2H_ID_COMP_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_COMP_ID_2_OFST))
418/* The address of the ALT_F2H_ID_COMP_ID_3 register for the ALT_F2H_IDGRP instance. */
419#define ALT_F2H_ID_COMP_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_COMP_ID_3_OFST))
420/* The base address byte offset for the start of the ALT_F2H_IDGRP component. */
421#define ALT_F2H_IDGRP_OFST 0x1000
422/* The start address of the ALT_F2H_IDGRP component. */
423#define ALT_F2H_IDGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_ADDR) + ALT_F2H_IDGRP_OFST))
424/* The lower bound address range of the ALT_F2H_IDGRP component. */
425#define ALT_F2H_IDGRP_LB_ADDR ALT_F2H_IDGRP_ADDR
426/* The upper bound address range of the ALT_F2H_IDGRP component. */
427#define ALT_F2H_IDGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + 0x1000) - 1))
428
429
430/*
431 * Register Group Instance : slavegrp
432 *
433 * Instance slavegrp of register group ALT_F2H_SLVGRP.
434 *
435 *
436 */
437/*
438 * Register Group Instance : slavegrp_b32
439 *
440 * Instance slavegrp_b32 of register group ALT_F2H_SLV_B32.
441 *
442 *
443 */
444/* The address of the ALT_F2H_FN_MOD2 register for the ALT_F2H_SLV_SLV_B32 instance. */
445#define ALT_F2H_SLV_SLV_B32_FN_MOD2_ADDR ALT_F2H_FN_MOD2_ADDR(ALT_F2H_SLV_SLV_B32_ADDR)
446/* The address of the ALT_F2H_FN_MOD register for the ALT_F2H_SLV_SLV_B32 instance. */
447#define ALT_F2H_SLV_SLV_B32_FN_MOD_ADDR ALT_F2H_FN_MOD_ADDR(ALT_F2H_SLV_SLV_B32_ADDR)
448/* The base address byte offset for the start of the ALT_F2H_SLV_SLV_B32 component. */
449#define ALT_F2H_SLV_SLV_B32_OFST 0x0
450/* The start address of the ALT_F2H_SLV_SLV_B32 component. */
451#define ALT_F2H_SLV_SLV_B32_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_SLVGRP_ADDR) + ALT_F2H_SLV_SLV_B32_OFST))
452/* The lower bound address range of the ALT_F2H_SLV_SLV_B32 component. */
453#define ALT_F2H_SLV_SLV_B32_LB_ADDR ALT_F2H_SLV_SLV_B32_ADDR
454/* The upper bound address range of the ALT_F2H_SLV_SLV_B32 component. */
455#define ALT_F2H_SLV_SLV_B32_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_F2H_SLV_SLV_B32_ADDR) + 0x10c) - 1))
456
457
458/*
459 * Register Group Instance : slavegrp_b128
460 *
461 * Instance slavegrp_b128 of register group ALT_F2H_SLV_B128.
462 *
463 *
464 */
465/* The address of the ALT_F2H_FN_MOD2 register for the ALT_F2H_SLV_SLV_B128 instance. */
466#define ALT_F2H_SLV_SLV_B128_FN_MOD2_ADDR ALT_F2H_FN_MOD2_ADDR(ALT_F2H_SLV_SLV_B128_ADDR)
467/* The address of the ALT_F2H_FN_MOD register for the ALT_F2H_SLV_SLV_B128 instance. */
468#define ALT_F2H_SLV_SLV_B128_FN_MOD_ADDR ALT_F2H_FN_MOD_ADDR(ALT_F2H_SLV_SLV_B128_ADDR)
469/* The base address byte offset for the start of the ALT_F2H_SLV_SLV_B128 component. */
470#define ALT_F2H_SLV_SLV_B128_OFST 0x2000
471/* The start address of the ALT_F2H_SLV_SLV_B128 component. */
472#define ALT_F2H_SLV_SLV_B128_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_SLVGRP_ADDR) + ALT_F2H_SLV_SLV_B128_OFST))
473/* The lower bound address range of the ALT_F2H_SLV_SLV_B128 component. */
474#define ALT_F2H_SLV_SLV_B128_LB_ADDR ALT_F2H_SLV_SLV_B128_ADDR
475/* The upper bound address range of the ALT_F2H_SLV_SLV_B128 component. */
476#define ALT_F2H_SLV_SLV_B128_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_F2H_SLV_SLV_B128_ADDR) + 0x10c) - 1))
477
478
479/* The base address byte offset for the start of the ALT_F2H_SLVGRP component. */
480#define ALT_F2H_SLVGRP_OFST 0x42000
481/* The start address of the ALT_F2H_SLVGRP component. */
482#define ALT_F2H_SLVGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_ADDR) + ALT_F2H_SLVGRP_OFST))
483/* The lower bound address range of the ALT_F2H_SLVGRP component. */
484#define ALT_F2H_SLVGRP_LB_ADDR ALT_F2H_SLVGRP_ADDR
485/* The upper bound address range of the ALT_F2H_SLVGRP component. */
486#define ALT_F2H_SLVGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_F2H_SLVGRP_ADDR) + 0x210c) - 1))
487
488
489/* The base address byte offset for the start of the ALT_F2H component. */
490#define ALT_F2H_OFST 0xff600000
491/* The start address of the ALT_F2H component. */
492#define ALT_F2H_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_F2H_OFST))
493/* The lower bound address range of the ALT_F2H component. */
494#define ALT_F2H_LB_ADDR ALT_F2H_ADDR
495/* The upper bound address range of the ALT_F2H component. */
496#define ALT_F2H_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_F2H_ADDR) + 0x80000) - 1))
497
498
499/*
500 * Component Instance : emac0
501 *
502 * Instance emac0 of component ALT_EMAC.
503 *
504 *
505 */
506/*
507 * Register Group Instance : gmacgrp
508 *
509 * Instance gmacgrp of register group ALT_EMAC_GMAC.
510 *
511 *
512 */
513/* The address of the ALT_EMAC_GMAC_MAC_CFG register for the ALT_EMAC0_GMACGRP instance. */
514#define ALT_EMAC0_GMAC_MAC_CFG_ADDR ALT_EMAC_GMAC_MAC_CFG_ADDR(ALT_EMAC0_GMACGRP_ADDR)
515/* The address of the ALT_EMAC_GMAC_MAC_FRM_FLT register for the ALT_EMAC0_GMACGRP instance. */
516#define ALT_EMAC0_GMAC_MAC_FRM_FLT_ADDR ALT_EMAC_GMAC_MAC_FRM_FLT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
517/* The address of the ALT_EMAC_GMAC_GMII_ADDR register for the ALT_EMAC0_GMACGRP instance. */
518#define ALT_EMAC0_GMAC_GMII_ADDR_ADDR ALT_EMAC_GMAC_GMII_ADDR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
519/* The address of the ALT_EMAC_GMAC_GMII_DATA register for the ALT_EMAC0_GMACGRP instance. */
520#define ALT_EMAC0_GMAC_GMII_DATA_ADDR ALT_EMAC_GMAC_GMII_DATA_ADDR(ALT_EMAC0_GMACGRP_ADDR)
521/* The address of the ALT_EMAC_GMAC_FLOW_CTL register for the ALT_EMAC0_GMACGRP instance. */
522#define ALT_EMAC0_GMAC_FLOW_CTL_ADDR ALT_EMAC_GMAC_FLOW_CTL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
523/* The address of the ALT_EMAC_GMAC_VLAN_TAG register for the ALT_EMAC0_GMACGRP instance. */
524#define ALT_EMAC0_GMAC_VLAN_TAG_ADDR ALT_EMAC_GMAC_VLAN_TAG_ADDR(ALT_EMAC0_GMACGRP_ADDR)
525/* The address of the ALT_EMAC_GMAC_VER register for the ALT_EMAC0_GMACGRP instance. */
526#define ALT_EMAC0_GMAC_VER_ADDR ALT_EMAC_GMAC_VER_ADDR(ALT_EMAC0_GMACGRP_ADDR)
527/* The address of the ALT_EMAC_GMAC_DBG register for the ALT_EMAC0_GMACGRP instance. */
528#define ALT_EMAC0_GMAC_DBG_ADDR ALT_EMAC_GMAC_DBG_ADDR(ALT_EMAC0_GMACGRP_ADDR)
529/* The address of the ALT_EMAC_GMAC_LPI_CTL_STAT register for the ALT_EMAC0_GMACGRP instance. */
530#define ALT_EMAC0_GMAC_LPI_CTL_STAT_ADDR ALT_EMAC_GMAC_LPI_CTL_STAT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
531/* The address of the ALT_EMAC_GMAC_LPI_TMRS_CTL register for the ALT_EMAC0_GMACGRP instance. */
532#define ALT_EMAC0_GMAC_LPI_TMRS_CTL_ADDR ALT_EMAC_GMAC_LPI_TMRS_CTL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
533/* The address of the ALT_EMAC_GMAC_INT_STAT register for the ALT_EMAC0_GMACGRP instance. */
534#define ALT_EMAC0_GMAC_INT_STAT_ADDR ALT_EMAC_GMAC_INT_STAT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
535/* The address of the ALT_EMAC_GMAC_INT_MSK register for the ALT_EMAC0_GMACGRP instance. */
536#define ALT_EMAC0_GMAC_INT_MSK_ADDR ALT_EMAC_GMAC_INT_MSK_ADDR(ALT_EMAC0_GMACGRP_ADDR)
537/* The address of the ALT_EMAC_GMAC_MAC_ADDR0_HIGH register for the ALT_EMAC0_GMACGRP instance. */
538#define ALT_EMAC0_GMAC_MAC_ADDR0_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR0_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
539/* The address of the ALT_EMAC_GMAC_MAC_ADDR0_LOW register for the ALT_EMAC0_GMACGRP instance. */
540#define ALT_EMAC0_GMAC_MAC_ADDR0_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR0_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
541/* The address of the ALT_EMAC_GMAC_MAC_ADDR1_HIGH register for the ALT_EMAC0_GMACGRP instance. */
542#define ALT_EMAC0_GMAC_MAC_ADDR1_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR1_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
543/* The address of the ALT_EMAC_GMAC_MAC_ADDR1_LOW register for the ALT_EMAC0_GMACGRP instance. */
544#define ALT_EMAC0_GMAC_MAC_ADDR1_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR1_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
545/* The address of the ALT_EMAC_GMAC_MAC_ADDR2_HIGH register for the ALT_EMAC0_GMACGRP instance. */
546#define ALT_EMAC0_GMAC_MAC_ADDR2_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR2_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
547/* The address of the ALT_EMAC_GMAC_MAC_ADDR2_LOW register for the ALT_EMAC0_GMACGRP instance. */
548#define ALT_EMAC0_GMAC_MAC_ADDR2_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR2_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
549/* The address of the ALT_EMAC_GMAC_MAC_ADDR3_HIGH register for the ALT_EMAC0_GMACGRP instance. */
550#define ALT_EMAC0_GMAC_MAC_ADDR3_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR3_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
551/* The address of the ALT_EMAC_GMAC_MAC_ADDR3_LOW register for the ALT_EMAC0_GMACGRP instance. */
552#define ALT_EMAC0_GMAC_MAC_ADDR3_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR3_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
553/* The address of the ALT_EMAC_GMAC_MAC_ADDR4_HIGH register for the ALT_EMAC0_GMACGRP instance. */
554#define ALT_EMAC0_GMAC_MAC_ADDR4_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR4_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
555/* The address of the ALT_EMAC_GMAC_MAC_ADDR4_LOW register for the ALT_EMAC0_GMACGRP instance. */
556#define ALT_EMAC0_GMAC_MAC_ADDR4_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR4_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
557/* The address of the ALT_EMAC_GMAC_MAC_ADDR5_HIGH register for the ALT_EMAC0_GMACGRP instance. */
558#define ALT_EMAC0_GMAC_MAC_ADDR5_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR5_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
559/* The address of the ALT_EMAC_GMAC_MAC_ADDR5_LOW register for the ALT_EMAC0_GMACGRP instance. */
560#define ALT_EMAC0_GMAC_MAC_ADDR5_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR5_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
561/* The address of the ALT_EMAC_GMAC_MAC_ADDR6_HIGH register for the ALT_EMAC0_GMACGRP instance. */
562#define ALT_EMAC0_GMAC_MAC_ADDR6_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR6_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
563/* The address of the ALT_EMAC_GMAC_MAC_ADDR6_LOW register for the ALT_EMAC0_GMACGRP instance. */
564#define ALT_EMAC0_GMAC_MAC_ADDR6_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR6_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
565/* The address of the ALT_EMAC_GMAC_MAC_ADDR7_HIGH register for the ALT_EMAC0_GMACGRP instance. */
566#define ALT_EMAC0_GMAC_MAC_ADDR7_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR7_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
567/* The address of the ALT_EMAC_GMAC_MAC_ADDR7_LOW register for the ALT_EMAC0_GMACGRP instance. */
568#define ALT_EMAC0_GMAC_MAC_ADDR7_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR7_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
569/* The address of the ALT_EMAC_GMAC_MAC_ADDR8_HIGH register for the ALT_EMAC0_GMACGRP instance. */
570#define ALT_EMAC0_GMAC_MAC_ADDR8_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR8_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
571/* The address of the ALT_EMAC_GMAC_MAC_ADDR8_LOW register for the ALT_EMAC0_GMACGRP instance. */
572#define ALT_EMAC0_GMAC_MAC_ADDR8_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR8_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
573/* The address of the ALT_EMAC_GMAC_MAC_ADDR9_HIGH register for the ALT_EMAC0_GMACGRP instance. */
574#define ALT_EMAC0_GMAC_MAC_ADDR9_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR9_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
575/* The address of the ALT_EMAC_GMAC_MAC_ADDR9_LOW register for the ALT_EMAC0_GMACGRP instance. */
576#define ALT_EMAC0_GMAC_MAC_ADDR9_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR9_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
577/* The address of the ALT_EMAC_GMAC_MAC_ADDR10_HIGH register for the ALT_EMAC0_GMACGRP instance. */
578#define ALT_EMAC0_GMAC_MAC_ADDR10_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR10_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
579/* The address of the ALT_EMAC_GMAC_MAC_ADDR10_LOW register for the ALT_EMAC0_GMACGRP instance. */
580#define ALT_EMAC0_GMAC_MAC_ADDR10_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR10_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
581/* The address of the ALT_EMAC_GMAC_MAC_ADDR11_HIGH register for the ALT_EMAC0_GMACGRP instance. */
582#define ALT_EMAC0_GMAC_MAC_ADDR11_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR11_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
583/* The address of the ALT_EMAC_GMAC_MAC_ADDR11_LOW register for the ALT_EMAC0_GMACGRP instance. */
584#define ALT_EMAC0_GMAC_MAC_ADDR11_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR11_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
585/* The address of the ALT_EMAC_GMAC_MAC_ADDR12_HIGH register for the ALT_EMAC0_GMACGRP instance. */
586#define ALT_EMAC0_GMAC_MAC_ADDR12_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR12_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
587/* The address of the ALT_EMAC_GMAC_MAC_ADDR12_LOW register for the ALT_EMAC0_GMACGRP instance. */
588#define ALT_EMAC0_GMAC_MAC_ADDR12_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR12_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
589/* The address of the ALT_EMAC_GMAC_MAC_ADDR13_HIGH register for the ALT_EMAC0_GMACGRP instance. */
590#define ALT_EMAC0_GMAC_MAC_ADDR13_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR13_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
591/* The address of the ALT_EMAC_GMAC_MAC_ADDR13_LOW register for the ALT_EMAC0_GMACGRP instance. */
592#define ALT_EMAC0_GMAC_MAC_ADDR13_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR13_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
593/* The address of the ALT_EMAC_GMAC_MAC_ADDR14_HIGH register for the ALT_EMAC0_GMACGRP instance. */
594#define ALT_EMAC0_GMAC_MAC_ADDR14_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR14_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
595/* The address of the ALT_EMAC_GMAC_MAC_ADDR14_LOW register for the ALT_EMAC0_GMACGRP instance. */
596#define ALT_EMAC0_GMAC_MAC_ADDR14_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR14_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
597/* The address of the ALT_EMAC_GMAC_MAC_ADDR15_HIGH register for the ALT_EMAC0_GMACGRP instance. */
598#define ALT_EMAC0_GMAC_MAC_ADDR15_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR15_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
599/* The address of the ALT_EMAC_GMAC_MAC_ADDR15_LOW register for the ALT_EMAC0_GMACGRP instance. */
600#define ALT_EMAC0_GMAC_MAC_ADDR15_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR15_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
601/* The address of the ALT_EMAC_GMAC_MII_CTL_STAT register for the ALT_EMAC0_GMACGRP instance. */
602#define ALT_EMAC0_GMAC_SGMII_RGMII_SMII_CTL_STAT_ADDR ALT_EMAC_GMAC_MII_CTL_STAT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
603/* The address of the ALT_EMAC_GMAC_MMC_CTL register for the ALT_EMAC0_GMACGRP instance. */
604#define ALT_EMAC0_GMAC_MMC_CTL_ADDR ALT_EMAC_GMAC_MMC_CTL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
605/* The address of the ALT_EMAC_GMAC_MMC_RX_INT register for the ALT_EMAC0_GMACGRP instance. */
606#define ALT_EMAC0_GMAC_MMC_RX_INT_ADDR ALT_EMAC_GMAC_MMC_RX_INT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
607/* The address of the ALT_EMAC_GMAC_MMC_TX_INT register for the ALT_EMAC0_GMACGRP instance. */
608#define ALT_EMAC0_GMAC_MMC_TX_INT_ADDR ALT_EMAC_GMAC_MMC_TX_INT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
609/* The address of the ALT_EMAC_GMAC_MMC_RX_INT_MSK register for the ALT_EMAC0_GMACGRP instance. */
610#define ALT_EMAC0_GMAC_MMC_RX_INT_MSK_ADDR ALT_EMAC_GMAC_MMC_RX_INT_MSK_ADDR(ALT_EMAC0_GMACGRP_ADDR)
611/* The address of the ALT_EMAC_GMAC_MMC_TX_INT_MSK register for the ALT_EMAC0_GMACGRP instance. */
612#define ALT_EMAC0_GMAC_MMC_TX_INT_MSK_ADDR ALT_EMAC_GMAC_MMC_TX_INT_MSK_ADDR(ALT_EMAC0_GMACGRP_ADDR)
613/* The address of the ALT_EMAC_GMAC_TXOCTETCOUNT_GB register for the ALT_EMAC0_GMACGRP instance. */
614#define ALT_EMAC0_GMAC_TXOCTETCOUNT_GB_ADDR ALT_EMAC_GMAC_TXOCTETCOUNT_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
615/* The address of the ALT_EMAC_GMAC_TXFRMCOUNT_GB register for the ALT_EMAC0_GMACGRP instance. */
616#define ALT_EMAC0_GMAC_TXFRMCOUNT_GB_ADDR ALT_EMAC_GMAC_TXFRMCOUNT_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
617/* The address of the ALT_EMAC_GMAC_TXBCASTFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
618#define ALT_EMAC0_GMAC_TXBCASTFRMS_G_ADDR ALT_EMAC_GMAC_TXBCASTFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
619/* The address of the ALT_EMAC_GMAC_TXMCASTFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
620#define ALT_EMAC0_GMAC_TXMCASTFRMS_G_ADDR ALT_EMAC_GMAC_TXMCASTFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
621/* The address of the ALT_EMAC_GMAC_TX64OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
622#define ALT_EMAC0_GMAC_TX64OCTETS_GB_ADDR ALT_EMAC_GMAC_TX64OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
623/* The address of the ALT_EMAC_GMAC_TX65TO127OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
624#define ALT_EMAC0_GMAC_TX65TO127OCTETS_GB_ADDR ALT_EMAC_GMAC_TX65TO127OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
625/* The address of the ALT_EMAC_GMAC_TX128TO255OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
626#define ALT_EMAC0_GMAC_TX128TO255OCTETS_GB_ADDR ALT_EMAC_GMAC_TX128TO255OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
627/* The address of the ALT_EMAC_GMAC_TX256TO511OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
628#define ALT_EMAC0_GMAC_TX256TO511OCTETS_GB_ADDR ALT_EMAC_GMAC_TX256TO511OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
629/* The address of the ALT_EMAC_GMAC_TX512TO1023OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
630#define ALT_EMAC0_GMAC_TX512TO1023OCTETS_GB_ADDR ALT_EMAC_GMAC_TX512TO1023OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
631/* The address of the ALT_EMAC_GMAC_TX1024TOMAXOCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
632#define ALT_EMAC0_GMAC_TX1024TOMAXOCTETS_GB_ADDR ALT_EMAC_GMAC_TX1024TOMAXOCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
633/* The address of the ALT_EMAC_GMAC_TXUNICASTFRMS_GB register for the ALT_EMAC0_GMACGRP instance. */
634#define ALT_EMAC0_GMAC_TXUNICASTFRMS_GB_ADDR ALT_EMAC_GMAC_TXUNICASTFRMS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
635/* The address of the ALT_EMAC_GMAC_TXMCASTFRMS_GB register for the ALT_EMAC0_GMACGRP instance. */
636#define ALT_EMAC0_GMAC_TXMCASTFRMS_GB_ADDR ALT_EMAC_GMAC_TXMCASTFRMS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
637/* The address of the ALT_EMAC_GMAC_TXBCASTFRMS_GB register for the ALT_EMAC0_GMACGRP instance. */
638#define ALT_EMAC0_GMAC_TXBCASTFRMS_GB_ADDR ALT_EMAC_GMAC_TXBCASTFRMS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
639/* The address of the ALT_EMAC_GMAC_TXUNDERFLOWERROR register for the ALT_EMAC0_GMACGRP instance. */
640#define ALT_EMAC0_GMAC_TXUNDERFLOWERROR_ADDR ALT_EMAC_GMAC_TXUNDERFLOWERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
641/* The address of the ALT_EMAC_GMAC_TXSINGLECOL_G register for the ALT_EMAC0_GMACGRP instance. */
642#define ALT_EMAC0_GMAC_TXSINGLECOL_G_ADDR ALT_EMAC_GMAC_TXSINGLECOL_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
643/* The address of the ALT_EMAC_GMAC_TXMULTICOL_G register for the ALT_EMAC0_GMACGRP instance. */
644#define ALT_EMAC0_GMAC_TXMULTICOL_G_ADDR ALT_EMAC_GMAC_TXMULTICOL_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
645/* The address of the ALT_EMAC_GMAC_TXDEFERRED register for the ALT_EMAC0_GMACGRP instance. */
646#define ALT_EMAC0_GMAC_TXDEFERRED_ADDR ALT_EMAC_GMAC_TXDEFERRED_ADDR(ALT_EMAC0_GMACGRP_ADDR)
647/* The address of the ALT_EMAC_GMAC_TXLATECOL register for the ALT_EMAC0_GMACGRP instance. */
648#define ALT_EMAC0_GMAC_TXLATECOL_ADDR ALT_EMAC_GMAC_TXLATECOL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
649/* The address of the ALT_EMAC_GMAC_TXEXESSCOL register for the ALT_EMAC0_GMACGRP instance. */
650#define ALT_EMAC0_GMAC_TXEXESSCOL_ADDR ALT_EMAC_GMAC_TXEXESSCOL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
651/* The address of the ALT_EMAC_GMAC_TXCARRIERERR register for the ALT_EMAC0_GMACGRP instance. */
652#define ALT_EMAC0_GMAC_TXCARRIERERR_ADDR ALT_EMAC_GMAC_TXCARRIERERR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
653/* The address of the ALT_EMAC_GMAC_TXOCTETCNT register for the ALT_EMAC0_GMACGRP instance. */
654#define ALT_EMAC0_GMAC_TXOCTETCNT_ADDR ALT_EMAC_GMAC_TXOCTETCNT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
655/* The address of the ALT_EMAC_GMAC_TXFRMCOUNT_G register for the ALT_EMAC0_GMACGRP instance. */
656#define ALT_EMAC0_GMAC_TXFRMCOUNT_G_ADDR ALT_EMAC_GMAC_TXFRMCOUNT_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
657/* The address of the ALT_EMAC_GMAC_TXEXCESSDEF register for the ALT_EMAC0_GMACGRP instance. */
658#define ALT_EMAC0_GMAC_TXEXCESSDEF_ADDR ALT_EMAC_GMAC_TXEXCESSDEF_ADDR(ALT_EMAC0_GMACGRP_ADDR)
659/* The address of the ALT_EMAC_GMAC_TXPAUSEFRMS register for the ALT_EMAC0_GMACGRP instance. */
660#define ALT_EMAC0_GMAC_TXPAUSEFRMS_ADDR ALT_EMAC_GMAC_TXPAUSEFRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
661/* The address of the ALT_EMAC_GMAC_TXVLANFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
662#define ALT_EMAC0_GMAC_TXVLANFRMS_G_ADDR ALT_EMAC_GMAC_TXVLANFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
663/* The address of the ALT_EMAC_GMAC_TXOVERSIZE_G register for the ALT_EMAC0_GMACGRP instance. */
664#define ALT_EMAC0_GMAC_TXOVERSIZE_G_ADDR ALT_EMAC_GMAC_TXOVERSIZE_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
665/* The address of the ALT_EMAC_GMAC_RXFRMCOUNT_GB register for the ALT_EMAC0_GMACGRP instance. */
666#define ALT_EMAC0_GMAC_RXFRMCOUNT_GB_ADDR ALT_EMAC_GMAC_RXFRMCOUNT_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
667/* The address of the ALT_EMAC_GMAC_RXOCTETCOUNT_GB register for the ALT_EMAC0_GMACGRP instance. */
668#define ALT_EMAC0_GMAC_RXOCTETCOUNT_GB_ADDR ALT_EMAC_GMAC_RXOCTETCOUNT_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
669/* The address of the ALT_EMAC_GMAC_RXOCTETCOUNT_G register for the ALT_EMAC0_GMACGRP instance. */
670#define ALT_EMAC0_GMAC_RXOCTETCOUNT_G_ADDR ALT_EMAC_GMAC_RXOCTETCOUNT_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
671/* The address of the ALT_EMAC_GMAC_RXBCASTFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
672#define ALT_EMAC0_GMAC_RXBCASTFRMS_G_ADDR ALT_EMAC_GMAC_RXBCASTFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
673/* The address of the ALT_EMAC_GMAC_RXMCASTFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
674#define ALT_EMAC0_GMAC_RXMCASTFRMS_G_ADDR ALT_EMAC_GMAC_RXMCASTFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
675/* The address of the ALT_EMAC_GMAC_RXCRCERROR register for the ALT_EMAC0_GMACGRP instance. */
676#define ALT_EMAC0_GMAC_RXCRCERROR_ADDR ALT_EMAC_GMAC_RXCRCERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
677/* The address of the ALT_EMAC_GMAC_RXALIGNMENTERROR register for the ALT_EMAC0_GMACGRP instance. */
678#define ALT_EMAC0_GMAC_RXALIGNMENTERROR_ADDR ALT_EMAC_GMAC_RXALIGNMENTERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
679/* The address of the ALT_EMAC_GMAC_RXRUNTERROR register for the ALT_EMAC0_GMACGRP instance. */
680#define ALT_EMAC0_GMAC_RXRUNTERROR_ADDR ALT_EMAC_GMAC_RXRUNTERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
681/* The address of the ALT_EMAC_GMAC_RXJABBERERROR register for the ALT_EMAC0_GMACGRP instance. */
682#define ALT_EMAC0_GMAC_RXJABBERERROR_ADDR ALT_EMAC_GMAC_RXJABBERERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
683/* The address of the ALT_EMAC_GMAC_RXUNDERSIZE_G register for the ALT_EMAC0_GMACGRP instance. */
684#define ALT_EMAC0_GMAC_RXUNDERSIZE_G_ADDR ALT_EMAC_GMAC_RXUNDERSIZE_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
685/* The address of the ALT_EMAC_GMAC_RXOVERSIZE_G register for the ALT_EMAC0_GMACGRP instance. */
686#define ALT_EMAC0_GMAC_RXOVERSIZE_G_ADDR ALT_EMAC_GMAC_RXOVERSIZE_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
687/* The address of the ALT_EMAC_GMAC_RX64OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
688#define ALT_EMAC0_GMAC_RX64OCTETS_GB_ADDR ALT_EMAC_GMAC_RX64OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
689/* The address of the ALT_EMAC_GMAC_RX65TO127OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
690#define ALT_EMAC0_GMAC_RX65TO127OCTETS_GB_ADDR ALT_EMAC_GMAC_RX65TO127OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
691/* The address of the ALT_EMAC_GMAC_RX128TO255OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
692#define ALT_EMAC0_GMAC_RX128TO255OCTETS_GB_ADDR ALT_EMAC_GMAC_RX128TO255OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
693/* The address of the ALT_EMAC_GMAC_RX256TO511OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
694#define ALT_EMAC0_GMAC_RX256TO511OCTETS_GB_ADDR ALT_EMAC_GMAC_RX256TO511OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
695/* The address of the ALT_EMAC_GMAC_RX512TO1023OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
696#define ALT_EMAC0_GMAC_RX512TO1023OCTETS_GB_ADDR ALT_EMAC_GMAC_RX512TO1023OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
697/* The address of the ALT_EMAC_GMAC_RX1024TOMAXOCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
698#define ALT_EMAC0_GMAC_RX1024TOMAXOCTETS_GB_ADDR ALT_EMAC_GMAC_RX1024TOMAXOCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
699/* The address of the ALT_EMAC_GMAC_RXUNICASTFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
700#define ALT_EMAC0_GMAC_RXUNICASTFRMS_G_ADDR ALT_EMAC_GMAC_RXUNICASTFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
701/* The address of the ALT_EMAC_GMAC_RXLENERROR register for the ALT_EMAC0_GMACGRP instance. */
702#define ALT_EMAC0_GMAC_RXLENERROR_ADDR ALT_EMAC_GMAC_RXLENERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
703/* The address of the ALT_EMAC_GMAC_RXOUTOFRANGETYPE register for the ALT_EMAC0_GMACGRP instance. */
704#define ALT_EMAC0_GMAC_RXOUTOFRANGETYPE_ADDR ALT_EMAC_GMAC_RXOUTOFRANGETYPE_ADDR(ALT_EMAC0_GMACGRP_ADDR)
705/* The address of the ALT_EMAC_GMAC_RXPAUSEFRMS register for the ALT_EMAC0_GMACGRP instance. */
706#define ALT_EMAC0_GMAC_RXPAUSEFRMS_ADDR ALT_EMAC_GMAC_RXPAUSEFRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
707/* The address of the ALT_EMAC_GMAC_RXFIFOOVF register for the ALT_EMAC0_GMACGRP instance. */
708#define ALT_EMAC0_GMAC_RXFIFOOVF_ADDR ALT_EMAC_GMAC_RXFIFOOVF_ADDR(ALT_EMAC0_GMACGRP_ADDR)
709/* The address of the ALT_EMAC_GMAC_RXVLANFRMS_GB register for the ALT_EMAC0_GMACGRP instance. */
710#define ALT_EMAC0_GMAC_RXVLANFRMS_GB_ADDR ALT_EMAC_GMAC_RXVLANFRMS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
711/* The address of the ALT_EMAC_GMAC_RXWDERROR register for the ALT_EMAC0_GMACGRP instance. */
712#define ALT_EMAC0_GMAC_RXWDERROR_ADDR ALT_EMAC_GMAC_RXWDERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
713/* The address of the ALT_EMAC_GMAC_RXRCVERROR register for the ALT_EMAC0_GMACGRP instance. */
714#define ALT_EMAC0_GMAC_RXRCVERROR_ADDR ALT_EMAC_GMAC_RXRCVERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
715/* The address of the ALT_EMAC_GMAC_RXCTLFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
716#define ALT_EMAC0_GMAC_RXCTLFRMS_G_ADDR ALT_EMAC_GMAC_RXCTLFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
717/* The address of the ALT_EMAC_GMAC_MMC_IPC_RX_INT_MSK register for the ALT_EMAC0_GMACGRP instance. */
718#define ALT_EMAC0_GMAC_MMC_IPC_RX_INT_MSK_ADDR ALT_EMAC_GMAC_MMC_IPC_RX_INT_MSK_ADDR(ALT_EMAC0_GMACGRP_ADDR)
719/* The address of the ALT_EMAC_GMAC_MMC_IPC_RX_INT register for the ALT_EMAC0_GMACGRP instance. */
720#define ALT_EMAC0_GMAC_MMC_IPC_RX_INT_ADDR ALT_EMAC_GMAC_MMC_IPC_RX_INT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
721/* The address of the ALT_EMAC_GMAC_RXIPV4_GD_FRMS register for the ALT_EMAC0_GMACGRP instance. */
722#define ALT_EMAC0_GMAC_RXIPV4_GD_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_GD_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
723/* The address of the ALT_EMAC_GMAC_RXIPV4_HDRERR_FRMS register for the ALT_EMAC0_GMACGRP instance. */
724#define ALT_EMAC0_GMAC_RXIPV4_HDRERR_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_HDRERR_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
725/* The address of the ALT_EMAC_GMAC_RXIPV4_NOPAY_FRMS register for the ALT_EMAC0_GMACGRP instance. */
726#define ALT_EMAC0_GMAC_RXIPV4_NOPAY_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_NOPAY_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
727/* The address of the ALT_EMAC_GMAC_RXIPV4_FRAG_FRMS register for the ALT_EMAC0_GMACGRP instance. */
728#define ALT_EMAC0_GMAC_RXIPV4_FRAG_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_FRAG_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
729/* The address of the ALT_EMAC_GMAC_RXIPV4_UDSBL_FRMS register for the ALT_EMAC0_GMACGRP instance. */
730#define ALT_EMAC0_GMAC_RXIPV4_UDSBL_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_UDSBL_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
731/* The address of the ALT_EMAC_GMAC_RXIPV6_GD_FRMS register for the ALT_EMAC0_GMACGRP instance. */
732#define ALT_EMAC0_GMAC_RXIPV6_GD_FRMS_ADDR ALT_EMAC_GMAC_RXIPV6_GD_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
733/* The address of the ALT_EMAC_GMAC_RXIPV6_HDRERR_FRMS register for the ALT_EMAC0_GMACGRP instance. */
734#define ALT_EMAC0_GMAC_RXIPV6_HDRERR_FRMS_ADDR ALT_EMAC_GMAC_RXIPV6_HDRERR_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
735/* The address of the ALT_EMAC_GMAC_RXIPV6_NOPAY_FRMS register for the ALT_EMAC0_GMACGRP instance. */
736#define ALT_EMAC0_GMAC_RXIPV6_NOPAY_FRMS_ADDR ALT_EMAC_GMAC_RXIPV6_NOPAY_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
737/* The address of the ALT_EMAC_GMAC_RXUDP_GD_FRMS register for the ALT_EMAC0_GMACGRP instance. */
738#define ALT_EMAC0_GMAC_RXUDP_GD_FRMS_ADDR ALT_EMAC_GMAC_RXUDP_GD_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
739/* The address of the ALT_EMAC_GMAC_RXUDP_ERR_FRMS register for the ALT_EMAC0_GMACGRP instance. */
740#define ALT_EMAC0_GMAC_RXUDP_ERR_FRMS_ADDR ALT_EMAC_GMAC_RXUDP_ERR_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
741/* The address of the ALT_EMAC_GMAC_RXTCP_GD_FRMS register for the ALT_EMAC0_GMACGRP instance. */
742#define ALT_EMAC0_GMAC_RXTCP_GD_FRMS_ADDR ALT_EMAC_GMAC_RXTCP_GD_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
743/* The address of the ALT_EMAC_GMAC_RXTCP_ERR_FRMS register for the ALT_EMAC0_GMACGRP instance. */
744#define ALT_EMAC0_GMAC_RXTCP_ERR_FRMS_ADDR ALT_EMAC_GMAC_RXTCP_ERR_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
745/* The address of the ALT_EMAC_GMAC_RXICMP_GD_FRMS register for the ALT_EMAC0_GMACGRP instance. */
746#define ALT_EMAC0_GMAC_RXICMP_GD_FRMS_ADDR ALT_EMAC_GMAC_RXICMP_GD_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
747/* The address of the ALT_EMAC_GMAC_RXICMP_ERR_FRMS register for the ALT_EMAC0_GMACGRP instance. */
748#define ALT_EMAC0_GMAC_RXICMP_ERR_FRMS_ADDR ALT_EMAC_GMAC_RXICMP_ERR_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
749/* The address of the ALT_EMAC_GMAC_RXIPV4_GD_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
750#define ALT_EMAC0_GMAC_RXIPV4_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_GD_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
751/* The address of the ALT_EMAC_GMAC_RXIPV4_HDRERR_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
752#define ALT_EMAC0_GMAC_RXIPV4_HDRERR_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_HDRERR_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
753/* The address of the ALT_EMAC_GMAC_RXIPV4_NOPAY_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
754#define ALT_EMAC0_GMAC_RXIPV4_NOPAY_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_NOPAY_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
755/* The address of the ALT_EMAC_GMAC_RXIPV4_FRAG_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
756#define ALT_EMAC0_GMAC_RXIPV4_FRAG_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_FRAG_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
757/* The address of the ALT_EMAC_GMAC_RXIPV4_UDSBL_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
758#define ALT_EMAC0_GMAC_RXIPV4_UDSBL_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_UDSBL_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
759/* The address of the ALT_EMAC_GMAC_RXIPV6_GD_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
760#define ALT_EMAC0_GMAC_RXIPV6_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV6_GD_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
761/* The address of the ALT_EMAC_GMAC_RXIPV6_HDRERR_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
762#define ALT_EMAC0_GMAC_RXIPV6_HDRERR_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV6_HDRERR_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
763/* The address of the ALT_EMAC_GMAC_RXIPV6_NOPAY_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
764#define ALT_EMAC0_GMAC_RXIPV6_NOPAY_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV6_NOPAY_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
765/* The address of the ALT_EMAC_GMAC_RXUDP_GD_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
766#define ALT_EMAC0_GMAC_RXUDP_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXUDP_GD_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
767/* The address of the ALT_EMAC_GMAC_RXUDP_ERR_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
768#define ALT_EMAC0_GMAC_RXUDP_ERR_OCTETS_ADDR ALT_EMAC_GMAC_RXUDP_ERR_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
769/* The address of the ALT_EMAC_GMAC_RXTCP_GD_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
770#define ALT_EMAC0_GMAC_RXTCP_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXTCP_GD_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
771/* The address of the ALT_EMAC_GMAC_RXTCPERROCTETS register for the ALT_EMAC0_GMACGRP instance. */
772#define ALT_EMAC0_GMAC_RXTCPERROCTETS_ADDR ALT_EMAC_GMAC_RXTCPERROCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
773/* The address of the ALT_EMAC_GMAC_RXICMP_GD_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
774#define ALT_EMAC0_GMAC_RXICMP_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXICMP_GD_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
775/* The address of the ALT_EMAC_GMAC_RXICMP_ERR_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
776#define ALT_EMAC0_GMAC_RXICMP_ERR_OCTETS_ADDR ALT_EMAC_GMAC_RXICMP_ERR_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
777/* The address of the ALT_EMAC_GMAC_L3_L4_CTL0 register for the ALT_EMAC0_GMACGRP instance. */
778#define ALT_EMAC0_GMAC_L3_L4_CTL0_ADDR ALT_EMAC_GMAC_L3_L4_CTL0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
779/* The address of the ALT_EMAC_GMAC_LYR4_ADDR0 register for the ALT_EMAC0_GMACGRP instance. */
780#define ALT_EMAC0_GMAC_LYR4_ADDR0_ADDR ALT_EMAC_GMAC_LYR4_ADDR0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
781/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG0 register for the ALT_EMAC0_GMACGRP instance. */
782#define ALT_EMAC0_GMAC_LYR3_ADDR0_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
783/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG0 register for the ALT_EMAC0_GMACGRP instance. */
784#define ALT_EMAC0_GMAC_LYR3_ADDR1_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
785/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG0 register for the ALT_EMAC0_GMACGRP instance. */
786#define ALT_EMAC0_GMAC_LYR3_ADDR2_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
787/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG0 register for the ALT_EMAC0_GMACGRP instance. */
788#define ALT_EMAC0_GMAC_LYR3_ADDR3_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
789/* The address of the ALT_EMAC_GMAC_L3_L4_CTL1 register for the ALT_EMAC0_GMACGRP instance. */
790#define ALT_EMAC0_GMAC_L3_L4_CTL1_ADDR ALT_EMAC_GMAC_L3_L4_CTL1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
791/* The address of the ALT_EMAC_GMAC_LYR4_ADDR1 register for the ALT_EMAC0_GMACGRP instance. */
792#define ALT_EMAC0_GMAC_LYR4_ADDR1_ADDR ALT_EMAC_GMAC_LYR4_ADDR1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
793/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG1 register for the ALT_EMAC0_GMACGRP instance. */
794#define ALT_EMAC0_GMAC_LYR3_ADDR0_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
795/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG1 register for the ALT_EMAC0_GMACGRP instance. */
796#define ALT_EMAC0_GMAC_LYR3_ADDR1_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
797/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG1 register for the ALT_EMAC0_GMACGRP instance. */
798#define ALT_EMAC0_GMAC_LYR3_ADDR2_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
799/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG1 register for the ALT_EMAC0_GMACGRP instance. */
800#define ALT_EMAC0_GMAC_LYR3_ADDR3_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
801/* The address of the ALT_EMAC_GMAC_L3_L4_CTL2 register for the ALT_EMAC0_GMACGRP instance. */
802#define ALT_EMAC0_GMAC_L3_L4_CTL2_ADDR ALT_EMAC_GMAC_L3_L4_CTL2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
803/* The address of the ALT_EMAC_GMAC_LYR4_ADDR2 register for the ALT_EMAC0_GMACGRP instance. */
804#define ALT_EMAC0_GMAC_LYR4_ADDR2_ADDR ALT_EMAC_GMAC_LYR4_ADDR2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
805/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG2 register for the ALT_EMAC0_GMACGRP instance. */
806#define ALT_EMAC0_GMAC_LYR3_ADDR0_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
807/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG2 register for the ALT_EMAC0_GMACGRP instance. */
808#define ALT_EMAC0_GMAC_LYR3_ADDR1_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
809/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG2 register for the ALT_EMAC0_GMACGRP instance. */
810#define ALT_EMAC0_GMAC_LYR3_ADDR2_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
811/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG2 register for the ALT_EMAC0_GMACGRP instance. */
812#define ALT_EMAC0_GMAC_LYR3_ADDR3_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
813/* The address of the ALT_EMAC_GMAC_L3_L4_CTL3 register for the ALT_EMAC0_GMACGRP instance. */
814#define ALT_EMAC0_GMAC_L3_L4_CTL3_ADDR ALT_EMAC_GMAC_L3_L4_CTL3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
815/* The address of the ALT_EMAC_GMAC_LYR4_ADDR3 register for the ALT_EMAC0_GMACGRP instance. */
816#define ALT_EMAC0_GMAC_LYR4_ADDR3_ADDR ALT_EMAC_GMAC_LYR4_ADDR3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
817/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG3 register for the ALT_EMAC0_GMACGRP instance. */
818#define ALT_EMAC0_GMAC_LYR3_ADDR0_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
819/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG3 register for the ALT_EMAC0_GMACGRP instance. */
820#define ALT_EMAC0_GMAC_LYR3_ADDR1_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
821/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG3 register for the ALT_EMAC0_GMACGRP instance. */
822#define ALT_EMAC0_GMAC_LYR3_ADDR2_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
823/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG3 register for the ALT_EMAC0_GMACGRP instance. */
824#define ALT_EMAC0_GMAC_LYR3_ADDR3_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
825/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG0 register for the ALT_EMAC0_GMACGRP instance. */
826#define ALT_EMAC0_GMAC_HASH_TABLE_REG0_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
827/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG1 register for the ALT_EMAC0_GMACGRP instance. */
828#define ALT_EMAC0_GMAC_HASH_TABLE_REG1_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
829/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG2 register for the ALT_EMAC0_GMACGRP instance. */
830#define ALT_EMAC0_GMAC_HASH_TABLE_REG2_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
831/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG3 register for the ALT_EMAC0_GMACGRP instance. */
832#define ALT_EMAC0_GMAC_HASH_TABLE_REG3_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
833/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG4 register for the ALT_EMAC0_GMACGRP instance. */
834#define ALT_EMAC0_GMAC_HASH_TABLE_REG4_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG4_ADDR(ALT_EMAC0_GMACGRP_ADDR)
835/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG5 register for the ALT_EMAC0_GMACGRP instance. */
836#define ALT_EMAC0_GMAC_HASH_TABLE_REG5_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG5_ADDR(ALT_EMAC0_GMACGRP_ADDR)
837/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG6 register for the ALT_EMAC0_GMACGRP instance. */
838#define ALT_EMAC0_GMAC_HASH_TABLE_REG6_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG6_ADDR(ALT_EMAC0_GMACGRP_ADDR)
839/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG7 register for the ALT_EMAC0_GMACGRP instance. */
840#define ALT_EMAC0_GMAC_HASH_TABLE_REG7_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG7_ADDR(ALT_EMAC0_GMACGRP_ADDR)
841/* The address of the ALT_EMAC_GMAC_VLAN_INCL_REG register for the ALT_EMAC0_GMACGRP instance. */
842#define ALT_EMAC0_GMAC_VLAN_INCL_REG_ADDR ALT_EMAC_GMAC_VLAN_INCL_REG_ADDR(ALT_EMAC0_GMACGRP_ADDR)
843/* The address of the ALT_EMAC_GMAC_VLAN_HASH_TABLE_REG register for the ALT_EMAC0_GMACGRP instance. */
844#define ALT_EMAC0_GMAC_VLAN_HASH_TABLE_REG_ADDR ALT_EMAC_GMAC_VLAN_HASH_TABLE_REG_ADDR(ALT_EMAC0_GMACGRP_ADDR)
845/* The address of the ALT_EMAC_GMAC_TS_CTL register for the ALT_EMAC0_GMACGRP instance. */
846#define ALT_EMAC0_GMAC_TS_CTL_ADDR ALT_EMAC_GMAC_TS_CTL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
847/* The address of the ALT_EMAC_GMAC_SUB_SEC_INCREMENT register for the ALT_EMAC0_GMACGRP instance. */
848#define ALT_EMAC0_GMAC_SUB_SEC_INCREMENT_ADDR ALT_EMAC_GMAC_SUB_SEC_INCREMENT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
849/* The address of the ALT_EMAC_GMAC_SYS_TIME_SECS register for the ALT_EMAC0_GMACGRP instance. */
850#define ALT_EMAC0_GMAC_SYS_TIME_SECS_ADDR ALT_EMAC_GMAC_SYS_TIME_SECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
851/* The address of the ALT_EMAC_GMAC_SYS_TIME_NANOSECS register for the ALT_EMAC0_GMACGRP instance. */
852#define ALT_EMAC0_GMAC_SYS_TIME_NANOSECS_ADDR ALT_EMAC_GMAC_SYS_TIME_NANOSECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
853/* The address of the ALT_EMAC_GMAC_SYS_TIME_SECS_UPDATE register for the ALT_EMAC0_GMACGRP instance. */
854#define ALT_EMAC0_GMAC_SYS_TIME_SECS_UPDATE_ADDR ALT_EMAC_GMAC_SYS_TIME_SECS_UPDATE_ADDR(ALT_EMAC0_GMACGRP_ADDR)
855/* The address of the ALT_EMAC_GMAC_SYS_TIME_NANOSECS_UPDATE register for the ALT_EMAC0_GMACGRP instance. */
856#define ALT_EMAC0_GMAC_SYS_TIME_NANOSECS_UPDATE_ADDR ALT_EMAC_GMAC_SYS_TIME_NANOSECS_UPDATE_ADDR(ALT_EMAC0_GMACGRP_ADDR)
857/* The address of the ALT_EMAC_GMAC_TS_ADDEND register for the ALT_EMAC0_GMACGRP instance. */
858#define ALT_EMAC0_GMAC_TS_ADDEND_ADDR ALT_EMAC_GMAC_TS_ADDEND_ADDR(ALT_EMAC0_GMACGRP_ADDR)
859/* The address of the ALT_EMAC_GMAC_TGT_TIME_SECS register for the ALT_EMAC0_GMACGRP instance. */
860#define ALT_EMAC0_GMAC_TGT_TIME_SECS_ADDR ALT_EMAC_GMAC_TGT_TIME_SECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
861/* The address of the ALT_EMAC_GMAC_TGT_TIME_NANOSECS register for the ALT_EMAC0_GMACGRP instance. */
862#define ALT_EMAC0_GMAC_TGT_TIME_NANOSECS_ADDR ALT_EMAC_GMAC_TGT_TIME_NANOSECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
863/* The address of the ALT_EMAC_GMAC_SYS_TIME_HIGHER_WORD_SECS register for the ALT_EMAC0_GMACGRP instance. */
864#define ALT_EMAC0_GMAC_SYS_TIME_HIGHER_WORD_SECS_ADDR ALT_EMAC_GMAC_SYS_TIME_HIGHER_WORD_SECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
865/* The address of the ALT_EMAC_GMAC_TS_STAT register for the ALT_EMAC0_GMACGRP instance. */
866#define ALT_EMAC0_GMAC_TS_STAT_ADDR ALT_EMAC_GMAC_TS_STAT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
867/* The address of the ALT_EMAC_GMAC_PPS_CTL register for the ALT_EMAC0_GMACGRP instance. */
868#define ALT_EMAC0_GMAC_PPS_CTL_ADDR ALT_EMAC_GMAC_PPS_CTL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
869/* The address of the ALT_EMAC_GMAC_AUX_TS_NANOSECS register for the ALT_EMAC0_GMACGRP instance. */
870#define ALT_EMAC0_GMAC_AUX_TS_NANOSECS_ADDR ALT_EMAC_GMAC_AUX_TS_NANOSECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
871/* The address of the ALT_EMAC_GMAC_AUX_TS_SECS register for the ALT_EMAC0_GMACGRP instance. */
872#define ALT_EMAC0_GMAC_AUX_TS_SECS_ADDR ALT_EMAC_GMAC_AUX_TS_SECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
873/* The address of the ALT_EMAC_GMAC_PPS0_INTERVAL register for the ALT_EMAC0_GMACGRP instance. */
874#define ALT_EMAC0_GMAC_PPS0_INTERVAL_ADDR ALT_EMAC_GMAC_PPS0_INTERVAL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
875/* The address of the ALT_EMAC_GMAC_PPS0_WIDTH register for the ALT_EMAC0_GMACGRP instance. */
876#define ALT_EMAC0_GMAC_PPS0_WIDTH_ADDR ALT_EMAC_GMAC_PPS0_WIDTH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
877/* The address of the ALT_EMAC_GMAC_MAC_ADDR16_HIGH register for the ALT_EMAC0_GMACGRP instance. */
878#define ALT_EMAC0_GMAC_MAC_ADDR16_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR16_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
879/* The address of the ALT_EMAC_GMAC_MAC_ADDR16_LOW register for the ALT_EMAC0_GMACGRP instance. */
880#define ALT_EMAC0_GMAC_MAC_ADDR16_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR16_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
881/* The address of the ALT_EMAC_GMAC_MAC_ADDR17_HIGH register for the ALT_EMAC0_GMACGRP instance. */
882#define ALT_EMAC0_GMAC_MAC_ADDR17_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR17_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
883/* The address of the ALT_EMAC_GMAC_MAC_ADDR17_LOW register for the ALT_EMAC0_GMACGRP instance. */
884#define ALT_EMAC0_GMAC_MAC_ADDR17_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR17_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
885/* The address of the ALT_EMAC_GMAC_MAC_ADDR18_HIGH register for the ALT_EMAC0_GMACGRP instance. */
886#define ALT_EMAC0_GMAC_MAC_ADDR18_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR18_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
887/* The address of the ALT_EMAC_GMAC_MAC_ADDR18_LOW register for the ALT_EMAC0_GMACGRP instance. */
888#define ALT_EMAC0_GMAC_MAC_ADDR18_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR18_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
889/* The address of the ALT_EMAC_GMAC_MAC_ADDR19_HIGH register for the ALT_EMAC0_GMACGRP instance. */
890#define ALT_EMAC0_GMAC_MAC_ADDR19_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR19_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
891/* The address of the ALT_EMAC_GMAC_MAC_ADDR19_LOW register for the ALT_EMAC0_GMACGRP instance. */
892#define ALT_EMAC0_GMAC_MAC_ADDR19_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR19_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
893/* The address of the ALT_EMAC_GMAC_MAC_ADDR20_HIGH register for the ALT_EMAC0_GMACGRP instance. */
894#define ALT_EMAC0_GMAC_MAC_ADDR20_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR20_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
895/* The address of the ALT_EMAC_GMAC_MAC_ADDR20_LOW register for the ALT_EMAC0_GMACGRP instance. */
896#define ALT_EMAC0_GMAC_MAC_ADDR20_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR20_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
897/* The address of the ALT_EMAC_GMAC_MAC_ADDR21_HIGH register for the ALT_EMAC0_GMACGRP instance. */
898#define ALT_EMAC0_GMAC_MAC_ADDR21_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR21_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
899/* The address of the ALT_EMAC_GMAC_MAC_ADDR21_LOW register for the ALT_EMAC0_GMACGRP instance. */
900#define ALT_EMAC0_GMAC_MAC_ADDR21_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR21_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
901/* The address of the ALT_EMAC_GMAC_MAC_ADDR22_HIGH register for the ALT_EMAC0_GMACGRP instance. */
902#define ALT_EMAC0_GMAC_MAC_ADDR22_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR22_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
903/* The address of the ALT_EMAC_GMAC_MAC_ADDR22_LOW register for the ALT_EMAC0_GMACGRP instance. */
904#define ALT_EMAC0_GMAC_MAC_ADDR22_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR22_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
905/* The address of the ALT_EMAC_GMAC_MAC_ADDR23_HIGH register for the ALT_EMAC0_GMACGRP instance. */
906#define ALT_EMAC0_GMAC_MAC_ADDR23_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR23_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
907/* The address of the ALT_EMAC_GMAC_MAC_ADDR23_LOW register for the ALT_EMAC0_GMACGRP instance. */
908#define ALT_EMAC0_GMAC_MAC_ADDR23_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR23_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
909/* The address of the ALT_EMAC_GMAC_MAC_ADDR24_HIGH register for the ALT_EMAC0_GMACGRP instance. */
910#define ALT_EMAC0_GMAC_MAC_ADDR24_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR24_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
911/* The address of the ALT_EMAC_GMAC_MAC_ADDR24_LOW register for the ALT_EMAC0_GMACGRP instance. */
912#define ALT_EMAC0_GMAC_MAC_ADDR24_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR24_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
913/* The address of the ALT_EMAC_GMAC_MAC_ADDR25_HIGH register for the ALT_EMAC0_GMACGRP instance. */
914#define ALT_EMAC0_GMAC_MAC_ADDR25_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR25_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
915/* The address of the ALT_EMAC_GMAC_MAC_ADDR25_LOW register for the ALT_EMAC0_GMACGRP instance. */
916#define ALT_EMAC0_GMAC_MAC_ADDR25_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR25_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
917/* The address of the ALT_EMAC_GMAC_MAC_ADDR26_HIGH register for the ALT_EMAC0_GMACGRP instance. */
918#define ALT_EMAC0_GMAC_MAC_ADDR26_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR26_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
919/* The address of the ALT_EMAC_GMAC_MAC_ADDR26_LOW register for the ALT_EMAC0_GMACGRP instance. */
920#define ALT_EMAC0_GMAC_MAC_ADDR26_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR26_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
921/* The address of the ALT_EMAC_GMAC_MAC_ADDR27_HIGH register for the ALT_EMAC0_GMACGRP instance. */
922#define ALT_EMAC0_GMAC_MAC_ADDR27_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR27_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
923/* The address of the ALT_EMAC_GMAC_MAC_ADDR27_LOW register for the ALT_EMAC0_GMACGRP instance. */
924#define ALT_EMAC0_GMAC_MAC_ADDR27_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR27_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
925/* The address of the ALT_EMAC_GMAC_MAC_ADDR28_HIGH register for the ALT_EMAC0_GMACGRP instance. */
926#define ALT_EMAC0_GMAC_MAC_ADDR28_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR28_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
927/* The address of the ALT_EMAC_GMAC_MAC_ADDR28_LOW register for the ALT_EMAC0_GMACGRP instance. */
928#define ALT_EMAC0_GMAC_MAC_ADDR28_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR28_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
929/* The address of the ALT_EMAC_GMAC_MAC_ADDR29_HIGH register for the ALT_EMAC0_GMACGRP instance. */
930#define ALT_EMAC0_GMAC_MAC_ADDR29_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR29_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
931/* The address of the ALT_EMAC_GMAC_MAC_ADDR29_LOW register for the ALT_EMAC0_GMACGRP instance. */
932#define ALT_EMAC0_GMAC_MAC_ADDR29_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR29_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
933/* The address of the ALT_EMAC_GMAC_MAC_ADDR30_HIGH register for the ALT_EMAC0_GMACGRP instance. */
934#define ALT_EMAC0_GMAC_MAC_ADDR30_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR30_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
935/* The address of the ALT_EMAC_GMAC_MAC_ADDR30_LOW register for the ALT_EMAC0_GMACGRP instance. */
936#define ALT_EMAC0_GMAC_MAC_ADDR30_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR30_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
937/* The address of the ALT_EMAC_GMAC_MAC_ADDR31_HIGH register for the ALT_EMAC0_GMACGRP instance. */
938#define ALT_EMAC0_GMAC_MAC_ADDR31_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR31_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
939/* The address of the ALT_EMAC_GMAC_MAC_ADDR31_LOW register for the ALT_EMAC0_GMACGRP instance. */
940#define ALT_EMAC0_GMAC_MAC_ADDR31_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR31_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
941/* The address of the ALT_EMAC_GMAC_MAC_ADDR32_HIGH register for the ALT_EMAC0_GMACGRP instance. */
942#define ALT_EMAC0_GMAC_MAC_ADDR32_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR32_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
943/* The address of the ALT_EMAC_GMAC_MAC_ADDR32_LOW register for the ALT_EMAC0_GMACGRP instance. */
944#define ALT_EMAC0_GMAC_MAC_ADDR32_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR32_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
945/* The address of the ALT_EMAC_GMAC_MAC_ADDR33_HIGH register for the ALT_EMAC0_GMACGRP instance. */
946#define ALT_EMAC0_GMAC_MAC_ADDR33_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR33_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
947/* The address of the ALT_EMAC_GMAC_MAC_ADDR33_LOW register for the ALT_EMAC0_GMACGRP instance. */
948#define ALT_EMAC0_GMAC_MAC_ADDR33_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR33_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
949/* The address of the ALT_EMAC_GMAC_MAC_ADDR34_HIGH register for the ALT_EMAC0_GMACGRP instance. */
950#define ALT_EMAC0_GMAC_MAC_ADDR34_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR34_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
951/* The address of the ALT_EMAC_GMAC_MAC_ADDR34_LOW register for the ALT_EMAC0_GMACGRP instance. */
952#define ALT_EMAC0_GMAC_MAC_ADDR34_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR34_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
953/* The address of the ALT_EMAC_GMAC_MAC_ADDR35_HIGH register for the ALT_EMAC0_GMACGRP instance. */
954#define ALT_EMAC0_GMAC_MAC_ADDR35_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR35_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
955/* The address of the ALT_EMAC_GMAC_MAC_ADDR35_LOW register for the ALT_EMAC0_GMACGRP instance. */
956#define ALT_EMAC0_GMAC_MAC_ADDR35_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR35_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
957/* The address of the ALT_EMAC_GMAC_MAC_ADDR36_HIGH register for the ALT_EMAC0_GMACGRP instance. */
958#define ALT_EMAC0_GMAC_MAC_ADDR36_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR36_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
959/* The address of the ALT_EMAC_GMAC_MAC_ADDR36_LOW register for the ALT_EMAC0_GMACGRP instance. */
960#define ALT_EMAC0_GMAC_MAC_ADDR36_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR36_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
961/* The address of the ALT_EMAC_GMAC_MAC_ADDR37_HIGH register for the ALT_EMAC0_GMACGRP instance. */
962#define ALT_EMAC0_GMAC_MAC_ADDR37_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR37_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
963/* The address of the ALT_EMAC_GMAC_MAC_ADDR37_LOW register for the ALT_EMAC0_GMACGRP instance. */
964#define ALT_EMAC0_GMAC_MAC_ADDR37_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR37_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
965/* The address of the ALT_EMAC_GMAC_MAC_ADDR38_HIGH register for the ALT_EMAC0_GMACGRP instance. */
966#define ALT_EMAC0_GMAC_MAC_ADDR38_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR38_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
967/* The address of the ALT_EMAC_GMAC_MAC_ADDR38_LOW register for the ALT_EMAC0_GMACGRP instance. */
968#define ALT_EMAC0_GMAC_MAC_ADDR38_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR38_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
969/* The address of the ALT_EMAC_GMAC_MAC_ADDR39_HIGH register for the ALT_EMAC0_GMACGRP instance. */
970#define ALT_EMAC0_GMAC_MAC_ADDR39_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR39_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
971/* The address of the ALT_EMAC_GMAC_MAC_ADDR39_LOW register for the ALT_EMAC0_GMACGRP instance. */
972#define ALT_EMAC0_GMAC_MAC_ADDR39_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR39_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
973/* The address of the ALT_EMAC_GMAC_MAC_ADDR40_HIGH register for the ALT_EMAC0_GMACGRP instance. */
974#define ALT_EMAC0_GMAC_MAC_ADDR40_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR40_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
975/* The address of the ALT_EMAC_GMAC_MAC_ADDR40_LOW register for the ALT_EMAC0_GMACGRP instance. */
976#define ALT_EMAC0_GMAC_MAC_ADDR40_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR40_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
977/* The address of the ALT_EMAC_GMAC_MAC_ADDR41_HIGH register for the ALT_EMAC0_GMACGRP instance. */
978#define ALT_EMAC0_GMAC_MAC_ADDR41_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR41_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
979/* The address of the ALT_EMAC_GMAC_MAC_ADDR41_LOW register for the ALT_EMAC0_GMACGRP instance. */
980#define ALT_EMAC0_GMAC_MAC_ADDR41_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR41_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
981/* The address of the ALT_EMAC_GMAC_MAC_ADDR42_HIGH register for the ALT_EMAC0_GMACGRP instance. */
982#define ALT_EMAC0_GMAC_MAC_ADDR42_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR42_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
983/* The address of the ALT_EMAC_GMAC_MAC_ADDR42_LOW register for the ALT_EMAC0_GMACGRP instance. */
984#define ALT_EMAC0_GMAC_MAC_ADDR42_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR42_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
985/* The address of the ALT_EMAC_GMAC_MAC_ADDR43_HIGH register for the ALT_EMAC0_GMACGRP instance. */
986#define ALT_EMAC0_GMAC_MAC_ADDR43_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR43_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
987/* The address of the ALT_EMAC_GMAC_MAC_ADDR43_LOW register for the ALT_EMAC0_GMACGRP instance. */
988#define ALT_EMAC0_GMAC_MAC_ADDR43_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR43_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
989/* The address of the ALT_EMAC_GMAC_MAC_ADDR44_HIGH register for the ALT_EMAC0_GMACGRP instance. */
990#define ALT_EMAC0_GMAC_MAC_ADDR44_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR44_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
991/* The address of the ALT_EMAC_GMAC_MAC_ADDR44_LOW register for the ALT_EMAC0_GMACGRP instance. */
992#define ALT_EMAC0_GMAC_MAC_ADDR44_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR44_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
993/* The address of the ALT_EMAC_GMAC_MAC_ADDR45_HIGH register for the ALT_EMAC0_GMACGRP instance. */
994#define ALT_EMAC0_GMAC_MAC_ADDR45_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR45_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
995/* The address of the ALT_EMAC_GMAC_MAC_ADDR45_LOW register for the ALT_EMAC0_GMACGRP instance. */
996#define ALT_EMAC0_GMAC_MAC_ADDR45_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR45_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
997/* The address of the ALT_EMAC_GMAC_MAC_ADDR46_HIGH register for the ALT_EMAC0_GMACGRP instance. */
998#define ALT_EMAC0_GMAC_MAC_ADDR46_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR46_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
999/* The address of the ALT_EMAC_GMAC_MAC_ADDR46_LOW register for the ALT_EMAC0_GMACGRP instance. */
1000#define ALT_EMAC0_GMAC_MAC_ADDR46_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR46_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1001/* The address of the ALT_EMAC_GMAC_MAC_ADDR47_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1002#define ALT_EMAC0_GMAC_MAC_ADDR47_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR47_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1003/* The address of the ALT_EMAC_GMAC_MAC_ADDR47_LOW register for the ALT_EMAC0_GMACGRP instance. */
1004#define ALT_EMAC0_GMAC_MAC_ADDR47_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR47_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1005/* The address of the ALT_EMAC_GMAC_MAC_ADDR48_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1006#define ALT_EMAC0_GMAC_MAC_ADDR48_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR48_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1007/* The address of the ALT_EMAC_GMAC_MAC_ADDR48_LOW register for the ALT_EMAC0_GMACGRP instance. */
1008#define ALT_EMAC0_GMAC_MAC_ADDR48_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR48_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1009/* The address of the ALT_EMAC_GMAC_MAC_ADDR49_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1010#define ALT_EMAC0_GMAC_MAC_ADDR49_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR49_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1011/* The address of the ALT_EMAC_GMAC_MAC_ADDR49_LOW register for the ALT_EMAC0_GMACGRP instance. */
1012#define ALT_EMAC0_GMAC_MAC_ADDR49_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR49_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1013/* The address of the ALT_EMAC_GMAC_MAC_ADDR50_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1014#define ALT_EMAC0_GMAC_MAC_ADDR50_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR50_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1015/* The address of the ALT_EMAC_GMAC_MAC_ADDR50_LOW register for the ALT_EMAC0_GMACGRP instance. */
1016#define ALT_EMAC0_GMAC_MAC_ADDR50_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR50_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1017/* The address of the ALT_EMAC_GMAC_MAC_ADDR51_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1018#define ALT_EMAC0_GMAC_MAC_ADDR51_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR51_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1019/* The address of the ALT_EMAC_GMAC_MAC_ADDR51_LOW register for the ALT_EMAC0_GMACGRP instance. */
1020#define ALT_EMAC0_GMAC_MAC_ADDR51_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR51_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1021/* The address of the ALT_EMAC_GMAC_MAC_ADDR52_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1022#define ALT_EMAC0_GMAC_MAC_ADDR52_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR52_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1023/* The address of the ALT_EMAC_GMAC_MAC_ADDR52_LOW register for the ALT_EMAC0_GMACGRP instance. */
1024#define ALT_EMAC0_GMAC_MAC_ADDR52_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR52_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1025/* The address of the ALT_EMAC_GMAC_MAC_ADDR53_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1026#define ALT_EMAC0_GMAC_MAC_ADDR53_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR53_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1027/* The address of the ALT_EMAC_GMAC_MAC_ADDR53_LOW register for the ALT_EMAC0_GMACGRP instance. */
1028#define ALT_EMAC0_GMAC_MAC_ADDR53_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR53_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1029/* The address of the ALT_EMAC_GMAC_MAC_ADDR54_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1030#define ALT_EMAC0_GMAC_MAC_ADDR54_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR54_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1031/* The address of the ALT_EMAC_GMAC_MAC_ADDR54_LOW register for the ALT_EMAC0_GMACGRP instance. */
1032#define ALT_EMAC0_GMAC_MAC_ADDR54_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR54_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1033/* The address of the ALT_EMAC_GMAC_MAC_ADDR55_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1034#define ALT_EMAC0_GMAC_MAC_ADDR55_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR55_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1035/* The address of the ALT_EMAC_GMAC_MAC_ADDR55_LOW register for the ALT_EMAC0_GMACGRP instance. */
1036#define ALT_EMAC0_GMAC_MAC_ADDR55_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR55_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1037/* The address of the ALT_EMAC_GMAC_MAC_ADDR56_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1038#define ALT_EMAC0_GMAC_MAC_ADDR56_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR56_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1039/* The address of the ALT_EMAC_GMAC_MAC_ADDR56_LOW register for the ALT_EMAC0_GMACGRP instance. */
1040#define ALT_EMAC0_GMAC_MAC_ADDR56_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR56_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1041/* The address of the ALT_EMAC_GMAC_MAC_ADDR57_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1042#define ALT_EMAC0_GMAC_MAC_ADDR57_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR57_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1043/* The address of the ALT_EMAC_GMAC_MAC_ADDR57_LOW register for the ALT_EMAC0_GMACGRP instance. */
1044#define ALT_EMAC0_GMAC_MAC_ADDR57_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR57_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1045/* The address of the ALT_EMAC_GMAC_MAC_ADDR58_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1046#define ALT_EMAC0_GMAC_MAC_ADDR58_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR58_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1047/* The address of the ALT_EMAC_GMAC_MAC_ADDR58_LOW register for the ALT_EMAC0_GMACGRP instance. */
1048#define ALT_EMAC0_GMAC_MAC_ADDR58_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR58_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1049/* The address of the ALT_EMAC_GMAC_MAC_ADDR59_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1050#define ALT_EMAC0_GMAC_MAC_ADDR59_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR59_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1051/* The address of the ALT_EMAC_GMAC_MAC_ADDR59_LOW register for the ALT_EMAC0_GMACGRP instance. */
1052#define ALT_EMAC0_GMAC_MAC_ADDR59_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR59_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1053/* The address of the ALT_EMAC_GMAC_MAC_ADDR60_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1054#define ALT_EMAC0_GMAC_MAC_ADDR60_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR60_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1055/* The address of the ALT_EMAC_GMAC_MAC_ADDR60_LOW register for the ALT_EMAC0_GMACGRP instance. */
1056#define ALT_EMAC0_GMAC_MAC_ADDR60_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR60_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1057/* The address of the ALT_EMAC_GMAC_MAC_ADDR61_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1058#define ALT_EMAC0_GMAC_MAC_ADDR61_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR61_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1059/* The address of the ALT_EMAC_GMAC_MAC_ADDR61_LOW register for the ALT_EMAC0_GMACGRP instance. */
1060#define ALT_EMAC0_GMAC_MAC_ADDR61_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR61_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1061/* The address of the ALT_EMAC_GMAC_MAC_ADDR62_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1062#define ALT_EMAC0_GMAC_MAC_ADDR62_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR62_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1063/* The address of the ALT_EMAC_GMAC_MAC_ADDR62_LOW register for the ALT_EMAC0_GMACGRP instance. */
1064#define ALT_EMAC0_GMAC_MAC_ADDR62_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR62_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1065/* The address of the ALT_EMAC_GMAC_MAC_ADDR63_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1066#define ALT_EMAC0_GMAC_MAC_ADDR63_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR63_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1067/* The address of the ALT_EMAC_GMAC_MAC_ADDR63_LOW register for the ALT_EMAC0_GMACGRP instance. */
1068#define ALT_EMAC0_GMAC_MAC_ADDR63_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR63_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1069/* The address of the ALT_EMAC_GMAC_MAC_ADDR64_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1070#define ALT_EMAC0_GMAC_MAC_ADDR64_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR64_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1071/* The address of the ALT_EMAC_GMAC_MAC_ADDR64_LOW register for the ALT_EMAC0_GMACGRP instance. */
1072#define ALT_EMAC0_GMAC_MAC_ADDR64_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR64_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1073/* The address of the ALT_EMAC_GMAC_MAC_ADDR65_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1074#define ALT_EMAC0_GMAC_MAC_ADDR65_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR65_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1075/* The address of the ALT_EMAC_GMAC_MAC_ADDR65_LOW register for the ALT_EMAC0_GMACGRP instance. */
1076#define ALT_EMAC0_GMAC_MAC_ADDR65_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR65_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1077/* The address of the ALT_EMAC_GMAC_MAC_ADDR66_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1078#define ALT_EMAC0_GMAC_MAC_ADDR66_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR66_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1079/* The address of the ALT_EMAC_GMAC_MAC_ADDR66_LOW register for the ALT_EMAC0_GMACGRP instance. */
1080#define ALT_EMAC0_GMAC_MAC_ADDR66_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR66_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1081/* The address of the ALT_EMAC_GMAC_MAC_ADDR67_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1082#define ALT_EMAC0_GMAC_MAC_ADDR67_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR67_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1083/* The address of the ALT_EMAC_GMAC_MAC_ADDR67_LOW register for the ALT_EMAC0_GMACGRP instance. */
1084#define ALT_EMAC0_GMAC_MAC_ADDR67_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR67_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1085/* The address of the ALT_EMAC_GMAC_MAC_ADDR68_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1086#define ALT_EMAC0_GMAC_MAC_ADDR68_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR68_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1087/* The address of the ALT_EMAC_GMAC_MAC_ADDR68_LOW register for the ALT_EMAC0_GMACGRP instance. */
1088#define ALT_EMAC0_GMAC_MAC_ADDR68_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR68_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1089/* The address of the ALT_EMAC_GMAC_MAC_ADDR69_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1090#define ALT_EMAC0_GMAC_MAC_ADDR69_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR69_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1091/* The address of the ALT_EMAC_GMAC_MAC_ADDR69_LOW register for the ALT_EMAC0_GMACGRP instance. */
1092#define ALT_EMAC0_GMAC_MAC_ADDR69_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR69_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1093/* The address of the ALT_EMAC_GMAC_MAC_ADDR70_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1094#define ALT_EMAC0_GMAC_MAC_ADDR70_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR70_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1095/* The address of the ALT_EMAC_GMAC_MAC_ADDR70_LOW register for the ALT_EMAC0_GMACGRP instance. */
1096#define ALT_EMAC0_GMAC_MAC_ADDR70_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR70_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1097/* The address of the ALT_EMAC_GMAC_MAC_ADDR71_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1098#define ALT_EMAC0_GMAC_MAC_ADDR71_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR71_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1099/* The address of the ALT_EMAC_GMAC_MAC_ADDR71_LOW register for the ALT_EMAC0_GMACGRP instance. */
1100#define ALT_EMAC0_GMAC_MAC_ADDR71_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR71_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1101/* The address of the ALT_EMAC_GMAC_MAC_ADDR72_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1102#define ALT_EMAC0_GMAC_MAC_ADDR72_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR72_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1103/* The address of the ALT_EMAC_GMAC_MAC_ADDR72_LOW register for the ALT_EMAC0_GMACGRP instance. */
1104#define ALT_EMAC0_GMAC_MAC_ADDR72_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR72_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1105/* The address of the ALT_EMAC_GMAC_MAC_ADDR73_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1106#define ALT_EMAC0_GMAC_MAC_ADDR73_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR73_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1107/* The address of the ALT_EMAC_GMAC_MAC_ADDR73_LOW register for the ALT_EMAC0_GMACGRP instance. */
1108#define ALT_EMAC0_GMAC_MAC_ADDR73_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR73_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1109/* The address of the ALT_EMAC_GMAC_MAC_ADDR74_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1110#define ALT_EMAC0_GMAC_MAC_ADDR74_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR74_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1111/* The address of the ALT_EMAC_GMAC_MAC_ADDR74_LOW register for the ALT_EMAC0_GMACGRP instance. */
1112#define ALT_EMAC0_GMAC_MAC_ADDR74_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR74_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1113/* The address of the ALT_EMAC_GMAC_MAC_ADDR75_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1114#define ALT_EMAC0_GMAC_MAC_ADDR75_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR75_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1115/* The address of the ALT_EMAC_GMAC_MAC_ADDR75_LOW register for the ALT_EMAC0_GMACGRP instance. */
1116#define ALT_EMAC0_GMAC_MAC_ADDR75_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR75_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1117/* The address of the ALT_EMAC_GMAC_MAC_ADDR76_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1118#define ALT_EMAC0_GMAC_MAC_ADDR76_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR76_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1119/* The address of the ALT_EMAC_GMAC_MAC_ADDR76_LOW register for the ALT_EMAC0_GMACGRP instance. */
1120#define ALT_EMAC0_GMAC_MAC_ADDR76_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR76_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1121/* The address of the ALT_EMAC_GMAC_MAC_ADDR77_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1122#define ALT_EMAC0_GMAC_MAC_ADDR77_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR77_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1123/* The address of the ALT_EMAC_GMAC_MAC_ADDR77_LOW register for the ALT_EMAC0_GMACGRP instance. */
1124#define ALT_EMAC0_GMAC_MAC_ADDR77_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR77_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1125/* The address of the ALT_EMAC_GMAC_MAC_ADDR78_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1126#define ALT_EMAC0_GMAC_MAC_ADDR78_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR78_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1127/* The address of the ALT_EMAC_GMAC_MAC_ADDR78_LOW register for the ALT_EMAC0_GMACGRP instance. */
1128#define ALT_EMAC0_GMAC_MAC_ADDR78_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR78_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1129/* The address of the ALT_EMAC_GMAC_MAC_ADDR79_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1130#define ALT_EMAC0_GMAC_MAC_ADDR79_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR79_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1131/* The address of the ALT_EMAC_GMAC_MAC_ADDR79_LOW register for the ALT_EMAC0_GMACGRP instance. */
1132#define ALT_EMAC0_GMAC_MAC_ADDR79_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR79_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1133/* The address of the ALT_EMAC_GMAC_MAC_ADDR80_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1134#define ALT_EMAC0_GMAC_MAC_ADDR80_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR80_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1135/* The address of the ALT_EMAC_GMAC_MAC_ADDR80_LOW register for the ALT_EMAC0_GMACGRP instance. */
1136#define ALT_EMAC0_GMAC_MAC_ADDR80_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR80_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1137/* The address of the ALT_EMAC_GMAC_MAC_ADDR81_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1138#define ALT_EMAC0_GMAC_MAC_ADDR81_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR81_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1139/* The address of the ALT_EMAC_GMAC_MAC_ADDR81_LOW register for the ALT_EMAC0_GMACGRP instance. */
1140#define ALT_EMAC0_GMAC_MAC_ADDR81_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR81_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1141/* The address of the ALT_EMAC_GMAC_MAC_ADDR82_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1142#define ALT_EMAC0_GMAC_MAC_ADDR82_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR82_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1143/* The address of the ALT_EMAC_GMAC_MAC_ADDR82_LOW register for the ALT_EMAC0_GMACGRP instance. */
1144#define ALT_EMAC0_GMAC_MAC_ADDR82_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR82_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1145/* The address of the ALT_EMAC_GMAC_MAC_ADDR83_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1146#define ALT_EMAC0_GMAC_MAC_ADDR83_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR83_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1147/* The address of the ALT_EMAC_GMAC_MAC_ADDR83_LOW register for the ALT_EMAC0_GMACGRP instance. */
1148#define ALT_EMAC0_GMAC_MAC_ADDR83_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR83_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1149/* The address of the ALT_EMAC_GMAC_MAC_ADDR84_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1150#define ALT_EMAC0_GMAC_MAC_ADDR84_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR84_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1151/* The address of the ALT_EMAC_GMAC_MAC_ADDR84_LOW register for the ALT_EMAC0_GMACGRP instance. */
1152#define ALT_EMAC0_GMAC_MAC_ADDR84_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR84_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1153/* The address of the ALT_EMAC_GMAC_MAC_ADDR85_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1154#define ALT_EMAC0_GMAC_MAC_ADDR85_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR85_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1155/* The address of the ALT_EMAC_GMAC_MAC_ADDR85_LOW register for the ALT_EMAC0_GMACGRP instance. */
1156#define ALT_EMAC0_GMAC_MAC_ADDR85_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR85_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1157/* The address of the ALT_EMAC_GMAC_MAC_ADDR86_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1158#define ALT_EMAC0_GMAC_MAC_ADDR86_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR86_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1159/* The address of the ALT_EMAC_GMAC_MAC_ADDR86_LOW register for the ALT_EMAC0_GMACGRP instance. */
1160#define ALT_EMAC0_GMAC_MAC_ADDR86_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR86_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1161/* The address of the ALT_EMAC_GMAC_MAC_ADDR87_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1162#define ALT_EMAC0_GMAC_MAC_ADDR87_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR87_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1163/* The address of the ALT_EMAC_GMAC_MAC_ADDR87_LOW register for the ALT_EMAC0_GMACGRP instance. */
1164#define ALT_EMAC0_GMAC_MAC_ADDR87_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR87_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1165/* The address of the ALT_EMAC_GMAC_MAC_ADDR88_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1166#define ALT_EMAC0_GMAC_MAC_ADDR88_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR88_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1167/* The address of the ALT_EMAC_GMAC_MAC_ADDR88_LOW register for the ALT_EMAC0_GMACGRP instance. */
1168#define ALT_EMAC0_GMAC_MAC_ADDR88_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR88_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1169/* The address of the ALT_EMAC_GMAC_MAC_ADDR89_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1170#define ALT_EMAC0_GMAC_MAC_ADDR89_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR89_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1171/* The address of the ALT_EMAC_GMAC_MAC_ADDR89_LOW register for the ALT_EMAC0_GMACGRP instance. */
1172#define ALT_EMAC0_GMAC_MAC_ADDR89_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR89_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1173/* The address of the ALT_EMAC_GMAC_MAC_ADDR90_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1174#define ALT_EMAC0_GMAC_MAC_ADDR90_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR90_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1175/* The address of the ALT_EMAC_GMAC_MAC_ADDR90_LOW register for the ALT_EMAC0_GMACGRP instance. */
1176#define ALT_EMAC0_GMAC_MAC_ADDR90_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR90_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1177/* The address of the ALT_EMAC_GMAC_MAC_ADDR91_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1178#define ALT_EMAC0_GMAC_MAC_ADDR91_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR91_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1179/* The address of the ALT_EMAC_GMAC_MAC_ADDR91_LOW register for the ALT_EMAC0_GMACGRP instance. */
1180#define ALT_EMAC0_GMAC_MAC_ADDR91_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR91_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1181/* The address of the ALT_EMAC_GMAC_MAC_ADDR92_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1182#define ALT_EMAC0_GMAC_MAC_ADDR92_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR92_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1183/* The address of the ALT_EMAC_GMAC_MAC_ADDR92_LOW register for the ALT_EMAC0_GMACGRP instance. */
1184#define ALT_EMAC0_GMAC_MAC_ADDR92_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR92_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1185/* The address of the ALT_EMAC_GMAC_MAC_ADDR93_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1186#define ALT_EMAC0_GMAC_MAC_ADDR93_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR93_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1187/* The address of the ALT_EMAC_GMAC_MAC_ADDR93_LOW register for the ALT_EMAC0_GMACGRP instance. */
1188#define ALT_EMAC0_GMAC_MAC_ADDR93_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR93_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1189/* The address of the ALT_EMAC_GMAC_MAC_ADDR94_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1190#define ALT_EMAC0_GMAC_MAC_ADDR94_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR94_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1191/* The address of the ALT_EMAC_GMAC_MAC_ADDR94_LOW register for the ALT_EMAC0_GMACGRP instance. */
1192#define ALT_EMAC0_GMAC_MAC_ADDR94_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR94_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1193/* The address of the ALT_EMAC_GMAC_MAC_ADDR95_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1194#define ALT_EMAC0_GMAC_MAC_ADDR95_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR95_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1195/* The address of the ALT_EMAC_GMAC_MAC_ADDR95_LOW register for the ALT_EMAC0_GMACGRP instance. */
1196#define ALT_EMAC0_GMAC_MAC_ADDR95_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR95_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1197/* The address of the ALT_EMAC_GMAC_MAC_ADDR96_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1198#define ALT_EMAC0_GMAC_MAC_ADDR96_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR96_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1199/* The address of the ALT_EMAC_GMAC_MAC_ADDR96_LOW register for the ALT_EMAC0_GMACGRP instance. */
1200#define ALT_EMAC0_GMAC_MAC_ADDR96_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR96_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1201/* The address of the ALT_EMAC_GMAC_MAC_ADDR97_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1202#define ALT_EMAC0_GMAC_MAC_ADDR97_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR97_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1203/* The address of the ALT_EMAC_GMAC_MAC_ADDR97_LOW register for the ALT_EMAC0_GMACGRP instance. */
1204#define ALT_EMAC0_GMAC_MAC_ADDR97_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR97_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1205/* The address of the ALT_EMAC_GMAC_MAC_ADDR98_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1206#define ALT_EMAC0_GMAC_MAC_ADDR98_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR98_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1207/* The address of the ALT_EMAC_GMAC_MAC_ADDR98_LOW register for the ALT_EMAC0_GMACGRP instance. */
1208#define ALT_EMAC0_GMAC_MAC_ADDR98_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR98_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1209/* The address of the ALT_EMAC_GMAC_MAC_ADDR99_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1210#define ALT_EMAC0_GMAC_MAC_ADDR99_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR99_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1211/* The address of the ALT_EMAC_GMAC_MAC_ADDR99_LOW register for the ALT_EMAC0_GMACGRP instance. */
1212#define ALT_EMAC0_GMAC_MAC_ADDR99_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR99_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1213/* The address of the ALT_EMAC_GMAC_MAC_ADDR100_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1214#define ALT_EMAC0_GMAC_MAC_ADDR100_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR100_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1215/* The address of the ALT_EMAC_GMAC_MAC_ADDR100_LOW register for the ALT_EMAC0_GMACGRP instance. */
1216#define ALT_EMAC0_GMAC_MAC_ADDR100_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR100_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1217/* The address of the ALT_EMAC_GMAC_MAC_ADDR101_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1218#define ALT_EMAC0_GMAC_MAC_ADDR101_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR101_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1219/* The address of the ALT_EMAC_GMAC_MAC_ADDR101_LOW register for the ALT_EMAC0_GMACGRP instance. */
1220#define ALT_EMAC0_GMAC_MAC_ADDR101_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR101_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1221/* The address of the ALT_EMAC_GMAC_MAC_ADDR102_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1222#define ALT_EMAC0_GMAC_MAC_ADDR102_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR102_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1223/* The address of the ALT_EMAC_GMAC_MAC_ADDR102_LOW register for the ALT_EMAC0_GMACGRP instance. */
1224#define ALT_EMAC0_GMAC_MAC_ADDR102_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR102_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1225/* The address of the ALT_EMAC_GMAC_MAC_ADDR103_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1226#define ALT_EMAC0_GMAC_MAC_ADDR103_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR103_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1227/* The address of the ALT_EMAC_GMAC_MAC_ADDR103_LOW register for the ALT_EMAC0_GMACGRP instance. */
1228#define ALT_EMAC0_GMAC_MAC_ADDR103_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR103_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1229/* The address of the ALT_EMAC_GMAC_MAC_ADDR104_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1230#define ALT_EMAC0_GMAC_MAC_ADDR104_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR104_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1231/* The address of the ALT_EMAC_GMAC_MAC_ADDR104_LOW register for the ALT_EMAC0_GMACGRP instance. */
1232#define ALT_EMAC0_GMAC_MAC_ADDR104_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR104_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1233/* The address of the ALT_EMAC_GMAC_MAC_ADDR105_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1234#define ALT_EMAC0_GMAC_MAC_ADDR105_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR105_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1235/* The address of the ALT_EMAC_GMAC_MAC_ADDR105_LOW register for the ALT_EMAC0_GMACGRP instance. */
1236#define ALT_EMAC0_GMAC_MAC_ADDR105_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR105_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1237/* The address of the ALT_EMAC_GMAC_MAC_ADDR106_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1238#define ALT_EMAC0_GMAC_MAC_ADDR106_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR106_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1239/* The address of the ALT_EMAC_GMAC_MAC_ADDR106_LOW register for the ALT_EMAC0_GMACGRP instance. */
1240#define ALT_EMAC0_GMAC_MAC_ADDR106_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR106_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1241/* The address of the ALT_EMAC_GMAC_MAC_ADDR107_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1242#define ALT_EMAC0_GMAC_MAC_ADDR107_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR107_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1243/* The address of the ALT_EMAC_GMAC_MAC_ADDR107_LOW register for the ALT_EMAC0_GMACGRP instance. */
1244#define ALT_EMAC0_GMAC_MAC_ADDR107_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR107_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1245/* The address of the ALT_EMAC_GMAC_MAC_ADDR108_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1246#define ALT_EMAC0_GMAC_MAC_ADDR108_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR108_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1247/* The address of the ALT_EMAC_GMAC_MAC_ADDR108_LOW register for the ALT_EMAC0_GMACGRP instance. */
1248#define ALT_EMAC0_GMAC_MAC_ADDR108_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR108_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1249/* The address of the ALT_EMAC_GMAC_MAC_ADDR109_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1250#define ALT_EMAC0_GMAC_MAC_ADDR109_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR109_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1251/* The address of the ALT_EMAC_GMAC_MAC_ADDR109_LOW register for the ALT_EMAC0_GMACGRP instance. */
1252#define ALT_EMAC0_GMAC_MAC_ADDR109_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR109_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1253/* The address of the ALT_EMAC_GMAC_MAC_ADDR110_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1254#define ALT_EMAC0_GMAC_MAC_ADDR110_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR110_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1255/* The address of the ALT_EMAC_GMAC_MAC_ADDR110_LOW register for the ALT_EMAC0_GMACGRP instance. */
1256#define ALT_EMAC0_GMAC_MAC_ADDR110_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR110_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1257/* The address of the ALT_EMAC_GMAC_MAC_ADDR111_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1258#define ALT_EMAC0_GMAC_MAC_ADDR111_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR111_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1259/* The address of the ALT_EMAC_GMAC_MAC_ADDR111_LOW register for the ALT_EMAC0_GMACGRP instance. */
1260#define ALT_EMAC0_GMAC_MAC_ADDR111_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR111_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1261/* The address of the ALT_EMAC_GMAC_MAC_ADDR112_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1262#define ALT_EMAC0_GMAC_MAC_ADDR112_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR112_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1263/* The address of the ALT_EMAC_GMAC_MAC_ADDR112_LOW register for the ALT_EMAC0_GMACGRP instance. */
1264#define ALT_EMAC0_GMAC_MAC_ADDR112_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR112_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1265/* The address of the ALT_EMAC_GMAC_MAC_ADDR113_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1266#define ALT_EMAC0_GMAC_MAC_ADDR113_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR113_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1267/* The address of the ALT_EMAC_GMAC_MAC_ADDR113_LOW register for the ALT_EMAC0_GMACGRP instance. */
1268#define ALT_EMAC0_GMAC_MAC_ADDR113_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR113_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1269/* The address of the ALT_EMAC_GMAC_MAC_ADDR114_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1270#define ALT_EMAC0_GMAC_MAC_ADDR114_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR114_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1271/* The address of the ALT_EMAC_GMAC_MAC_ADDR114_LOW register for the ALT_EMAC0_GMACGRP instance. */
1272#define ALT_EMAC0_GMAC_MAC_ADDR114_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR114_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1273/* The address of the ALT_EMAC_GMAC_MAC_ADDR115_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1274#define ALT_EMAC0_GMAC_MAC_ADDR115_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR115_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1275/* The address of the ALT_EMAC_GMAC_MAC_ADDR115_LOW register for the ALT_EMAC0_GMACGRP instance. */
1276#define ALT_EMAC0_GMAC_MAC_ADDR115_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR115_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1277/* The address of the ALT_EMAC_GMAC_MAC_ADDR116_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1278#define ALT_EMAC0_GMAC_MAC_ADDR116_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR116_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1279/* The address of the ALT_EMAC_GMAC_MAC_ADDR116_LOW register for the ALT_EMAC0_GMACGRP instance. */
1280#define ALT_EMAC0_GMAC_MAC_ADDR116_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR116_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1281/* The address of the ALT_EMAC_GMAC_MAC_ADDR117_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1282#define ALT_EMAC0_GMAC_MAC_ADDR117_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR117_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1283/* The address of the ALT_EMAC_GMAC_MAC_ADDR117_LOW register for the ALT_EMAC0_GMACGRP instance. */
1284#define ALT_EMAC0_GMAC_MAC_ADDR117_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR117_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1285/* The address of the ALT_EMAC_GMAC_MAC_ADDR118_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1286#define ALT_EMAC0_GMAC_MAC_ADDR118_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR118_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1287/* The address of the ALT_EMAC_GMAC_MAC_ADDR118_LOW register for the ALT_EMAC0_GMACGRP instance. */
1288#define ALT_EMAC0_GMAC_MAC_ADDR118_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR118_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1289/* The address of the ALT_EMAC_GMAC_MAC_ADDR119_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1290#define ALT_EMAC0_GMAC_MAC_ADDR119_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR119_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1291/* The address of the ALT_EMAC_GMAC_MAC_ADDR119_LOW register for the ALT_EMAC0_GMACGRP instance. */
1292#define ALT_EMAC0_GMAC_MAC_ADDR119_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR119_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1293/* The address of the ALT_EMAC_GMAC_MAC_ADDR120_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1294#define ALT_EMAC0_GMAC_MAC_ADDR120_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR120_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1295/* The address of the ALT_EMAC_GMAC_MAC_ADDR120_LOW register for the ALT_EMAC0_GMACGRP instance. */
1296#define ALT_EMAC0_GMAC_MAC_ADDR120_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR120_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1297/* The address of the ALT_EMAC_GMAC_MAC_ADDR121_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1298#define ALT_EMAC0_GMAC_MAC_ADDR121_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR121_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1299/* The address of the ALT_EMAC_GMAC_MAC_ADDR121_LOW register for the ALT_EMAC0_GMACGRP instance. */
1300#define ALT_EMAC0_GMAC_MAC_ADDR121_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR121_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1301/* The address of the ALT_EMAC_GMAC_MAC_ADDR122_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1302#define ALT_EMAC0_GMAC_MAC_ADDR122_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR122_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1303/* The address of the ALT_EMAC_GMAC_MAC_ADDR122_LOW register for the ALT_EMAC0_GMACGRP instance. */
1304#define ALT_EMAC0_GMAC_MAC_ADDR122_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR122_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1305/* The address of the ALT_EMAC_GMAC_MAC_ADDR123_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1306#define ALT_EMAC0_GMAC_MAC_ADDR123_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR123_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1307/* The address of the ALT_EMAC_GMAC_MAC_ADDR123_LOW register for the ALT_EMAC0_GMACGRP instance. */
1308#define ALT_EMAC0_GMAC_MAC_ADDR123_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR123_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1309/* The address of the ALT_EMAC_GMAC_MAC_ADDR124_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1310#define ALT_EMAC0_GMAC_MAC_ADDR124_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR124_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1311/* The address of the ALT_EMAC_GMAC_MAC_ADDR124_LOW register for the ALT_EMAC0_GMACGRP instance. */
1312#define ALT_EMAC0_GMAC_MAC_ADDR124_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR124_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1313/* The address of the ALT_EMAC_GMAC_MAC_ADDR125_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1314#define ALT_EMAC0_GMAC_MAC_ADDR125_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR125_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1315/* The address of the ALT_EMAC_GMAC_MAC_ADDR125_LOW register for the ALT_EMAC0_GMACGRP instance. */
1316#define ALT_EMAC0_GMAC_MAC_ADDR125_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR125_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1317/* The address of the ALT_EMAC_GMAC_MAC_ADDR126_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1318#define ALT_EMAC0_GMAC_MAC_ADDR126_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR126_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1319/* The address of the ALT_EMAC_GMAC_MAC_ADDR126_LOW register for the ALT_EMAC0_GMACGRP instance. */
1320#define ALT_EMAC0_GMAC_MAC_ADDR126_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR126_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1321/* The address of the ALT_EMAC_GMAC_MAC_ADDR127_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1322#define ALT_EMAC0_GMAC_MAC_ADDR127_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR127_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1323/* The address of the ALT_EMAC_GMAC_MAC_ADDR127_LOW register for the ALT_EMAC0_GMACGRP instance. */
1324#define ALT_EMAC0_GMAC_MAC_ADDR127_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR127_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1325/* The base address byte offset for the start of the ALT_EMAC0_GMACGRP component. */
1326#define ALT_EMAC0_GMACGRP_OFST 0x0
1327/* The start address of the ALT_EMAC0_GMACGRP component. */
1328#define ALT_EMAC0_GMACGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_EMAC0_ADDR) + ALT_EMAC0_GMACGRP_OFST))
1329/* The lower bound address range of the ALT_EMAC0_GMACGRP component. */
1330#define ALT_EMAC0_GMACGRP_LB_ADDR ALT_EMAC0_GMACGRP_ADDR
1331/* The upper bound address range of the ALT_EMAC0_GMACGRP component. */
1332#define ALT_EMAC0_GMACGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_EMAC0_GMACGRP_ADDR) + 0xb80) - 1))
1333
1334
1335/*
1336 * Register Group Instance : dmagrp
1337 *
1338 * Instance dmagrp of register group ALT_EMAC_DMA.
1339 *
1340 *
1341 */
1342/* The address of the ALT_EMAC_DMA_BUS_MOD register for the ALT_EMAC0_DMAGRP instance. */
1343#define ALT_EMAC0_DMA_BUS_MOD_ADDR ALT_EMAC_DMA_BUS_MOD_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1344/* The address of the ALT_EMAC_DMA_TX_POLL_DEMAND register for the ALT_EMAC0_DMAGRP instance. */
1345#define ALT_EMAC0_DMA_TX_POLL_DEMAND_ADDR ALT_EMAC_DMA_TX_POLL_DEMAND_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1346/* The address of the ALT_EMAC_DMA_RX_POLL_DEMAND register for the ALT_EMAC0_DMAGRP instance. */
1347#define ALT_EMAC0_DMA_RX_POLL_DEMAND_ADDR ALT_EMAC_DMA_RX_POLL_DEMAND_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1348/* The address of the ALT_EMAC_DMA_RX_DESC_LIST_ADDR register for the ALT_EMAC0_DMAGRP instance. */
1349#define ALT_EMAC0_DMA_RX_DESC_LIST_ADDR_ADDR ALT_EMAC_DMA_RX_DESC_LIST_ADDR_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1350/* The address of the ALT_EMAC_DMA_TX_DESC_LIST_ADDR register for the ALT_EMAC0_DMAGRP instance. */
1351#define ALT_EMAC0_DMA_TX_DESC_LIST_ADDR_ADDR ALT_EMAC_DMA_TX_DESC_LIST_ADDR_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1352/* The address of the ALT_EMAC_DMA_STAT register for the ALT_EMAC0_DMAGRP instance. */
1353#define ALT_EMAC0_DMA_STAT_ADDR ALT_EMAC_DMA_STAT_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1354/* The address of the ALT_EMAC_DMA_OP_MOD register for the ALT_EMAC0_DMAGRP instance. */
1355#define ALT_EMAC0_DMA_OP_MOD_ADDR ALT_EMAC_DMA_OP_MOD_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1356/* The address of the ALT_EMAC_DMA_INT_EN register for the ALT_EMAC0_DMAGRP instance. */
1357#define ALT_EMAC0_DMA_INT_EN_ADDR ALT_EMAC_DMA_INT_EN_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1358/* The address of the ALT_EMAC_DMA_MFRM_BUF_OVF_CNTR register for the ALT_EMAC0_DMAGRP instance. */
1359#define ALT_EMAC0_DMA_MISSED_FRM_AND_BUF_OVF_CNTR_ADDR ALT_EMAC_DMA_MFRM_BUF_OVF_CNTR_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1360/* The address of the ALT_EMAC_DMA_RX_INT_WDT register for the ALT_EMAC0_DMAGRP instance. */
1361#define ALT_EMAC0_DMA_RX_INT_WDT_ADDR ALT_EMAC_DMA_RX_INT_WDT_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1362/* The address of the ALT_EMAC_DMA_AXI_BUS_MOD register for the ALT_EMAC0_DMAGRP instance. */
1363#define ALT_EMAC0_DMA_AXI_BUS_MOD_ADDR ALT_EMAC_DMA_AXI_BUS_MOD_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1364/* The address of the ALT_EMAC_DMA_AHB_OR_AXI_STAT register for the ALT_EMAC0_DMAGRP instance. */
1365#define ALT_EMAC0_DMA_AHB_OR_AXI_STAT_ADDR ALT_EMAC_DMA_AHB_OR_AXI_STAT_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1366/* The address of the ALT_EMAC_DMA_CUR_HOST_TX_DESC register for the ALT_EMAC0_DMAGRP instance. */
1367#define ALT_EMAC0_DMA_CUR_HOST_TX_DESC_ADDR ALT_EMAC_DMA_CUR_HOST_TX_DESC_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1368/* The address of the ALT_EMAC_DMA_CUR_HOST_RX_DESC register for the ALT_EMAC0_DMAGRP instance. */
1369#define ALT_EMAC0_DMA_CUR_HOST_RX_DESC_ADDR ALT_EMAC_DMA_CUR_HOST_RX_DESC_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1370/* The address of the ALT_EMAC_DMA_CUR_HOST_TX_BUF_ADDR register for the ALT_EMAC0_DMAGRP instance. */
1371#define ALT_EMAC0_DMA_CUR_HOST_TX_BUF_ADDR_ADDR ALT_EMAC_DMA_CUR_HOST_TX_BUF_ADDR_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1372/* The address of the ALT_EMAC_DMA_CUR_HOST_RX_BUF_ADDR register for the ALT_EMAC0_DMAGRP instance. */
1373#define ALT_EMAC0_DMA_CUR_HOST_RX_BUF_ADDR_ADDR ALT_EMAC_DMA_CUR_HOST_RX_BUF_ADDR_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1374/* The address of the ALT_EMAC_DMA_HW_FEATURE register for the ALT_EMAC0_DMAGRP instance. */
1375#define ALT_EMAC0_DMA_HW_FEATURE_ADDR ALT_EMAC_DMA_HW_FEATURE_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1376/* The base address byte offset for the start of the ALT_EMAC0_DMAGRP component. */
1377#define ALT_EMAC0_DMAGRP_OFST 0x1000
1378/* The start address of the ALT_EMAC0_DMAGRP component. */
1379#define ALT_EMAC0_DMAGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_EMAC0_ADDR) + ALT_EMAC0_DMAGRP_OFST))
1380/* The lower bound address range of the ALT_EMAC0_DMAGRP component. */
1381#define ALT_EMAC0_DMAGRP_LB_ADDR ALT_EMAC0_DMAGRP_ADDR
1382/* The upper bound address range of the ALT_EMAC0_DMAGRP component. */
1383#define ALT_EMAC0_DMAGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_EMAC0_DMAGRP_ADDR) + 0x5c) - 1))
1384
1385
1386/* The base address byte offset for the start of the ALT_EMAC0 component. */
1387#define ALT_EMAC0_OFST 0xff700000
1388/* The start address of the ALT_EMAC0 component. */
1389#define ALT_EMAC0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_EMAC0_OFST))
1390/* The lower bound address range of the ALT_EMAC0 component. */
1391#define ALT_EMAC0_LB_ADDR ALT_EMAC0_ADDR
1392/* The upper bound address range of the ALT_EMAC0 component. */
1393#define ALT_EMAC0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_EMAC0_ADDR) + 0x2000) - 1))
1394
1395
1396/*
1397 * Component Instance : emac1
1398 *
1399 * Instance emac1 of component ALT_EMAC.
1400 *
1401 *
1402 */
1403/*
1404 * Register Group Instance : gmacgrp
1405 *
1406 * Instance gmacgrp of register group ALT_EMAC_GMAC.
1407 *
1408 *
1409 */
1410/* The address of the ALT_EMAC_GMAC_MAC_CFG register for the ALT_EMAC1_GMACGRP instance. */
1411#define ALT_EMAC1_GMAC_MAC_CFG_ADDR ALT_EMAC_GMAC_MAC_CFG_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1412/* The address of the ALT_EMAC_GMAC_MAC_FRM_FLT register for the ALT_EMAC1_GMACGRP instance. */
1413#define ALT_EMAC1_GMAC_MAC_FRM_FLT_ADDR ALT_EMAC_GMAC_MAC_FRM_FLT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1414/* The address of the ALT_EMAC_GMAC_GMII_ADDR register for the ALT_EMAC1_GMACGRP instance. */
1415#define ALT_EMAC1_GMAC_GMII_ADDR_ADDR ALT_EMAC_GMAC_GMII_ADDR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1416/* The address of the ALT_EMAC_GMAC_GMII_DATA register for the ALT_EMAC1_GMACGRP instance. */
1417#define ALT_EMAC1_GMAC_GMII_DATA_ADDR ALT_EMAC_GMAC_GMII_DATA_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1418/* The address of the ALT_EMAC_GMAC_FLOW_CTL register for the ALT_EMAC1_GMACGRP instance. */
1419#define ALT_EMAC1_GMAC_FLOW_CTL_ADDR ALT_EMAC_GMAC_FLOW_CTL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1420/* The address of the ALT_EMAC_GMAC_VLAN_TAG register for the ALT_EMAC1_GMACGRP instance. */
1421#define ALT_EMAC1_GMAC_VLAN_TAG_ADDR ALT_EMAC_GMAC_VLAN_TAG_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1422/* The address of the ALT_EMAC_GMAC_VER register for the ALT_EMAC1_GMACGRP instance. */
1423#define ALT_EMAC1_GMAC_VER_ADDR ALT_EMAC_GMAC_VER_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1424/* The address of the ALT_EMAC_GMAC_DBG register for the ALT_EMAC1_GMACGRP instance. */
1425#define ALT_EMAC1_GMAC_DBG_ADDR ALT_EMAC_GMAC_DBG_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1426/* The address of the ALT_EMAC_GMAC_LPI_CTL_STAT register for the ALT_EMAC1_GMACGRP instance. */
1427#define ALT_EMAC1_GMAC_LPI_CTL_STAT_ADDR ALT_EMAC_GMAC_LPI_CTL_STAT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1428/* The address of the ALT_EMAC_GMAC_LPI_TMRS_CTL register for the ALT_EMAC1_GMACGRP instance. */
1429#define ALT_EMAC1_GMAC_LPI_TMRS_CTL_ADDR ALT_EMAC_GMAC_LPI_TMRS_CTL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1430/* The address of the ALT_EMAC_GMAC_INT_STAT register for the ALT_EMAC1_GMACGRP instance. */
1431#define ALT_EMAC1_GMAC_INT_STAT_ADDR ALT_EMAC_GMAC_INT_STAT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1432/* The address of the ALT_EMAC_GMAC_INT_MSK register for the ALT_EMAC1_GMACGRP instance. */
1433#define ALT_EMAC1_GMAC_INT_MSK_ADDR ALT_EMAC_GMAC_INT_MSK_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1434/* The address of the ALT_EMAC_GMAC_MAC_ADDR0_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1435#define ALT_EMAC1_GMAC_MAC_ADDR0_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR0_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1436/* The address of the ALT_EMAC_GMAC_MAC_ADDR0_LOW register for the ALT_EMAC1_GMACGRP instance. */
1437#define ALT_EMAC1_GMAC_MAC_ADDR0_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR0_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1438/* The address of the ALT_EMAC_GMAC_MAC_ADDR1_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1439#define ALT_EMAC1_GMAC_MAC_ADDR1_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR1_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1440/* The address of the ALT_EMAC_GMAC_MAC_ADDR1_LOW register for the ALT_EMAC1_GMACGRP instance. */
1441#define ALT_EMAC1_GMAC_MAC_ADDR1_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR1_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1442/* The address of the ALT_EMAC_GMAC_MAC_ADDR2_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1443#define ALT_EMAC1_GMAC_MAC_ADDR2_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR2_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1444/* The address of the ALT_EMAC_GMAC_MAC_ADDR2_LOW register for the ALT_EMAC1_GMACGRP instance. */
1445#define ALT_EMAC1_GMAC_MAC_ADDR2_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR2_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1446/* The address of the ALT_EMAC_GMAC_MAC_ADDR3_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1447#define ALT_EMAC1_GMAC_MAC_ADDR3_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR3_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1448/* The address of the ALT_EMAC_GMAC_MAC_ADDR3_LOW register for the ALT_EMAC1_GMACGRP instance. */
1449#define ALT_EMAC1_GMAC_MAC_ADDR3_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR3_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1450/* The address of the ALT_EMAC_GMAC_MAC_ADDR4_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1451#define ALT_EMAC1_GMAC_MAC_ADDR4_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR4_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1452/* The address of the ALT_EMAC_GMAC_MAC_ADDR4_LOW register for the ALT_EMAC1_GMACGRP instance. */
1453#define ALT_EMAC1_GMAC_MAC_ADDR4_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR4_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1454/* The address of the ALT_EMAC_GMAC_MAC_ADDR5_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1455#define ALT_EMAC1_GMAC_MAC_ADDR5_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR5_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1456/* The address of the ALT_EMAC_GMAC_MAC_ADDR5_LOW register for the ALT_EMAC1_GMACGRP instance. */
1457#define ALT_EMAC1_GMAC_MAC_ADDR5_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR5_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1458/* The address of the ALT_EMAC_GMAC_MAC_ADDR6_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1459#define ALT_EMAC1_GMAC_MAC_ADDR6_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR6_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1460/* The address of the ALT_EMAC_GMAC_MAC_ADDR6_LOW register for the ALT_EMAC1_GMACGRP instance. */
1461#define ALT_EMAC1_GMAC_MAC_ADDR6_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR6_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1462/* The address of the ALT_EMAC_GMAC_MAC_ADDR7_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1463#define ALT_EMAC1_GMAC_MAC_ADDR7_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR7_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1464/* The address of the ALT_EMAC_GMAC_MAC_ADDR7_LOW register for the ALT_EMAC1_GMACGRP instance. */
1465#define ALT_EMAC1_GMAC_MAC_ADDR7_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR7_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1466/* The address of the ALT_EMAC_GMAC_MAC_ADDR8_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1467#define ALT_EMAC1_GMAC_MAC_ADDR8_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR8_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1468/* The address of the ALT_EMAC_GMAC_MAC_ADDR8_LOW register for the ALT_EMAC1_GMACGRP instance. */
1469#define ALT_EMAC1_GMAC_MAC_ADDR8_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR8_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1470/* The address of the ALT_EMAC_GMAC_MAC_ADDR9_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1471#define ALT_EMAC1_GMAC_MAC_ADDR9_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR9_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1472/* The address of the ALT_EMAC_GMAC_MAC_ADDR9_LOW register for the ALT_EMAC1_GMACGRP instance. */
1473#define ALT_EMAC1_GMAC_MAC_ADDR9_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR9_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1474/* The address of the ALT_EMAC_GMAC_MAC_ADDR10_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1475#define ALT_EMAC1_GMAC_MAC_ADDR10_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR10_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1476/* The address of the ALT_EMAC_GMAC_MAC_ADDR10_LOW register for the ALT_EMAC1_GMACGRP instance. */
1477#define ALT_EMAC1_GMAC_MAC_ADDR10_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR10_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1478/* The address of the ALT_EMAC_GMAC_MAC_ADDR11_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1479#define ALT_EMAC1_GMAC_MAC_ADDR11_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR11_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1480/* The address of the ALT_EMAC_GMAC_MAC_ADDR11_LOW register for the ALT_EMAC1_GMACGRP instance. */
1481#define ALT_EMAC1_GMAC_MAC_ADDR11_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR11_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1482/* The address of the ALT_EMAC_GMAC_MAC_ADDR12_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1483#define ALT_EMAC1_GMAC_MAC_ADDR12_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR12_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1484/* The address of the ALT_EMAC_GMAC_MAC_ADDR12_LOW register for the ALT_EMAC1_GMACGRP instance. */
1485#define ALT_EMAC1_GMAC_MAC_ADDR12_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR12_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1486/* The address of the ALT_EMAC_GMAC_MAC_ADDR13_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1487#define ALT_EMAC1_GMAC_MAC_ADDR13_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR13_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1488/* The address of the ALT_EMAC_GMAC_MAC_ADDR13_LOW register for the ALT_EMAC1_GMACGRP instance. */
1489#define ALT_EMAC1_GMAC_MAC_ADDR13_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR13_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1490/* The address of the ALT_EMAC_GMAC_MAC_ADDR14_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1491#define ALT_EMAC1_GMAC_MAC_ADDR14_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR14_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1492/* The address of the ALT_EMAC_GMAC_MAC_ADDR14_LOW register for the ALT_EMAC1_GMACGRP instance. */
1493#define ALT_EMAC1_GMAC_MAC_ADDR14_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR14_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1494/* The address of the ALT_EMAC_GMAC_MAC_ADDR15_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1495#define ALT_EMAC1_GMAC_MAC_ADDR15_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR15_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1496/* The address of the ALT_EMAC_GMAC_MAC_ADDR15_LOW register for the ALT_EMAC1_GMACGRP instance. */
1497#define ALT_EMAC1_GMAC_MAC_ADDR15_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR15_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1498/* The address of the ALT_EMAC_GMAC_MII_CTL_STAT register for the ALT_EMAC1_GMACGRP instance. */
1499#define ALT_EMAC1_GMAC_SGMII_RGMII_SMII_CTL_STAT_ADDR ALT_EMAC_GMAC_MII_CTL_STAT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1500/* The address of the ALT_EMAC_GMAC_MMC_CTL register for the ALT_EMAC1_GMACGRP instance. */
1501#define ALT_EMAC1_GMAC_MMC_CTL_ADDR ALT_EMAC_GMAC_MMC_CTL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1502/* The address of the ALT_EMAC_GMAC_MMC_RX_INT register for the ALT_EMAC1_GMACGRP instance. */
1503#define ALT_EMAC1_GMAC_MMC_RX_INT_ADDR ALT_EMAC_GMAC_MMC_RX_INT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1504/* The address of the ALT_EMAC_GMAC_MMC_TX_INT register for the ALT_EMAC1_GMACGRP instance. */
1505#define ALT_EMAC1_GMAC_MMC_TX_INT_ADDR ALT_EMAC_GMAC_MMC_TX_INT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1506/* The address of the ALT_EMAC_GMAC_MMC_RX_INT_MSK register for the ALT_EMAC1_GMACGRP instance. */
1507#define ALT_EMAC1_GMAC_MMC_RX_INT_MSK_ADDR ALT_EMAC_GMAC_MMC_RX_INT_MSK_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1508/* The address of the ALT_EMAC_GMAC_MMC_TX_INT_MSK register for the ALT_EMAC1_GMACGRP instance. */
1509#define ALT_EMAC1_GMAC_MMC_TX_INT_MSK_ADDR ALT_EMAC_GMAC_MMC_TX_INT_MSK_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1510/* The address of the ALT_EMAC_GMAC_TXOCTETCOUNT_GB register for the ALT_EMAC1_GMACGRP instance. */
1511#define ALT_EMAC1_GMAC_TXOCTETCOUNT_GB_ADDR ALT_EMAC_GMAC_TXOCTETCOUNT_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1512/* The address of the ALT_EMAC_GMAC_TXFRMCOUNT_GB register for the ALT_EMAC1_GMACGRP instance. */
1513#define ALT_EMAC1_GMAC_TXFRMCOUNT_GB_ADDR ALT_EMAC_GMAC_TXFRMCOUNT_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1514/* The address of the ALT_EMAC_GMAC_TXBCASTFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1515#define ALT_EMAC1_GMAC_TXBCASTFRMS_G_ADDR ALT_EMAC_GMAC_TXBCASTFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1516/* The address of the ALT_EMAC_GMAC_TXMCASTFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1517#define ALT_EMAC1_GMAC_TXMCASTFRMS_G_ADDR ALT_EMAC_GMAC_TXMCASTFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1518/* The address of the ALT_EMAC_GMAC_TX64OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1519#define ALT_EMAC1_GMAC_TX64OCTETS_GB_ADDR ALT_EMAC_GMAC_TX64OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1520/* The address of the ALT_EMAC_GMAC_TX65TO127OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1521#define ALT_EMAC1_GMAC_TX65TO127OCTETS_GB_ADDR ALT_EMAC_GMAC_TX65TO127OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1522/* The address of the ALT_EMAC_GMAC_TX128TO255OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1523#define ALT_EMAC1_GMAC_TX128TO255OCTETS_GB_ADDR ALT_EMAC_GMAC_TX128TO255OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1524/* The address of the ALT_EMAC_GMAC_TX256TO511OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1525#define ALT_EMAC1_GMAC_TX256TO511OCTETS_GB_ADDR ALT_EMAC_GMAC_TX256TO511OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1526/* The address of the ALT_EMAC_GMAC_TX512TO1023OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1527#define ALT_EMAC1_GMAC_TX512TO1023OCTETS_GB_ADDR ALT_EMAC_GMAC_TX512TO1023OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1528/* The address of the ALT_EMAC_GMAC_TX1024TOMAXOCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1529#define ALT_EMAC1_GMAC_TX1024TOMAXOCTETS_GB_ADDR ALT_EMAC_GMAC_TX1024TOMAXOCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1530/* The address of the ALT_EMAC_GMAC_TXUNICASTFRMS_GB register for the ALT_EMAC1_GMACGRP instance. */
1531#define ALT_EMAC1_GMAC_TXUNICASTFRMS_GB_ADDR ALT_EMAC_GMAC_TXUNICASTFRMS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1532/* The address of the ALT_EMAC_GMAC_TXMCASTFRMS_GB register for the ALT_EMAC1_GMACGRP instance. */
1533#define ALT_EMAC1_GMAC_TXMCASTFRMS_GB_ADDR ALT_EMAC_GMAC_TXMCASTFRMS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1534/* The address of the ALT_EMAC_GMAC_TXBCASTFRMS_GB register for the ALT_EMAC1_GMACGRP instance. */
1535#define ALT_EMAC1_GMAC_TXBCASTFRMS_GB_ADDR ALT_EMAC_GMAC_TXBCASTFRMS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1536/* The address of the ALT_EMAC_GMAC_TXUNDERFLOWERROR register for the ALT_EMAC1_GMACGRP instance. */
1537#define ALT_EMAC1_GMAC_TXUNDERFLOWERROR_ADDR ALT_EMAC_GMAC_TXUNDERFLOWERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1538/* The address of the ALT_EMAC_GMAC_TXSINGLECOL_G register for the ALT_EMAC1_GMACGRP instance. */
1539#define ALT_EMAC1_GMAC_TXSINGLECOL_G_ADDR ALT_EMAC_GMAC_TXSINGLECOL_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1540/* The address of the ALT_EMAC_GMAC_TXMULTICOL_G register for the ALT_EMAC1_GMACGRP instance. */
1541#define ALT_EMAC1_GMAC_TXMULTICOL_G_ADDR ALT_EMAC_GMAC_TXMULTICOL_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1542/* The address of the ALT_EMAC_GMAC_TXDEFERRED register for the ALT_EMAC1_GMACGRP instance. */
1543#define ALT_EMAC1_GMAC_TXDEFERRED_ADDR ALT_EMAC_GMAC_TXDEFERRED_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1544/* The address of the ALT_EMAC_GMAC_TXLATECOL register for the ALT_EMAC1_GMACGRP instance. */
1545#define ALT_EMAC1_GMAC_TXLATECOL_ADDR ALT_EMAC_GMAC_TXLATECOL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1546/* The address of the ALT_EMAC_GMAC_TXEXESSCOL register for the ALT_EMAC1_GMACGRP instance. */
1547#define ALT_EMAC1_GMAC_TXEXESSCOL_ADDR ALT_EMAC_GMAC_TXEXESSCOL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1548/* The address of the ALT_EMAC_GMAC_TXCARRIERERR register for the ALT_EMAC1_GMACGRP instance. */
1549#define ALT_EMAC1_GMAC_TXCARRIERERR_ADDR ALT_EMAC_GMAC_TXCARRIERERR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1550/* The address of the ALT_EMAC_GMAC_TXOCTETCNT register for the ALT_EMAC1_GMACGRP instance. */
1551#define ALT_EMAC1_GMAC_TXOCTETCNT_ADDR ALT_EMAC_GMAC_TXOCTETCNT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1552/* The address of the ALT_EMAC_GMAC_TXFRMCOUNT_G register for the ALT_EMAC1_GMACGRP instance. */
1553#define ALT_EMAC1_GMAC_TXFRMCOUNT_G_ADDR ALT_EMAC_GMAC_TXFRMCOUNT_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1554/* The address of the ALT_EMAC_GMAC_TXEXCESSDEF register for the ALT_EMAC1_GMACGRP instance. */
1555#define ALT_EMAC1_GMAC_TXEXCESSDEF_ADDR ALT_EMAC_GMAC_TXEXCESSDEF_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1556/* The address of the ALT_EMAC_GMAC_TXPAUSEFRMS register for the ALT_EMAC1_GMACGRP instance. */
1557#define ALT_EMAC1_GMAC_TXPAUSEFRMS_ADDR ALT_EMAC_GMAC_TXPAUSEFRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1558/* The address of the ALT_EMAC_GMAC_TXVLANFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1559#define ALT_EMAC1_GMAC_TXVLANFRMS_G_ADDR ALT_EMAC_GMAC_TXVLANFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1560/* The address of the ALT_EMAC_GMAC_TXOVERSIZE_G register for the ALT_EMAC1_GMACGRP instance. */
1561#define ALT_EMAC1_GMAC_TXOVERSIZE_G_ADDR ALT_EMAC_GMAC_TXOVERSIZE_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1562/* The address of the ALT_EMAC_GMAC_RXFRMCOUNT_GB register for the ALT_EMAC1_GMACGRP instance. */
1563#define ALT_EMAC1_GMAC_RXFRMCOUNT_GB_ADDR ALT_EMAC_GMAC_RXFRMCOUNT_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1564/* The address of the ALT_EMAC_GMAC_RXOCTETCOUNT_GB register for the ALT_EMAC1_GMACGRP instance. */
1565#define ALT_EMAC1_GMAC_RXOCTETCOUNT_GB_ADDR ALT_EMAC_GMAC_RXOCTETCOUNT_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1566/* The address of the ALT_EMAC_GMAC_RXOCTETCOUNT_G register for the ALT_EMAC1_GMACGRP instance. */
1567#define ALT_EMAC1_GMAC_RXOCTETCOUNT_G_ADDR ALT_EMAC_GMAC_RXOCTETCOUNT_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1568/* The address of the ALT_EMAC_GMAC_RXBCASTFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1569#define ALT_EMAC1_GMAC_RXBCASTFRMS_G_ADDR ALT_EMAC_GMAC_RXBCASTFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1570/* The address of the ALT_EMAC_GMAC_RXMCASTFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1571#define ALT_EMAC1_GMAC_RXMCASTFRMS_G_ADDR ALT_EMAC_GMAC_RXMCASTFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1572/* The address of the ALT_EMAC_GMAC_RXCRCERROR register for the ALT_EMAC1_GMACGRP instance. */
1573#define ALT_EMAC1_GMAC_RXCRCERROR_ADDR ALT_EMAC_GMAC_RXCRCERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1574/* The address of the ALT_EMAC_GMAC_RXALIGNMENTERROR register for the ALT_EMAC1_GMACGRP instance. */
1575#define ALT_EMAC1_GMAC_RXALIGNMENTERROR_ADDR ALT_EMAC_GMAC_RXALIGNMENTERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1576/* The address of the ALT_EMAC_GMAC_RXRUNTERROR register for the ALT_EMAC1_GMACGRP instance. */
1577#define ALT_EMAC1_GMAC_RXRUNTERROR_ADDR ALT_EMAC_GMAC_RXRUNTERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1578/* The address of the ALT_EMAC_GMAC_RXJABBERERROR register for the ALT_EMAC1_GMACGRP instance. */
1579#define ALT_EMAC1_GMAC_RXJABBERERROR_ADDR ALT_EMAC_GMAC_RXJABBERERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1580/* The address of the ALT_EMAC_GMAC_RXUNDERSIZE_G register for the ALT_EMAC1_GMACGRP instance. */
1581#define ALT_EMAC1_GMAC_RXUNDERSIZE_G_ADDR ALT_EMAC_GMAC_RXUNDERSIZE_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1582/* The address of the ALT_EMAC_GMAC_RXOVERSIZE_G register for the ALT_EMAC1_GMACGRP instance. */
1583#define ALT_EMAC1_GMAC_RXOVERSIZE_G_ADDR ALT_EMAC_GMAC_RXOVERSIZE_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1584/* The address of the ALT_EMAC_GMAC_RX64OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1585#define ALT_EMAC1_GMAC_RX64OCTETS_GB_ADDR ALT_EMAC_GMAC_RX64OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1586/* The address of the ALT_EMAC_GMAC_RX65TO127OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1587#define ALT_EMAC1_GMAC_RX65TO127OCTETS_GB_ADDR ALT_EMAC_GMAC_RX65TO127OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1588/* The address of the ALT_EMAC_GMAC_RX128TO255OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1589#define ALT_EMAC1_GMAC_RX128TO255OCTETS_GB_ADDR ALT_EMAC_GMAC_RX128TO255OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1590/* The address of the ALT_EMAC_GMAC_RX256TO511OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1591#define ALT_EMAC1_GMAC_RX256TO511OCTETS_GB_ADDR ALT_EMAC_GMAC_RX256TO511OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1592/* The address of the ALT_EMAC_GMAC_RX512TO1023OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1593#define ALT_EMAC1_GMAC_RX512TO1023OCTETS_GB_ADDR ALT_EMAC_GMAC_RX512TO1023OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1594/* The address of the ALT_EMAC_GMAC_RX1024TOMAXOCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1595#define ALT_EMAC1_GMAC_RX1024TOMAXOCTETS_GB_ADDR ALT_EMAC_GMAC_RX1024TOMAXOCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1596/* The address of the ALT_EMAC_GMAC_RXUNICASTFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1597#define ALT_EMAC1_GMAC_RXUNICASTFRMS_G_ADDR ALT_EMAC_GMAC_RXUNICASTFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1598/* The address of the ALT_EMAC_GMAC_RXLENERROR register for the ALT_EMAC1_GMACGRP instance. */
1599#define ALT_EMAC1_GMAC_RXLENERROR_ADDR ALT_EMAC_GMAC_RXLENERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1600/* The address of the ALT_EMAC_GMAC_RXOUTOFRANGETYPE register for the ALT_EMAC1_GMACGRP instance. */
1601#define ALT_EMAC1_GMAC_RXOUTOFRANGETYPE_ADDR ALT_EMAC_GMAC_RXOUTOFRANGETYPE_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1602/* The address of the ALT_EMAC_GMAC_RXPAUSEFRMS register for the ALT_EMAC1_GMACGRP instance. */
1603#define ALT_EMAC1_GMAC_RXPAUSEFRMS_ADDR ALT_EMAC_GMAC_RXPAUSEFRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1604/* The address of the ALT_EMAC_GMAC_RXFIFOOVF register for the ALT_EMAC1_GMACGRP instance. */
1605#define ALT_EMAC1_GMAC_RXFIFOOVF_ADDR ALT_EMAC_GMAC_RXFIFOOVF_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1606/* The address of the ALT_EMAC_GMAC_RXVLANFRMS_GB register for the ALT_EMAC1_GMACGRP instance. */
1607#define ALT_EMAC1_GMAC_RXVLANFRMS_GB_ADDR ALT_EMAC_GMAC_RXVLANFRMS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1608/* The address of the ALT_EMAC_GMAC_RXWDERROR register for the ALT_EMAC1_GMACGRP instance. */
1609#define ALT_EMAC1_GMAC_RXWDERROR_ADDR ALT_EMAC_GMAC_RXWDERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1610/* The address of the ALT_EMAC_GMAC_RXRCVERROR register for the ALT_EMAC1_GMACGRP instance. */
1611#define ALT_EMAC1_GMAC_RXRCVERROR_ADDR ALT_EMAC_GMAC_RXRCVERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1612/* The address of the ALT_EMAC_GMAC_RXCTLFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1613#define ALT_EMAC1_GMAC_RXCTLFRMS_G_ADDR ALT_EMAC_GMAC_RXCTLFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1614/* The address of the ALT_EMAC_GMAC_MMC_IPC_RX_INT_MSK register for the ALT_EMAC1_GMACGRP instance. */
1615#define ALT_EMAC1_GMAC_MMC_IPC_RX_INT_MSK_ADDR ALT_EMAC_GMAC_MMC_IPC_RX_INT_MSK_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1616/* The address of the ALT_EMAC_GMAC_MMC_IPC_RX_INT register for the ALT_EMAC1_GMACGRP instance. */
1617#define ALT_EMAC1_GMAC_MMC_IPC_RX_INT_ADDR ALT_EMAC_GMAC_MMC_IPC_RX_INT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1618/* The address of the ALT_EMAC_GMAC_RXIPV4_GD_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1619#define ALT_EMAC1_GMAC_RXIPV4_GD_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_GD_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1620/* The address of the ALT_EMAC_GMAC_RXIPV4_HDRERR_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1621#define ALT_EMAC1_GMAC_RXIPV4_HDRERR_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_HDRERR_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1622/* The address of the ALT_EMAC_GMAC_RXIPV4_NOPAY_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1623#define ALT_EMAC1_GMAC_RXIPV4_NOPAY_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_NOPAY_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1624/* The address of the ALT_EMAC_GMAC_RXIPV4_FRAG_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1625#define ALT_EMAC1_GMAC_RXIPV4_FRAG_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_FRAG_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1626/* The address of the ALT_EMAC_GMAC_RXIPV4_UDSBL_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1627#define ALT_EMAC1_GMAC_RXIPV4_UDSBL_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_UDSBL_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1628/* The address of the ALT_EMAC_GMAC_RXIPV6_GD_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1629#define ALT_EMAC1_GMAC_RXIPV6_GD_FRMS_ADDR ALT_EMAC_GMAC_RXIPV6_GD_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1630/* The address of the ALT_EMAC_GMAC_RXIPV6_HDRERR_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1631#define ALT_EMAC1_GMAC_RXIPV6_HDRERR_FRMS_ADDR ALT_EMAC_GMAC_RXIPV6_HDRERR_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1632/* The address of the ALT_EMAC_GMAC_RXIPV6_NOPAY_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1633#define ALT_EMAC1_GMAC_RXIPV6_NOPAY_FRMS_ADDR ALT_EMAC_GMAC_RXIPV6_NOPAY_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1634/* The address of the ALT_EMAC_GMAC_RXUDP_GD_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1635#define ALT_EMAC1_GMAC_RXUDP_GD_FRMS_ADDR ALT_EMAC_GMAC_RXUDP_GD_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1636/* The address of the ALT_EMAC_GMAC_RXUDP_ERR_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1637#define ALT_EMAC1_GMAC_RXUDP_ERR_FRMS_ADDR ALT_EMAC_GMAC_RXUDP_ERR_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1638/* The address of the ALT_EMAC_GMAC_RXTCP_GD_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1639#define ALT_EMAC1_GMAC_RXTCP_GD_FRMS_ADDR ALT_EMAC_GMAC_RXTCP_GD_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1640/* The address of the ALT_EMAC_GMAC_RXTCP_ERR_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1641#define ALT_EMAC1_GMAC_RXTCP_ERR_FRMS_ADDR ALT_EMAC_GMAC_RXTCP_ERR_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1642/* The address of the ALT_EMAC_GMAC_RXICMP_GD_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1643#define ALT_EMAC1_GMAC_RXICMP_GD_FRMS_ADDR ALT_EMAC_GMAC_RXICMP_GD_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1644/* The address of the ALT_EMAC_GMAC_RXICMP_ERR_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1645#define ALT_EMAC1_GMAC_RXICMP_ERR_FRMS_ADDR ALT_EMAC_GMAC_RXICMP_ERR_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1646/* The address of the ALT_EMAC_GMAC_RXIPV4_GD_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1647#define ALT_EMAC1_GMAC_RXIPV4_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_GD_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1648/* The address of the ALT_EMAC_GMAC_RXIPV4_HDRERR_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1649#define ALT_EMAC1_GMAC_RXIPV4_HDRERR_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_HDRERR_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1650/* The address of the ALT_EMAC_GMAC_RXIPV4_NOPAY_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1651#define ALT_EMAC1_GMAC_RXIPV4_NOPAY_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_NOPAY_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1652/* The address of the ALT_EMAC_GMAC_RXIPV4_FRAG_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1653#define ALT_EMAC1_GMAC_RXIPV4_FRAG_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_FRAG_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1654/* The address of the ALT_EMAC_GMAC_RXIPV4_UDSBL_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1655#define ALT_EMAC1_GMAC_RXIPV4_UDSBL_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_UDSBL_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1656/* The address of the ALT_EMAC_GMAC_RXIPV6_GD_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1657#define ALT_EMAC1_GMAC_RXIPV6_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV6_GD_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1658/* The address of the ALT_EMAC_GMAC_RXIPV6_HDRERR_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1659#define ALT_EMAC1_GMAC_RXIPV6_HDRERR_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV6_HDRERR_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1660/* The address of the ALT_EMAC_GMAC_RXIPV6_NOPAY_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1661#define ALT_EMAC1_GMAC_RXIPV6_NOPAY_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV6_NOPAY_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1662/* The address of the ALT_EMAC_GMAC_RXUDP_GD_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1663#define ALT_EMAC1_GMAC_RXUDP_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXUDP_GD_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1664/* The address of the ALT_EMAC_GMAC_RXUDP_ERR_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1665#define ALT_EMAC1_GMAC_RXUDP_ERR_OCTETS_ADDR ALT_EMAC_GMAC_RXUDP_ERR_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1666/* The address of the ALT_EMAC_GMAC_RXTCP_GD_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1667#define ALT_EMAC1_GMAC_RXTCP_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXTCP_GD_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1668/* The address of the ALT_EMAC_GMAC_RXTCPERROCTETS register for the ALT_EMAC1_GMACGRP instance. */
1669#define ALT_EMAC1_GMAC_RXTCPERROCTETS_ADDR ALT_EMAC_GMAC_RXTCPERROCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1670/* The address of the ALT_EMAC_GMAC_RXICMP_GD_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1671#define ALT_EMAC1_GMAC_RXICMP_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXICMP_GD_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1672/* The address of the ALT_EMAC_GMAC_RXICMP_ERR_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1673#define ALT_EMAC1_GMAC_RXICMP_ERR_OCTETS_ADDR ALT_EMAC_GMAC_RXICMP_ERR_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1674/* The address of the ALT_EMAC_GMAC_L3_L4_CTL0 register for the ALT_EMAC1_GMACGRP instance. */
1675#define ALT_EMAC1_GMAC_L3_L4_CTL0_ADDR ALT_EMAC_GMAC_L3_L4_CTL0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1676/* The address of the ALT_EMAC_GMAC_LYR4_ADDR0 register for the ALT_EMAC1_GMACGRP instance. */
1677#define ALT_EMAC1_GMAC_LYR4_ADDR0_ADDR ALT_EMAC_GMAC_LYR4_ADDR0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1678/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG0 register for the ALT_EMAC1_GMACGRP instance. */
1679#define ALT_EMAC1_GMAC_LYR3_ADDR0_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1680/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG0 register for the ALT_EMAC1_GMACGRP instance. */
1681#define ALT_EMAC1_GMAC_LYR3_ADDR1_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1682/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG0 register for the ALT_EMAC1_GMACGRP instance. */
1683#define ALT_EMAC1_GMAC_LYR3_ADDR2_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1684/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG0 register for the ALT_EMAC1_GMACGRP instance. */
1685#define ALT_EMAC1_GMAC_LYR3_ADDR3_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1686/* The address of the ALT_EMAC_GMAC_L3_L4_CTL1 register for the ALT_EMAC1_GMACGRP instance. */
1687#define ALT_EMAC1_GMAC_L3_L4_CTL1_ADDR ALT_EMAC_GMAC_L3_L4_CTL1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1688/* The address of the ALT_EMAC_GMAC_LYR4_ADDR1 register for the ALT_EMAC1_GMACGRP instance. */
1689#define ALT_EMAC1_GMAC_LYR4_ADDR1_ADDR ALT_EMAC_GMAC_LYR4_ADDR1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1690/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG1 register for the ALT_EMAC1_GMACGRP instance. */
1691#define ALT_EMAC1_GMAC_LYR3_ADDR0_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1692/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG1 register for the ALT_EMAC1_GMACGRP instance. */
1693#define ALT_EMAC1_GMAC_LYR3_ADDR1_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1694/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG1 register for the ALT_EMAC1_GMACGRP instance. */
1695#define ALT_EMAC1_GMAC_LYR3_ADDR2_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1696/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG1 register for the ALT_EMAC1_GMACGRP instance. */
1697#define ALT_EMAC1_GMAC_LYR3_ADDR3_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1698/* The address of the ALT_EMAC_GMAC_L3_L4_CTL2 register for the ALT_EMAC1_GMACGRP instance. */
1699#define ALT_EMAC1_GMAC_L3_L4_CTL2_ADDR ALT_EMAC_GMAC_L3_L4_CTL2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1700/* The address of the ALT_EMAC_GMAC_LYR4_ADDR2 register for the ALT_EMAC1_GMACGRP instance. */
1701#define ALT_EMAC1_GMAC_LYR4_ADDR2_ADDR ALT_EMAC_GMAC_LYR4_ADDR2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1702/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG2 register for the ALT_EMAC1_GMACGRP instance. */
1703#define ALT_EMAC1_GMAC_LYR3_ADDR0_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1704/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG2 register for the ALT_EMAC1_GMACGRP instance. */
1705#define ALT_EMAC1_GMAC_LYR3_ADDR1_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1706/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG2 register for the ALT_EMAC1_GMACGRP instance. */
1707#define ALT_EMAC1_GMAC_LYR3_ADDR2_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1708/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG2 register for the ALT_EMAC1_GMACGRP instance. */
1709#define ALT_EMAC1_GMAC_LYR3_ADDR3_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1710/* The address of the ALT_EMAC_GMAC_L3_L4_CTL3 register for the ALT_EMAC1_GMACGRP instance. */
1711#define ALT_EMAC1_GMAC_L3_L4_CTL3_ADDR ALT_EMAC_GMAC_L3_L4_CTL3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1712/* The address of the ALT_EMAC_GMAC_LYR4_ADDR3 register for the ALT_EMAC1_GMACGRP instance. */
1713#define ALT_EMAC1_GMAC_LYR4_ADDR3_ADDR ALT_EMAC_GMAC_LYR4_ADDR3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1714/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG3 register for the ALT_EMAC1_GMACGRP instance. */
1715#define ALT_EMAC1_GMAC_LYR3_ADDR0_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1716/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG3 register for the ALT_EMAC1_GMACGRP instance. */
1717#define ALT_EMAC1_GMAC_LYR3_ADDR1_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1718/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG3 register for the ALT_EMAC1_GMACGRP instance. */
1719#define ALT_EMAC1_GMAC_LYR3_ADDR2_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1720/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG3 register for the ALT_EMAC1_GMACGRP instance. */
1721#define ALT_EMAC1_GMAC_LYR3_ADDR3_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1722/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG0 register for the ALT_EMAC1_GMACGRP instance. */
1723#define ALT_EMAC1_GMAC_HASH_TABLE_REG0_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1724/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG1 register for the ALT_EMAC1_GMACGRP instance. */
1725#define ALT_EMAC1_GMAC_HASH_TABLE_REG1_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1726/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG2 register for the ALT_EMAC1_GMACGRP instance. */
1727#define ALT_EMAC1_GMAC_HASH_TABLE_REG2_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1728/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG3 register for the ALT_EMAC1_GMACGRP instance. */
1729#define ALT_EMAC1_GMAC_HASH_TABLE_REG3_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1730/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG4 register for the ALT_EMAC1_GMACGRP instance. */
1731#define ALT_EMAC1_GMAC_HASH_TABLE_REG4_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG4_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1732/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG5 register for the ALT_EMAC1_GMACGRP instance. */
1733#define ALT_EMAC1_GMAC_HASH_TABLE_REG5_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG5_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1734/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG6 register for the ALT_EMAC1_GMACGRP instance. */
1735#define ALT_EMAC1_GMAC_HASH_TABLE_REG6_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG6_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1736/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG7 register for the ALT_EMAC1_GMACGRP instance. */
1737#define ALT_EMAC1_GMAC_HASH_TABLE_REG7_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG7_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1738/* The address of the ALT_EMAC_GMAC_VLAN_INCL_REG register for the ALT_EMAC1_GMACGRP instance. */
1739#define ALT_EMAC1_GMAC_VLAN_INCL_REG_ADDR ALT_EMAC_GMAC_VLAN_INCL_REG_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1740/* The address of the ALT_EMAC_GMAC_VLAN_HASH_TABLE_REG register for the ALT_EMAC1_GMACGRP instance. */
1741#define ALT_EMAC1_GMAC_VLAN_HASH_TABLE_REG_ADDR ALT_EMAC_GMAC_VLAN_HASH_TABLE_REG_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1742/* The address of the ALT_EMAC_GMAC_TS_CTL register for the ALT_EMAC1_GMACGRP instance. */
1743#define ALT_EMAC1_GMAC_TS_CTL_ADDR ALT_EMAC_GMAC_TS_CTL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1744/* The address of the ALT_EMAC_GMAC_SUB_SEC_INCREMENT register for the ALT_EMAC1_GMACGRP instance. */
1745#define ALT_EMAC1_GMAC_SUB_SEC_INCREMENT_ADDR ALT_EMAC_GMAC_SUB_SEC_INCREMENT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1746/* The address of the ALT_EMAC_GMAC_SYS_TIME_SECS register for the ALT_EMAC1_GMACGRP instance. */
1747#define ALT_EMAC1_GMAC_SYS_TIME_SECS_ADDR ALT_EMAC_GMAC_SYS_TIME_SECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1748/* The address of the ALT_EMAC_GMAC_SYS_TIME_NANOSECS register for the ALT_EMAC1_GMACGRP instance. */
1749#define ALT_EMAC1_GMAC_SYS_TIME_NANOSECS_ADDR ALT_EMAC_GMAC_SYS_TIME_NANOSECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1750/* The address of the ALT_EMAC_GMAC_SYS_TIME_SECS_UPDATE register for the ALT_EMAC1_GMACGRP instance. */
1751#define ALT_EMAC1_GMAC_SYS_TIME_SECS_UPDATE_ADDR ALT_EMAC_GMAC_SYS_TIME_SECS_UPDATE_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1752/* The address of the ALT_EMAC_GMAC_SYS_TIME_NANOSECS_UPDATE register for the ALT_EMAC1_GMACGRP instance. */
1753#define ALT_EMAC1_GMAC_SYS_TIME_NANOSECS_UPDATE_ADDR ALT_EMAC_GMAC_SYS_TIME_NANOSECS_UPDATE_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1754/* The address of the ALT_EMAC_GMAC_TS_ADDEND register for the ALT_EMAC1_GMACGRP instance. */
1755#define ALT_EMAC1_GMAC_TS_ADDEND_ADDR ALT_EMAC_GMAC_TS_ADDEND_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1756/* The address of the ALT_EMAC_GMAC_TGT_TIME_SECS register for the ALT_EMAC1_GMACGRP instance. */
1757#define ALT_EMAC1_GMAC_TGT_TIME_SECS_ADDR ALT_EMAC_GMAC_TGT_TIME_SECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1758/* The address of the ALT_EMAC_GMAC_TGT_TIME_NANOSECS register for the ALT_EMAC1_GMACGRP instance. */
1759#define ALT_EMAC1_GMAC_TGT_TIME_NANOSECS_ADDR ALT_EMAC_GMAC_TGT_TIME_NANOSECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1760/* The address of the ALT_EMAC_GMAC_SYS_TIME_HIGHER_WORD_SECS register for the ALT_EMAC1_GMACGRP instance. */
1761#define ALT_EMAC1_GMAC_SYS_TIME_HIGHER_WORD_SECS_ADDR ALT_EMAC_GMAC_SYS_TIME_HIGHER_WORD_SECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1762/* The address of the ALT_EMAC_GMAC_TS_STAT register for the ALT_EMAC1_GMACGRP instance. */
1763#define ALT_EMAC1_GMAC_TS_STAT_ADDR ALT_EMAC_GMAC_TS_STAT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1764/* The address of the ALT_EMAC_GMAC_PPS_CTL register for the ALT_EMAC1_GMACGRP instance. */
1765#define ALT_EMAC1_GMAC_PPS_CTL_ADDR ALT_EMAC_GMAC_PPS_CTL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1766/* The address of the ALT_EMAC_GMAC_AUX_TS_NANOSECS register for the ALT_EMAC1_GMACGRP instance. */
1767#define ALT_EMAC1_GMAC_AUX_TS_NANOSECS_ADDR ALT_EMAC_GMAC_AUX_TS_NANOSECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1768/* The address of the ALT_EMAC_GMAC_AUX_TS_SECS register for the ALT_EMAC1_GMACGRP instance. */
1769#define ALT_EMAC1_GMAC_AUX_TS_SECS_ADDR ALT_EMAC_GMAC_AUX_TS_SECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1770/* The address of the ALT_EMAC_GMAC_PPS0_INTERVAL register for the ALT_EMAC1_GMACGRP instance. */
1771#define ALT_EMAC1_GMAC_PPS0_INTERVAL_ADDR ALT_EMAC_GMAC_PPS0_INTERVAL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1772/* The address of the ALT_EMAC_GMAC_PPS0_WIDTH register for the ALT_EMAC1_GMACGRP instance. */
1773#define ALT_EMAC1_GMAC_PPS0_WIDTH_ADDR ALT_EMAC_GMAC_PPS0_WIDTH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1774/* The address of the ALT_EMAC_GMAC_MAC_ADDR16_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1775#define ALT_EMAC1_GMAC_MAC_ADDR16_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR16_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1776/* The address of the ALT_EMAC_GMAC_MAC_ADDR16_LOW register for the ALT_EMAC1_GMACGRP instance. */
1777#define ALT_EMAC1_GMAC_MAC_ADDR16_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR16_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1778/* The address of the ALT_EMAC_GMAC_MAC_ADDR17_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1779#define ALT_EMAC1_GMAC_MAC_ADDR17_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR17_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1780/* The address of the ALT_EMAC_GMAC_MAC_ADDR17_LOW register for the ALT_EMAC1_GMACGRP instance. */
1781#define ALT_EMAC1_GMAC_MAC_ADDR17_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR17_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1782/* The address of the ALT_EMAC_GMAC_MAC_ADDR18_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1783#define ALT_EMAC1_GMAC_MAC_ADDR18_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR18_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1784/* The address of the ALT_EMAC_GMAC_MAC_ADDR18_LOW register for the ALT_EMAC1_GMACGRP instance. */
1785#define ALT_EMAC1_GMAC_MAC_ADDR18_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR18_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1786/* The address of the ALT_EMAC_GMAC_MAC_ADDR19_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1787#define ALT_EMAC1_GMAC_MAC_ADDR19_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR19_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1788/* The address of the ALT_EMAC_GMAC_MAC_ADDR19_LOW register for the ALT_EMAC1_GMACGRP instance. */
1789#define ALT_EMAC1_GMAC_MAC_ADDR19_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR19_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1790/* The address of the ALT_EMAC_GMAC_MAC_ADDR20_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1791#define ALT_EMAC1_GMAC_MAC_ADDR20_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR20_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1792/* The address of the ALT_EMAC_GMAC_MAC_ADDR20_LOW register for the ALT_EMAC1_GMACGRP instance. */
1793#define ALT_EMAC1_GMAC_MAC_ADDR20_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR20_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1794/* The address of the ALT_EMAC_GMAC_MAC_ADDR21_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1795#define ALT_EMAC1_GMAC_MAC_ADDR21_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR21_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1796/* The address of the ALT_EMAC_GMAC_MAC_ADDR21_LOW register for the ALT_EMAC1_GMACGRP instance. */
1797#define ALT_EMAC1_GMAC_MAC_ADDR21_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR21_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1798/* The address of the ALT_EMAC_GMAC_MAC_ADDR22_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1799#define ALT_EMAC1_GMAC_MAC_ADDR22_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR22_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1800/* The address of the ALT_EMAC_GMAC_MAC_ADDR22_LOW register for the ALT_EMAC1_GMACGRP instance. */
1801#define ALT_EMAC1_GMAC_MAC_ADDR22_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR22_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1802/* The address of the ALT_EMAC_GMAC_MAC_ADDR23_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1803#define ALT_EMAC1_GMAC_MAC_ADDR23_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR23_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1804/* The address of the ALT_EMAC_GMAC_MAC_ADDR23_LOW register for the ALT_EMAC1_GMACGRP instance. */
1805#define ALT_EMAC1_GMAC_MAC_ADDR23_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR23_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1806/* The address of the ALT_EMAC_GMAC_MAC_ADDR24_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1807#define ALT_EMAC1_GMAC_MAC_ADDR24_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR24_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1808/* The address of the ALT_EMAC_GMAC_MAC_ADDR24_LOW register for the ALT_EMAC1_GMACGRP instance. */
1809#define ALT_EMAC1_GMAC_MAC_ADDR24_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR24_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1810/* The address of the ALT_EMAC_GMAC_MAC_ADDR25_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1811#define ALT_EMAC1_GMAC_MAC_ADDR25_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR25_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1812/* The address of the ALT_EMAC_GMAC_MAC_ADDR25_LOW register for the ALT_EMAC1_GMACGRP instance. */
1813#define ALT_EMAC1_GMAC_MAC_ADDR25_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR25_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1814/* The address of the ALT_EMAC_GMAC_MAC_ADDR26_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1815#define ALT_EMAC1_GMAC_MAC_ADDR26_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR26_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1816/* The address of the ALT_EMAC_GMAC_MAC_ADDR26_LOW register for the ALT_EMAC1_GMACGRP instance. */
1817#define ALT_EMAC1_GMAC_MAC_ADDR26_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR26_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1818/* The address of the ALT_EMAC_GMAC_MAC_ADDR27_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1819#define ALT_EMAC1_GMAC_MAC_ADDR27_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR27_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1820/* The address of the ALT_EMAC_GMAC_MAC_ADDR27_LOW register for the ALT_EMAC1_GMACGRP instance. */
1821#define ALT_EMAC1_GMAC_MAC_ADDR27_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR27_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1822/* The address of the ALT_EMAC_GMAC_MAC_ADDR28_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1823#define ALT_EMAC1_GMAC_MAC_ADDR28_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR28_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1824/* The address of the ALT_EMAC_GMAC_MAC_ADDR28_LOW register for the ALT_EMAC1_GMACGRP instance. */
1825#define ALT_EMAC1_GMAC_MAC_ADDR28_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR28_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1826/* The address of the ALT_EMAC_GMAC_MAC_ADDR29_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1827#define ALT_EMAC1_GMAC_MAC_ADDR29_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR29_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1828/* The address of the ALT_EMAC_GMAC_MAC_ADDR29_LOW register for the ALT_EMAC1_GMACGRP instance. */
1829#define ALT_EMAC1_GMAC_MAC_ADDR29_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR29_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1830/* The address of the ALT_EMAC_GMAC_MAC_ADDR30_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1831#define ALT_EMAC1_GMAC_MAC_ADDR30_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR30_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1832/* The address of the ALT_EMAC_GMAC_MAC_ADDR30_LOW register for the ALT_EMAC1_GMACGRP instance. */
1833#define ALT_EMAC1_GMAC_MAC_ADDR30_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR30_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1834/* The address of the ALT_EMAC_GMAC_MAC_ADDR31_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1835#define ALT_EMAC1_GMAC_MAC_ADDR31_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR31_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1836/* The address of the ALT_EMAC_GMAC_MAC_ADDR31_LOW register for the ALT_EMAC1_GMACGRP instance. */
1837#define ALT_EMAC1_GMAC_MAC_ADDR31_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR31_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1838/* The address of the ALT_EMAC_GMAC_MAC_ADDR32_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1839#define ALT_EMAC1_GMAC_MAC_ADDR32_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR32_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1840/* The address of the ALT_EMAC_GMAC_MAC_ADDR32_LOW register for the ALT_EMAC1_GMACGRP instance. */
1841#define ALT_EMAC1_GMAC_MAC_ADDR32_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR32_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1842/* The address of the ALT_EMAC_GMAC_MAC_ADDR33_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1843#define ALT_EMAC1_GMAC_MAC_ADDR33_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR33_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1844/* The address of the ALT_EMAC_GMAC_MAC_ADDR33_LOW register for the ALT_EMAC1_GMACGRP instance. */
1845#define ALT_EMAC1_GMAC_MAC_ADDR33_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR33_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1846/* The address of the ALT_EMAC_GMAC_MAC_ADDR34_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1847#define ALT_EMAC1_GMAC_MAC_ADDR34_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR34_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1848/* The address of the ALT_EMAC_GMAC_MAC_ADDR34_LOW register for the ALT_EMAC1_GMACGRP instance. */
1849#define ALT_EMAC1_GMAC_MAC_ADDR34_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR34_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1850/* The address of the ALT_EMAC_GMAC_MAC_ADDR35_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1851#define ALT_EMAC1_GMAC_MAC_ADDR35_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR35_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1852/* The address of the ALT_EMAC_GMAC_MAC_ADDR35_LOW register for the ALT_EMAC1_GMACGRP instance. */
1853#define ALT_EMAC1_GMAC_MAC_ADDR35_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR35_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1854/* The address of the ALT_EMAC_GMAC_MAC_ADDR36_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1855#define ALT_EMAC1_GMAC_MAC_ADDR36_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR36_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1856/* The address of the ALT_EMAC_GMAC_MAC_ADDR36_LOW register for the ALT_EMAC1_GMACGRP instance. */
1857#define ALT_EMAC1_GMAC_MAC_ADDR36_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR36_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1858/* The address of the ALT_EMAC_GMAC_MAC_ADDR37_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1859#define ALT_EMAC1_GMAC_MAC_ADDR37_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR37_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1860/* The address of the ALT_EMAC_GMAC_MAC_ADDR37_LOW register for the ALT_EMAC1_GMACGRP instance. */
1861#define ALT_EMAC1_GMAC_MAC_ADDR37_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR37_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1862/* The address of the ALT_EMAC_GMAC_MAC_ADDR38_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1863#define ALT_EMAC1_GMAC_MAC_ADDR38_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR38_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1864/* The address of the ALT_EMAC_GMAC_MAC_ADDR38_LOW register for the ALT_EMAC1_GMACGRP instance. */
1865#define ALT_EMAC1_GMAC_MAC_ADDR38_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR38_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1866/* The address of the ALT_EMAC_GMAC_MAC_ADDR39_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1867#define ALT_EMAC1_GMAC_MAC_ADDR39_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR39_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1868/* The address of the ALT_EMAC_GMAC_MAC_ADDR39_LOW register for the ALT_EMAC1_GMACGRP instance. */
1869#define ALT_EMAC1_GMAC_MAC_ADDR39_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR39_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1870/* The address of the ALT_EMAC_GMAC_MAC_ADDR40_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1871#define ALT_EMAC1_GMAC_MAC_ADDR40_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR40_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1872/* The address of the ALT_EMAC_GMAC_MAC_ADDR40_LOW register for the ALT_EMAC1_GMACGRP instance. */
1873#define ALT_EMAC1_GMAC_MAC_ADDR40_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR40_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1874/* The address of the ALT_EMAC_GMAC_MAC_ADDR41_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1875#define ALT_EMAC1_GMAC_MAC_ADDR41_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR41_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1876/* The address of the ALT_EMAC_GMAC_MAC_ADDR41_LOW register for the ALT_EMAC1_GMACGRP instance. */
1877#define ALT_EMAC1_GMAC_MAC_ADDR41_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR41_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1878/* The address of the ALT_EMAC_GMAC_MAC_ADDR42_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1879#define ALT_EMAC1_GMAC_MAC_ADDR42_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR42_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1880/* The address of the ALT_EMAC_GMAC_MAC_ADDR42_LOW register for the ALT_EMAC1_GMACGRP instance. */
1881#define ALT_EMAC1_GMAC_MAC_ADDR42_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR42_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1882/* The address of the ALT_EMAC_GMAC_MAC_ADDR43_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1883#define ALT_EMAC1_GMAC_MAC_ADDR43_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR43_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1884/* The address of the ALT_EMAC_GMAC_MAC_ADDR43_LOW register for the ALT_EMAC1_GMACGRP instance. */
1885#define ALT_EMAC1_GMAC_MAC_ADDR43_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR43_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1886/* The address of the ALT_EMAC_GMAC_MAC_ADDR44_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1887#define ALT_EMAC1_GMAC_MAC_ADDR44_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR44_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1888/* The address of the ALT_EMAC_GMAC_MAC_ADDR44_LOW register for the ALT_EMAC1_GMACGRP instance. */
1889#define ALT_EMAC1_GMAC_MAC_ADDR44_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR44_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1890/* The address of the ALT_EMAC_GMAC_MAC_ADDR45_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1891#define ALT_EMAC1_GMAC_MAC_ADDR45_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR45_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1892/* The address of the ALT_EMAC_GMAC_MAC_ADDR45_LOW register for the ALT_EMAC1_GMACGRP instance. */
1893#define ALT_EMAC1_GMAC_MAC_ADDR45_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR45_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1894/* The address of the ALT_EMAC_GMAC_MAC_ADDR46_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1895#define ALT_EMAC1_GMAC_MAC_ADDR46_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR46_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1896/* The address of the ALT_EMAC_GMAC_MAC_ADDR46_LOW register for the ALT_EMAC1_GMACGRP instance. */
1897#define ALT_EMAC1_GMAC_MAC_ADDR46_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR46_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1898/* The address of the ALT_EMAC_GMAC_MAC_ADDR47_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1899#define ALT_EMAC1_GMAC_MAC_ADDR47_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR47_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1900/* The address of the ALT_EMAC_GMAC_MAC_ADDR47_LOW register for the ALT_EMAC1_GMACGRP instance. */
1901#define ALT_EMAC1_GMAC_MAC_ADDR47_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR47_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1902/* The address of the ALT_EMAC_GMAC_MAC_ADDR48_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1903#define ALT_EMAC1_GMAC_MAC_ADDR48_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR48_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1904/* The address of the ALT_EMAC_GMAC_MAC_ADDR48_LOW register for the ALT_EMAC1_GMACGRP instance. */
1905#define ALT_EMAC1_GMAC_MAC_ADDR48_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR48_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1906/* The address of the ALT_EMAC_GMAC_MAC_ADDR49_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1907#define ALT_EMAC1_GMAC_MAC_ADDR49_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR49_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1908/* The address of the ALT_EMAC_GMAC_MAC_ADDR49_LOW register for the ALT_EMAC1_GMACGRP instance. */
1909#define ALT_EMAC1_GMAC_MAC_ADDR49_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR49_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1910/* The address of the ALT_EMAC_GMAC_MAC_ADDR50_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1911#define ALT_EMAC1_GMAC_MAC_ADDR50_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR50_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1912/* The address of the ALT_EMAC_GMAC_MAC_ADDR50_LOW register for the ALT_EMAC1_GMACGRP instance. */
1913#define ALT_EMAC1_GMAC_MAC_ADDR50_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR50_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1914/* The address of the ALT_EMAC_GMAC_MAC_ADDR51_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1915#define ALT_EMAC1_GMAC_MAC_ADDR51_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR51_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1916/* The address of the ALT_EMAC_GMAC_MAC_ADDR51_LOW register for the ALT_EMAC1_GMACGRP instance. */
1917#define ALT_EMAC1_GMAC_MAC_ADDR51_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR51_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1918/* The address of the ALT_EMAC_GMAC_MAC_ADDR52_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1919#define ALT_EMAC1_GMAC_MAC_ADDR52_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR52_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1920/* The address of the ALT_EMAC_GMAC_MAC_ADDR52_LOW register for the ALT_EMAC1_GMACGRP instance. */
1921#define ALT_EMAC1_GMAC_MAC_ADDR52_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR52_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1922/* The address of the ALT_EMAC_GMAC_MAC_ADDR53_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1923#define ALT_EMAC1_GMAC_MAC_ADDR53_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR53_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1924/* The address of the ALT_EMAC_GMAC_MAC_ADDR53_LOW register for the ALT_EMAC1_GMACGRP instance. */
1925#define ALT_EMAC1_GMAC_MAC_ADDR53_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR53_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1926/* The address of the ALT_EMAC_GMAC_MAC_ADDR54_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1927#define ALT_EMAC1_GMAC_MAC_ADDR54_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR54_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1928/* The address of the ALT_EMAC_GMAC_MAC_ADDR54_LOW register for the ALT_EMAC1_GMACGRP instance. */
1929#define ALT_EMAC1_GMAC_MAC_ADDR54_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR54_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1930/* The address of the ALT_EMAC_GMAC_MAC_ADDR55_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1931#define ALT_EMAC1_GMAC_MAC_ADDR55_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR55_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1932/* The address of the ALT_EMAC_GMAC_MAC_ADDR55_LOW register for the ALT_EMAC1_GMACGRP instance. */
1933#define ALT_EMAC1_GMAC_MAC_ADDR55_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR55_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1934/* The address of the ALT_EMAC_GMAC_MAC_ADDR56_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1935#define ALT_EMAC1_GMAC_MAC_ADDR56_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR56_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1936/* The address of the ALT_EMAC_GMAC_MAC_ADDR56_LOW register for the ALT_EMAC1_GMACGRP instance. */
1937#define ALT_EMAC1_GMAC_MAC_ADDR56_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR56_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1938/* The address of the ALT_EMAC_GMAC_MAC_ADDR57_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1939#define ALT_EMAC1_GMAC_MAC_ADDR57_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR57_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1940/* The address of the ALT_EMAC_GMAC_MAC_ADDR57_LOW register for the ALT_EMAC1_GMACGRP instance. */
1941#define ALT_EMAC1_GMAC_MAC_ADDR57_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR57_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1942/* The address of the ALT_EMAC_GMAC_MAC_ADDR58_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1943#define ALT_EMAC1_GMAC_MAC_ADDR58_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR58_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1944/* The address of the ALT_EMAC_GMAC_MAC_ADDR58_LOW register for the ALT_EMAC1_GMACGRP instance. */
1945#define ALT_EMAC1_GMAC_MAC_ADDR58_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR58_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1946/* The address of the ALT_EMAC_GMAC_MAC_ADDR59_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1947#define ALT_EMAC1_GMAC_MAC_ADDR59_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR59_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1948/* The address of the ALT_EMAC_GMAC_MAC_ADDR59_LOW register for the ALT_EMAC1_GMACGRP instance. */
1949#define ALT_EMAC1_GMAC_MAC_ADDR59_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR59_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1950/* The address of the ALT_EMAC_GMAC_MAC_ADDR60_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1951#define ALT_EMAC1_GMAC_MAC_ADDR60_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR60_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1952/* The address of the ALT_EMAC_GMAC_MAC_ADDR60_LOW register for the ALT_EMAC1_GMACGRP instance. */
1953#define ALT_EMAC1_GMAC_MAC_ADDR60_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR60_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1954/* The address of the ALT_EMAC_GMAC_MAC_ADDR61_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1955#define ALT_EMAC1_GMAC_MAC_ADDR61_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR61_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1956/* The address of the ALT_EMAC_GMAC_MAC_ADDR61_LOW register for the ALT_EMAC1_GMACGRP instance. */
1957#define ALT_EMAC1_GMAC_MAC_ADDR61_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR61_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1958/* The address of the ALT_EMAC_GMAC_MAC_ADDR62_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1959#define ALT_EMAC1_GMAC_MAC_ADDR62_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR62_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1960/* The address of the ALT_EMAC_GMAC_MAC_ADDR62_LOW register for the ALT_EMAC1_GMACGRP instance. */
1961#define ALT_EMAC1_GMAC_MAC_ADDR62_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR62_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1962/* The address of the ALT_EMAC_GMAC_MAC_ADDR63_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1963#define ALT_EMAC1_GMAC_MAC_ADDR63_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR63_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1964/* The address of the ALT_EMAC_GMAC_MAC_ADDR63_LOW register for the ALT_EMAC1_GMACGRP instance. */
1965#define ALT_EMAC1_GMAC_MAC_ADDR63_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR63_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1966/* The address of the ALT_EMAC_GMAC_MAC_ADDR64_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1967#define ALT_EMAC1_GMAC_MAC_ADDR64_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR64_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1968/* The address of the ALT_EMAC_GMAC_MAC_ADDR64_LOW register for the ALT_EMAC1_GMACGRP instance. */
1969#define ALT_EMAC1_GMAC_MAC_ADDR64_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR64_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1970/* The address of the ALT_EMAC_GMAC_MAC_ADDR65_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1971#define ALT_EMAC1_GMAC_MAC_ADDR65_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR65_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1972/* The address of the ALT_EMAC_GMAC_MAC_ADDR65_LOW register for the ALT_EMAC1_GMACGRP instance. */
1973#define ALT_EMAC1_GMAC_MAC_ADDR65_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR65_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1974/* The address of the ALT_EMAC_GMAC_MAC_ADDR66_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1975#define ALT_EMAC1_GMAC_MAC_ADDR66_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR66_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1976/* The address of the ALT_EMAC_GMAC_MAC_ADDR66_LOW register for the ALT_EMAC1_GMACGRP instance. */
1977#define ALT_EMAC1_GMAC_MAC_ADDR66_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR66_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1978/* The address of the ALT_EMAC_GMAC_MAC_ADDR67_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1979#define ALT_EMAC1_GMAC_MAC_ADDR67_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR67_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1980/* The address of the ALT_EMAC_GMAC_MAC_ADDR67_LOW register for the ALT_EMAC1_GMACGRP instance. */
1981#define ALT_EMAC1_GMAC_MAC_ADDR67_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR67_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1982/* The address of the ALT_EMAC_GMAC_MAC_ADDR68_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1983#define ALT_EMAC1_GMAC_MAC_ADDR68_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR68_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1984/* The address of the ALT_EMAC_GMAC_MAC_ADDR68_LOW register for the ALT_EMAC1_GMACGRP instance. */
1985#define ALT_EMAC1_GMAC_MAC_ADDR68_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR68_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1986/* The address of the ALT_EMAC_GMAC_MAC_ADDR69_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1987#define ALT_EMAC1_GMAC_MAC_ADDR69_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR69_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1988/* The address of the ALT_EMAC_GMAC_MAC_ADDR69_LOW register for the ALT_EMAC1_GMACGRP instance. */
1989#define ALT_EMAC1_GMAC_MAC_ADDR69_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR69_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1990/* The address of the ALT_EMAC_GMAC_MAC_ADDR70_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1991#define ALT_EMAC1_GMAC_MAC_ADDR70_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR70_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1992/* The address of the ALT_EMAC_GMAC_MAC_ADDR70_LOW register for the ALT_EMAC1_GMACGRP instance. */
1993#define ALT_EMAC1_GMAC_MAC_ADDR70_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR70_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1994/* The address of the ALT_EMAC_GMAC_MAC_ADDR71_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1995#define ALT_EMAC1_GMAC_MAC_ADDR71_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR71_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1996/* The address of the ALT_EMAC_GMAC_MAC_ADDR71_LOW register for the ALT_EMAC1_GMACGRP instance. */
1997#define ALT_EMAC1_GMAC_MAC_ADDR71_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR71_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1998/* The address of the ALT_EMAC_GMAC_MAC_ADDR72_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1999#define ALT_EMAC1_GMAC_MAC_ADDR72_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR72_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2000/* The address of the ALT_EMAC_GMAC_MAC_ADDR72_LOW register for the ALT_EMAC1_GMACGRP instance. */
2001#define ALT_EMAC1_GMAC_MAC_ADDR72_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR72_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2002/* The address of the ALT_EMAC_GMAC_MAC_ADDR73_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2003#define ALT_EMAC1_GMAC_MAC_ADDR73_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR73_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2004/* The address of the ALT_EMAC_GMAC_MAC_ADDR73_LOW register for the ALT_EMAC1_GMACGRP instance. */
2005#define ALT_EMAC1_GMAC_MAC_ADDR73_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR73_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2006/* The address of the ALT_EMAC_GMAC_MAC_ADDR74_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2007#define ALT_EMAC1_GMAC_MAC_ADDR74_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR74_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2008/* The address of the ALT_EMAC_GMAC_MAC_ADDR74_LOW register for the ALT_EMAC1_GMACGRP instance. */
2009#define ALT_EMAC1_GMAC_MAC_ADDR74_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR74_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2010/* The address of the ALT_EMAC_GMAC_MAC_ADDR75_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2011#define ALT_EMAC1_GMAC_MAC_ADDR75_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR75_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2012/* The address of the ALT_EMAC_GMAC_MAC_ADDR75_LOW register for the ALT_EMAC1_GMACGRP instance. */
2013#define ALT_EMAC1_GMAC_MAC_ADDR75_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR75_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2014/* The address of the ALT_EMAC_GMAC_MAC_ADDR76_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2015#define ALT_EMAC1_GMAC_MAC_ADDR76_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR76_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2016/* The address of the ALT_EMAC_GMAC_MAC_ADDR76_LOW register for the ALT_EMAC1_GMACGRP instance. */
2017#define ALT_EMAC1_GMAC_MAC_ADDR76_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR76_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2018/* The address of the ALT_EMAC_GMAC_MAC_ADDR77_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2019#define ALT_EMAC1_GMAC_MAC_ADDR77_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR77_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2020/* The address of the ALT_EMAC_GMAC_MAC_ADDR77_LOW register for the ALT_EMAC1_GMACGRP instance. */
2021#define ALT_EMAC1_GMAC_MAC_ADDR77_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR77_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2022/* The address of the ALT_EMAC_GMAC_MAC_ADDR78_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2023#define ALT_EMAC1_GMAC_MAC_ADDR78_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR78_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2024/* The address of the ALT_EMAC_GMAC_MAC_ADDR78_LOW register for the ALT_EMAC1_GMACGRP instance. */
2025#define ALT_EMAC1_GMAC_MAC_ADDR78_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR78_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2026/* The address of the ALT_EMAC_GMAC_MAC_ADDR79_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2027#define ALT_EMAC1_GMAC_MAC_ADDR79_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR79_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2028/* The address of the ALT_EMAC_GMAC_MAC_ADDR79_LOW register for the ALT_EMAC1_GMACGRP instance. */
2029#define ALT_EMAC1_GMAC_MAC_ADDR79_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR79_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2030/* The address of the ALT_EMAC_GMAC_MAC_ADDR80_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2031#define ALT_EMAC1_GMAC_MAC_ADDR80_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR80_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2032/* The address of the ALT_EMAC_GMAC_MAC_ADDR80_LOW register for the ALT_EMAC1_GMACGRP instance. */
2033#define ALT_EMAC1_GMAC_MAC_ADDR80_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR80_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2034/* The address of the ALT_EMAC_GMAC_MAC_ADDR81_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2035#define ALT_EMAC1_GMAC_MAC_ADDR81_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR81_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2036/* The address of the ALT_EMAC_GMAC_MAC_ADDR81_LOW register for the ALT_EMAC1_GMACGRP instance. */
2037#define ALT_EMAC1_GMAC_MAC_ADDR81_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR81_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2038/* The address of the ALT_EMAC_GMAC_MAC_ADDR82_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2039#define ALT_EMAC1_GMAC_MAC_ADDR82_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR82_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2040/* The address of the ALT_EMAC_GMAC_MAC_ADDR82_LOW register for the ALT_EMAC1_GMACGRP instance. */
2041#define ALT_EMAC1_GMAC_MAC_ADDR82_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR82_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2042/* The address of the ALT_EMAC_GMAC_MAC_ADDR83_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2043#define ALT_EMAC1_GMAC_MAC_ADDR83_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR83_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2044/* The address of the ALT_EMAC_GMAC_MAC_ADDR83_LOW register for the ALT_EMAC1_GMACGRP instance. */
2045#define ALT_EMAC1_GMAC_MAC_ADDR83_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR83_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2046/* The address of the ALT_EMAC_GMAC_MAC_ADDR84_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2047#define ALT_EMAC1_GMAC_MAC_ADDR84_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR84_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2048/* The address of the ALT_EMAC_GMAC_MAC_ADDR84_LOW register for the ALT_EMAC1_GMACGRP instance. */
2049#define ALT_EMAC1_GMAC_MAC_ADDR84_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR84_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2050/* The address of the ALT_EMAC_GMAC_MAC_ADDR85_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2051#define ALT_EMAC1_GMAC_MAC_ADDR85_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR85_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2052/* The address of the ALT_EMAC_GMAC_MAC_ADDR85_LOW register for the ALT_EMAC1_GMACGRP instance. */
2053#define ALT_EMAC1_GMAC_MAC_ADDR85_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR85_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2054/* The address of the ALT_EMAC_GMAC_MAC_ADDR86_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2055#define ALT_EMAC1_GMAC_MAC_ADDR86_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR86_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2056/* The address of the ALT_EMAC_GMAC_MAC_ADDR86_LOW register for the ALT_EMAC1_GMACGRP instance. */
2057#define ALT_EMAC1_GMAC_MAC_ADDR86_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR86_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2058/* The address of the ALT_EMAC_GMAC_MAC_ADDR87_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2059#define ALT_EMAC1_GMAC_MAC_ADDR87_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR87_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2060/* The address of the ALT_EMAC_GMAC_MAC_ADDR87_LOW register for the ALT_EMAC1_GMACGRP instance. */
2061#define ALT_EMAC1_GMAC_MAC_ADDR87_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR87_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2062/* The address of the ALT_EMAC_GMAC_MAC_ADDR88_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2063#define ALT_EMAC1_GMAC_MAC_ADDR88_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR88_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2064/* The address of the ALT_EMAC_GMAC_MAC_ADDR88_LOW register for the ALT_EMAC1_GMACGRP instance. */
2065#define ALT_EMAC1_GMAC_MAC_ADDR88_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR88_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2066/* The address of the ALT_EMAC_GMAC_MAC_ADDR89_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2067#define ALT_EMAC1_GMAC_MAC_ADDR89_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR89_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2068/* The address of the ALT_EMAC_GMAC_MAC_ADDR89_LOW register for the ALT_EMAC1_GMACGRP instance. */
2069#define ALT_EMAC1_GMAC_MAC_ADDR89_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR89_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2070/* The address of the ALT_EMAC_GMAC_MAC_ADDR90_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2071#define ALT_EMAC1_GMAC_MAC_ADDR90_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR90_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2072/* The address of the ALT_EMAC_GMAC_MAC_ADDR90_LOW register for the ALT_EMAC1_GMACGRP instance. */
2073#define ALT_EMAC1_GMAC_MAC_ADDR90_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR90_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2074/* The address of the ALT_EMAC_GMAC_MAC_ADDR91_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2075#define ALT_EMAC1_GMAC_MAC_ADDR91_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR91_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2076/* The address of the ALT_EMAC_GMAC_MAC_ADDR91_LOW register for the ALT_EMAC1_GMACGRP instance. */
2077#define ALT_EMAC1_GMAC_MAC_ADDR91_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR91_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2078/* The address of the ALT_EMAC_GMAC_MAC_ADDR92_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2079#define ALT_EMAC1_GMAC_MAC_ADDR92_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR92_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2080/* The address of the ALT_EMAC_GMAC_MAC_ADDR92_LOW register for the ALT_EMAC1_GMACGRP instance. */
2081#define ALT_EMAC1_GMAC_MAC_ADDR92_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR92_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2082/* The address of the ALT_EMAC_GMAC_MAC_ADDR93_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2083#define ALT_EMAC1_GMAC_MAC_ADDR93_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR93_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2084/* The address of the ALT_EMAC_GMAC_MAC_ADDR93_LOW register for the ALT_EMAC1_GMACGRP instance. */
2085#define ALT_EMAC1_GMAC_MAC_ADDR93_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR93_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2086/* The address of the ALT_EMAC_GMAC_MAC_ADDR94_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2087#define ALT_EMAC1_GMAC_MAC_ADDR94_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR94_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2088/* The address of the ALT_EMAC_GMAC_MAC_ADDR94_LOW register for the ALT_EMAC1_GMACGRP instance. */
2089#define ALT_EMAC1_GMAC_MAC_ADDR94_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR94_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2090/* The address of the ALT_EMAC_GMAC_MAC_ADDR95_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2091#define ALT_EMAC1_GMAC_MAC_ADDR95_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR95_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2092/* The address of the ALT_EMAC_GMAC_MAC_ADDR95_LOW register for the ALT_EMAC1_GMACGRP instance. */
2093#define ALT_EMAC1_GMAC_MAC_ADDR95_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR95_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2094/* The address of the ALT_EMAC_GMAC_MAC_ADDR96_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2095#define ALT_EMAC1_GMAC_MAC_ADDR96_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR96_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2096/* The address of the ALT_EMAC_GMAC_MAC_ADDR96_LOW register for the ALT_EMAC1_GMACGRP instance. */
2097#define ALT_EMAC1_GMAC_MAC_ADDR96_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR96_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2098/* The address of the ALT_EMAC_GMAC_MAC_ADDR97_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2099#define ALT_EMAC1_GMAC_MAC_ADDR97_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR97_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2100/* The address of the ALT_EMAC_GMAC_MAC_ADDR97_LOW register for the ALT_EMAC1_GMACGRP instance. */
2101#define ALT_EMAC1_GMAC_MAC_ADDR97_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR97_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2102/* The address of the ALT_EMAC_GMAC_MAC_ADDR98_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2103#define ALT_EMAC1_GMAC_MAC_ADDR98_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR98_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2104/* The address of the ALT_EMAC_GMAC_MAC_ADDR98_LOW register for the ALT_EMAC1_GMACGRP instance. */
2105#define ALT_EMAC1_GMAC_MAC_ADDR98_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR98_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2106/* The address of the ALT_EMAC_GMAC_MAC_ADDR99_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2107#define ALT_EMAC1_GMAC_MAC_ADDR99_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR99_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2108/* The address of the ALT_EMAC_GMAC_MAC_ADDR99_LOW register for the ALT_EMAC1_GMACGRP instance. */
2109#define ALT_EMAC1_GMAC_MAC_ADDR99_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR99_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2110/* The address of the ALT_EMAC_GMAC_MAC_ADDR100_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2111#define ALT_EMAC1_GMAC_MAC_ADDR100_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR100_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2112/* The address of the ALT_EMAC_GMAC_MAC_ADDR100_LOW register for the ALT_EMAC1_GMACGRP instance. */
2113#define ALT_EMAC1_GMAC_MAC_ADDR100_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR100_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2114/* The address of the ALT_EMAC_GMAC_MAC_ADDR101_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2115#define ALT_EMAC1_GMAC_MAC_ADDR101_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR101_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2116/* The address of the ALT_EMAC_GMAC_MAC_ADDR101_LOW register for the ALT_EMAC1_GMACGRP instance. */
2117#define ALT_EMAC1_GMAC_MAC_ADDR101_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR101_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2118/* The address of the ALT_EMAC_GMAC_MAC_ADDR102_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2119#define ALT_EMAC1_GMAC_MAC_ADDR102_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR102_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2120/* The address of the ALT_EMAC_GMAC_MAC_ADDR102_LOW register for the ALT_EMAC1_GMACGRP instance. */
2121#define ALT_EMAC1_GMAC_MAC_ADDR102_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR102_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2122/* The address of the ALT_EMAC_GMAC_MAC_ADDR103_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2123#define ALT_EMAC1_GMAC_MAC_ADDR103_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR103_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2124/* The address of the ALT_EMAC_GMAC_MAC_ADDR103_LOW register for the ALT_EMAC1_GMACGRP instance. */
2125#define ALT_EMAC1_GMAC_MAC_ADDR103_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR103_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2126/* The address of the ALT_EMAC_GMAC_MAC_ADDR104_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2127#define ALT_EMAC1_GMAC_MAC_ADDR104_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR104_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2128/* The address of the ALT_EMAC_GMAC_MAC_ADDR104_LOW register for the ALT_EMAC1_GMACGRP instance. */
2129#define ALT_EMAC1_GMAC_MAC_ADDR104_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR104_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2130/* The address of the ALT_EMAC_GMAC_MAC_ADDR105_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2131#define ALT_EMAC1_GMAC_MAC_ADDR105_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR105_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2132/* The address of the ALT_EMAC_GMAC_MAC_ADDR105_LOW register for the ALT_EMAC1_GMACGRP instance. */
2133#define ALT_EMAC1_GMAC_MAC_ADDR105_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR105_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2134/* The address of the ALT_EMAC_GMAC_MAC_ADDR106_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2135#define ALT_EMAC1_GMAC_MAC_ADDR106_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR106_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2136/* The address of the ALT_EMAC_GMAC_MAC_ADDR106_LOW register for the ALT_EMAC1_GMACGRP instance. */
2137#define ALT_EMAC1_GMAC_MAC_ADDR106_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR106_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2138/* The address of the ALT_EMAC_GMAC_MAC_ADDR107_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2139#define ALT_EMAC1_GMAC_MAC_ADDR107_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR107_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2140/* The address of the ALT_EMAC_GMAC_MAC_ADDR107_LOW register for the ALT_EMAC1_GMACGRP instance. */
2141#define ALT_EMAC1_GMAC_MAC_ADDR107_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR107_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2142/* The address of the ALT_EMAC_GMAC_MAC_ADDR108_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2143#define ALT_EMAC1_GMAC_MAC_ADDR108_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR108_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2144/* The address of the ALT_EMAC_GMAC_MAC_ADDR108_LOW register for the ALT_EMAC1_GMACGRP instance. */
2145#define ALT_EMAC1_GMAC_MAC_ADDR108_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR108_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2146/* The address of the ALT_EMAC_GMAC_MAC_ADDR109_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2147#define ALT_EMAC1_GMAC_MAC_ADDR109_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR109_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2148/* The address of the ALT_EMAC_GMAC_MAC_ADDR109_LOW register for the ALT_EMAC1_GMACGRP instance. */
2149#define ALT_EMAC1_GMAC_MAC_ADDR109_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR109_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2150/* The address of the ALT_EMAC_GMAC_MAC_ADDR110_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2151#define ALT_EMAC1_GMAC_MAC_ADDR110_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR110_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2152/* The address of the ALT_EMAC_GMAC_MAC_ADDR110_LOW register for the ALT_EMAC1_GMACGRP instance. */
2153#define ALT_EMAC1_GMAC_MAC_ADDR110_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR110_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2154/* The address of the ALT_EMAC_GMAC_MAC_ADDR111_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2155#define ALT_EMAC1_GMAC_MAC_ADDR111_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR111_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2156/* The address of the ALT_EMAC_GMAC_MAC_ADDR111_LOW register for the ALT_EMAC1_GMACGRP instance. */
2157#define ALT_EMAC1_GMAC_MAC_ADDR111_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR111_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2158/* The address of the ALT_EMAC_GMAC_MAC_ADDR112_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2159#define ALT_EMAC1_GMAC_MAC_ADDR112_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR112_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2160/* The address of the ALT_EMAC_GMAC_MAC_ADDR112_LOW register for the ALT_EMAC1_GMACGRP instance. */
2161#define ALT_EMAC1_GMAC_MAC_ADDR112_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR112_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2162/* The address of the ALT_EMAC_GMAC_MAC_ADDR113_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2163#define ALT_EMAC1_GMAC_MAC_ADDR113_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR113_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2164/* The address of the ALT_EMAC_GMAC_MAC_ADDR113_LOW register for the ALT_EMAC1_GMACGRP instance. */
2165#define ALT_EMAC1_GMAC_MAC_ADDR113_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR113_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2166/* The address of the ALT_EMAC_GMAC_MAC_ADDR114_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2167#define ALT_EMAC1_GMAC_MAC_ADDR114_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR114_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2168/* The address of the ALT_EMAC_GMAC_MAC_ADDR114_LOW register for the ALT_EMAC1_GMACGRP instance. */
2169#define ALT_EMAC1_GMAC_MAC_ADDR114_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR114_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2170/* The address of the ALT_EMAC_GMAC_MAC_ADDR115_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2171#define ALT_EMAC1_GMAC_MAC_ADDR115_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR115_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2172/* The address of the ALT_EMAC_GMAC_MAC_ADDR115_LOW register for the ALT_EMAC1_GMACGRP instance. */
2173#define ALT_EMAC1_GMAC_MAC_ADDR115_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR115_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2174/* The address of the ALT_EMAC_GMAC_MAC_ADDR116_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2175#define ALT_EMAC1_GMAC_MAC_ADDR116_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR116_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2176/* The address of the ALT_EMAC_GMAC_MAC_ADDR116_LOW register for the ALT_EMAC1_GMACGRP instance. */
2177#define ALT_EMAC1_GMAC_MAC_ADDR116_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR116_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2178/* The address of the ALT_EMAC_GMAC_MAC_ADDR117_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2179#define ALT_EMAC1_GMAC_MAC_ADDR117_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR117_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2180/* The address of the ALT_EMAC_GMAC_MAC_ADDR117_LOW register for the ALT_EMAC1_GMACGRP instance. */
2181#define ALT_EMAC1_GMAC_MAC_ADDR117_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR117_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2182/* The address of the ALT_EMAC_GMAC_MAC_ADDR118_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2183#define ALT_EMAC1_GMAC_MAC_ADDR118_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR118_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2184/* The address of the ALT_EMAC_GMAC_MAC_ADDR118_LOW register for the ALT_EMAC1_GMACGRP instance. */
2185#define ALT_EMAC1_GMAC_MAC_ADDR118_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR118_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2186/* The address of the ALT_EMAC_GMAC_MAC_ADDR119_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2187#define ALT_EMAC1_GMAC_MAC_ADDR119_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR119_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2188/* The address of the ALT_EMAC_GMAC_MAC_ADDR119_LOW register for the ALT_EMAC1_GMACGRP instance. */
2189#define ALT_EMAC1_GMAC_MAC_ADDR119_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR119_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2190/* The address of the ALT_EMAC_GMAC_MAC_ADDR120_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2191#define ALT_EMAC1_GMAC_MAC_ADDR120_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR120_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2192/* The address of the ALT_EMAC_GMAC_MAC_ADDR120_LOW register for the ALT_EMAC1_GMACGRP instance. */
2193#define ALT_EMAC1_GMAC_MAC_ADDR120_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR120_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2194/* The address of the ALT_EMAC_GMAC_MAC_ADDR121_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2195#define ALT_EMAC1_GMAC_MAC_ADDR121_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR121_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2196/* The address of the ALT_EMAC_GMAC_MAC_ADDR121_LOW register for the ALT_EMAC1_GMACGRP instance. */
2197#define ALT_EMAC1_GMAC_MAC_ADDR121_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR121_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2198/* The address of the ALT_EMAC_GMAC_MAC_ADDR122_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2199#define ALT_EMAC1_GMAC_MAC_ADDR122_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR122_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2200/* The address of the ALT_EMAC_GMAC_MAC_ADDR122_LOW register for the ALT_EMAC1_GMACGRP instance. */
2201#define ALT_EMAC1_GMAC_MAC_ADDR122_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR122_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2202/* The address of the ALT_EMAC_GMAC_MAC_ADDR123_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2203#define ALT_EMAC1_GMAC_MAC_ADDR123_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR123_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2204/* The address of the ALT_EMAC_GMAC_MAC_ADDR123_LOW register for the ALT_EMAC1_GMACGRP instance. */
2205#define ALT_EMAC1_GMAC_MAC_ADDR123_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR123_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2206/* The address of the ALT_EMAC_GMAC_MAC_ADDR124_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2207#define ALT_EMAC1_GMAC_MAC_ADDR124_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR124_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2208/* The address of the ALT_EMAC_GMAC_MAC_ADDR124_LOW register for the ALT_EMAC1_GMACGRP instance. */
2209#define ALT_EMAC1_GMAC_MAC_ADDR124_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR124_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2210/* The address of the ALT_EMAC_GMAC_MAC_ADDR125_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2211#define ALT_EMAC1_GMAC_MAC_ADDR125_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR125_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2212/* The address of the ALT_EMAC_GMAC_MAC_ADDR125_LOW register for the ALT_EMAC1_GMACGRP instance. */
2213#define ALT_EMAC1_GMAC_MAC_ADDR125_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR125_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2214/* The address of the ALT_EMAC_GMAC_MAC_ADDR126_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2215#define ALT_EMAC1_GMAC_MAC_ADDR126_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR126_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2216/* The address of the ALT_EMAC_GMAC_MAC_ADDR126_LOW register for the ALT_EMAC1_GMACGRP instance. */
2217#define ALT_EMAC1_GMAC_MAC_ADDR126_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR126_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2218/* The address of the ALT_EMAC_GMAC_MAC_ADDR127_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2219#define ALT_EMAC1_GMAC_MAC_ADDR127_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR127_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2220/* The address of the ALT_EMAC_GMAC_MAC_ADDR127_LOW register for the ALT_EMAC1_GMACGRP instance. */
2221#define ALT_EMAC1_GMAC_MAC_ADDR127_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR127_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2222/* The base address byte offset for the start of the ALT_EMAC1_GMACGRP component. */
2223#define ALT_EMAC1_GMACGRP_OFST 0x0
2224/* The start address of the ALT_EMAC1_GMACGRP component. */
2225#define ALT_EMAC1_GMACGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_EMAC1_ADDR) + ALT_EMAC1_GMACGRP_OFST))
2226/* The lower bound address range of the ALT_EMAC1_GMACGRP component. */
2227#define ALT_EMAC1_GMACGRP_LB_ADDR ALT_EMAC1_GMACGRP_ADDR
2228/* The upper bound address range of the ALT_EMAC1_GMACGRP component. */
2229#define ALT_EMAC1_GMACGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_EMAC1_GMACGRP_ADDR) + 0xb80) - 1))
2230
2231
2232/*
2233 * Register Group Instance : dmagrp
2234 *
2235 * Instance dmagrp of register group ALT_EMAC_DMA.
2236 *
2237 *
2238 */
2239/* The address of the ALT_EMAC_DMA_BUS_MOD register for the ALT_EMAC1_DMAGRP instance. */
2240#define ALT_EMAC1_DMA_BUS_MOD_ADDR ALT_EMAC_DMA_BUS_MOD_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2241/* The address of the ALT_EMAC_DMA_TX_POLL_DEMAND register for the ALT_EMAC1_DMAGRP instance. */
2242#define ALT_EMAC1_DMA_TX_POLL_DEMAND_ADDR ALT_EMAC_DMA_TX_POLL_DEMAND_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2243/* The address of the ALT_EMAC_DMA_RX_POLL_DEMAND register for the ALT_EMAC1_DMAGRP instance. */
2244#define ALT_EMAC1_DMA_RX_POLL_DEMAND_ADDR ALT_EMAC_DMA_RX_POLL_DEMAND_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2245/* The address of the ALT_EMAC_DMA_RX_DESC_LIST_ADDR register for the ALT_EMAC1_DMAGRP instance. */
2246#define ALT_EMAC1_DMA_RX_DESC_LIST_ADDR_ADDR ALT_EMAC_DMA_RX_DESC_LIST_ADDR_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2247/* The address of the ALT_EMAC_DMA_TX_DESC_LIST_ADDR register for the ALT_EMAC1_DMAGRP instance. */
2248#define ALT_EMAC1_DMA_TX_DESC_LIST_ADDR_ADDR ALT_EMAC_DMA_TX_DESC_LIST_ADDR_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2249/* The address of the ALT_EMAC_DMA_STAT register for the ALT_EMAC1_DMAGRP instance. */
2250#define ALT_EMAC1_DMA_STAT_ADDR ALT_EMAC_DMA_STAT_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2251/* The address of the ALT_EMAC_DMA_OP_MOD register for the ALT_EMAC1_DMAGRP instance. */
2252#define ALT_EMAC1_DMA_OP_MOD_ADDR ALT_EMAC_DMA_OP_MOD_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2253/* The address of the ALT_EMAC_DMA_INT_EN register for the ALT_EMAC1_DMAGRP instance. */
2254#define ALT_EMAC1_DMA_INT_EN_ADDR ALT_EMAC_DMA_INT_EN_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2255/* The address of the ALT_EMAC_DMA_MFRM_BUF_OVF_CNTR register for the ALT_EMAC1_DMAGRP instance. */
2256#define ALT_EMAC1_DMA_MISSED_FRM_AND_BUF_OVF_CNTR_ADDR ALT_EMAC_DMA_MFRM_BUF_OVF_CNTR_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2257/* The address of the ALT_EMAC_DMA_RX_INT_WDT register for the ALT_EMAC1_DMAGRP instance. */
2258#define ALT_EMAC1_DMA_RX_INT_WDT_ADDR ALT_EMAC_DMA_RX_INT_WDT_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2259/* The address of the ALT_EMAC_DMA_AXI_BUS_MOD register for the ALT_EMAC1_DMAGRP instance. */
2260#define ALT_EMAC1_DMA_AXI_BUS_MOD_ADDR ALT_EMAC_DMA_AXI_BUS_MOD_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2261/* The address of the ALT_EMAC_DMA_AHB_OR_AXI_STAT register for the ALT_EMAC1_DMAGRP instance. */
2262#define ALT_EMAC1_DMA_AHB_OR_AXI_STAT_ADDR ALT_EMAC_DMA_AHB_OR_AXI_STAT_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2263/* The address of the ALT_EMAC_DMA_CUR_HOST_TX_DESC register for the ALT_EMAC1_DMAGRP instance. */
2264#define ALT_EMAC1_DMA_CUR_HOST_TX_DESC_ADDR ALT_EMAC_DMA_CUR_HOST_TX_DESC_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2265/* The address of the ALT_EMAC_DMA_CUR_HOST_RX_DESC register for the ALT_EMAC1_DMAGRP instance. */
2266#define ALT_EMAC1_DMA_CUR_HOST_RX_DESC_ADDR ALT_EMAC_DMA_CUR_HOST_RX_DESC_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2267/* The address of the ALT_EMAC_DMA_CUR_HOST_TX_BUF_ADDR register for the ALT_EMAC1_DMAGRP instance. */
2268#define ALT_EMAC1_DMA_CUR_HOST_TX_BUF_ADDR_ADDR ALT_EMAC_DMA_CUR_HOST_TX_BUF_ADDR_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2269/* The address of the ALT_EMAC_DMA_CUR_HOST_RX_BUF_ADDR register for the ALT_EMAC1_DMAGRP instance. */
2270#define ALT_EMAC1_DMA_CUR_HOST_RX_BUF_ADDR_ADDR ALT_EMAC_DMA_CUR_HOST_RX_BUF_ADDR_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2271/* The address of the ALT_EMAC_DMA_HW_FEATURE register for the ALT_EMAC1_DMAGRP instance. */
2272#define ALT_EMAC1_DMA_HW_FEATURE_ADDR ALT_EMAC_DMA_HW_FEATURE_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2273/* The base address byte offset for the start of the ALT_EMAC1_DMAGRP component. */
2274#define ALT_EMAC1_DMAGRP_OFST 0x1000
2275/* The start address of the ALT_EMAC1_DMAGRP component. */
2276#define ALT_EMAC1_DMAGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_EMAC1_ADDR) + ALT_EMAC1_DMAGRP_OFST))
2277/* The lower bound address range of the ALT_EMAC1_DMAGRP component. */
2278#define ALT_EMAC1_DMAGRP_LB_ADDR ALT_EMAC1_DMAGRP_ADDR
2279/* The upper bound address range of the ALT_EMAC1_DMAGRP component. */
2280#define ALT_EMAC1_DMAGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_EMAC1_DMAGRP_ADDR) + 0x5c) - 1))
2281
2282
2283/* The base address byte offset for the start of the ALT_EMAC1 component. */
2284#define ALT_EMAC1_OFST 0xff702000
2285/* The start address of the ALT_EMAC1 component. */
2286#define ALT_EMAC1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_EMAC1_OFST))
2287/* The lower bound address range of the ALT_EMAC1 component. */
2288#define ALT_EMAC1_LB_ADDR ALT_EMAC1_ADDR
2289/* The upper bound address range of the ALT_EMAC1 component. */
2290#define ALT_EMAC1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_EMAC1_ADDR) + 0x2000) - 1))
2291
2292
2293/*
2294 * Component Instance : sdmmc
2295 *
2296 * Instance sdmmc of component ALT_SDMMC.
2297 *
2298 *
2299 */
2300/* The address of the ALT_SDMMC_CTL register for the ALT_SDMMC instance. */
2301#define ALT_SDMMC_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CTL_OFST))
2302/* The address of the ALT_SDMMC_PWREN register for the ALT_SDMMC instance. */
2303#define ALT_SDMMC_PWREN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_PWREN_OFST))
2304/* The address of the ALT_SDMMC_CLKDIV register for the ALT_SDMMC instance. */
2305#define ALT_SDMMC_CLKDIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CLKDIV_OFST))
2306/* The address of the ALT_SDMMC_CLKSRC register for the ALT_SDMMC instance. */
2307#define ALT_SDMMC_CLKSRC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CLKSRC_OFST))
2308/* The address of the ALT_SDMMC_CLKENA register for the ALT_SDMMC instance. */
2309#define ALT_SDMMC_CLKENA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CLKENA_OFST))
2310/* The address of the ALT_SDMMC_TMOUT register for the ALT_SDMMC instance. */
2311#define ALT_SDMMC_TMOUT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_TMOUT_OFST))
2312/* The address of the ALT_SDMMC_CTYPE register for the ALT_SDMMC instance. */
2313#define ALT_SDMMC_CTYPE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CTYPE_OFST))
2314/* The address of the ALT_SDMMC_BLKSIZ register for the ALT_SDMMC instance. */
2315#define ALT_SDMMC_BLKSIZ_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_BLKSIZ_OFST))
2316/* The address of the ALT_SDMMC_BYTCNT register for the ALT_SDMMC instance. */
2317#define ALT_SDMMC_BYTCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_BYTCNT_OFST))
2318/* The address of the ALT_SDMMC_INTMSK register for the ALT_SDMMC instance. */
2319#define ALT_SDMMC_INTMSK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_INTMSK_OFST))
2320/* The address of the ALT_SDMMC_CMDARG register for the ALT_SDMMC instance. */
2321#define ALT_SDMMC_CMDARG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CMDARG_OFST))
2322/* The address of the ALT_SDMMC_CMD register for the ALT_SDMMC instance. */
2323#define ALT_SDMMC_CMD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CMD_OFST))
2324/* The address of the ALT_SDMMC_RESP0 register for the ALT_SDMMC instance. */
2325#define ALT_SDMMC_RESP0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_RESP0_OFST))
2326/* The address of the ALT_SDMMC_RESP1 register for the ALT_SDMMC instance. */
2327#define ALT_SDMMC_RESP1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_RESP1_OFST))
2328/* The address of the ALT_SDMMC_RESP2 register for the ALT_SDMMC instance. */
2329#define ALT_SDMMC_RESP2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_RESP2_OFST))
2330/* The address of the ALT_SDMMC_RESP3 register for the ALT_SDMMC instance. */
2331#define ALT_SDMMC_RESP3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_RESP3_OFST))
2332/* The address of the ALT_SDMMC_MINTSTS register for the ALT_SDMMC instance. */
2333#define ALT_SDMMC_MINTSTS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_MINTSTS_OFST))
2334/* The address of the ALT_SDMMC_RINTSTS register for the ALT_SDMMC instance. */
2335#define ALT_SDMMC_RINTSTS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_RINTSTS_OFST))
2336/* The address of the ALT_SDMMC_STAT register for the ALT_SDMMC instance. */
2337#define ALT_SDMMC_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_STAT_OFST))
2338/* The address of the ALT_SDMMC_FIFOTH register for the ALT_SDMMC instance. */
2339#define ALT_SDMMC_FIFOTH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_FIFOTH_OFST))
2340/* The address of the ALT_SDMMC_CDETECT register for the ALT_SDMMC instance. */
2341#define ALT_SDMMC_CDETECT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CDETECT_OFST))
2342/* The address of the ALT_SDMMC_WRTPRT register for the ALT_SDMMC instance. */
2343#define ALT_SDMMC_WRTPRT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_WRTPRT_OFST))
2344/* The address of the ALT_SDMMC_TCBCNT register for the ALT_SDMMC instance. */
2345#define ALT_SDMMC_TCBCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_TCBCNT_OFST))
2346/* The address of the ALT_SDMMC_TBBCNT register for the ALT_SDMMC instance. */
2347#define ALT_SDMMC_TBBCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_TBBCNT_OFST))
2348/* The address of the ALT_SDMMC_DEBNCE register for the ALT_SDMMC instance. */
2349#define ALT_SDMMC_DEBNCE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_DEBNCE_OFST))
2350/* The address of the ALT_SDMMC_USRID register for the ALT_SDMMC instance. */
2351#define ALT_SDMMC_USRID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_USRID_OFST))
2352/* The address of the ALT_SDMMC_VERID register for the ALT_SDMMC instance. */
2353#define ALT_SDMMC_VERID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_VERID_OFST))
2354/* The address of the ALT_SDMMC_HCON register for the ALT_SDMMC instance. */
2355#define ALT_SDMMC_HCON_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_HCON_OFST))
2356/* The address of the ALT_SDMMC_UHS_REG register for the ALT_SDMMC instance. */
2357#define ALT_SDMMC_UHS_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_UHS_REG_OFST))
2358/* The address of the ALT_SDMMC_RST_N register for the ALT_SDMMC instance. */
2359#define ALT_SDMMC_RST_N_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_RST_N_OFST))
2360/* The address of the ALT_SDMMC_BMOD register for the ALT_SDMMC instance. */
2361#define ALT_SDMMC_BMOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_BMOD_OFST))
2362/* The address of the ALT_SDMMC_PLDMND register for the ALT_SDMMC instance. */
2363#define ALT_SDMMC_PLDMND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_PLDMND_OFST))
2364/* The address of the ALT_SDMMC_DBADDR register for the ALT_SDMMC instance. */
2365#define ALT_SDMMC_DBADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_DBADDR_OFST))
2366/* The address of the ALT_SDMMC_IDSTS register for the ALT_SDMMC instance. */
2367#define ALT_SDMMC_IDSTS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_IDSTS_OFST))
2368/* The address of the ALT_SDMMC_IDINTEN register for the ALT_SDMMC instance. */
2369#define ALT_SDMMC_IDINTEN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_IDINTEN_OFST))
2370/* The address of the ALT_SDMMC_DSCADDR register for the ALT_SDMMC instance. */
2371#define ALT_SDMMC_DSCADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_DSCADDR_OFST))
2372/* The address of the ALT_SDMMC_BUFADDR register for the ALT_SDMMC instance. */
2373#define ALT_SDMMC_BUFADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_BUFADDR_OFST))
2374/* The address of the ALT_SDMMC_CARDTHRCTL register for the ALT_SDMMC instance. */
2375#define ALT_SDMMC_CARDTHRCTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CARDTHRCTL_OFST))
2376/* The address of the ALT_SDMMC_BACK_END_POWER_R register for the ALT_SDMMC instance. */
2377#define ALT_SDMMC_BACK_END_POWER_R_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_BACK_END_POWER_R_OFST))
2378/* The address of the ALT_SDMMC_DATA register for the ALT_SDMMC instance. */
2379#define ALT_SDMMC_DATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_DATA_OFST))
2380/* The base address byte offset for the start of the ALT_SDMMC component. */
2381#define ALT_SDMMC_OFST 0xff704000
2382/* The start address of the ALT_SDMMC component. */
2383#define ALT_SDMMC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SDMMC_OFST))
2384/* The lower bound address range of the ALT_SDMMC component. */
2385#define ALT_SDMMC_LB_ADDR ALT_SDMMC_ADDR
2386/* The upper bound address range of the ALT_SDMMC component. */
2387#define ALT_SDMMC_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SDMMC_ADDR) + 0x400) - 1))
2388
2389
2390/*
2391 * Component Instance : qspiregs
2392 *
2393 * Instance qspiregs of component ALT_QSPI.
2394 *
2395 *
2396 */
2397/* The address of the ALT_QSPI_CFG register for the ALT_QSPI instance. */
2398#define ALT_QSPI_CFG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_CFG_OFST))
2399/* The address of the ALT_QSPI_DEVRD register for the ALT_QSPI instance. */
2400#define ALT_QSPI_DEVRD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_DEVRD_OFST))
2401/* The address of the ALT_QSPI_DEVWR register for the ALT_QSPI instance. */
2402#define ALT_QSPI_DEVWR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_DEVWR_OFST))
2403/* The address of the ALT_QSPI_DELAY register for the ALT_QSPI instance. */
2404#define ALT_QSPI_DELAY_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_DELAY_OFST))
2405/* The address of the ALT_QSPI_RDDATACAP register for the ALT_QSPI instance. */
2406#define ALT_QSPI_RDDATACAP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_RDDATACAP_OFST))
2407/* The address of the ALT_QSPI_DEVSZ register for the ALT_QSPI instance. */
2408#define ALT_QSPI_DEVSZ_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_DEVSZ_OFST))
2409/* The address of the ALT_QSPI_SRAMPART register for the ALT_QSPI instance. */
2410#define ALT_QSPI_SRAMPART_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_SRAMPART_OFST))
2411/* The address of the ALT_QSPI_INDADDRTRIG register for the ALT_QSPI instance. */
2412#define ALT_QSPI_INDADDRTRIG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDADDRTRIG_OFST))
2413/* The address of the ALT_QSPI_DMAPER register for the ALT_QSPI instance. */
2414#define ALT_QSPI_DMAPER_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_DMAPER_OFST))
2415/* The address of the ALT_QSPI_REMAPADDR register for the ALT_QSPI instance. */
2416#define ALT_QSPI_REMAPADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_REMAPADDR_OFST))
2417/* The address of the ALT_QSPI_MODBIT register for the ALT_QSPI instance. */
2418#define ALT_QSPI_MODBIT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_MODBIT_OFST))
2419/* The address of the ALT_QSPI_SRAMFILL register for the ALT_QSPI instance. */
2420#define ALT_QSPI_SRAMFILL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_SRAMFILL_OFST))
2421/* The address of the ALT_QSPI_TXTHRESH register for the ALT_QSPI instance. */
2422#define ALT_QSPI_TXTHRESH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_TXTHRESH_OFST))
2423/* The address of the ALT_QSPI_RXTHRESH register for the ALT_QSPI instance. */
2424#define ALT_QSPI_RXTHRESH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_RXTHRESH_OFST))
2425/* The address of the ALT_QSPI_IRQSTAT register for the ALT_QSPI instance. */
2426#define ALT_QSPI_IRQSTAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_IRQSTAT_OFST))
2427/* The address of the ALT_QSPI_IRQMSK register for the ALT_QSPI instance. */
2428#define ALT_QSPI_IRQMSK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_IRQMSK_OFST))
2429/* The address of the ALT_QSPI_LOWWRPROT register for the ALT_QSPI instance. */
2430#define ALT_QSPI_LOWWRPROT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_LOWWRPROT_OFST))
2431/* The address of the ALT_QSPI_UPPWRPROT register for the ALT_QSPI instance. */
2432#define ALT_QSPI_UPPWRPROT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_UPPWRPROT_OFST))
2433/* The address of the ALT_QSPI_WRPROT register for the ALT_QSPI instance. */
2434#define ALT_QSPI_WRPROT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_WRPROT_OFST))
2435/* The address of the ALT_QSPI_INDRD register for the ALT_QSPI instance. */
2436#define ALT_QSPI_INDRD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDRD_OFST))
2437/* The address of the ALT_QSPI_INDRDWATER register for the ALT_QSPI instance. */
2438#define ALT_QSPI_INDRDWATER_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDRDWATER_OFST))
2439/* The address of the ALT_QSPI_INDRDSTADDR register for the ALT_QSPI instance. */
2440#define ALT_QSPI_INDRDSTADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDRDSTADDR_OFST))
2441/* The address of the ALT_QSPI_INDRDCNT register for the ALT_QSPI instance. */
2442#define ALT_QSPI_INDRDCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDRDCNT_OFST))
2443/* The address of the ALT_QSPI_INDWR register for the ALT_QSPI instance. */
2444#define ALT_QSPI_INDWR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDWR_OFST))
2445/* The address of the ALT_QSPI_INDWRWATER register for the ALT_QSPI instance. */
2446#define ALT_QSPI_INDWRWATER_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDWRWATER_OFST))
2447/* The address of the ALT_QSPI_INDWRSTADDR register for the ALT_QSPI instance. */
2448#define ALT_QSPI_INDWRSTADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDWRSTADDR_OFST))
2449/* The address of the ALT_QSPI_INDWRCNT register for the ALT_QSPI instance. */
2450#define ALT_QSPI_INDWRCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDWRCNT_OFST))
2451/* The address of the ALT_QSPI_FLSHCMD register for the ALT_QSPI instance. */
2452#define ALT_QSPI_FLSHCMD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_FLSHCMD_OFST))
2453/* The address of the ALT_QSPI_FLSHCMDADDR register for the ALT_QSPI instance. */
2454#define ALT_QSPI_FLSHCMDADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_FLSHCMDADDR_OFST))
2455/* The address of the ALT_QSPI_FLSHCMDRDDATALO register for the ALT_QSPI instance. */
2456#define ALT_QSPI_FLSHCMDRDDATALO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_FLSHCMDRDDATALO_OFST))
2457/* The address of the ALT_QSPI_FLSHCMDRDDATAUP register for the ALT_QSPI instance. */
2458#define ALT_QSPI_FLSHCMDRDDATAUP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_FLSHCMDRDDATAUP_OFST))
2459/* The address of the ALT_QSPI_FLSHCMDWRDATALO register for the ALT_QSPI instance. */
2460#define ALT_QSPI_FLSHCMDWRDATALO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_FLSHCMDWRDATALO_OFST))
2461/* The address of the ALT_QSPI_FLSHCMDWRDATAUP register for the ALT_QSPI instance. */
2462#define ALT_QSPI_FLSHCMDWRDATAUP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_FLSHCMDWRDATAUP_OFST))
2463/* The address of the ALT_QSPI_MODULEID register for the ALT_QSPI instance. */
2464#define ALT_QSPI_MODULEID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_MODULEID_OFST))
2465/* The base address byte offset for the start of the ALT_QSPI component. */
2466#define ALT_QSPI_OFST 0xff705000
2467/* The start address of the ALT_QSPI component. */
2468#define ALT_QSPI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_QSPI_OFST))
2469/* The lower bound address range of the ALT_QSPI component. */
2470#define ALT_QSPI_LB_ADDR ALT_QSPI_ADDR
2471/* The upper bound address range of the ALT_QSPI component. */
2472#define ALT_QSPI_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_QSPI_ADDR) + 0x100) - 1))
2473
2474
2475/*
2476 * Component Instance : fpgamgrregs
2477 *
2478 * Instance fpgamgrregs of component ALT_FPGAMGR.
2479 *
2480 *
2481 */
2482/* The address of the ALT_FPGAMGR_STAT register for the ALT_FPGAMGR instance. */
2483#define ALT_FPGAMGR_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_STAT_OFST))
2484/* The address of the ALT_FPGAMGR_CTL register for the ALT_FPGAMGR instance. */
2485#define ALT_FPGAMGR_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_CTL_OFST))
2486/* The address of the ALT_FPGAMGR_DCLKCNT register for the ALT_FPGAMGR instance. */
2487#define ALT_FPGAMGR_DCLKCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_DCLKCNT_OFST))
2488/* The address of the ALT_FPGAMGR_DCLKSTAT register for the ALT_FPGAMGR instance. */
2489#define ALT_FPGAMGR_DCLKSTAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_DCLKSTAT_OFST))
2490/* The address of the ALT_FPGAMGR_GPO register for the ALT_FPGAMGR instance. */
2491#define ALT_FPGAMGR_GPO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_GPO_OFST))
2492/* The address of the ALT_FPGAMGR_GPI register for the ALT_FPGAMGR instance. */
2493#define ALT_FPGAMGR_GPI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_GPI_OFST))
2494/* The address of the ALT_FPGAMGR_MISCI register for the ALT_FPGAMGR instance. */
2495#define ALT_FPGAMGR_MISCI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_MISCI_OFST))
2496/*
2497 * Register Group Instance : mon
2498 *
2499 * Instance mon of register group ALT_MON.
2500 *
2501 *
2502 */
2503/* The address of the ALT_MON_GPIO_INTEN register for the ALT_FPGAMGR_MON instance. */
2504#define ALT_FPGAMGR_MON_GPIO_INTEN_ADDR ALT_MON_GPIO_INTEN_ADDR(ALT_FPGAMGR_MON_ADDR)
2505/* The address of the ALT_MON_GPIO_INTMSK register for the ALT_FPGAMGR_MON instance. */
2506#define ALT_FPGAMGR_MON_GPIO_INTMSK_ADDR ALT_MON_GPIO_INTMSK_ADDR(ALT_FPGAMGR_MON_ADDR)
2507/* The address of the ALT_MON_GPIO_INTTYPE_LEVEL register for the ALT_FPGAMGR_MON instance. */
2508#define ALT_FPGAMGR_MON_GPIO_INTTYPE_LEVEL_ADDR ALT_MON_GPIO_INTTYPE_LEVEL_ADDR(ALT_FPGAMGR_MON_ADDR)
2509/* The address of the ALT_MON_GPIO_INT_POL register for the ALT_FPGAMGR_MON instance. */
2510#define ALT_FPGAMGR_MON_GPIO_INT_POL_ADDR ALT_MON_GPIO_INT_POL_ADDR(ALT_FPGAMGR_MON_ADDR)
2511/* The address of the ALT_MON_GPIO_INTSTAT register for the ALT_FPGAMGR_MON instance. */
2512#define ALT_FPGAMGR_MON_GPIO_INTSTAT_ADDR ALT_MON_GPIO_INTSTAT_ADDR(ALT_FPGAMGR_MON_ADDR)
2513/* The address of the ALT_MON_GPIO_RAW_INTSTAT register for the ALT_FPGAMGR_MON instance. */
2514#define ALT_FPGAMGR_MON_GPIO_RAW_INTSTAT_ADDR ALT_MON_GPIO_RAW_INTSTAT_ADDR(ALT_FPGAMGR_MON_ADDR)
2515/* The address of the ALT_MON_GPIO_PORTA_EOI register for the ALT_FPGAMGR_MON instance. */
2516#define ALT_FPGAMGR_MON_GPIO_PORTA_EOI_ADDR ALT_MON_GPIO_PORTA_EOI_ADDR(ALT_FPGAMGR_MON_ADDR)
2517/* The address of the ALT_MON_GPIO_EXT_PORTA register for the ALT_FPGAMGR_MON instance. */
2518#define ALT_FPGAMGR_MON_GPIO_EXT_PORTA_ADDR ALT_MON_GPIO_EXT_PORTA_ADDR(ALT_FPGAMGR_MON_ADDR)
2519/* The address of the ALT_MON_GPIO_LS_SYNC register for the ALT_FPGAMGR_MON instance. */
2520#define ALT_FPGAMGR_MON_GPIO_LS_SYNC_ADDR ALT_MON_GPIO_LS_SYNC_ADDR(ALT_FPGAMGR_MON_ADDR)
2521/* The address of the ALT_MON_GPIO_VER_ID_CODE register for the ALT_FPGAMGR_MON instance. */
2522#define ALT_FPGAMGR_MON_GPIO_VER_ID_CODE_ADDR ALT_MON_GPIO_VER_ID_CODE_ADDR(ALT_FPGAMGR_MON_ADDR)
2523/* The address of the ALT_MON_GPIO_CFG_REG2 register for the ALT_FPGAMGR_MON instance. */
2524#define ALT_FPGAMGR_MON_GPIO_CFG_REG2_ADDR ALT_MON_GPIO_CFG_REG2_ADDR(ALT_FPGAMGR_MON_ADDR)
2525/* The address of the ALT_MON_GPIO_CFG_REG1 register for the ALT_FPGAMGR_MON instance. */
2526#define ALT_FPGAMGR_MON_GPIO_CFG_REG1_ADDR ALT_MON_GPIO_CFG_REG1_ADDR(ALT_FPGAMGR_MON_ADDR)
2527/* The base address byte offset for the start of the ALT_FPGAMGR_MON component. */
2528#define ALT_FPGAMGR_MON_OFST 0x800
2529/* The start address of the ALT_FPGAMGR_MON component. */
2530#define ALT_FPGAMGR_MON_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_MON_OFST))
2531/* The lower bound address range of the ALT_FPGAMGR_MON component. */
2532#define ALT_FPGAMGR_MON_LB_ADDR ALT_FPGAMGR_MON_ADDR
2533/* The upper bound address range of the ALT_FPGAMGR_MON component. */
2534#define ALT_FPGAMGR_MON_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_FPGAMGR_MON_ADDR) + 0x80) - 1))
2535
2536
2537/* The base address byte offset for the start of the ALT_FPGAMGR component. */
2538#define ALT_FPGAMGR_OFST 0xff706000
2539/* The start address of the ALT_FPGAMGR component. */
2540#define ALT_FPGAMGR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_FPGAMGR_OFST))
2541/* The lower bound address range of the ALT_FPGAMGR component. */
2542#define ALT_FPGAMGR_LB_ADDR ALT_FPGAMGR_ADDR
2543/* The upper bound address range of the ALT_FPGAMGR component. */
2544#define ALT_FPGAMGR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_FPGAMGR_ADDR) + 0x1000) - 1))
2545
2546
2547/*
2548 * Component Instance : acpidmap
2549 *
2550 * Instance acpidmap of component ALT_ACPIDMAP.
2551 *
2552 *
2553 */
2554/* The address of the ALT_ACPIDMAP_VID2RD register for the ALT_ACPIDMAP instance. */
2555#define ALT_ACPIDMAP_VID2RD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID2RD_OFST))
2556/* The address of the ALT_ACPIDMAP_VID2WR register for the ALT_ACPIDMAP instance. */
2557#define ALT_ACPIDMAP_VID2WR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID2WR_OFST))
2558/* The address of the ALT_ACPIDMAP_VID3RD register for the ALT_ACPIDMAP instance. */
2559#define ALT_ACPIDMAP_VID3RD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID3RD_OFST))
2560/* The address of the ALT_ACPIDMAP_VID3WR register for the ALT_ACPIDMAP instance. */
2561#define ALT_ACPIDMAP_VID3WR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID3WR_OFST))
2562/* The address of the ALT_ACPIDMAP_VID4RD register for the ALT_ACPIDMAP instance. */
2563#define ALT_ACPIDMAP_VID4RD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID4RD_OFST))
2564/* The address of the ALT_ACPIDMAP_VID4WR register for the ALT_ACPIDMAP instance. */
2565#define ALT_ACPIDMAP_VID4WR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID4WR_OFST))
2566/* The address of the ALT_ACPIDMAP_VID5RD register for the ALT_ACPIDMAP instance. */
2567#define ALT_ACPIDMAP_VID5RD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID5RD_OFST))
2568/* The address of the ALT_ACPIDMAP_VID5WR register for the ALT_ACPIDMAP instance. */
2569#define ALT_ACPIDMAP_VID5WR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID5WR_OFST))
2570/* The address of the ALT_ACPIDMAP_VID6RD register for the ALT_ACPIDMAP instance. */
2571#define ALT_ACPIDMAP_VID6RD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID6RD_OFST))
2572/* The address of the ALT_ACPIDMAP_VID6WR register for the ALT_ACPIDMAP instance. */
2573#define ALT_ACPIDMAP_VID6WR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID6WR_OFST))
2574/* The address of the ALT_ACPIDMAP_DYNRD register for the ALT_ACPIDMAP instance. */
2575#define ALT_ACPIDMAP_DYNRD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_DYNRD_OFST))
2576/* The address of the ALT_ACPIDMAP_DYNWR register for the ALT_ACPIDMAP instance. */
2577#define ALT_ACPIDMAP_DYNWR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_DYNWR_OFST))
2578/* The address of the ALT_ACPIDMAP_VID2RD_S register for the ALT_ACPIDMAP instance. */
2579#define ALT_ACPIDMAP_VID2RD_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID2RD_S_OFST))
2580/* The address of the ALT_ACPIDMAP_VID2WR_S register for the ALT_ACPIDMAP instance. */
2581#define ALT_ACPIDMAP_VID2WR_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID2WR_S_OFST))
2582/* The address of the ALT_ACPIDMAP_VID3RD_S register for the ALT_ACPIDMAP instance. */
2583#define ALT_ACPIDMAP_VID3RD_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID3RD_S_OFST))
2584/* The address of the ALT_ACPIDMAP_VID3WR_S register for the ALT_ACPIDMAP instance. */
2585#define ALT_ACPIDMAP_VID3WR_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID3WR_S_OFST))
2586/* The address of the ALT_ACPIDMAP_VID4RD_S register for the ALT_ACPIDMAP instance. */
2587#define ALT_ACPIDMAP_VID4RD_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID4RD_S_OFST))
2588/* The address of the ALT_ACPIDMAP_VID4WR_S register for the ALT_ACPIDMAP instance. */
2589#define ALT_ACPIDMAP_VID4WR_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID4WR_S_OFST))
2590/* The address of the ALT_ACPIDMAP_VID5RD_S register for the ALT_ACPIDMAP instance. */
2591#define ALT_ACPIDMAP_VID5RD_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID5RD_S_OFST))
2592/* The address of the ALT_ACPIDMAP_VID5WR_S register for the ALT_ACPIDMAP instance. */
2593#define ALT_ACPIDMAP_VID5WR_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID5WR_S_OFST))
2594/* The address of the ALT_ACPIDMAP_VID6RD_S register for the ALT_ACPIDMAP instance. */
2595#define ALT_ACPIDMAP_VID6RD_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID6RD_S_OFST))
2596/* The address of the ALT_ACPIDMAP_VID6WR_S register for the ALT_ACPIDMAP instance. */
2597#define ALT_ACPIDMAP_VID6WR_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID6WR_S_OFST))
2598/* The address of the ALT_ACPIDMAP_DYNRD_S register for the ALT_ACPIDMAP instance. */
2599#define ALT_ACPIDMAP_DYNRD_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_DYNRD_S_OFST))
2600/* The address of the ALT_ACPIDMAP_DYNWR_S register for the ALT_ACPIDMAP instance. */
2601#define ALT_ACPIDMAP_DYNWR_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_DYNWR_S_OFST))
2602/* The base address byte offset for the start of the ALT_ACPIDMAP component. */
2603#define ALT_ACPIDMAP_OFST 0xff707000
2604/* The start address of the ALT_ACPIDMAP component. */
2605#define ALT_ACPIDMAP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_ACPIDMAP_OFST))
2606/* The lower bound address range of the ALT_ACPIDMAP component. */
2607#define ALT_ACPIDMAP_LB_ADDR ALT_ACPIDMAP_ADDR
2608/* The upper bound address range of the ALT_ACPIDMAP component. */
2609#define ALT_ACPIDMAP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + 0x1000) - 1))
2610
2611
2612/*
2613 * Component Instance : gpio0
2614 *
2615 * Instance gpio0 of component ALT_GPIO.
2616 *
2617 *
2618 */
2619/* The address of the ALT_GPIO_SWPORTA_DR register for the ALT_GPIO0 instance. */
2620#define ALT_GPIO0_SWPORTA_DR_ADDR ALT_GPIO_SWPORTA_DR_ADDR(ALT_GPIO0_ADDR)
2621/* The address of the ALT_GPIO_SWPORTA_DDR register for the ALT_GPIO0 instance. */
2622#define ALT_GPIO0_SWPORTA_DDR_ADDR ALT_GPIO_SWPORTA_DDR_ADDR(ALT_GPIO0_ADDR)
2623/* The address of the ALT_GPIO_INTEN register for the ALT_GPIO0 instance. */
2624#define ALT_GPIO0_INTEN_ADDR ALT_GPIO_INTEN_ADDR(ALT_GPIO0_ADDR)
2625/* The address of the ALT_GPIO_INTMSK register for the ALT_GPIO0 instance. */
2626#define ALT_GPIO0_INTMSK_ADDR ALT_GPIO_INTMSK_ADDR(ALT_GPIO0_ADDR)
2627/* The address of the ALT_GPIO_INTTYPE_LEVEL register for the ALT_GPIO0 instance. */
2628#define ALT_GPIO0_INTTYPE_LEVEL_ADDR ALT_GPIO_INTTYPE_LEVEL_ADDR(ALT_GPIO0_ADDR)
2629/* The address of the ALT_GPIO_INT_POL register for the ALT_GPIO0 instance. */
2630#define ALT_GPIO0_INT_POL_ADDR ALT_GPIO_INT_POL_ADDR(ALT_GPIO0_ADDR)
2631/* The address of the ALT_GPIO_INTSTAT register for the ALT_GPIO0 instance. */
2632#define ALT_GPIO0_INTSTAT_ADDR ALT_GPIO_INTSTAT_ADDR(ALT_GPIO0_ADDR)
2633/* The address of the ALT_GPIO_RAW_INTSTAT register for the ALT_GPIO0 instance. */
2634#define ALT_GPIO0_RAW_INTSTAT_ADDR ALT_GPIO_RAW_INTSTAT_ADDR(ALT_GPIO0_ADDR)
2635/* The address of the ALT_GPIO_DEBOUNCE register for the ALT_GPIO0 instance. */
2636#define ALT_GPIO0_DEBOUNCE_ADDR ALT_GPIO_DEBOUNCE_ADDR(ALT_GPIO0_ADDR)
2637/* The address of the ALT_GPIO_PORTA_EOI register for the ALT_GPIO0 instance. */
2638#define ALT_GPIO0_PORTA_EOI_ADDR ALT_GPIO_PORTA_EOI_ADDR(ALT_GPIO0_ADDR)
2639/* The address of the ALT_GPIO_EXT_PORTA register for the ALT_GPIO0 instance. */
2640#define ALT_GPIO0_EXT_PORTA_ADDR ALT_GPIO_EXT_PORTA_ADDR(ALT_GPIO0_ADDR)
2641/* The address of the ALT_GPIO_LS_SYNC register for the ALT_GPIO0 instance. */
2642#define ALT_GPIO0_LS_SYNC_ADDR ALT_GPIO_LS_SYNC_ADDR(ALT_GPIO0_ADDR)
2643/* The address of the ALT_GPIO_ID_CODE register for the ALT_GPIO0 instance. */
2644#define ALT_GPIO0_ID_CODE_ADDR ALT_GPIO_ID_CODE_ADDR(ALT_GPIO0_ADDR)
2645/* The address of the ALT_GPIO_VER_ID_CODE register for the ALT_GPIO0 instance. */
2646#define ALT_GPIO0_VER_ID_CODE_ADDR ALT_GPIO_VER_ID_CODE_ADDR(ALT_GPIO0_ADDR)
2647/* The address of the ALT_GPIO_CFG_REG2 register for the ALT_GPIO0 instance. */
2648#define ALT_GPIO0_CFG_REG2_ADDR ALT_GPIO_CFG_REG2_ADDR(ALT_GPIO0_ADDR)
2649/* The address of the ALT_GPIO_CFG_REG1 register for the ALT_GPIO0 instance. */
2650#define ALT_GPIO0_CFG_REG1_ADDR ALT_GPIO_CFG_REG1_ADDR(ALT_GPIO0_ADDR)
2651/* The base address byte offset for the start of the ALT_GPIO0 component. */
2652#define ALT_GPIO0_OFST 0xff708000
2653/* The start address of the ALT_GPIO0 component. */
2654#define ALT_GPIO0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_GPIO0_OFST))
2655/* The lower bound address range of the ALT_GPIO0 component. */
2656#define ALT_GPIO0_LB_ADDR ALT_GPIO0_ADDR
2657/* The upper bound address range of the ALT_GPIO0 component. */
2658#define ALT_GPIO0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_GPIO0_ADDR) + 0x80) - 1))
2659
2660
2661/*
2662 * Component Instance : gpio1
2663 *
2664 * Instance gpio1 of component ALT_GPIO.
2665 *
2666 *
2667 */
2668/* The address of the ALT_GPIO_SWPORTA_DR register for the ALT_GPIO1 instance. */
2669#define ALT_GPIO1_SWPORTA_DR_ADDR ALT_GPIO_SWPORTA_DR_ADDR(ALT_GPIO1_ADDR)
2670/* The address of the ALT_GPIO_SWPORTA_DDR register for the ALT_GPIO1 instance. */
2671#define ALT_GPIO1_SWPORTA_DDR_ADDR ALT_GPIO_SWPORTA_DDR_ADDR(ALT_GPIO1_ADDR)
2672/* The address of the ALT_GPIO_INTEN register for the ALT_GPIO1 instance. */
2673#define ALT_GPIO1_INTEN_ADDR ALT_GPIO_INTEN_ADDR(ALT_GPIO1_ADDR)
2674/* The address of the ALT_GPIO_INTMSK register for the ALT_GPIO1 instance. */
2675#define ALT_GPIO1_INTMSK_ADDR ALT_GPIO_INTMSK_ADDR(ALT_GPIO1_ADDR)
2676/* The address of the ALT_GPIO_INTTYPE_LEVEL register for the ALT_GPIO1 instance. */
2677#define ALT_GPIO1_INTTYPE_LEVEL_ADDR ALT_GPIO_INTTYPE_LEVEL_ADDR(ALT_GPIO1_ADDR)
2678/* The address of the ALT_GPIO_INT_POL register for the ALT_GPIO1 instance. */
2679#define ALT_GPIO1_INT_POL_ADDR ALT_GPIO_INT_POL_ADDR(ALT_GPIO1_ADDR)
2680/* The address of the ALT_GPIO_INTSTAT register for the ALT_GPIO1 instance. */
2681#define ALT_GPIO1_INTSTAT_ADDR ALT_GPIO_INTSTAT_ADDR(ALT_GPIO1_ADDR)
2682/* The address of the ALT_GPIO_RAW_INTSTAT register for the ALT_GPIO1 instance. */
2683#define ALT_GPIO1_RAW_INTSTAT_ADDR ALT_GPIO_RAW_INTSTAT_ADDR(ALT_GPIO1_ADDR)
2684/* The address of the ALT_GPIO_DEBOUNCE register for the ALT_GPIO1 instance. */
2685#define ALT_GPIO1_DEBOUNCE_ADDR ALT_GPIO_DEBOUNCE_ADDR(ALT_GPIO1_ADDR)
2686/* The address of the ALT_GPIO_PORTA_EOI register for the ALT_GPIO1 instance. */
2687#define ALT_GPIO1_PORTA_EOI_ADDR ALT_GPIO_PORTA_EOI_ADDR(ALT_GPIO1_ADDR)
2688/* The address of the ALT_GPIO_EXT_PORTA register for the ALT_GPIO1 instance. */
2689#define ALT_GPIO1_EXT_PORTA_ADDR ALT_GPIO_EXT_PORTA_ADDR(ALT_GPIO1_ADDR)
2690/* The address of the ALT_GPIO_LS_SYNC register for the ALT_GPIO1 instance. */
2691#define ALT_GPIO1_LS_SYNC_ADDR ALT_GPIO_LS_SYNC_ADDR(ALT_GPIO1_ADDR)
2692/* The address of the ALT_GPIO_ID_CODE register for the ALT_GPIO1 instance. */
2693#define ALT_GPIO1_ID_CODE_ADDR ALT_GPIO_ID_CODE_ADDR(ALT_GPIO1_ADDR)
2694/* The address of the ALT_GPIO_VER_ID_CODE register for the ALT_GPIO1 instance. */
2695#define ALT_GPIO1_VER_ID_CODE_ADDR ALT_GPIO_VER_ID_CODE_ADDR(ALT_GPIO1_ADDR)
2696/* The address of the ALT_GPIO_CFG_REG2 register for the ALT_GPIO1 instance. */
2697#define ALT_GPIO1_CFG_REG2_ADDR ALT_GPIO_CFG_REG2_ADDR(ALT_GPIO1_ADDR)
2698/* The address of the ALT_GPIO_CFG_REG1 register for the ALT_GPIO1 instance. */
2699#define ALT_GPIO1_CFG_REG1_ADDR ALT_GPIO_CFG_REG1_ADDR(ALT_GPIO1_ADDR)
2700/* The base address byte offset for the start of the ALT_GPIO1 component. */
2701#define ALT_GPIO1_OFST 0xff709000
2702/* The start address of the ALT_GPIO1 component. */
2703#define ALT_GPIO1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_GPIO1_OFST))
2704/* The lower bound address range of the ALT_GPIO1 component. */
2705#define ALT_GPIO1_LB_ADDR ALT_GPIO1_ADDR
2706/* The upper bound address range of the ALT_GPIO1 component. */
2707#define ALT_GPIO1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_GPIO1_ADDR) + 0x80) - 1))
2708
2709
2710/*
2711 * Component Instance : gpio2
2712 *
2713 * Instance gpio2 of component ALT_GPIO.
2714 *
2715 *
2716 */
2717/* The address of the ALT_GPIO_SWPORTA_DR register for the ALT_GPIO2 instance. */
2718#define ALT_GPIO2_SWPORTA_DR_ADDR ALT_GPIO_SWPORTA_DR_ADDR(ALT_GPIO2_ADDR)
2719/* The address of the ALT_GPIO_SWPORTA_DDR register for the ALT_GPIO2 instance. */
2720#define ALT_GPIO2_SWPORTA_DDR_ADDR ALT_GPIO_SWPORTA_DDR_ADDR(ALT_GPIO2_ADDR)
2721/* The address of the ALT_GPIO_INTEN register for the ALT_GPIO2 instance. */
2722#define ALT_GPIO2_INTEN_ADDR ALT_GPIO_INTEN_ADDR(ALT_GPIO2_ADDR)
2723/* The address of the ALT_GPIO_INTMSK register for the ALT_GPIO2 instance. */
2724#define ALT_GPIO2_INTMSK_ADDR ALT_GPIO_INTMSK_ADDR(ALT_GPIO2_ADDR)
2725/* The address of the ALT_GPIO_INTTYPE_LEVEL register for the ALT_GPIO2 instance. */
2726#define ALT_GPIO2_INTTYPE_LEVEL_ADDR ALT_GPIO_INTTYPE_LEVEL_ADDR(ALT_GPIO2_ADDR)
2727/* The address of the ALT_GPIO_INT_POL register for the ALT_GPIO2 instance. */
2728#define ALT_GPIO2_INT_POL_ADDR ALT_GPIO_INT_POL_ADDR(ALT_GPIO2_ADDR)
2729/* The address of the ALT_GPIO_INTSTAT register for the ALT_GPIO2 instance. */
2730#define ALT_GPIO2_INTSTAT_ADDR ALT_GPIO_INTSTAT_ADDR(ALT_GPIO2_ADDR)
2731/* The address of the ALT_GPIO_RAW_INTSTAT register for the ALT_GPIO2 instance. */
2732#define ALT_GPIO2_RAW_INTSTAT_ADDR ALT_GPIO_RAW_INTSTAT_ADDR(ALT_GPIO2_ADDR)
2733/* The address of the ALT_GPIO_DEBOUNCE register for the ALT_GPIO2 instance. */
2734#define ALT_GPIO2_DEBOUNCE_ADDR ALT_GPIO_DEBOUNCE_ADDR(ALT_GPIO2_ADDR)
2735/* The address of the ALT_GPIO_PORTA_EOI register for the ALT_GPIO2 instance. */
2736#define ALT_GPIO2_PORTA_EOI_ADDR ALT_GPIO_PORTA_EOI_ADDR(ALT_GPIO2_ADDR)
2737/* The address of the ALT_GPIO_EXT_PORTA register for the ALT_GPIO2 instance. */
2738#define ALT_GPIO2_EXT_PORTA_ADDR ALT_GPIO_EXT_PORTA_ADDR(ALT_GPIO2_ADDR)
2739/* The address of the ALT_GPIO_LS_SYNC register for the ALT_GPIO2 instance. */
2740#define ALT_GPIO2_LS_SYNC_ADDR ALT_GPIO_LS_SYNC_ADDR(ALT_GPIO2_ADDR)
2741/* The address of the ALT_GPIO_ID_CODE register for the ALT_GPIO2 instance. */
2742#define ALT_GPIO2_ID_CODE_ADDR ALT_GPIO_ID_CODE_ADDR(ALT_GPIO2_ADDR)
2743/* The address of the ALT_GPIO_VER_ID_CODE register for the ALT_GPIO2 instance. */
2744#define ALT_GPIO2_VER_ID_CODE_ADDR ALT_GPIO_VER_ID_CODE_ADDR(ALT_GPIO2_ADDR)
2745/* The address of the ALT_GPIO_CFG_REG2 register for the ALT_GPIO2 instance. */
2746#define ALT_GPIO2_CFG_REG2_ADDR ALT_GPIO_CFG_REG2_ADDR(ALT_GPIO2_ADDR)
2747/* The address of the ALT_GPIO_CFG_REG1 register for the ALT_GPIO2 instance. */
2748#define ALT_GPIO2_CFG_REG1_ADDR ALT_GPIO_CFG_REG1_ADDR(ALT_GPIO2_ADDR)
2749/* The base address byte offset for the start of the ALT_GPIO2 component. */
2750#define ALT_GPIO2_OFST 0xff70a000
2751/* The start address of the ALT_GPIO2 component. */
2752#define ALT_GPIO2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_GPIO2_OFST))
2753/* The lower bound address range of the ALT_GPIO2 component. */
2754#define ALT_GPIO2_LB_ADDR ALT_GPIO2_ADDR
2755/* The upper bound address range of the ALT_GPIO2 component. */
2756#define ALT_GPIO2_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_GPIO2_ADDR) + 0x80) - 1))
2757
2758
2759/*
2760 * Component Instance : l3regs
2761 *
2762 * Instance l3regs of component ALT_L3.
2763 *
2764 *
2765 */
2766/* The address of the ALT_L3_REMAP register for the ALT_L3 instance. */
2767#define ALT_L3_REMAP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_ADDR) + ALT_L3_REMAP_OFST))
2768/*
2769 * Register Group Instance : secgrp
2770 *
2771 * Instance secgrp of register group ALT_L3_SECGRP.
2772 *
2773 *
2774 */
2775/* The address of the ALT_L3_SEC_L4MAIN register for the ALT_L3_SECGRP instance. */
2776#define ALT_L3_SEC_L4MAIN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_L4MAIN_OFST))
2777/* The address of the ALT_L3_SEC_L4SP register for the ALT_L3_SECGRP instance. */
2778#define ALT_L3_SEC_L4SP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_L4SP_OFST))
2779/* The address of the ALT_L3_SEC_L4MP register for the ALT_L3_SECGRP instance. */
2780#define ALT_L3_SEC_L4MP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_L4MP_OFST))
2781/* The address of the ALT_L3_SEC_L4OSC1 register for the ALT_L3_SECGRP instance. */
2782#define ALT_L3_SEC_L4OSC1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_L4OSC1_OFST))
2783/* The address of the ALT_L3_SEC_L4SPIM register for the ALT_L3_SECGRP instance. */
2784#define ALT_L3_SEC_L4SPIM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_L4SPIM_OFST))
2785/* The address of the ALT_L3_SEC_STM register for the ALT_L3_SECGRP instance. */
2786#define ALT_L3_SEC_STM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_STM_OFST))
2787/* The address of the ALT_L3_SEC_LWH2F register for the ALT_L3_SECGRP instance. */
2788#define ALT_L3_SEC_LWH2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_LWH2F_OFST))
2789/* The address of the ALT_L3_SEC_USB1 register for the ALT_L3_SECGRP instance. */
2790#define ALT_L3_SEC_USB1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_USB1_OFST))
2791/* The address of the ALT_L3_SEC_NANDDATA register for the ALT_L3_SECGRP instance. */
2792#define ALT_L3_SEC_NANDDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_NANDDATA_OFST))
2793/* The address of the ALT_L3_SEC_USB0 register for the ALT_L3_SECGRP instance. */
2794#define ALT_L3_SEC_USB0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_USB0_OFST))
2795/* The address of the ALT_L3_SEC_NAND register for the ALT_L3_SECGRP instance. */
2796#define ALT_L3_SEC_NAND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_NAND_OFST))
2797/* The address of the ALT_L3_SEC_QSPIDATA register for the ALT_L3_SECGRP instance. */
2798#define ALT_L3_SEC_QSPIDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_QSPIDATA_OFST))
2799/* The address of the ALT_L3_SEC_FPGAMGRDATA register for the ALT_L3_SECGRP instance. */
2800#define ALT_L3_SEC_FPGAMGRDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_FPGAMGRDATA_OFST))
2801/* The address of the ALT_L3_SEC_H2F register for the ALT_L3_SECGRP instance. */
2802#define ALT_L3_SEC_H2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_H2F_OFST))
2803/* The address of the ALT_L3_SEC_ACP register for the ALT_L3_SECGRP instance. */
2804#define ALT_L3_SEC_ACP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_ACP_OFST))
2805/* The address of the ALT_L3_SEC_ROM register for the ALT_L3_SECGRP instance. */
2806#define ALT_L3_SEC_ROM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_ROM_OFST))
2807/* The address of the ALT_L3_SEC_OCRAM register for the ALT_L3_SECGRP instance. */
2808#define ALT_L3_SEC_OCRAM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_OCRAM_OFST))
2809/* The address of the ALT_L3_SEC_SDRDATA register for the ALT_L3_SECGRP instance. */
2810#define ALT_L3_SEC_SDRDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_SDRDATA_OFST))
2811/* The base address byte offset for the start of the ALT_L3_SECGRP component. */
2812#define ALT_L3_SECGRP_OFST 0x8
2813/* The start address of the ALT_L3_SECGRP component. */
2814#define ALT_L3_SECGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_ADDR) + ALT_L3_SECGRP_OFST))
2815/* The lower bound address range of the ALT_L3_SECGRP component. */
2816#define ALT_L3_SECGRP_LB_ADDR ALT_L3_SECGRP_ADDR
2817/* The upper bound address range of the ALT_L3_SECGRP component. */
2818#define ALT_L3_SECGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + 0x9c) - 1))
2819
2820
2821/*
2822 * Register Group Instance : idgrp
2823 *
2824 * Instance idgrp of register group ALT_L3_IDGRP.
2825 *
2826 *
2827 */
2828/* The address of the ALT_L3_ID_PERIPH_ID_4 register for the ALT_L3_IDGRP instance. */
2829#define ALT_L3_ID_PERIPH_ID_4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_PERIPH_ID_4_OFST))
2830/* The address of the ALT_L3_ID_PERIPH_ID_0 register for the ALT_L3_IDGRP instance. */
2831#define ALT_L3_ID_PERIPH_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_PERIPH_ID_0_OFST))
2832/* The address of the ALT_L3_ID_PERIPH_ID_1 register for the ALT_L3_IDGRP instance. */
2833#define ALT_L3_ID_PERIPH_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_PERIPH_ID_1_OFST))
2834/* The address of the ALT_L3_ID_PERIPH_ID_2 register for the ALT_L3_IDGRP instance. */
2835#define ALT_L3_ID_PERIPH_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_PERIPH_ID_2_OFST))
2836/* The address of the ALT_L3_ID_PERIPH_ID_3 register for the ALT_L3_IDGRP instance. */
2837#define ALT_L3_ID_PERIPH_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_PERIPH_ID_3_OFST))
2838/* The address of the ALT_L3_ID_COMP_ID_0 register for the ALT_L3_IDGRP instance. */
2839#define ALT_L3_ID_COMP_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_COMP_ID_0_OFST))
2840/* The address of the ALT_L3_ID_COMP_ID_1 register for the ALT_L3_IDGRP instance. */
2841#define ALT_L3_ID_COMP_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_COMP_ID_1_OFST))
2842/* The address of the ALT_L3_ID_COMP_ID_2 register for the ALT_L3_IDGRP instance. */
2843#define ALT_L3_ID_COMP_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_COMP_ID_2_OFST))
2844/* The address of the ALT_L3_ID_COMP_ID_3 register for the ALT_L3_IDGRP instance. */
2845#define ALT_L3_ID_COMP_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_COMP_ID_3_OFST))
2846/* The base address byte offset for the start of the ALT_L3_IDGRP component. */
2847#define ALT_L3_IDGRP_OFST 0x1000
2848/* The start address of the ALT_L3_IDGRP component. */
2849#define ALT_L3_IDGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_ADDR) + ALT_L3_IDGRP_OFST))
2850/* The lower bound address range of the ALT_L3_IDGRP component. */
2851#define ALT_L3_IDGRP_LB_ADDR ALT_L3_IDGRP_ADDR
2852/* The upper bound address range of the ALT_L3_IDGRP component. */
2853#define ALT_L3_IDGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + 0x1000) - 1))
2854
2855
2856/*
2857 * Register Group Instance : mastergrp
2858 *
2859 * Instance mastergrp of register group ALT_L3_MSTGRP.
2860 *
2861 *
2862 */
2863/*
2864 * Register Group Instance : mastergrp_l4main
2865 *
2866 * Instance mastergrp_l4main of register group ALT_L3_MST_L4MAIN.
2867 *
2868 *
2869 */
2870/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_L4MAIN instance. */
2871#define ALT_L3_MST_MST_L4MAIN_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_L4MAIN_ADDR)
2872/* The base address byte offset for the start of the ALT_L3_MST_MST_L4MAIN component. */
2873#define ALT_L3_MST_MST_L4MAIN_OFST 0x0
2874/* The start address of the ALT_L3_MST_MST_L4MAIN component. */
2875#define ALT_L3_MST_MST_L4MAIN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_L4MAIN_OFST))
2876/* The lower bound address range of the ALT_L3_MST_MST_L4MAIN component. */
2877#define ALT_L3_MST_MST_L4MAIN_LB_ADDR ALT_L3_MST_MST_L4MAIN_ADDR
2878/* The upper bound address range of the ALT_L3_MST_MST_L4MAIN component. */
2879#define ALT_L3_MST_MST_L4MAIN_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_L4MAIN_ADDR) + 0xc) - 1))
2880
2881
2882/*
2883 * Register Group Instance : mastergrp_l4sp
2884 *
2885 * Instance mastergrp_l4sp of register group ALT_L3_MST_L4SP.
2886 *
2887 *
2888 */
2889/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_L4SP instance. */
2890#define ALT_L3_MST_MST_L4SP_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_L4SP_ADDR)
2891/* The base address byte offset for the start of the ALT_L3_MST_MST_L4SP component. */
2892#define ALT_L3_MST_MST_L4SP_OFST 0x1000
2893/* The start address of the ALT_L3_MST_MST_L4SP component. */
2894#define ALT_L3_MST_MST_L4SP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_L4SP_OFST))
2895/* The lower bound address range of the ALT_L3_MST_MST_L4SP component. */
2896#define ALT_L3_MST_MST_L4SP_LB_ADDR ALT_L3_MST_MST_L4SP_ADDR
2897/* The upper bound address range of the ALT_L3_MST_MST_L4SP component. */
2898#define ALT_L3_MST_MST_L4SP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_L4SP_ADDR) + 0xc) - 1))
2899
2900
2901/*
2902 * Register Group Instance : mastergrp_l4mp
2903 *
2904 * Instance mastergrp_l4mp of register group ALT_L3_MST_L4MP.
2905 *
2906 *
2907 */
2908/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_L4MP instance. */
2909#define ALT_L3_MST_MST_L4MP_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_L4MP_ADDR)
2910/* The base address byte offset for the start of the ALT_L3_MST_MST_L4MP component. */
2911#define ALT_L3_MST_MST_L4MP_OFST 0x2000
2912/* The start address of the ALT_L3_MST_MST_L4MP component. */
2913#define ALT_L3_MST_MST_L4MP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_L4MP_OFST))
2914/* The lower bound address range of the ALT_L3_MST_MST_L4MP component. */
2915#define ALT_L3_MST_MST_L4MP_LB_ADDR ALT_L3_MST_MST_L4MP_ADDR
2916/* The upper bound address range of the ALT_L3_MST_MST_L4MP component. */
2917#define ALT_L3_MST_MST_L4MP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_L4MP_ADDR) + 0xc) - 1))
2918
2919
2920/*
2921 * Register Group Instance : mastergrp_l4osc1
2922 *
2923 * Instance mastergrp_l4osc1 of register group ALT_L3_MST_L4OSC1.
2924 *
2925 *
2926 */
2927/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_L4OSC1 instance. */
2928#define ALT_L3_MST_MST_L4OSC1_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_L4OSC1_ADDR)
2929/* The base address byte offset for the start of the ALT_L3_MST_MST_L4OSC1 component. */
2930#define ALT_L3_MST_MST_L4OSC1_OFST 0x3000
2931/* The start address of the ALT_L3_MST_MST_L4OSC1 component. */
2932#define ALT_L3_MST_MST_L4OSC1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_L4OSC1_OFST))
2933/* The lower bound address range of the ALT_L3_MST_MST_L4OSC1 component. */
2934#define ALT_L3_MST_MST_L4OSC1_LB_ADDR ALT_L3_MST_MST_L4OSC1_ADDR
2935/* The upper bound address range of the ALT_L3_MST_MST_L4OSC1 component. */
2936#define ALT_L3_MST_MST_L4OSC1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_L4OSC1_ADDR) + 0xc) - 1))
2937
2938
2939/*
2940 * Register Group Instance : mastergrp_l4spim
2941 *
2942 * Instance mastergrp_l4spim of register group ALT_L3_MST_L4SPIM.
2943 *
2944 *
2945 */
2946/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_L4SPIM instance. */
2947#define ALT_L3_MST_MST_L4SPIM_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_L4SPIM_ADDR)
2948/* The base address byte offset for the start of the ALT_L3_MST_MST_L4SPIM component. */
2949#define ALT_L3_MST_MST_L4SPIM_OFST 0x4000
2950/* The start address of the ALT_L3_MST_MST_L4SPIM component. */
2951#define ALT_L3_MST_MST_L4SPIM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_L4SPIM_OFST))
2952/* The lower bound address range of the ALT_L3_MST_MST_L4SPIM component. */
2953#define ALT_L3_MST_MST_L4SPIM_LB_ADDR ALT_L3_MST_MST_L4SPIM_ADDR
2954/* The upper bound address range of the ALT_L3_MST_MST_L4SPIM component. */
2955#define ALT_L3_MST_MST_L4SPIM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_L4SPIM_ADDR) + 0xc) - 1))
2956
2957
2958/*
2959 * Register Group Instance : mastergrp_stm
2960 *
2961 * Instance mastergrp_stm of register group ALT_L3_MST_STM.
2962 *
2963 *
2964 */
2965/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_STM instance. */
2966#define ALT_L3_MST_MST_STM_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_STM_ADDR)
2967/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_STM instance. */
2968#define ALT_L3_MST_MST_STM_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_STM_ADDR)
2969/* The base address byte offset for the start of the ALT_L3_MST_MST_STM component. */
2970#define ALT_L3_MST_MST_STM_OFST 0x5000
2971/* The start address of the ALT_L3_MST_MST_STM component. */
2972#define ALT_L3_MST_MST_STM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_STM_OFST))
2973/* The lower bound address range of the ALT_L3_MST_MST_STM component. */
2974#define ALT_L3_MST_MST_STM_LB_ADDR ALT_L3_MST_MST_STM_ADDR
2975/* The upper bound address range of the ALT_L3_MST_MST_STM component. */
2976#define ALT_L3_MST_MST_STM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_STM_ADDR) + 0x10c) - 1))
2977
2978
2979/*
2980 * Register Group Instance : mastergrp_lwhps2fpga
2981 *
2982 * Instance mastergrp_lwhps2fpga of register group ALT_L3_MST_LWH2F.
2983 *
2984 *
2985 */
2986/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_LWH2F instance. */
2987#define ALT_L3_MST_MST_LWH2F_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_LWH2F_ADDR)
2988/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_LWH2F instance. */
2989#define ALT_L3_MST_MST_LWH2F_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_LWH2F_ADDR)
2990/* The base address byte offset for the start of the ALT_L3_MST_MST_LWH2F component. */
2991#define ALT_L3_MST_MST_LWH2F_OFST 0x6000
2992/* The start address of the ALT_L3_MST_MST_LWH2F component. */
2993#define ALT_L3_MST_MST_LWH2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_LWH2F_OFST))
2994/* The lower bound address range of the ALT_L3_MST_MST_LWH2F component. */
2995#define ALT_L3_MST_MST_LWH2F_LB_ADDR ALT_L3_MST_MST_LWH2F_ADDR
2996/* The upper bound address range of the ALT_L3_MST_MST_LWH2F component. */
2997#define ALT_L3_MST_MST_LWH2F_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_LWH2F_ADDR) + 0x10c) - 1))
2998
2999
3000/*
3001 * Register Group Instance : mastergrp_usb1
3002 *
3003 * Instance mastergrp_usb1 of register group ALT_L3_MST_USB1.
3004 *
3005 *
3006 */
3007/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_USB1 instance. */
3008#define ALT_L3_MST_MST_USB1_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_USB1_ADDR)
3009/* The address of the ALT_L3_AHB_CNTL register for the ALT_L3_MST_MST_USB1 instance. */
3010#define ALT_L3_MST_MST_USB1_AHB_CNTL_ADDR ALT_L3_AHB_CNTL_ADDR(ALT_L3_MST_MST_USB1_ADDR)
3011/* The base address byte offset for the start of the ALT_L3_MST_MST_USB1 component. */
3012#define ALT_L3_MST_MST_USB1_OFST 0x8000
3013/* The start address of the ALT_L3_MST_MST_USB1 component. */
3014#define ALT_L3_MST_MST_USB1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_USB1_OFST))
3015/* The lower bound address range of the ALT_L3_MST_MST_USB1 component. */
3016#define ALT_L3_MST_MST_USB1_LB_ADDR ALT_L3_MST_MST_USB1_ADDR
3017/* The upper bound address range of the ALT_L3_MST_MST_USB1 component. */
3018#define ALT_L3_MST_MST_USB1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_USB1_ADDR) + 0x48) - 1))
3019
3020
3021/*
3022 * Register Group Instance : mastergrp_nanddata
3023 *
3024 * Instance mastergrp_nanddata of register group ALT_L3_MST_NANDDATA.
3025 *
3026 *
3027 */
3028/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_NANDDATA instance. */
3029#define ALT_L3_MST_MST_NANDDATA_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_NANDDATA_ADDR)
3030/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_NANDDATA instance. */
3031#define ALT_L3_MST_MST_NANDDATA_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_NANDDATA_ADDR)
3032/* The base address byte offset for the start of the ALT_L3_MST_MST_NANDDATA component. */
3033#define ALT_L3_MST_MST_NANDDATA_OFST 0x9000
3034/* The start address of the ALT_L3_MST_MST_NANDDATA component. */
3035#define ALT_L3_MST_MST_NANDDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_NANDDATA_OFST))
3036/* The lower bound address range of the ALT_L3_MST_MST_NANDDATA component. */
3037#define ALT_L3_MST_MST_NANDDATA_LB_ADDR ALT_L3_MST_MST_NANDDATA_ADDR
3038/* The upper bound address range of the ALT_L3_MST_MST_NANDDATA component. */
3039#define ALT_L3_MST_MST_NANDDATA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_NANDDATA_ADDR) + 0x10c) - 1))
3040
3041
3042/*
3043 * Register Group Instance : mastergrp_usb0
3044 *
3045 * Instance mastergrp_usb0 of register group ALT_L3_MST_USB0.
3046 *
3047 *
3048 */
3049/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_USB0 instance. */
3050#define ALT_L3_MST_MST_USB0_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_USB0_ADDR)
3051/* The address of the ALT_L3_AHB_CNTL register for the ALT_L3_MST_MST_USB0 instance. */
3052#define ALT_L3_MST_MST_USB0_AHB_CNTL_ADDR ALT_L3_AHB_CNTL_ADDR(ALT_L3_MST_MST_USB0_ADDR)
3053/* The base address byte offset for the start of the ALT_L3_MST_MST_USB0 component. */
3054#define ALT_L3_MST_MST_USB0_OFST 0x1e000
3055/* The start address of the ALT_L3_MST_MST_USB0 component. */
3056#define ALT_L3_MST_MST_USB0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_USB0_OFST))
3057/* The lower bound address range of the ALT_L3_MST_MST_USB0 component. */
3058#define ALT_L3_MST_MST_USB0_LB_ADDR ALT_L3_MST_MST_USB0_ADDR
3059/* The upper bound address range of the ALT_L3_MST_MST_USB0 component. */
3060#define ALT_L3_MST_MST_USB0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_USB0_ADDR) + 0x48) - 1))
3061
3062
3063/*
3064 * Register Group Instance : mastergrp_nandregs
3065 *
3066 * Instance mastergrp_nandregs of register group ALT_L3_MST_NAND.
3067 *
3068 *
3069 */
3070/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_NAND instance. */
3071#define ALT_L3_MST_MST_NAND_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_NAND_ADDR)
3072/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_NAND instance. */
3073#define ALT_L3_MST_MST_NAND_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_NAND_ADDR)
3074/* The base address byte offset for the start of the ALT_L3_MST_MST_NAND component. */
3075#define ALT_L3_MST_MST_NAND_OFST 0x1f000
3076/* The start address of the ALT_L3_MST_MST_NAND component. */
3077#define ALT_L3_MST_MST_NAND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_NAND_OFST))
3078/* The lower bound address range of the ALT_L3_MST_MST_NAND component. */
3079#define ALT_L3_MST_MST_NAND_LB_ADDR ALT_L3_MST_MST_NAND_ADDR
3080/* The upper bound address range of the ALT_L3_MST_MST_NAND component. */
3081#define ALT_L3_MST_MST_NAND_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_NAND_ADDR) + 0x10c) - 1))
3082
3083
3084/*
3085 * Register Group Instance : mastergrp_qspidata
3086 *
3087 * Instance mastergrp_qspidata of register group ALT_L3_MST_QSPIDATA.
3088 *
3089 *
3090 */
3091/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_QSPIDATA instance. */
3092#define ALT_L3_MST_MST_QSPIDATA_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_QSPIDATA_ADDR)
3093/* The address of the ALT_L3_AHB_CNTL register for the ALT_L3_MST_MST_QSPIDATA instance. */
3094#define ALT_L3_MST_MST_QSPIDATA_AHB_CNTL_ADDR ALT_L3_AHB_CNTL_ADDR(ALT_L3_MST_MST_QSPIDATA_ADDR)
3095/* The base address byte offset for the start of the ALT_L3_MST_MST_QSPIDATA component. */
3096#define ALT_L3_MST_MST_QSPIDATA_OFST 0x20000
3097/* The start address of the ALT_L3_MST_MST_QSPIDATA component. */
3098#define ALT_L3_MST_MST_QSPIDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_QSPIDATA_OFST))
3099/* The lower bound address range of the ALT_L3_MST_MST_QSPIDATA component. */
3100#define ALT_L3_MST_MST_QSPIDATA_LB_ADDR ALT_L3_MST_MST_QSPIDATA_ADDR
3101/* The upper bound address range of the ALT_L3_MST_MST_QSPIDATA component. */
3102#define ALT_L3_MST_MST_QSPIDATA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_QSPIDATA_ADDR) + 0x48) - 1))
3103
3104
3105/*
3106 * Register Group Instance : mastergrp_fpgamgrdata
3107 *
3108 * Instance mastergrp_fpgamgrdata of register group ALT_L3_MST_FPGAMGRDATA.
3109 *
3110 *
3111 */
3112/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_FPGAMGRDATA instance. */
3113#define ALT_L3_MST_MST_FPGAMGRDATA_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_FPGAMGRDATA_ADDR)
3114/* The address of the ALT_L3_WR_TIDEMARK register for the ALT_L3_MST_MST_FPGAMGRDATA instance. */
3115#define ALT_L3_MST_MST_FPGAMGRDATA_WR_TIDEMARK_ADDR ALT_L3_WR_TIDEMARK_ADDR(ALT_L3_MST_MST_FPGAMGRDATA_ADDR)
3116/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_FPGAMGRDATA instance. */
3117#define ALT_L3_MST_MST_FPGAMGRDATA_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_FPGAMGRDATA_ADDR)
3118/* The base address byte offset for the start of the ALT_L3_MST_MST_FPGAMGRDATA component. */
3119#define ALT_L3_MST_MST_FPGAMGRDATA_OFST 0x21000
3120/* The start address of the ALT_L3_MST_MST_FPGAMGRDATA component. */
3121#define ALT_L3_MST_MST_FPGAMGRDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_FPGAMGRDATA_OFST))
3122/* The lower bound address range of the ALT_L3_MST_MST_FPGAMGRDATA component. */
3123#define ALT_L3_MST_MST_FPGAMGRDATA_LB_ADDR ALT_L3_MST_MST_FPGAMGRDATA_ADDR
3124/* The upper bound address range of the ALT_L3_MST_MST_FPGAMGRDATA component. */
3125#define ALT_L3_MST_MST_FPGAMGRDATA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_FPGAMGRDATA_ADDR) + 0x10c) - 1))
3126
3127
3128/*
3129 * Register Group Instance : mastergrp_hps2fpga
3130 *
3131 * Instance mastergrp_hps2fpga of register group ALT_L3_MST_H2F.
3132 *
3133 *
3134 */
3135/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_H2F instance. */
3136#define ALT_L3_MST_MST_H2F_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_H2F_ADDR)
3137/* The address of the ALT_L3_WR_TIDEMARK register for the ALT_L3_MST_MST_H2F instance. */
3138#define ALT_L3_MST_MST_H2F_WR_TIDEMARK_ADDR ALT_L3_WR_TIDEMARK_ADDR(ALT_L3_MST_MST_H2F_ADDR)
3139/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_H2F instance. */
3140#define ALT_L3_MST_MST_H2F_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_H2F_ADDR)
3141/* The base address byte offset for the start of the ALT_L3_MST_MST_H2F component. */
3142#define ALT_L3_MST_MST_H2F_OFST 0x22000
3143/* The start address of the ALT_L3_MST_MST_H2F component. */
3144#define ALT_L3_MST_MST_H2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_H2F_OFST))
3145/* The lower bound address range of the ALT_L3_MST_MST_H2F component. */
3146#define ALT_L3_MST_MST_H2F_LB_ADDR ALT_L3_MST_MST_H2F_ADDR
3147/* The upper bound address range of the ALT_L3_MST_MST_H2F component. */
3148#define ALT_L3_MST_MST_H2F_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_H2F_ADDR) + 0x10c) - 1))
3149
3150
3151/*
3152 * Register Group Instance : mastergrp_acp
3153 *
3154 * Instance mastergrp_acp of register group ALT_L3_MST_ACP.
3155 *
3156 *
3157 */
3158/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_ACP instance. */
3159#define ALT_L3_MST_MST_ACP_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_ACP_ADDR)
3160/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_ACP instance. */
3161#define ALT_L3_MST_MST_ACP_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_ACP_ADDR)
3162/* The base address byte offset for the start of the ALT_L3_MST_MST_ACP component. */
3163#define ALT_L3_MST_MST_ACP_OFST 0x23000
3164/* The start address of the ALT_L3_MST_MST_ACP component. */
3165#define ALT_L3_MST_MST_ACP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_ACP_OFST))
3166/* The lower bound address range of the ALT_L3_MST_MST_ACP component. */
3167#define ALT_L3_MST_MST_ACP_LB_ADDR ALT_L3_MST_MST_ACP_ADDR
3168/* The upper bound address range of the ALT_L3_MST_MST_ACP component. */
3169#define ALT_L3_MST_MST_ACP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_ACP_ADDR) + 0x10c) - 1))
3170
3171
3172/*
3173 * Register Group Instance : mastergrp_rom
3174 *
3175 * Instance mastergrp_rom of register group ALT_L3_MST_ROM.
3176 *
3177 *
3178 */
3179/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_ROM instance. */
3180#define ALT_L3_MST_MST_ROM_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_ROM_ADDR)
3181/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_ROM instance. */
3182#define ALT_L3_MST_MST_ROM_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_ROM_ADDR)
3183/* The base address byte offset for the start of the ALT_L3_MST_MST_ROM component. */
3184#define ALT_L3_MST_MST_ROM_OFST 0x24000
3185/* The start address of the ALT_L3_MST_MST_ROM component. */
3186#define ALT_L3_MST_MST_ROM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_ROM_OFST))
3187/* The lower bound address range of the ALT_L3_MST_MST_ROM component. */
3188#define ALT_L3_MST_MST_ROM_LB_ADDR ALT_L3_MST_MST_ROM_ADDR
3189/* The upper bound address range of the ALT_L3_MST_MST_ROM component. */
3190#define ALT_L3_MST_MST_ROM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_ROM_ADDR) + 0x10c) - 1))
3191
3192
3193/*
3194 * Register Group Instance : mastergrp_ocram
3195 *
3196 * Instance mastergrp_ocram of register group ALT_L3_MST_OCRAM.
3197 *
3198 *
3199 */
3200/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_OCRAM instance. */
3201#define ALT_L3_MST_MST_OCRAM_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_OCRAM_ADDR)
3202/* The address of the ALT_L3_WR_TIDEMARK register for the ALT_L3_MST_MST_OCRAM instance. */
3203#define ALT_L3_MST_MST_OCRAM_WR_TIDEMARK_ADDR ALT_L3_WR_TIDEMARK_ADDR(ALT_L3_MST_MST_OCRAM_ADDR)
3204/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_OCRAM instance. */
3205#define ALT_L3_MST_MST_OCRAM_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_OCRAM_ADDR)
3206/* The base address byte offset for the start of the ALT_L3_MST_MST_OCRAM component. */
3207#define ALT_L3_MST_MST_OCRAM_OFST 0x25000
3208/* The start address of the ALT_L3_MST_MST_OCRAM component. */
3209#define ALT_L3_MST_MST_OCRAM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_OCRAM_OFST))
3210/* The lower bound address range of the ALT_L3_MST_MST_OCRAM component. */
3211#define ALT_L3_MST_MST_OCRAM_LB_ADDR ALT_L3_MST_MST_OCRAM_ADDR
3212/* The upper bound address range of the ALT_L3_MST_MST_OCRAM component. */
3213#define ALT_L3_MST_MST_OCRAM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_OCRAM_ADDR) + 0x10c) - 1))
3214
3215
3216/* The base address byte offset for the start of the ALT_L3_MSTGRP component. */
3217#define ALT_L3_MSTGRP_OFST 0x2000
3218/* The start address of the ALT_L3_MSTGRP component. */
3219#define ALT_L3_MSTGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_ADDR) + ALT_L3_MSTGRP_OFST))
3220/* The lower bound address range of the ALT_L3_MSTGRP component. */
3221#define ALT_L3_MSTGRP_LB_ADDR ALT_L3_MSTGRP_ADDR
3222/* The upper bound address range of the ALT_L3_MSTGRP component. */
3223#define ALT_L3_MSTGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + 0x2510c) - 1))
3224
3225
3226/*
3227 * Register Group Instance : slavegrp
3228 *
3229 * Instance slavegrp of register group ALT_L3_SLVGRP.
3230 *
3231 *
3232 */
3233/*
3234 * Register Group Instance : slavegrp_dap
3235 *
3236 * Instance slavegrp_dap of register group ALT_L3_SLV_DAP.
3237 *
3238 *
3239 */
3240/* The address of the ALT_L3_FN_MOD2 register for the ALT_L3_SLV_SLV_DAP instance. */
3241#define ALT_L3_SLV_SLV_DAP_FN_MOD2_ADDR ALT_L3_FN_MOD2_ADDR(ALT_L3_SLV_SLV_DAP_ADDR)
3242/* The address of the ALT_L3_FN_MOD_AHB register for the ALT_L3_SLV_SLV_DAP instance. */
3243#define ALT_L3_SLV_SLV_DAP_FN_MOD_AHB_ADDR ALT_L3_FN_MOD_AHB_ADDR(ALT_L3_SLV_SLV_DAP_ADDR)
3244/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_DAP instance. */
3245#define ALT_L3_SLV_SLV_DAP_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_DAP_ADDR)
3246/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_DAP instance. */
3247#define ALT_L3_SLV_SLV_DAP_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_DAP_ADDR)
3248/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_DAP instance. */
3249#define ALT_L3_SLV_SLV_DAP_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_DAP_ADDR)
3250/* The base address byte offset for the start of the ALT_L3_SLV_SLV_DAP component. */
3251#define ALT_L3_SLV_SLV_DAP_OFST 0x0
3252/* The start address of the ALT_L3_SLV_SLV_DAP component. */
3253#define ALT_L3_SLV_SLV_DAP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_DAP_OFST))
3254/* The lower bound address range of the ALT_L3_SLV_SLV_DAP component. */
3255#define ALT_L3_SLV_SLV_DAP_LB_ADDR ALT_L3_SLV_SLV_DAP_ADDR
3256/* The upper bound address range of the ALT_L3_SLV_SLV_DAP component. */
3257#define ALT_L3_SLV_SLV_DAP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_DAP_ADDR) + 0x10c) - 1))
3258
3259
3260/*
3261 * Register Group Instance : slavegrp_mpu
3262 *
3263 * Instance slavegrp_mpu of register group ALT_L3_SLV_MPU.
3264 *
3265 *
3266 */
3267/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_MPU instance. */
3268#define ALT_L3_SLV_SLV_MPU_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_MPU_ADDR)
3269/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_MPU instance. */
3270#define ALT_L3_SLV_SLV_MPU_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_MPU_ADDR)
3271/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_MPU instance. */
3272#define ALT_L3_SLV_SLV_MPU_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_MPU_ADDR)
3273/* The base address byte offset for the start of the ALT_L3_SLV_SLV_MPU component. */
3274#define ALT_L3_SLV_SLV_MPU_OFST 0x1000
3275/* The start address of the ALT_L3_SLV_SLV_MPU component. */
3276#define ALT_L3_SLV_SLV_MPU_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_MPU_OFST))
3277/* The lower bound address range of the ALT_L3_SLV_SLV_MPU component. */
3278#define ALT_L3_SLV_SLV_MPU_LB_ADDR ALT_L3_SLV_SLV_MPU_ADDR
3279/* The upper bound address range of the ALT_L3_SLV_SLV_MPU component. */
3280#define ALT_L3_SLV_SLV_MPU_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_MPU_ADDR) + 0x10c) - 1))
3281
3282
3283/*
3284 * Register Group Instance : slavegrp_sdmmc
3285 *
3286 * Instance slavegrp_sdmmc of register group ALT_L3_SLV_SDMMC.
3287 *
3288 *
3289 */
3290/* The address of the ALT_L3_FN_MOD_AHB register for the ALT_L3_SLV_SLV_SDMMC instance. */
3291#define ALT_L3_SLV_SLV_SDMMC_FN_MOD_AHB_ADDR ALT_L3_FN_MOD_AHB_ADDR(ALT_L3_SLV_SLV_SDMMC_ADDR)
3292/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_SDMMC instance. */
3293#define ALT_L3_SLV_SLV_SDMMC_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_SDMMC_ADDR)
3294/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_SDMMC instance. */
3295#define ALT_L3_SLV_SLV_SDMMC_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_SDMMC_ADDR)
3296/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_SDMMC instance. */
3297#define ALT_L3_SLV_SLV_SDMMC_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_SDMMC_ADDR)
3298/* The base address byte offset for the start of the ALT_L3_SLV_SLV_SDMMC component. */
3299#define ALT_L3_SLV_SLV_SDMMC_OFST 0x2000
3300/* The start address of the ALT_L3_SLV_SLV_SDMMC component. */
3301#define ALT_L3_SLV_SLV_SDMMC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_SDMMC_OFST))
3302/* The lower bound address range of the ALT_L3_SLV_SLV_SDMMC component. */
3303#define ALT_L3_SLV_SLV_SDMMC_LB_ADDR ALT_L3_SLV_SLV_SDMMC_ADDR
3304/* The upper bound address range of the ALT_L3_SLV_SLV_SDMMC component. */
3305#define ALT_L3_SLV_SLV_SDMMC_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_SDMMC_ADDR) + 0x10c) - 1))
3306
3307
3308/*
3309 * Register Group Instance : slavegrp_dma
3310 *
3311 * Instance slavegrp_dma of register group ALT_L3_SLV_DMA.
3312 *
3313 *
3314 */
3315/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_DMA instance. */
3316#define ALT_L3_SLV_SLV_DMA_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_DMA_ADDR)
3317/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_DMA instance. */
3318#define ALT_L3_SLV_SLV_DMA_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_DMA_ADDR)
3319/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_DMA instance. */
3320#define ALT_L3_SLV_SLV_DMA_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_DMA_ADDR)
3321/* The base address byte offset for the start of the ALT_L3_SLV_SLV_DMA component. */
3322#define ALT_L3_SLV_SLV_DMA_OFST 0x3000
3323/* The start address of the ALT_L3_SLV_SLV_DMA component. */
3324#define ALT_L3_SLV_SLV_DMA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_DMA_OFST))
3325/* The lower bound address range of the ALT_L3_SLV_SLV_DMA component. */
3326#define ALT_L3_SLV_SLV_DMA_LB_ADDR ALT_L3_SLV_SLV_DMA_ADDR
3327/* The upper bound address range of the ALT_L3_SLV_SLV_DMA component. */
3328#define ALT_L3_SLV_SLV_DMA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_DMA_ADDR) + 0x10c) - 1))
3329
3330
3331/*
3332 * Register Group Instance : slavegrp_fpga2hps
3333 *
3334 * Instance slavegrp_fpga2hps of register group ALT_L3_SLV_F2H.
3335 *
3336 *
3337 */
3338/* The address of the ALT_L3_WR_TIDEMARK register for the ALT_L3_SLV_SLV_F2H instance. */
3339#define ALT_L3_SLV_SLV_FPGA2WR_TIDEMARK_ADDR ALT_L3_WR_TIDEMARK_ADDR(ALT_L3_SLV_SLV_F2H_ADDR)
3340/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_F2H instance. */
3341#define ALT_L3_SLV_SLV_FPGA2RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_F2H_ADDR)
3342/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_F2H instance. */
3343#define ALT_L3_SLV_SLV_FPGA2WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_F2H_ADDR)
3344/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_F2H instance. */
3345#define ALT_L3_SLV_SLV_FPGA2FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_F2H_ADDR)
3346/* The base address byte offset for the start of the ALT_L3_SLV_SLV_F2H component. */
3347#define ALT_L3_SLV_SLV_F2H_OFST 0x4000
3348/* The start address of the ALT_L3_SLV_SLV_F2H component. */
3349#define ALT_L3_SLV_SLV_F2H_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_F2H_OFST))
3350/* The lower bound address range of the ALT_L3_SLV_SLV_F2H component. */
3351#define ALT_L3_SLV_SLV_F2H_LB_ADDR ALT_L3_SLV_SLV_F2H_ADDR
3352/* The upper bound address range of the ALT_L3_SLV_SLV_F2H component. */
3353#define ALT_L3_SLV_SLV_F2H_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_F2H_ADDR) + 0x10c) - 1))
3354
3355
3356/*
3357 * Register Group Instance : slavegrp_etr
3358 *
3359 * Instance slavegrp_etr of register group ALT_L3_SLV_ETR.
3360 *
3361 *
3362 */
3363/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_ETR instance. */
3364#define ALT_L3_SLV_SLV_ETR_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_ETR_ADDR)
3365/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_ETR instance. */
3366#define ALT_L3_SLV_SLV_ETR_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_ETR_ADDR)
3367/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_ETR instance. */
3368#define ALT_L3_SLV_SLV_ETR_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_ETR_ADDR)
3369/* The base address byte offset for the start of the ALT_L3_SLV_SLV_ETR component. */
3370#define ALT_L3_SLV_SLV_ETR_OFST 0x5000
3371/* The start address of the ALT_L3_SLV_SLV_ETR component. */
3372#define ALT_L3_SLV_SLV_ETR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_ETR_OFST))
3373/* The lower bound address range of the ALT_L3_SLV_SLV_ETR component. */
3374#define ALT_L3_SLV_SLV_ETR_LB_ADDR ALT_L3_SLV_SLV_ETR_ADDR
3375/* The upper bound address range of the ALT_L3_SLV_SLV_ETR component. */
3376#define ALT_L3_SLV_SLV_ETR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_ETR_ADDR) + 0x10c) - 1))
3377
3378
3379/*
3380 * Register Group Instance : slavegrp_emac0
3381 *
3382 * Instance slavegrp_emac0 of register group ALT_L3_SLV_EMAC0.
3383 *
3384 *
3385 */
3386/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_EMAC0 instance. */
3387#define ALT_L3_SLV_SLV_EMAC0_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_EMAC0_ADDR)
3388/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_EMAC0 instance. */
3389#define ALT_L3_SLV_SLV_EMAC0_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_EMAC0_ADDR)
3390/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_EMAC0 instance. */
3391#define ALT_L3_SLV_SLV_EMAC0_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_EMAC0_ADDR)
3392/* The base address byte offset for the start of the ALT_L3_SLV_SLV_EMAC0 component. */
3393#define ALT_L3_SLV_SLV_EMAC0_OFST 0x6000
3394/* The start address of the ALT_L3_SLV_SLV_EMAC0 component. */
3395#define ALT_L3_SLV_SLV_EMAC0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_EMAC0_OFST))
3396/* The lower bound address range of the ALT_L3_SLV_SLV_EMAC0 component. */
3397#define ALT_L3_SLV_SLV_EMAC0_LB_ADDR ALT_L3_SLV_SLV_EMAC0_ADDR
3398/* The upper bound address range of the ALT_L3_SLV_SLV_EMAC0 component. */
3399#define ALT_L3_SLV_SLV_EMAC0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_EMAC0_ADDR) + 0x10c) - 1))
3400
3401
3402/*
3403 * Register Group Instance : slavegrp_emac1
3404 *
3405 * Instance slavegrp_emac1 of register group ALT_L3_SLV_EMAC1.
3406 *
3407 *
3408 */
3409/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_EMAC1 instance. */
3410#define ALT_L3_SLV_SLV_EMAC1_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_EMAC1_ADDR)
3411/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_EMAC1 instance. */
3412#define ALT_L3_SLV_SLV_EMAC1_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_EMAC1_ADDR)
3413/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_EMAC1 instance. */
3414#define ALT_L3_SLV_SLV_EMAC1_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_EMAC1_ADDR)
3415/* The base address byte offset for the start of the ALT_L3_SLV_SLV_EMAC1 component. */
3416#define ALT_L3_SLV_SLV_EMAC1_OFST 0x7000
3417/* The start address of the ALT_L3_SLV_SLV_EMAC1 component. */
3418#define ALT_L3_SLV_SLV_EMAC1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_EMAC1_OFST))
3419/* The lower bound address range of the ALT_L3_SLV_SLV_EMAC1 component. */
3420#define ALT_L3_SLV_SLV_EMAC1_LB_ADDR ALT_L3_SLV_SLV_EMAC1_ADDR
3421/* The upper bound address range of the ALT_L3_SLV_SLV_EMAC1 component. */
3422#define ALT_L3_SLV_SLV_EMAC1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_EMAC1_ADDR) + 0x10c) - 1))
3423
3424
3425/*
3426 * Register Group Instance : slavegrp_usb0
3427 *
3428 * Instance slavegrp_usb0 of register group ALT_L3_SLV_USB0.
3429 *
3430 *
3431 */
3432/* The address of the ALT_L3_FN_MOD_AHB register for the ALT_L3_SLV_SLV_USB0 instance. */
3433#define ALT_L3_SLV_SLV_USB0_FN_MOD_AHB_ADDR ALT_L3_FN_MOD_AHB_ADDR(ALT_L3_SLV_SLV_USB0_ADDR)
3434/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_USB0 instance. */
3435#define ALT_L3_SLV_SLV_USB0_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_USB0_ADDR)
3436/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_USB0 instance. */
3437#define ALT_L3_SLV_SLV_USB0_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_USB0_ADDR)
3438/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_USB0 instance. */
3439#define ALT_L3_SLV_SLV_USB0_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_USB0_ADDR)
3440/* The base address byte offset for the start of the ALT_L3_SLV_SLV_USB0 component. */
3441#define ALT_L3_SLV_SLV_USB0_OFST 0x8000
3442/* The start address of the ALT_L3_SLV_SLV_USB0 component. */
3443#define ALT_L3_SLV_SLV_USB0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_USB0_OFST))
3444/* The lower bound address range of the ALT_L3_SLV_SLV_USB0 component. */
3445#define ALT_L3_SLV_SLV_USB0_LB_ADDR ALT_L3_SLV_SLV_USB0_ADDR
3446/* The upper bound address range of the ALT_L3_SLV_SLV_USB0 component. */
3447#define ALT_L3_SLV_SLV_USB0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_USB0_ADDR) + 0x10c) - 1))
3448
3449
3450/*
3451 * Register Group Instance : slavegrp_nand
3452 *
3453 * Instance slavegrp_nand of register group ALT_L3_SLV_NAND.
3454 *
3455 *
3456 */
3457/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_NAND instance. */
3458#define ALT_L3_SLV_SLV_NAND_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_NAND_ADDR)
3459/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_NAND instance. */
3460#define ALT_L3_SLV_SLV_NAND_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_NAND_ADDR)
3461/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_NAND instance. */
3462#define ALT_L3_SLV_SLV_NAND_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_NAND_ADDR)
3463/* The base address byte offset for the start of the ALT_L3_SLV_SLV_NAND component. */
3464#define ALT_L3_SLV_SLV_NAND_OFST 0x9000
3465/* The start address of the ALT_L3_SLV_SLV_NAND component. */
3466#define ALT_L3_SLV_SLV_NAND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_NAND_OFST))
3467/* The lower bound address range of the ALT_L3_SLV_SLV_NAND component. */
3468#define ALT_L3_SLV_SLV_NAND_LB_ADDR ALT_L3_SLV_SLV_NAND_ADDR
3469/* The upper bound address range of the ALT_L3_SLV_SLV_NAND component. */
3470#define ALT_L3_SLV_SLV_NAND_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_NAND_ADDR) + 0x10c) - 1))
3471
3472
3473/*
3474 * Register Group Instance : slavegrp_usb1
3475 *
3476 * Instance slavegrp_usb1 of register group ALT_L3_SLV_USB1.
3477 *
3478 *
3479 */
3480/* The address of the ALT_L3_FN_MOD_AHB register for the ALT_L3_SLV_SLV_USB1 instance. */
3481#define ALT_L3_SLV_SLV_USB1_FN_MOD_AHB_ADDR ALT_L3_FN_MOD_AHB_ADDR(ALT_L3_SLV_SLV_USB1_ADDR)
3482/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_USB1 instance. */
3483#define ALT_L3_SLV_SLV_USB1_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_USB1_ADDR)
3484/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_USB1 instance. */
3485#define ALT_L3_SLV_SLV_USB1_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_USB1_ADDR)
3486/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_USB1 instance. */
3487#define ALT_L3_SLV_SLV_USB1_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_USB1_ADDR)
3488/* The base address byte offset for the start of the ALT_L3_SLV_SLV_USB1 component. */
3489#define ALT_L3_SLV_SLV_USB1_OFST 0xa000
3490/* The start address of the ALT_L3_SLV_SLV_USB1 component. */
3491#define ALT_L3_SLV_SLV_USB1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_USB1_OFST))
3492/* The lower bound address range of the ALT_L3_SLV_SLV_USB1 component. */
3493#define ALT_L3_SLV_SLV_USB1_LB_ADDR ALT_L3_SLV_SLV_USB1_ADDR
3494/* The upper bound address range of the ALT_L3_SLV_SLV_USB1 component. */
3495#define ALT_L3_SLV_SLV_USB1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_USB1_ADDR) + 0x10c) - 1))
3496
3497
3498/* The base address byte offset for the start of the ALT_L3_SLVGRP component. */
3499#define ALT_L3_SLVGRP_OFST 0x42000
3500/* The start address of the ALT_L3_SLVGRP component. */
3501#define ALT_L3_SLVGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_ADDR) + ALT_L3_SLVGRP_OFST))
3502/* The lower bound address range of the ALT_L3_SLVGRP component. */
3503#define ALT_L3_SLVGRP_LB_ADDR ALT_L3_SLVGRP_ADDR
3504/* The upper bound address range of the ALT_L3_SLVGRP component. */
3505#define ALT_L3_SLVGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + 0xa10c) - 1))
3506
3507
3508/* The base address byte offset for the start of the ALT_L3 component. */
3509#define ALT_L3_OFST 0xff800000
3510/* The start address of the ALT_L3 component. */
3511#define ALT_L3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_L3_OFST))
3512/* The lower bound address range of the ALT_L3 component. */
3513#define ALT_L3_LB_ADDR ALT_L3_ADDR
3514/* The upper bound address range of the ALT_L3 component. */
3515#define ALT_L3_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_ADDR) + 0x80000) - 1))
3516
3517
3518/*
3519 * Component Instance : nanddata
3520 *
3521 * Instance nanddata of component ALT_NANDDATA.
3522 *
3523 *
3524 */
3525/* The base address byte offset for the start of the ALT_NANDDATA component. */
3526#define ALT_NANDDATA_OFST 0xff900000
3527/* The start address of the ALT_NANDDATA component. */
3528#define ALT_NANDDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_NANDDATA_OFST))
3529/* The lower bound address range of the ALT_NANDDATA component. */
3530#define ALT_NANDDATA_LB_ADDR ALT_NANDDATA_ADDR
3531/* The upper bound address range of the ALT_NANDDATA component. */
3532#define ALT_NANDDATA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NANDDATA_ADDR) + 0x100000) - 1))
3533
3534
3535/*
3536 * Component Instance : qspidata
3537 *
3538 * Instance qspidata of component ALT_QSPIDATA.
3539 *
3540 *
3541 */
3542/* The base address byte offset for the start of the ALT_QSPIDATA component. */
3543#define ALT_QSPIDATA_OFST 0xffa00000
3544/* The start address of the ALT_QSPIDATA component. */
3545#define ALT_QSPIDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_QSPIDATA_OFST))
3546/* The lower bound address range of the ALT_QSPIDATA component. */
3547#define ALT_QSPIDATA_LB_ADDR ALT_QSPIDATA_ADDR
3548/* The upper bound address range of the ALT_QSPIDATA component. */
3549#define ALT_QSPIDATA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_QSPIDATA_ADDR) + 0x100000) - 1))
3550
3551
3552/*
3553 * Component Instance : usb0
3554 *
3555 * Instance usb0 of component ALT_USB.
3556 *
3557 *
3558 */
3559/*
3560 * Register Group Instance : globgrp
3561 *
3562 * Instance globgrp of register group ALT_USB_GLOB.
3563 *
3564 *
3565 */
3566/* The address of the ALT_USB_GLOB_GOTGCTL register for the ALT_USB0_GLOBGRP instance. */
3567#define ALT_USB0_GLOB_GOTGCTL_ADDR ALT_USB_GLOB_GOTGCTL_ADDR(ALT_USB0_GLOBGRP_ADDR)
3568/* The address of the ALT_USB_GLOB_GOTGINT register for the ALT_USB0_GLOBGRP instance. */
3569#define ALT_USB0_GLOB_GOTGINT_ADDR ALT_USB_GLOB_GOTGINT_ADDR(ALT_USB0_GLOBGRP_ADDR)
3570/* The address of the ALT_USB_GLOB_GAHBCFG register for the ALT_USB0_GLOBGRP instance. */
3571#define ALT_USB0_GLOB_GAHBCFG_ADDR ALT_USB_GLOB_GAHBCFG_ADDR(ALT_USB0_GLOBGRP_ADDR)
3572/* The address of the ALT_USB_GLOB_GUSBCFG register for the ALT_USB0_GLOBGRP instance. */
3573#define ALT_USB0_GLOB_GUSBCFG_ADDR ALT_USB_GLOB_GUSBCFG_ADDR(ALT_USB0_GLOBGRP_ADDR)
3574/* The address of the ALT_USB_GLOB_GRSTCTL register for the ALT_USB0_GLOBGRP instance. */
3575#define ALT_USB0_GLOB_GRSTCTL_ADDR ALT_USB_GLOB_GRSTCTL_ADDR(ALT_USB0_GLOBGRP_ADDR)
3576/* The address of the ALT_USB_GLOB_GINTSTS register for the ALT_USB0_GLOBGRP instance. */
3577#define ALT_USB0_GLOB_GINTSTS_ADDR ALT_USB_GLOB_GINTSTS_ADDR(ALT_USB0_GLOBGRP_ADDR)
3578/* The address of the ALT_USB_GLOB_GINTMSK register for the ALT_USB0_GLOBGRP instance. */
3579#define ALT_USB0_GLOB_GINTMSK_ADDR ALT_USB_GLOB_GINTMSK_ADDR(ALT_USB0_GLOBGRP_ADDR)
3580/* The address of the ALT_USB_GLOB_GRXSTSR register for the ALT_USB0_GLOBGRP instance. */
3581#define ALT_USB0_GLOB_GRXSTSR_ADDR ALT_USB_GLOB_GRXSTSR_ADDR(ALT_USB0_GLOBGRP_ADDR)
3582/* The address of the ALT_USB_GLOB_GRXSTSP register for the ALT_USB0_GLOBGRP instance. */
3583#define ALT_USB0_GLOB_GRXSTSP_ADDR ALT_USB_GLOB_GRXSTSP_ADDR(ALT_USB0_GLOBGRP_ADDR)
3584/* The address of the ALT_USB_GLOB_GRXFSIZ register for the ALT_USB0_GLOBGRP instance. */
3585#define ALT_USB0_GLOB_GRXFSIZ_ADDR ALT_USB_GLOB_GRXFSIZ_ADDR(ALT_USB0_GLOBGRP_ADDR)
3586/* The address of the ALT_USB_GLOB_GNPTXFSIZ register for the ALT_USB0_GLOBGRP instance. */
3587#define ALT_USB0_GLOB_GNPTXFSIZ_ADDR ALT_USB_GLOB_GNPTXFSIZ_ADDR(ALT_USB0_GLOBGRP_ADDR)
3588/* The address of the ALT_USB_GLOB_GNPTXSTS register for the ALT_USB0_GLOBGRP instance. */
3589#define ALT_USB0_GLOB_GNPTXSTS_ADDR ALT_USB_GLOB_GNPTXSTS_ADDR(ALT_USB0_GLOBGRP_ADDR)
3590/* The address of the ALT_USB_GLOB_GPVNDCTL register for the ALT_USB0_GLOBGRP instance. */
3591#define ALT_USB0_GLOB_GPVNDCTL_ADDR ALT_USB_GLOB_GPVNDCTL_ADDR(ALT_USB0_GLOBGRP_ADDR)
3592/* The address of the ALT_USB_GLOB_GGPIO register for the ALT_USB0_GLOBGRP instance. */
3593#define ALT_USB0_GLOB_GGPIO_ADDR ALT_USB_GLOB_GGPIO_ADDR(ALT_USB0_GLOBGRP_ADDR)
3594/* The address of the ALT_USB_GLOB_GUID register for the ALT_USB0_GLOBGRP instance. */
3595#define ALT_USB0_GLOB_GUID_ADDR ALT_USB_GLOB_GUID_ADDR(ALT_USB0_GLOBGRP_ADDR)
3596/* The address of the ALT_USB_GLOB_GSNPSID register for the ALT_USB0_GLOBGRP instance. */
3597#define ALT_USB0_GLOB_GSNPSID_ADDR ALT_USB_GLOB_GSNPSID_ADDR(ALT_USB0_GLOBGRP_ADDR)
3598/* The address of the ALT_USB_GLOB_GHWCFG1 register for the ALT_USB0_GLOBGRP instance. */
3599#define ALT_USB0_GLOB_GHWCFG1_ADDR ALT_USB_GLOB_GHWCFG1_ADDR(ALT_USB0_GLOBGRP_ADDR)
3600/* The address of the ALT_USB_GLOB_GHWCFG2 register for the ALT_USB0_GLOBGRP instance. */
3601#define ALT_USB0_GLOB_GHWCFG2_ADDR ALT_USB_GLOB_GHWCFG2_ADDR(ALT_USB0_GLOBGRP_ADDR)
3602/* The address of the ALT_USB_GLOB_GHWCFG3 register for the ALT_USB0_GLOBGRP instance. */
3603#define ALT_USB0_GLOB_GHWCFG3_ADDR ALT_USB_GLOB_GHWCFG3_ADDR(ALT_USB0_GLOBGRP_ADDR)
3604/* The address of the ALT_USB_GLOB_GHWCFG4 register for the ALT_USB0_GLOBGRP instance. */
3605#define ALT_USB0_GLOB_GHWCFG4_ADDR ALT_USB_GLOB_GHWCFG4_ADDR(ALT_USB0_GLOBGRP_ADDR)
3606/* The address of the ALT_USB_GLOB_GDFIFOCFG register for the ALT_USB0_GLOBGRP instance. */
3607#define ALT_USB0_GLOB_GDFIFOCFG_ADDR ALT_USB_GLOB_GDFIFOCFG_ADDR(ALT_USB0_GLOBGRP_ADDR)
3608/* The address of the ALT_USB_GLOB_HPTXFSIZ register for the ALT_USB0_GLOBGRP instance. */
3609#define ALT_USB0_GLOB_HPTXFSIZ_ADDR ALT_USB_GLOB_HPTXFSIZ_ADDR(ALT_USB0_GLOBGRP_ADDR)
3610/* The address of the ALT_USB_GLOB_DIEPTXF1 register for the ALT_USB0_GLOBGRP instance. */
3611#define ALT_USB0_GLOB_DIEPTXF1_ADDR ALT_USB_GLOB_DIEPTXF1_ADDR(ALT_USB0_GLOBGRP_ADDR)
3612/* The address of the ALT_USB_GLOB_DIEPTXF2 register for the ALT_USB0_GLOBGRP instance. */
3613#define ALT_USB0_GLOB_DIEPTXF2_ADDR ALT_USB_GLOB_DIEPTXF2_ADDR(ALT_USB0_GLOBGRP_ADDR)
3614/* The address of the ALT_USB_GLOB_DIEPTXF3 register for the ALT_USB0_GLOBGRP instance. */
3615#define ALT_USB0_GLOB_DIEPTXF3_ADDR ALT_USB_GLOB_DIEPTXF3_ADDR(ALT_USB0_GLOBGRP_ADDR)
3616/* The address of the ALT_USB_GLOB_DIEPTXF4 register for the ALT_USB0_GLOBGRP instance. */
3617#define ALT_USB0_GLOB_DIEPTXF4_ADDR ALT_USB_GLOB_DIEPTXF4_ADDR(ALT_USB0_GLOBGRP_ADDR)
3618/* The address of the ALT_USB_GLOB_DIEPTXF5 register for the ALT_USB0_GLOBGRP instance. */
3619#define ALT_USB0_GLOB_DIEPTXF5_ADDR ALT_USB_GLOB_DIEPTXF5_ADDR(ALT_USB0_GLOBGRP_ADDR)
3620/* The address of the ALT_USB_GLOB_DIEPTXF6 register for the ALT_USB0_GLOBGRP instance. */
3621#define ALT_USB0_GLOB_DIEPTXF6_ADDR ALT_USB_GLOB_DIEPTXF6_ADDR(ALT_USB0_GLOBGRP_ADDR)
3622/* The address of the ALT_USB_GLOB_DIEPTXF7 register for the ALT_USB0_GLOBGRP instance. */
3623#define ALT_USB0_GLOB_DIEPTXF7_ADDR ALT_USB_GLOB_DIEPTXF7_ADDR(ALT_USB0_GLOBGRP_ADDR)
3624/* The address of the ALT_USB_GLOB_DIEPTXF8 register for the ALT_USB0_GLOBGRP instance. */
3625#define ALT_USB0_GLOB_DIEPTXF8_ADDR ALT_USB_GLOB_DIEPTXF8_ADDR(ALT_USB0_GLOBGRP_ADDR)
3626/* The address of the ALT_USB_GLOB_DIEPTXF9 register for the ALT_USB0_GLOBGRP instance. */
3627#define ALT_USB0_GLOB_DIEPTXF9_ADDR ALT_USB_GLOB_DIEPTXF9_ADDR(ALT_USB0_GLOBGRP_ADDR)
3628/* The address of the ALT_USB_GLOB_DIEPTXF10 register for the ALT_USB0_GLOBGRP instance. */
3629#define ALT_USB0_GLOB_DIEPTXF10_ADDR ALT_USB_GLOB_DIEPTXF10_ADDR(ALT_USB0_GLOBGRP_ADDR)
3630/* The address of the ALT_USB_GLOB_DIEPTXF11 register for the ALT_USB0_GLOBGRP instance. */
3631#define ALT_USB0_GLOB_DIEPTXF11_ADDR ALT_USB_GLOB_DIEPTXF11_ADDR(ALT_USB0_GLOBGRP_ADDR)
3632/* The address of the ALT_USB_GLOB_DIEPTXF12 register for the ALT_USB0_GLOBGRP instance. */
3633#define ALT_USB0_GLOB_DIEPTXF12_ADDR ALT_USB_GLOB_DIEPTXF12_ADDR(ALT_USB0_GLOBGRP_ADDR)
3634/* The address of the ALT_USB_GLOB_DIEPTXF13 register for the ALT_USB0_GLOBGRP instance. */
3635#define ALT_USB0_GLOB_DIEPTXF13_ADDR ALT_USB_GLOB_DIEPTXF13_ADDR(ALT_USB0_GLOBGRP_ADDR)
3636/* The address of the ALT_USB_GLOB_DIEPTXF14 register for the ALT_USB0_GLOBGRP instance. */
3637#define ALT_USB0_GLOB_DIEPTXF14_ADDR ALT_USB_GLOB_DIEPTXF14_ADDR(ALT_USB0_GLOBGRP_ADDR)
3638/* The address of the ALT_USB_GLOB_DIEPTXF15 register for the ALT_USB0_GLOBGRP instance. */
3639#define ALT_USB0_GLOB_DIEPTXF15_ADDR ALT_USB_GLOB_DIEPTXF15_ADDR(ALT_USB0_GLOBGRP_ADDR)
3640/* The base address byte offset for the start of the ALT_USB0_GLOBGRP component. */
3641#define ALT_USB0_GLOBGRP_OFST 0x0
3642/* The start address of the ALT_USB0_GLOBGRP component. */
3643#define ALT_USB0_GLOBGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB0_ADDR) + ALT_USB0_GLOBGRP_OFST))
3644/* The lower bound address range of the ALT_USB0_GLOBGRP component. */
3645#define ALT_USB0_GLOBGRP_LB_ADDR ALT_USB0_GLOBGRP_ADDR
3646/* The upper bound address range of the ALT_USB0_GLOBGRP component. */
3647#define ALT_USB0_GLOBGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB0_GLOBGRP_ADDR) + 0x140) - 1))
3648
3649
3650/*
3651 * Register Group Instance : hostgrp
3652 *
3653 * Instance hostgrp of register group ALT_USB_HOST.
3654 *
3655 *
3656 */
3657/* The address of the ALT_USB_HOST_HCFG register for the ALT_USB0_HOSTGRP instance. */
3658#define ALT_USB0_HOST_HCFG_ADDR ALT_USB_HOST_HCFG_ADDR(ALT_USB0_HOSTGRP_ADDR)
3659/* The address of the ALT_USB_HOST_HFIR register for the ALT_USB0_HOSTGRP instance. */
3660#define ALT_USB0_HOST_HFIR_ADDR ALT_USB_HOST_HFIR_ADDR(ALT_USB0_HOSTGRP_ADDR)
3661/* The address of the ALT_USB_HOST_HFNUM register for the ALT_USB0_HOSTGRP instance. */
3662#define ALT_USB0_HOST_HFNUM_ADDR ALT_USB_HOST_HFNUM_ADDR(ALT_USB0_HOSTGRP_ADDR)
3663/* The address of the ALT_USB_HOST_HPTXSTS register for the ALT_USB0_HOSTGRP instance. */
3664#define ALT_USB0_HOST_HPTXSTS_ADDR ALT_USB_HOST_HPTXSTS_ADDR(ALT_USB0_HOSTGRP_ADDR)
3665/* The address of the ALT_USB_HOST_HAINT register for the ALT_USB0_HOSTGRP instance. */
3666#define ALT_USB0_HOST_HAINT_ADDR ALT_USB_HOST_HAINT_ADDR(ALT_USB0_HOSTGRP_ADDR)
3667/* The address of the ALT_USB_HOST_HAINTMSK register for the ALT_USB0_HOSTGRP instance. */
3668#define ALT_USB0_HOST_HAINTMSK_ADDR ALT_USB_HOST_HAINTMSK_ADDR(ALT_USB0_HOSTGRP_ADDR)
3669/* The address of the ALT_USB_HOST_HFLBADDR register for the ALT_USB0_HOSTGRP instance. */
3670#define ALT_USB0_HOST_HFLBADDR_ADDR ALT_USB_HOST_HFLBADDR_ADDR(ALT_USB0_HOSTGRP_ADDR)
3671/* The address of the ALT_USB_HOST_HPRT register for the ALT_USB0_HOSTGRP instance. */
3672#define ALT_USB0_HOST_HPRT_ADDR ALT_USB_HOST_HPRT_ADDR(ALT_USB0_HOSTGRP_ADDR)
3673/* The address of the ALT_USB_HOST_HCCHAR0 register for the ALT_USB0_HOSTGRP instance. */
3674#define ALT_USB0_HOST_HCCHAR0_ADDR ALT_USB_HOST_HCCHAR0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3675/* The address of the ALT_USB_HOST_HCSPLT0 register for the ALT_USB0_HOSTGRP instance. */
3676#define ALT_USB0_HOST_HCSPLT0_ADDR ALT_USB_HOST_HCSPLT0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3677/* The address of the ALT_USB_HOST_HCINT0 register for the ALT_USB0_HOSTGRP instance. */
3678#define ALT_USB0_HOST_HCINT0_ADDR ALT_USB_HOST_HCINT0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3679/* The address of the ALT_USB_HOST_HCINTMSK0 register for the ALT_USB0_HOSTGRP instance. */
3680#define ALT_USB0_HOST_HCINTMSK0_ADDR ALT_USB_HOST_HCINTMSK0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3681/* The address of the ALT_USB_HOST_HCTSIZ0 register for the ALT_USB0_HOSTGRP instance. */
3682#define ALT_USB0_HOST_HCTSIZ0_ADDR ALT_USB_HOST_HCTSIZ0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3683/* The address of the ALT_USB_HOST_HCDMA0 register for the ALT_USB0_HOSTGRP instance. */
3684#define ALT_USB0_HOST_HCDMA0_ADDR ALT_USB_HOST_HCDMA0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3685/* The address of the ALT_USB_HOST_HCDMAB0 register for the ALT_USB0_HOSTGRP instance. */
3686#define ALT_USB0_HOST_HCDMAB0_ADDR ALT_USB_HOST_HCDMAB0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3687/* The address of the ALT_USB_HOST_HCCHAR1 register for the ALT_USB0_HOSTGRP instance. */
3688#define ALT_USB0_HOST_HCCHAR1_ADDR ALT_USB_HOST_HCCHAR1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3689/* The address of the ALT_USB_HOST_HCSPLT1 register for the ALT_USB0_HOSTGRP instance. */
3690#define ALT_USB0_HOST_HCSPLT1_ADDR ALT_USB_HOST_HCSPLT1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3691/* The address of the ALT_USB_HOST_HCINT1 register for the ALT_USB0_HOSTGRP instance. */
3692#define ALT_USB0_HOST_HCINT1_ADDR ALT_USB_HOST_HCINT1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3693/* The address of the ALT_USB_HOST_HCINTMSK1 register for the ALT_USB0_HOSTGRP instance. */
3694#define ALT_USB0_HOST_HCINTMSK1_ADDR ALT_USB_HOST_HCINTMSK1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3695/* The address of the ALT_USB_HOST_HCTSIZ1 register for the ALT_USB0_HOSTGRP instance. */
3696#define ALT_USB0_HOST_HCTSIZ1_ADDR ALT_USB_HOST_HCTSIZ1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3697/* The address of the ALT_USB_HOST_HCDMA1 register for the ALT_USB0_HOSTGRP instance. */
3698#define ALT_USB0_HOST_HCDMA1_ADDR ALT_USB_HOST_HCDMA1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3699/* The address of the ALT_USB_HOST_HCDMAB1 register for the ALT_USB0_HOSTGRP instance. */
3700#define ALT_USB0_HOST_HCDMAB1_ADDR ALT_USB_HOST_HCDMAB1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3701/* The address of the ALT_USB_HOST_HCCHAR2 register for the ALT_USB0_HOSTGRP instance. */
3702#define ALT_USB0_HOST_HCCHAR2_ADDR ALT_USB_HOST_HCCHAR2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3703/* The address of the ALT_USB_HOST_HCSPLT2 register for the ALT_USB0_HOSTGRP instance. */
3704#define ALT_USB0_HOST_HCSPLT2_ADDR ALT_USB_HOST_HCSPLT2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3705/* The address of the ALT_USB_HOST_HCINT2 register for the ALT_USB0_HOSTGRP instance. */
3706#define ALT_USB0_HOST_HCINT2_ADDR ALT_USB_HOST_HCINT2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3707/* The address of the ALT_USB_HOST_HCINTMSK2 register for the ALT_USB0_HOSTGRP instance. */
3708#define ALT_USB0_HOST_HCINTMSK2_ADDR ALT_USB_HOST_HCINTMSK2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3709/* The address of the ALT_USB_HOST_HCTSIZ2 register for the ALT_USB0_HOSTGRP instance. */
3710#define ALT_USB0_HOST_HCTSIZ2_ADDR ALT_USB_HOST_HCTSIZ2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3711/* The address of the ALT_USB_HOST_HCDMA2 register for the ALT_USB0_HOSTGRP instance. */
3712#define ALT_USB0_HOST_HCDMA2_ADDR ALT_USB_HOST_HCDMA2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3713/* The address of the ALT_USB_HOST_HCDMAB2 register for the ALT_USB0_HOSTGRP instance. */
3714#define ALT_USB0_HOST_HCDMAB2_ADDR ALT_USB_HOST_HCDMAB2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3715/* The address of the ALT_USB_HOST_HCCHAR3 register for the ALT_USB0_HOSTGRP instance. */
3716#define ALT_USB0_HOST_HCCHAR3_ADDR ALT_USB_HOST_HCCHAR3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3717/* The address of the ALT_USB_HOST_HCSPLT3 register for the ALT_USB0_HOSTGRP instance. */
3718#define ALT_USB0_HOST_HCSPLT3_ADDR ALT_USB_HOST_HCSPLT3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3719/* The address of the ALT_USB_HOST_HCINT3 register for the ALT_USB0_HOSTGRP instance. */
3720#define ALT_USB0_HOST_HCINT3_ADDR ALT_USB_HOST_HCINT3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3721/* The address of the ALT_USB_HOST_HCINTMSK3 register for the ALT_USB0_HOSTGRP instance. */
3722#define ALT_USB0_HOST_HCINTMSK3_ADDR ALT_USB_HOST_HCINTMSK3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3723/* The address of the ALT_USB_HOST_HCTSIZ3 register for the ALT_USB0_HOSTGRP instance. */
3724#define ALT_USB0_HOST_HCTSIZ3_ADDR ALT_USB_HOST_HCTSIZ3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3725/* The address of the ALT_USB_HOST_HCDMA3 register for the ALT_USB0_HOSTGRP instance. */
3726#define ALT_USB0_HOST_HCDMA3_ADDR ALT_USB_HOST_HCDMA3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3727/* The address of the ALT_USB_HOST_HCDMAB3 register for the ALT_USB0_HOSTGRP instance. */
3728#define ALT_USB0_HOST_HCDMAB3_ADDR ALT_USB_HOST_HCDMAB3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3729/* The address of the ALT_USB_HOST_HCCHAR4 register for the ALT_USB0_HOSTGRP instance. */
3730#define ALT_USB0_HOST_HCCHAR4_ADDR ALT_USB_HOST_HCCHAR4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3731/* The address of the ALT_USB_HOST_HCSPLT4 register for the ALT_USB0_HOSTGRP instance. */
3732#define ALT_USB0_HOST_HCSPLT4_ADDR ALT_USB_HOST_HCSPLT4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3733/* The address of the ALT_USB_HOST_HCINT4 register for the ALT_USB0_HOSTGRP instance. */
3734#define ALT_USB0_HOST_HCINT4_ADDR ALT_USB_HOST_HCINT4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3735/* The address of the ALT_USB_HOST_HCINTMSK4 register for the ALT_USB0_HOSTGRP instance. */
3736#define ALT_USB0_HOST_HCINTMSK4_ADDR ALT_USB_HOST_HCINTMSK4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3737/* The address of the ALT_USB_HOST_HCTSIZ4 register for the ALT_USB0_HOSTGRP instance. */
3738#define ALT_USB0_HOST_HCTSIZ4_ADDR ALT_USB_HOST_HCTSIZ4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3739/* The address of the ALT_USB_HOST_HCDMA4 register for the ALT_USB0_HOSTGRP instance. */
3740#define ALT_USB0_HOST_HCDMA4_ADDR ALT_USB_HOST_HCDMA4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3741/* The address of the ALT_USB_HOST_HCDMAB4 register for the ALT_USB0_HOSTGRP instance. */
3742#define ALT_USB0_HOST_HCDMAB4_ADDR ALT_USB_HOST_HCDMAB4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3743/* The address of the ALT_USB_HOST_HCCHAR5 register for the ALT_USB0_HOSTGRP instance. */
3744#define ALT_USB0_HOST_HCCHAR5_ADDR ALT_USB_HOST_HCCHAR5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3745/* The address of the ALT_USB_HOST_HCSPLT5 register for the ALT_USB0_HOSTGRP instance. */
3746#define ALT_USB0_HOST_HCSPLT5_ADDR ALT_USB_HOST_HCSPLT5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3747/* The address of the ALT_USB_HOST_HCINT5 register for the ALT_USB0_HOSTGRP instance. */
3748#define ALT_USB0_HOST_HCINT5_ADDR ALT_USB_HOST_HCINT5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3749/* The address of the ALT_USB_HOST_HCINTMSK5 register for the ALT_USB0_HOSTGRP instance. */
3750#define ALT_USB0_HOST_HCINTMSK5_ADDR ALT_USB_HOST_HCINTMSK5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3751/* The address of the ALT_USB_HOST_HCTSIZ5 register for the ALT_USB0_HOSTGRP instance. */
3752#define ALT_USB0_HOST_HCTSIZ5_ADDR ALT_USB_HOST_HCTSIZ5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3753/* The address of the ALT_USB_HOST_HCDMA5 register for the ALT_USB0_HOSTGRP instance. */
3754#define ALT_USB0_HOST_HCDMA5_ADDR ALT_USB_HOST_HCDMA5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3755/* The address of the ALT_USB_HOST_HCDMAB5 register for the ALT_USB0_HOSTGRP instance. */
3756#define ALT_USB0_HOST_HCDMAB5_ADDR ALT_USB_HOST_HCDMAB5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3757/* The address of the ALT_USB_HOST_HCCHAR6 register for the ALT_USB0_HOSTGRP instance. */
3758#define ALT_USB0_HOST_HCCHAR6_ADDR ALT_USB_HOST_HCCHAR6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3759/* The address of the ALT_USB_HOST_HCSPLT6 register for the ALT_USB0_HOSTGRP instance. */
3760#define ALT_USB0_HOST_HCSPLT6_ADDR ALT_USB_HOST_HCSPLT6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3761/* The address of the ALT_USB_HOST_HCINT6 register for the ALT_USB0_HOSTGRP instance. */
3762#define ALT_USB0_HOST_HCINT6_ADDR ALT_USB_HOST_HCINT6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3763/* The address of the ALT_USB_HOST_HCINTMSK6 register for the ALT_USB0_HOSTGRP instance. */
3764#define ALT_USB0_HOST_HCINTMSK6_ADDR ALT_USB_HOST_HCINTMSK6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3765/* The address of the ALT_USB_HOST_HCTSIZ6 register for the ALT_USB0_HOSTGRP instance. */
3766#define ALT_USB0_HOST_HCTSIZ6_ADDR ALT_USB_HOST_HCTSIZ6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3767/* The address of the ALT_USB_HOST_HCDMA6 register for the ALT_USB0_HOSTGRP instance. */
3768#define ALT_USB0_HOST_HCDMA6_ADDR ALT_USB_HOST_HCDMA6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3769/* The address of the ALT_USB_HOST_HCDMAB6 register for the ALT_USB0_HOSTGRP instance. */
3770#define ALT_USB0_HOST_HCDMAB6_ADDR ALT_USB_HOST_HCDMAB6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3771/* The address of the ALT_USB_HOST_HCCHAR7 register for the ALT_USB0_HOSTGRP instance. */
3772#define ALT_USB0_HOST_HCCHAR7_ADDR ALT_USB_HOST_HCCHAR7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3773/* The address of the ALT_USB_HOST_HCSPLT7 register for the ALT_USB0_HOSTGRP instance. */
3774#define ALT_USB0_HOST_HCSPLT7_ADDR ALT_USB_HOST_HCSPLT7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3775/* The address of the ALT_USB_HOST_HCINT7 register for the ALT_USB0_HOSTGRP instance. */
3776#define ALT_USB0_HOST_HCINT7_ADDR ALT_USB_HOST_HCINT7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3777/* The address of the ALT_USB_HOST_HCINTMSK7 register for the ALT_USB0_HOSTGRP instance. */
3778#define ALT_USB0_HOST_HCINTMSK7_ADDR ALT_USB_HOST_HCINTMSK7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3779/* The address of the ALT_USB_HOST_HCTSIZ7 register for the ALT_USB0_HOSTGRP instance. */
3780#define ALT_USB0_HOST_HCTSIZ7_ADDR ALT_USB_HOST_HCTSIZ7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3781/* The address of the ALT_USB_HOST_HCDMA7 register for the ALT_USB0_HOSTGRP instance. */
3782#define ALT_USB0_HOST_HCDMA7_ADDR ALT_USB_HOST_HCDMA7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3783/* The address of the ALT_USB_HOST_HCDMAB7 register for the ALT_USB0_HOSTGRP instance. */
3784#define ALT_USB0_HOST_HCDMAB7_ADDR ALT_USB_HOST_HCDMAB7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3785/* The address of the ALT_USB_HOST_HCCHAR8 register for the ALT_USB0_HOSTGRP instance. */
3786#define ALT_USB0_HOST_HCCHAR8_ADDR ALT_USB_HOST_HCCHAR8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3787/* The address of the ALT_USB_HOST_HCSPLT8 register for the ALT_USB0_HOSTGRP instance. */
3788#define ALT_USB0_HOST_HCSPLT8_ADDR ALT_USB_HOST_HCSPLT8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3789/* The address of the ALT_USB_HOST_HCINT8 register for the ALT_USB0_HOSTGRP instance. */
3790#define ALT_USB0_HOST_HCINT8_ADDR ALT_USB_HOST_HCINT8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3791/* The address of the ALT_USB_HOST_HCINTMSK8 register for the ALT_USB0_HOSTGRP instance. */
3792#define ALT_USB0_HOST_HCINTMSK8_ADDR ALT_USB_HOST_HCINTMSK8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3793/* The address of the ALT_USB_HOST_HCTSIZ8 register for the ALT_USB0_HOSTGRP instance. */
3794#define ALT_USB0_HOST_HCTSIZ8_ADDR ALT_USB_HOST_HCTSIZ8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3795/* The address of the ALT_USB_HOST_HCDMA8 register for the ALT_USB0_HOSTGRP instance. */
3796#define ALT_USB0_HOST_HCDMA8_ADDR ALT_USB_HOST_HCDMA8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3797/* The address of the ALT_USB_HOST_HCDMAB8 register for the ALT_USB0_HOSTGRP instance. */
3798#define ALT_USB0_HOST_HCDMAB8_ADDR ALT_USB_HOST_HCDMAB8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3799/* The address of the ALT_USB_HOST_HCCHAR9 register for the ALT_USB0_HOSTGRP instance. */
3800#define ALT_USB0_HOST_HCCHAR9_ADDR ALT_USB_HOST_HCCHAR9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3801/* The address of the ALT_USB_HOST_HCSPLT9 register for the ALT_USB0_HOSTGRP instance. */
3802#define ALT_USB0_HOST_HCSPLT9_ADDR ALT_USB_HOST_HCSPLT9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3803/* The address of the ALT_USB_HOST_HCINT9 register for the ALT_USB0_HOSTGRP instance. */
3804#define ALT_USB0_HOST_HCINT9_ADDR ALT_USB_HOST_HCINT9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3805/* The address of the ALT_USB_HOST_HCINTMSK9 register for the ALT_USB0_HOSTGRP instance. */
3806#define ALT_USB0_HOST_HCINTMSK9_ADDR ALT_USB_HOST_HCINTMSK9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3807/* The address of the ALT_USB_HOST_HCTSIZ9 register for the ALT_USB0_HOSTGRP instance. */
3808#define ALT_USB0_HOST_HCTSIZ9_ADDR ALT_USB_HOST_HCTSIZ9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3809/* The address of the ALT_USB_HOST_HCDMA9 register for the ALT_USB0_HOSTGRP instance. */
3810#define ALT_USB0_HOST_HCDMA9_ADDR ALT_USB_HOST_HCDMA9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3811/* The address of the ALT_USB_HOST_HCDMAB9 register for the ALT_USB0_HOSTGRP instance. */
3812#define ALT_USB0_HOST_HCDMAB9_ADDR ALT_USB_HOST_HCDMAB9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3813/* The address of the ALT_USB_HOST_HCCHAR10 register for the ALT_USB0_HOSTGRP instance. */
3814#define ALT_USB0_HOST_HCCHAR10_ADDR ALT_USB_HOST_HCCHAR10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3815/* The address of the ALT_USB_HOST_HCSPLT10 register for the ALT_USB0_HOSTGRP instance. */
3816#define ALT_USB0_HOST_HCSPLT10_ADDR ALT_USB_HOST_HCSPLT10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3817/* The address of the ALT_USB_HOST_HCINT10 register for the ALT_USB0_HOSTGRP instance. */
3818#define ALT_USB0_HOST_HCINT10_ADDR ALT_USB_HOST_HCINT10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3819/* The address of the ALT_USB_HOST_HCINTMSK10 register for the ALT_USB0_HOSTGRP instance. */
3820#define ALT_USB0_HOST_HCINTMSK10_ADDR ALT_USB_HOST_HCINTMSK10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3821/* The address of the ALT_USB_HOST_HCTSIZ10 register for the ALT_USB0_HOSTGRP instance. */
3822#define ALT_USB0_HOST_HCTSIZ10_ADDR ALT_USB_HOST_HCTSIZ10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3823/* The address of the ALT_USB_HOST_HCDMA10 register for the ALT_USB0_HOSTGRP instance. */
3824#define ALT_USB0_HOST_HCDMA10_ADDR ALT_USB_HOST_HCDMA10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3825/* The address of the ALT_USB_HOST_HCDMAB10 register for the ALT_USB0_HOSTGRP instance. */
3826#define ALT_USB0_HOST_HCDMAB10_ADDR ALT_USB_HOST_HCDMAB10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3827/* The address of the ALT_USB_HOST_HCCHAR11 register for the ALT_USB0_HOSTGRP instance. */
3828#define ALT_USB0_HOST_HCCHAR11_ADDR ALT_USB_HOST_HCCHAR11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3829/* The address of the ALT_USB_HOST_HCSPLT11 register for the ALT_USB0_HOSTGRP instance. */
3830#define ALT_USB0_HOST_HCSPLT11_ADDR ALT_USB_HOST_HCSPLT11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3831/* The address of the ALT_USB_HOST_HCINT11 register for the ALT_USB0_HOSTGRP instance. */
3832#define ALT_USB0_HOST_HCINT11_ADDR ALT_USB_HOST_HCINT11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3833/* The address of the ALT_USB_HOST_HCINTMSK11 register for the ALT_USB0_HOSTGRP instance. */
3834#define ALT_USB0_HOST_HCINTMSK11_ADDR ALT_USB_HOST_HCINTMSK11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3835/* The address of the ALT_USB_HOST_HCTSIZ11 register for the ALT_USB0_HOSTGRP instance. */
3836#define ALT_USB0_HOST_HCTSIZ11_ADDR ALT_USB_HOST_HCTSIZ11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3837/* The address of the ALT_USB_HOST_HCDMA11 register for the ALT_USB0_HOSTGRP instance. */
3838#define ALT_USB0_HOST_HCDMA11_ADDR ALT_USB_HOST_HCDMA11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3839/* The address of the ALT_USB_HOST_HCDMAB11 register for the ALT_USB0_HOSTGRP instance. */
3840#define ALT_USB0_HOST_HCDMAB11_ADDR ALT_USB_HOST_HCDMAB11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3841/* The address of the ALT_USB_HOST_HCCHAR12 register for the ALT_USB0_HOSTGRP instance. */
3842#define ALT_USB0_HOST_HCCHAR12_ADDR ALT_USB_HOST_HCCHAR12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3843/* The address of the ALT_USB_HOST_HCSPLT12 register for the ALT_USB0_HOSTGRP instance. */
3844#define ALT_USB0_HOST_HCSPLT12_ADDR ALT_USB_HOST_HCSPLT12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3845/* The address of the ALT_USB_HOST_HCINT12 register for the ALT_USB0_HOSTGRP instance. */
3846#define ALT_USB0_HOST_HCINT12_ADDR ALT_USB_HOST_HCINT12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3847/* The address of the ALT_USB_HOST_HCINTMSK12 register for the ALT_USB0_HOSTGRP instance. */
3848#define ALT_USB0_HOST_HCINTMSK12_ADDR ALT_USB_HOST_HCINTMSK12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3849/* The address of the ALT_USB_HOST_HCTSIZ12 register for the ALT_USB0_HOSTGRP instance. */
3850#define ALT_USB0_HOST_HCTSIZ12_ADDR ALT_USB_HOST_HCTSIZ12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3851/* The address of the ALT_USB_HOST_HCDMA12 register for the ALT_USB0_HOSTGRP instance. */
3852#define ALT_USB0_HOST_HCDMA12_ADDR ALT_USB_HOST_HCDMA12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3853/* The address of the ALT_USB_HOST_HCDMAB12 register for the ALT_USB0_HOSTGRP instance. */
3854#define ALT_USB0_HOST_HCDMAB12_ADDR ALT_USB_HOST_HCDMAB12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3855/* The address of the ALT_USB_HOST_HCCHAR13 register for the ALT_USB0_HOSTGRP instance. */
3856#define ALT_USB0_HOST_HCCHAR13_ADDR ALT_USB_HOST_HCCHAR13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3857/* The address of the ALT_USB_HOST_HCSPLT13 register for the ALT_USB0_HOSTGRP instance. */
3858#define ALT_USB0_HOST_HCSPLT13_ADDR ALT_USB_HOST_HCSPLT13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3859/* The address of the ALT_USB_HOST_HCINT13 register for the ALT_USB0_HOSTGRP instance. */
3860#define ALT_USB0_HOST_HCINT13_ADDR ALT_USB_HOST_HCINT13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3861/* The address of the ALT_USB_HOST_HCINTMSK13 register for the ALT_USB0_HOSTGRP instance. */
3862#define ALT_USB0_HOST_HCINTMSK13_ADDR ALT_USB_HOST_HCINTMSK13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3863/* The address of the ALT_USB_HOST_HCTSIZ13 register for the ALT_USB0_HOSTGRP instance. */
3864#define ALT_USB0_HOST_HCTSIZ13_ADDR ALT_USB_HOST_HCTSIZ13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3865/* The address of the ALT_USB_HOST_HCDMA13 register for the ALT_USB0_HOSTGRP instance. */
3866#define ALT_USB0_HOST_HCDMA13_ADDR ALT_USB_HOST_HCDMA13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3867/* The address of the ALT_USB_HOST_HCDMAB13 register for the ALT_USB0_HOSTGRP instance. */
3868#define ALT_USB0_HOST_HCDMAB13_ADDR ALT_USB_HOST_HCDMAB13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3869/* The address of the ALT_USB_HOST_HCCHAR14 register for the ALT_USB0_HOSTGRP instance. */
3870#define ALT_USB0_HOST_HCCHAR14_ADDR ALT_USB_HOST_HCCHAR14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3871/* The address of the ALT_USB_HOST_HCSPLT14 register for the ALT_USB0_HOSTGRP instance. */
3872#define ALT_USB0_HOST_HCSPLT14_ADDR ALT_USB_HOST_HCSPLT14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3873/* The address of the ALT_USB_HOST_HCINT14 register for the ALT_USB0_HOSTGRP instance. */
3874#define ALT_USB0_HOST_HCINT14_ADDR ALT_USB_HOST_HCINT14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3875/* The address of the ALT_USB_HOST_HCINTMSK14 register for the ALT_USB0_HOSTGRP instance. */
3876#define ALT_USB0_HOST_HCINTMSK14_ADDR ALT_USB_HOST_HCINTMSK14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3877/* The address of the ALT_USB_HOST_HCTSIZ14 register for the ALT_USB0_HOSTGRP instance. */
3878#define ALT_USB0_HOST_HCTSIZ14_ADDR ALT_USB_HOST_HCTSIZ14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3879/* The address of the ALT_USB_HOST_HCDMA14 register for the ALT_USB0_HOSTGRP instance. */
3880#define ALT_USB0_HOST_HCDMA14_ADDR ALT_USB_HOST_HCDMA14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3881/* The address of the ALT_USB_HOST_HCDMAB14 register for the ALT_USB0_HOSTGRP instance. */
3882#define ALT_USB0_HOST_HCDMAB14_ADDR ALT_USB_HOST_HCDMAB14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3883/* The address of the ALT_USB_HOST_HCCHAR15 register for the ALT_USB0_HOSTGRP instance. */
3884#define ALT_USB0_HOST_HCCHAR15_ADDR ALT_USB_HOST_HCCHAR15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3885/* The address of the ALT_USB_HOST_HCSPLT15 register for the ALT_USB0_HOSTGRP instance. */
3886#define ALT_USB0_HOST_HCSPLT15_ADDR ALT_USB_HOST_HCSPLT15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3887/* The address of the ALT_USB_HOST_HCINT15 register for the ALT_USB0_HOSTGRP instance. */
3888#define ALT_USB0_HOST_HCINT15_ADDR ALT_USB_HOST_HCINT15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3889/* The address of the ALT_USB_HOST_HCINTMSK15 register for the ALT_USB0_HOSTGRP instance. */
3890#define ALT_USB0_HOST_HCINTMSK15_ADDR ALT_USB_HOST_HCINTMSK15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3891/* The address of the ALT_USB_HOST_HCTSIZ15 register for the ALT_USB0_HOSTGRP instance. */
3892#define ALT_USB0_HOST_HCTSIZ15_ADDR ALT_USB_HOST_HCTSIZ15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3893/* The address of the ALT_USB_HOST_HCDMA15 register for the ALT_USB0_HOSTGRP instance. */
3894#define ALT_USB0_HOST_HCDMA15_ADDR ALT_USB_HOST_HCDMA15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3895/* The address of the ALT_USB_HOST_HCDMAB15 register for the ALT_USB0_HOSTGRP instance. */
3896#define ALT_USB0_HOST_HCDMAB15_ADDR ALT_USB_HOST_HCDMAB15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3897/* The base address byte offset for the start of the ALT_USB0_HOSTGRP component. */
3898#define ALT_USB0_HOSTGRP_OFST 0x400
3899/* The start address of the ALT_USB0_HOSTGRP component. */
3900#define ALT_USB0_HOSTGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB0_ADDR) + ALT_USB0_HOSTGRP_OFST))
3901/* The lower bound address range of the ALT_USB0_HOSTGRP component. */
3902#define ALT_USB0_HOSTGRP_LB_ADDR ALT_USB0_HOSTGRP_ADDR
3903/* The upper bound address range of the ALT_USB0_HOSTGRP component. */
3904#define ALT_USB0_HOSTGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB0_HOSTGRP_ADDR) + 0x2fc) - 1))
3905
3906
3907/*
3908 * Register Group Instance : devgrp
3909 *
3910 * Instance devgrp of register group ALT_USB_DEV.
3911 *
3912 *
3913 */
3914/* The address of the ALT_USB_DEV_DCFG register for the ALT_USB0_DEVGRP instance. */
3915#define ALT_USB0_DEV_DCFG_ADDR ALT_USB_DEV_DCFG_ADDR(ALT_USB0_DEVGRP_ADDR)
3916/* The address of the ALT_USB_DEV_DCTL register for the ALT_USB0_DEVGRP instance. */
3917#define ALT_USB0_DEV_DCTL_ADDR ALT_USB_DEV_DCTL_ADDR(ALT_USB0_DEVGRP_ADDR)
3918/* The address of the ALT_USB_DEV_DSTS register for the ALT_USB0_DEVGRP instance. */
3919#define ALT_USB0_DEV_DSTS_ADDR ALT_USB_DEV_DSTS_ADDR(ALT_USB0_DEVGRP_ADDR)
3920/* The address of the ALT_USB_DEV_DIEPMSK register for the ALT_USB0_DEVGRP instance. */
3921#define ALT_USB0_DEV_DIEPMSK_ADDR ALT_USB_DEV_DIEPMSK_ADDR(ALT_USB0_DEVGRP_ADDR)
3922/* The address of the ALT_USB_DEV_DOEPMSK register for the ALT_USB0_DEVGRP instance. */
3923#define ALT_USB0_DEV_DOEPMSK_ADDR ALT_USB_DEV_DOEPMSK_ADDR(ALT_USB0_DEVGRP_ADDR)
3924/* The address of the ALT_USB_DEV_DAINT register for the ALT_USB0_DEVGRP instance. */
3925#define ALT_USB0_DEV_DAINT_ADDR ALT_USB_DEV_DAINT_ADDR(ALT_USB0_DEVGRP_ADDR)
3926/* The address of the ALT_USB_DEV_DAINTMSK register for the ALT_USB0_DEVGRP instance. */
3927#define ALT_USB0_DEV_DAINTMSK_ADDR ALT_USB_DEV_DAINTMSK_ADDR(ALT_USB0_DEVGRP_ADDR)
3928/* The address of the ALT_USB_DEV_DVBUSDIS register for the ALT_USB0_DEVGRP instance. */
3929#define ALT_USB0_DEV_DVBUSDIS_ADDR ALT_USB_DEV_DVBUSDIS_ADDR(ALT_USB0_DEVGRP_ADDR)
3930/* The address of the ALT_USB_DEV_DVBUSPULSE register for the ALT_USB0_DEVGRP instance. */
3931#define ALT_USB0_DEV_DVBUSPULSE_ADDR ALT_USB_DEV_DVBUSPULSE_ADDR(ALT_USB0_DEVGRP_ADDR)
3932/* The address of the ALT_USB_DEV_DTHRCTL register for the ALT_USB0_DEVGRP instance. */
3933#define ALT_USB0_DEV_DTHRCTL_ADDR ALT_USB_DEV_DTHRCTL_ADDR(ALT_USB0_DEVGRP_ADDR)
3934/* The address of the ALT_USB_DEV_DIEPEMPMSK register for the ALT_USB0_DEVGRP instance. */
3935#define ALT_USB0_DEV_DIEPEMPMSK_ADDR ALT_USB_DEV_DIEPEMPMSK_ADDR(ALT_USB0_DEVGRP_ADDR)
3936/* The address of the ALT_USB_DEV_DIEPCTL0 register for the ALT_USB0_DEVGRP instance. */
3937#define ALT_USB0_DEV_DIEPCTL0_ADDR ALT_USB_DEV_DIEPCTL0_ADDR(ALT_USB0_DEVGRP_ADDR)
3938/* The address of the ALT_USB_DEV_DIEPINT0 register for the ALT_USB0_DEVGRP instance. */
3939#define ALT_USB0_DEV_DIEPINT0_ADDR ALT_USB_DEV_DIEPINT0_ADDR(ALT_USB0_DEVGRP_ADDR)
3940/* The address of the ALT_USB_DEV_DIEPTSIZ0 register for the ALT_USB0_DEVGRP instance. */
3941#define ALT_USB0_DEV_DIEPTSIZ0_ADDR ALT_USB_DEV_DIEPTSIZ0_ADDR(ALT_USB0_DEVGRP_ADDR)
3942/* The address of the ALT_USB_DEV_DIEPDMA0 register for the ALT_USB0_DEVGRP instance. */
3943#define ALT_USB0_DEV_DIEPDMA0_ADDR ALT_USB_DEV_DIEPDMA0_ADDR(ALT_USB0_DEVGRP_ADDR)
3944/* The address of the ALT_USB_DEV_DTXFSTS0 register for the ALT_USB0_DEVGRP instance. */
3945#define ALT_USB0_DEV_DTXFSTS0_ADDR ALT_USB_DEV_DTXFSTS0_ADDR(ALT_USB0_DEVGRP_ADDR)
3946/* The address of the ALT_USB_DEV_DIEPDMAB0 register for the ALT_USB0_DEVGRP instance. */
3947#define ALT_USB0_DEV_DIEPDMAB0_ADDR ALT_USB_DEV_DIEPDMAB0_ADDR(ALT_USB0_DEVGRP_ADDR)
3948/* The address of the ALT_USB_DEV_DIEPCTL1 register for the ALT_USB0_DEVGRP instance. */
3949#define ALT_USB0_DEV_DIEPCTL1_ADDR ALT_USB_DEV_DIEPCTL1_ADDR(ALT_USB0_DEVGRP_ADDR)
3950/* The address of the ALT_USB_DEV_DIEPINT1 register for the ALT_USB0_DEVGRP instance. */
3951#define ALT_USB0_DEV_DIEPINT1_ADDR ALT_USB_DEV_DIEPINT1_ADDR(ALT_USB0_DEVGRP_ADDR)
3952/* The address of the ALT_USB_DEV_DIEPTSIZ1 register for the ALT_USB0_DEVGRP instance. */
3953#define ALT_USB0_DEV_DIEPTSIZ1_ADDR ALT_USB_DEV_DIEPTSIZ1_ADDR(ALT_USB0_DEVGRP_ADDR)
3954/* The address of the ALT_USB_DEV_DIEPDMA1 register for the ALT_USB0_DEVGRP instance. */
3955#define ALT_USB0_DEV_DIEPDMA1_ADDR ALT_USB_DEV_DIEPDMA1_ADDR(ALT_USB0_DEVGRP_ADDR)
3956/* The address of the ALT_USB_DEV_DTXFSTS1 register for the ALT_USB0_DEVGRP instance. */
3957#define ALT_USB0_DEV_DTXFSTS1_ADDR ALT_USB_DEV_DTXFSTS1_ADDR(ALT_USB0_DEVGRP_ADDR)
3958/* The address of the ALT_USB_DEV_DIEPDMAB1 register for the ALT_USB0_DEVGRP instance. */
3959#define ALT_USB0_DEV_DIEPDMAB1_ADDR ALT_USB_DEV_DIEPDMAB1_ADDR(ALT_USB0_DEVGRP_ADDR)
3960/* The address of the ALT_USB_DEV_DIEPCTL2 register for the ALT_USB0_DEVGRP instance. */
3961#define ALT_USB0_DEV_DIEPCTL2_ADDR ALT_USB_DEV_DIEPCTL2_ADDR(ALT_USB0_DEVGRP_ADDR)
3962/* The address of the ALT_USB_DEV_DIEPINT2 register for the ALT_USB0_DEVGRP instance. */
3963#define ALT_USB0_DEV_DIEPINT2_ADDR ALT_USB_DEV_DIEPINT2_ADDR(ALT_USB0_DEVGRP_ADDR)
3964/* The address of the ALT_USB_DEV_DIEPTSIZ2 register for the ALT_USB0_DEVGRP instance. */
3965#define ALT_USB0_DEV_DIEPTSIZ2_ADDR ALT_USB_DEV_DIEPTSIZ2_ADDR(ALT_USB0_DEVGRP_ADDR)
3966/* The address of the ALT_USB_DEV_DIEPDMA2 register for the ALT_USB0_DEVGRP instance. */
3967#define ALT_USB0_DEV_DIEPDMA2_ADDR ALT_USB_DEV_DIEPDMA2_ADDR(ALT_USB0_DEVGRP_ADDR)
3968/* The address of the ALT_USB_DEV_DTXFSTS2 register for the ALT_USB0_DEVGRP instance. */
3969#define ALT_USB0_DEV_DTXFSTS2_ADDR ALT_USB_DEV_DTXFSTS2_ADDR(ALT_USB0_DEVGRP_ADDR)
3970/* The address of the ALT_USB_DEV_DIEPDMAB2 register for the ALT_USB0_DEVGRP instance. */
3971#define ALT_USB0_DEV_DIEPDMAB2_ADDR ALT_USB_DEV_DIEPDMAB2_ADDR(ALT_USB0_DEVGRP_ADDR)
3972/* The address of the ALT_USB_DEV_DIEPCTL3 register for the ALT_USB0_DEVGRP instance. */
3973#define ALT_USB0_DEV_DIEPCTL3_ADDR ALT_USB_DEV_DIEPCTL3_ADDR(ALT_USB0_DEVGRP_ADDR)
3974/* The address of the ALT_USB_DEV_DIEPINT3 register for the ALT_USB0_DEVGRP instance. */
3975#define ALT_USB0_DEV_DIEPINT3_ADDR ALT_USB_DEV_DIEPINT3_ADDR(ALT_USB0_DEVGRP_ADDR)
3976/* The address of the ALT_USB_DEV_DIEPTSIZ3 register for the ALT_USB0_DEVGRP instance. */
3977#define ALT_USB0_DEV_DIEPTSIZ3_ADDR ALT_USB_DEV_DIEPTSIZ3_ADDR(ALT_USB0_DEVGRP_ADDR)
3978/* The address of the ALT_USB_DEV_DIEPDMA3 register for the ALT_USB0_DEVGRP instance. */
3979#define ALT_USB0_DEV_DIEPDMA3_ADDR ALT_USB_DEV_DIEPDMA3_ADDR(ALT_USB0_DEVGRP_ADDR)
3980/* The address of the ALT_USB_DEV_DTXFSTS3 register for the ALT_USB0_DEVGRP instance. */
3981#define ALT_USB0_DEV_DTXFSTS3_ADDR ALT_USB_DEV_DTXFSTS3_ADDR(ALT_USB0_DEVGRP_ADDR)
3982/* The address of the ALT_USB_DEV_DIEPDMAB3 register for the ALT_USB0_DEVGRP instance. */
3983#define ALT_USB0_DEV_DIEPDMAB3_ADDR ALT_USB_DEV_DIEPDMAB3_ADDR(ALT_USB0_DEVGRP_ADDR)
3984/* The address of the ALT_USB_DEV_DIEPCTL4 register for the ALT_USB0_DEVGRP instance. */
3985#define ALT_USB0_DEV_DIEPCTL4_ADDR ALT_USB_DEV_DIEPCTL4_ADDR(ALT_USB0_DEVGRP_ADDR)
3986/* The address of the ALT_USB_DEV_DIEPINT4 register for the ALT_USB0_DEVGRP instance. */
3987#define ALT_USB0_DEV_DIEPINT4_ADDR ALT_USB_DEV_DIEPINT4_ADDR(ALT_USB0_DEVGRP_ADDR)
3988/* The address of the ALT_USB_DEV_DIEPTSIZ4 register for the ALT_USB0_DEVGRP instance. */
3989#define ALT_USB0_DEV_DIEPTSIZ4_ADDR ALT_USB_DEV_DIEPTSIZ4_ADDR(ALT_USB0_DEVGRP_ADDR)
3990/* The address of the ALT_USB_DEV_DIEPDMA4 register for the ALT_USB0_DEVGRP instance. */
3991#define ALT_USB0_DEV_DIEPDMA4_ADDR ALT_USB_DEV_DIEPDMA4_ADDR(ALT_USB0_DEVGRP_ADDR)
3992/* The address of the ALT_USB_DEV_DTXFSTS4 register for the ALT_USB0_DEVGRP instance. */
3993#define ALT_USB0_DEV_DTXFSTS4_ADDR ALT_USB_DEV_DTXFSTS4_ADDR(ALT_USB0_DEVGRP_ADDR)
3994/* The address of the ALT_USB_DEV_DIEPDMAB4 register for the ALT_USB0_DEVGRP instance. */
3995#define ALT_USB0_DEV_DIEPDMAB4_ADDR ALT_USB_DEV_DIEPDMAB4_ADDR(ALT_USB0_DEVGRP_ADDR)
3996/* The address of the ALT_USB_DEV_DIEPCTL5 register for the ALT_USB0_DEVGRP instance. */
3997#define ALT_USB0_DEV_DIEPCTL5_ADDR ALT_USB_DEV_DIEPCTL5_ADDR(ALT_USB0_DEVGRP_ADDR)
3998/* The address of the ALT_USB_DEV_DIEPINT5 register for the ALT_USB0_DEVGRP instance. */
3999#define ALT_USB0_DEV_DIEPINT5_ADDR ALT_USB_DEV_DIEPINT5_ADDR(ALT_USB0_DEVGRP_ADDR)
4000/* The address of the ALT_USB_DEV_DIEPTSIZ5 register for the ALT_USB0_DEVGRP instance. */
4001#define ALT_USB0_DEV_DIEPTSIZ5_ADDR ALT_USB_DEV_DIEPTSIZ5_ADDR(ALT_USB0_DEVGRP_ADDR)
4002/* The address of the ALT_USB_DEV_DIEPDMA5 register for the ALT_USB0_DEVGRP instance. */
4003#define ALT_USB0_DEV_DIEPDMA5_ADDR ALT_USB_DEV_DIEPDMA5_ADDR(ALT_USB0_DEVGRP_ADDR)
4004/* The address of the ALT_USB_DEV_DTXFSTS5 register for the ALT_USB0_DEVGRP instance. */
4005#define ALT_USB0_DEV_DTXFSTS5_ADDR ALT_USB_DEV_DTXFSTS5_ADDR(ALT_USB0_DEVGRP_ADDR)
4006/* The address of the ALT_USB_DEV_DIEPDMAB5 register for the ALT_USB0_DEVGRP instance. */
4007#define ALT_USB0_DEV_DIEPDMAB5_ADDR ALT_USB_DEV_DIEPDMAB5_ADDR(ALT_USB0_DEVGRP_ADDR)
4008/* The address of the ALT_USB_DEV_DIEPCTL6 register for the ALT_USB0_DEVGRP instance. */
4009#define ALT_USB0_DEV_DIEPCTL6_ADDR ALT_USB_DEV_DIEPCTL6_ADDR(ALT_USB0_DEVGRP_ADDR)
4010/* The address of the ALT_USB_DEV_DIEPINT6 register for the ALT_USB0_DEVGRP instance. */
4011#define ALT_USB0_DEV_DIEPINT6_ADDR ALT_USB_DEV_DIEPINT6_ADDR(ALT_USB0_DEVGRP_ADDR)
4012/* The address of the ALT_USB_DEV_DIEPTSIZ6 register for the ALT_USB0_DEVGRP instance. */
4013#define ALT_USB0_DEV_DIEPTSIZ6_ADDR ALT_USB_DEV_DIEPTSIZ6_ADDR(ALT_USB0_DEVGRP_ADDR)
4014/* The address of the ALT_USB_DEV_DIEPDMA6 register for the ALT_USB0_DEVGRP instance. */
4015#define ALT_USB0_DEV_DIEPDMA6_ADDR ALT_USB_DEV_DIEPDMA6_ADDR(ALT_USB0_DEVGRP_ADDR)
4016/* The address of the ALT_USB_DEV_DTXFSTS6 register for the ALT_USB0_DEVGRP instance. */
4017#define ALT_USB0_DEV_DTXFSTS6_ADDR ALT_USB_DEV_DTXFSTS6_ADDR(ALT_USB0_DEVGRP_ADDR)
4018/* The address of the ALT_USB_DEV_DIEPDMAB6 register for the ALT_USB0_DEVGRP instance. */
4019#define ALT_USB0_DEV_DIEPDMAB6_ADDR ALT_USB_DEV_DIEPDMAB6_ADDR(ALT_USB0_DEVGRP_ADDR)
4020/* The address of the ALT_USB_DEV_DIEPCTL7 register for the ALT_USB0_DEVGRP instance. */
4021#define ALT_USB0_DEV_DIEPCTL7_ADDR ALT_USB_DEV_DIEPCTL7_ADDR(ALT_USB0_DEVGRP_ADDR)
4022/* The address of the ALT_USB_DEV_DIEPINT7 register for the ALT_USB0_DEVGRP instance. */
4023#define ALT_USB0_DEV_DIEPINT7_ADDR ALT_USB_DEV_DIEPINT7_ADDR(ALT_USB0_DEVGRP_ADDR)
4024/* The address of the ALT_USB_DEV_DIEPTSIZ7 register for the ALT_USB0_DEVGRP instance. */
4025#define ALT_USB0_DEV_DIEPTSIZ7_ADDR ALT_USB_DEV_DIEPTSIZ7_ADDR(ALT_USB0_DEVGRP_ADDR)
4026/* The address of the ALT_USB_DEV_DIEPDMA7 register for the ALT_USB0_DEVGRP instance. */
4027#define ALT_USB0_DEV_DIEPDMA7_ADDR ALT_USB_DEV_DIEPDMA7_ADDR(ALT_USB0_DEVGRP_ADDR)
4028/* The address of the ALT_USB_DEV_DTXFSTS7 register for the ALT_USB0_DEVGRP instance. */
4029#define ALT_USB0_DEV_DTXFSTS7_ADDR ALT_USB_DEV_DTXFSTS7_ADDR(ALT_USB0_DEVGRP_ADDR)
4030/* The address of the ALT_USB_DEV_DIEPDMAB7 register for the ALT_USB0_DEVGRP instance. */
4031#define ALT_USB0_DEV_DIEPDMAB7_ADDR ALT_USB_DEV_DIEPDMAB7_ADDR(ALT_USB0_DEVGRP_ADDR)
4032/* The address of the ALT_USB_DEV_DIEPCTL8 register for the ALT_USB0_DEVGRP instance. */
4033#define ALT_USB0_DEV_DIEPCTL8_ADDR ALT_USB_DEV_DIEPCTL8_ADDR(ALT_USB0_DEVGRP_ADDR)
4034/* The address of the ALT_USB_DEV_DIEPINT8 register for the ALT_USB0_DEVGRP instance. */
4035#define ALT_USB0_DEV_DIEPINT8_ADDR ALT_USB_DEV_DIEPINT8_ADDR(ALT_USB0_DEVGRP_ADDR)
4036/* The address of the ALT_USB_DEV_DIEPTSIZ8 register for the ALT_USB0_DEVGRP instance. */
4037#define ALT_USB0_DEV_DIEPTSIZ8_ADDR ALT_USB_DEV_DIEPTSIZ8_ADDR(ALT_USB0_DEVGRP_ADDR)
4038/* The address of the ALT_USB_DEV_DIEPDMA8 register for the ALT_USB0_DEVGRP instance. */
4039#define ALT_USB0_DEV_DIEPDMA8_ADDR ALT_USB_DEV_DIEPDMA8_ADDR(ALT_USB0_DEVGRP_ADDR)
4040/* The address of the ALT_USB_DEV_DTXFSTS8 register for the ALT_USB0_DEVGRP instance. */
4041#define ALT_USB0_DEV_DTXFSTS8_ADDR ALT_USB_DEV_DTXFSTS8_ADDR(ALT_USB0_DEVGRP_ADDR)
4042/* The address of the ALT_USB_DEV_DIEPDMAB8 register for the ALT_USB0_DEVGRP instance. */
4043#define ALT_USB0_DEV_DIEPDMAB8_ADDR ALT_USB_DEV_DIEPDMAB8_ADDR(ALT_USB0_DEVGRP_ADDR)
4044/* The address of the ALT_USB_DEV_DIEPCTL9 register for the ALT_USB0_DEVGRP instance. */
4045#define ALT_USB0_DEV_DIEPCTL9_ADDR ALT_USB_DEV_DIEPCTL9_ADDR(ALT_USB0_DEVGRP_ADDR)
4046/* The address of the ALT_USB_DEV_DIEPINT9 register for the ALT_USB0_DEVGRP instance. */
4047#define ALT_USB0_DEV_DIEPINT9_ADDR ALT_USB_DEV_DIEPINT9_ADDR(ALT_USB0_DEVGRP_ADDR)
4048/* The address of the ALT_USB_DEV_DIEPTSIZ9 register for the ALT_USB0_DEVGRP instance. */
4049#define ALT_USB0_DEV_DIEPTSIZ9_ADDR ALT_USB_DEV_DIEPTSIZ9_ADDR(ALT_USB0_DEVGRP_ADDR)
4050/* The address of the ALT_USB_DEV_DIEPDMA9 register for the ALT_USB0_DEVGRP instance. */
4051#define ALT_USB0_DEV_DIEPDMA9_ADDR ALT_USB_DEV_DIEPDMA9_ADDR(ALT_USB0_DEVGRP_ADDR)
4052/* The address of the ALT_USB_DEV_DTXFSTS9 register for the ALT_USB0_DEVGRP instance. */
4053#define ALT_USB0_DEV_DTXFSTS9_ADDR ALT_USB_DEV_DTXFSTS9_ADDR(ALT_USB0_DEVGRP_ADDR)
4054/* The address of the ALT_USB_DEV_DIEPDMAB9 register for the ALT_USB0_DEVGRP instance. */
4055#define ALT_USB0_DEV_DIEPDMAB9_ADDR ALT_USB_DEV_DIEPDMAB9_ADDR(ALT_USB0_DEVGRP_ADDR)
4056/* The address of the ALT_USB_DEV_DIEPCTL10 register for the ALT_USB0_DEVGRP instance. */
4057#define ALT_USB0_DEV_DIEPCTL10_ADDR ALT_USB_DEV_DIEPCTL10_ADDR(ALT_USB0_DEVGRP_ADDR)
4058/* The address of the ALT_USB_DEV_DIEPINT10 register for the ALT_USB0_DEVGRP instance. */
4059#define ALT_USB0_DEV_DIEPINT10_ADDR ALT_USB_DEV_DIEPINT10_ADDR(ALT_USB0_DEVGRP_ADDR)
4060/* The address of the ALT_USB_DEV_DIEPTSIZ10 register for the ALT_USB0_DEVGRP instance. */
4061#define ALT_USB0_DEV_DIEPTSIZ10_ADDR ALT_USB_DEV_DIEPTSIZ10_ADDR(ALT_USB0_DEVGRP_ADDR)
4062/* The address of the ALT_USB_DEV_DIEPDMA10 register for the ALT_USB0_DEVGRP instance. */
4063#define ALT_USB0_DEV_DIEPDMA10_ADDR ALT_USB_DEV_DIEPDMA10_ADDR(ALT_USB0_DEVGRP_ADDR)
4064/* The address of the ALT_USB_DEV_DTXFSTS10 register for the ALT_USB0_DEVGRP instance. */
4065#define ALT_USB0_DEV_DTXFSTS10_ADDR ALT_USB_DEV_DTXFSTS10_ADDR(ALT_USB0_DEVGRP_ADDR)
4066/* The address of the ALT_USB_DEV_DIEPDMAB10 register for the ALT_USB0_DEVGRP instance. */
4067#define ALT_USB0_DEV_DIEPDMAB10_ADDR ALT_USB_DEV_DIEPDMAB10_ADDR(ALT_USB0_DEVGRP_ADDR)
4068/* The address of the ALT_USB_DEV_DIEPCTL11 register for the ALT_USB0_DEVGRP instance. */
4069#define ALT_USB0_DEV_DIEPCTL11_ADDR ALT_USB_DEV_DIEPCTL11_ADDR(ALT_USB0_DEVGRP_ADDR)
4070/* The address of the ALT_USB_DEV_DIEPINT11 register for the ALT_USB0_DEVGRP instance. */
4071#define ALT_USB0_DEV_DIEPINT11_ADDR ALT_USB_DEV_DIEPINT11_ADDR(ALT_USB0_DEVGRP_ADDR)
4072/* The address of the ALT_USB_DEV_DIEPTSIZ11 register for the ALT_USB0_DEVGRP instance. */
4073#define ALT_USB0_DEV_DIEPTSIZ11_ADDR ALT_USB_DEV_DIEPTSIZ11_ADDR(ALT_USB0_DEVGRP_ADDR)
4074/* The address of the ALT_USB_DEV_DIEPDMA11 register for the ALT_USB0_DEVGRP instance. */
4075#define ALT_USB0_DEV_DIEPDMA11_ADDR ALT_USB_DEV_DIEPDMA11_ADDR(ALT_USB0_DEVGRP_ADDR)
4076/* The address of the ALT_USB_DEV_DTXFSTS11 register for the ALT_USB0_DEVGRP instance. */
4077#define ALT_USB0_DEV_DTXFSTS11_ADDR ALT_USB_DEV_DTXFSTS11_ADDR(ALT_USB0_DEVGRP_ADDR)
4078/* The address of the ALT_USB_DEV_DIEPDMAB11 register for the ALT_USB0_DEVGRP instance. */
4079#define ALT_USB0_DEV_DIEPDMAB11_ADDR ALT_USB_DEV_DIEPDMAB11_ADDR(ALT_USB0_DEVGRP_ADDR)
4080/* The address of the ALT_USB_DEV_DIEPCTL12 register for the ALT_USB0_DEVGRP instance. */
4081#define ALT_USB0_DEV_DIEPCTL12_ADDR ALT_USB_DEV_DIEPCTL12_ADDR(ALT_USB0_DEVGRP_ADDR)
4082/* The address of the ALT_USB_DEV_DIEPINT12 register for the ALT_USB0_DEVGRP instance. */
4083#define ALT_USB0_DEV_DIEPINT12_ADDR ALT_USB_DEV_DIEPINT12_ADDR(ALT_USB0_DEVGRP_ADDR)
4084/* The address of the ALT_USB_DEV_DIEPTSIZ12 register for the ALT_USB0_DEVGRP instance. */
4085#define ALT_USB0_DEV_DIEPTSIZ12_ADDR ALT_USB_DEV_DIEPTSIZ12_ADDR(ALT_USB0_DEVGRP_ADDR)
4086/* The address of the ALT_USB_DEV_DIEPDMA12 register for the ALT_USB0_DEVGRP instance. */
4087#define ALT_USB0_DEV_DIEPDMA12_ADDR ALT_USB_DEV_DIEPDMA12_ADDR(ALT_USB0_DEVGRP_ADDR)
4088/* The address of the ALT_USB_DEV_DTXFSTS12 register for the ALT_USB0_DEVGRP instance. */
4089#define ALT_USB0_DEV_DTXFSTS12_ADDR ALT_USB_DEV_DTXFSTS12_ADDR(ALT_USB0_DEVGRP_ADDR)
4090/* The address of the ALT_USB_DEV_DIEPDMAB12 register for the ALT_USB0_DEVGRP instance. */
4091#define ALT_USB0_DEV_DIEPDMAB12_ADDR ALT_USB_DEV_DIEPDMAB12_ADDR(ALT_USB0_DEVGRP_ADDR)
4092/* The address of the ALT_USB_DEV_DIEPCTL13 register for the ALT_USB0_DEVGRP instance. */
4093#define ALT_USB0_DEV_DIEPCTL13_ADDR ALT_USB_DEV_DIEPCTL13_ADDR(ALT_USB0_DEVGRP_ADDR)
4094/* The address of the ALT_USB_DEV_DIEPINT13 register for the ALT_USB0_DEVGRP instance. */
4095#define ALT_USB0_DEV_DIEPINT13_ADDR ALT_USB_DEV_DIEPINT13_ADDR(ALT_USB0_DEVGRP_ADDR)
4096/* The address of the ALT_USB_DEV_DIEPTSIZ13 register for the ALT_USB0_DEVGRP instance. */
4097#define ALT_USB0_DEV_DIEPTSIZ13_ADDR ALT_USB_DEV_DIEPTSIZ13_ADDR(ALT_USB0_DEVGRP_ADDR)
4098/* The address of the ALT_USB_DEV_DIEPDMA13 register for the ALT_USB0_DEVGRP instance. */
4099#define ALT_USB0_DEV_DIEPDMA13_ADDR ALT_USB_DEV_DIEPDMA13_ADDR(ALT_USB0_DEVGRP_ADDR)
4100/* The address of the ALT_USB_DEV_DTXFSTS13 register for the ALT_USB0_DEVGRP instance. */
4101#define ALT_USB0_DEV_DTXFSTS13_ADDR ALT_USB_DEV_DTXFSTS13_ADDR(ALT_USB0_DEVGRP_ADDR)
4102/* The address of the ALT_USB_DEV_DIEPDMAB13 register for the ALT_USB0_DEVGRP instance. */
4103#define ALT_USB0_DEV_DIEPDMAB13_ADDR ALT_USB_DEV_DIEPDMAB13_ADDR(ALT_USB0_DEVGRP_ADDR)
4104/* The address of the ALT_USB_DEV_DIEPCTL14 register for the ALT_USB0_DEVGRP instance. */
4105#define ALT_USB0_DEV_DIEPCTL14_ADDR ALT_USB_DEV_DIEPCTL14_ADDR(ALT_USB0_DEVGRP_ADDR)
4106/* The address of the ALT_USB_DEV_DIEPINT14 register for the ALT_USB0_DEVGRP instance. */
4107#define ALT_USB0_DEV_DIEPINT14_ADDR ALT_USB_DEV_DIEPINT14_ADDR(ALT_USB0_DEVGRP_ADDR)
4108/* The address of the ALT_USB_DEV_DIEPTSIZ14 register for the ALT_USB0_DEVGRP instance. */
4109#define ALT_USB0_DEV_DIEPTSIZ14_ADDR ALT_USB_DEV_DIEPTSIZ14_ADDR(ALT_USB0_DEVGRP_ADDR)
4110/* The address of the ALT_USB_DEV_DIEPDMA14 register for the ALT_USB0_DEVGRP instance. */
4111#define ALT_USB0_DEV_DIEPDMA14_ADDR ALT_USB_DEV_DIEPDMA14_ADDR(ALT_USB0_DEVGRP_ADDR)
4112/* The address of the ALT_USB_DEV_DTXFSTS14 register for the ALT_USB0_DEVGRP instance. */
4113#define ALT_USB0_DEV_DTXFSTS14_ADDR ALT_USB_DEV_DTXFSTS14_ADDR(ALT_USB0_DEVGRP_ADDR)
4114/* The address of the ALT_USB_DEV_DIEPDMAB14 register for the ALT_USB0_DEVGRP instance. */
4115#define ALT_USB0_DEV_DIEPDMAB14_ADDR ALT_USB_DEV_DIEPDMAB14_ADDR(ALT_USB0_DEVGRP_ADDR)
4116/* The address of the ALT_USB_DEV_DIEPCTL15 register for the ALT_USB0_DEVGRP instance. */
4117#define ALT_USB0_DEV_DIEPCTL15_ADDR ALT_USB_DEV_DIEPCTL15_ADDR(ALT_USB0_DEVGRP_ADDR)
4118/* The address of the ALT_USB_DEV_DIEPINT15 register for the ALT_USB0_DEVGRP instance. */
4119#define ALT_USB0_DEV_DIEPINT15_ADDR ALT_USB_DEV_DIEPINT15_ADDR(ALT_USB0_DEVGRP_ADDR)
4120/* The address of the ALT_USB_DEV_DIEPTSIZ15 register for the ALT_USB0_DEVGRP instance. */
4121#define ALT_USB0_DEV_DIEPTSIZ15_ADDR ALT_USB_DEV_DIEPTSIZ15_ADDR(ALT_USB0_DEVGRP_ADDR)
4122/* The address of the ALT_USB_DEV_DIEPDMA15 register for the ALT_USB0_DEVGRP instance. */
4123#define ALT_USB0_DEV_DIEPDMA15_ADDR ALT_USB_DEV_DIEPDMA15_ADDR(ALT_USB0_DEVGRP_ADDR)
4124/* The address of the ALT_USB_DEV_DTXFSTS15 register for the ALT_USB0_DEVGRP instance. */
4125#define ALT_USB0_DEV_DTXFSTS15_ADDR ALT_USB_DEV_DTXFSTS15_ADDR(ALT_USB0_DEVGRP_ADDR)
4126/* The address of the ALT_USB_DEV_DIEPDMAB15 register for the ALT_USB0_DEVGRP instance. */
4127#define ALT_USB0_DEV_DIEPDMAB15_ADDR ALT_USB_DEV_DIEPDMAB15_ADDR(ALT_USB0_DEVGRP_ADDR)
4128/* The address of the ALT_USB_DEV_DOEPCTL0 register for the ALT_USB0_DEVGRP instance. */
4129#define ALT_USB0_DEV_DOEPCTL0_ADDR ALT_USB_DEV_DOEPCTL0_ADDR(ALT_USB0_DEVGRP_ADDR)
4130/* The address of the ALT_USB_DEV_DOEPINT0 register for the ALT_USB0_DEVGRP instance. */
4131#define ALT_USB0_DEV_DOEPINT0_ADDR ALT_USB_DEV_DOEPINT0_ADDR(ALT_USB0_DEVGRP_ADDR)
4132/* The address of the ALT_USB_DEV_DOEPTSIZ0 register for the ALT_USB0_DEVGRP instance. */
4133#define ALT_USB0_DEV_DOEPTSIZ0_ADDR ALT_USB_DEV_DOEPTSIZ0_ADDR(ALT_USB0_DEVGRP_ADDR)
4134/* The address of the ALT_USB_DEV_DOEPDMA0 register for the ALT_USB0_DEVGRP instance. */
4135#define ALT_USB0_DEV_DOEPDMA0_ADDR ALT_USB_DEV_DOEPDMA0_ADDR(ALT_USB0_DEVGRP_ADDR)
4136/* The address of the ALT_USB_DEV_DOEPDMAB0 register for the ALT_USB0_DEVGRP instance. */
4137#define ALT_USB0_DEV_DOEPDMAB0_ADDR ALT_USB_DEV_DOEPDMAB0_ADDR(ALT_USB0_DEVGRP_ADDR)
4138/* The address of the ALT_USB_DEV_DOEPCTL1 register for the ALT_USB0_DEVGRP instance. */
4139#define ALT_USB0_DEV_DOEPCTL1_ADDR ALT_USB_DEV_DOEPCTL1_ADDR(ALT_USB0_DEVGRP_ADDR)
4140/* The address of the ALT_USB_DEV_DOEPINT1 register for the ALT_USB0_DEVGRP instance. */
4141#define ALT_USB0_DEV_DOEPINT1_ADDR ALT_USB_DEV_DOEPINT1_ADDR(ALT_USB0_DEVGRP_ADDR)
4142/* The address of the ALT_USB_DEV_DOEPTSIZ1 register for the ALT_USB0_DEVGRP instance. */
4143#define ALT_USB0_DEV_DOEPTSIZ1_ADDR ALT_USB_DEV_DOEPTSIZ1_ADDR(ALT_USB0_DEVGRP_ADDR)
4144/* The address of the ALT_USB_DEV_DOEPDMA1 register for the ALT_USB0_DEVGRP instance. */
4145#define ALT_USB0_DEV_DOEPDMA1_ADDR ALT_USB_DEV_DOEPDMA1_ADDR(ALT_USB0_DEVGRP_ADDR)
4146/* The address of the ALT_USB_DEV_DOEPDMAB1 register for the ALT_USB0_DEVGRP instance. */
4147#define ALT_USB0_DEV_DOEPDMAB1_ADDR ALT_USB_DEV_DOEPDMAB1_ADDR(ALT_USB0_DEVGRP_ADDR)
4148/* The address of the ALT_USB_DEV_DOEPCTL2 register for the ALT_USB0_DEVGRP instance. */
4149#define ALT_USB0_DEV_DOEPCTL2_ADDR ALT_USB_DEV_DOEPCTL2_ADDR(ALT_USB0_DEVGRP_ADDR)
4150/* The address of the ALT_USB_DEV_DOEPINT2 register for the ALT_USB0_DEVGRP instance. */
4151#define ALT_USB0_DEV_DOEPINT2_ADDR ALT_USB_DEV_DOEPINT2_ADDR(ALT_USB0_DEVGRP_ADDR)
4152/* The address of the ALT_USB_DEV_DOEPTSIZ2 register for the ALT_USB0_DEVGRP instance. */
4153#define ALT_USB0_DEV_DOEPTSIZ2_ADDR ALT_USB_DEV_DOEPTSIZ2_ADDR(ALT_USB0_DEVGRP_ADDR)
4154/* The address of the ALT_USB_DEV_DOEPDMA2 register for the ALT_USB0_DEVGRP instance. */
4155#define ALT_USB0_DEV_DOEPDMA2_ADDR ALT_USB_DEV_DOEPDMA2_ADDR(ALT_USB0_DEVGRP_ADDR)
4156/* The address of the ALT_USB_DEV_DOEPDMAB2 register for the ALT_USB0_DEVGRP instance. */
4157#define ALT_USB0_DEV_DOEPDMAB2_ADDR ALT_USB_DEV_DOEPDMAB2_ADDR(ALT_USB0_DEVGRP_ADDR)
4158/* The address of the ALT_USB_DEV_DOEPCTL3 register for the ALT_USB0_DEVGRP instance. */
4159#define ALT_USB0_DEV_DOEPCTL3_ADDR ALT_USB_DEV_DOEPCTL3_ADDR(ALT_USB0_DEVGRP_ADDR)
4160/* The address of the ALT_USB_DEV_DOEPINT3 register for the ALT_USB0_DEVGRP instance. */
4161#define ALT_USB0_DEV_DOEPINT3_ADDR ALT_USB_DEV_DOEPINT3_ADDR(ALT_USB0_DEVGRP_ADDR)
4162/* The address of the ALT_USB_DEV_DOEPTSIZ3 register for the ALT_USB0_DEVGRP instance. */
4163#define ALT_USB0_DEV_DOEPTSIZ3_ADDR ALT_USB_DEV_DOEPTSIZ3_ADDR(ALT_USB0_DEVGRP_ADDR)
4164/* The address of the ALT_USB_DEV_DOEPDMA3 register for the ALT_USB0_DEVGRP instance. */
4165#define ALT_USB0_DEV_DOEPDMA3_ADDR ALT_USB_DEV_DOEPDMA3_ADDR(ALT_USB0_DEVGRP_ADDR)
4166/* The address of the ALT_USB_DEV_DOEPDMAB3 register for the ALT_USB0_DEVGRP instance. */
4167#define ALT_USB0_DEV_DOEPDMAB3_ADDR ALT_USB_DEV_DOEPDMAB3_ADDR(ALT_USB0_DEVGRP_ADDR)
4168/* The address of the ALT_USB_DEV_DOEPCTL4 register for the ALT_USB0_DEVGRP instance. */
4169#define ALT_USB0_DEV_DOEPCTL4_ADDR ALT_USB_DEV_DOEPCTL4_ADDR(ALT_USB0_DEVGRP_ADDR)
4170/* The address of the ALT_USB_DEV_DOEPINT4 register for the ALT_USB0_DEVGRP instance. */
4171#define ALT_USB0_DEV_DOEPINT4_ADDR ALT_USB_DEV_DOEPINT4_ADDR(ALT_USB0_DEVGRP_ADDR)
4172/* The address of the ALT_USB_DEV_DOEPTSIZ4 register for the ALT_USB0_DEVGRP instance. */
4173#define ALT_USB0_DEV_DOEPTSIZ4_ADDR ALT_USB_DEV_DOEPTSIZ4_ADDR(ALT_USB0_DEVGRP_ADDR)
4174/* The address of the ALT_USB_DEV_DOEPDMA4 register for the ALT_USB0_DEVGRP instance. */
4175#define ALT_USB0_DEV_DOEPDMA4_ADDR ALT_USB_DEV_DOEPDMA4_ADDR(ALT_USB0_DEVGRP_ADDR)
4176/* The address of the ALT_USB_DEV_DOEPDMAB4 register for the ALT_USB0_DEVGRP instance. */
4177#define ALT_USB0_DEV_DOEPDMAB4_ADDR ALT_USB_DEV_DOEPDMAB4_ADDR(ALT_USB0_DEVGRP_ADDR)
4178/* The address of the ALT_USB_DEV_DOEPCTL5 register for the ALT_USB0_DEVGRP instance. */
4179#define ALT_USB0_DEV_DOEPCTL5_ADDR ALT_USB_DEV_DOEPCTL5_ADDR(ALT_USB0_DEVGRP_ADDR)
4180/* The address of the ALT_USB_DEV_DOEPINT5 register for the ALT_USB0_DEVGRP instance. */
4181#define ALT_USB0_DEV_DOEPINT5_ADDR ALT_USB_DEV_DOEPINT5_ADDR(ALT_USB0_DEVGRP_ADDR)
4182/* The address of the ALT_USB_DEV_DOEPTSIZ5 register for the ALT_USB0_DEVGRP instance. */
4183#define ALT_USB0_DEV_DOEPTSIZ5_ADDR ALT_USB_DEV_DOEPTSIZ5_ADDR(ALT_USB0_DEVGRP_ADDR)
4184/* The address of the ALT_USB_DEV_DOEPDMA5 register for the ALT_USB0_DEVGRP instance. */
4185#define ALT_USB0_DEV_DOEPDMA5_ADDR ALT_USB_DEV_DOEPDMA5_ADDR(ALT_USB0_DEVGRP_ADDR)
4186/* The address of the ALT_USB_DEV_DOEPDMAB5 register for the ALT_USB0_DEVGRP instance. */
4187#define ALT_USB0_DEV_DOEPDMAB5_ADDR ALT_USB_DEV_DOEPDMAB5_ADDR(ALT_USB0_DEVGRP_ADDR)
4188/* The address of the ALT_USB_DEV_DOEPCTL6 register for the ALT_USB0_DEVGRP instance. */
4189#define ALT_USB0_DEV_DOEPCTL6_ADDR ALT_USB_DEV_DOEPCTL6_ADDR(ALT_USB0_DEVGRP_ADDR)
4190/* The address of the ALT_USB_DEV_DOEPINT6 register for the ALT_USB0_DEVGRP instance. */
4191#define ALT_USB0_DEV_DOEPINT6_ADDR ALT_USB_DEV_DOEPINT6_ADDR(ALT_USB0_DEVGRP_ADDR)
4192/* The address of the ALT_USB_DEV_DOEPTSIZ6 register for the ALT_USB0_DEVGRP instance. */
4193#define ALT_USB0_DEV_DOEPTSIZ6_ADDR ALT_USB_DEV_DOEPTSIZ6_ADDR(ALT_USB0_DEVGRP_ADDR)
4194/* The address of the ALT_USB_DEV_DOEPDMA6 register for the ALT_USB0_DEVGRP instance. */
4195#define ALT_USB0_DEV_DOEPDMA6_ADDR ALT_USB_DEV_DOEPDMA6_ADDR(ALT_USB0_DEVGRP_ADDR)
4196/* The address of the ALT_USB_DEV_DOEPDMAB6 register for the ALT_USB0_DEVGRP instance. */
4197#define ALT_USB0_DEV_DOEPDMAB6_ADDR ALT_USB_DEV_DOEPDMAB6_ADDR(ALT_USB0_DEVGRP_ADDR)
4198/* The address of the ALT_USB_DEV_DOEPCTL7 register for the ALT_USB0_DEVGRP instance. */
4199#define ALT_USB0_DEV_DOEPCTL7_ADDR ALT_USB_DEV_DOEPCTL7_ADDR(ALT_USB0_DEVGRP_ADDR)
4200/* The address of the ALT_USB_DEV_DOEPINT7 register for the ALT_USB0_DEVGRP instance. */
4201#define ALT_USB0_DEV_DOEPINT7_ADDR ALT_USB_DEV_DOEPINT7_ADDR(ALT_USB0_DEVGRP_ADDR)
4202/* The address of the ALT_USB_DEV_DOEPTSIZ7 register for the ALT_USB0_DEVGRP instance. */
4203#define ALT_USB0_DEV_DOEPTSIZ7_ADDR ALT_USB_DEV_DOEPTSIZ7_ADDR(ALT_USB0_DEVGRP_ADDR)
4204/* The address of the ALT_USB_DEV_DOEPDMA7 register for the ALT_USB0_DEVGRP instance. */
4205#define ALT_USB0_DEV_DOEPDMA7_ADDR ALT_USB_DEV_DOEPDMA7_ADDR(ALT_USB0_DEVGRP_ADDR)
4206/* The address of the ALT_USB_DEV_DOEPDMAB7 register for the ALT_USB0_DEVGRP instance. */
4207#define ALT_USB0_DEV_DOEPDMAB7_ADDR ALT_USB_DEV_DOEPDMAB7_ADDR(ALT_USB0_DEVGRP_ADDR)
4208/* The address of the ALT_USB_DEV_DOEPCTL8 register for the ALT_USB0_DEVGRP instance. */
4209#define ALT_USB0_DEV_DOEPCTL8_ADDR ALT_USB_DEV_DOEPCTL8_ADDR(ALT_USB0_DEVGRP_ADDR)
4210/* The address of the ALT_USB_DEV_DOEPINT8 register for the ALT_USB0_DEVGRP instance. */
4211#define ALT_USB0_DEV_DOEPINT8_ADDR ALT_USB_DEV_DOEPINT8_ADDR(ALT_USB0_DEVGRP_ADDR)
4212/* The address of the ALT_USB_DEV_DOEPTSIZ8 register for the ALT_USB0_DEVGRP instance. */
4213#define ALT_USB0_DEV_DOEPTSIZ8_ADDR ALT_USB_DEV_DOEPTSIZ8_ADDR(ALT_USB0_DEVGRP_ADDR)
4214/* The address of the ALT_USB_DEV_DOEPDMA8 register for the ALT_USB0_DEVGRP instance. */
4215#define ALT_USB0_DEV_DOEPDMA8_ADDR ALT_USB_DEV_DOEPDMA8_ADDR(ALT_USB0_DEVGRP_ADDR)
4216/* The address of the ALT_USB_DEV_DOEPDMAB8 register for the ALT_USB0_DEVGRP instance. */
4217#define ALT_USB0_DEV_DOEPDMAB8_ADDR ALT_USB_DEV_DOEPDMAB8_ADDR(ALT_USB0_DEVGRP_ADDR)
4218/* The address of the ALT_USB_DEV_DOEPCTL9 register for the ALT_USB0_DEVGRP instance. */
4219#define ALT_USB0_DEV_DOEPCTL9_ADDR ALT_USB_DEV_DOEPCTL9_ADDR(ALT_USB0_DEVGRP_ADDR)
4220/* The address of the ALT_USB_DEV_DOEPINT9 register for the ALT_USB0_DEVGRP instance. */
4221#define ALT_USB0_DEV_DOEPINT9_ADDR ALT_USB_DEV_DOEPINT9_ADDR(ALT_USB0_DEVGRP_ADDR)
4222/* The address of the ALT_USB_DEV_DOEPTSIZ9 register for the ALT_USB0_DEVGRP instance. */
4223#define ALT_USB0_DEV_DOEPTSIZ9_ADDR ALT_USB_DEV_DOEPTSIZ9_ADDR(ALT_USB0_DEVGRP_ADDR)
4224/* The address of the ALT_USB_DEV_DOEPDMA9 register for the ALT_USB0_DEVGRP instance. */
4225#define ALT_USB0_DEV_DOEPDMA9_ADDR ALT_USB_DEV_DOEPDMA9_ADDR(ALT_USB0_DEVGRP_ADDR)
4226/* The address of the ALT_USB_DEV_DOEPDMAB9 register for the ALT_USB0_DEVGRP instance. */
4227#define ALT_USB0_DEV_DOEPDMAB9_ADDR ALT_USB_DEV_DOEPDMAB9_ADDR(ALT_USB0_DEVGRP_ADDR)
4228/* The address of the ALT_USB_DEV_DOEPCTL10 register for the ALT_USB0_DEVGRP instance. */
4229#define ALT_USB0_DEV_DOEPCTL10_ADDR ALT_USB_DEV_DOEPCTL10_ADDR(ALT_USB0_DEVGRP_ADDR)
4230/* The address of the ALT_USB_DEV_DOEPINT10 register for the ALT_USB0_DEVGRP instance. */
4231#define ALT_USB0_DEV_DOEPINT10_ADDR ALT_USB_DEV_DOEPINT10_ADDR(ALT_USB0_DEVGRP_ADDR)
4232/* The address of the ALT_USB_DEV_DOEPTSIZ10 register for the ALT_USB0_DEVGRP instance. */
4233#define ALT_USB0_DEV_DOEPTSIZ10_ADDR ALT_USB_DEV_DOEPTSIZ10_ADDR(ALT_USB0_DEVGRP_ADDR)
4234/* The address of the ALT_USB_DEV_DOEPDMA10 register for the ALT_USB0_DEVGRP instance. */
4235#define ALT_USB0_DEV_DOEPDMA10_ADDR ALT_USB_DEV_DOEPDMA10_ADDR(ALT_USB0_DEVGRP_ADDR)
4236/* The address of the ALT_USB_DEV_DOEPDMAB10 register for the ALT_USB0_DEVGRP instance. */
4237#define ALT_USB0_DEV_DOEPDMAB10_ADDR ALT_USB_DEV_DOEPDMAB10_ADDR(ALT_USB0_DEVGRP_ADDR)
4238/* The address of the ALT_USB_DEV_DOEPCTL11 register for the ALT_USB0_DEVGRP instance. */
4239#define ALT_USB0_DEV_DOEPCTL11_ADDR ALT_USB_DEV_DOEPCTL11_ADDR(ALT_USB0_DEVGRP_ADDR)
4240/* The address of the ALT_USB_DEV_DOEPINT11 register for the ALT_USB0_DEVGRP instance. */
4241#define ALT_USB0_DEV_DOEPINT11_ADDR ALT_USB_DEV_DOEPINT11_ADDR(ALT_USB0_DEVGRP_ADDR)
4242/* The address of the ALT_USB_DEV_DOEPTSIZ11 register for the ALT_USB0_DEVGRP instance. */
4243#define ALT_USB0_DEV_DOEPTSIZ11_ADDR ALT_USB_DEV_DOEPTSIZ11_ADDR(ALT_USB0_DEVGRP_ADDR)
4244/* The address of the ALT_USB_DEV_DOEPDMA11 register for the ALT_USB0_DEVGRP instance. */
4245#define ALT_USB0_DEV_DOEPDMA11_ADDR ALT_USB_DEV_DOEPDMA11_ADDR(ALT_USB0_DEVGRP_ADDR)
4246/* The address of the ALT_USB_DEV_DOEPDMAB11 register for the ALT_USB0_DEVGRP instance. */
4247#define ALT_USB0_DEV_DOEPDMAB11_ADDR ALT_USB_DEV_DOEPDMAB11_ADDR(ALT_USB0_DEVGRP_ADDR)
4248/* The address of the ALT_USB_DEV_DOEPCTL12 register for the ALT_USB0_DEVGRP instance. */
4249#define ALT_USB0_DEV_DOEPCTL12_ADDR ALT_USB_DEV_DOEPCTL12_ADDR(ALT_USB0_DEVGRP_ADDR)
4250/* The address of the ALT_USB_DEV_DOEPINT12 register for the ALT_USB0_DEVGRP instance. */
4251#define ALT_USB0_DEV_DOEPINT12_ADDR ALT_USB_DEV_DOEPINT12_ADDR(ALT_USB0_DEVGRP_ADDR)
4252/* The address of the ALT_USB_DEV_DOEPTSIZ12 register for the ALT_USB0_DEVGRP instance. */
4253#define ALT_USB0_DEV_DOEPTSIZ12_ADDR ALT_USB_DEV_DOEPTSIZ12_ADDR(ALT_USB0_DEVGRP_ADDR)
4254/* The address of the ALT_USB_DEV_DOEPDMA12 register for the ALT_USB0_DEVGRP instance. */
4255#define ALT_USB0_DEV_DOEPDMA12_ADDR ALT_USB_DEV_DOEPDMA12_ADDR(ALT_USB0_DEVGRP_ADDR)
4256/* The address of the ALT_USB_DEV_DOEPDMAB12 register for the ALT_USB0_DEVGRP instance. */
4257#define ALT_USB0_DEV_DOEPDMAB12_ADDR ALT_USB_DEV_DOEPDMAB12_ADDR(ALT_USB0_DEVGRP_ADDR)
4258/* The address of the ALT_USB_DEV_DOEPCTL13 register for the ALT_USB0_DEVGRP instance. */
4259#define ALT_USB0_DEV_DOEPCTL13_ADDR ALT_USB_DEV_DOEPCTL13_ADDR(ALT_USB0_DEVGRP_ADDR)
4260/* The address of the ALT_USB_DEV_DOEPINT13 register for the ALT_USB0_DEVGRP instance. */
4261#define ALT_USB0_DEV_DOEPINT13_ADDR ALT_USB_DEV_DOEPINT13_ADDR(ALT_USB0_DEVGRP_ADDR)
4262/* The address of the ALT_USB_DEV_DOEPTSIZ13 register for the ALT_USB0_DEVGRP instance. */
4263#define ALT_USB0_DEV_DOEPTSIZ13_ADDR ALT_USB_DEV_DOEPTSIZ13_ADDR(ALT_USB0_DEVGRP_ADDR)
4264/* The address of the ALT_USB_DEV_DOEPDMA13 register for the ALT_USB0_DEVGRP instance. */
4265#define ALT_USB0_DEV_DOEPDMA13_ADDR ALT_USB_DEV_DOEPDMA13_ADDR(ALT_USB0_DEVGRP_ADDR)
4266/* The address of the ALT_USB_DEV_DOEPDMAB13 register for the ALT_USB0_DEVGRP instance. */
4267#define ALT_USB0_DEV_DOEPDMAB13_ADDR ALT_USB_DEV_DOEPDMAB13_ADDR(ALT_USB0_DEVGRP_ADDR)
4268/* The address of the ALT_USB_DEV_DOEPCTL14 register for the ALT_USB0_DEVGRP instance. */
4269#define ALT_USB0_DEV_DOEPCTL14_ADDR ALT_USB_DEV_DOEPCTL14_ADDR(ALT_USB0_DEVGRP_ADDR)
4270/* The address of the ALT_USB_DEV_DOEPINT14 register for the ALT_USB0_DEVGRP instance. */
4271#define ALT_USB0_DEV_DOEPINT14_ADDR ALT_USB_DEV_DOEPINT14_ADDR(ALT_USB0_DEVGRP_ADDR)
4272/* The address of the ALT_USB_DEV_DOEPTSIZ14 register for the ALT_USB0_DEVGRP instance. */
4273#define ALT_USB0_DEV_DOEPTSIZ14_ADDR ALT_USB_DEV_DOEPTSIZ14_ADDR(ALT_USB0_DEVGRP_ADDR)
4274/* The address of the ALT_USB_DEV_DOEPDMA14 register for the ALT_USB0_DEVGRP instance. */
4275#define ALT_USB0_DEV_DOEPDMA14_ADDR ALT_USB_DEV_DOEPDMA14_ADDR(ALT_USB0_DEVGRP_ADDR)
4276/* The address of the ALT_USB_DEV_DOEPDMAB14 register for the ALT_USB0_DEVGRP instance. */
4277#define ALT_USB0_DEV_DOEPDMAB14_ADDR ALT_USB_DEV_DOEPDMAB14_ADDR(ALT_USB0_DEVGRP_ADDR)
4278/* The address of the ALT_USB_DEV_DOEPCTL15 register for the ALT_USB0_DEVGRP instance. */
4279#define ALT_USB0_DEV_DOEPCTL15_ADDR ALT_USB_DEV_DOEPCTL15_ADDR(ALT_USB0_DEVGRP_ADDR)
4280/* The address of the ALT_USB_DEV_DOEPINT15 register for the ALT_USB0_DEVGRP instance. */
4281#define ALT_USB0_DEV_DOEPINT15_ADDR ALT_USB_DEV_DOEPINT15_ADDR(ALT_USB0_DEVGRP_ADDR)
4282/* The address of the ALT_USB_DEV_DOEPTSIZ15 register for the ALT_USB0_DEVGRP instance. */
4283#define ALT_USB0_DEV_DOEPTSIZ15_ADDR ALT_USB_DEV_DOEPTSIZ15_ADDR(ALT_USB0_DEVGRP_ADDR)
4284/* The address of the ALT_USB_DEV_DOEPDMA15 register for the ALT_USB0_DEVGRP instance. */
4285#define ALT_USB0_DEV_DOEPDMA15_ADDR ALT_USB_DEV_DOEPDMA15_ADDR(ALT_USB0_DEVGRP_ADDR)
4286/* The address of the ALT_USB_DEV_DOEPDMAB15 register for the ALT_USB0_DEVGRP instance. */
4287#define ALT_USB0_DEV_DOEPDMAB15_ADDR ALT_USB_DEV_DOEPDMAB15_ADDR(ALT_USB0_DEVGRP_ADDR)
4288/* The base address byte offset for the start of the ALT_USB0_DEVGRP component. */
4289#define ALT_USB0_DEVGRP_OFST 0x800
4290/* The start address of the ALT_USB0_DEVGRP component. */
4291#define ALT_USB0_DEVGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB0_ADDR) + ALT_USB0_DEVGRP_OFST))
4292/* The lower bound address range of the ALT_USB0_DEVGRP component. */
4293#define ALT_USB0_DEVGRP_LB_ADDR ALT_USB0_DEVGRP_ADDR
4294/* The upper bound address range of the ALT_USB0_DEVGRP component. */
4295#define ALT_USB0_DEVGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB0_DEVGRP_ADDR) + 0x500) - 1))
4296
4297
4298/*
4299 * Register Group Instance : pwrclkgrp
4300 *
4301 * Instance pwrclkgrp of register group ALT_USB_PWRCLK.
4302 *
4303 *
4304 */
4305/* The address of the ALT_USB_PWRCLK_PCGCCTL register for the ALT_USB0_PWRCLKGRP instance. */
4306#define ALT_USB0_PWRCLK_PCGCCTL_ADDR ALT_USB_PWRCLK_PCGCCTL_ADDR(ALT_USB0_PWRCLKGRP_ADDR)
4307/* The base address byte offset for the start of the ALT_USB0_PWRCLKGRP component. */
4308#define ALT_USB0_PWRCLKGRP_OFST 0xe00
4309/* The start address of the ALT_USB0_PWRCLKGRP component. */
4310#define ALT_USB0_PWRCLKGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB0_ADDR) + ALT_USB0_PWRCLKGRP_OFST))
4311/* The lower bound address range of the ALT_USB0_PWRCLKGRP component. */
4312#define ALT_USB0_PWRCLKGRP_LB_ADDR ALT_USB0_PWRCLKGRP_ADDR
4313/* The upper bound address range of the ALT_USB0_PWRCLKGRP component. */
4314#define ALT_USB0_PWRCLKGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB0_PWRCLKGRP_ADDR) + 0x4) - 1))
4315
4316
4317/* The base address byte offset for the start of the ALT_USB0 component. */
4318#define ALT_USB0_OFST 0xffb00000
4319/* The start address of the ALT_USB0 component. */
4320#define ALT_USB0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_USB0_OFST))
4321/* The lower bound address range of the ALT_USB0 component. */
4322#define ALT_USB0_LB_ADDR ALT_USB0_ADDR
4323/* The upper bound address range of the ALT_USB0 component. */
4324#define ALT_USB0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB0_ADDR) + 0x40000) - 1))
4325
4326
4327/*
4328 * Component Instance : usb1
4329 *
4330 * Instance usb1 of component ALT_USB.
4331 *
4332 *
4333 */
4334/*
4335 * Register Group Instance : globgrp
4336 *
4337 * Instance globgrp of register group ALT_USB_GLOB.
4338 *
4339 *
4340 */
4341/* The address of the ALT_USB_GLOB_GOTGCTL register for the ALT_USB1_GLOBGRP instance. */
4342#define ALT_USB1_GLOB_GOTGCTL_ADDR ALT_USB_GLOB_GOTGCTL_ADDR(ALT_USB1_GLOBGRP_ADDR)
4343/* The address of the ALT_USB_GLOB_GOTGINT register for the ALT_USB1_GLOBGRP instance. */
4344#define ALT_USB1_GLOB_GOTGINT_ADDR ALT_USB_GLOB_GOTGINT_ADDR(ALT_USB1_GLOBGRP_ADDR)
4345/* The address of the ALT_USB_GLOB_GAHBCFG register for the ALT_USB1_GLOBGRP instance. */
4346#define ALT_USB1_GLOB_GAHBCFG_ADDR ALT_USB_GLOB_GAHBCFG_ADDR(ALT_USB1_GLOBGRP_ADDR)
4347/* The address of the ALT_USB_GLOB_GUSBCFG register for the ALT_USB1_GLOBGRP instance. */
4348#define ALT_USB1_GLOB_GUSBCFG_ADDR ALT_USB_GLOB_GUSBCFG_ADDR(ALT_USB1_GLOBGRP_ADDR)
4349/* The address of the ALT_USB_GLOB_GRSTCTL register for the ALT_USB1_GLOBGRP instance. */
4350#define ALT_USB1_GLOB_GRSTCTL_ADDR ALT_USB_GLOB_GRSTCTL_ADDR(ALT_USB1_GLOBGRP_ADDR)
4351/* The address of the ALT_USB_GLOB_GINTSTS register for the ALT_USB1_GLOBGRP instance. */
4352#define ALT_USB1_GLOB_GINTSTS_ADDR ALT_USB_GLOB_GINTSTS_ADDR(ALT_USB1_GLOBGRP_ADDR)
4353/* The address of the ALT_USB_GLOB_GINTMSK register for the ALT_USB1_GLOBGRP instance. */
4354#define ALT_USB1_GLOB_GINTMSK_ADDR ALT_USB_GLOB_GINTMSK_ADDR(ALT_USB1_GLOBGRP_ADDR)
4355/* The address of the ALT_USB_GLOB_GRXSTSR register for the ALT_USB1_GLOBGRP instance. */
4356#define ALT_USB1_GLOB_GRXSTSR_ADDR ALT_USB_GLOB_GRXSTSR_ADDR(ALT_USB1_GLOBGRP_ADDR)
4357/* The address of the ALT_USB_GLOB_GRXSTSP register for the ALT_USB1_GLOBGRP instance. */
4358#define ALT_USB1_GLOB_GRXSTSP_ADDR ALT_USB_GLOB_GRXSTSP_ADDR(ALT_USB1_GLOBGRP_ADDR)
4359/* The address of the ALT_USB_GLOB_GRXFSIZ register for the ALT_USB1_GLOBGRP instance. */
4360#define ALT_USB1_GLOB_GRXFSIZ_ADDR ALT_USB_GLOB_GRXFSIZ_ADDR(ALT_USB1_GLOBGRP_ADDR)
4361/* The address of the ALT_USB_GLOB_GNPTXFSIZ register for the ALT_USB1_GLOBGRP instance. */
4362#define ALT_USB1_GLOB_GNPTXFSIZ_ADDR ALT_USB_GLOB_GNPTXFSIZ_ADDR(ALT_USB1_GLOBGRP_ADDR)
4363/* The address of the ALT_USB_GLOB_GNPTXSTS register for the ALT_USB1_GLOBGRP instance. */
4364#define ALT_USB1_GLOB_GNPTXSTS_ADDR ALT_USB_GLOB_GNPTXSTS_ADDR(ALT_USB1_GLOBGRP_ADDR)
4365/* The address of the ALT_USB_GLOB_GPVNDCTL register for the ALT_USB1_GLOBGRP instance. */
4366#define ALT_USB1_GLOB_GPVNDCTL_ADDR ALT_USB_GLOB_GPVNDCTL_ADDR(ALT_USB1_GLOBGRP_ADDR)
4367/* The address of the ALT_USB_GLOB_GGPIO register for the ALT_USB1_GLOBGRP instance. */
4368#define ALT_USB1_GLOB_GGPIO_ADDR ALT_USB_GLOB_GGPIO_ADDR(ALT_USB1_GLOBGRP_ADDR)
4369/* The address of the ALT_USB_GLOB_GUID register for the ALT_USB1_GLOBGRP instance. */
4370#define ALT_USB1_GLOB_GUID_ADDR ALT_USB_GLOB_GUID_ADDR(ALT_USB1_GLOBGRP_ADDR)
4371/* The address of the ALT_USB_GLOB_GSNPSID register for the ALT_USB1_GLOBGRP instance. */
4372#define ALT_USB1_GLOB_GSNPSID_ADDR ALT_USB_GLOB_GSNPSID_ADDR(ALT_USB1_GLOBGRP_ADDR)
4373/* The address of the ALT_USB_GLOB_GHWCFG1 register for the ALT_USB1_GLOBGRP instance. */
4374#define ALT_USB1_GLOB_GHWCFG1_ADDR ALT_USB_GLOB_GHWCFG1_ADDR(ALT_USB1_GLOBGRP_ADDR)
4375/* The address of the ALT_USB_GLOB_GHWCFG2 register for the ALT_USB1_GLOBGRP instance. */
4376#define ALT_USB1_GLOB_GHWCFG2_ADDR ALT_USB_GLOB_GHWCFG2_ADDR(ALT_USB1_GLOBGRP_ADDR)
4377/* The address of the ALT_USB_GLOB_GHWCFG3 register for the ALT_USB1_GLOBGRP instance. */
4378#define ALT_USB1_GLOB_GHWCFG3_ADDR ALT_USB_GLOB_GHWCFG3_ADDR(ALT_USB1_GLOBGRP_ADDR)
4379/* The address of the ALT_USB_GLOB_GHWCFG4 register for the ALT_USB1_GLOBGRP instance. */
4380#define ALT_USB1_GLOB_GHWCFG4_ADDR ALT_USB_GLOB_GHWCFG4_ADDR(ALT_USB1_GLOBGRP_ADDR)
4381/* The address of the ALT_USB_GLOB_GDFIFOCFG register for the ALT_USB1_GLOBGRP instance. */
4382#define ALT_USB1_GLOB_GDFIFOCFG_ADDR ALT_USB_GLOB_GDFIFOCFG_ADDR(ALT_USB1_GLOBGRP_ADDR)
4383/* The address of the ALT_USB_GLOB_HPTXFSIZ register for the ALT_USB1_GLOBGRP instance. */
4384#define ALT_USB1_GLOB_HPTXFSIZ_ADDR ALT_USB_GLOB_HPTXFSIZ_ADDR(ALT_USB1_GLOBGRP_ADDR)
4385/* The address of the ALT_USB_GLOB_DIEPTXF1 register for the ALT_USB1_GLOBGRP instance. */
4386#define ALT_USB1_GLOB_DIEPTXF1_ADDR ALT_USB_GLOB_DIEPTXF1_ADDR(ALT_USB1_GLOBGRP_ADDR)
4387/* The address of the ALT_USB_GLOB_DIEPTXF2 register for the ALT_USB1_GLOBGRP instance. */
4388#define ALT_USB1_GLOB_DIEPTXF2_ADDR ALT_USB_GLOB_DIEPTXF2_ADDR(ALT_USB1_GLOBGRP_ADDR)
4389/* The address of the ALT_USB_GLOB_DIEPTXF3 register for the ALT_USB1_GLOBGRP instance. */
4390#define ALT_USB1_GLOB_DIEPTXF3_ADDR ALT_USB_GLOB_DIEPTXF3_ADDR(ALT_USB1_GLOBGRP_ADDR)
4391/* The address of the ALT_USB_GLOB_DIEPTXF4 register for the ALT_USB1_GLOBGRP instance. */
4392#define ALT_USB1_GLOB_DIEPTXF4_ADDR ALT_USB_GLOB_DIEPTXF4_ADDR(ALT_USB1_GLOBGRP_ADDR)
4393/* The address of the ALT_USB_GLOB_DIEPTXF5 register for the ALT_USB1_GLOBGRP instance. */
4394#define ALT_USB1_GLOB_DIEPTXF5_ADDR ALT_USB_GLOB_DIEPTXF5_ADDR(ALT_USB1_GLOBGRP_ADDR)
4395/* The address of the ALT_USB_GLOB_DIEPTXF6 register for the ALT_USB1_GLOBGRP instance. */
4396#define ALT_USB1_GLOB_DIEPTXF6_ADDR ALT_USB_GLOB_DIEPTXF6_ADDR(ALT_USB1_GLOBGRP_ADDR)
4397/* The address of the ALT_USB_GLOB_DIEPTXF7 register for the ALT_USB1_GLOBGRP instance. */
4398#define ALT_USB1_GLOB_DIEPTXF7_ADDR ALT_USB_GLOB_DIEPTXF7_ADDR(ALT_USB1_GLOBGRP_ADDR)
4399/* The address of the ALT_USB_GLOB_DIEPTXF8 register for the ALT_USB1_GLOBGRP instance. */
4400#define ALT_USB1_GLOB_DIEPTXF8_ADDR ALT_USB_GLOB_DIEPTXF8_ADDR(ALT_USB1_GLOBGRP_ADDR)
4401/* The address of the ALT_USB_GLOB_DIEPTXF9 register for the ALT_USB1_GLOBGRP instance. */
4402#define ALT_USB1_GLOB_DIEPTXF9_ADDR ALT_USB_GLOB_DIEPTXF9_ADDR(ALT_USB1_GLOBGRP_ADDR)
4403/* The address of the ALT_USB_GLOB_DIEPTXF10 register for the ALT_USB1_GLOBGRP instance. */
4404#define ALT_USB1_GLOB_DIEPTXF10_ADDR ALT_USB_GLOB_DIEPTXF10_ADDR(ALT_USB1_GLOBGRP_ADDR)
4405/* The address of the ALT_USB_GLOB_DIEPTXF11 register for the ALT_USB1_GLOBGRP instance. */
4406#define ALT_USB1_GLOB_DIEPTXF11_ADDR ALT_USB_GLOB_DIEPTXF11_ADDR(ALT_USB1_GLOBGRP_ADDR)
4407/* The address of the ALT_USB_GLOB_DIEPTXF12 register for the ALT_USB1_GLOBGRP instance. */
4408#define ALT_USB1_GLOB_DIEPTXF12_ADDR ALT_USB_GLOB_DIEPTXF12_ADDR(ALT_USB1_GLOBGRP_ADDR)
4409/* The address of the ALT_USB_GLOB_DIEPTXF13 register for the ALT_USB1_GLOBGRP instance. */
4410#define ALT_USB1_GLOB_DIEPTXF13_ADDR ALT_USB_GLOB_DIEPTXF13_ADDR(ALT_USB1_GLOBGRP_ADDR)
4411/* The address of the ALT_USB_GLOB_DIEPTXF14 register for the ALT_USB1_GLOBGRP instance. */
4412#define ALT_USB1_GLOB_DIEPTXF14_ADDR ALT_USB_GLOB_DIEPTXF14_ADDR(ALT_USB1_GLOBGRP_ADDR)
4413/* The address of the ALT_USB_GLOB_DIEPTXF15 register for the ALT_USB1_GLOBGRP instance. */
4414#define ALT_USB1_GLOB_DIEPTXF15_ADDR ALT_USB_GLOB_DIEPTXF15_ADDR(ALT_USB1_GLOBGRP_ADDR)
4415/* The base address byte offset for the start of the ALT_USB1_GLOBGRP component. */
4416#define ALT_USB1_GLOBGRP_OFST 0x0
4417/* The start address of the ALT_USB1_GLOBGRP component. */
4418#define ALT_USB1_GLOBGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB1_ADDR) + ALT_USB1_GLOBGRP_OFST))
4419/* The lower bound address range of the ALT_USB1_GLOBGRP component. */
4420#define ALT_USB1_GLOBGRP_LB_ADDR ALT_USB1_GLOBGRP_ADDR
4421/* The upper bound address range of the ALT_USB1_GLOBGRP component. */
4422#define ALT_USB1_GLOBGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB1_GLOBGRP_ADDR) + 0x140) - 1))
4423
4424
4425/*
4426 * Register Group Instance : hostgrp
4427 *
4428 * Instance hostgrp of register group ALT_USB_HOST.
4429 *
4430 *
4431 */
4432/* The address of the ALT_USB_HOST_HCFG register for the ALT_USB1_HOSTGRP instance. */
4433#define ALT_USB1_HOST_HCFG_ADDR ALT_USB_HOST_HCFG_ADDR(ALT_USB1_HOSTGRP_ADDR)
4434/* The address of the ALT_USB_HOST_HFIR register for the ALT_USB1_HOSTGRP instance. */
4435#define ALT_USB1_HOST_HFIR_ADDR ALT_USB_HOST_HFIR_ADDR(ALT_USB1_HOSTGRP_ADDR)
4436/* The address of the ALT_USB_HOST_HFNUM register for the ALT_USB1_HOSTGRP instance. */
4437#define ALT_USB1_HOST_HFNUM_ADDR ALT_USB_HOST_HFNUM_ADDR(ALT_USB1_HOSTGRP_ADDR)
4438/* The address of the ALT_USB_HOST_HPTXSTS register for the ALT_USB1_HOSTGRP instance. */
4439#define ALT_USB1_HOST_HPTXSTS_ADDR ALT_USB_HOST_HPTXSTS_ADDR(ALT_USB1_HOSTGRP_ADDR)
4440/* The address of the ALT_USB_HOST_HAINT register for the ALT_USB1_HOSTGRP instance. */
4441#define ALT_USB1_HOST_HAINT_ADDR ALT_USB_HOST_HAINT_ADDR(ALT_USB1_HOSTGRP_ADDR)
4442/* The address of the ALT_USB_HOST_HAINTMSK register for the ALT_USB1_HOSTGRP instance. */
4443#define ALT_USB1_HOST_HAINTMSK_ADDR ALT_USB_HOST_HAINTMSK_ADDR(ALT_USB1_HOSTGRP_ADDR)
4444/* The address of the ALT_USB_HOST_HFLBADDR register for the ALT_USB1_HOSTGRP instance. */
4445#define ALT_USB1_HOST_HFLBADDR_ADDR ALT_USB_HOST_HFLBADDR_ADDR(ALT_USB1_HOSTGRP_ADDR)
4446/* The address of the ALT_USB_HOST_HPRT register for the ALT_USB1_HOSTGRP instance. */
4447#define ALT_USB1_HOST_HPRT_ADDR ALT_USB_HOST_HPRT_ADDR(ALT_USB1_HOSTGRP_ADDR)
4448/* The address of the ALT_USB_HOST_HCCHAR0 register for the ALT_USB1_HOSTGRP instance. */
4449#define ALT_USB1_HOST_HCCHAR0_ADDR ALT_USB_HOST_HCCHAR0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4450/* The address of the ALT_USB_HOST_HCSPLT0 register for the ALT_USB1_HOSTGRP instance. */
4451#define ALT_USB1_HOST_HCSPLT0_ADDR ALT_USB_HOST_HCSPLT0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4452/* The address of the ALT_USB_HOST_HCINT0 register for the ALT_USB1_HOSTGRP instance. */
4453#define ALT_USB1_HOST_HCINT0_ADDR ALT_USB_HOST_HCINT0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4454/* The address of the ALT_USB_HOST_HCINTMSK0 register for the ALT_USB1_HOSTGRP instance. */
4455#define ALT_USB1_HOST_HCINTMSK0_ADDR ALT_USB_HOST_HCINTMSK0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4456/* The address of the ALT_USB_HOST_HCTSIZ0 register for the ALT_USB1_HOSTGRP instance. */
4457#define ALT_USB1_HOST_HCTSIZ0_ADDR ALT_USB_HOST_HCTSIZ0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4458/* The address of the ALT_USB_HOST_HCDMA0 register for the ALT_USB1_HOSTGRP instance. */
4459#define ALT_USB1_HOST_HCDMA0_ADDR ALT_USB_HOST_HCDMA0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4460/* The address of the ALT_USB_HOST_HCDMAB0 register for the ALT_USB1_HOSTGRP instance. */
4461#define ALT_USB1_HOST_HCDMAB0_ADDR ALT_USB_HOST_HCDMAB0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4462/* The address of the ALT_USB_HOST_HCCHAR1 register for the ALT_USB1_HOSTGRP instance. */
4463#define ALT_USB1_HOST_HCCHAR1_ADDR ALT_USB_HOST_HCCHAR1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4464/* The address of the ALT_USB_HOST_HCSPLT1 register for the ALT_USB1_HOSTGRP instance. */
4465#define ALT_USB1_HOST_HCSPLT1_ADDR ALT_USB_HOST_HCSPLT1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4466/* The address of the ALT_USB_HOST_HCINT1 register for the ALT_USB1_HOSTGRP instance. */
4467#define ALT_USB1_HOST_HCINT1_ADDR ALT_USB_HOST_HCINT1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4468/* The address of the ALT_USB_HOST_HCINTMSK1 register for the ALT_USB1_HOSTGRP instance. */
4469#define ALT_USB1_HOST_HCINTMSK1_ADDR ALT_USB_HOST_HCINTMSK1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4470/* The address of the ALT_USB_HOST_HCTSIZ1 register for the ALT_USB1_HOSTGRP instance. */
4471#define ALT_USB1_HOST_HCTSIZ1_ADDR ALT_USB_HOST_HCTSIZ1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4472/* The address of the ALT_USB_HOST_HCDMA1 register for the ALT_USB1_HOSTGRP instance. */
4473#define ALT_USB1_HOST_HCDMA1_ADDR ALT_USB_HOST_HCDMA1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4474/* The address of the ALT_USB_HOST_HCDMAB1 register for the ALT_USB1_HOSTGRP instance. */
4475#define ALT_USB1_HOST_HCDMAB1_ADDR ALT_USB_HOST_HCDMAB1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4476/* The address of the ALT_USB_HOST_HCCHAR2 register for the ALT_USB1_HOSTGRP instance. */
4477#define ALT_USB1_HOST_HCCHAR2_ADDR ALT_USB_HOST_HCCHAR2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4478/* The address of the ALT_USB_HOST_HCSPLT2 register for the ALT_USB1_HOSTGRP instance. */
4479#define ALT_USB1_HOST_HCSPLT2_ADDR ALT_USB_HOST_HCSPLT2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4480/* The address of the ALT_USB_HOST_HCINT2 register for the ALT_USB1_HOSTGRP instance. */
4481#define ALT_USB1_HOST_HCINT2_ADDR ALT_USB_HOST_HCINT2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4482/* The address of the ALT_USB_HOST_HCINTMSK2 register for the ALT_USB1_HOSTGRP instance. */
4483#define ALT_USB1_HOST_HCINTMSK2_ADDR ALT_USB_HOST_HCINTMSK2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4484/* The address of the ALT_USB_HOST_HCTSIZ2 register for the ALT_USB1_HOSTGRP instance. */
4485#define ALT_USB1_HOST_HCTSIZ2_ADDR ALT_USB_HOST_HCTSIZ2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4486/* The address of the ALT_USB_HOST_HCDMA2 register for the ALT_USB1_HOSTGRP instance. */
4487#define ALT_USB1_HOST_HCDMA2_ADDR ALT_USB_HOST_HCDMA2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4488/* The address of the ALT_USB_HOST_HCDMAB2 register for the ALT_USB1_HOSTGRP instance. */
4489#define ALT_USB1_HOST_HCDMAB2_ADDR ALT_USB_HOST_HCDMAB2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4490/* The address of the ALT_USB_HOST_HCCHAR3 register for the ALT_USB1_HOSTGRP instance. */
4491#define ALT_USB1_HOST_HCCHAR3_ADDR ALT_USB_HOST_HCCHAR3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4492/* The address of the ALT_USB_HOST_HCSPLT3 register for the ALT_USB1_HOSTGRP instance. */
4493#define ALT_USB1_HOST_HCSPLT3_ADDR ALT_USB_HOST_HCSPLT3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4494/* The address of the ALT_USB_HOST_HCINT3 register for the ALT_USB1_HOSTGRP instance. */
4495#define ALT_USB1_HOST_HCINT3_ADDR ALT_USB_HOST_HCINT3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4496/* The address of the ALT_USB_HOST_HCINTMSK3 register for the ALT_USB1_HOSTGRP instance. */
4497#define ALT_USB1_HOST_HCINTMSK3_ADDR ALT_USB_HOST_HCINTMSK3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4498/* The address of the ALT_USB_HOST_HCTSIZ3 register for the ALT_USB1_HOSTGRP instance. */
4499#define ALT_USB1_HOST_HCTSIZ3_ADDR ALT_USB_HOST_HCTSIZ3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4500/* The address of the ALT_USB_HOST_HCDMA3 register for the ALT_USB1_HOSTGRP instance. */
4501#define ALT_USB1_HOST_HCDMA3_ADDR ALT_USB_HOST_HCDMA3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4502/* The address of the ALT_USB_HOST_HCDMAB3 register for the ALT_USB1_HOSTGRP instance. */
4503#define ALT_USB1_HOST_HCDMAB3_ADDR ALT_USB_HOST_HCDMAB3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4504/* The address of the ALT_USB_HOST_HCCHAR4 register for the ALT_USB1_HOSTGRP instance. */
4505#define ALT_USB1_HOST_HCCHAR4_ADDR ALT_USB_HOST_HCCHAR4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4506/* The address of the ALT_USB_HOST_HCSPLT4 register for the ALT_USB1_HOSTGRP instance. */
4507#define ALT_USB1_HOST_HCSPLT4_ADDR ALT_USB_HOST_HCSPLT4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4508/* The address of the ALT_USB_HOST_HCINT4 register for the ALT_USB1_HOSTGRP instance. */
4509#define ALT_USB1_HOST_HCINT4_ADDR ALT_USB_HOST_HCINT4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4510/* The address of the ALT_USB_HOST_HCINTMSK4 register for the ALT_USB1_HOSTGRP instance. */
4511#define ALT_USB1_HOST_HCINTMSK4_ADDR ALT_USB_HOST_HCINTMSK4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4512/* The address of the ALT_USB_HOST_HCTSIZ4 register for the ALT_USB1_HOSTGRP instance. */
4513#define ALT_USB1_HOST_HCTSIZ4_ADDR ALT_USB_HOST_HCTSIZ4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4514/* The address of the ALT_USB_HOST_HCDMA4 register for the ALT_USB1_HOSTGRP instance. */
4515#define ALT_USB1_HOST_HCDMA4_ADDR ALT_USB_HOST_HCDMA4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4516/* The address of the ALT_USB_HOST_HCDMAB4 register for the ALT_USB1_HOSTGRP instance. */
4517#define ALT_USB1_HOST_HCDMAB4_ADDR ALT_USB_HOST_HCDMAB4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4518/* The address of the ALT_USB_HOST_HCCHAR5 register for the ALT_USB1_HOSTGRP instance. */
4519#define ALT_USB1_HOST_HCCHAR5_ADDR ALT_USB_HOST_HCCHAR5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4520/* The address of the ALT_USB_HOST_HCSPLT5 register for the ALT_USB1_HOSTGRP instance. */
4521#define ALT_USB1_HOST_HCSPLT5_ADDR ALT_USB_HOST_HCSPLT5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4522/* The address of the ALT_USB_HOST_HCINT5 register for the ALT_USB1_HOSTGRP instance. */
4523#define ALT_USB1_HOST_HCINT5_ADDR ALT_USB_HOST_HCINT5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4524/* The address of the ALT_USB_HOST_HCINTMSK5 register for the ALT_USB1_HOSTGRP instance. */
4525#define ALT_USB1_HOST_HCINTMSK5_ADDR ALT_USB_HOST_HCINTMSK5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4526/* The address of the ALT_USB_HOST_HCTSIZ5 register for the ALT_USB1_HOSTGRP instance. */
4527#define ALT_USB1_HOST_HCTSIZ5_ADDR ALT_USB_HOST_HCTSIZ5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4528/* The address of the ALT_USB_HOST_HCDMA5 register for the ALT_USB1_HOSTGRP instance. */
4529#define ALT_USB1_HOST_HCDMA5_ADDR ALT_USB_HOST_HCDMA5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4530/* The address of the ALT_USB_HOST_HCDMAB5 register for the ALT_USB1_HOSTGRP instance. */
4531#define ALT_USB1_HOST_HCDMAB5_ADDR ALT_USB_HOST_HCDMAB5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4532/* The address of the ALT_USB_HOST_HCCHAR6 register for the ALT_USB1_HOSTGRP instance. */
4533#define ALT_USB1_HOST_HCCHAR6_ADDR ALT_USB_HOST_HCCHAR6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4534/* The address of the ALT_USB_HOST_HCSPLT6 register for the ALT_USB1_HOSTGRP instance. */
4535#define ALT_USB1_HOST_HCSPLT6_ADDR ALT_USB_HOST_HCSPLT6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4536/* The address of the ALT_USB_HOST_HCINT6 register for the ALT_USB1_HOSTGRP instance. */
4537#define ALT_USB1_HOST_HCINT6_ADDR ALT_USB_HOST_HCINT6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4538/* The address of the ALT_USB_HOST_HCINTMSK6 register for the ALT_USB1_HOSTGRP instance. */
4539#define ALT_USB1_HOST_HCINTMSK6_ADDR ALT_USB_HOST_HCINTMSK6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4540/* The address of the ALT_USB_HOST_HCTSIZ6 register for the ALT_USB1_HOSTGRP instance. */
4541#define ALT_USB1_HOST_HCTSIZ6_ADDR ALT_USB_HOST_HCTSIZ6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4542/* The address of the ALT_USB_HOST_HCDMA6 register for the ALT_USB1_HOSTGRP instance. */
4543#define ALT_USB1_HOST_HCDMA6_ADDR ALT_USB_HOST_HCDMA6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4544/* The address of the ALT_USB_HOST_HCDMAB6 register for the ALT_USB1_HOSTGRP instance. */
4545#define ALT_USB1_HOST_HCDMAB6_ADDR ALT_USB_HOST_HCDMAB6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4546/* The address of the ALT_USB_HOST_HCCHAR7 register for the ALT_USB1_HOSTGRP instance. */
4547#define ALT_USB1_HOST_HCCHAR7_ADDR ALT_USB_HOST_HCCHAR7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4548/* The address of the ALT_USB_HOST_HCSPLT7 register for the ALT_USB1_HOSTGRP instance. */
4549#define ALT_USB1_HOST_HCSPLT7_ADDR ALT_USB_HOST_HCSPLT7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4550/* The address of the ALT_USB_HOST_HCINT7 register for the ALT_USB1_HOSTGRP instance. */
4551#define ALT_USB1_HOST_HCINT7_ADDR ALT_USB_HOST_HCINT7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4552/* The address of the ALT_USB_HOST_HCINTMSK7 register for the ALT_USB1_HOSTGRP instance. */
4553#define ALT_USB1_HOST_HCINTMSK7_ADDR ALT_USB_HOST_HCINTMSK7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4554/* The address of the ALT_USB_HOST_HCTSIZ7 register for the ALT_USB1_HOSTGRP instance. */
4555#define ALT_USB1_HOST_HCTSIZ7_ADDR ALT_USB_HOST_HCTSIZ7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4556/* The address of the ALT_USB_HOST_HCDMA7 register for the ALT_USB1_HOSTGRP instance. */
4557#define ALT_USB1_HOST_HCDMA7_ADDR ALT_USB_HOST_HCDMA7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4558/* The address of the ALT_USB_HOST_HCDMAB7 register for the ALT_USB1_HOSTGRP instance. */
4559#define ALT_USB1_HOST_HCDMAB7_ADDR ALT_USB_HOST_HCDMAB7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4560/* The address of the ALT_USB_HOST_HCCHAR8 register for the ALT_USB1_HOSTGRP instance. */
4561#define ALT_USB1_HOST_HCCHAR8_ADDR ALT_USB_HOST_HCCHAR8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4562/* The address of the ALT_USB_HOST_HCSPLT8 register for the ALT_USB1_HOSTGRP instance. */
4563#define ALT_USB1_HOST_HCSPLT8_ADDR ALT_USB_HOST_HCSPLT8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4564/* The address of the ALT_USB_HOST_HCINT8 register for the ALT_USB1_HOSTGRP instance. */
4565#define ALT_USB1_HOST_HCINT8_ADDR ALT_USB_HOST_HCINT8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4566/* The address of the ALT_USB_HOST_HCINTMSK8 register for the ALT_USB1_HOSTGRP instance. */
4567#define ALT_USB1_HOST_HCINTMSK8_ADDR ALT_USB_HOST_HCINTMSK8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4568/* The address of the ALT_USB_HOST_HCTSIZ8 register for the ALT_USB1_HOSTGRP instance. */
4569#define ALT_USB1_HOST_HCTSIZ8_ADDR ALT_USB_HOST_HCTSIZ8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4570/* The address of the ALT_USB_HOST_HCDMA8 register for the ALT_USB1_HOSTGRP instance. */
4571#define ALT_USB1_HOST_HCDMA8_ADDR ALT_USB_HOST_HCDMA8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4572/* The address of the ALT_USB_HOST_HCDMAB8 register for the ALT_USB1_HOSTGRP instance. */
4573#define ALT_USB1_HOST_HCDMAB8_ADDR ALT_USB_HOST_HCDMAB8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4574/* The address of the ALT_USB_HOST_HCCHAR9 register for the ALT_USB1_HOSTGRP instance. */
4575#define ALT_USB1_HOST_HCCHAR9_ADDR ALT_USB_HOST_HCCHAR9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4576/* The address of the ALT_USB_HOST_HCSPLT9 register for the ALT_USB1_HOSTGRP instance. */
4577#define ALT_USB1_HOST_HCSPLT9_ADDR ALT_USB_HOST_HCSPLT9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4578/* The address of the ALT_USB_HOST_HCINT9 register for the ALT_USB1_HOSTGRP instance. */
4579#define ALT_USB1_HOST_HCINT9_ADDR ALT_USB_HOST_HCINT9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4580/* The address of the ALT_USB_HOST_HCINTMSK9 register for the ALT_USB1_HOSTGRP instance. */
4581#define ALT_USB1_HOST_HCINTMSK9_ADDR ALT_USB_HOST_HCINTMSK9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4582/* The address of the ALT_USB_HOST_HCTSIZ9 register for the ALT_USB1_HOSTGRP instance. */
4583#define ALT_USB1_HOST_HCTSIZ9_ADDR ALT_USB_HOST_HCTSIZ9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4584/* The address of the ALT_USB_HOST_HCDMA9 register for the ALT_USB1_HOSTGRP instance. */
4585#define ALT_USB1_HOST_HCDMA9_ADDR ALT_USB_HOST_HCDMA9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4586/* The address of the ALT_USB_HOST_HCDMAB9 register for the ALT_USB1_HOSTGRP instance. */
4587#define ALT_USB1_HOST_HCDMAB9_ADDR ALT_USB_HOST_HCDMAB9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4588/* The address of the ALT_USB_HOST_HCCHAR10 register for the ALT_USB1_HOSTGRP instance. */
4589#define ALT_USB1_HOST_HCCHAR10_ADDR ALT_USB_HOST_HCCHAR10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4590/* The address of the ALT_USB_HOST_HCSPLT10 register for the ALT_USB1_HOSTGRP instance. */
4591#define ALT_USB1_HOST_HCSPLT10_ADDR ALT_USB_HOST_HCSPLT10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4592/* The address of the ALT_USB_HOST_HCINT10 register for the ALT_USB1_HOSTGRP instance. */
4593#define ALT_USB1_HOST_HCINT10_ADDR ALT_USB_HOST_HCINT10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4594/* The address of the ALT_USB_HOST_HCINTMSK10 register for the ALT_USB1_HOSTGRP instance. */
4595#define ALT_USB1_HOST_HCINTMSK10_ADDR ALT_USB_HOST_HCINTMSK10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4596/* The address of the ALT_USB_HOST_HCTSIZ10 register for the ALT_USB1_HOSTGRP instance. */
4597#define ALT_USB1_HOST_HCTSIZ10_ADDR ALT_USB_HOST_HCTSIZ10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4598/* The address of the ALT_USB_HOST_HCDMA10 register for the ALT_USB1_HOSTGRP instance. */
4599#define ALT_USB1_HOST_HCDMA10_ADDR ALT_USB_HOST_HCDMA10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4600/* The address of the ALT_USB_HOST_HCDMAB10 register for the ALT_USB1_HOSTGRP instance. */
4601#define ALT_USB1_HOST_HCDMAB10_ADDR ALT_USB_HOST_HCDMAB10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4602/* The address of the ALT_USB_HOST_HCCHAR11 register for the ALT_USB1_HOSTGRP instance. */
4603#define ALT_USB1_HOST_HCCHAR11_ADDR ALT_USB_HOST_HCCHAR11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4604/* The address of the ALT_USB_HOST_HCSPLT11 register for the ALT_USB1_HOSTGRP instance. */
4605#define ALT_USB1_HOST_HCSPLT11_ADDR ALT_USB_HOST_HCSPLT11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4606/* The address of the ALT_USB_HOST_HCINT11 register for the ALT_USB1_HOSTGRP instance. */
4607#define ALT_USB1_HOST_HCINT11_ADDR ALT_USB_HOST_HCINT11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4608/* The address of the ALT_USB_HOST_HCINTMSK11 register for the ALT_USB1_HOSTGRP instance. */
4609#define ALT_USB1_HOST_HCINTMSK11_ADDR ALT_USB_HOST_HCINTMSK11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4610/* The address of the ALT_USB_HOST_HCTSIZ11 register for the ALT_USB1_HOSTGRP instance. */
4611#define ALT_USB1_HOST_HCTSIZ11_ADDR ALT_USB_HOST_HCTSIZ11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4612/* The address of the ALT_USB_HOST_HCDMA11 register for the ALT_USB1_HOSTGRP instance. */
4613#define ALT_USB1_HOST_HCDMA11_ADDR ALT_USB_HOST_HCDMA11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4614/* The address of the ALT_USB_HOST_HCDMAB11 register for the ALT_USB1_HOSTGRP instance. */
4615#define ALT_USB1_HOST_HCDMAB11_ADDR ALT_USB_HOST_HCDMAB11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4616/* The address of the ALT_USB_HOST_HCCHAR12 register for the ALT_USB1_HOSTGRP instance. */
4617#define ALT_USB1_HOST_HCCHAR12_ADDR ALT_USB_HOST_HCCHAR12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4618/* The address of the ALT_USB_HOST_HCSPLT12 register for the ALT_USB1_HOSTGRP instance. */
4619#define ALT_USB1_HOST_HCSPLT12_ADDR ALT_USB_HOST_HCSPLT12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4620/* The address of the ALT_USB_HOST_HCINT12 register for the ALT_USB1_HOSTGRP instance. */
4621#define ALT_USB1_HOST_HCINT12_ADDR ALT_USB_HOST_HCINT12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4622/* The address of the ALT_USB_HOST_HCINTMSK12 register for the ALT_USB1_HOSTGRP instance. */
4623#define ALT_USB1_HOST_HCINTMSK12_ADDR ALT_USB_HOST_HCINTMSK12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4624/* The address of the ALT_USB_HOST_HCTSIZ12 register for the ALT_USB1_HOSTGRP instance. */
4625#define ALT_USB1_HOST_HCTSIZ12_ADDR ALT_USB_HOST_HCTSIZ12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4626/* The address of the ALT_USB_HOST_HCDMA12 register for the ALT_USB1_HOSTGRP instance. */
4627#define ALT_USB1_HOST_HCDMA12_ADDR ALT_USB_HOST_HCDMA12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4628/* The address of the ALT_USB_HOST_HCDMAB12 register for the ALT_USB1_HOSTGRP instance. */
4629#define ALT_USB1_HOST_HCDMAB12_ADDR ALT_USB_HOST_HCDMAB12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4630/* The address of the ALT_USB_HOST_HCCHAR13 register for the ALT_USB1_HOSTGRP instance. */
4631#define ALT_USB1_HOST_HCCHAR13_ADDR ALT_USB_HOST_HCCHAR13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4632/* The address of the ALT_USB_HOST_HCSPLT13 register for the ALT_USB1_HOSTGRP instance. */
4633#define ALT_USB1_HOST_HCSPLT13_ADDR ALT_USB_HOST_HCSPLT13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4634/* The address of the ALT_USB_HOST_HCINT13 register for the ALT_USB1_HOSTGRP instance. */
4635#define ALT_USB1_HOST_HCINT13_ADDR ALT_USB_HOST_HCINT13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4636/* The address of the ALT_USB_HOST_HCINTMSK13 register for the ALT_USB1_HOSTGRP instance. */
4637#define ALT_USB1_HOST_HCINTMSK13_ADDR ALT_USB_HOST_HCINTMSK13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4638/* The address of the ALT_USB_HOST_HCTSIZ13 register for the ALT_USB1_HOSTGRP instance. */
4639#define ALT_USB1_HOST_HCTSIZ13_ADDR ALT_USB_HOST_HCTSIZ13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4640/* The address of the ALT_USB_HOST_HCDMA13 register for the ALT_USB1_HOSTGRP instance. */
4641#define ALT_USB1_HOST_HCDMA13_ADDR ALT_USB_HOST_HCDMA13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4642/* The address of the ALT_USB_HOST_HCDMAB13 register for the ALT_USB1_HOSTGRP instance. */
4643#define ALT_USB1_HOST_HCDMAB13_ADDR ALT_USB_HOST_HCDMAB13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4644/* The address of the ALT_USB_HOST_HCCHAR14 register for the ALT_USB1_HOSTGRP instance. */
4645#define ALT_USB1_HOST_HCCHAR14_ADDR ALT_USB_HOST_HCCHAR14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4646/* The address of the ALT_USB_HOST_HCSPLT14 register for the ALT_USB1_HOSTGRP instance. */
4647#define ALT_USB1_HOST_HCSPLT14_ADDR ALT_USB_HOST_HCSPLT14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4648/* The address of the ALT_USB_HOST_HCINT14 register for the ALT_USB1_HOSTGRP instance. */
4649#define ALT_USB1_HOST_HCINT14_ADDR ALT_USB_HOST_HCINT14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4650/* The address of the ALT_USB_HOST_HCINTMSK14 register for the ALT_USB1_HOSTGRP instance. */
4651#define ALT_USB1_HOST_HCINTMSK14_ADDR ALT_USB_HOST_HCINTMSK14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4652/* The address of the ALT_USB_HOST_HCTSIZ14 register for the ALT_USB1_HOSTGRP instance. */
4653#define ALT_USB1_HOST_HCTSIZ14_ADDR ALT_USB_HOST_HCTSIZ14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4654/* The address of the ALT_USB_HOST_HCDMA14 register for the ALT_USB1_HOSTGRP instance. */
4655#define ALT_USB1_HOST_HCDMA14_ADDR ALT_USB_HOST_HCDMA14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4656/* The address of the ALT_USB_HOST_HCDMAB14 register for the ALT_USB1_HOSTGRP instance. */
4657#define ALT_USB1_HOST_HCDMAB14_ADDR ALT_USB_HOST_HCDMAB14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4658/* The address of the ALT_USB_HOST_HCCHAR15 register for the ALT_USB1_HOSTGRP instance. */
4659#define ALT_USB1_HOST_HCCHAR15_ADDR ALT_USB_HOST_HCCHAR15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4660/* The address of the ALT_USB_HOST_HCSPLT15 register for the ALT_USB1_HOSTGRP instance. */
4661#define ALT_USB1_HOST_HCSPLT15_ADDR ALT_USB_HOST_HCSPLT15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4662/* The address of the ALT_USB_HOST_HCINT15 register for the ALT_USB1_HOSTGRP instance. */
4663#define ALT_USB1_HOST_HCINT15_ADDR ALT_USB_HOST_HCINT15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4664/* The address of the ALT_USB_HOST_HCINTMSK15 register for the ALT_USB1_HOSTGRP instance. */
4665#define ALT_USB1_HOST_HCINTMSK15_ADDR ALT_USB_HOST_HCINTMSK15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4666/* The address of the ALT_USB_HOST_HCTSIZ15 register for the ALT_USB1_HOSTGRP instance. */
4667#define ALT_USB1_HOST_HCTSIZ15_ADDR ALT_USB_HOST_HCTSIZ15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4668/* The address of the ALT_USB_HOST_HCDMA15 register for the ALT_USB1_HOSTGRP instance. */
4669#define ALT_USB1_HOST_HCDMA15_ADDR ALT_USB_HOST_HCDMA15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4670/* The address of the ALT_USB_HOST_HCDMAB15 register for the ALT_USB1_HOSTGRP instance. */
4671#define ALT_USB1_HOST_HCDMAB15_ADDR ALT_USB_HOST_HCDMAB15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4672/* The base address byte offset for the start of the ALT_USB1_HOSTGRP component. */
4673#define ALT_USB1_HOSTGRP_OFST 0x400
4674/* The start address of the ALT_USB1_HOSTGRP component. */
4675#define ALT_USB1_HOSTGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB1_ADDR) + ALT_USB1_HOSTGRP_OFST))
4676/* The lower bound address range of the ALT_USB1_HOSTGRP component. */
4677#define ALT_USB1_HOSTGRP_LB_ADDR ALT_USB1_HOSTGRP_ADDR
4678/* The upper bound address range of the ALT_USB1_HOSTGRP component. */
4679#define ALT_USB1_HOSTGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB1_HOSTGRP_ADDR) + 0x2fc) - 1))
4680
4681
4682/*
4683 * Register Group Instance : devgrp
4684 *
4685 * Instance devgrp of register group ALT_USB_DEV.
4686 *
4687 *
4688 */
4689/* The address of the ALT_USB_DEV_DCFG register for the ALT_USB1_DEVGRP instance. */
4690#define ALT_USB1_DEV_DCFG_ADDR ALT_USB_DEV_DCFG_ADDR(ALT_USB1_DEVGRP_ADDR)
4691/* The address of the ALT_USB_DEV_DCTL register for the ALT_USB1_DEVGRP instance. */
4692#define ALT_USB1_DEV_DCTL_ADDR ALT_USB_DEV_DCTL_ADDR(ALT_USB1_DEVGRP_ADDR)
4693/* The address of the ALT_USB_DEV_DSTS register for the ALT_USB1_DEVGRP instance. */
4694#define ALT_USB1_DEV_DSTS_ADDR ALT_USB_DEV_DSTS_ADDR(ALT_USB1_DEVGRP_ADDR)
4695/* The address of the ALT_USB_DEV_DIEPMSK register for the ALT_USB1_DEVGRP instance. */
4696#define ALT_USB1_DEV_DIEPMSK_ADDR ALT_USB_DEV_DIEPMSK_ADDR(ALT_USB1_DEVGRP_ADDR)
4697/* The address of the ALT_USB_DEV_DOEPMSK register for the ALT_USB1_DEVGRP instance. */
4698#define ALT_USB1_DEV_DOEPMSK_ADDR ALT_USB_DEV_DOEPMSK_ADDR(ALT_USB1_DEVGRP_ADDR)
4699/* The address of the ALT_USB_DEV_DAINT register for the ALT_USB1_DEVGRP instance. */
4700#define ALT_USB1_DEV_DAINT_ADDR ALT_USB_DEV_DAINT_ADDR(ALT_USB1_DEVGRP_ADDR)
4701/* The address of the ALT_USB_DEV_DAINTMSK register for the ALT_USB1_DEVGRP instance. */
4702#define ALT_USB1_DEV_DAINTMSK_ADDR ALT_USB_DEV_DAINTMSK_ADDR(ALT_USB1_DEVGRP_ADDR)
4703/* The address of the ALT_USB_DEV_DVBUSDIS register for the ALT_USB1_DEVGRP instance. */
4704#define ALT_USB1_DEV_DVBUSDIS_ADDR ALT_USB_DEV_DVBUSDIS_ADDR(ALT_USB1_DEVGRP_ADDR)
4705/* The address of the ALT_USB_DEV_DVBUSPULSE register for the ALT_USB1_DEVGRP instance. */
4706#define ALT_USB1_DEV_DVBUSPULSE_ADDR ALT_USB_DEV_DVBUSPULSE_ADDR(ALT_USB1_DEVGRP_ADDR)
4707/* The address of the ALT_USB_DEV_DTHRCTL register for the ALT_USB1_DEVGRP instance. */
4708#define ALT_USB1_DEV_DTHRCTL_ADDR ALT_USB_DEV_DTHRCTL_ADDR(ALT_USB1_DEVGRP_ADDR)
4709/* The address of the ALT_USB_DEV_DIEPEMPMSK register for the ALT_USB1_DEVGRP instance. */
4710#define ALT_USB1_DEV_DIEPEMPMSK_ADDR ALT_USB_DEV_DIEPEMPMSK_ADDR(ALT_USB1_DEVGRP_ADDR)
4711/* The address of the ALT_USB_DEV_DIEPCTL0 register for the ALT_USB1_DEVGRP instance. */
4712#define ALT_USB1_DEV_DIEPCTL0_ADDR ALT_USB_DEV_DIEPCTL0_ADDR(ALT_USB1_DEVGRP_ADDR)
4713/* The address of the ALT_USB_DEV_DIEPINT0 register for the ALT_USB1_DEVGRP instance. */
4714#define ALT_USB1_DEV_DIEPINT0_ADDR ALT_USB_DEV_DIEPINT0_ADDR(ALT_USB1_DEVGRP_ADDR)
4715/* The address of the ALT_USB_DEV_DIEPTSIZ0 register for the ALT_USB1_DEVGRP instance. */
4716#define ALT_USB1_DEV_DIEPTSIZ0_ADDR ALT_USB_DEV_DIEPTSIZ0_ADDR(ALT_USB1_DEVGRP_ADDR)
4717/* The address of the ALT_USB_DEV_DIEPDMA0 register for the ALT_USB1_DEVGRP instance. */
4718#define ALT_USB1_DEV_DIEPDMA0_ADDR ALT_USB_DEV_DIEPDMA0_ADDR(ALT_USB1_DEVGRP_ADDR)
4719/* The address of the ALT_USB_DEV_DTXFSTS0 register for the ALT_USB1_DEVGRP instance. */
4720#define ALT_USB1_DEV_DTXFSTS0_ADDR ALT_USB_DEV_DTXFSTS0_ADDR(ALT_USB1_DEVGRP_ADDR)
4721/* The address of the ALT_USB_DEV_DIEPDMAB0 register for the ALT_USB1_DEVGRP instance. */
4722#define ALT_USB1_DEV_DIEPDMAB0_ADDR ALT_USB_DEV_DIEPDMAB0_ADDR(ALT_USB1_DEVGRP_ADDR)
4723/* The address of the ALT_USB_DEV_DIEPCTL1 register for the ALT_USB1_DEVGRP instance. */
4724#define ALT_USB1_DEV_DIEPCTL1_ADDR ALT_USB_DEV_DIEPCTL1_ADDR(ALT_USB1_DEVGRP_ADDR)
4725/* The address of the ALT_USB_DEV_DIEPINT1 register for the ALT_USB1_DEVGRP instance. */
4726#define ALT_USB1_DEV_DIEPINT1_ADDR ALT_USB_DEV_DIEPINT1_ADDR(ALT_USB1_DEVGRP_ADDR)
4727/* The address of the ALT_USB_DEV_DIEPTSIZ1 register for the ALT_USB1_DEVGRP instance. */
4728#define ALT_USB1_DEV_DIEPTSIZ1_ADDR ALT_USB_DEV_DIEPTSIZ1_ADDR(ALT_USB1_DEVGRP_ADDR)
4729/* The address of the ALT_USB_DEV_DIEPDMA1 register for the ALT_USB1_DEVGRP instance. */
4730#define ALT_USB1_DEV_DIEPDMA1_ADDR ALT_USB_DEV_DIEPDMA1_ADDR(ALT_USB1_DEVGRP_ADDR)
4731/* The address of the ALT_USB_DEV_DTXFSTS1 register for the ALT_USB1_DEVGRP instance. */
4732#define ALT_USB1_DEV_DTXFSTS1_ADDR ALT_USB_DEV_DTXFSTS1_ADDR(ALT_USB1_DEVGRP_ADDR)
4733/* The address of the ALT_USB_DEV_DIEPDMAB1 register for the ALT_USB1_DEVGRP instance. */
4734#define ALT_USB1_DEV_DIEPDMAB1_ADDR ALT_USB_DEV_DIEPDMAB1_ADDR(ALT_USB1_DEVGRP_ADDR)
4735/* The address of the ALT_USB_DEV_DIEPCTL2 register for the ALT_USB1_DEVGRP instance. */
4736#define ALT_USB1_DEV_DIEPCTL2_ADDR ALT_USB_DEV_DIEPCTL2_ADDR(ALT_USB1_DEVGRP_ADDR)
4737/* The address of the ALT_USB_DEV_DIEPINT2 register for the ALT_USB1_DEVGRP instance. */
4738#define ALT_USB1_DEV_DIEPINT2_ADDR ALT_USB_DEV_DIEPINT2_ADDR(ALT_USB1_DEVGRP_ADDR)
4739/* The address of the ALT_USB_DEV_DIEPTSIZ2 register for the ALT_USB1_DEVGRP instance. */
4740#define ALT_USB1_DEV_DIEPTSIZ2_ADDR ALT_USB_DEV_DIEPTSIZ2_ADDR(ALT_USB1_DEVGRP_ADDR)
4741/* The address of the ALT_USB_DEV_DIEPDMA2 register for the ALT_USB1_DEVGRP instance. */
4742#define ALT_USB1_DEV_DIEPDMA2_ADDR ALT_USB_DEV_DIEPDMA2_ADDR(ALT_USB1_DEVGRP_ADDR)
4743/* The address of the ALT_USB_DEV_DTXFSTS2 register for the ALT_USB1_DEVGRP instance. */
4744#define ALT_USB1_DEV_DTXFSTS2_ADDR ALT_USB_DEV_DTXFSTS2_ADDR(ALT_USB1_DEVGRP_ADDR)
4745/* The address of the ALT_USB_DEV_DIEPDMAB2 register for the ALT_USB1_DEVGRP instance. */
4746#define ALT_USB1_DEV_DIEPDMAB2_ADDR ALT_USB_DEV_DIEPDMAB2_ADDR(ALT_USB1_DEVGRP_ADDR)
4747/* The address of the ALT_USB_DEV_DIEPCTL3 register for the ALT_USB1_DEVGRP instance. */
4748#define ALT_USB1_DEV_DIEPCTL3_ADDR ALT_USB_DEV_DIEPCTL3_ADDR(ALT_USB1_DEVGRP_ADDR)
4749/* The address of the ALT_USB_DEV_DIEPINT3 register for the ALT_USB1_DEVGRP instance. */
4750#define ALT_USB1_DEV_DIEPINT3_ADDR ALT_USB_DEV_DIEPINT3_ADDR(ALT_USB1_DEVGRP_ADDR)
4751/* The address of the ALT_USB_DEV_DIEPTSIZ3 register for the ALT_USB1_DEVGRP instance. */
4752#define ALT_USB1_DEV_DIEPTSIZ3_ADDR ALT_USB_DEV_DIEPTSIZ3_ADDR(ALT_USB1_DEVGRP_ADDR)
4753/* The address of the ALT_USB_DEV_DIEPDMA3 register for the ALT_USB1_DEVGRP instance. */
4754#define ALT_USB1_DEV_DIEPDMA3_ADDR ALT_USB_DEV_DIEPDMA3_ADDR(ALT_USB1_DEVGRP_ADDR)
4755/* The address of the ALT_USB_DEV_DTXFSTS3 register for the ALT_USB1_DEVGRP instance. */
4756#define ALT_USB1_DEV_DTXFSTS3_ADDR ALT_USB_DEV_DTXFSTS3_ADDR(ALT_USB1_DEVGRP_ADDR)
4757/* The address of the ALT_USB_DEV_DIEPDMAB3 register for the ALT_USB1_DEVGRP instance. */
4758#define ALT_USB1_DEV_DIEPDMAB3_ADDR ALT_USB_DEV_DIEPDMAB3_ADDR(ALT_USB1_DEVGRP_ADDR)
4759/* The address of the ALT_USB_DEV_DIEPCTL4 register for the ALT_USB1_DEVGRP instance. */
4760#define ALT_USB1_DEV_DIEPCTL4_ADDR ALT_USB_DEV_DIEPCTL4_ADDR(ALT_USB1_DEVGRP_ADDR)
4761/* The address of the ALT_USB_DEV_DIEPINT4 register for the ALT_USB1_DEVGRP instance. */
4762#define ALT_USB1_DEV_DIEPINT4_ADDR ALT_USB_DEV_DIEPINT4_ADDR(ALT_USB1_DEVGRP_ADDR)
4763/* The address of the ALT_USB_DEV_DIEPTSIZ4 register for the ALT_USB1_DEVGRP instance. */
4764#define ALT_USB1_DEV_DIEPTSIZ4_ADDR ALT_USB_DEV_DIEPTSIZ4_ADDR(ALT_USB1_DEVGRP_ADDR)
4765/* The address of the ALT_USB_DEV_DIEPDMA4 register for the ALT_USB1_DEVGRP instance. */
4766#define ALT_USB1_DEV_DIEPDMA4_ADDR ALT_USB_DEV_DIEPDMA4_ADDR(ALT_USB1_DEVGRP_ADDR)
4767/* The address of the ALT_USB_DEV_DTXFSTS4 register for the ALT_USB1_DEVGRP instance. */
4768#define ALT_USB1_DEV_DTXFSTS4_ADDR ALT_USB_DEV_DTXFSTS4_ADDR(ALT_USB1_DEVGRP_ADDR)
4769/* The address of the ALT_USB_DEV_DIEPDMAB4 register for the ALT_USB1_DEVGRP instance. */
4770#define ALT_USB1_DEV_DIEPDMAB4_ADDR ALT_USB_DEV_DIEPDMAB4_ADDR(ALT_USB1_DEVGRP_ADDR)
4771/* The address of the ALT_USB_DEV_DIEPCTL5 register for the ALT_USB1_DEVGRP instance. */
4772#define ALT_USB1_DEV_DIEPCTL5_ADDR ALT_USB_DEV_DIEPCTL5_ADDR(ALT_USB1_DEVGRP_ADDR)
4773/* The address of the ALT_USB_DEV_DIEPINT5 register for the ALT_USB1_DEVGRP instance. */
4774#define ALT_USB1_DEV_DIEPINT5_ADDR ALT_USB_DEV_DIEPINT5_ADDR(ALT_USB1_DEVGRP_ADDR)
4775/* The address of the ALT_USB_DEV_DIEPTSIZ5 register for the ALT_USB1_DEVGRP instance. */
4776#define ALT_USB1_DEV_DIEPTSIZ5_ADDR ALT_USB_DEV_DIEPTSIZ5_ADDR(ALT_USB1_DEVGRP_ADDR)
4777/* The address of the ALT_USB_DEV_DIEPDMA5 register for the ALT_USB1_DEVGRP instance. */
4778#define ALT_USB1_DEV_DIEPDMA5_ADDR ALT_USB_DEV_DIEPDMA5_ADDR(ALT_USB1_DEVGRP_ADDR)
4779/* The address of the ALT_USB_DEV_DTXFSTS5 register for the ALT_USB1_DEVGRP instance. */
4780#define ALT_USB1_DEV_DTXFSTS5_ADDR ALT_USB_DEV_DTXFSTS5_ADDR(ALT_USB1_DEVGRP_ADDR)
4781/* The address of the ALT_USB_DEV_DIEPDMAB5 register for the ALT_USB1_DEVGRP instance. */
4782#define ALT_USB1_DEV_DIEPDMAB5_ADDR ALT_USB_DEV_DIEPDMAB5_ADDR(ALT_USB1_DEVGRP_ADDR)
4783/* The address of the ALT_USB_DEV_DIEPCTL6 register for the ALT_USB1_DEVGRP instance. */
4784#define ALT_USB1_DEV_DIEPCTL6_ADDR ALT_USB_DEV_DIEPCTL6_ADDR(ALT_USB1_DEVGRP_ADDR)
4785/* The address of the ALT_USB_DEV_DIEPINT6 register for the ALT_USB1_DEVGRP instance. */
4786#define ALT_USB1_DEV_DIEPINT6_ADDR ALT_USB_DEV_DIEPINT6_ADDR(ALT_USB1_DEVGRP_ADDR)
4787/* The address of the ALT_USB_DEV_DIEPTSIZ6 register for the ALT_USB1_DEVGRP instance. */
4788#define ALT_USB1_DEV_DIEPTSIZ6_ADDR ALT_USB_DEV_DIEPTSIZ6_ADDR(ALT_USB1_DEVGRP_ADDR)
4789/* The address of the ALT_USB_DEV_DIEPDMA6 register for the ALT_USB1_DEVGRP instance. */
4790#define ALT_USB1_DEV_DIEPDMA6_ADDR ALT_USB_DEV_DIEPDMA6_ADDR(ALT_USB1_DEVGRP_ADDR)
4791/* The address of the ALT_USB_DEV_DTXFSTS6 register for the ALT_USB1_DEVGRP instance. */
4792#define ALT_USB1_DEV_DTXFSTS6_ADDR ALT_USB_DEV_DTXFSTS6_ADDR(ALT_USB1_DEVGRP_ADDR)
4793/* The address of the ALT_USB_DEV_DIEPDMAB6 register for the ALT_USB1_DEVGRP instance. */
4794#define ALT_USB1_DEV_DIEPDMAB6_ADDR ALT_USB_DEV_DIEPDMAB6_ADDR(ALT_USB1_DEVGRP_ADDR)
4795/* The address of the ALT_USB_DEV_DIEPCTL7 register for the ALT_USB1_DEVGRP instance. */
4796#define ALT_USB1_DEV_DIEPCTL7_ADDR ALT_USB_DEV_DIEPCTL7_ADDR(ALT_USB1_DEVGRP_ADDR)
4797/* The address of the ALT_USB_DEV_DIEPINT7 register for the ALT_USB1_DEVGRP instance. */
4798#define ALT_USB1_DEV_DIEPINT7_ADDR ALT_USB_DEV_DIEPINT7_ADDR(ALT_USB1_DEVGRP_ADDR)
4799/* The address of the ALT_USB_DEV_DIEPTSIZ7 register for the ALT_USB1_DEVGRP instance. */
4800#define ALT_USB1_DEV_DIEPTSIZ7_ADDR ALT_USB_DEV_DIEPTSIZ7_ADDR(ALT_USB1_DEVGRP_ADDR)
4801/* The address of the ALT_USB_DEV_DIEPDMA7 register for the ALT_USB1_DEVGRP instance. */
4802#define ALT_USB1_DEV_DIEPDMA7_ADDR ALT_USB_DEV_DIEPDMA7_ADDR(ALT_USB1_DEVGRP_ADDR)
4803/* The address of the ALT_USB_DEV_DTXFSTS7 register for the ALT_USB1_DEVGRP instance. */
4804#define ALT_USB1_DEV_DTXFSTS7_ADDR ALT_USB_DEV_DTXFSTS7_ADDR(ALT_USB1_DEVGRP_ADDR)
4805/* The address of the ALT_USB_DEV_DIEPDMAB7 register for the ALT_USB1_DEVGRP instance. */
4806#define ALT_USB1_DEV_DIEPDMAB7_ADDR ALT_USB_DEV_DIEPDMAB7_ADDR(ALT_USB1_DEVGRP_ADDR)
4807/* The address of the ALT_USB_DEV_DIEPCTL8 register for the ALT_USB1_DEVGRP instance. */
4808#define ALT_USB1_DEV_DIEPCTL8_ADDR ALT_USB_DEV_DIEPCTL8_ADDR(ALT_USB1_DEVGRP_ADDR)
4809/* The address of the ALT_USB_DEV_DIEPINT8 register for the ALT_USB1_DEVGRP instance. */
4810#define ALT_USB1_DEV_DIEPINT8_ADDR ALT_USB_DEV_DIEPINT8_ADDR(ALT_USB1_DEVGRP_ADDR)
4811/* The address of the ALT_USB_DEV_DIEPTSIZ8 register for the ALT_USB1_DEVGRP instance. */
4812#define ALT_USB1_DEV_DIEPTSIZ8_ADDR ALT_USB_DEV_DIEPTSIZ8_ADDR(ALT_USB1_DEVGRP_ADDR)
4813/* The address of the ALT_USB_DEV_DIEPDMA8 register for the ALT_USB1_DEVGRP instance. */
4814#define ALT_USB1_DEV_DIEPDMA8_ADDR ALT_USB_DEV_DIEPDMA8_ADDR(ALT_USB1_DEVGRP_ADDR)
4815/* The address of the ALT_USB_DEV_DTXFSTS8 register for the ALT_USB1_DEVGRP instance. */
4816#define ALT_USB1_DEV_DTXFSTS8_ADDR ALT_USB_DEV_DTXFSTS8_ADDR(ALT_USB1_DEVGRP_ADDR)
4817/* The address of the ALT_USB_DEV_DIEPDMAB8 register for the ALT_USB1_DEVGRP instance. */
4818#define ALT_USB1_DEV_DIEPDMAB8_ADDR ALT_USB_DEV_DIEPDMAB8_ADDR(ALT_USB1_DEVGRP_ADDR)
4819/* The address of the ALT_USB_DEV_DIEPCTL9 register for the ALT_USB1_DEVGRP instance. */
4820#define ALT_USB1_DEV_DIEPCTL9_ADDR ALT_USB_DEV_DIEPCTL9_ADDR(ALT_USB1_DEVGRP_ADDR)
4821/* The address of the ALT_USB_DEV_DIEPINT9 register for the ALT_USB1_DEVGRP instance. */
4822#define ALT_USB1_DEV_DIEPINT9_ADDR ALT_USB_DEV_DIEPINT9_ADDR(ALT_USB1_DEVGRP_ADDR)
4823/* The address of the ALT_USB_DEV_DIEPTSIZ9 register for the ALT_USB1_DEVGRP instance. */
4824#define ALT_USB1_DEV_DIEPTSIZ9_ADDR ALT_USB_DEV_DIEPTSIZ9_ADDR(ALT_USB1_DEVGRP_ADDR)
4825/* The address of the ALT_USB_DEV_DIEPDMA9 register for the ALT_USB1_DEVGRP instance. */
4826#define ALT_USB1_DEV_DIEPDMA9_ADDR ALT_USB_DEV_DIEPDMA9_ADDR(ALT_USB1_DEVGRP_ADDR)
4827/* The address of the ALT_USB_DEV_DTXFSTS9 register for the ALT_USB1_DEVGRP instance. */
4828#define ALT_USB1_DEV_DTXFSTS9_ADDR ALT_USB_DEV_DTXFSTS9_ADDR(ALT_USB1_DEVGRP_ADDR)
4829/* The address of the ALT_USB_DEV_DIEPDMAB9 register for the ALT_USB1_DEVGRP instance. */
4830#define ALT_USB1_DEV_DIEPDMAB9_ADDR ALT_USB_DEV_DIEPDMAB9_ADDR(ALT_USB1_DEVGRP_ADDR)
4831/* The address of the ALT_USB_DEV_DIEPCTL10 register for the ALT_USB1_DEVGRP instance. */
4832#define ALT_USB1_DEV_DIEPCTL10_ADDR ALT_USB_DEV_DIEPCTL10_ADDR(ALT_USB1_DEVGRP_ADDR)
4833/* The address of the ALT_USB_DEV_DIEPINT10 register for the ALT_USB1_DEVGRP instance. */
4834#define ALT_USB1_DEV_DIEPINT10_ADDR ALT_USB_DEV_DIEPINT10_ADDR(ALT_USB1_DEVGRP_ADDR)
4835/* The address of the ALT_USB_DEV_DIEPTSIZ10 register for the ALT_USB1_DEVGRP instance. */
4836#define ALT_USB1_DEV_DIEPTSIZ10_ADDR ALT_USB_DEV_DIEPTSIZ10_ADDR(ALT_USB1_DEVGRP_ADDR)
4837/* The address of the ALT_USB_DEV_DIEPDMA10 register for the ALT_USB1_DEVGRP instance. */
4838#define ALT_USB1_DEV_DIEPDMA10_ADDR ALT_USB_DEV_DIEPDMA10_ADDR(ALT_USB1_DEVGRP_ADDR)
4839/* The address of the ALT_USB_DEV_DTXFSTS10 register for the ALT_USB1_DEVGRP instance. */
4840#define ALT_USB1_DEV_DTXFSTS10_ADDR ALT_USB_DEV_DTXFSTS10_ADDR(ALT_USB1_DEVGRP_ADDR)
4841/* The address of the ALT_USB_DEV_DIEPDMAB10 register for the ALT_USB1_DEVGRP instance. */
4842#define ALT_USB1_DEV_DIEPDMAB10_ADDR ALT_USB_DEV_DIEPDMAB10_ADDR(ALT_USB1_DEVGRP_ADDR)
4843/* The address of the ALT_USB_DEV_DIEPCTL11 register for the ALT_USB1_DEVGRP instance. */
4844#define ALT_USB1_DEV_DIEPCTL11_ADDR ALT_USB_DEV_DIEPCTL11_ADDR(ALT_USB1_DEVGRP_ADDR)
4845/* The address of the ALT_USB_DEV_DIEPINT11 register for the ALT_USB1_DEVGRP instance. */
4846#define ALT_USB1_DEV_DIEPINT11_ADDR ALT_USB_DEV_DIEPINT11_ADDR(ALT_USB1_DEVGRP_ADDR)
4847/* The address of the ALT_USB_DEV_DIEPTSIZ11 register for the ALT_USB1_DEVGRP instance. */
4848#define ALT_USB1_DEV_DIEPTSIZ11_ADDR ALT_USB_DEV_DIEPTSIZ11_ADDR(ALT_USB1_DEVGRP_ADDR)
4849/* The address of the ALT_USB_DEV_DIEPDMA11 register for the ALT_USB1_DEVGRP instance. */
4850#define ALT_USB1_DEV_DIEPDMA11_ADDR ALT_USB_DEV_DIEPDMA11_ADDR(ALT_USB1_DEVGRP_ADDR)
4851/* The address of the ALT_USB_DEV_DTXFSTS11 register for the ALT_USB1_DEVGRP instance. */
4852#define ALT_USB1_DEV_DTXFSTS11_ADDR ALT_USB_DEV_DTXFSTS11_ADDR(ALT_USB1_DEVGRP_ADDR)
4853/* The address of the ALT_USB_DEV_DIEPDMAB11 register for the ALT_USB1_DEVGRP instance. */
4854#define ALT_USB1_DEV_DIEPDMAB11_ADDR ALT_USB_DEV_DIEPDMAB11_ADDR(ALT_USB1_DEVGRP_ADDR)
4855/* The address of the ALT_USB_DEV_DIEPCTL12 register for the ALT_USB1_DEVGRP instance. */
4856#define ALT_USB1_DEV_DIEPCTL12_ADDR ALT_USB_DEV_DIEPCTL12_ADDR(ALT_USB1_DEVGRP_ADDR)
4857/* The address of the ALT_USB_DEV_DIEPINT12 register for the ALT_USB1_DEVGRP instance. */
4858#define ALT_USB1_DEV_DIEPINT12_ADDR ALT_USB_DEV_DIEPINT12_ADDR(ALT_USB1_DEVGRP_ADDR)
4859/* The address of the ALT_USB_DEV_DIEPTSIZ12 register for the ALT_USB1_DEVGRP instance. */
4860#define ALT_USB1_DEV_DIEPTSIZ12_ADDR ALT_USB_DEV_DIEPTSIZ12_ADDR(ALT_USB1_DEVGRP_ADDR)
4861/* The address of the ALT_USB_DEV_DIEPDMA12 register for the ALT_USB1_DEVGRP instance. */
4862#define ALT_USB1_DEV_DIEPDMA12_ADDR ALT_USB_DEV_DIEPDMA12_ADDR(ALT_USB1_DEVGRP_ADDR)
4863/* The address of the ALT_USB_DEV_DTXFSTS12 register for the ALT_USB1_DEVGRP instance. */
4864#define ALT_USB1_DEV_DTXFSTS12_ADDR ALT_USB_DEV_DTXFSTS12_ADDR(ALT_USB1_DEVGRP_ADDR)
4865/* The address of the ALT_USB_DEV_DIEPDMAB12 register for the ALT_USB1_DEVGRP instance. */
4866#define ALT_USB1_DEV_DIEPDMAB12_ADDR ALT_USB_DEV_DIEPDMAB12_ADDR(ALT_USB1_DEVGRP_ADDR)
4867/* The address of the ALT_USB_DEV_DIEPCTL13 register for the ALT_USB1_DEVGRP instance. */
4868#define ALT_USB1_DEV_DIEPCTL13_ADDR ALT_USB_DEV_DIEPCTL13_ADDR(ALT_USB1_DEVGRP_ADDR)
4869/* The address of the ALT_USB_DEV_DIEPINT13 register for the ALT_USB1_DEVGRP instance. */
4870#define ALT_USB1_DEV_DIEPINT13_ADDR ALT_USB_DEV_DIEPINT13_ADDR(ALT_USB1_DEVGRP_ADDR)
4871/* The address of the ALT_USB_DEV_DIEPTSIZ13 register for the ALT_USB1_DEVGRP instance. */
4872#define ALT_USB1_DEV_DIEPTSIZ13_ADDR ALT_USB_DEV_DIEPTSIZ13_ADDR(ALT_USB1_DEVGRP_ADDR)
4873/* The address of the ALT_USB_DEV_DIEPDMA13 register for the ALT_USB1_DEVGRP instance. */
4874#define ALT_USB1_DEV_DIEPDMA13_ADDR ALT_USB_DEV_DIEPDMA13_ADDR(ALT_USB1_DEVGRP_ADDR)
4875/* The address of the ALT_USB_DEV_DTXFSTS13 register for the ALT_USB1_DEVGRP instance. */
4876#define ALT_USB1_DEV_DTXFSTS13_ADDR ALT_USB_DEV_DTXFSTS13_ADDR(ALT_USB1_DEVGRP_ADDR)
4877/* The address of the ALT_USB_DEV_DIEPDMAB13 register for the ALT_USB1_DEVGRP instance. */
4878#define ALT_USB1_DEV_DIEPDMAB13_ADDR ALT_USB_DEV_DIEPDMAB13_ADDR(ALT_USB1_DEVGRP_ADDR)
4879/* The address of the ALT_USB_DEV_DIEPCTL14 register for the ALT_USB1_DEVGRP instance. */
4880#define ALT_USB1_DEV_DIEPCTL14_ADDR ALT_USB_DEV_DIEPCTL14_ADDR(ALT_USB1_DEVGRP_ADDR)
4881/* The address of the ALT_USB_DEV_DIEPINT14 register for the ALT_USB1_DEVGRP instance. */
4882#define ALT_USB1_DEV_DIEPINT14_ADDR ALT_USB_DEV_DIEPINT14_ADDR(ALT_USB1_DEVGRP_ADDR)
4883/* The address of the ALT_USB_DEV_DIEPTSIZ14 register for the ALT_USB1_DEVGRP instance. */
4884#define ALT_USB1_DEV_DIEPTSIZ14_ADDR ALT_USB_DEV_DIEPTSIZ14_ADDR(ALT_USB1_DEVGRP_ADDR)
4885/* The address of the ALT_USB_DEV_DIEPDMA14 register for the ALT_USB1_DEVGRP instance. */
4886#define ALT_USB1_DEV_DIEPDMA14_ADDR ALT_USB_DEV_DIEPDMA14_ADDR(ALT_USB1_DEVGRP_ADDR)
4887/* The address of the ALT_USB_DEV_DTXFSTS14 register for the ALT_USB1_DEVGRP instance. */
4888#define ALT_USB1_DEV_DTXFSTS14_ADDR ALT_USB_DEV_DTXFSTS14_ADDR(ALT_USB1_DEVGRP_ADDR)
4889/* The address of the ALT_USB_DEV_DIEPDMAB14 register for the ALT_USB1_DEVGRP instance. */
4890#define ALT_USB1_DEV_DIEPDMAB14_ADDR ALT_USB_DEV_DIEPDMAB14_ADDR(ALT_USB1_DEVGRP_ADDR)
4891/* The address of the ALT_USB_DEV_DIEPCTL15 register for the ALT_USB1_DEVGRP instance. */
4892#define ALT_USB1_DEV_DIEPCTL15_ADDR ALT_USB_DEV_DIEPCTL15_ADDR(ALT_USB1_DEVGRP_ADDR)
4893/* The address of the ALT_USB_DEV_DIEPINT15 register for the ALT_USB1_DEVGRP instance. */
4894#define ALT_USB1_DEV_DIEPINT15_ADDR ALT_USB_DEV_DIEPINT15_ADDR(ALT_USB1_DEVGRP_ADDR)
4895/* The address of the ALT_USB_DEV_DIEPTSIZ15 register for the ALT_USB1_DEVGRP instance. */
4896#define ALT_USB1_DEV_DIEPTSIZ15_ADDR ALT_USB_DEV_DIEPTSIZ15_ADDR(ALT_USB1_DEVGRP_ADDR)
4897/* The address of the ALT_USB_DEV_DIEPDMA15 register for the ALT_USB1_DEVGRP instance. */
4898#define ALT_USB1_DEV_DIEPDMA15_ADDR ALT_USB_DEV_DIEPDMA15_ADDR(ALT_USB1_DEVGRP_ADDR)
4899/* The address of the ALT_USB_DEV_DTXFSTS15 register for the ALT_USB1_DEVGRP instance. */
4900#define ALT_USB1_DEV_DTXFSTS15_ADDR ALT_USB_DEV_DTXFSTS15_ADDR(ALT_USB1_DEVGRP_ADDR)
4901/* The address of the ALT_USB_DEV_DIEPDMAB15 register for the ALT_USB1_DEVGRP instance. */
4902#define ALT_USB1_DEV_DIEPDMAB15_ADDR ALT_USB_DEV_DIEPDMAB15_ADDR(ALT_USB1_DEVGRP_ADDR)
4903/* The address of the ALT_USB_DEV_DOEPCTL0 register for the ALT_USB1_DEVGRP instance. */
4904#define ALT_USB1_DEV_DOEPCTL0_ADDR ALT_USB_DEV_DOEPCTL0_ADDR(ALT_USB1_DEVGRP_ADDR)
4905/* The address of the ALT_USB_DEV_DOEPINT0 register for the ALT_USB1_DEVGRP instance. */
4906#define ALT_USB1_DEV_DOEPINT0_ADDR ALT_USB_DEV_DOEPINT0_ADDR(ALT_USB1_DEVGRP_ADDR)
4907/* The address of the ALT_USB_DEV_DOEPTSIZ0 register for the ALT_USB1_DEVGRP instance. */
4908#define ALT_USB1_DEV_DOEPTSIZ0_ADDR ALT_USB_DEV_DOEPTSIZ0_ADDR(ALT_USB1_DEVGRP_ADDR)
4909/* The address of the ALT_USB_DEV_DOEPDMA0 register for the ALT_USB1_DEVGRP instance. */
4910#define ALT_USB1_DEV_DOEPDMA0_ADDR ALT_USB_DEV_DOEPDMA0_ADDR(ALT_USB1_DEVGRP_ADDR)
4911/* The address of the ALT_USB_DEV_DOEPDMAB0 register for the ALT_USB1_DEVGRP instance. */
4912#define ALT_USB1_DEV_DOEPDMAB0_ADDR ALT_USB_DEV_DOEPDMAB0_ADDR(ALT_USB1_DEVGRP_ADDR)
4913/* The address of the ALT_USB_DEV_DOEPCTL1 register for the ALT_USB1_DEVGRP instance. */
4914#define ALT_USB1_DEV_DOEPCTL1_ADDR ALT_USB_DEV_DOEPCTL1_ADDR(ALT_USB1_DEVGRP_ADDR)
4915/* The address of the ALT_USB_DEV_DOEPINT1 register for the ALT_USB1_DEVGRP instance. */
4916#define ALT_USB1_DEV_DOEPINT1_ADDR ALT_USB_DEV_DOEPINT1_ADDR(ALT_USB1_DEVGRP_ADDR)
4917/* The address of the ALT_USB_DEV_DOEPTSIZ1 register for the ALT_USB1_DEVGRP instance. */
4918#define ALT_USB1_DEV_DOEPTSIZ1_ADDR ALT_USB_DEV_DOEPTSIZ1_ADDR(ALT_USB1_DEVGRP_ADDR)
4919/* The address of the ALT_USB_DEV_DOEPDMA1 register for the ALT_USB1_DEVGRP instance. */
4920#define ALT_USB1_DEV_DOEPDMA1_ADDR ALT_USB_DEV_DOEPDMA1_ADDR(ALT_USB1_DEVGRP_ADDR)
4921/* The address of the ALT_USB_DEV_DOEPDMAB1 register for the ALT_USB1_DEVGRP instance. */
4922#define ALT_USB1_DEV_DOEPDMAB1_ADDR ALT_USB_DEV_DOEPDMAB1_ADDR(ALT_USB1_DEVGRP_ADDR)
4923/* The address of the ALT_USB_DEV_DOEPCTL2 register for the ALT_USB1_DEVGRP instance. */
4924#define ALT_USB1_DEV_DOEPCTL2_ADDR ALT_USB_DEV_DOEPCTL2_ADDR(ALT_USB1_DEVGRP_ADDR)
4925/* The address of the ALT_USB_DEV_DOEPINT2 register for the ALT_USB1_DEVGRP instance. */
4926#define ALT_USB1_DEV_DOEPINT2_ADDR ALT_USB_DEV_DOEPINT2_ADDR(ALT_USB1_DEVGRP_ADDR)
4927/* The address of the ALT_USB_DEV_DOEPTSIZ2 register for the ALT_USB1_DEVGRP instance. */
4928#define ALT_USB1_DEV_DOEPTSIZ2_ADDR ALT_USB_DEV_DOEPTSIZ2_ADDR(ALT_USB1_DEVGRP_ADDR)
4929/* The address of the ALT_USB_DEV_DOEPDMA2 register for the ALT_USB1_DEVGRP instance. */
4930#define ALT_USB1_DEV_DOEPDMA2_ADDR ALT_USB_DEV_DOEPDMA2_ADDR(ALT_USB1_DEVGRP_ADDR)
4931/* The address of the ALT_USB_DEV_DOEPDMAB2 register for the ALT_USB1_DEVGRP instance. */
4932#define ALT_USB1_DEV_DOEPDMAB2_ADDR ALT_USB_DEV_DOEPDMAB2_ADDR(ALT_USB1_DEVGRP_ADDR)
4933/* The address of the ALT_USB_DEV_DOEPCTL3 register for the ALT_USB1_DEVGRP instance. */
4934#define ALT_USB1_DEV_DOEPCTL3_ADDR ALT_USB_DEV_DOEPCTL3_ADDR(ALT_USB1_DEVGRP_ADDR)
4935/* The address of the ALT_USB_DEV_DOEPINT3 register for the ALT_USB1_DEVGRP instance. */
4936#define ALT_USB1_DEV_DOEPINT3_ADDR ALT_USB_DEV_DOEPINT3_ADDR(ALT_USB1_DEVGRP_ADDR)
4937/* The address of the ALT_USB_DEV_DOEPTSIZ3 register for the ALT_USB1_DEVGRP instance. */
4938#define ALT_USB1_DEV_DOEPTSIZ3_ADDR ALT_USB_DEV_DOEPTSIZ3_ADDR(ALT_USB1_DEVGRP_ADDR)
4939/* The address of the ALT_USB_DEV_DOEPDMA3 register for the ALT_USB1_DEVGRP instance. */
4940#define ALT_USB1_DEV_DOEPDMA3_ADDR ALT_USB_DEV_DOEPDMA3_ADDR(ALT_USB1_DEVGRP_ADDR)
4941/* The address of the ALT_USB_DEV_DOEPDMAB3 register for the ALT_USB1_DEVGRP instance. */
4942#define ALT_USB1_DEV_DOEPDMAB3_ADDR ALT_USB_DEV_DOEPDMAB3_ADDR(ALT_USB1_DEVGRP_ADDR)
4943/* The address of the ALT_USB_DEV_DOEPCTL4 register for the ALT_USB1_DEVGRP instance. */
4944#define ALT_USB1_DEV_DOEPCTL4_ADDR ALT_USB_DEV_DOEPCTL4_ADDR(ALT_USB1_DEVGRP_ADDR)
4945/* The address of the ALT_USB_DEV_DOEPINT4 register for the ALT_USB1_DEVGRP instance. */
4946#define ALT_USB1_DEV_DOEPINT4_ADDR ALT_USB_DEV_DOEPINT4_ADDR(ALT_USB1_DEVGRP_ADDR)
4947/* The address of the ALT_USB_DEV_DOEPTSIZ4 register for the ALT_USB1_DEVGRP instance. */
4948#define ALT_USB1_DEV_DOEPTSIZ4_ADDR ALT_USB_DEV_DOEPTSIZ4_ADDR(ALT_USB1_DEVGRP_ADDR)
4949/* The address of the ALT_USB_DEV_DOEPDMA4 register for the ALT_USB1_DEVGRP instance. */
4950#define ALT_USB1_DEV_DOEPDMA4_ADDR ALT_USB_DEV_DOEPDMA4_ADDR(ALT_USB1_DEVGRP_ADDR)
4951/* The address of the ALT_USB_DEV_DOEPDMAB4 register for the ALT_USB1_DEVGRP instance. */
4952#define ALT_USB1_DEV_DOEPDMAB4_ADDR ALT_USB_DEV_DOEPDMAB4_ADDR(ALT_USB1_DEVGRP_ADDR)
4953/* The address of the ALT_USB_DEV_DOEPCTL5 register for the ALT_USB1_DEVGRP instance. */
4954#define ALT_USB1_DEV_DOEPCTL5_ADDR ALT_USB_DEV_DOEPCTL5_ADDR(ALT_USB1_DEVGRP_ADDR)
4955/* The address of the ALT_USB_DEV_DOEPINT5 register for the ALT_USB1_DEVGRP instance. */
4956#define ALT_USB1_DEV_DOEPINT5_ADDR ALT_USB_DEV_DOEPINT5_ADDR(ALT_USB1_DEVGRP_ADDR)
4957/* The address of the ALT_USB_DEV_DOEPTSIZ5 register for the ALT_USB1_DEVGRP instance. */
4958#define ALT_USB1_DEV_DOEPTSIZ5_ADDR ALT_USB_DEV_DOEPTSIZ5_ADDR(ALT_USB1_DEVGRP_ADDR)
4959/* The address of the ALT_USB_DEV_DOEPDMA5 register for the ALT_USB1_DEVGRP instance. */
4960#define ALT_USB1_DEV_DOEPDMA5_ADDR ALT_USB_DEV_DOEPDMA5_ADDR(ALT_USB1_DEVGRP_ADDR)
4961/* The address of the ALT_USB_DEV_DOEPDMAB5 register for the ALT_USB1_DEVGRP instance. */
4962#define ALT_USB1_DEV_DOEPDMAB5_ADDR ALT_USB_DEV_DOEPDMAB5_ADDR(ALT_USB1_DEVGRP_ADDR)
4963/* The address of the ALT_USB_DEV_DOEPCTL6 register for the ALT_USB1_DEVGRP instance. */
4964#define ALT_USB1_DEV_DOEPCTL6_ADDR ALT_USB_DEV_DOEPCTL6_ADDR(ALT_USB1_DEVGRP_ADDR)
4965/* The address of the ALT_USB_DEV_DOEPINT6 register for the ALT_USB1_DEVGRP instance. */
4966#define ALT_USB1_DEV_DOEPINT6_ADDR ALT_USB_DEV_DOEPINT6_ADDR(ALT_USB1_DEVGRP_ADDR)
4967/* The address of the ALT_USB_DEV_DOEPTSIZ6 register for the ALT_USB1_DEVGRP instance. */
4968#define ALT_USB1_DEV_DOEPTSIZ6_ADDR ALT_USB_DEV_DOEPTSIZ6_ADDR(ALT_USB1_DEVGRP_ADDR)
4969/* The address of the ALT_USB_DEV_DOEPDMA6 register for the ALT_USB1_DEVGRP instance. */
4970#define ALT_USB1_DEV_DOEPDMA6_ADDR ALT_USB_DEV_DOEPDMA6_ADDR(ALT_USB1_DEVGRP_ADDR)
4971/* The address of the ALT_USB_DEV_DOEPDMAB6 register for the ALT_USB1_DEVGRP instance. */
4972#define ALT_USB1_DEV_DOEPDMAB6_ADDR ALT_USB_DEV_DOEPDMAB6_ADDR(ALT_USB1_DEVGRP_ADDR)
4973/* The address of the ALT_USB_DEV_DOEPCTL7 register for the ALT_USB1_DEVGRP instance. */
4974#define ALT_USB1_DEV_DOEPCTL7_ADDR ALT_USB_DEV_DOEPCTL7_ADDR(ALT_USB1_DEVGRP_ADDR)
4975/* The address of the ALT_USB_DEV_DOEPINT7 register for the ALT_USB1_DEVGRP instance. */
4976#define ALT_USB1_DEV_DOEPINT7_ADDR ALT_USB_DEV_DOEPINT7_ADDR(ALT_USB1_DEVGRP_ADDR)
4977/* The address of the ALT_USB_DEV_DOEPTSIZ7 register for the ALT_USB1_DEVGRP instance. */
4978#define ALT_USB1_DEV_DOEPTSIZ7_ADDR ALT_USB_DEV_DOEPTSIZ7_ADDR(ALT_USB1_DEVGRP_ADDR)
4979/* The address of the ALT_USB_DEV_DOEPDMA7 register for the ALT_USB1_DEVGRP instance. */
4980#define ALT_USB1_DEV_DOEPDMA7_ADDR ALT_USB_DEV_DOEPDMA7_ADDR(ALT_USB1_DEVGRP_ADDR)
4981/* The address of the ALT_USB_DEV_DOEPDMAB7 register for the ALT_USB1_DEVGRP instance. */
4982#define ALT_USB1_DEV_DOEPDMAB7_ADDR ALT_USB_DEV_DOEPDMAB7_ADDR(ALT_USB1_DEVGRP_ADDR)
4983/* The address of the ALT_USB_DEV_DOEPCTL8 register for the ALT_USB1_DEVGRP instance. */
4984#define ALT_USB1_DEV_DOEPCTL8_ADDR ALT_USB_DEV_DOEPCTL8_ADDR(ALT_USB1_DEVGRP_ADDR)
4985/* The address of the ALT_USB_DEV_DOEPINT8 register for the ALT_USB1_DEVGRP instance. */
4986#define ALT_USB1_DEV_DOEPINT8_ADDR ALT_USB_DEV_DOEPINT8_ADDR(ALT_USB1_DEVGRP_ADDR)
4987/* The address of the ALT_USB_DEV_DOEPTSIZ8 register for the ALT_USB1_DEVGRP instance. */
4988#define ALT_USB1_DEV_DOEPTSIZ8_ADDR ALT_USB_DEV_DOEPTSIZ8_ADDR(ALT_USB1_DEVGRP_ADDR)
4989/* The address of the ALT_USB_DEV_DOEPDMA8 register for the ALT_USB1_DEVGRP instance. */
4990#define ALT_USB1_DEV_DOEPDMA8_ADDR ALT_USB_DEV_DOEPDMA8_ADDR(ALT_USB1_DEVGRP_ADDR)
4991/* The address of the ALT_USB_DEV_DOEPDMAB8 register for the ALT_USB1_DEVGRP instance. */
4992#define ALT_USB1_DEV_DOEPDMAB8_ADDR ALT_USB_DEV_DOEPDMAB8_ADDR(ALT_USB1_DEVGRP_ADDR)
4993/* The address of the ALT_USB_DEV_DOEPCTL9 register for the ALT_USB1_DEVGRP instance. */
4994#define ALT_USB1_DEV_DOEPCTL9_ADDR ALT_USB_DEV_DOEPCTL9_ADDR(ALT_USB1_DEVGRP_ADDR)
4995/* The address of the ALT_USB_DEV_DOEPINT9 register for the ALT_USB1_DEVGRP instance. */
4996#define ALT_USB1_DEV_DOEPINT9_ADDR ALT_USB_DEV_DOEPINT9_ADDR(ALT_USB1_DEVGRP_ADDR)
4997/* The address of the ALT_USB_DEV_DOEPTSIZ9 register for the ALT_USB1_DEVGRP instance. */
4998#define ALT_USB1_DEV_DOEPTSIZ9_ADDR ALT_USB_DEV_DOEPTSIZ9_ADDR(ALT_USB1_DEVGRP_ADDR)
4999/* The address of the ALT_USB_DEV_DOEPDMA9 register for the ALT_USB1_DEVGRP instance. */
5000#define ALT_USB1_DEV_DOEPDMA9_ADDR ALT_USB_DEV_DOEPDMA9_ADDR(ALT_USB1_DEVGRP_ADDR)
5001/* The address of the ALT_USB_DEV_DOEPDMAB9 register for the ALT_USB1_DEVGRP instance. */
5002#define ALT_USB1_DEV_DOEPDMAB9_ADDR ALT_USB_DEV_DOEPDMAB9_ADDR(ALT_USB1_DEVGRP_ADDR)
5003/* The address of the ALT_USB_DEV_DOEPCTL10 register for the ALT_USB1_DEVGRP instance. */
5004#define ALT_USB1_DEV_DOEPCTL10_ADDR ALT_USB_DEV_DOEPCTL10_ADDR(ALT_USB1_DEVGRP_ADDR)
5005/* The address of the ALT_USB_DEV_DOEPINT10 register for the ALT_USB1_DEVGRP instance. */
5006#define ALT_USB1_DEV_DOEPINT10_ADDR ALT_USB_DEV_DOEPINT10_ADDR(ALT_USB1_DEVGRP_ADDR)
5007/* The address of the ALT_USB_DEV_DOEPTSIZ10 register for the ALT_USB1_DEVGRP instance. */
5008#define ALT_USB1_DEV_DOEPTSIZ10_ADDR ALT_USB_DEV_DOEPTSIZ10_ADDR(ALT_USB1_DEVGRP_ADDR)
5009/* The address of the ALT_USB_DEV_DOEPDMA10 register for the ALT_USB1_DEVGRP instance. */
5010#define ALT_USB1_DEV_DOEPDMA10_ADDR ALT_USB_DEV_DOEPDMA10_ADDR(ALT_USB1_DEVGRP_ADDR)
5011/* The address of the ALT_USB_DEV_DOEPDMAB10 register for the ALT_USB1_DEVGRP instance. */
5012#define ALT_USB1_DEV_DOEPDMAB10_ADDR ALT_USB_DEV_DOEPDMAB10_ADDR(ALT_USB1_DEVGRP_ADDR)
5013/* The address of the ALT_USB_DEV_DOEPCTL11 register for the ALT_USB1_DEVGRP instance. */
5014#define ALT_USB1_DEV_DOEPCTL11_ADDR ALT_USB_DEV_DOEPCTL11_ADDR(ALT_USB1_DEVGRP_ADDR)
5015/* The address of the ALT_USB_DEV_DOEPINT11 register for the ALT_USB1_DEVGRP instance. */
5016#define ALT_USB1_DEV_DOEPINT11_ADDR ALT_USB_DEV_DOEPINT11_ADDR(ALT_USB1_DEVGRP_ADDR)
5017/* The address of the ALT_USB_DEV_DOEPTSIZ11 register for the ALT_USB1_DEVGRP instance. */
5018#define ALT_USB1_DEV_DOEPTSIZ11_ADDR ALT_USB_DEV_DOEPTSIZ11_ADDR(ALT_USB1_DEVGRP_ADDR)
5019/* The address of the ALT_USB_DEV_DOEPDMA11 register for the ALT_USB1_DEVGRP instance. */
5020#define ALT_USB1_DEV_DOEPDMA11_ADDR ALT_USB_DEV_DOEPDMA11_ADDR(ALT_USB1_DEVGRP_ADDR)
5021/* The address of the ALT_USB_DEV_DOEPDMAB11 register for the ALT_USB1_DEVGRP instance. */
5022#define ALT_USB1_DEV_DOEPDMAB11_ADDR ALT_USB_DEV_DOEPDMAB11_ADDR(ALT_USB1_DEVGRP_ADDR)
5023/* The address of the ALT_USB_DEV_DOEPCTL12 register for the ALT_USB1_DEVGRP instance. */
5024#define ALT_USB1_DEV_DOEPCTL12_ADDR ALT_USB_DEV_DOEPCTL12_ADDR(ALT_USB1_DEVGRP_ADDR)
5025/* The address of the ALT_USB_DEV_DOEPINT12 register for the ALT_USB1_DEVGRP instance. */
5026#define ALT_USB1_DEV_DOEPINT12_ADDR ALT_USB_DEV_DOEPINT12_ADDR(ALT_USB1_DEVGRP_ADDR)
5027/* The address of the ALT_USB_DEV_DOEPTSIZ12 register for the ALT_USB1_DEVGRP instance. */
5028#define ALT_USB1_DEV_DOEPTSIZ12_ADDR ALT_USB_DEV_DOEPTSIZ12_ADDR(ALT_USB1_DEVGRP_ADDR)
5029/* The address of the ALT_USB_DEV_DOEPDMA12 register for the ALT_USB1_DEVGRP instance. */
5030#define ALT_USB1_DEV_DOEPDMA12_ADDR ALT_USB_DEV_DOEPDMA12_ADDR(ALT_USB1_DEVGRP_ADDR)
5031/* The address of the ALT_USB_DEV_DOEPDMAB12 register for the ALT_USB1_DEVGRP instance. */
5032#define ALT_USB1_DEV_DOEPDMAB12_ADDR ALT_USB_DEV_DOEPDMAB12_ADDR(ALT_USB1_DEVGRP_ADDR)
5033/* The address of the ALT_USB_DEV_DOEPCTL13 register for the ALT_USB1_DEVGRP instance. */
5034#define ALT_USB1_DEV_DOEPCTL13_ADDR ALT_USB_DEV_DOEPCTL13_ADDR(ALT_USB1_DEVGRP_ADDR)
5035/* The address of the ALT_USB_DEV_DOEPINT13 register for the ALT_USB1_DEVGRP instance. */
5036#define ALT_USB1_DEV_DOEPINT13_ADDR ALT_USB_DEV_DOEPINT13_ADDR(ALT_USB1_DEVGRP_ADDR)
5037/* The address of the ALT_USB_DEV_DOEPTSIZ13 register for the ALT_USB1_DEVGRP instance. */
5038#define ALT_USB1_DEV_DOEPTSIZ13_ADDR ALT_USB_DEV_DOEPTSIZ13_ADDR(ALT_USB1_DEVGRP_ADDR)
5039/* The address of the ALT_USB_DEV_DOEPDMA13 register for the ALT_USB1_DEVGRP instance. */
5040#define ALT_USB1_DEV_DOEPDMA13_ADDR ALT_USB_DEV_DOEPDMA13_ADDR(ALT_USB1_DEVGRP_ADDR)
5041/* The address of the ALT_USB_DEV_DOEPDMAB13 register for the ALT_USB1_DEVGRP instance. */
5042#define ALT_USB1_DEV_DOEPDMAB13_ADDR ALT_USB_DEV_DOEPDMAB13_ADDR(ALT_USB1_DEVGRP_ADDR)
5043/* The address of the ALT_USB_DEV_DOEPCTL14 register for the ALT_USB1_DEVGRP instance. */
5044#define ALT_USB1_DEV_DOEPCTL14_ADDR ALT_USB_DEV_DOEPCTL14_ADDR(ALT_USB1_DEVGRP_ADDR)
5045/* The address of the ALT_USB_DEV_DOEPINT14 register for the ALT_USB1_DEVGRP instance. */
5046#define ALT_USB1_DEV_DOEPINT14_ADDR ALT_USB_DEV_DOEPINT14_ADDR(ALT_USB1_DEVGRP_ADDR)
5047/* The address of the ALT_USB_DEV_DOEPTSIZ14 register for the ALT_USB1_DEVGRP instance. */
5048#define ALT_USB1_DEV_DOEPTSIZ14_ADDR ALT_USB_DEV_DOEPTSIZ14_ADDR(ALT_USB1_DEVGRP_ADDR)
5049/* The address of the ALT_USB_DEV_DOEPDMA14 register for the ALT_USB1_DEVGRP instance. */
5050#define ALT_USB1_DEV_DOEPDMA14_ADDR ALT_USB_DEV_DOEPDMA14_ADDR(ALT_USB1_DEVGRP_ADDR)
5051/* The address of the ALT_USB_DEV_DOEPDMAB14 register for the ALT_USB1_DEVGRP instance. */
5052#define ALT_USB1_DEV_DOEPDMAB14_ADDR ALT_USB_DEV_DOEPDMAB14_ADDR(ALT_USB1_DEVGRP_ADDR)
5053/* The address of the ALT_USB_DEV_DOEPCTL15 register for the ALT_USB1_DEVGRP instance. */
5054#define ALT_USB1_DEV_DOEPCTL15_ADDR ALT_USB_DEV_DOEPCTL15_ADDR(ALT_USB1_DEVGRP_ADDR)
5055/* The address of the ALT_USB_DEV_DOEPINT15 register for the ALT_USB1_DEVGRP instance. */
5056#define ALT_USB1_DEV_DOEPINT15_ADDR ALT_USB_DEV_DOEPINT15_ADDR(ALT_USB1_DEVGRP_ADDR)
5057/* The address of the ALT_USB_DEV_DOEPTSIZ15 register for the ALT_USB1_DEVGRP instance. */
5058#define ALT_USB1_DEV_DOEPTSIZ15_ADDR ALT_USB_DEV_DOEPTSIZ15_ADDR(ALT_USB1_DEVGRP_ADDR)
5059/* The address of the ALT_USB_DEV_DOEPDMA15 register for the ALT_USB1_DEVGRP instance. */
5060#define ALT_USB1_DEV_DOEPDMA15_ADDR ALT_USB_DEV_DOEPDMA15_ADDR(ALT_USB1_DEVGRP_ADDR)
5061/* The address of the ALT_USB_DEV_DOEPDMAB15 register for the ALT_USB1_DEVGRP instance. */
5062#define ALT_USB1_DEV_DOEPDMAB15_ADDR ALT_USB_DEV_DOEPDMAB15_ADDR(ALT_USB1_DEVGRP_ADDR)
5063/* The base address byte offset for the start of the ALT_USB1_DEVGRP component. */
5064#define ALT_USB1_DEVGRP_OFST 0x800
5065/* The start address of the ALT_USB1_DEVGRP component. */
5066#define ALT_USB1_DEVGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB1_ADDR) + ALT_USB1_DEVGRP_OFST))
5067/* The lower bound address range of the ALT_USB1_DEVGRP component. */
5068#define ALT_USB1_DEVGRP_LB_ADDR ALT_USB1_DEVGRP_ADDR
5069/* The upper bound address range of the ALT_USB1_DEVGRP component. */
5070#define ALT_USB1_DEVGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB1_DEVGRP_ADDR) + 0x500) - 1))
5071
5072
5073/*
5074 * Register Group Instance : pwrclkgrp
5075 *
5076 * Instance pwrclkgrp of register group ALT_USB_PWRCLK.
5077 *
5078 *
5079 */
5080/* The address of the ALT_USB_PWRCLK_PCGCCTL register for the ALT_USB1_PWRCLKGRP instance. */
5081#define ALT_USB1_PWRCLK_PCGCCTL_ADDR ALT_USB_PWRCLK_PCGCCTL_ADDR(ALT_USB1_PWRCLKGRP_ADDR)
5082/* The base address byte offset for the start of the ALT_USB1_PWRCLKGRP component. */
5083#define ALT_USB1_PWRCLKGRP_OFST 0xe00
5084/* The start address of the ALT_USB1_PWRCLKGRP component. */
5085#define ALT_USB1_PWRCLKGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB1_ADDR) + ALT_USB1_PWRCLKGRP_OFST))
5086/* The lower bound address range of the ALT_USB1_PWRCLKGRP component. */
5087#define ALT_USB1_PWRCLKGRP_LB_ADDR ALT_USB1_PWRCLKGRP_ADDR
5088/* The upper bound address range of the ALT_USB1_PWRCLKGRP component. */
5089#define ALT_USB1_PWRCLKGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB1_PWRCLKGRP_ADDR) + 0x4) - 1))
5090
5091
5092/* The base address byte offset for the start of the ALT_USB1 component. */
5093#define ALT_USB1_OFST 0xffb40000
5094/* The start address of the ALT_USB1 component. */
5095#define ALT_USB1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_USB1_OFST))
5096/* The lower bound address range of the ALT_USB1 component. */
5097#define ALT_USB1_LB_ADDR ALT_USB1_ADDR
5098/* The upper bound address range of the ALT_USB1 component. */
5099#define ALT_USB1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB1_ADDR) + 0x40000) - 1))
5100
5101
5102/*
5103 * Component Instance : nandregs
5104 *
5105 * Instance nandregs of component ALT_NAND.
5106 *
5107 *
5108 */
5109/*
5110 * Register Group Instance : config
5111 *
5112 * Instance config of register group ALT_NAND_CFG.
5113 *
5114 *
5115 */
5116/* The address of the ALT_NAND_CFG_DEVICE_RST register for the ALT_NAND_CFG instance. */
5117#define ALT_NAND_CFG_DEVICE_RST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_DEVICE_RST_OFST))
5118/* The address of the ALT_NAND_CFG_TFR_SPARE_REG register for the ALT_NAND_CFG instance. */
5119#define ALT_NAND_CFG_TFR_SPARE_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_TFR_SPARE_REG_OFST))
5120/* The address of the ALT_NAND_CFG_LD_WAIT_CNT register for the ALT_NAND_CFG instance. */
5121#define ALT_NAND_CFG_LD_WAIT_CNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_LD_WAIT_CNT_OFST))
5122/* The address of the ALT_NAND_CFG_PROGRAM_WAIT_CNT register for the ALT_NAND_CFG instance. */
5123#define ALT_NAND_CFG_PROGRAM_WAIT_CNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_PROGRAM_WAIT_CNT_OFST))
5124/* The address of the ALT_NAND_CFG_ERASE_WAIT_CNT register for the ALT_NAND_CFG instance. */
5125#define ALT_NAND_CFG_ERASE_WAIT_CNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_ERASE_WAIT_CNT_OFST))
5126/* The address of the ALT_NAND_CFG_INT_MON_CYCCNT register for the ALT_NAND_CFG instance. */
5127#define ALT_NAND_CFG_INT_MON_CYCCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_INT_MON_CYCCNT_OFST))
5128/* The address of the ALT_NAND_CFG_RB_PIN_END register for the ALT_NAND_CFG instance. */
5129#define ALT_NAND_CFG_RB_PIN_END_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_RB_PIN_END_OFST))
5130/* The address of the ALT_NAND_CFG_MULTIPLANE_OP register for the ALT_NAND_CFG instance. */
5131#define ALT_NAND_CFG_MULTIPLANE_OP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_MULTIPLANE_OP_OFST))
5132/* The address of the ALT_NAND_CFG_MULTIPLANE_RD_EN register for the ALT_NAND_CFG instance. */
5133#define ALT_NAND_CFG_MULTIPLANE_RD_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_MULTIPLANE_RD_EN_OFST))
5134/* The address of the ALT_NAND_CFG_COPYBACK_DIS register for the ALT_NAND_CFG instance. */
5135#define ALT_NAND_CFG_COPYBACK_DIS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_COPYBACK_DIS_OFST))
5136/* The address of the ALT_NAND_CFG_CACHE_WR_EN register for the ALT_NAND_CFG instance. */
5137#define ALT_NAND_CFG_CACHE_WR_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_CACHE_WR_EN_OFST))
5138/* The address of the ALT_NAND_CFG_CACHE_RD_EN register for the ALT_NAND_CFG instance. */
5139#define ALT_NAND_CFG_CACHE_RD_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_CACHE_RD_EN_OFST))
5140/* The address of the ALT_NAND_CFG_PREFETCH_MOD register for the ALT_NAND_CFG instance. */
5141#define ALT_NAND_CFG_PREFETCH_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_PREFETCH_MOD_OFST))
5142/* The address of the ALT_NAND_CFG_CHIP_EN_DONT_CARE register for the ALT_NAND_CFG instance. */
5143#define ALT_NAND_CFG_CHIP_EN_DONT_CARE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_CHIP_EN_DONT_CARE_OFST))
5144/* The address of the ALT_NAND_CFG_ECC_EN register for the ALT_NAND_CFG instance. */
5145#define ALT_NAND_CFG_ECC_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_ECC_EN_OFST))
5146/* The address of the ALT_NAND_CFG_GLOB_INT_EN register for the ALT_NAND_CFG instance. */
5147#define ALT_NAND_CFG_GLOB_INT_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_GLOB_INT_EN_OFST))
5148/* The address of the ALT_NAND_CFG_TWHR2_AND_WE_2_RE register for the ALT_NAND_CFG instance. */
5149#define ALT_NAND_CFG_TWHR2_AND_WE_2_RE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_TWHR2_AND_WE_2_RE_OFST))
5150/* The address of the ALT_NAND_CFG_TCWAW_AND_ADDR_2_DATA register for the ALT_NAND_CFG instance. */
5151#define ALT_NAND_CFG_TCWAW_AND_ADDR_2_DATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_TCWAW_AND_ADDR_2_DATA_OFST))
5152/* The address of the ALT_NAND_CFG_RE_2_WE register for the ALT_NAND_CFG instance. */
5153#define ALT_NAND_CFG_RE_2_WE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_RE_2_WE_OFST))
5154/* The address of the ALT_NAND_CFG_ACC_CLKS register for the ALT_NAND_CFG instance. */
5155#define ALT_NAND_CFG_ACC_CLKS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_ACC_CLKS_OFST))
5156/* The address of the ALT_NAND_CFG_NUMBER_OF_PLANES register for the ALT_NAND_CFG instance. */
5157#define ALT_NAND_CFG_NUMBER_OF_PLANES_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_NUMBER_OF_PLANES_OFST))
5158/* The address of the ALT_NAND_CFG_PAGES_PER_BLOCK register for the ALT_NAND_CFG instance. */
5159#define ALT_NAND_CFG_PAGES_PER_BLOCK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_PAGES_PER_BLOCK_OFST))
5160/* The address of the ALT_NAND_CFG_DEVICE_WIDTH register for the ALT_NAND_CFG instance. */
5161#define ALT_NAND_CFG_DEVICE_WIDTH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_DEVICE_WIDTH_OFST))
5162/* The address of the ALT_NAND_CFG_DEVICE_MAIN_AREA_SIZE register for the ALT_NAND_CFG instance. */
5163#define ALT_NAND_CFG_DEVICE_MAIN_AREA_SIZE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_DEVICE_MAIN_AREA_SIZE_OFST))
5164/* The address of the ALT_NAND_CFG_DEVICE_SPARE_AREA_SIZE register for the ALT_NAND_CFG instance. */
5165#define ALT_NAND_CFG_DEVICE_SPARE_AREA_SIZE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_DEVICE_SPARE_AREA_SIZE_OFST))
5166/* The address of the ALT_NAND_CFG_TWO_ROW_ADDR_CYCLES register for the ALT_NAND_CFG instance. */
5167#define ALT_NAND_CFG_TWO_ROW_ADDR_CYCLES_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_TWO_ROW_ADDR_CYCLES_OFST))
5168/* The address of the ALT_NAND_CFG_MULTIPLANE_ADDR_RESTRICT register for the ALT_NAND_CFG instance. */
5169#define ALT_NAND_CFG_MULTIPLANE_ADDR_RESTRICT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_MULTIPLANE_ADDR_RESTRICT_OFST))
5170/* The address of the ALT_NAND_CFG_ECC_CORRECTION register for the ALT_NAND_CFG instance. */
5171#define ALT_NAND_CFG_ECC_CORRECTION_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_ECC_CORRECTION_OFST))
5172/* The address of the ALT_NAND_CFG_RD_MOD register for the ALT_NAND_CFG instance. */
5173#define ALT_NAND_CFG_RD_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_RD_MOD_OFST))
5174/* The address of the ALT_NAND_CFG_WR_MOD register for the ALT_NAND_CFG instance. */
5175#define ALT_NAND_CFG_WR_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_WR_MOD_OFST))
5176/* The address of the ALT_NAND_CFG_COPYBACK_MOD register for the ALT_NAND_CFG instance. */
5177#define ALT_NAND_CFG_COPYBACK_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_COPYBACK_MOD_OFST))
5178/* The address of the ALT_NAND_CFG_RDWR_EN_LO_CNT register for the ALT_NAND_CFG instance. */
5179#define ALT_NAND_CFG_RDWR_EN_LO_CNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_RDWR_EN_LO_CNT_OFST))
5180/* The address of the ALT_NAND_CFG_RDWR_EN_HI_CNT register for the ALT_NAND_CFG instance. */
5181#define ALT_NAND_CFG_RDWR_EN_HI_CNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_RDWR_EN_HI_CNT_OFST))
5182/* The address of the ALT_NAND_CFG_MAX_RD_DELAY register for the ALT_NAND_CFG instance. */
5183#define ALT_NAND_CFG_MAX_RD_DELAY_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_MAX_RD_DELAY_OFST))
5184/* The address of the ALT_NAND_CFG_CS_SETUP_CNT register for the ALT_NAND_CFG instance. */
5185#define ALT_NAND_CFG_CS_SETUP_CNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_CS_SETUP_CNT_OFST))
5186/* The address of the ALT_NAND_CFG_SPARE_AREA_SKIP_BYTES register for the ALT_NAND_CFG instance. */
5187#define ALT_NAND_CFG_SPARE_AREA_SKIP_BYTES_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_SPARE_AREA_SKIP_BYTES_OFST))
5188/* The address of the ALT_NAND_CFG_SPARE_AREA_MARKER register for the ALT_NAND_CFG instance. */
5189#define ALT_NAND_CFG_SPARE_AREA_MARKER_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_SPARE_AREA_MARKER_OFST))
5190/* The address of the ALT_NAND_CFG_DEVICES_CONNECTED register for the ALT_NAND_CFG instance. */
5191#define ALT_NAND_CFG_DEVICES_CONNECTED_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_DEVICES_CONNECTED_OFST))
5192/* The address of the ALT_NAND_CFG_DIE_MSK register for the ALT_NAND_CFG instance. */
5193#define ALT_NAND_CFG_DIE_MSK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_DIE_MSK_OFST))
5194/* The address of the ALT_NAND_CFG_FIRST_BLOCK_OF_NEXT_PLANE register for the ALT_NAND_CFG instance. */
5195#define ALT_NAND_CFG_FIRST_BLOCK_OF_NEXT_PLANE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_FIRST_BLOCK_OF_NEXT_PLANE_OFST))
5196/* The address of the ALT_NAND_CFG_WR_PROTECT register for the ALT_NAND_CFG instance. */
5197#define ALT_NAND_CFG_WR_PROTECT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_WR_PROTECT_OFST))
5198/* The address of the ALT_NAND_CFG_RE_2_RE register for the ALT_NAND_CFG instance. */
5199#define ALT_NAND_CFG_RE_2_RE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_RE_2_RE_OFST))
5200/* The address of the ALT_NAND_CFG_POR_RST_COUNT register for the ALT_NAND_CFG instance. */
5201#define ALT_NAND_CFG_POR_RST_COUNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_POR_RST_COUNT_OFST))
5202/* The address of the ALT_NAND_CFG_WD_RST_COUNT register for the ALT_NAND_CFG instance. */
5203#define ALT_NAND_CFG_WD_RST_COUNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_WD_RST_COUNT_OFST))
5204/* The base address byte offset for the start of the ALT_NAND_CFG component. */
5205#define ALT_NAND_CFG_OFST 0x0
5206/* The start address of the ALT_NAND_CFG component. */
5207#define ALT_NAND_CFG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ADDR) + ALT_NAND_CFG_OFST))
5208/* The lower bound address range of the ALT_NAND_CFG component. */
5209#define ALT_NAND_CFG_LB_ADDR ALT_NAND_CFG_ADDR
5210/* The upper bound address range of the ALT_NAND_CFG component. */
5211#define ALT_NAND_CFG_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NAND_CFG_ADDR) + 0x2b4) - 1))
5212
5213
5214/*
5215 * Register Group Instance : param
5216 *
5217 * Instance param of register group ALT_NAND_PARAM.
5218 *
5219 *
5220 */
5221/* The address of the ALT_NAND_PARAM_MANUFACTURER_ID register for the ALT_NAND_PARAM instance. */
5222#define ALT_NAND_PARAM_MANUFACTURER_ID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_MANUFACTURER_ID_OFST))
5223/* The address of the ALT_NAND_PARAM_DEVICE_ID register for the ALT_NAND_PARAM instance. */
5224#define ALT_NAND_PARAM_DEVICE_ID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_DEVICE_ID_OFST))
5225/* The address of the ALT_NAND_PARAM_DEVICE_PARAM_0 register for the ALT_NAND_PARAM instance. */
5226#define ALT_NAND_PARAM_DEVICE_PARAM_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_DEVICE_PARAM_0_OFST))
5227/* The address of the ALT_NAND_PARAM_DEVICE_PARAM_1 register for the ALT_NAND_PARAM instance. */
5228#define ALT_NAND_PARAM_DEVICE_PARAM_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_DEVICE_PARAM_1_OFST))
5229/* The address of the ALT_NAND_PARAM_DEVICE_PARAM_2 register for the ALT_NAND_PARAM instance. */
5230#define ALT_NAND_PARAM_DEVICE_PARAM_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_DEVICE_PARAM_2_OFST))
5231/* The address of the ALT_NAND_PARAM_LOGICAL_PAGE_DATA_SIZE register for the ALT_NAND_PARAM instance. */
5232#define ALT_NAND_PARAM_LOGICAL_PAGE_DATA_SIZE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_LOGICAL_PAGE_DATA_SIZE_OFST))
5233/* The address of the ALT_NAND_PARAM_LOGICAL_PAGE_SPARE_SIZE register for the ALT_NAND_PARAM instance. */
5234#define ALT_NAND_PARAM_LOGICAL_PAGE_SPARE_SIZE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_LOGICAL_PAGE_SPARE_SIZE_OFST))
5235/* The address of the ALT_NAND_PARAM_REVISION register for the ALT_NAND_PARAM instance. */
5236#define ALT_NAND_PARAM_REVISION_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_REVISION_OFST))
5237/* The address of the ALT_NAND_PARAM_ONFI_DEV_FEATURES register for the ALT_NAND_PARAM instance. */
5238#define ALT_NAND_PARAM_ONFI_DEV_FEATURES_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_DEV_FEATURES_OFST))
5239/* The address of the ALT_NAND_PARAM_ONFI_OPTIONAL_CMDS register for the ALT_NAND_PARAM instance. */
5240#define ALT_NAND_PARAM_ONFI_OPTIONAL_CMDS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_OPTIONAL_CMDS_OFST))
5241/* The address of the ALT_NAND_PARAM_ONFI_TIMING_MOD register for the ALT_NAND_PARAM instance. */
5242#define ALT_NAND_PARAM_ONFI_TIMING_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_TIMING_MOD_OFST))
5243/* The address of the ALT_NAND_PARAM_ONFI_PGM_CACHE_TIMING_MOD register for the ALT_NAND_PARAM instance. */
5244#define ALT_NAND_PARAM_ONFI_PGM_CACHE_TIMING_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_PGM_CACHE_TIMING_MOD_OFST))
5245/* The address of the ALT_NAND_PARAM_ONFI_DEV_NO_OF_LUNS register for the ALT_NAND_PARAM instance. */
5246#define ALT_NAND_PARAM_ONFI_DEV_NO_OF_LUNS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_DEV_NO_OF_LUNS_OFST))
5247/* The address of the ALT_NAND_PARAM_ONFI_DEV_BLKS_PER_LUN_L register for the ALT_NAND_PARAM instance. */
5248#define ALT_NAND_PARAM_ONFI_DEV_BLKS_PER_LUN_L_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_DEV_BLKS_PER_LUN_L_OFST))
5249/* The address of the ALT_NAND_PARAM_ONFI_DEV_BLKS_PER_LUN_U register for the ALT_NAND_PARAM instance. */
5250#define ALT_NAND_PARAM_ONFI_DEV_BLKS_PER_LUN_U_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_DEV_BLKS_PER_LUN_U_OFST))
5251/* The address of the ALT_NAND_PARAM_FEATURES register for the ALT_NAND_PARAM instance. */
5252#define ALT_NAND_PARAM_FEATURES_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_FEATURES_OFST))
5253/* The base address byte offset for the start of the ALT_NAND_PARAM component. */
5254#define ALT_NAND_PARAM_OFST 0x300
5255/* The start address of the ALT_NAND_PARAM component. */
5256#define ALT_NAND_PARAM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ADDR) + ALT_NAND_PARAM_OFST))
5257/* The lower bound address range of the ALT_NAND_PARAM component. */
5258#define ALT_NAND_PARAM_LB_ADDR ALT_NAND_PARAM_ADDR
5259/* The upper bound address range of the ALT_NAND_PARAM component. */
5260#define ALT_NAND_PARAM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + 0xf4) - 1))
5261
5262
5263/*
5264 * Register Group Instance : status
5265 *
5266 * Instance status of register group ALT_NAND_STAT.
5267 *
5268 *
5269 */
5270/* The address of the ALT_NAND_STAT_TFR_MOD register for the ALT_NAND_STAT instance. */
5271#define ALT_NAND_STAT_TFR_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_TFR_MOD_OFST))
5272/* The address of the ALT_NAND_STAT_INTR_STAT0 register for the ALT_NAND_STAT instance. */
5273#define ALT_NAND_STAT_INTR_STAT0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_STAT0_OFST))
5274/* The address of the ALT_NAND_STAT_INTR_EN0 register for the ALT_NAND_STAT instance. */
5275#define ALT_NAND_STAT_INTR_EN0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_EN0_OFST))
5276/* The address of the ALT_NAND_STAT_PAGE_CNT0 register for the ALT_NAND_STAT instance. */
5277#define ALT_NAND_STAT_PAGE_CNT0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_PAGE_CNT0_OFST))
5278/* The address of the ALT_NAND_STAT_ERR_PAGE_ADDR0 register for the ALT_NAND_STAT instance. */
5279#define ALT_NAND_STAT_ERR_PAGE_ADDR0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_PAGE_ADDR0_OFST))
5280/* The address of the ALT_NAND_STAT_ERR_BLOCK_ADDR0 register for the ALT_NAND_STAT instance. */
5281#define ALT_NAND_STAT_ERR_BLOCK_ADDR0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_BLOCK_ADDR0_OFST))
5282/* The address of the ALT_NAND_STAT_INTR_STAT1 register for the ALT_NAND_STAT instance. */
5283#define ALT_NAND_STAT_INTR_STAT1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_STAT1_OFST))
5284/* The address of the ALT_NAND_STAT_INTR_EN1 register for the ALT_NAND_STAT instance. */
5285#define ALT_NAND_STAT_INTR_EN1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_EN1_OFST))
5286/* The address of the ALT_NAND_STAT_PAGE_CNT1 register for the ALT_NAND_STAT instance. */
5287#define ALT_NAND_STAT_PAGE_CNT1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_PAGE_CNT1_OFST))
5288/* The address of the ALT_NAND_STAT_ERR_PAGE_ADDR1 register for the ALT_NAND_STAT instance. */
5289#define ALT_NAND_STAT_ERR_PAGE_ADDR1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_PAGE_ADDR1_OFST))
5290/* The address of the ALT_NAND_STAT_ERR_BLOCK_ADDR1 register for the ALT_NAND_STAT instance. */
5291#define ALT_NAND_STAT_ERR_BLOCK_ADDR1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_BLOCK_ADDR1_OFST))
5292/* The address of the ALT_NAND_STAT_INTR_STAT2 register for the ALT_NAND_STAT instance. */
5293#define ALT_NAND_STAT_INTR_STAT2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_STAT2_OFST))
5294/* The address of the ALT_NAND_STAT_INTR_EN2 register for the ALT_NAND_STAT instance. */
5295#define ALT_NAND_STAT_INTR_EN2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_EN2_OFST))
5296/* The address of the ALT_NAND_STAT_PAGE_CNT2 register for the ALT_NAND_STAT instance. */
5297#define ALT_NAND_STAT_PAGE_CNT2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_PAGE_CNT2_OFST))
5298/* The address of the ALT_NAND_STAT_ERR_PAGE_ADDR2 register for the ALT_NAND_STAT instance. */
5299#define ALT_NAND_STAT_ERR_PAGE_ADDR2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_PAGE_ADDR2_OFST))
5300/* The address of the ALT_NAND_STAT_ERR_BLOCK_ADDR2 register for the ALT_NAND_STAT instance. */
5301#define ALT_NAND_STAT_ERR_BLOCK_ADDR2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_BLOCK_ADDR2_OFST))
5302/* The address of the ALT_NAND_STAT_INTR_STAT3 register for the ALT_NAND_STAT instance. */
5303#define ALT_NAND_STAT_INTR_STAT3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_STAT3_OFST))
5304/* The address of the ALT_NAND_STAT_INTR_EN3 register for the ALT_NAND_STAT instance. */
5305#define ALT_NAND_STAT_INTR_EN3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_EN3_OFST))
5306/* The address of the ALT_NAND_STAT_PAGE_CNT3 register for the ALT_NAND_STAT instance. */
5307#define ALT_NAND_STAT_PAGE_CNT3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_PAGE_CNT3_OFST))
5308/* The address of the ALT_NAND_STAT_ERR_PAGE_ADDR3 register for the ALT_NAND_STAT instance. */
5309#define ALT_NAND_STAT_ERR_PAGE_ADDR3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_PAGE_ADDR3_OFST))
5310/* The address of the ALT_NAND_STAT_ERR_BLOCK_ADDR3 register for the ALT_NAND_STAT instance. */
5311#define ALT_NAND_STAT_ERR_BLOCK_ADDR3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_BLOCK_ADDR3_OFST))
5312/* The base address byte offset for the start of the ALT_NAND_STAT component. */
5313#define ALT_NAND_STAT_OFST 0x400
5314/* The start address of the ALT_NAND_STAT component. */
5315#define ALT_NAND_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ADDR) + ALT_NAND_STAT_OFST))
5316/* The lower bound address range of the ALT_NAND_STAT component. */
5317#define ALT_NAND_STAT_LB_ADDR ALT_NAND_STAT_ADDR
5318/* The upper bound address range of the ALT_NAND_STAT component. */
5319#define ALT_NAND_STAT_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NAND_STAT_ADDR) + 0x144) - 1))
5320
5321
5322/*
5323 * Register Group Instance : ecc
5324 *
5325 * Instance ecc of register group ALT_NAND_ECC.
5326 *
5327 *
5328 */
5329/* The address of the ALT_NAND_ECC_ECCCORINFO_B01 register for the ALT_NAND_ECC instance. */
5330#define ALT_NAND_ECC_ECCCORINFO_B01_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ECC_ADDR) + ALT_NAND_ECC_ECCCORINFO_B01_OFST))
5331/* The address of the ALT_NAND_ECC_ECCCORINFO_B23 register for the ALT_NAND_ECC instance. */
5332#define ALT_NAND_ECC_ECCCORINFO_B23_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ECC_ADDR) + ALT_NAND_ECC_ECCCORINFO_B23_OFST))
5333/* The base address byte offset for the start of the ALT_NAND_ECC component. */
5334#define ALT_NAND_ECC_OFST 0x650
5335/* The start address of the ALT_NAND_ECC component. */
5336#define ALT_NAND_ECC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ADDR) + ALT_NAND_ECC_OFST))
5337/* The lower bound address range of the ALT_NAND_ECC component. */
5338#define ALT_NAND_ECC_LB_ADDR ALT_NAND_ECC_ADDR
5339/* The upper bound address range of the ALT_NAND_ECC component. */
5340#define ALT_NAND_ECC_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NAND_ECC_ADDR) + 0x14) - 1))
5341
5342
5343/*
5344 * Register Group Instance : dma
5345 *
5346 * Instance dma of register group ALT_NAND_DMA.
5347 *
5348 *
5349 */
5350/* The address of the ALT_NAND_DMA_DMA_EN register for the ALT_NAND_DMA instance. */
5351#define ALT_NAND_DMA_DMA_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_DMA_EN_OFST))
5352/* The address of the ALT_NAND_DMA_DMA_INTR register for the ALT_NAND_DMA instance. */
5353#define ALT_NAND_DMA_DMA_INTR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_DMA_INTR_OFST))
5354/* The address of the ALT_NAND_DMA_DMA_INTR_EN register for the ALT_NAND_DMA instance. */
5355#define ALT_NAND_DMA_DMA_INTR_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_DMA_INTR_EN_OFST))
5356/* The address of the ALT_NAND_DMA_TGT_ERR_ADDR_LO register for the ALT_NAND_DMA instance. */
5357#define ALT_NAND_DMA_TGT_ERR_ADDR_LO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_TGT_ERR_ADDR_LO_OFST))
5358/* The address of the ALT_NAND_DMA_TGT_ERR_ADDR_HI register for the ALT_NAND_DMA instance. */
5359#define ALT_NAND_DMA_TGT_ERR_ADDR_HI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_TGT_ERR_ADDR_HI_OFST))
5360/* The address of the ALT_NAND_DMA_FLSH_BURST_LEN register for the ALT_NAND_DMA instance. */
5361#define ALT_NAND_DMA_FLSH_BURST_LEN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_FLSH_BURST_LEN_OFST))
5362/* The address of the ALT_NAND_DMA_INTRLV register for the ALT_NAND_DMA instance. */
5363#define ALT_NAND_DMA_INTRLV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_INTRLV_OFST))
5364/* The address of the ALT_NAND_DMA_NO_OF_BLOCKS_PER_LUN register for the ALT_NAND_DMA instance. */
5365#define ALT_NAND_DMA_NO_OF_BLOCKS_PER_LUN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_NO_OF_BLOCKS_PER_LUN_OFST))
5366/* The address of the ALT_NAND_DMA_LUN_STAT_CMD register for the ALT_NAND_DMA instance. */
5367#define ALT_NAND_DMA_LUN_STAT_CMD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_LUN_STAT_CMD_OFST))
5368/* The base address byte offset for the start of the ALT_NAND_DMA component. */
5369#define ALT_NAND_DMA_OFST 0x700
5370/* The start address of the ALT_NAND_DMA component. */
5371#define ALT_NAND_DMA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ADDR) + ALT_NAND_DMA_OFST))
5372/* The lower bound address range of the ALT_NAND_DMA component. */
5373#define ALT_NAND_DMA_LB_ADDR ALT_NAND_DMA_ADDR
5374/* The upper bound address range of the ALT_NAND_DMA component. */
5375#define ALT_NAND_DMA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NAND_DMA_ADDR) + 0xa4) - 1))
5376
5377
5378/* The base address byte offset for the start of the ALT_NAND component. */
5379#define ALT_NAND_OFST 0xffb80000
5380/* The start address of the ALT_NAND component. */
5381#define ALT_NAND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_NAND_OFST))
5382/* The lower bound address range of the ALT_NAND component. */
5383#define ALT_NAND_LB_ADDR ALT_NAND_ADDR
5384/* The upper bound address range of the ALT_NAND component. */
5385#define ALT_NAND_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NAND_ADDR) + 0x800) - 1))
5386
5387
5388/*
5389 * Component Instance : fpgamgrdata
5390 *
5391 * Instance fpgamgrdata of component ALT_FPGAMGRDATA.
5392 *
5393 *
5394 */
5395/* The address of the ALT_FPGAMGRDATA_DATA register for the ALT_FPGAMGRDATA instance. */
5396#define ALT_FPGAMGRDATA_DATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGRDATA_ADDR) + ALT_FPGAMGRDATA_DATA_OFST))
5397/* The base address byte offset for the start of the ALT_FPGAMGRDATA component. */
5398#define ALT_FPGAMGRDATA_OFST 0xffb90000
5399/* The start address of the ALT_FPGAMGRDATA component. */
5400#define ALT_FPGAMGRDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_FPGAMGRDATA_OFST))
5401/* The lower bound address range of the ALT_FPGAMGRDATA component. */
5402#define ALT_FPGAMGRDATA_LB_ADDR ALT_FPGAMGRDATA_ADDR
5403/* The upper bound address range of the ALT_FPGAMGRDATA component. */
5404#define ALT_FPGAMGRDATA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_FPGAMGRDATA_ADDR) + 0x4) - 1))
5405
5406
5407/*
5408 * Component Instance : can0
5409 *
5410 * Instance can0 of component ALT_CAN.
5411 *
5412 *
5413 */
5414/*
5415 * Register Group Instance : protogrp
5416 *
5417 * Instance protogrp of register group ALT_CAN_PROTO.
5418 *
5419 *
5420 */
5421/* The address of the ALT_CAN_PROTO_CCTL register for the ALT_CAN0_PROTOGRP instance. */
5422#define ALT_CAN0_PROTO_CCTL_ADDR ALT_CAN_PROTO_CCTL_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5423/* The address of the ALT_CAN_PROTO_CSTS register for the ALT_CAN0_PROTOGRP instance. */
5424#define ALT_CAN0_PROTO_CSTS_ADDR ALT_CAN_PROTO_CSTS_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5425/* The address of the ALT_CAN_PROTO_CERC register for the ALT_CAN0_PROTOGRP instance. */
5426#define ALT_CAN0_PROTO_CERC_ADDR ALT_CAN_PROTO_CERC_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5427/* The address of the ALT_CAN_PROTO_CBT register for the ALT_CAN0_PROTOGRP instance. */
5428#define ALT_CAN0_PROTO_CBT_ADDR ALT_CAN_PROTO_CBT_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5429/* The address of the ALT_CAN_PROTO_CIR register for the ALT_CAN0_PROTOGRP instance. */
5430#define ALT_CAN0_PROTO_CIR_ADDR ALT_CAN_PROTO_CIR_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5431/* The address of the ALT_CAN_PROTO_CTR register for the ALT_CAN0_PROTOGRP instance. */
5432#define ALT_CAN0_PROTO_CTR_ADDR ALT_CAN_PROTO_CTR_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5433/* The address of the ALT_CAN_PROTO_CFR register for the ALT_CAN0_PROTOGRP instance. */
5434#define ALT_CAN0_PROTO_CFR_ADDR ALT_CAN_PROTO_CFR_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5435/* The address of the ALT_CAN_PROTO_CRR register for the ALT_CAN0_PROTOGRP instance. */
5436#define ALT_CAN0_PROTO_CRR_ADDR ALT_CAN_PROTO_CRR_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5437/* The address of the ALT_CAN_PROTO_HWS register for the ALT_CAN0_PROTOGRP instance. */
5438#define ALT_CAN0_PROTO_HWS_ADDR ALT_CAN_PROTO_HWS_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5439/* The base address byte offset for the start of the ALT_CAN0_PROTOGRP component. */
5440#define ALT_CAN0_PROTOGRP_OFST 0x0
5441/* The start address of the ALT_CAN0_PROTOGRP component. */
5442#define ALT_CAN0_PROTOGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CAN0_ADDR) + ALT_CAN0_PROTOGRP_OFST))
5443/* The lower bound address range of the ALT_CAN0_PROTOGRP component. */
5444#define ALT_CAN0_PROTOGRP_LB_ADDR ALT_CAN0_PROTOGRP_ADDR
5445/* The upper bound address range of the ALT_CAN0_PROTOGRP component. */
5446#define ALT_CAN0_PROTOGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN0_PROTOGRP_ADDR) + 0x28) - 1))
5447
5448
5449/*
5450 * Register Group Instance : msghandgrp
5451 *
5452 * Instance msghandgrp of register group ALT_CAN_MSGHAND.
5453 *
5454 *
5455 */
5456/* The address of the ALT_CAN_MSGHAND_MOTRX register for the ALT_CAN0_MSGHANDGRP instance. */
5457#define ALT_CAN0_MSGHAND_MOTRX_ADDR ALT_CAN_MSGHAND_MOTRX_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5458/* The address of the ALT_CAN_MSGHAND_MOTRA register for the ALT_CAN0_MSGHANDGRP instance. */
5459#define ALT_CAN0_MSGHAND_MOTRA_ADDR ALT_CAN_MSGHAND_MOTRA_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5460/* The address of the ALT_CAN_MSGHAND_MOTRB register for the ALT_CAN0_MSGHANDGRP instance. */
5461#define ALT_CAN0_MSGHAND_MOTRB_ADDR ALT_CAN_MSGHAND_MOTRB_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5462/* The address of the ALT_CAN_MSGHAND_MOTRC register for the ALT_CAN0_MSGHANDGRP instance. */
5463#define ALT_CAN0_MSGHAND_MOTRC_ADDR ALT_CAN_MSGHAND_MOTRC_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5464/* The address of the ALT_CAN_MSGHAND_MOTRD register for the ALT_CAN0_MSGHANDGRP instance. */
5465#define ALT_CAN0_MSGHAND_MOTRD_ADDR ALT_CAN_MSGHAND_MOTRD_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5466/* The address of the ALT_CAN_MSGHAND_MONDX register for the ALT_CAN0_MSGHANDGRP instance. */
5467#define ALT_CAN0_MSGHAND_MONDX_ADDR ALT_CAN_MSGHAND_MONDX_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5468/* The address of the ALT_CAN_MSGHAND_MONDA register for the ALT_CAN0_MSGHANDGRP instance. */
5469#define ALT_CAN0_MSGHAND_MONDA_ADDR ALT_CAN_MSGHAND_MONDA_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5470/* The address of the ALT_CAN_MSGHAND_MONDB register for the ALT_CAN0_MSGHANDGRP instance. */
5471#define ALT_CAN0_MSGHAND_MONDB_ADDR ALT_CAN_MSGHAND_MONDB_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5472/* The address of the ALT_CAN_MSGHAND_MONDC register for the ALT_CAN0_MSGHANDGRP instance. */
5473#define ALT_CAN0_MSGHAND_MONDC_ADDR ALT_CAN_MSGHAND_MONDC_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5474/* The address of the ALT_CAN_MSGHAND_MONDD register for the ALT_CAN0_MSGHANDGRP instance. */
5475#define ALT_CAN0_MSGHAND_MONDD_ADDR ALT_CAN_MSGHAND_MONDD_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5476/* The address of the ALT_CAN_MSGHAND_MOIPX register for the ALT_CAN0_MSGHANDGRP instance. */
5477#define ALT_CAN0_MSGHAND_MOIPX_ADDR ALT_CAN_MSGHAND_MOIPX_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5478/* The address of the ALT_CAN_MSGHAND_MOIPA register for the ALT_CAN0_MSGHANDGRP instance. */
5479#define ALT_CAN0_MSGHAND_MOIPA_ADDR ALT_CAN_MSGHAND_MOIPA_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5480/* The address of the ALT_CAN_MSGHAND_MOIPB register for the ALT_CAN0_MSGHANDGRP instance. */
5481#define ALT_CAN0_MSGHAND_MOIPB_ADDR ALT_CAN_MSGHAND_MOIPB_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5482/* The address of the ALT_CAN_MSGHAND_MOIPC register for the ALT_CAN0_MSGHANDGRP instance. */
5483#define ALT_CAN0_MSGHAND_MOIPC_ADDR ALT_CAN_MSGHAND_MOIPC_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5484/* The address of the ALT_CAN_MSGHAND_MOIPD register for the ALT_CAN0_MSGHANDGRP instance. */
5485#define ALT_CAN0_MSGHAND_MOIPD_ADDR ALT_CAN_MSGHAND_MOIPD_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5486/* The address of the ALT_CAN_MSGHAND_MOVALX register for the ALT_CAN0_MSGHANDGRP instance. */
5487#define ALT_CAN0_MSGHAND_MOVALX_ADDR ALT_CAN_MSGHAND_MOVALX_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5488/* The address of the ALT_CAN_MSGHAND_MOVALA register for the ALT_CAN0_MSGHANDGRP instance. */
5489#define ALT_CAN0_MSGHAND_MOVALA_ADDR ALT_CAN_MSGHAND_MOVALA_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5490/* The address of the ALT_CAN_MSGHAND_MOVALB register for the ALT_CAN0_MSGHANDGRP instance. */
5491#define ALT_CAN0_MSGHAND_MOVALB_ADDR ALT_CAN_MSGHAND_MOVALB_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5492/* The address of the ALT_CAN_MSGHAND_MOVALC register for the ALT_CAN0_MSGHANDGRP instance. */
5493#define ALT_CAN0_MSGHAND_MOVALC_ADDR ALT_CAN_MSGHAND_MOVALC_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5494/* The address of the ALT_CAN_MSGHAND_MOVALD register for the ALT_CAN0_MSGHANDGRP instance. */
5495#define ALT_CAN0_MSGHAND_MOVALD_ADDR ALT_CAN_MSGHAND_MOVALD_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5496/* The base address byte offset for the start of the ALT_CAN0_MSGHANDGRP component. */
5497#define ALT_CAN0_MSGHANDGRP_OFST 0x84
5498/* The start address of the ALT_CAN0_MSGHANDGRP component. */
5499#define ALT_CAN0_MSGHANDGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CAN0_ADDR) + ALT_CAN0_MSGHANDGRP_OFST))
5500/* The lower bound address range of the ALT_CAN0_MSGHANDGRP component. */
5501#define ALT_CAN0_MSGHANDGRP_LB_ADDR ALT_CAN0_MSGHANDGRP_ADDR
5502/* The upper bound address range of the ALT_CAN0_MSGHANDGRP component. */
5503#define ALT_CAN0_MSGHANDGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN0_MSGHANDGRP_ADDR) + 0x50) - 1))
5504
5505
5506/*
5507 * Register Group Instance : msgifgrp
5508 *
5509 * Instance msgifgrp of register group ALT_CAN_MSGIF.
5510 *
5511 *
5512 */
5513/* The address of the ALT_CAN_MSGIF_IF1CMR register for the ALT_CAN0_MSGIFGRP instance. */
5514#define ALT_CAN0_MSGIF_IF1CMR_ADDR ALT_CAN_MSGIF_IF1CMR_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5515/* The address of the ALT_CAN_MSGIF_IF1MSK register for the ALT_CAN0_MSGIFGRP instance. */
5516#define ALT_CAN0_MSGIF_IF1MSK_ADDR ALT_CAN_MSGIF_IF1MSK_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5517/* The address of the ALT_CAN_MSGIF_IF1ARB register for the ALT_CAN0_MSGIFGRP instance. */
5518#define ALT_CAN0_MSGIF_IF1ARB_ADDR ALT_CAN_MSGIF_IF1ARB_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5519/* The address of the ALT_CAN_MSGIF_IF1MCTR register for the ALT_CAN0_MSGIFGRP instance. */
5520#define ALT_CAN0_MSGIF_IF1MCTR_ADDR ALT_CAN_MSGIF_IF1MCTR_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5521/* The address of the ALT_CAN_MSGIF_IF1DA register for the ALT_CAN0_MSGIFGRP instance. */
5522#define ALT_CAN0_MSGIF_IF1DA_ADDR ALT_CAN_MSGIF_IF1DA_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5523/* The address of the ALT_CAN_MSGIF_IF1DB register for the ALT_CAN0_MSGIFGRP instance. */
5524#define ALT_CAN0_MSGIF_IF1DB_ADDR ALT_CAN_MSGIF_IF1DB_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5525/* The address of the ALT_CAN_MSGIF_IF2CMR register for the ALT_CAN0_MSGIFGRP instance. */
5526#define ALT_CAN0_MSGIF_IF2CMR_ADDR ALT_CAN_MSGIF_IF2CMR_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5527/* The address of the ALT_CAN_MSGIF_IF2MSK register for the ALT_CAN0_MSGIFGRP instance. */
5528#define ALT_CAN0_MSGIF_IF2MSK_ADDR ALT_CAN_MSGIF_IF2MSK_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5529/* The address of the ALT_CAN_MSGIF_IF2ARB register for the ALT_CAN0_MSGIFGRP instance. */
5530#define ALT_CAN0_MSGIF_IF2ARB_ADDR ALT_CAN_MSGIF_IF2ARB_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5531/* The address of the ALT_CAN_MSGIF_IF2MCTR register for the ALT_CAN0_MSGIFGRP instance. */
5532#define ALT_CAN0_MSGIF_IF2MCTR_ADDR ALT_CAN_MSGIF_IF2MCTR_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5533/* The address of the ALT_CAN_MSGIF_IF2DA register for the ALT_CAN0_MSGIFGRP instance. */
5534#define ALT_CAN0_MSGIF_IF2DA_ADDR ALT_CAN_MSGIF_IF2DA_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5535/* The address of the ALT_CAN_MSGIF_IF2DB register for the ALT_CAN0_MSGIFGRP instance. */
5536#define ALT_CAN0_MSGIF_IF2DB_ADDR ALT_CAN_MSGIF_IF2DB_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5537/* The base address byte offset for the start of the ALT_CAN0_MSGIFGRP component. */
5538#define ALT_CAN0_MSGIFGRP_OFST 0x100
5539/* The start address of the ALT_CAN0_MSGIFGRP component. */
5540#define ALT_CAN0_MSGIFGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CAN0_ADDR) + ALT_CAN0_MSGIFGRP_OFST))
5541/* The lower bound address range of the ALT_CAN0_MSGIFGRP component. */
5542#define ALT_CAN0_MSGIFGRP_LB_ADDR ALT_CAN0_MSGIFGRP_ADDR
5543/* The upper bound address range of the ALT_CAN0_MSGIFGRP component. */
5544#define ALT_CAN0_MSGIFGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN0_MSGIFGRP_ADDR) + 0x38) - 1))
5545
5546
5547/* The base address byte offset for the start of the ALT_CAN0 component. */
5548#define ALT_CAN0_OFST 0xffc00000
5549/* The start address of the ALT_CAN0 component. */
5550#define ALT_CAN0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_CAN0_OFST))
5551/* The lower bound address range of the ALT_CAN0 component. */
5552#define ALT_CAN0_LB_ADDR ALT_CAN0_ADDR
5553/* The upper bound address range of the ALT_CAN0 component. */
5554#define ALT_CAN0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN0_ADDR) + 0x200) - 1))
5555
5556
5557/*
5558 * Component Instance : can1
5559 *
5560 * Instance can1 of component ALT_CAN.
5561 *
5562 *
5563 */
5564/*
5565 * Register Group Instance : protogrp
5566 *
5567 * Instance protogrp of register group ALT_CAN_PROTO.
5568 *
5569 *
5570 */
5571/* The address of the ALT_CAN_PROTO_CCTL register for the ALT_CAN1_PROTOGRP instance. */
5572#define ALT_CAN1_PROTO_CCTL_ADDR ALT_CAN_PROTO_CCTL_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5573/* The address of the ALT_CAN_PROTO_CSTS register for the ALT_CAN1_PROTOGRP instance. */
5574#define ALT_CAN1_PROTO_CSTS_ADDR ALT_CAN_PROTO_CSTS_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5575/* The address of the ALT_CAN_PROTO_CERC register for the ALT_CAN1_PROTOGRP instance. */
5576#define ALT_CAN1_PROTO_CERC_ADDR ALT_CAN_PROTO_CERC_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5577/* The address of the ALT_CAN_PROTO_CBT register for the ALT_CAN1_PROTOGRP instance. */
5578#define ALT_CAN1_PROTO_CBT_ADDR ALT_CAN_PROTO_CBT_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5579/* The address of the ALT_CAN_PROTO_CIR register for the ALT_CAN1_PROTOGRP instance. */
5580#define ALT_CAN1_PROTO_CIR_ADDR ALT_CAN_PROTO_CIR_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5581/* The address of the ALT_CAN_PROTO_CTR register for the ALT_CAN1_PROTOGRP instance. */
5582#define ALT_CAN1_PROTO_CTR_ADDR ALT_CAN_PROTO_CTR_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5583/* The address of the ALT_CAN_PROTO_CFR register for the ALT_CAN1_PROTOGRP instance. */
5584#define ALT_CAN1_PROTO_CFR_ADDR ALT_CAN_PROTO_CFR_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5585/* The address of the ALT_CAN_PROTO_CRR register for the ALT_CAN1_PROTOGRP instance. */
5586#define ALT_CAN1_PROTO_CRR_ADDR ALT_CAN_PROTO_CRR_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5587/* The address of the ALT_CAN_PROTO_HWS register for the ALT_CAN1_PROTOGRP instance. */
5588#define ALT_CAN1_PROTO_HWS_ADDR ALT_CAN_PROTO_HWS_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5589/* The base address byte offset for the start of the ALT_CAN1_PROTOGRP component. */
5590#define ALT_CAN1_PROTOGRP_OFST 0x0
5591/* The start address of the ALT_CAN1_PROTOGRP component. */
5592#define ALT_CAN1_PROTOGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CAN1_ADDR) + ALT_CAN1_PROTOGRP_OFST))
5593/* The lower bound address range of the ALT_CAN1_PROTOGRP component. */
5594#define ALT_CAN1_PROTOGRP_LB_ADDR ALT_CAN1_PROTOGRP_ADDR
5595/* The upper bound address range of the ALT_CAN1_PROTOGRP component. */
5596#define ALT_CAN1_PROTOGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN1_PROTOGRP_ADDR) + 0x28) - 1))
5597
5598
5599/*
5600 * Register Group Instance : msghandgrp
5601 *
5602 * Instance msghandgrp of register group ALT_CAN_MSGHAND.
5603 *
5604 *
5605 */
5606/* The address of the ALT_CAN_MSGHAND_MOTRX register for the ALT_CAN1_MSGHANDGRP instance. */
5607#define ALT_CAN1_MSGHAND_MOTRX_ADDR ALT_CAN_MSGHAND_MOTRX_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5608/* The address of the ALT_CAN_MSGHAND_MOTRA register for the ALT_CAN1_MSGHANDGRP instance. */
5609#define ALT_CAN1_MSGHAND_MOTRA_ADDR ALT_CAN_MSGHAND_MOTRA_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5610/* The address of the ALT_CAN_MSGHAND_MOTRB register for the ALT_CAN1_MSGHANDGRP instance. */
5611#define ALT_CAN1_MSGHAND_MOTRB_ADDR ALT_CAN_MSGHAND_MOTRB_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5612/* The address of the ALT_CAN_MSGHAND_MOTRC register for the ALT_CAN1_MSGHANDGRP instance. */
5613#define ALT_CAN1_MSGHAND_MOTRC_ADDR ALT_CAN_MSGHAND_MOTRC_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5614/* The address of the ALT_CAN_MSGHAND_MOTRD register for the ALT_CAN1_MSGHANDGRP instance. */
5615#define ALT_CAN1_MSGHAND_MOTRD_ADDR ALT_CAN_MSGHAND_MOTRD_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5616/* The address of the ALT_CAN_MSGHAND_MONDX register for the ALT_CAN1_MSGHANDGRP instance. */
5617#define ALT_CAN1_MSGHAND_MONDX_ADDR ALT_CAN_MSGHAND_MONDX_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5618/* The address of the ALT_CAN_MSGHAND_MONDA register for the ALT_CAN1_MSGHANDGRP instance. */
5619#define ALT_CAN1_MSGHAND_MONDA_ADDR ALT_CAN_MSGHAND_MONDA_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5620/* The address of the ALT_CAN_MSGHAND_MONDB register for the ALT_CAN1_MSGHANDGRP instance. */
5621#define ALT_CAN1_MSGHAND_MONDB_ADDR ALT_CAN_MSGHAND_MONDB_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5622/* The address of the ALT_CAN_MSGHAND_MONDC register for the ALT_CAN1_MSGHANDGRP instance. */
5623#define ALT_CAN1_MSGHAND_MONDC_ADDR ALT_CAN_MSGHAND_MONDC_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5624/* The address of the ALT_CAN_MSGHAND_MONDD register for the ALT_CAN1_MSGHANDGRP instance. */
5625#define ALT_CAN1_MSGHAND_MONDD_ADDR ALT_CAN_MSGHAND_MONDD_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5626/* The address of the ALT_CAN_MSGHAND_MOIPX register for the ALT_CAN1_MSGHANDGRP instance. */
5627#define ALT_CAN1_MSGHAND_MOIPX_ADDR ALT_CAN_MSGHAND_MOIPX_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5628/* The address of the ALT_CAN_MSGHAND_MOIPA register for the ALT_CAN1_MSGHANDGRP instance. */
5629#define ALT_CAN1_MSGHAND_MOIPA_ADDR ALT_CAN_MSGHAND_MOIPA_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5630/* The address of the ALT_CAN_MSGHAND_MOIPB register for the ALT_CAN1_MSGHANDGRP instance. */
5631#define ALT_CAN1_MSGHAND_MOIPB_ADDR ALT_CAN_MSGHAND_MOIPB_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5632/* The address of the ALT_CAN_MSGHAND_MOIPC register for the ALT_CAN1_MSGHANDGRP instance. */
5633#define ALT_CAN1_MSGHAND_MOIPC_ADDR ALT_CAN_MSGHAND_MOIPC_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5634/* The address of the ALT_CAN_MSGHAND_MOIPD register for the ALT_CAN1_MSGHANDGRP instance. */
5635#define ALT_CAN1_MSGHAND_MOIPD_ADDR ALT_CAN_MSGHAND_MOIPD_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5636/* The address of the ALT_CAN_MSGHAND_MOVALX register for the ALT_CAN1_MSGHANDGRP instance. */
5637#define ALT_CAN1_MSGHAND_MOVALX_ADDR ALT_CAN_MSGHAND_MOVALX_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5638/* The address of the ALT_CAN_MSGHAND_MOVALA register for the ALT_CAN1_MSGHANDGRP instance. */
5639#define ALT_CAN1_MSGHAND_MOVALA_ADDR ALT_CAN_MSGHAND_MOVALA_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5640/* The address of the ALT_CAN_MSGHAND_MOVALB register for the ALT_CAN1_MSGHANDGRP instance. */
5641#define ALT_CAN1_MSGHAND_MOVALB_ADDR ALT_CAN_MSGHAND_MOVALB_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5642/* The address of the ALT_CAN_MSGHAND_MOVALC register for the ALT_CAN1_MSGHANDGRP instance. */
5643#define ALT_CAN1_MSGHAND_MOVALC_ADDR ALT_CAN_MSGHAND_MOVALC_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5644/* The address of the ALT_CAN_MSGHAND_MOVALD register for the ALT_CAN1_MSGHANDGRP instance. */
5645#define ALT_CAN1_MSGHAND_MOVALD_ADDR ALT_CAN_MSGHAND_MOVALD_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5646/* The base address byte offset for the start of the ALT_CAN1_MSGHANDGRP component. */
5647#define ALT_CAN1_MSGHANDGRP_OFST 0x84
5648/* The start address of the ALT_CAN1_MSGHANDGRP component. */
5649#define ALT_CAN1_MSGHANDGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CAN1_ADDR) + ALT_CAN1_MSGHANDGRP_OFST))
5650/* The lower bound address range of the ALT_CAN1_MSGHANDGRP component. */
5651#define ALT_CAN1_MSGHANDGRP_LB_ADDR ALT_CAN1_MSGHANDGRP_ADDR
5652/* The upper bound address range of the ALT_CAN1_MSGHANDGRP component. */
5653#define ALT_CAN1_MSGHANDGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN1_MSGHANDGRP_ADDR) + 0x50) - 1))
5654
5655
5656/*
5657 * Register Group Instance : msgifgrp
5658 *
5659 * Instance msgifgrp of register group ALT_CAN_MSGIF.
5660 *
5661 *
5662 */
5663/* The address of the ALT_CAN_MSGIF_IF1CMR register for the ALT_CAN1_MSGIFGRP instance. */
5664#define ALT_CAN1_MSGIF_IF1CMR_ADDR ALT_CAN_MSGIF_IF1CMR_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5665/* The address of the ALT_CAN_MSGIF_IF1MSK register for the ALT_CAN1_MSGIFGRP instance. */
5666#define ALT_CAN1_MSGIF_IF1MSK_ADDR ALT_CAN_MSGIF_IF1MSK_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5667/* The address of the ALT_CAN_MSGIF_IF1ARB register for the ALT_CAN1_MSGIFGRP instance. */
5668#define ALT_CAN1_MSGIF_IF1ARB_ADDR ALT_CAN_MSGIF_IF1ARB_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5669/* The address of the ALT_CAN_MSGIF_IF1MCTR register for the ALT_CAN1_MSGIFGRP instance. */
5670#define ALT_CAN1_MSGIF_IF1MCTR_ADDR ALT_CAN_MSGIF_IF1MCTR_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5671/* The address of the ALT_CAN_MSGIF_IF1DA register for the ALT_CAN1_MSGIFGRP instance. */
5672#define ALT_CAN1_MSGIF_IF1DA_ADDR ALT_CAN_MSGIF_IF1DA_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5673/* The address of the ALT_CAN_MSGIF_IF1DB register for the ALT_CAN1_MSGIFGRP instance. */
5674#define ALT_CAN1_MSGIF_IF1DB_ADDR ALT_CAN_MSGIF_IF1DB_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5675/* The address of the ALT_CAN_MSGIF_IF2CMR register for the ALT_CAN1_MSGIFGRP instance. */
5676#define ALT_CAN1_MSGIF_IF2CMR_ADDR ALT_CAN_MSGIF_IF2CMR_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5677/* The address of the ALT_CAN_MSGIF_IF2MSK register for the ALT_CAN1_MSGIFGRP instance. */
5678#define ALT_CAN1_MSGIF_IF2MSK_ADDR ALT_CAN_MSGIF_IF2MSK_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5679/* The address of the ALT_CAN_MSGIF_IF2ARB register for the ALT_CAN1_MSGIFGRP instance. */
5680#define ALT_CAN1_MSGIF_IF2ARB_ADDR ALT_CAN_MSGIF_IF2ARB_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5681/* The address of the ALT_CAN_MSGIF_IF2MCTR register for the ALT_CAN1_MSGIFGRP instance. */
5682#define ALT_CAN1_MSGIF_IF2MCTR_ADDR ALT_CAN_MSGIF_IF2MCTR_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5683/* The address of the ALT_CAN_MSGIF_IF2DA register for the ALT_CAN1_MSGIFGRP instance. */
5684#define ALT_CAN1_MSGIF_IF2DA_ADDR ALT_CAN_MSGIF_IF2DA_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5685/* The address of the ALT_CAN_MSGIF_IF2DB register for the ALT_CAN1_MSGIFGRP instance. */
5686#define ALT_CAN1_MSGIF_IF2DB_ADDR ALT_CAN_MSGIF_IF2DB_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5687/* The base address byte offset for the start of the ALT_CAN1_MSGIFGRP component. */
5688#define ALT_CAN1_MSGIFGRP_OFST 0x100
5689/* The start address of the ALT_CAN1_MSGIFGRP component. */
5690#define ALT_CAN1_MSGIFGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CAN1_ADDR) + ALT_CAN1_MSGIFGRP_OFST))
5691/* The lower bound address range of the ALT_CAN1_MSGIFGRP component. */
5692#define ALT_CAN1_MSGIFGRP_LB_ADDR ALT_CAN1_MSGIFGRP_ADDR
5693/* The upper bound address range of the ALT_CAN1_MSGIFGRP component. */
5694#define ALT_CAN1_MSGIFGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN1_MSGIFGRP_ADDR) + 0x38) - 1))
5695
5696
5697/* The base address byte offset for the start of the ALT_CAN1 component. */
5698#define ALT_CAN1_OFST 0xffc01000
5699/* The start address of the ALT_CAN1 component. */
5700#define ALT_CAN1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_CAN1_OFST))
5701/* The lower bound address range of the ALT_CAN1 component. */
5702#define ALT_CAN1_LB_ADDR ALT_CAN1_ADDR
5703/* The upper bound address range of the ALT_CAN1 component. */
5704#define ALT_CAN1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN1_ADDR) + 0x200) - 1))
5705
5706
5707/*
5708 * Component Instance : uart0
5709 *
5710 * Instance uart0 of component ALT_UART.
5711 *
5712 *
5713 */
5714/* The address of the ALT_UART_RBR_THR_DLL register for the ALT_UART0 instance. */
5715#define ALT_UART0_RBR_THR_DLL_ADDR ALT_UART_RBR_THR_DLL_ADDR(ALT_UART0_ADDR)
5716/* The address of the ALT_UART_IER_DLH register for the ALT_UART0 instance. */
5717#define ALT_UART0_IER_DLH_ADDR ALT_UART_IER_DLH_ADDR(ALT_UART0_ADDR)
5718/* The address of the ALT_UART_IIR register for the ALT_UART0 instance. */
5719#define ALT_UART0_IIR_ADDR ALT_UART_IIR_ADDR(ALT_UART0_ADDR)
5720/* The address of the ALT_UART_FCR register for the ALT_UART0 instance. */
5721#define ALT_UART0_FCR_ADDR ALT_UART_FCR_ADDR(ALT_UART0_ADDR)
5722/* The address of the ALT_UART_LCR register for the ALT_UART0 instance. */
5723#define ALT_UART0_LCR_ADDR ALT_UART_LCR_ADDR(ALT_UART0_ADDR)
5724/* The address of the ALT_UART_MCR register for the ALT_UART0 instance. */
5725#define ALT_UART0_MCR_ADDR ALT_UART_MCR_ADDR(ALT_UART0_ADDR)
5726/* The address of the ALT_UART_LSR register for the ALT_UART0 instance. */
5727#define ALT_UART0_LSR_ADDR ALT_UART_LSR_ADDR(ALT_UART0_ADDR)
5728/* The address of the ALT_UART_MSR register for the ALT_UART0 instance. */
5729#define ALT_UART0_MSR_ADDR ALT_UART_MSR_ADDR(ALT_UART0_ADDR)
5730/* The address of the ALT_UART_SCR register for the ALT_UART0 instance. */
5731#define ALT_UART0_SCR_ADDR ALT_UART_SCR_ADDR(ALT_UART0_ADDR)
5732/* The address of the ALT_UART_SRBR register for the ALT_UART0 instance. */
5733#define ALT_UART0_SRBR_ADDR ALT_UART_SRBR_ADDR(ALT_UART0_ADDR)
5734/* The address of the ALT_UART_STHR register for the ALT_UART0 instance. */
5735#define ALT_UART0_STHR_ADDR ALT_UART_STHR_ADDR(ALT_UART0_ADDR)
5736/* The address of the ALT_UART_FAR register for the ALT_UART0 instance. */
5737#define ALT_UART0_FAR_ADDR ALT_UART_FAR_ADDR(ALT_UART0_ADDR)
5738/* The address of the ALT_UART_TFR register for the ALT_UART0 instance. */
5739#define ALT_UART0_TFR_ADDR ALT_UART_TFR_ADDR(ALT_UART0_ADDR)
5740/* The address of the ALT_UART_RFW register for the ALT_UART0 instance. */
5741#define ALT_UART0_RFW_ADDR ALT_UART_RFW_ADDR(ALT_UART0_ADDR)
5742/* The address of the ALT_UART_USR register for the ALT_UART0 instance. */
5743#define ALT_UART0_USR_ADDR ALT_UART_USR_ADDR(ALT_UART0_ADDR)
5744/* The address of the ALT_UART_TFL register for the ALT_UART0 instance. */
5745#define ALT_UART0_TFL_ADDR ALT_UART_TFL_ADDR(ALT_UART0_ADDR)
5746/* The address of the ALT_UART_RFL register for the ALT_UART0 instance. */
5747#define ALT_UART0_RFL_ADDR ALT_UART_RFL_ADDR(ALT_UART0_ADDR)
5748/* The address of the ALT_UART_SRR register for the ALT_UART0 instance. */
5749#define ALT_UART0_SRR_ADDR ALT_UART_SRR_ADDR(ALT_UART0_ADDR)
5750/* The address of the ALT_UART_SRTS register for the ALT_UART0 instance. */
5751#define ALT_UART0_SRTS_ADDR ALT_UART_SRTS_ADDR(ALT_UART0_ADDR)
5752/* The address of the ALT_UART_SBCR register for the ALT_UART0 instance. */
5753#define ALT_UART0_SBCR_ADDR ALT_UART_SBCR_ADDR(ALT_UART0_ADDR)
5754/* The address of the ALT_UART_SDMAM register for the ALT_UART0 instance. */
5755#define ALT_UART0_SDMAM_ADDR ALT_UART_SDMAM_ADDR(ALT_UART0_ADDR)
5756/* The address of the ALT_UART_SFE register for the ALT_UART0 instance. */
5757#define ALT_UART0_SFE_ADDR ALT_UART_SFE_ADDR(ALT_UART0_ADDR)
5758/* The address of the ALT_UART_SRT register for the ALT_UART0 instance. */
5759#define ALT_UART0_SRT_ADDR ALT_UART_SRT_ADDR(ALT_UART0_ADDR)
5760/* The address of the ALT_UART_STET register for the ALT_UART0 instance. */
5761#define ALT_UART0_STET_ADDR ALT_UART_STET_ADDR(ALT_UART0_ADDR)
5762/* The address of the ALT_UART_HTX register for the ALT_UART0 instance. */
5763#define ALT_UART0_HTX_ADDR ALT_UART_HTX_ADDR(ALT_UART0_ADDR)
5764/* The address of the ALT_UART_DMASA register for the ALT_UART0 instance. */
5765#define ALT_UART0_DMASA_ADDR ALT_UART_DMASA_ADDR(ALT_UART0_ADDR)
5766/* The address of the ALT_UART_CPR register for the ALT_UART0 instance. */
5767#define ALT_UART0_CPR_ADDR ALT_UART_CPR_ADDR(ALT_UART0_ADDR)
5768/* The address of the ALT_UART_UCV register for the ALT_UART0 instance. */
5769#define ALT_UART0_UCV_ADDR ALT_UART_UCV_ADDR(ALT_UART0_ADDR)
5770/* The address of the ALT_UART_CTR register for the ALT_UART0 instance. */
5771#define ALT_UART0_CTR_ADDR ALT_UART_CTR_ADDR(ALT_UART0_ADDR)
5772/* The base address byte offset for the start of the ALT_UART0 component. */
5773#define ALT_UART0_OFST 0xffc02000
5774/* The start address of the ALT_UART0 component. */
5775#define ALT_UART0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_UART0_OFST))
5776/* The lower bound address range of the ALT_UART0 component. */
5777#define ALT_UART0_LB_ADDR ALT_UART0_ADDR
5778/* The upper bound address range of the ALT_UART0 component. */
5779#define ALT_UART0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_UART0_ADDR) + 0x100) - 1))
5780
5781
5782/*
5783 * Component Instance : uart1
5784 *
5785 * Instance uart1 of component ALT_UART.
5786 *
5787 *
5788 */
5789/* The address of the ALT_UART_RBR_THR_DLL register for the ALT_UART1 instance. */
5790#define ALT_UART1_RBR_THR_DLL_ADDR ALT_UART_RBR_THR_DLL_ADDR(ALT_UART1_ADDR)
5791/* The address of the ALT_UART_IER_DLH register for the ALT_UART1 instance. */
5792#define ALT_UART1_IER_DLH_ADDR ALT_UART_IER_DLH_ADDR(ALT_UART1_ADDR)
5793/* The address of the ALT_UART_IIR register for the ALT_UART1 instance. */
5794#define ALT_UART1_IIR_ADDR ALT_UART_IIR_ADDR(ALT_UART1_ADDR)
5795/* The address of the ALT_UART_FCR register for the ALT_UART1 instance. */
5796#define ALT_UART1_FCR_ADDR ALT_UART_FCR_ADDR(ALT_UART1_ADDR)
5797/* The address of the ALT_UART_LCR register for the ALT_UART1 instance. */
5798#define ALT_UART1_LCR_ADDR ALT_UART_LCR_ADDR(ALT_UART1_ADDR)
5799/* The address of the ALT_UART_MCR register for the ALT_UART1 instance. */
5800#define ALT_UART1_MCR_ADDR ALT_UART_MCR_ADDR(ALT_UART1_ADDR)
5801/* The address of the ALT_UART_LSR register for the ALT_UART1 instance. */
5802#define ALT_UART1_LSR_ADDR ALT_UART_LSR_ADDR(ALT_UART1_ADDR)
5803/* The address of the ALT_UART_MSR register for the ALT_UART1 instance. */
5804#define ALT_UART1_MSR_ADDR ALT_UART_MSR_ADDR(ALT_UART1_ADDR)
5805/* The address of the ALT_UART_SCR register for the ALT_UART1 instance. */
5806#define ALT_UART1_SCR_ADDR ALT_UART_SCR_ADDR(ALT_UART1_ADDR)
5807/* The address of the ALT_UART_SRBR register for the ALT_UART1 instance. */
5808#define ALT_UART1_SRBR_ADDR ALT_UART_SRBR_ADDR(ALT_UART1_ADDR)
5809/* The address of the ALT_UART_STHR register for the ALT_UART1 instance. */
5810#define ALT_UART1_STHR_ADDR ALT_UART_STHR_ADDR(ALT_UART1_ADDR)
5811/* The address of the ALT_UART_FAR register for the ALT_UART1 instance. */
5812#define ALT_UART1_FAR_ADDR ALT_UART_FAR_ADDR(ALT_UART1_ADDR)
5813/* The address of the ALT_UART_TFR register for the ALT_UART1 instance. */
5814#define ALT_UART1_TFR_ADDR ALT_UART_TFR_ADDR(ALT_UART1_ADDR)
5815/* The address of the ALT_UART_RFW register for the ALT_UART1 instance. */
5816#define ALT_UART1_RFW_ADDR ALT_UART_RFW_ADDR(ALT_UART1_ADDR)
5817/* The address of the ALT_UART_USR register for the ALT_UART1 instance. */
5818#define ALT_UART1_USR_ADDR ALT_UART_USR_ADDR(ALT_UART1_ADDR)
5819/* The address of the ALT_UART_TFL register for the ALT_UART1 instance. */
5820#define ALT_UART1_TFL_ADDR ALT_UART_TFL_ADDR(ALT_UART1_ADDR)
5821/* The address of the ALT_UART_RFL register for the ALT_UART1 instance. */
5822#define ALT_UART1_RFL_ADDR ALT_UART_RFL_ADDR(ALT_UART1_ADDR)
5823/* The address of the ALT_UART_SRR register for the ALT_UART1 instance. */
5824#define ALT_UART1_SRR_ADDR ALT_UART_SRR_ADDR(ALT_UART1_ADDR)
5825/* The address of the ALT_UART_SRTS register for the ALT_UART1 instance. */
5826#define ALT_UART1_SRTS_ADDR ALT_UART_SRTS_ADDR(ALT_UART1_ADDR)
5827/* The address of the ALT_UART_SBCR register for the ALT_UART1 instance. */
5828#define ALT_UART1_SBCR_ADDR ALT_UART_SBCR_ADDR(ALT_UART1_ADDR)
5829/* The address of the ALT_UART_SDMAM register for the ALT_UART1 instance. */
5830#define ALT_UART1_SDMAM_ADDR ALT_UART_SDMAM_ADDR(ALT_UART1_ADDR)
5831/* The address of the ALT_UART_SFE register for the ALT_UART1 instance. */
5832#define ALT_UART1_SFE_ADDR ALT_UART_SFE_ADDR(ALT_UART1_ADDR)
5833/* The address of the ALT_UART_SRT register for the ALT_UART1 instance. */
5834#define ALT_UART1_SRT_ADDR ALT_UART_SRT_ADDR(ALT_UART1_ADDR)
5835/* The address of the ALT_UART_STET register for the ALT_UART1 instance. */
5836#define ALT_UART1_STET_ADDR ALT_UART_STET_ADDR(ALT_UART1_ADDR)
5837/* The address of the ALT_UART_HTX register for the ALT_UART1 instance. */
5838#define ALT_UART1_HTX_ADDR ALT_UART_HTX_ADDR(ALT_UART1_ADDR)
5839/* The address of the ALT_UART_DMASA register for the ALT_UART1 instance. */
5840#define ALT_UART1_DMASA_ADDR ALT_UART_DMASA_ADDR(ALT_UART1_ADDR)
5841/* The address of the ALT_UART_CPR register for the ALT_UART1 instance. */
5842#define ALT_UART1_CPR_ADDR ALT_UART_CPR_ADDR(ALT_UART1_ADDR)
5843/* The address of the ALT_UART_UCV register for the ALT_UART1 instance. */
5844#define ALT_UART1_UCV_ADDR ALT_UART_UCV_ADDR(ALT_UART1_ADDR)
5845/* The address of the ALT_UART_CTR register for the ALT_UART1 instance. */
5846#define ALT_UART1_CTR_ADDR ALT_UART_CTR_ADDR(ALT_UART1_ADDR)
5847/* The base address byte offset for the start of the ALT_UART1 component. */
5848#define ALT_UART1_OFST 0xffc03000
5849/* The start address of the ALT_UART1 component. */
5850#define ALT_UART1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_UART1_OFST))
5851/* The lower bound address range of the ALT_UART1 component. */
5852#define ALT_UART1_LB_ADDR ALT_UART1_ADDR
5853/* The upper bound address range of the ALT_UART1 component. */
5854#define ALT_UART1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_UART1_ADDR) + 0x100) - 1))
5855
5856
5857/*
5858 * Component Instance : i2c0
5859 *
5860 * Instance i2c0 of component ALT_I2C.
5861 *
5862 *
5863 */
5864/* The address of the ALT_I2C_CON register for the ALT_I2C0 instance. */
5865#define ALT_I2C0_IC_CON_ADDR ALT_I2C_CON_ADDR(ALT_I2C0_ADDR)
5866/* The address of the ALT_I2C_TAR register for the ALT_I2C0 instance. */
5867#define ALT_I2C0_IC_TAR_ADDR ALT_I2C_TAR_ADDR(ALT_I2C0_ADDR)
5868/* The address of the ALT_I2C_SAR register for the ALT_I2C0 instance. */
5869#define ALT_I2C0_IC_SAR_ADDR ALT_I2C_SAR_ADDR(ALT_I2C0_ADDR)
5870/* The address of the ALT_I2C_DATA_CMD register for the ALT_I2C0 instance. */
5871#define ALT_I2C0_IC_DATA_CMD_ADDR ALT_I2C_DATA_CMD_ADDR(ALT_I2C0_ADDR)
5872/* The address of the ALT_I2C_SS_SCL_HCNT register for the ALT_I2C0 instance. */
5873#define ALT_I2C0_IC_SS_SCL_HCNT_ADDR ALT_I2C_SS_SCL_HCNT_ADDR(ALT_I2C0_ADDR)
5874/* The address of the ALT_I2C_SS_SCL_LCNT register for the ALT_I2C0 instance. */
5875#define ALT_I2C0_IC_SS_SCL_LCNT_ADDR ALT_I2C_SS_SCL_LCNT_ADDR(ALT_I2C0_ADDR)
5876/* The address of the ALT_I2C_FS_SCL_HCNT register for the ALT_I2C0 instance. */
5877#define ALT_I2C0_IC_FS_SCL_HCNT_ADDR ALT_I2C_FS_SCL_HCNT_ADDR(ALT_I2C0_ADDR)
5878/* The address of the ALT_I2C_FS_SCL_LCNT register for the ALT_I2C0 instance. */
5879#define ALT_I2C0_IC_FS_SCL_LCNT_ADDR ALT_I2C_FS_SCL_LCNT_ADDR(ALT_I2C0_ADDR)
5880/* The address of the ALT_I2C_INTR_STAT register for the ALT_I2C0 instance. */
5881#define ALT_I2C0_IC_INTR_STAT_ADDR ALT_I2C_INTR_STAT_ADDR(ALT_I2C0_ADDR)
5882/* The address of the ALT_I2C_INTR_MSK register for the ALT_I2C0 instance. */
5883#define ALT_I2C0_IC_INTR_MSK_ADDR ALT_I2C_INTR_MSK_ADDR(ALT_I2C0_ADDR)
5884/* The address of the ALT_I2C_RAW_INTR_STAT register for the ALT_I2C0 instance. */
5885#define ALT_I2C0_IC_RAW_INTR_STAT_ADDR ALT_I2C_RAW_INTR_STAT_ADDR(ALT_I2C0_ADDR)
5886/* The address of the ALT_I2C_RX_TL register for the ALT_I2C0 instance. */
5887#define ALT_I2C0_IC_RX_TL_ADDR ALT_I2C_RX_TL_ADDR(ALT_I2C0_ADDR)
5888/* The address of the ALT_I2C_TX_TL register for the ALT_I2C0 instance. */
5889#define ALT_I2C0_IC_TX_TL_ADDR ALT_I2C_TX_TL_ADDR(ALT_I2C0_ADDR)
5890/* The address of the ALT_I2C_CLR_INTR register for the ALT_I2C0 instance. */
5891#define ALT_I2C0_IC_CLR_INTR_ADDR ALT_I2C_CLR_INTR_ADDR(ALT_I2C0_ADDR)
5892/* The address of the ALT_I2C_CLR_RX_UNDER register for the ALT_I2C0 instance. */
5893#define ALT_I2C0_IC_CLR_RX_UNDER_ADDR ALT_I2C_CLR_RX_UNDER_ADDR(ALT_I2C0_ADDR)
5894/* The address of the ALT_I2C_CLR_RX_OVER register for the ALT_I2C0 instance. */
5895#define ALT_I2C0_IC_CLR_RX_OVER_ADDR ALT_I2C_CLR_RX_OVER_ADDR(ALT_I2C0_ADDR)
5896/* The address of the ALT_I2C_CLR_TX_OVER register for the ALT_I2C0 instance. */
5897#define ALT_I2C0_IC_CLR_TX_OVER_ADDR ALT_I2C_CLR_TX_OVER_ADDR(ALT_I2C0_ADDR)
5898/* The address of the ALT_I2C_CLR_RD_REQ register for the ALT_I2C0 instance. */
5899#define ALT_I2C0_IC_CLR_RD_REQ_ADDR ALT_I2C_CLR_RD_REQ_ADDR(ALT_I2C0_ADDR)
5900/* The address of the ALT_I2C_CLR_TX_ABRT register for the ALT_I2C0 instance. */
5901#define ALT_I2C0_IC_CLR_TX_ABRT_ADDR ALT_I2C_CLR_TX_ABRT_ADDR(ALT_I2C0_ADDR)
5902/* The address of the ALT_I2C_CLR_RX_DONE register for the ALT_I2C0 instance. */
5903#define ALT_I2C0_IC_CLR_RX_DONE_ADDR ALT_I2C_CLR_RX_DONE_ADDR(ALT_I2C0_ADDR)
5904/* The address of the ALT_I2C_CLR_ACTIVITY register for the ALT_I2C0 instance. */
5905#define ALT_I2C0_IC_CLR_ACTIVITY_ADDR ALT_I2C_CLR_ACTIVITY_ADDR(ALT_I2C0_ADDR)
5906/* The address of the ALT_I2C_CLR_STOP_DET register for the ALT_I2C0 instance. */
5907#define ALT_I2C0_IC_CLR_STOP_DET_ADDR ALT_I2C_CLR_STOP_DET_ADDR(ALT_I2C0_ADDR)
5908/* The address of the ALT_I2C_CLR_START_DET register for the ALT_I2C0 instance. */
5909#define ALT_I2C0_IC_CLR_START_DET_ADDR ALT_I2C_CLR_START_DET_ADDR(ALT_I2C0_ADDR)
5910/* The address of the ALT_I2C_CLR_GEN_CALL register for the ALT_I2C0 instance. */
5911#define ALT_I2C0_IC_CLR_GEN_CALL_ADDR ALT_I2C_CLR_GEN_CALL_ADDR(ALT_I2C0_ADDR)
5912/* The address of the ALT_I2C_EN register for the ALT_I2C0 instance. */
5913#define ALT_I2C0_IC_EN_ADDR ALT_I2C_EN_ADDR(ALT_I2C0_ADDR)
5914/* The address of the ALT_I2C_STAT register for the ALT_I2C0 instance. */
5915#define ALT_I2C0_IC_STAT_ADDR ALT_I2C_STAT_ADDR(ALT_I2C0_ADDR)
5916/* The address of the ALT_I2C_TXFLR register for the ALT_I2C0 instance. */
5917#define ALT_I2C0_IC_TXFLR_ADDR ALT_I2C_TXFLR_ADDR(ALT_I2C0_ADDR)
5918/* The address of the ALT_I2C_RXFLR register for the ALT_I2C0 instance. */
5919#define ALT_I2C0_IC_RXFLR_ADDR ALT_I2C_RXFLR_ADDR(ALT_I2C0_ADDR)
5920/* The address of the ALT_I2C_SDA_HOLD register for the ALT_I2C0 instance. */
5921#define ALT_I2C0_IC_SDA_HOLD_ADDR ALT_I2C_SDA_HOLD_ADDR(ALT_I2C0_ADDR)
5922/* The address of the ALT_I2C_TX_ABRT_SRC register for the ALT_I2C0 instance. */
5923#define ALT_I2C0_IC_TX_ABRT_SRC_ADDR ALT_I2C_TX_ABRT_SRC_ADDR(ALT_I2C0_ADDR)
5924/* The address of the ALT_I2C_SLV_DATA_NACK_ONLY register for the ALT_I2C0 instance. */
5925#define ALT_I2C0_IC_SLV_DATA_NACK_ONLY_ADDR ALT_I2C_SLV_DATA_NACK_ONLY_ADDR(ALT_I2C0_ADDR)
5926/* The address of the ALT_I2C_DMA_CR register for the ALT_I2C0 instance. */
5927#define ALT_I2C0_IC_DMA_CR_ADDR ALT_I2C_DMA_CR_ADDR(ALT_I2C0_ADDR)
5928/* The address of the ALT_I2C_DMA_TDLR register for the ALT_I2C0 instance. */
5929#define ALT_I2C0_IC_DMA_TDLR_ADDR ALT_I2C_DMA_TDLR_ADDR(ALT_I2C0_ADDR)
5930/* The address of the ALT_I2C_DMA_RDLR register for the ALT_I2C0 instance. */
5931#define ALT_I2C0_IC_DMA_RDLR_ADDR ALT_I2C_DMA_RDLR_ADDR(ALT_I2C0_ADDR)
5932/* The address of the ALT_I2C_SDA_SETUP register for the ALT_I2C0 instance. */
5933#define ALT_I2C0_IC_SDA_SETUP_ADDR ALT_I2C_SDA_SETUP_ADDR(ALT_I2C0_ADDR)
5934/* The address of the ALT_I2C_ACK_GENERAL_CALL register for the ALT_I2C0 instance. */
5935#define ALT_I2C0_IC_ACK_GENERAL_CALL_ADDR ALT_I2C_ACK_GENERAL_CALL_ADDR(ALT_I2C0_ADDR)
5936/* The address of the ALT_I2C_EN_STAT register for the ALT_I2C0 instance. */
5937#define ALT_I2C0_IC_EN_STAT_ADDR ALT_I2C_EN_STAT_ADDR(ALT_I2C0_ADDR)
5938/* The address of the ALT_I2C_FS_SPKLEN register for the ALT_I2C0 instance. */
5939#define ALT_I2C0_IC_FS_SPKLEN_ADDR ALT_I2C_FS_SPKLEN_ADDR(ALT_I2C0_ADDR)
5940/* The address of the ALT_I2C_COMP_PARAM_1 register for the ALT_I2C0 instance. */
5941#define ALT_I2C0_IC_COMP_PARAM_1_ADDR ALT_I2C_COMP_PARAM_1_ADDR(ALT_I2C0_ADDR)
5942/* The address of the ALT_I2C_COMP_VER register for the ALT_I2C0 instance. */
5943#define ALT_I2C0_IC_COMP_VER_ADDR ALT_I2C_COMP_VER_ADDR(ALT_I2C0_ADDR)
5944/* The address of the ALT_I2C_COMP_TYPE register for the ALT_I2C0 instance. */
5945#define ALT_I2C0_IC_COMP_TYPE_ADDR ALT_I2C_COMP_TYPE_ADDR(ALT_I2C0_ADDR)
5946/* The base address byte offset for the start of the ALT_I2C0 component. */
5947#define ALT_I2C0_OFST 0xffc04000
5948/* The start address of the ALT_I2C0 component. */
5949#define ALT_I2C0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_I2C0_OFST))
5950/* The lower bound address range of the ALT_I2C0 component. */
5951#define ALT_I2C0_LB_ADDR ALT_I2C0_ADDR
5952/* The upper bound address range of the ALT_I2C0 component. */
5953#define ALT_I2C0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_I2C0_ADDR) + 0x100) - 1))
5954
5955
5956/*
5957 * Component Instance : i2c1
5958 *
5959 * Instance i2c1 of component ALT_I2C.
5960 *
5961 *
5962 */
5963/* The address of the ALT_I2C_CON register for the ALT_I2C1 instance. */
5964#define ALT_I2C1_IC_CON_ADDR ALT_I2C_CON_ADDR(ALT_I2C1_ADDR)
5965/* The address of the ALT_I2C_TAR register for the ALT_I2C1 instance. */
5966#define ALT_I2C1_IC_TAR_ADDR ALT_I2C_TAR_ADDR(ALT_I2C1_ADDR)
5967/* The address of the ALT_I2C_SAR register for the ALT_I2C1 instance. */
5968#define ALT_I2C1_IC_SAR_ADDR ALT_I2C_SAR_ADDR(ALT_I2C1_ADDR)
5969/* The address of the ALT_I2C_DATA_CMD register for the ALT_I2C1 instance. */
5970#define ALT_I2C1_IC_DATA_CMD_ADDR ALT_I2C_DATA_CMD_ADDR(ALT_I2C1_ADDR)
5971/* The address of the ALT_I2C_SS_SCL_HCNT register for the ALT_I2C1 instance. */
5972#define ALT_I2C1_IC_SS_SCL_HCNT_ADDR ALT_I2C_SS_SCL_HCNT_ADDR(ALT_I2C1_ADDR)
5973/* The address of the ALT_I2C_SS_SCL_LCNT register for the ALT_I2C1 instance. */
5974#define ALT_I2C1_IC_SS_SCL_LCNT_ADDR ALT_I2C_SS_SCL_LCNT_ADDR(ALT_I2C1_ADDR)
5975/* The address of the ALT_I2C_FS_SCL_HCNT register for the ALT_I2C1 instance. */
5976#define ALT_I2C1_IC_FS_SCL_HCNT_ADDR ALT_I2C_FS_SCL_HCNT_ADDR(ALT_I2C1_ADDR)
5977/* The address of the ALT_I2C_FS_SCL_LCNT register for the ALT_I2C1 instance. */
5978#define ALT_I2C1_IC_FS_SCL_LCNT_ADDR ALT_I2C_FS_SCL_LCNT_ADDR(ALT_I2C1_ADDR)
5979/* The address of the ALT_I2C_INTR_STAT register for the ALT_I2C1 instance. */
5980#define ALT_I2C1_IC_INTR_STAT_ADDR ALT_I2C_INTR_STAT_ADDR(ALT_I2C1_ADDR)
5981/* The address of the ALT_I2C_INTR_MSK register for the ALT_I2C1 instance. */
5982#define ALT_I2C1_IC_INTR_MSK_ADDR ALT_I2C_INTR_MSK_ADDR(ALT_I2C1_ADDR)
5983/* The address of the ALT_I2C_RAW_INTR_STAT register for the ALT_I2C1 instance. */
5984#define ALT_I2C1_IC_RAW_INTR_STAT_ADDR ALT_I2C_RAW_INTR_STAT_ADDR(ALT_I2C1_ADDR)
5985/* The address of the ALT_I2C_RX_TL register for the ALT_I2C1 instance. */
5986#define ALT_I2C1_IC_RX_TL_ADDR ALT_I2C_RX_TL_ADDR(ALT_I2C1_ADDR)
5987/* The address of the ALT_I2C_TX_TL register for the ALT_I2C1 instance. */
5988#define ALT_I2C1_IC_TX_TL_ADDR ALT_I2C_TX_TL_ADDR(ALT_I2C1_ADDR)
5989/* The address of the ALT_I2C_CLR_INTR register for the ALT_I2C1 instance. */
5990#define ALT_I2C1_IC_CLR_INTR_ADDR ALT_I2C_CLR_INTR_ADDR(ALT_I2C1_ADDR)
5991/* The address of the ALT_I2C_CLR_RX_UNDER register for the ALT_I2C1 instance. */
5992#define ALT_I2C1_IC_CLR_RX_UNDER_ADDR ALT_I2C_CLR_RX_UNDER_ADDR(ALT_I2C1_ADDR)
5993/* The address of the ALT_I2C_CLR_RX_OVER register for the ALT_I2C1 instance. */
5994#define ALT_I2C1_IC_CLR_RX_OVER_ADDR ALT_I2C_CLR_RX_OVER_ADDR(ALT_I2C1_ADDR)
5995/* The address of the ALT_I2C_CLR_TX_OVER register for the ALT_I2C1 instance. */
5996#define ALT_I2C1_IC_CLR_TX_OVER_ADDR ALT_I2C_CLR_TX_OVER_ADDR(ALT_I2C1_ADDR)
5997/* The address of the ALT_I2C_CLR_RD_REQ register for the ALT_I2C1 instance. */
5998#define ALT_I2C1_IC_CLR_RD_REQ_ADDR ALT_I2C_CLR_RD_REQ_ADDR(ALT_I2C1_ADDR)
5999/* The address of the ALT_I2C_CLR_TX_ABRT register for the ALT_I2C1 instance. */
6000#define ALT_I2C1_IC_CLR_TX_ABRT_ADDR ALT_I2C_CLR_TX_ABRT_ADDR(ALT_I2C1_ADDR)
6001/* The address of the ALT_I2C_CLR_RX_DONE register for the ALT_I2C1 instance. */
6002#define ALT_I2C1_IC_CLR_RX_DONE_ADDR ALT_I2C_CLR_RX_DONE_ADDR(ALT_I2C1_ADDR)
6003/* The address of the ALT_I2C_CLR_ACTIVITY register for the ALT_I2C1 instance. */
6004#define ALT_I2C1_IC_CLR_ACTIVITY_ADDR ALT_I2C_CLR_ACTIVITY_ADDR(ALT_I2C1_ADDR)
6005/* The address of the ALT_I2C_CLR_STOP_DET register for the ALT_I2C1 instance. */
6006#define ALT_I2C1_IC_CLR_STOP_DET_ADDR ALT_I2C_CLR_STOP_DET_ADDR(ALT_I2C1_ADDR)
6007/* The address of the ALT_I2C_CLR_START_DET register for the ALT_I2C1 instance. */
6008#define ALT_I2C1_IC_CLR_START_DET_ADDR ALT_I2C_CLR_START_DET_ADDR(ALT_I2C1_ADDR)
6009/* The address of the ALT_I2C_CLR_GEN_CALL register for the ALT_I2C1 instance. */
6010#define ALT_I2C1_IC_CLR_GEN_CALL_ADDR ALT_I2C_CLR_GEN_CALL_ADDR(ALT_I2C1_ADDR)
6011/* The address of the ALT_I2C_EN register for the ALT_I2C1 instance. */
6012#define ALT_I2C1_IC_EN_ADDR ALT_I2C_EN_ADDR(ALT_I2C1_ADDR)
6013/* The address of the ALT_I2C_STAT register for the ALT_I2C1 instance. */
6014#define ALT_I2C1_IC_STAT_ADDR ALT_I2C_STAT_ADDR(ALT_I2C1_ADDR)
6015/* The address of the ALT_I2C_TXFLR register for the ALT_I2C1 instance. */
6016#define ALT_I2C1_IC_TXFLR_ADDR ALT_I2C_TXFLR_ADDR(ALT_I2C1_ADDR)
6017/* The address of the ALT_I2C_RXFLR register for the ALT_I2C1 instance. */
6018#define ALT_I2C1_IC_RXFLR_ADDR ALT_I2C_RXFLR_ADDR(ALT_I2C1_ADDR)
6019/* The address of the ALT_I2C_SDA_HOLD register for the ALT_I2C1 instance. */
6020#define ALT_I2C1_IC_SDA_HOLD_ADDR ALT_I2C_SDA_HOLD_ADDR(ALT_I2C1_ADDR)
6021/* The address of the ALT_I2C_TX_ABRT_SRC register for the ALT_I2C1 instance. */
6022#define ALT_I2C1_IC_TX_ABRT_SRC_ADDR ALT_I2C_TX_ABRT_SRC_ADDR(ALT_I2C1_ADDR)
6023/* The address of the ALT_I2C_SLV_DATA_NACK_ONLY register for the ALT_I2C1 instance. */
6024#define ALT_I2C1_IC_SLV_DATA_NACK_ONLY_ADDR ALT_I2C_SLV_DATA_NACK_ONLY_ADDR(ALT_I2C1_ADDR)
6025/* The address of the ALT_I2C_DMA_CR register for the ALT_I2C1 instance. */
6026#define ALT_I2C1_IC_DMA_CR_ADDR ALT_I2C_DMA_CR_ADDR(ALT_I2C1_ADDR)
6027/* The address of the ALT_I2C_DMA_TDLR register for the ALT_I2C1 instance. */
6028#define ALT_I2C1_IC_DMA_TDLR_ADDR ALT_I2C_DMA_TDLR_ADDR(ALT_I2C1_ADDR)
6029/* The address of the ALT_I2C_DMA_RDLR register for the ALT_I2C1 instance. */
6030#define ALT_I2C1_IC_DMA_RDLR_ADDR ALT_I2C_DMA_RDLR_ADDR(ALT_I2C1_ADDR)
6031/* The address of the ALT_I2C_SDA_SETUP register for the ALT_I2C1 instance. */
6032#define ALT_I2C1_IC_SDA_SETUP_ADDR ALT_I2C_SDA_SETUP_ADDR(ALT_I2C1_ADDR)
6033/* The address of the ALT_I2C_ACK_GENERAL_CALL register for the ALT_I2C1 instance. */
6034#define ALT_I2C1_IC_ACK_GENERAL_CALL_ADDR ALT_I2C_ACK_GENERAL_CALL_ADDR(ALT_I2C1_ADDR)
6035/* The address of the ALT_I2C_EN_STAT register for the ALT_I2C1 instance. */
6036#define ALT_I2C1_IC_EN_STAT_ADDR ALT_I2C_EN_STAT_ADDR(ALT_I2C1_ADDR)
6037/* The address of the ALT_I2C_FS_SPKLEN register for the ALT_I2C1 instance. */
6038#define ALT_I2C1_IC_FS_SPKLEN_ADDR ALT_I2C_FS_SPKLEN_ADDR(ALT_I2C1_ADDR)
6039/* The address of the ALT_I2C_COMP_PARAM_1 register for the ALT_I2C1 instance. */
6040#define ALT_I2C1_IC_COMP_PARAM_1_ADDR ALT_I2C_COMP_PARAM_1_ADDR(ALT_I2C1_ADDR)
6041/* The address of the ALT_I2C_COMP_VER register for the ALT_I2C1 instance. */
6042#define ALT_I2C1_IC_COMP_VER_ADDR ALT_I2C_COMP_VER_ADDR(ALT_I2C1_ADDR)
6043/* The address of the ALT_I2C_COMP_TYPE register for the ALT_I2C1 instance. */
6044#define ALT_I2C1_IC_COMP_TYPE_ADDR ALT_I2C_COMP_TYPE_ADDR(ALT_I2C1_ADDR)
6045/* The base address byte offset for the start of the ALT_I2C1 component. */
6046#define ALT_I2C1_OFST 0xffc05000
6047/* The start address of the ALT_I2C1 component. */
6048#define ALT_I2C1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_I2C1_OFST))
6049/* The lower bound address range of the ALT_I2C1 component. */
6050#define ALT_I2C1_LB_ADDR ALT_I2C1_ADDR
6051/* The upper bound address range of the ALT_I2C1 component. */
6052#define ALT_I2C1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_I2C1_ADDR) + 0x100) - 1))
6053
6054
6055/*
6056 * Component Instance : i2c2
6057 *
6058 * Instance i2c2 of component ALT_I2C.
6059 *
6060 *
6061 */
6062/* The address of the ALT_I2C_CON register for the ALT_I2C2 instance. */
6063#define ALT_I2C2_IC_CON_ADDR ALT_I2C_CON_ADDR(ALT_I2C2_ADDR)
6064/* The address of the ALT_I2C_TAR register for the ALT_I2C2 instance. */
6065#define ALT_I2C2_IC_TAR_ADDR ALT_I2C_TAR_ADDR(ALT_I2C2_ADDR)
6066/* The address of the ALT_I2C_SAR register for the ALT_I2C2 instance. */
6067#define ALT_I2C2_IC_SAR_ADDR ALT_I2C_SAR_ADDR(ALT_I2C2_ADDR)
6068/* The address of the ALT_I2C_DATA_CMD register for the ALT_I2C2 instance. */
6069#define ALT_I2C2_IC_DATA_CMD_ADDR ALT_I2C_DATA_CMD_ADDR(ALT_I2C2_ADDR)
6070/* The address of the ALT_I2C_SS_SCL_HCNT register for the ALT_I2C2 instance. */
6071#define ALT_I2C2_IC_SS_SCL_HCNT_ADDR ALT_I2C_SS_SCL_HCNT_ADDR(ALT_I2C2_ADDR)
6072/* The address of the ALT_I2C_SS_SCL_LCNT register for the ALT_I2C2 instance. */
6073#define ALT_I2C2_IC_SS_SCL_LCNT_ADDR ALT_I2C_SS_SCL_LCNT_ADDR(ALT_I2C2_ADDR)
6074/* The address of the ALT_I2C_FS_SCL_HCNT register for the ALT_I2C2 instance. */
6075#define ALT_I2C2_IC_FS_SCL_HCNT_ADDR ALT_I2C_FS_SCL_HCNT_ADDR(ALT_I2C2_ADDR)
6076/* The address of the ALT_I2C_FS_SCL_LCNT register for the ALT_I2C2 instance. */
6077#define ALT_I2C2_IC_FS_SCL_LCNT_ADDR ALT_I2C_FS_SCL_LCNT_ADDR(ALT_I2C2_ADDR)
6078/* The address of the ALT_I2C_INTR_STAT register for the ALT_I2C2 instance. */
6079#define ALT_I2C2_IC_INTR_STAT_ADDR ALT_I2C_INTR_STAT_ADDR(ALT_I2C2_ADDR)
6080/* The address of the ALT_I2C_INTR_MSK register for the ALT_I2C2 instance. */
6081#define ALT_I2C2_IC_INTR_MSK_ADDR ALT_I2C_INTR_MSK_ADDR(ALT_I2C2_ADDR)
6082/* The address of the ALT_I2C_RAW_INTR_STAT register for the ALT_I2C2 instance. */
6083#define ALT_I2C2_IC_RAW_INTR_STAT_ADDR ALT_I2C_RAW_INTR_STAT_ADDR(ALT_I2C2_ADDR)
6084/* The address of the ALT_I2C_RX_TL register for the ALT_I2C2 instance. */
6085#define ALT_I2C2_IC_RX_TL_ADDR ALT_I2C_RX_TL_ADDR(ALT_I2C2_ADDR)
6086/* The address of the ALT_I2C_TX_TL register for the ALT_I2C2 instance. */
6087#define ALT_I2C2_IC_TX_TL_ADDR ALT_I2C_TX_TL_ADDR(ALT_I2C2_ADDR)
6088/* The address of the ALT_I2C_CLR_INTR register for the ALT_I2C2 instance. */
6089#define ALT_I2C2_IC_CLR_INTR_ADDR ALT_I2C_CLR_INTR_ADDR(ALT_I2C2_ADDR)
6090/* The address of the ALT_I2C_CLR_RX_UNDER register for the ALT_I2C2 instance. */
6091#define ALT_I2C2_IC_CLR_RX_UNDER_ADDR ALT_I2C_CLR_RX_UNDER_ADDR(ALT_I2C2_ADDR)
6092/* The address of the ALT_I2C_CLR_RX_OVER register for the ALT_I2C2 instance. */
6093#define ALT_I2C2_IC_CLR_RX_OVER_ADDR ALT_I2C_CLR_RX_OVER_ADDR(ALT_I2C2_ADDR)
6094/* The address of the ALT_I2C_CLR_TX_OVER register for the ALT_I2C2 instance. */
6095#define ALT_I2C2_IC_CLR_TX_OVER_ADDR ALT_I2C_CLR_TX_OVER_ADDR(ALT_I2C2_ADDR)
6096/* The address of the ALT_I2C_CLR_RD_REQ register for the ALT_I2C2 instance. */
6097#define ALT_I2C2_IC_CLR_RD_REQ_ADDR ALT_I2C_CLR_RD_REQ_ADDR(ALT_I2C2_ADDR)
6098/* The address of the ALT_I2C_CLR_TX_ABRT register for the ALT_I2C2 instance. */
6099#define ALT_I2C2_IC_CLR_TX_ABRT_ADDR ALT_I2C_CLR_TX_ABRT_ADDR(ALT_I2C2_ADDR)
6100/* The address of the ALT_I2C_CLR_RX_DONE register for the ALT_I2C2 instance. */
6101#define ALT_I2C2_IC_CLR_RX_DONE_ADDR ALT_I2C_CLR_RX_DONE_ADDR(ALT_I2C2_ADDR)
6102/* The address of the ALT_I2C_CLR_ACTIVITY register for the ALT_I2C2 instance. */
6103#define ALT_I2C2_IC_CLR_ACTIVITY_ADDR ALT_I2C_CLR_ACTIVITY_ADDR(ALT_I2C2_ADDR)
6104/* The address of the ALT_I2C_CLR_STOP_DET register for the ALT_I2C2 instance. */
6105#define ALT_I2C2_IC_CLR_STOP_DET_ADDR ALT_I2C_CLR_STOP_DET_ADDR(ALT_I2C2_ADDR)
6106/* The address of the ALT_I2C_CLR_START_DET register for the ALT_I2C2 instance. */
6107#define ALT_I2C2_IC_CLR_START_DET_ADDR ALT_I2C_CLR_START_DET_ADDR(ALT_I2C2_ADDR)
6108/* The address of the ALT_I2C_CLR_GEN_CALL register for the ALT_I2C2 instance. */
6109#define ALT_I2C2_IC_CLR_GEN_CALL_ADDR ALT_I2C_CLR_GEN_CALL_ADDR(ALT_I2C2_ADDR)
6110/* The address of the ALT_I2C_EN register for the ALT_I2C2 instance. */
6111#define ALT_I2C2_IC_EN_ADDR ALT_I2C_EN_ADDR(ALT_I2C2_ADDR)
6112/* The address of the ALT_I2C_STAT register for the ALT_I2C2 instance. */
6113#define ALT_I2C2_IC_STAT_ADDR ALT_I2C_STAT_ADDR(ALT_I2C2_ADDR)
6114/* The address of the ALT_I2C_TXFLR register for the ALT_I2C2 instance. */
6115#define ALT_I2C2_IC_TXFLR_ADDR ALT_I2C_TXFLR_ADDR(ALT_I2C2_ADDR)
6116/* The address of the ALT_I2C_RXFLR register for the ALT_I2C2 instance. */
6117#define ALT_I2C2_IC_RXFLR_ADDR ALT_I2C_RXFLR_ADDR(ALT_I2C2_ADDR)
6118/* The address of the ALT_I2C_SDA_HOLD register for the ALT_I2C2 instance. */
6119#define ALT_I2C2_IC_SDA_HOLD_ADDR ALT_I2C_SDA_HOLD_ADDR(ALT_I2C2_ADDR)
6120/* The address of the ALT_I2C_TX_ABRT_SRC register for the ALT_I2C2 instance. */
6121#define ALT_I2C2_IC_TX_ABRT_SRC_ADDR ALT_I2C_TX_ABRT_SRC_ADDR(ALT_I2C2_ADDR)
6122/* The address of the ALT_I2C_SLV_DATA_NACK_ONLY register for the ALT_I2C2 instance. */
6123#define ALT_I2C2_IC_SLV_DATA_NACK_ONLY_ADDR ALT_I2C_SLV_DATA_NACK_ONLY_ADDR(ALT_I2C2_ADDR)
6124/* The address of the ALT_I2C_DMA_CR register for the ALT_I2C2 instance. */
6125#define ALT_I2C2_IC_DMA_CR_ADDR ALT_I2C_DMA_CR_ADDR(ALT_I2C2_ADDR)
6126/* The address of the ALT_I2C_DMA_TDLR register for the ALT_I2C2 instance. */
6127#define ALT_I2C2_IC_DMA_TDLR_ADDR ALT_I2C_DMA_TDLR_ADDR(ALT_I2C2_ADDR)
6128/* The address of the ALT_I2C_DMA_RDLR register for the ALT_I2C2 instance. */
6129#define ALT_I2C2_IC_DMA_RDLR_ADDR ALT_I2C_DMA_RDLR_ADDR(ALT_I2C2_ADDR)
6130/* The address of the ALT_I2C_SDA_SETUP register for the ALT_I2C2 instance. */
6131#define ALT_I2C2_IC_SDA_SETUP_ADDR ALT_I2C_SDA_SETUP_ADDR(ALT_I2C2_ADDR)
6132/* The address of the ALT_I2C_ACK_GENERAL_CALL register for the ALT_I2C2 instance. */
6133#define ALT_I2C2_IC_ACK_GENERAL_CALL_ADDR ALT_I2C_ACK_GENERAL_CALL_ADDR(ALT_I2C2_ADDR)
6134/* The address of the ALT_I2C_EN_STAT register for the ALT_I2C2 instance. */
6135#define ALT_I2C2_IC_EN_STAT_ADDR ALT_I2C_EN_STAT_ADDR(ALT_I2C2_ADDR)
6136/* The address of the ALT_I2C_FS_SPKLEN register for the ALT_I2C2 instance. */
6137#define ALT_I2C2_IC_FS_SPKLEN_ADDR ALT_I2C_FS_SPKLEN_ADDR(ALT_I2C2_ADDR)
6138/* The address of the ALT_I2C_COMP_PARAM_1 register for the ALT_I2C2 instance. */
6139#define ALT_I2C2_IC_COMP_PARAM_1_ADDR ALT_I2C_COMP_PARAM_1_ADDR(ALT_I2C2_ADDR)
6140/* The address of the ALT_I2C_COMP_VER register for the ALT_I2C2 instance. */
6141#define ALT_I2C2_IC_COMP_VER_ADDR ALT_I2C_COMP_VER_ADDR(ALT_I2C2_ADDR)
6142/* The address of the ALT_I2C_COMP_TYPE register for the ALT_I2C2 instance. */
6143#define ALT_I2C2_IC_COMP_TYPE_ADDR ALT_I2C_COMP_TYPE_ADDR(ALT_I2C2_ADDR)
6144/* The base address byte offset for the start of the ALT_I2C2 component. */
6145#define ALT_I2C2_OFST 0xffc06000
6146/* The start address of the ALT_I2C2 component. */
6147#define ALT_I2C2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_I2C2_OFST))
6148/* The lower bound address range of the ALT_I2C2 component. */
6149#define ALT_I2C2_LB_ADDR ALT_I2C2_ADDR
6150/* The upper bound address range of the ALT_I2C2 component. */
6151#define ALT_I2C2_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_I2C2_ADDR) + 0x100) - 1))
6152
6153
6154/*
6155 * Component Instance : i2c3
6156 *
6157 * Instance i2c3 of component ALT_I2C.
6158 *
6159 *
6160 */
6161/* The address of the ALT_I2C_CON register for the ALT_I2C3 instance. */
6162#define ALT_I2C3_IC_CON_ADDR ALT_I2C_CON_ADDR(ALT_I2C3_ADDR)
6163/* The address of the ALT_I2C_TAR register for the ALT_I2C3 instance. */
6164#define ALT_I2C3_IC_TAR_ADDR ALT_I2C_TAR_ADDR(ALT_I2C3_ADDR)
6165/* The address of the ALT_I2C_SAR register for the ALT_I2C3 instance. */
6166#define ALT_I2C3_IC_SAR_ADDR ALT_I2C_SAR_ADDR(ALT_I2C3_ADDR)
6167/* The address of the ALT_I2C_DATA_CMD register for the ALT_I2C3 instance. */
6168#define ALT_I2C3_IC_DATA_CMD_ADDR ALT_I2C_DATA_CMD_ADDR(ALT_I2C3_ADDR)
6169/* The address of the ALT_I2C_SS_SCL_HCNT register for the ALT_I2C3 instance. */
6170#define ALT_I2C3_IC_SS_SCL_HCNT_ADDR ALT_I2C_SS_SCL_HCNT_ADDR(ALT_I2C3_ADDR)
6171/* The address of the ALT_I2C_SS_SCL_LCNT register for the ALT_I2C3 instance. */
6172#define ALT_I2C3_IC_SS_SCL_LCNT_ADDR ALT_I2C_SS_SCL_LCNT_ADDR(ALT_I2C3_ADDR)
6173/* The address of the ALT_I2C_FS_SCL_HCNT register for the ALT_I2C3 instance. */
6174#define ALT_I2C3_IC_FS_SCL_HCNT_ADDR ALT_I2C_FS_SCL_HCNT_ADDR(ALT_I2C3_ADDR)
6175/* The address of the ALT_I2C_FS_SCL_LCNT register for the ALT_I2C3 instance. */
6176#define ALT_I2C3_IC_FS_SCL_LCNT_ADDR ALT_I2C_FS_SCL_LCNT_ADDR(ALT_I2C3_ADDR)
6177/* The address of the ALT_I2C_INTR_STAT register for the ALT_I2C3 instance. */
6178#define ALT_I2C3_IC_INTR_STAT_ADDR ALT_I2C_INTR_STAT_ADDR(ALT_I2C3_ADDR)
6179/* The address of the ALT_I2C_INTR_MSK register for the ALT_I2C3 instance. */
6180#define ALT_I2C3_IC_INTR_MSK_ADDR ALT_I2C_INTR_MSK_ADDR(ALT_I2C3_ADDR)
6181/* The address of the ALT_I2C_RAW_INTR_STAT register for the ALT_I2C3 instance. */
6182#define ALT_I2C3_IC_RAW_INTR_STAT_ADDR ALT_I2C_RAW_INTR_STAT_ADDR(ALT_I2C3_ADDR)
6183/* The address of the ALT_I2C_RX_TL register for the ALT_I2C3 instance. */
6184#define ALT_I2C3_IC_RX_TL_ADDR ALT_I2C_RX_TL_ADDR(ALT_I2C3_ADDR)
6185/* The address of the ALT_I2C_TX_TL register for the ALT_I2C3 instance. */
6186#define ALT_I2C3_IC_TX_TL_ADDR ALT_I2C_TX_TL_ADDR(ALT_I2C3_ADDR)
6187/* The address of the ALT_I2C_CLR_INTR register for the ALT_I2C3 instance. */
6188#define ALT_I2C3_IC_CLR_INTR_ADDR ALT_I2C_CLR_INTR_ADDR(ALT_I2C3_ADDR)
6189/* The address of the ALT_I2C_CLR_RX_UNDER register for the ALT_I2C3 instance. */
6190#define ALT_I2C3_IC_CLR_RX_UNDER_ADDR ALT_I2C_CLR_RX_UNDER_ADDR(ALT_I2C3_ADDR)
6191/* The address of the ALT_I2C_CLR_RX_OVER register for the ALT_I2C3 instance. */
6192#define ALT_I2C3_IC_CLR_RX_OVER_ADDR ALT_I2C_CLR_RX_OVER_ADDR(ALT_I2C3_ADDR)
6193/* The address of the ALT_I2C_CLR_TX_OVER register for the ALT_I2C3 instance. */
6194#define ALT_I2C3_IC_CLR_TX_OVER_ADDR ALT_I2C_CLR_TX_OVER_ADDR(ALT_I2C3_ADDR)
6195/* The address of the ALT_I2C_CLR_RD_REQ register for the ALT_I2C3 instance. */
6196#define ALT_I2C3_IC_CLR_RD_REQ_ADDR ALT_I2C_CLR_RD_REQ_ADDR(ALT_I2C3_ADDR)
6197/* The address of the ALT_I2C_CLR_TX_ABRT register for the ALT_I2C3 instance. */
6198#define ALT_I2C3_IC_CLR_TX_ABRT_ADDR ALT_I2C_CLR_TX_ABRT_ADDR(ALT_I2C3_ADDR)
6199/* The address of the ALT_I2C_CLR_RX_DONE register for the ALT_I2C3 instance. */
6200#define ALT_I2C3_IC_CLR_RX_DONE_ADDR ALT_I2C_CLR_RX_DONE_ADDR(ALT_I2C3_ADDR)
6201/* The address of the ALT_I2C_CLR_ACTIVITY register for the ALT_I2C3 instance. */
6202#define ALT_I2C3_IC_CLR_ACTIVITY_ADDR ALT_I2C_CLR_ACTIVITY_ADDR(ALT_I2C3_ADDR)
6203/* The address of the ALT_I2C_CLR_STOP_DET register for the ALT_I2C3 instance. */
6204#define ALT_I2C3_IC_CLR_STOP_DET_ADDR ALT_I2C_CLR_STOP_DET_ADDR(ALT_I2C3_ADDR)
6205/* The address of the ALT_I2C_CLR_START_DET register for the ALT_I2C3 instance. */
6206#define ALT_I2C3_IC_CLR_START_DET_ADDR ALT_I2C_CLR_START_DET_ADDR(ALT_I2C3_ADDR)
6207/* The address of the ALT_I2C_CLR_GEN_CALL register for the ALT_I2C3 instance. */
6208#define ALT_I2C3_IC_CLR_GEN_CALL_ADDR ALT_I2C_CLR_GEN_CALL_ADDR(ALT_I2C3_ADDR)
6209/* The address of the ALT_I2C_EN register for the ALT_I2C3 instance. */
6210#define ALT_I2C3_IC_EN_ADDR ALT_I2C_EN_ADDR(ALT_I2C3_ADDR)
6211/* The address of the ALT_I2C_STAT register for the ALT_I2C3 instance. */
6212#define ALT_I2C3_IC_STAT_ADDR ALT_I2C_STAT_ADDR(ALT_I2C3_ADDR)
6213/* The address of the ALT_I2C_TXFLR register for the ALT_I2C3 instance. */
6214#define ALT_I2C3_IC_TXFLR_ADDR ALT_I2C_TXFLR_ADDR(ALT_I2C3_ADDR)
6215/* The address of the ALT_I2C_RXFLR register for the ALT_I2C3 instance. */
6216#define ALT_I2C3_IC_RXFLR_ADDR ALT_I2C_RXFLR_ADDR(ALT_I2C3_ADDR)
6217/* The address of the ALT_I2C_SDA_HOLD register for the ALT_I2C3 instance. */
6218#define ALT_I2C3_IC_SDA_HOLD_ADDR ALT_I2C_SDA_HOLD_ADDR(ALT_I2C3_ADDR)
6219/* The address of the ALT_I2C_TX_ABRT_SRC register for the ALT_I2C3 instance. */
6220#define ALT_I2C3_IC_TX_ABRT_SRC_ADDR ALT_I2C_TX_ABRT_SRC_ADDR(ALT_I2C3_ADDR)
6221/* The address of the ALT_I2C_SLV_DATA_NACK_ONLY register for the ALT_I2C3 instance. */
6222#define ALT_I2C3_IC_SLV_DATA_NACK_ONLY_ADDR ALT_I2C_SLV_DATA_NACK_ONLY_ADDR(ALT_I2C3_ADDR)
6223/* The address of the ALT_I2C_DMA_CR register for the ALT_I2C3 instance. */
6224#define ALT_I2C3_IC_DMA_CR_ADDR ALT_I2C_DMA_CR_ADDR(ALT_I2C3_ADDR)
6225/* The address of the ALT_I2C_DMA_TDLR register for the ALT_I2C3 instance. */
6226#define ALT_I2C3_IC_DMA_TDLR_ADDR ALT_I2C_DMA_TDLR_ADDR(ALT_I2C3_ADDR)
6227/* The address of the ALT_I2C_DMA_RDLR register for the ALT_I2C3 instance. */
6228#define ALT_I2C3_IC_DMA_RDLR_ADDR ALT_I2C_DMA_RDLR_ADDR(ALT_I2C3_ADDR)
6229/* The address of the ALT_I2C_SDA_SETUP register for the ALT_I2C3 instance. */
6230#define ALT_I2C3_IC_SDA_SETUP_ADDR ALT_I2C_SDA_SETUP_ADDR(ALT_I2C3_ADDR)
6231/* The address of the ALT_I2C_ACK_GENERAL_CALL register for the ALT_I2C3 instance. */
6232#define ALT_I2C3_IC_ACK_GENERAL_CALL_ADDR ALT_I2C_ACK_GENERAL_CALL_ADDR(ALT_I2C3_ADDR)
6233/* The address of the ALT_I2C_EN_STAT register for the ALT_I2C3 instance. */
6234#define ALT_I2C3_IC_EN_STAT_ADDR ALT_I2C_EN_STAT_ADDR(ALT_I2C3_ADDR)
6235/* The address of the ALT_I2C_FS_SPKLEN register for the ALT_I2C3 instance. */
6236#define ALT_I2C3_IC_FS_SPKLEN_ADDR ALT_I2C_FS_SPKLEN_ADDR(ALT_I2C3_ADDR)
6237/* The address of the ALT_I2C_COMP_PARAM_1 register for the ALT_I2C3 instance. */
6238#define ALT_I2C3_IC_COMP_PARAM_1_ADDR ALT_I2C_COMP_PARAM_1_ADDR(ALT_I2C3_ADDR)
6239/* The address of the ALT_I2C_COMP_VER register for the ALT_I2C3 instance. */
6240#define ALT_I2C3_IC_COMP_VER_ADDR ALT_I2C_COMP_VER_ADDR(ALT_I2C3_ADDR)
6241/* The address of the ALT_I2C_COMP_TYPE register for the ALT_I2C3 instance. */
6242#define ALT_I2C3_IC_COMP_TYPE_ADDR ALT_I2C_COMP_TYPE_ADDR(ALT_I2C3_ADDR)
6243/* The base address byte offset for the start of the ALT_I2C3 component. */
6244#define ALT_I2C3_OFST 0xffc07000
6245/* The start address of the ALT_I2C3 component. */
6246#define ALT_I2C3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_I2C3_OFST))
6247/* The lower bound address range of the ALT_I2C3 component. */
6248#define ALT_I2C3_LB_ADDR ALT_I2C3_ADDR
6249/* The upper bound address range of the ALT_I2C3 component. */
6250#define ALT_I2C3_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_I2C3_ADDR) + 0x100) - 1))
6251
6252
6253/*
6254 * Component Instance : sptimer0
6255 *
6256 * Instance sptimer0 of component ALT_TMR.
6257 *
6258 *
6259 */
6260/* The address of the ALT_TMR_TMR1LDCOUNT register for the ALT_SPTMR0 instance. */
6261#define ALT_SPTMR0_TMR1LDCOUNT_ADDR ALT_TMR_TMR1LDCOUNT_ADDR(ALT_SPTMR0_ADDR)
6262/* The address of the ALT_TMR_TMR1CURVAL register for the ALT_SPTMR0 instance. */
6263#define ALT_SPTMR0_TMR1CURVAL_ADDR ALT_TMR_TMR1CURVAL_ADDR(ALT_SPTMR0_ADDR)
6264/* The address of the ALT_TMR_TMR1CTLREG register for the ALT_SPTMR0 instance. */
6265#define ALT_SPTMR0_TMR1CTLREG_ADDR ALT_TMR_TMR1CTLREG_ADDR(ALT_SPTMR0_ADDR)
6266/* The address of the ALT_TMR_TMR1EOI register for the ALT_SPTMR0 instance. */
6267#define ALT_SPTMR0_TMR1EOI_ADDR ALT_TMR_TMR1EOI_ADDR(ALT_SPTMR0_ADDR)
6268/* The address of the ALT_TMR_TMR1INTSTAT register for the ALT_SPTMR0 instance. */
6269#define ALT_SPTMR0_TMR1INTSTAT_ADDR ALT_TMR_TMR1INTSTAT_ADDR(ALT_SPTMR0_ADDR)
6270/* The address of the ALT_TMR_TMRSINTSTAT register for the ALT_SPTMR0 instance. */
6271#define ALT_SPTMR0_TMRSINTSTAT_ADDR ALT_TMR_TMRSINTSTAT_ADDR(ALT_SPTMR0_ADDR)
6272/* The address of the ALT_TMR_TMRSEOI register for the ALT_SPTMR0 instance. */
6273#define ALT_SPTMR0_TMRSEOI_ADDR ALT_TMR_TMRSEOI_ADDR(ALT_SPTMR0_ADDR)
6274/* The address of the ALT_TMR_TMRSRAWINTSTAT register for the ALT_SPTMR0 instance. */
6275#define ALT_SPTMR0_TMRSRAWINTSTAT_ADDR ALT_TMR_TMRSRAWINTSTAT_ADDR(ALT_SPTMR0_ADDR)
6276/* The address of the ALT_TMR_TMRSCOMPVER register for the ALT_SPTMR0 instance. */
6277#define ALT_SPTMR0_TMRSCOMPVER_ADDR ALT_TMR_TMRSCOMPVER_ADDR(ALT_SPTMR0_ADDR)
6278/* The base address byte offset for the start of the ALT_SPTMR0 component. */
6279#define ALT_SPTMR0_OFST 0xffc08000
6280/* The start address of the ALT_SPTMR0 component. */
6281#define ALT_SPTMR0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SPTMR0_OFST))
6282/* The lower bound address range of the ALT_SPTMR0 component. */
6283#define ALT_SPTMR0_LB_ADDR ALT_SPTMR0_ADDR
6284/* The upper bound address range of the ALT_SPTMR0 component. */
6285#define ALT_SPTMR0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SPTMR0_ADDR) + 0x100) - 1))
6286
6287
6288/*
6289 * Component Instance : sptimer1
6290 *
6291 * Instance sptimer1 of component ALT_TMR.
6292 *
6293 *
6294 */
6295/* The address of the ALT_TMR_TMR1LDCOUNT register for the ALT_SPTMR1 instance. */
6296#define ALT_SPTMR1_TMR1LDCOUNT_ADDR ALT_TMR_TMR1LDCOUNT_ADDR(ALT_SPTMR1_ADDR)
6297/* The address of the ALT_TMR_TMR1CURVAL register for the ALT_SPTMR1 instance. */
6298#define ALT_SPTMR1_TMR1CURVAL_ADDR ALT_TMR_TMR1CURVAL_ADDR(ALT_SPTMR1_ADDR)
6299/* The address of the ALT_TMR_TMR1CTLREG register for the ALT_SPTMR1 instance. */
6300#define ALT_SPTMR1_TMR1CTLREG_ADDR ALT_TMR_TMR1CTLREG_ADDR(ALT_SPTMR1_ADDR)
6301/* The address of the ALT_TMR_TMR1EOI register for the ALT_SPTMR1 instance. */
6302#define ALT_SPTMR1_TMR1EOI_ADDR ALT_TMR_TMR1EOI_ADDR(ALT_SPTMR1_ADDR)
6303/* The address of the ALT_TMR_TMR1INTSTAT register for the ALT_SPTMR1 instance. */
6304#define ALT_SPTMR1_TMR1INTSTAT_ADDR ALT_TMR_TMR1INTSTAT_ADDR(ALT_SPTMR1_ADDR)
6305/* The address of the ALT_TMR_TMRSINTSTAT register for the ALT_SPTMR1 instance. */
6306#define ALT_SPTMR1_TMRSINTSTAT_ADDR ALT_TMR_TMRSINTSTAT_ADDR(ALT_SPTMR1_ADDR)
6307/* The address of the ALT_TMR_TMRSEOI register for the ALT_SPTMR1 instance. */
6308#define ALT_SPTMR1_TMRSEOI_ADDR ALT_TMR_TMRSEOI_ADDR(ALT_SPTMR1_ADDR)
6309/* The address of the ALT_TMR_TMRSRAWINTSTAT register for the ALT_SPTMR1 instance. */
6310#define ALT_SPTMR1_TMRSRAWINTSTAT_ADDR ALT_TMR_TMRSRAWINTSTAT_ADDR(ALT_SPTMR1_ADDR)
6311/* The address of the ALT_TMR_TMRSCOMPVER register for the ALT_SPTMR1 instance. */
6312#define ALT_SPTMR1_TMRSCOMPVER_ADDR ALT_TMR_TMRSCOMPVER_ADDR(ALT_SPTMR1_ADDR)
6313/* The base address byte offset for the start of the ALT_SPTMR1 component. */
6314#define ALT_SPTMR1_OFST 0xffc09000
6315/* The start address of the ALT_SPTMR1 component. */
6316#define ALT_SPTMR1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SPTMR1_OFST))
6317/* The lower bound address range of the ALT_SPTMR1 component. */
6318#define ALT_SPTMR1_LB_ADDR ALT_SPTMR1_ADDR
6319/* The upper bound address range of the ALT_SPTMR1 component. */
6320#define ALT_SPTMR1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SPTMR1_ADDR) + 0x100) - 1))
6321
6322
6323/*
6324 * Component Instance : sdr
6325 *
6326 * Instance sdr of component ALT_SDR.
6327 *
6328 *
6329 */
6330/*
6331 * Register Group Instance : ctrlgrp
6332 *
6333 * Instance ctrlgrp of register group ALT_SDR_CTL.
6334 *
6335 *
6336 */
6337/* The address of the ALT_SDR_CTL_CTLCFG register for the ALT_SDR_CTL instance. */
6338#define ALT_SDR_CTL_CTLCFG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_CTLCFG_OFST))
6339/* The address of the ALT_SDR_CTL_DRAMTIMING1 register for the ALT_SDR_CTL instance. */
6340#define ALT_SDR_CTL_DRAMTIMING1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMTIMING1_OFST))
6341/* The address of the ALT_SDR_CTL_DRAMTIMING2 register for the ALT_SDR_CTL instance. */
6342#define ALT_SDR_CTL_DRAMTIMING2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMTIMING2_OFST))
6343/* The address of the ALT_SDR_CTL_DRAMTIMING3 register for the ALT_SDR_CTL instance. */
6344#define ALT_SDR_CTL_DRAMTIMING3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMTIMING3_OFST))
6345/* The address of the ALT_SDR_CTL_DRAMTIMING4 register for the ALT_SDR_CTL instance. */
6346#define ALT_SDR_CTL_DRAMTIMING4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMTIMING4_OFST))
6347/* The address of the ALT_SDR_CTL_LOWPWRTIMING register for the ALT_SDR_CTL instance. */
6348#define ALT_SDR_CTL_LOWPWRTIMING_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_LOWPWRTIMING_OFST))
6349/* The address of the ALT_SDR_CTL_DRAMODT register for the ALT_SDR_CTL instance. */
6350#define ALT_SDR_CTL_DRAMODT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMODT_OFST))
6351/* The address of the ALT_SDR_CTL_DRAMADDRW register for the ALT_SDR_CTL instance. */
6352#define ALT_SDR_CTL_DRAMADDRW_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMADDRW_OFST))
6353/* The address of the ALT_SDR_CTL_DRAMIFWIDTH register for the ALT_SDR_CTL instance. */
6354#define ALT_SDR_CTL_DRAMIFWIDTH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMIFWIDTH_OFST))
6355/* The address of the ALT_SDR_CTL_DRAMDEVWIDTH register for the ALT_SDR_CTL instance. */
6356#define ALT_SDR_CTL_DRAMDEVWIDTH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMDEVWIDTH_OFST))
6357/* The address of the ALT_SDR_CTL_DRAMSTS register for the ALT_SDR_CTL instance. */
6358#define ALT_SDR_CTL_DRAMSTS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMSTS_OFST))
6359/* The address of the ALT_SDR_CTL_DRAMINTR register for the ALT_SDR_CTL instance. */
6360#define ALT_SDR_CTL_DRAMINTR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMINTR_OFST))
6361/* The address of the ALT_SDR_CTL_SBECOUNT register for the ALT_SDR_CTL instance. */
6362#define ALT_SDR_CTL_SBECOUNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_SBECOUNT_OFST))
6363/* The address of the ALT_SDR_CTL_DBECOUNT register for the ALT_SDR_CTL instance. */
6364#define ALT_SDR_CTL_DBECOUNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DBECOUNT_OFST))
6365/* The address of the ALT_SDR_CTL_ERRADDR register for the ALT_SDR_CTL instance. */
6366#define ALT_SDR_CTL_ERRADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_ERRADDR_OFST))
6367/* The address of the ALT_SDR_CTL_DROPCOUNT register for the ALT_SDR_CTL instance. */
6368#define ALT_SDR_CTL_DROPCOUNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DROPCOUNT_OFST))
6369/* The address of the ALT_SDR_CTL_DROPADDR register for the ALT_SDR_CTL instance. */
6370#define ALT_SDR_CTL_DROPADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DROPADDR_OFST))
6371/* The address of the ALT_SDR_CTL_LOWPWREQ register for the ALT_SDR_CTL instance. */
6372#define ALT_SDR_CTL_LOWPWREQ_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_LOWPWREQ_OFST))
6373/* The address of the ALT_SDR_CTL_LOWPWRACK register for the ALT_SDR_CTL instance. */
6374#define ALT_SDR_CTL_LOWPWRACK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_LOWPWRACK_OFST))
6375/* The address of the ALT_SDR_CTL_STATICCFG register for the ALT_SDR_CTL instance. */
6376#define ALT_SDR_CTL_STATICCFG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_STATICCFG_OFST))
6377/* The address of the ALT_SDR_CTL_CTLWIDTH register for the ALT_SDR_CTL instance. */
6378#define ALT_SDR_CTL_CTLWIDTH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_CTLWIDTH_OFST))
6379/* The address of the ALT_SDR_CTL_PORTCFG register for the ALT_SDR_CTL instance. */
6380#define ALT_SDR_CTL_PORTCFG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_PORTCFG_OFST))
6381/* The address of the ALT_SDR_CTL_FPGAPORTRST register for the ALT_SDR_CTL instance. */
6382#define ALT_SDR_CTL_FPGAPORTRST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_FPGAPORTRST_OFST))
6383/* The address of the ALT_SDR_CTL_PROTPORTDEFAULT register for the ALT_SDR_CTL instance. */
6384#define ALT_SDR_CTL_PROTPORTDEFAULT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_PROTPORTDEFAULT_OFST))
6385/* The address of the ALT_SDR_CTL_PROTRULEADDR register for the ALT_SDR_CTL instance. */
6386#define ALT_SDR_CTL_PROTRULEADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_PROTRULEADDR_OFST))
6387/* The address of the ALT_SDR_CTL_PROTRULEID register for the ALT_SDR_CTL instance. */
6388#define ALT_SDR_CTL_PROTRULEID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_PROTRULEID_OFST))
6389/* The address of the ALT_SDR_CTL_PROTRULEDATA register for the ALT_SDR_CTL instance. */
6390#define ALT_SDR_CTL_PROTRULEDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_PROTRULEDATA_OFST))
6391/* The address of the ALT_SDR_CTL_PROTRULERDWR register for the ALT_SDR_CTL instance. */
6392#define ALT_SDR_CTL_PROTRULERDWR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_PROTRULERDWR_OFST))
6393/* The address of the ALT_SDR_CTL_QOSLOWPRI register for the ALT_SDR_CTL instance. */
6394#define ALT_SDR_CTL_QOSLOWPRI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_QOSLOWPRI_OFST))
6395/* The address of the ALT_SDR_CTL_QOSHIGHPRI register for the ALT_SDR_CTL instance. */
6396#define ALT_SDR_CTL_QOSHIGHPRI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_QOSHIGHPRI_OFST))
6397/* The address of the ALT_SDR_CTL_QOSPRIORITYEN register for the ALT_SDR_CTL instance. */
6398#define ALT_SDR_CTL_QOSPRIORITYEN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_QOSPRIORITYEN_OFST))
6399/* The address of the ALT_SDR_CTL_MPPRIORITY register for the ALT_SDR_CTL instance. */
6400#define ALT_SDR_CTL_MPPRIORITY_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_MPPRIORITY_OFST))
6401/* The address of the ALT_SDR_CTL_REMAPPRIORITY register for the ALT_SDR_CTL instance. */
6402#define ALT_SDR_CTL_REMAPPRIORITY_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_REMAPPRIORITY_OFST))
6403/*
6404 * Register Group Instance : ctrlgrp_mpweight
6405 *
6406 * Instance ctrlgrp_mpweight of register group ALT_SDR_CTL_MPWT.
6407 *
6408 *
6409 */
6410/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4 register for the ALT_SDR_CTL_CTL_MPWEIGHT instance. */
6411#define ALT_SDR_CTL_CTL_MPWEIGHT_MPWEIGHT_0_4_ADDR ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_ADDR(ALT_SDR_CTL_CTL_MPWEIGHT_ADDR)
6412/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4 register for the ALT_SDR_CTL_CTL_MPWEIGHT instance. */
6413#define ALT_SDR_CTL_CTL_MPWEIGHT_MPWEIGHT_1_4_ADDR ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_ADDR(ALT_SDR_CTL_CTL_MPWEIGHT_ADDR)
6414/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4 register for the ALT_SDR_CTL_CTL_MPWEIGHT instance. */
6415#define ALT_SDR_CTL_CTL_MPWEIGHT_MPWEIGHT_2_4_ADDR ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_ADDR(ALT_SDR_CTL_CTL_MPWEIGHT_ADDR)
6416/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4 register for the ALT_SDR_CTL_CTL_MPWEIGHT instance. */
6417#define ALT_SDR_CTL_CTL_MPWEIGHT_MPWEIGHT_3_4_ADDR ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_ADDR(ALT_SDR_CTL_CTL_MPWEIGHT_ADDR)
6418/* The base address byte offset for the start of the ALT_SDR_CTL_CTL_MPWEIGHT component. */
6419#define ALT_SDR_CTL_CTL_MPWEIGHT_OFST 0xb0
6420/* The start address of the ALT_SDR_CTL_CTL_MPWEIGHT component. */
6421#define ALT_SDR_CTL_CTL_MPWEIGHT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_CTL_MPWEIGHT_OFST))
6422/* The lower bound address range of the ALT_SDR_CTL_CTL_MPWEIGHT component. */
6423#define ALT_SDR_CTL_CTL_MPWEIGHT_LB_ADDR ALT_SDR_CTL_CTL_MPWEIGHT_ADDR
6424/* The upper bound address range of the ALT_SDR_CTL_CTL_MPWEIGHT component. */
6425#define ALT_SDR_CTL_CTL_MPWEIGHT_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SDR_CTL_CTL_MPWEIGHT_ADDR) + 0x10) - 1))
6426
6427
6428/* The base address byte offset for the start of the ALT_SDR_CTL component. */
6429#define ALT_SDR_CTL_OFST 0x5000
6430/* The start address of the ALT_SDR_CTL component. */
6431#define ALT_SDR_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_ADDR) + ALT_SDR_CTL_OFST))
6432/* The lower bound address range of the ALT_SDR_CTL component. */
6433#define ALT_SDR_CTL_LB_ADDR ALT_SDR_CTL_ADDR
6434/* The upper bound address range of the ALT_SDR_CTL component. */
6435#define ALT_SDR_CTL_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SDR_CTL_ADDR) + 0x1000) - 1))
6436
6437
6438/* The base address byte offset for the start of the ALT_SDR component. */
6439#define ALT_SDR_OFST 0xffc20000
6440/* The start address of the ALT_SDR component. */
6441#define ALT_SDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SDR_OFST))
6442/* The lower bound address range of the ALT_SDR component. */
6443#define ALT_SDR_LB_ADDR ALT_SDR_ADDR
6444/* The upper bound address range of the ALT_SDR component. */
6445#define ALT_SDR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SDR_ADDR) + 0x20000) - 1))
6446
6447
6448/*
6449 * Component Instance : osc1timer0
6450 *
6451 * Instance osc1timer0 of component ALT_TMR.
6452 *
6453 *
6454 */
6455/* The address of the ALT_TMR_TMR1LDCOUNT register for the ALT_OSC1TMR0 instance. */
6456#define ALT_OSC1TMR0_TMR1LDCOUNT_ADDR ALT_TMR_TMR1LDCOUNT_ADDR(ALT_OSC1TMR0_ADDR)
6457/* The address of the ALT_TMR_TMR1CURVAL register for the ALT_OSC1TMR0 instance. */
6458#define ALT_OSC1TMR0_TMR1CURVAL_ADDR ALT_TMR_TMR1CURVAL_ADDR(ALT_OSC1TMR0_ADDR)
6459/* The address of the ALT_TMR_TMR1CTLREG register for the ALT_OSC1TMR0 instance. */
6460#define ALT_OSC1TMR0_TMR1CTLREG_ADDR ALT_TMR_TMR1CTLREG_ADDR(ALT_OSC1TMR0_ADDR)
6461/* The address of the ALT_TMR_TMR1EOI register for the ALT_OSC1TMR0 instance. */
6462#define ALT_OSC1TMR0_TMR1EOI_ADDR ALT_TMR_TMR1EOI_ADDR(ALT_OSC1TMR0_ADDR)
6463/* The address of the ALT_TMR_TMR1INTSTAT register for the ALT_OSC1TMR0 instance. */
6464#define ALT_OSC1TMR0_TMR1INTSTAT_ADDR ALT_TMR_TMR1INTSTAT_ADDR(ALT_OSC1TMR0_ADDR)
6465/* The address of the ALT_TMR_TMRSINTSTAT register for the ALT_OSC1TMR0 instance. */
6466#define ALT_OSC1TMR0_TMRSINTSTAT_ADDR ALT_TMR_TMRSINTSTAT_ADDR(ALT_OSC1TMR0_ADDR)
6467/* The address of the ALT_TMR_TMRSEOI register for the ALT_OSC1TMR0 instance. */
6468#define ALT_OSC1TMR0_TMRSEOI_ADDR ALT_TMR_TMRSEOI_ADDR(ALT_OSC1TMR0_ADDR)
6469/* The address of the ALT_TMR_TMRSRAWINTSTAT register for the ALT_OSC1TMR0 instance. */
6470#define ALT_OSC1TMR0_TMRSRAWINTSTAT_ADDR ALT_TMR_TMRSRAWINTSTAT_ADDR(ALT_OSC1TMR0_ADDR)
6471/* The address of the ALT_TMR_TMRSCOMPVER register for the ALT_OSC1TMR0 instance. */
6472#define ALT_OSC1TMR0_TMRSCOMPVER_ADDR ALT_TMR_TMRSCOMPVER_ADDR(ALT_OSC1TMR0_ADDR)
6473/* The base address byte offset for the start of the ALT_OSC1TMR0 component. */
6474#define ALT_OSC1TMR0_OFST 0xffd00000
6475/* The start address of the ALT_OSC1TMR0 component. */
6476#define ALT_OSC1TMR0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_OSC1TMR0_OFST))
6477/* The lower bound address range of the ALT_OSC1TMR0 component. */
6478#define ALT_OSC1TMR0_LB_ADDR ALT_OSC1TMR0_ADDR
6479/* The upper bound address range of the ALT_OSC1TMR0 component. */
6480#define ALT_OSC1TMR0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_OSC1TMR0_ADDR) + 0x100) - 1))
6481
6482
6483/*
6484 * Component Instance : osc1timer1
6485 *
6486 * Instance osc1timer1 of component ALT_TMR.
6487 *
6488 *
6489 */
6490/* The address of the ALT_TMR_TMR1LDCOUNT register for the ALT_OSC1TMR1 instance. */
6491#define ALT_OSC1TMR1_TMR1LDCOUNT_ADDR ALT_TMR_TMR1LDCOUNT_ADDR(ALT_OSC1TMR1_ADDR)
6492/* The address of the ALT_TMR_TMR1CURVAL register for the ALT_OSC1TMR1 instance. */
6493#define ALT_OSC1TMR1_TMR1CURVAL_ADDR ALT_TMR_TMR1CURVAL_ADDR(ALT_OSC1TMR1_ADDR)
6494/* The address of the ALT_TMR_TMR1CTLREG register for the ALT_OSC1TMR1 instance. */
6495#define ALT_OSC1TMR1_TMR1CTLREG_ADDR ALT_TMR_TMR1CTLREG_ADDR(ALT_OSC1TMR1_ADDR)
6496/* The address of the ALT_TMR_TMR1EOI register for the ALT_OSC1TMR1 instance. */
6497#define ALT_OSC1TMR1_TMR1EOI_ADDR ALT_TMR_TMR1EOI_ADDR(ALT_OSC1TMR1_ADDR)
6498/* The address of the ALT_TMR_TMR1INTSTAT register for the ALT_OSC1TMR1 instance. */
6499#define ALT_OSC1TMR1_TMR1INTSTAT_ADDR ALT_TMR_TMR1INTSTAT_ADDR(ALT_OSC1TMR1_ADDR)
6500/* The address of the ALT_TMR_TMRSINTSTAT register for the ALT_OSC1TMR1 instance. */
6501#define ALT_OSC1TMR1_TMRSINTSTAT_ADDR ALT_TMR_TMRSINTSTAT_ADDR(ALT_OSC1TMR1_ADDR)
6502/* The address of the ALT_TMR_TMRSEOI register for the ALT_OSC1TMR1 instance. */
6503#define ALT_OSC1TMR1_TMRSEOI_ADDR ALT_TMR_TMRSEOI_ADDR(ALT_OSC1TMR1_ADDR)
6504/* The address of the ALT_TMR_TMRSRAWINTSTAT register for the ALT_OSC1TMR1 instance. */
6505#define ALT_OSC1TMR1_TMRSRAWINTSTAT_ADDR ALT_TMR_TMRSRAWINTSTAT_ADDR(ALT_OSC1TMR1_ADDR)
6506/* The address of the ALT_TMR_TMRSCOMPVER register for the ALT_OSC1TMR1 instance. */
6507#define ALT_OSC1TMR1_TMRSCOMPVER_ADDR ALT_TMR_TMRSCOMPVER_ADDR(ALT_OSC1TMR1_ADDR)
6508/* The base address byte offset for the start of the ALT_OSC1TMR1 component. */
6509#define ALT_OSC1TMR1_OFST 0xffd01000
6510/* The start address of the ALT_OSC1TMR1 component. */
6511#define ALT_OSC1TMR1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_OSC1TMR1_OFST))
6512/* The lower bound address range of the ALT_OSC1TMR1 component. */
6513#define ALT_OSC1TMR1_LB_ADDR ALT_OSC1TMR1_ADDR
6514/* The upper bound address range of the ALT_OSC1TMR1 component. */
6515#define ALT_OSC1TMR1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_OSC1TMR1_ADDR) + 0x100) - 1))
6516
6517
6518/*
6519 * Component Instance : l4wd0
6520 *
6521 * Instance l4wd0 of component ALT_L4WD.
6522 *
6523 *
6524 */
6525/* The address of the ALT_L4WD_CR register for the ALT_L4WD0 instance. */
6526#define ALT_L4WD0_WDT_CR_ADDR ALT_L4WD_CR_ADDR(ALT_L4WD0_ADDR)
6527/* The address of the ALT_L4WD_TORR register for the ALT_L4WD0 instance. */
6528#define ALT_L4WD0_WDT_TORR_ADDR ALT_L4WD_TORR_ADDR(ALT_L4WD0_ADDR)
6529/* The address of the ALT_L4WD_CCVR register for the ALT_L4WD0 instance. */
6530#define ALT_L4WD0_WDT_CCVR_ADDR ALT_L4WD_CCVR_ADDR(ALT_L4WD0_ADDR)
6531/* The address of the ALT_L4WD_CRR register for the ALT_L4WD0 instance. */
6532#define ALT_L4WD0_WDT_CRR_ADDR ALT_L4WD_CRR_ADDR(ALT_L4WD0_ADDR)
6533/* The address of the ALT_L4WD_STAT register for the ALT_L4WD0 instance. */
6534#define ALT_L4WD0_WDT_STAT_ADDR ALT_L4WD_STAT_ADDR(ALT_L4WD0_ADDR)
6535/* The address of the ALT_L4WD_EOI register for the ALT_L4WD0 instance. */
6536#define ALT_L4WD0_WDT_EOI_ADDR ALT_L4WD_EOI_ADDR(ALT_L4WD0_ADDR)
6537/* The address of the ALT_L4WD_CP_WDT_USER_TOP_MAX register for the ALT_L4WD0 instance. */
6538#define ALT_L4WD0_CP_WDT_USER_TOP_MAX_ADDR ALT_L4WD_CP_WDT_USER_TOP_MAX_ADDR(ALT_L4WD0_ADDR)
6539/* The address of the ALT_L4WD_CP_WDT_USER_TOP_INIT_MAX register for the ALT_L4WD0 instance. */
6540#define ALT_L4WD0_CP_WDT_USER_TOP_INIT_MAX_ADDR ALT_L4WD_CP_WDT_USER_TOP_INIT_MAX_ADDR(ALT_L4WD0_ADDR)
6541/* The address of the ALT_L4WD_CD_WDT_TOP_RST register for the ALT_L4WD0 instance. */
6542#define ALT_L4WD0_CD_WDT_TOP_RST_ADDR ALT_L4WD_CD_WDT_TOP_RST_ADDR(ALT_L4WD0_ADDR)
6543/* The address of the ALT_L4WD_CP_WDT_CNT_RST register for the ALT_L4WD0 instance. */
6544#define ALT_L4WD0_CP_WDT_CNT_RST_ADDR ALT_L4WD_CP_WDT_CNT_RST_ADDR(ALT_L4WD0_ADDR)
6545/* The address of the ALT_L4WD_COMP_PARAM_1 register for the ALT_L4WD0 instance. */
6546#define ALT_L4WD0_WDT_COMP_PARAM_1_ADDR ALT_L4WD_COMP_PARAM_1_ADDR(ALT_L4WD0_ADDR)
6547/* The address of the ALT_L4WD_COMP_VER register for the ALT_L4WD0 instance. */
6548#define ALT_L4WD0_WDT_COMP_VER_ADDR ALT_L4WD_COMP_VER_ADDR(ALT_L4WD0_ADDR)
6549/* The address of the ALT_L4WD_COMP_TYPE register for the ALT_L4WD0 instance. */
6550#define ALT_L4WD0_WDT_COMP_TYPE_ADDR ALT_L4WD_COMP_TYPE_ADDR(ALT_L4WD0_ADDR)
6551/* The base address byte offset for the start of the ALT_L4WD0 component. */
6552#define ALT_L4WD0_OFST 0xffd02000
6553/* The start address of the ALT_L4WD0 component. */
6554#define ALT_L4WD0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_L4WD0_OFST))
6555/* The lower bound address range of the ALT_L4WD0 component. */
6556#define ALT_L4WD0_LB_ADDR ALT_L4WD0_ADDR
6557/* The upper bound address range of the ALT_L4WD0 component. */
6558#define ALT_L4WD0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L4WD0_ADDR) + 0x100) - 1))
6559
6560
6561/*
6562 * Component Instance : l4wd1
6563 *
6564 * Instance l4wd1 of component ALT_L4WD.
6565 *
6566 *
6567 */
6568/* The address of the ALT_L4WD_CR register for the ALT_L4WD1 instance. */
6569#define ALT_L4WD1_WDT_CR_ADDR ALT_L4WD_CR_ADDR(ALT_L4WD1_ADDR)
6570/* The address of the ALT_L4WD_TORR register for the ALT_L4WD1 instance. */
6571#define ALT_L4WD1_WDT_TORR_ADDR ALT_L4WD_TORR_ADDR(ALT_L4WD1_ADDR)
6572/* The address of the ALT_L4WD_CCVR register for the ALT_L4WD1 instance. */
6573#define ALT_L4WD1_WDT_CCVR_ADDR ALT_L4WD_CCVR_ADDR(ALT_L4WD1_ADDR)
6574/* The address of the ALT_L4WD_CRR register for the ALT_L4WD1 instance. */
6575#define ALT_L4WD1_WDT_CRR_ADDR ALT_L4WD_CRR_ADDR(ALT_L4WD1_ADDR)
6576/* The address of the ALT_L4WD_STAT register for the ALT_L4WD1 instance. */
6577#define ALT_L4WD1_WDT_STAT_ADDR ALT_L4WD_STAT_ADDR(ALT_L4WD1_ADDR)
6578/* The address of the ALT_L4WD_EOI register for the ALT_L4WD1 instance. */
6579#define ALT_L4WD1_WDT_EOI_ADDR ALT_L4WD_EOI_ADDR(ALT_L4WD1_ADDR)
6580/* The address of the ALT_L4WD_CP_WDT_USER_TOP_MAX register for the ALT_L4WD1 instance. */
6581#define ALT_L4WD1_CP_WDT_USER_TOP_MAX_ADDR ALT_L4WD_CP_WDT_USER_TOP_MAX_ADDR(ALT_L4WD1_ADDR)
6582/* The address of the ALT_L4WD_CP_WDT_USER_TOP_INIT_MAX register for the ALT_L4WD1 instance. */
6583#define ALT_L4WD1_CP_WDT_USER_TOP_INIT_MAX_ADDR ALT_L4WD_CP_WDT_USER_TOP_INIT_MAX_ADDR(ALT_L4WD1_ADDR)
6584/* The address of the ALT_L4WD_CD_WDT_TOP_RST register for the ALT_L4WD1 instance. */
6585#define ALT_L4WD1_CD_WDT_TOP_RST_ADDR ALT_L4WD_CD_WDT_TOP_RST_ADDR(ALT_L4WD1_ADDR)
6586/* The address of the ALT_L4WD_CP_WDT_CNT_RST register for the ALT_L4WD1 instance. */
6587#define ALT_L4WD1_CP_WDT_CNT_RST_ADDR ALT_L4WD_CP_WDT_CNT_RST_ADDR(ALT_L4WD1_ADDR)
6588/* The address of the ALT_L4WD_COMP_PARAM_1 register for the ALT_L4WD1 instance. */
6589#define ALT_L4WD1_WDT_COMP_PARAM_1_ADDR ALT_L4WD_COMP_PARAM_1_ADDR(ALT_L4WD1_ADDR)
6590/* The address of the ALT_L4WD_COMP_VER register for the ALT_L4WD1 instance. */
6591#define ALT_L4WD1_WDT_COMP_VER_ADDR ALT_L4WD_COMP_VER_ADDR(ALT_L4WD1_ADDR)
6592/* The address of the ALT_L4WD_COMP_TYPE register for the ALT_L4WD1 instance. */
6593#define ALT_L4WD1_WDT_COMP_TYPE_ADDR ALT_L4WD_COMP_TYPE_ADDR(ALT_L4WD1_ADDR)
6594/* The base address byte offset for the start of the ALT_L4WD1 component. */
6595#define ALT_L4WD1_OFST 0xffd03000
6596/* The start address of the ALT_L4WD1 component. */
6597#define ALT_L4WD1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_L4WD1_OFST))
6598/* The lower bound address range of the ALT_L4WD1 component. */
6599#define ALT_L4WD1_LB_ADDR ALT_L4WD1_ADDR
6600/* The upper bound address range of the ALT_L4WD1 component. */
6601#define ALT_L4WD1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L4WD1_ADDR) + 0x100) - 1))
6602
6603
6604/*
6605 * Component Instance : clkmgr
6606 *
6607 * Instance clkmgr of component ALT_CLKMGR.
6608 *
6609 *
6610 */
6611/* The address of the ALT_CLKMGR_CTL register for the ALT_CLKMGR instance. */
6612#define ALT_CLKMGR_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_CTL_OFST))
6613/* The address of the ALT_CLKMGR_BYPASS register for the ALT_CLKMGR instance. */
6614#define ALT_CLKMGR_BYPASS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_BYPASS_OFST))
6615/* The address of the ALT_CLKMGR_INTER register for the ALT_CLKMGR instance. */
6616#define ALT_CLKMGR_INTER_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_INTER_OFST))
6617/* The address of the ALT_CLKMGR_INTREN register for the ALT_CLKMGR instance. */
6618#define ALT_CLKMGR_INTREN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_INTREN_OFST))
6619/* The address of the ALT_CLKMGR_DBCTL register for the ALT_CLKMGR instance. */
6620#define ALT_CLKMGR_DBCTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_DBCTL_OFST))
6621/* The address of the ALT_CLKMGR_STAT register for the ALT_CLKMGR instance. */
6622#define ALT_CLKMGR_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_STAT_OFST))
6623/*
6624 * Register Group Instance : mainpllgrp
6625 *
6626 * Instance mainpllgrp of register group ALT_CLKMGR_MAINPLL.
6627 *
6628 *
6629 */
6630/* The address of the ALT_CLKMGR_MAINPLL_VCO register for the ALT_CLKMGR_MAINPLL instance. */
6631#define ALT_CLKMGR_MAINPLL_VCO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_VCO_OFST))
6632/* The address of the ALT_CLKMGR_MAINPLL_MISC register for the ALT_CLKMGR_MAINPLL instance. */
6633#define ALT_CLKMGR_MAINPLL_MISC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_MISC_OFST))
6634/* The address of the ALT_CLKMGR_MAINPLL_MPUCLK register for the ALT_CLKMGR_MAINPLL instance. */
6635#define ALT_CLKMGR_MAINPLL_MPUCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_MPUCLK_OFST))
6636/* The address of the ALT_CLKMGR_MAINPLL_MAINCLK register for the ALT_CLKMGR_MAINPLL instance. */
6637#define ALT_CLKMGR_MAINPLL_MAINCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_MAINCLK_OFST))
6638/* The address of the ALT_CLKMGR_MAINPLL_DBGATCLK register for the ALT_CLKMGR_MAINPLL instance. */
6639#define ALT_CLKMGR_MAINPLL_DBGATCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_DBGATCLK_OFST))
6640/* The address of the ALT_CLKMGR_MAINPLL_MAINQSPICLK register for the ALT_CLKMGR_MAINPLL instance. */
6641#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_MAINQSPICLK_OFST))
6642/* The address of the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK register for the ALT_CLKMGR_MAINPLL instance. */
6643#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_OFST))
6644/* The address of the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK register for the ALT_CLKMGR_MAINPLL instance. */
6645#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_OFST))
6646/* The address of the ALT_CLKMGR_MAINPLL_EN register for the ALT_CLKMGR_MAINPLL instance. */
6647#define ALT_CLKMGR_MAINPLL_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_EN_OFST))
6648/* The address of the ALT_CLKMGR_MAINPLL_MAINDIV register for the ALT_CLKMGR_MAINPLL instance. */
6649#define ALT_CLKMGR_MAINPLL_MAINDIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_MAINDIV_OFST))
6650/* The address of the ALT_CLKMGR_MAINPLL_DBGDIV register for the ALT_CLKMGR_MAINPLL instance. */
6651#define ALT_CLKMGR_MAINPLL_DBGDIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_DBGDIV_OFST))
6652/* The address of the ALT_CLKMGR_MAINPLL_TRACEDIV register for the ALT_CLKMGR_MAINPLL instance. */
6653#define ALT_CLKMGR_MAINPLL_TRACEDIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_TRACEDIV_OFST))
6654/* The address of the ALT_CLKMGR_MAINPLL_L4SRC register for the ALT_CLKMGR_MAINPLL instance. */
6655#define ALT_CLKMGR_MAINPLL_L4SRC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_L4SRC_OFST))
6656/* The address of the ALT_CLKMGR_MAINPLL_STAT register for the ALT_CLKMGR_MAINPLL instance. */
6657#define ALT_CLKMGR_MAINPLL_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_STAT_OFST))
6658/* The base address byte offset for the start of the ALT_CLKMGR_MAINPLL component. */
6659#define ALT_CLKMGR_MAINPLL_OFST 0x40
6660/* The start address of the ALT_CLKMGR_MAINPLL component. */
6661#define ALT_CLKMGR_MAINPLL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_MAINPLL_OFST))
6662/* The lower bound address range of the ALT_CLKMGR_MAINPLL component. */
6663#define ALT_CLKMGR_MAINPLL_LB_ADDR ALT_CLKMGR_MAINPLL_ADDR
6664/* The upper bound address range of the ALT_CLKMGR_MAINPLL component. */
6665#define ALT_CLKMGR_MAINPLL_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + 0x40) - 1))
6666
6667
6668/*
6669 * Register Group Instance : perpllgrp
6670 *
6671 * Instance perpllgrp of register group ALT_CLKMGR_PERPLL.
6672 *
6673 *
6674 */
6675/* The address of the ALT_CLKMGR_PERPLL_VCO register for the ALT_CLKMGR_PERPLL instance. */
6676#define ALT_CLKMGR_PERPLL_VCO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_VCO_OFST))
6677/* The address of the ALT_CLKMGR_PERPLL_MISC register for the ALT_CLKMGR_PERPLL instance. */
6678#define ALT_CLKMGR_PERPLL_MISC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_MISC_OFST))
6679/* The address of the ALT_CLKMGR_PERPLL_EMAC0CLK register for the ALT_CLKMGR_PERPLL instance. */
6680#define ALT_CLKMGR_PERPLL_EMAC0CLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_EMAC0CLK_OFST))
6681/* The address of the ALT_CLKMGR_PERPLL_EMAC1CLK register for the ALT_CLKMGR_PERPLL instance. */
6682#define ALT_CLKMGR_PERPLL_EMAC1CLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_EMAC1CLK_OFST))
6683/* The address of the ALT_CLKMGR_PERPLL_PERQSPICLK register for the ALT_CLKMGR_PERPLL instance. */
6684#define ALT_CLKMGR_PERPLL_PERQSPICLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_PERQSPICLK_OFST))
6685/* The address of the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK register for the ALT_CLKMGR_PERPLL instance. */
6686#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_OFST))
6687/* The address of the ALT_CLKMGR_PERPLL_PERBASECLK register for the ALT_CLKMGR_PERPLL instance. */
6688#define ALT_CLKMGR_PERPLL_PERBASECLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_PERBASECLK_OFST))
6689/* The address of the ALT_CLKMGR_PERPLL_S2FUSER1CLK register for the ALT_CLKMGR_PERPLL instance. */
6690#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_S2FUSER1CLK_OFST))
6691/* The address of the ALT_CLKMGR_PERPLL_EN register for the ALT_CLKMGR_PERPLL instance. */
6692#define ALT_CLKMGR_PERPLL_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_EN_OFST))
6693/* The address of the ALT_CLKMGR_PERPLL_DIV register for the ALT_CLKMGR_PERPLL instance. */
6694#define ALT_CLKMGR_PERPLL_DIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_DIV_OFST))
6695/* The address of the ALT_CLKMGR_PERPLL_GPIODIV register for the ALT_CLKMGR_PERPLL instance. */
6696#define ALT_CLKMGR_PERPLL_GPIODIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_GPIODIV_OFST))
6697/* The address of the ALT_CLKMGR_PERPLL_SRC register for the ALT_CLKMGR_PERPLL instance. */
6698#define ALT_CLKMGR_PERPLL_SRC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_SRC_OFST))
6699/* The address of the ALT_CLKMGR_PERPLL_STAT register for the ALT_CLKMGR_PERPLL instance. */
6700#define ALT_CLKMGR_PERPLL_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_STAT_OFST))
6701/* The base address byte offset for the start of the ALT_CLKMGR_PERPLL component. */
6702#define ALT_CLKMGR_PERPLL_OFST 0x80
6703/* The start address of the ALT_CLKMGR_PERPLL component. */
6704#define ALT_CLKMGR_PERPLL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_PERPLL_OFST))
6705/* The lower bound address range of the ALT_CLKMGR_PERPLL component. */
6706#define ALT_CLKMGR_PERPLL_LB_ADDR ALT_CLKMGR_PERPLL_ADDR
6707/* The upper bound address range of the ALT_CLKMGR_PERPLL component. */
6708#define ALT_CLKMGR_PERPLL_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + 0x40) - 1))
6709
6710
6711/*
6712 * Register Group Instance : sdrpllgrp
6713 *
6714 * Instance sdrpllgrp of register group ALT_CLKMGR_SDRPLL.
6715 *
6716 *
6717 */
6718/* The address of the ALT_CLKMGR_SDRPLL_VCO register for the ALT_CLKMGR_SDRPLL instance. */
6719#define ALT_CLKMGR_SDRPLL_VCO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_VCO_OFST))
6720/* The address of the ALT_CLKMGR_SDRPLL_CTL register for the ALT_CLKMGR_SDRPLL instance. */
6721#define ALT_CLKMGR_SDRPLL_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_CTL_OFST))
6722/* The address of the ALT_CLKMGR_SDRPLL_DDRDQSCLK register for the ALT_CLKMGR_SDRPLL instance. */
6723#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_DDRDQSCLK_OFST))
6724/* The address of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK register for the ALT_CLKMGR_SDRPLL instance. */
6725#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_OFST))
6726/* The address of the ALT_CLKMGR_SDRPLL_DDRDQCLK register for the ALT_CLKMGR_SDRPLL instance. */
6727#define ALT_CLKMGR_SDRPLL_DDRDQCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_DDRDQCLK_OFST))
6728/* The address of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK register for the ALT_CLKMGR_SDRPLL instance. */
6729#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_S2FUSER2CLK_OFST))
6730/* The address of the ALT_CLKMGR_SDRPLL_EN register for the ALT_CLKMGR_SDRPLL instance. */
6731#define ALT_CLKMGR_SDRPLL_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_EN_OFST))
6732/* The address of the ALT_CLKMGR_SDRPLL_STAT register for the ALT_CLKMGR_SDRPLL instance. */
6733#define ALT_CLKMGR_SDRPLL_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_STAT_OFST))
6734/* The base address byte offset for the start of the ALT_CLKMGR_SDRPLL component. */
6735#define ALT_CLKMGR_SDRPLL_OFST 0xc0
6736/* The start address of the ALT_CLKMGR_SDRPLL component. */
6737#define ALT_CLKMGR_SDRPLL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_SDRPLL_OFST))
6738/* The lower bound address range of the ALT_CLKMGR_SDRPLL component. */
6739#define ALT_CLKMGR_SDRPLL_LB_ADDR ALT_CLKMGR_SDRPLL_ADDR
6740/* The upper bound address range of the ALT_CLKMGR_SDRPLL component. */
6741#define ALT_CLKMGR_SDRPLL_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + 0x20) - 1))
6742
6743
6744/* The base address byte offset for the start of the ALT_CLKMGR component. */
6745#define ALT_CLKMGR_OFST 0xffd04000
6746/* The start address of the ALT_CLKMGR component. */
6747#define ALT_CLKMGR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_CLKMGR_OFST))
6748/* The lower bound address range of the ALT_CLKMGR component. */
6749#define ALT_CLKMGR_LB_ADDR ALT_CLKMGR_ADDR
6750/* The upper bound address range of the ALT_CLKMGR component. */
6751#define ALT_CLKMGR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CLKMGR_ADDR) + 0x200) - 1))
6752
6753
6754/*
6755 * Component Instance : rstmgr
6756 *
6757 * Instance rstmgr of component ALT_RSTMGR.
6758 *
6759 *
6760 */
6761/* The address of the ALT_RSTMGR_STAT register for the ALT_RSTMGR instance. */
6762#define ALT_RSTMGR_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_STAT_OFST))
6763/* The address of the ALT_RSTMGR_CTL register for the ALT_RSTMGR instance. */
6764#define ALT_RSTMGR_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_CTL_OFST))
6765/* The address of the ALT_RSTMGR_COUNTS register for the ALT_RSTMGR instance. */
6766#define ALT_RSTMGR_COUNTS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_COUNTS_OFST))
6767/* The address of the ALT_RSTMGR_MPUMODRST register for the ALT_RSTMGR instance. */
6768#define ALT_RSTMGR_MPUMODRST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_MPUMODRST_OFST))
6769/* The address of the ALT_RSTMGR_PERMODRST register for the ALT_RSTMGR instance. */
6770#define ALT_RSTMGR_PERMODRST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_PERMODRST_OFST))
6771/* The address of the ALT_RSTMGR_PER2MODRST register for the ALT_RSTMGR instance. */
6772#define ALT_RSTMGR_PER2MODRST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_PER2MODRST_OFST))
6773/* The address of the ALT_RSTMGR_BRGMODRST register for the ALT_RSTMGR instance. */
6774#define ALT_RSTMGR_BRGMODRST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_BRGMODRST_OFST))
6775/* The address of the ALT_RSTMGR_MISCMODRST register for the ALT_RSTMGR instance. */
6776#define ALT_RSTMGR_MISCMODRST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_MISCMODRST_OFST))
6777/* The base address byte offset for the start of the ALT_RSTMGR component. */
6778#define ALT_RSTMGR_OFST 0xffd05000
6779/* The start address of the ALT_RSTMGR component. */
6780#define ALT_RSTMGR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_RSTMGR_OFST))
6781/* The lower bound address range of the ALT_RSTMGR component. */
6782#define ALT_RSTMGR_LB_ADDR ALT_RSTMGR_ADDR
6783/* The upper bound address range of the ALT_RSTMGR component. */
6784#define ALT_RSTMGR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_RSTMGR_ADDR) + 0x100) - 1))
6785
6786
6787/*
6788 * Component Instance : sysmgr
6789 *
6790 * Instance sysmgr of component ALT_SYSMGR.
6791 *
6792 *
6793 */
6794/* The address of the ALT_SYSMGR_SILICONID1 register for the ALT_SYSMGR instance. */
6795#define ALT_SYSMGR_SILICONID1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_SILICONID1_OFST))
6796/* The address of the ALT_SYSMGR_SILICONID2 register for the ALT_SYSMGR instance. */
6797#define ALT_SYSMGR_SILICONID2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_SILICONID2_OFST))
6798/* The address of the ALT_SYSMGR_WDDBG register for the ALT_SYSMGR instance. */
6799#define ALT_SYSMGR_WDDBG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_WDDBG_OFST))
6800/* The address of the ALT_SYSMGR_BOOT register for the ALT_SYSMGR instance. */
6801#define ALT_SYSMGR_BOOT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_BOOT_OFST))
6802/* The address of the ALT_SYSMGR_HPSINFO register for the ALT_SYSMGR instance. */
6803#define ALT_SYSMGR_HPSINFO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_HPSINFO_OFST))
6804/* The address of the ALT_SYSMGR_PARITYINJ register for the ALT_SYSMGR instance. */
6805#define ALT_SYSMGR_PARITYINJ_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_PARITYINJ_OFST))
6806/*
6807 * Register Group Instance : fpgaintfgrp
6808 *
6809 * Instance fpgaintfgrp of register group ALT_SYSMGR_FPGAINTF.
6810 *
6811 *
6812 */
6813/* The address of the ALT_SYSMGR_FPGAINTF_GBL register for the ALT_SYSMGR_FPGAINTF instance. */
6814#define ALT_SYSMGR_FPGAINTF_GBL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FPGAINTF_ADDR) + ALT_SYSMGR_FPGAINTF_GBL_OFST))
6815/* The address of the ALT_SYSMGR_FPGAINTF_INDIV register for the ALT_SYSMGR_FPGAINTF instance. */
6816#define ALT_SYSMGR_FPGAINTF_INDIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FPGAINTF_ADDR) + ALT_SYSMGR_FPGAINTF_INDIV_OFST))
6817/* The address of the ALT_SYSMGR_FPGAINTF_MODULE register for the ALT_SYSMGR_FPGAINTF instance. */
6818#define ALT_SYSMGR_FPGAINTF_MODULE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FPGAINTF_ADDR) + ALT_SYSMGR_FPGAINTF_MODULE_OFST))
6819/* The base address byte offset for the start of the ALT_SYSMGR_FPGAINTF component. */
6820#define ALT_SYSMGR_FPGAINTF_OFST 0x20
6821/* The start address of the ALT_SYSMGR_FPGAINTF component. */
6822#define ALT_SYSMGR_FPGAINTF_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_FPGAINTF_OFST))
6823/* The lower bound address range of the ALT_SYSMGR_FPGAINTF component. */
6824#define ALT_SYSMGR_FPGAINTF_LB_ADDR ALT_SYSMGR_FPGAINTF_ADDR
6825/* The upper bound address range of the ALT_SYSMGR_FPGAINTF component. */
6826#define ALT_SYSMGR_FPGAINTF_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_FPGAINTF_ADDR) + 0x10) - 1))
6827
6828
6829/*
6830 * Register Group Instance : scanmgrgrp
6831 *
6832 * Instance scanmgrgrp of register group ALT_SYSMGR_SCANMGR.
6833 *
6834 *
6835 */
6836/* The address of the ALT_SYSMGR_SCANMGR_CTL register for the ALT_SYSMGR_SCANMGR instance. */
6837#define ALT_SYSMGR_SCANMGR_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_SCANMGR_ADDR) + ALT_SYSMGR_SCANMGR_CTL_OFST))
6838/* The base address byte offset for the start of the ALT_SYSMGR_SCANMGR component. */
6839#define ALT_SYSMGR_SCANMGR_OFST 0x30
6840/* The start address of the ALT_SYSMGR_SCANMGR component. */
6841#define ALT_SYSMGR_SCANMGR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_SCANMGR_OFST))
6842/* The lower bound address range of the ALT_SYSMGR_SCANMGR component. */
6843#define ALT_SYSMGR_SCANMGR_LB_ADDR ALT_SYSMGR_SCANMGR_ADDR
6844/* The upper bound address range of the ALT_SYSMGR_SCANMGR component. */
6845#define ALT_SYSMGR_SCANMGR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_SCANMGR_ADDR) + 0x4) - 1))
6846
6847
6848/*
6849 * Register Group Instance : frzctrl
6850 *
6851 * Instance frzctrl of register group ALT_SYSMGR_FRZCTL.
6852 *
6853 *
6854 */
6855/* The address of the ALT_SYSMGR_FRZCTL_VIOCTL register for the ALT_SYSMGR_FRZCTL instance. */
6856#define ALT_SYSMGR_FRZCTL_VIOCTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FRZCTL_ADDR) + ALT_SYSMGR_FRZCTL_VIOCTL_OFST))
6857/* The address of the ALT_SYSMGR_FRZCTL_HIOCTL register for the ALT_SYSMGR_FRZCTL instance. */
6858#define ALT_SYSMGR_FRZCTL_HIOCTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FRZCTL_ADDR) + ALT_SYSMGR_FRZCTL_HIOCTL_OFST))
6859/* The address of the ALT_SYSMGR_FRZCTL_SRC register for the ALT_SYSMGR_FRZCTL instance. */
6860#define ALT_SYSMGR_FRZCTL_SRC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FRZCTL_ADDR) + ALT_SYSMGR_FRZCTL_SRC_OFST))
6861/* The address of the ALT_SYSMGR_FRZCTL_HWCTL register for the ALT_SYSMGR_FRZCTL instance. */
6862#define ALT_SYSMGR_FRZCTL_HWCTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FRZCTL_ADDR) + ALT_SYSMGR_FRZCTL_HWCTL_OFST))
6863/* The base address byte offset for the start of the ALT_SYSMGR_FRZCTL component. */
6864#define ALT_SYSMGR_FRZCTL_OFST 0x40
6865/* The start address of the ALT_SYSMGR_FRZCTL component. */
6866#define ALT_SYSMGR_FRZCTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_FRZCTL_OFST))
6867/* The lower bound address range of the ALT_SYSMGR_FRZCTL component. */
6868#define ALT_SYSMGR_FRZCTL_LB_ADDR ALT_SYSMGR_FRZCTL_ADDR
6869/* The upper bound address range of the ALT_SYSMGR_FRZCTL component. */
6870#define ALT_SYSMGR_FRZCTL_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_FRZCTL_ADDR) + 0x20) - 1))
6871
6872
6873/*
6874 * Register Group Instance : emacgrp
6875 *
6876 * Instance emacgrp of register group ALT_SYSMGR_EMAC.
6877 *
6878 *
6879 */
6880/* The address of the ALT_SYSMGR_EMAC_CTL register for the ALT_SYSMGR_EMAC instance. */
6881#define ALT_SYSMGR_EMAC_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_EMAC_ADDR) + ALT_SYSMGR_EMAC_CTL_OFST))
6882/* The address of the ALT_SYSMGR_EMAC_L3MST register for the ALT_SYSMGR_EMAC instance. */
6883#define ALT_SYSMGR_EMAC_L3MST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_EMAC_ADDR) + ALT_SYSMGR_EMAC_L3MST_OFST))
6884/* The base address byte offset for the start of the ALT_SYSMGR_EMAC component. */
6885#define ALT_SYSMGR_EMAC_OFST 0x60
6886/* The start address of the ALT_SYSMGR_EMAC component. */
6887#define ALT_SYSMGR_EMAC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_EMAC_OFST))
6888/* The lower bound address range of the ALT_SYSMGR_EMAC component. */
6889#define ALT_SYSMGR_EMAC_LB_ADDR ALT_SYSMGR_EMAC_ADDR
6890/* The upper bound address range of the ALT_SYSMGR_EMAC component. */
6891#define ALT_SYSMGR_EMAC_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_EMAC_ADDR) + 0x10) - 1))
6892
6893
6894/*
6895 * Register Group Instance : dmagrp
6896 *
6897 * Instance dmagrp of register group ALT_SYSMGR_DMA.
6898 *
6899 *
6900 */
6901/* The address of the ALT_SYSMGR_DMA_CTL register for the ALT_SYSMGR_DMA instance. */
6902#define ALT_SYSMGR_DMA_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_DMA_ADDR) + ALT_SYSMGR_DMA_CTL_OFST))
6903/* The address of the ALT_SYSMGR_DMA_PERSECURITY register for the ALT_SYSMGR_DMA instance. */
6904#define ALT_SYSMGR_DMA_PERSECURITY_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_DMA_ADDR) + ALT_SYSMGR_DMA_PERSECURITY_OFST))
6905/* The base address byte offset for the start of the ALT_SYSMGR_DMA component. */
6906#define ALT_SYSMGR_DMA_OFST 0x70
6907/* The start address of the ALT_SYSMGR_DMA component. */
6908#define ALT_SYSMGR_DMA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_DMA_OFST))
6909/* The lower bound address range of the ALT_SYSMGR_DMA component. */
6910#define ALT_SYSMGR_DMA_LB_ADDR ALT_SYSMGR_DMA_ADDR
6911/* The upper bound address range of the ALT_SYSMGR_DMA component. */
6912#define ALT_SYSMGR_DMA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_DMA_ADDR) + 0x8) - 1))
6913
6914
6915/*
6916 * Register Group Instance : iswgrp
6917 *
6918 * Instance iswgrp of register group ALT_SYSMGR_ISW.
6919 *
6920 *
6921 */
6922/* The address of the ALT_SYSMGR_ISW_HANDOFF register for the ALT_SYSMGR_ISW instance. */
6923#define ALT_SYSMGR_ISW_HANDOFF_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ISW_ADDR) + ALT_SYSMGR_ISW_HANDOFF_OFST))
6924/* The base address byte offset for the start of the ALT_SYSMGR_ISW component. */
6925#define ALT_SYSMGR_ISW_OFST 0x80
6926/* The start address of the ALT_SYSMGR_ISW component. */
6927#define ALT_SYSMGR_ISW_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_ISW_OFST))
6928/* The lower bound address range of the ALT_SYSMGR_ISW component. */
6929#define ALT_SYSMGR_ISW_LB_ADDR ALT_SYSMGR_ISW_ADDR
6930/* The upper bound address range of the ALT_SYSMGR_ISW component. */
6931#define ALT_SYSMGR_ISW_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_ISW_ADDR) + 0x20) - 1))
6932
6933
6934/*
6935 * Register Group Instance : romcodegrp
6936 *
6937 * Instance romcodegrp of register group ALT_SYSMGR_ROMCODE.
6938 *
6939 *
6940 */
6941/* The address of the ALT_SYSMGR_ROMCODE_CTL register for the ALT_SYSMGR_ROMCODE instance. */
6942#define ALT_SYSMGR_ROMCODE_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + ALT_SYSMGR_ROMCODE_CTL_OFST))
6943/* The address of the ALT_SYSMGR_ROMCODE_CPU1STARTADDR register for the ALT_SYSMGR_ROMCODE instance. */
6944#define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + ALT_SYSMGR_ROMCODE_CPU1STARTADDR_OFST))
6945/* The address of the ALT_SYSMGR_ROMCODE_INITSWSTATE register for the ALT_SYSMGR_ROMCODE instance. */
6946#define ALT_SYSMGR_ROMCODE_INITSWSTATE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + ALT_SYSMGR_ROMCODE_INITSWSTATE_OFST))
6947/* The address of the ALT_SYSMGR_ROMCODE_INITSWLASTLD register for the ALT_SYSMGR_ROMCODE instance. */
6948#define ALT_SYSMGR_ROMCODE_INITSWLASTLD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + ALT_SYSMGR_ROMCODE_INITSWLASTLD_OFST))
6949/* The address of the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE register for the ALT_SYSMGR_ROMCODE instance. */
6950#define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_OFST))
6951/*
6952 * Register Group Instance : romcodegrp_warmramgrp
6953 *
6954 * Instance romcodegrp_warmramgrp of register group ALT_SYSMGR_ROMCODE_WARMRAM.
6955 *
6956 *
6957 */
6958/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_EN register for the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP instance. */
6959#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAM_EN_ADDR ALT_SYSMGR_ROMCODE_WARMRAM_EN_ADDR(ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR)
6960/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART register for the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP instance. */
6961#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAM_DATASTART_ADDR ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_ADDR(ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR)
6962/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN register for the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP instance. */
6963#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAM_LEN_ADDR ALT_SYSMGR_ROMCODE_WARMRAM_LEN_ADDR(ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR)
6964/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION register for the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP instance. */
6965#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAM_EXECUTION_ADDR ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_ADDR(ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR)
6966/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC register for the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP instance. */
6967#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAM_CRC_ADDR ALT_SYSMGR_ROMCODE_WARMRAM_CRC_ADDR(ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR)
6968/* The base address byte offset for the start of the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP component. */
6969#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_OFST 0x20
6970/* The start address of the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP component. */
6971#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_OFST))
6972/* The lower bound address range of the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP component. */
6973#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_LB_ADDR ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR
6974/* The upper bound address range of the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP component. */
6975#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR) + 0x20) - 1))
6976
6977
6978/* The base address byte offset for the start of the ALT_SYSMGR_ROMCODE component. */
6979#define ALT_SYSMGR_ROMCODE_OFST 0xc0
6980/* The start address of the ALT_SYSMGR_ROMCODE component. */
6981#define ALT_SYSMGR_ROMCODE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_ROMCODE_OFST))
6982/* The lower bound address range of the ALT_SYSMGR_ROMCODE component. */
6983#define ALT_SYSMGR_ROMCODE_LB_ADDR ALT_SYSMGR_ROMCODE_ADDR
6984/* The upper bound address range of the ALT_SYSMGR_ROMCODE component. */
6985#define ALT_SYSMGR_ROMCODE_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + 0x40) - 1))
6986
6987
6988/*
6989 * Register Group Instance : romhwgrp
6990 *
6991 * Instance romhwgrp of register group ALT_SYSMGR_ROMHW.
6992 *
6993 *
6994 */
6995/* The address of the ALT_SYSMGR_ROMHW_CTL register for the ALT_SYSMGR_ROMHW instance. */
6996#define ALT_SYSMGR_ROMHW_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMHW_ADDR) + ALT_SYSMGR_ROMHW_CTL_OFST))
6997/* The base address byte offset for the start of the ALT_SYSMGR_ROMHW component. */
6998#define ALT_SYSMGR_ROMHW_OFST 0x100
6999/* The start address of the ALT_SYSMGR_ROMHW component. */
7000#define ALT_SYSMGR_ROMHW_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_ROMHW_OFST))
7001/* The lower bound address range of the ALT_SYSMGR_ROMHW component. */
7002#define ALT_SYSMGR_ROMHW_LB_ADDR ALT_SYSMGR_ROMHW_ADDR
7003/* The upper bound address range of the ALT_SYSMGR_ROMHW component. */
7004#define ALT_SYSMGR_ROMHW_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_ROMHW_ADDR) + 0x4) - 1))
7005
7006
7007/*
7008 * Register Group Instance : sdmmcgrp
7009 *
7010 * Instance sdmmcgrp of register group ALT_SYSMGR_SDMMC.
7011 *
7012 *
7013 */
7014/* The address of the ALT_SYSMGR_SDMMC_CTL register for the ALT_SYSMGR_SDMMC instance. */
7015#define ALT_SYSMGR_SDMMC_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_SDMMC_ADDR) + ALT_SYSMGR_SDMMC_CTL_OFST))
7016/* The address of the ALT_SYSMGR_SDMMC_L3MST register for the ALT_SYSMGR_SDMMC instance. */
7017#define ALT_SYSMGR_SDMMC_L3MST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_SDMMC_ADDR) + ALT_SYSMGR_SDMMC_L3MST_OFST))
7018/* The base address byte offset for the start of the ALT_SYSMGR_SDMMC component. */
7019#define ALT_SYSMGR_SDMMC_OFST 0x108
7020/* The start address of the ALT_SYSMGR_SDMMC component. */
7021#define ALT_SYSMGR_SDMMC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_SDMMC_OFST))
7022/* The lower bound address range of the ALT_SYSMGR_SDMMC component. */
7023#define ALT_SYSMGR_SDMMC_LB_ADDR ALT_SYSMGR_SDMMC_ADDR
7024/* The upper bound address range of the ALT_SYSMGR_SDMMC component. */
7025#define ALT_SYSMGR_SDMMC_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_SDMMC_ADDR) + 0x8) - 1))
7026
7027
7028/*
7029 * Register Group Instance : nandgrp
7030 *
7031 * Instance nandgrp of register group ALT_SYSMGR_NAND.
7032 *
7033 *
7034 */
7035/* The address of the ALT_SYSMGR_NAND_BOOTSTRAP register for the ALT_SYSMGR_NAND instance. */
7036#define ALT_SYSMGR_NAND_BOOTSTRAP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_NAND_ADDR) + ALT_SYSMGR_NAND_BOOTSTRAP_OFST))
7037/* The address of the ALT_SYSMGR_NAND_L3MST register for the ALT_SYSMGR_NAND instance. */
7038#define ALT_SYSMGR_NAND_L3MST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_NAND_ADDR) + ALT_SYSMGR_NAND_L3MST_OFST))
7039/* The base address byte offset for the start of the ALT_SYSMGR_NAND component. */
7040#define ALT_SYSMGR_NAND_OFST 0x110
7041/* The start address of the ALT_SYSMGR_NAND component. */
7042#define ALT_SYSMGR_NAND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_NAND_OFST))
7043/* The lower bound address range of the ALT_SYSMGR_NAND component. */
7044#define ALT_SYSMGR_NAND_LB_ADDR ALT_SYSMGR_NAND_ADDR
7045/* The upper bound address range of the ALT_SYSMGR_NAND component. */
7046#define ALT_SYSMGR_NAND_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_NAND_ADDR) + 0x8) - 1))
7047
7048
7049/*
7050 * Register Group Instance : usbgrp
7051 *
7052 * Instance usbgrp of register group ALT_SYSMGR_USB.
7053 *
7054 *
7055 */
7056/* The address of the ALT_SYSMGR_USB_L3MST register for the ALT_SYSMGR_USB instance. */
7057#define ALT_SYSMGR_USB_L3MST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_USB_ADDR) + ALT_SYSMGR_USB_L3MST_OFST))
7058/* The base address byte offset for the start of the ALT_SYSMGR_USB component. */
7059#define ALT_SYSMGR_USB_OFST 0x118
7060/* The start address of the ALT_SYSMGR_USB component. */
7061#define ALT_SYSMGR_USB_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_USB_OFST))
7062/* The lower bound address range of the ALT_SYSMGR_USB component. */
7063#define ALT_SYSMGR_USB_LB_ADDR ALT_SYSMGR_USB_ADDR
7064/* The upper bound address range of the ALT_SYSMGR_USB component. */
7065#define ALT_SYSMGR_USB_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_USB_ADDR) + 0x4) - 1))
7066
7067
7068/*
7069 * Register Group Instance : eccgrp
7070 *
7071 * Instance eccgrp of register group ALT_SYSMGR_ECC.
7072 *
7073 *
7074 */
7075/* The address of the ALT_SYSMGR_ECC_L2 register for the ALT_SYSMGR_ECC instance. */
7076#define ALT_SYSMGR_ECC_L2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_L2_OFST))
7077/* The address of the ALT_SYSMGR_ECC_OCRAM register for the ALT_SYSMGR_ECC instance. */
7078#define ALT_SYSMGR_ECC_OCRAM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_OCRAM_OFST))
7079/* The address of the ALT_SYSMGR_ECC_USB0 register for the ALT_SYSMGR_ECC instance. */
7080#define ALT_SYSMGR_ECC_USB0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_USB0_OFST))
7081/* The address of the ALT_SYSMGR_ECC_USB1 register for the ALT_SYSMGR_ECC instance. */
7082#define ALT_SYSMGR_ECC_USB1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_USB1_OFST))
7083/* The address of the ALT_SYSMGR_ECC_EMAC0 register for the ALT_SYSMGR_ECC instance. */
7084#define ALT_SYSMGR_ECC_EMAC0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_EMAC0_OFST))
7085/* The address of the ALT_SYSMGR_ECC_EMAC1 register for the ALT_SYSMGR_ECC instance. */
7086#define ALT_SYSMGR_ECC_EMAC1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_EMAC1_OFST))
7087/* The address of the ALT_SYSMGR_ECC_DMA register for the ALT_SYSMGR_ECC instance. */
7088#define ALT_SYSMGR_ECC_DMA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_DMA_OFST))
7089/* The address of the ALT_SYSMGR_ECC_CAN0 register for the ALT_SYSMGR_ECC instance. */
7090#define ALT_SYSMGR_ECC_CAN0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_CAN0_OFST))
7091/* The address of the ALT_SYSMGR_ECC_CAN1 register for the ALT_SYSMGR_ECC instance. */
7092#define ALT_SYSMGR_ECC_CAN1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_CAN1_OFST))
7093/* The address of the ALT_SYSMGR_ECC_NAND register for the ALT_SYSMGR_ECC instance. */
7094#define ALT_SYSMGR_ECC_NAND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_NAND_OFST))
7095/* The address of the ALT_SYSMGR_ECC_QSPI register for the ALT_SYSMGR_ECC instance. */
7096#define ALT_SYSMGR_ECC_QSPI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_QSPI_OFST))
7097/* The address of the ALT_SYSMGR_ECC_SDMMC register for the ALT_SYSMGR_ECC instance. */
7098#define ALT_SYSMGR_ECC_SDMMC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_SDMMC_OFST))
7099/* The base address byte offset for the start of the ALT_SYSMGR_ECC component. */
7100#define ALT_SYSMGR_ECC_OFST 0x140
7101/* The start address of the ALT_SYSMGR_ECC component. */
7102#define ALT_SYSMGR_ECC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_ECC_OFST))
7103/* The lower bound address range of the ALT_SYSMGR_ECC component. */
7104#define ALT_SYSMGR_ECC_LB_ADDR ALT_SYSMGR_ECC_ADDR
7105/* The upper bound address range of the ALT_SYSMGR_ECC component. */
7106#define ALT_SYSMGR_ECC_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + 0x40) - 1))
7107
7108
7109/*
7110 * Register Group Instance : pinmuxgrp
7111 *
7112 * Instance pinmuxgrp of register group ALT_SYSMGR_PINMUX.
7113 *
7114 *
7115 */
7116/* The address of the ALT_SYSMGR_PINMUX_EMACIO0 register for the ALT_SYSMGR_PINMUX instance. */
7117#define ALT_SYSMGR_PINMUX_EMACIO0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO0_OFST))
7118/* The address of the ALT_SYSMGR_PINMUX_EMACIO1 register for the ALT_SYSMGR_PINMUX instance. */
7119#define ALT_SYSMGR_PINMUX_EMACIO1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO1_OFST))
7120/* The address of the ALT_SYSMGR_PINMUX_EMACIO2 register for the ALT_SYSMGR_PINMUX instance. */
7121#define ALT_SYSMGR_PINMUX_EMACIO2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO2_OFST))
7122/* The address of the ALT_SYSMGR_PINMUX_EMACIO3 register for the ALT_SYSMGR_PINMUX instance. */
7123#define ALT_SYSMGR_PINMUX_EMACIO3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO3_OFST))
7124/* The address of the ALT_SYSMGR_PINMUX_EMACIO4 register for the ALT_SYSMGR_PINMUX instance. */
7125#define ALT_SYSMGR_PINMUX_EMACIO4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO4_OFST))
7126/* The address of the ALT_SYSMGR_PINMUX_EMACIO5 register for the ALT_SYSMGR_PINMUX instance. */
7127#define ALT_SYSMGR_PINMUX_EMACIO5_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO5_OFST))
7128/* The address of the ALT_SYSMGR_PINMUX_EMACIO6 register for the ALT_SYSMGR_PINMUX instance. */
7129#define ALT_SYSMGR_PINMUX_EMACIO6_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO6_OFST))
7130/* The address of the ALT_SYSMGR_PINMUX_EMACIO7 register for the ALT_SYSMGR_PINMUX instance. */
7131#define ALT_SYSMGR_PINMUX_EMACIO7_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO7_OFST))
7132/* The address of the ALT_SYSMGR_PINMUX_EMACIO8 register for the ALT_SYSMGR_PINMUX instance. */
7133#define ALT_SYSMGR_PINMUX_EMACIO8_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO8_OFST))
7134/* The address of the ALT_SYSMGR_PINMUX_EMACIO9 register for the ALT_SYSMGR_PINMUX instance. */
7135#define ALT_SYSMGR_PINMUX_EMACIO9_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO9_OFST))
7136/* The address of the ALT_SYSMGR_PINMUX_EMACIO10 register for the ALT_SYSMGR_PINMUX instance. */
7137#define ALT_SYSMGR_PINMUX_EMACIO10_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO10_OFST))
7138/* The address of the ALT_SYSMGR_PINMUX_EMACIO11 register for the ALT_SYSMGR_PINMUX instance. */
7139#define ALT_SYSMGR_PINMUX_EMACIO11_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO11_OFST))
7140/* The address of the ALT_SYSMGR_PINMUX_EMACIO12 register for the ALT_SYSMGR_PINMUX instance. */
7141#define ALT_SYSMGR_PINMUX_EMACIO12_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO12_OFST))
7142/* The address of the ALT_SYSMGR_PINMUX_EMACIO13 register for the ALT_SYSMGR_PINMUX instance. */
7143#define ALT_SYSMGR_PINMUX_EMACIO13_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO13_OFST))
7144/* The address of the ALT_SYSMGR_PINMUX_EMACIO14 register for the ALT_SYSMGR_PINMUX instance. */
7145#define ALT_SYSMGR_PINMUX_EMACIO14_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO14_OFST))
7146/* The address of the ALT_SYSMGR_PINMUX_EMACIO15 register for the ALT_SYSMGR_PINMUX instance. */
7147#define ALT_SYSMGR_PINMUX_EMACIO15_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO15_OFST))
7148/* The address of the ALT_SYSMGR_PINMUX_EMACIO16 register for the ALT_SYSMGR_PINMUX instance. */
7149#define ALT_SYSMGR_PINMUX_EMACIO16_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO16_OFST))
7150/* The address of the ALT_SYSMGR_PINMUX_EMACIO17 register for the ALT_SYSMGR_PINMUX instance. */
7151#define ALT_SYSMGR_PINMUX_EMACIO17_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO17_OFST))
7152/* The address of the ALT_SYSMGR_PINMUX_EMACIO18 register for the ALT_SYSMGR_PINMUX instance. */
7153#define ALT_SYSMGR_PINMUX_EMACIO18_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO18_OFST))
7154/* The address of the ALT_SYSMGR_PINMUX_EMACIO19 register for the ALT_SYSMGR_PINMUX instance. */
7155#define ALT_SYSMGR_PINMUX_EMACIO19_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO19_OFST))
7156/* The address of the ALT_SYSMGR_PINMUX_FLSHIO0 register for the ALT_SYSMGR_PINMUX instance. */
7157#define ALT_SYSMGR_PINMUX_FLSHIO0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO0_OFST))
7158/* The address of the ALT_SYSMGR_PINMUX_FLSHIO1 register for the ALT_SYSMGR_PINMUX instance. */
7159#define ALT_SYSMGR_PINMUX_FLSHIO1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO1_OFST))
7160/* The address of the ALT_SYSMGR_PINMUX_FLSHIO2 register for the ALT_SYSMGR_PINMUX instance. */
7161#define ALT_SYSMGR_PINMUX_FLSHIO2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO2_OFST))
7162/* The address of the ALT_SYSMGR_PINMUX_FLSHIO3 register for the ALT_SYSMGR_PINMUX instance. */
7163#define ALT_SYSMGR_PINMUX_FLSHIO3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO3_OFST))
7164/* The address of the ALT_SYSMGR_PINMUX_FLSHIO4 register for the ALT_SYSMGR_PINMUX instance. */
7165#define ALT_SYSMGR_PINMUX_FLSHIO4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO4_OFST))
7166/* The address of the ALT_SYSMGR_PINMUX_FLSHIO5 register for the ALT_SYSMGR_PINMUX instance. */
7167#define ALT_SYSMGR_PINMUX_FLSHIO5_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO5_OFST))
7168/* The address of the ALT_SYSMGR_PINMUX_FLSHIO6 register for the ALT_SYSMGR_PINMUX instance. */
7169#define ALT_SYSMGR_PINMUX_FLSHIO6_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO6_OFST))
7170/* The address of the ALT_SYSMGR_PINMUX_FLSHIO7 register for the ALT_SYSMGR_PINMUX instance. */
7171#define ALT_SYSMGR_PINMUX_FLSHIO7_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO7_OFST))
7172/* The address of the ALT_SYSMGR_PINMUX_FLSHIO8 register for the ALT_SYSMGR_PINMUX instance. */
7173#define ALT_SYSMGR_PINMUX_FLSHIO8_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO8_OFST))
7174/* The address of the ALT_SYSMGR_PINMUX_FLSHIO9 register for the ALT_SYSMGR_PINMUX instance. */
7175#define ALT_SYSMGR_PINMUX_FLSHIO9_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO9_OFST))
7176/* The address of the ALT_SYSMGR_PINMUX_FLSHIO10 register for the ALT_SYSMGR_PINMUX instance. */
7177#define ALT_SYSMGR_PINMUX_FLSHIO10_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO10_OFST))
7178/* The address of the ALT_SYSMGR_PINMUX_FLSHIO11 register for the ALT_SYSMGR_PINMUX instance. */
7179#define ALT_SYSMGR_PINMUX_FLSHIO11_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO11_OFST))
7180/* The address of the ALT_SYSMGR_PINMUX_GENERALIO0 register for the ALT_SYSMGR_PINMUX instance. */
7181#define ALT_SYSMGR_PINMUX_GENERALIO0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO0_OFST))
7182/* The address of the ALT_SYSMGR_PINMUX_GENERALIO1 register for the ALT_SYSMGR_PINMUX instance. */
7183#define ALT_SYSMGR_PINMUX_GENERALIO1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO1_OFST))
7184/* The address of the ALT_SYSMGR_PINMUX_GENERALIO2 register for the ALT_SYSMGR_PINMUX instance. */
7185#define ALT_SYSMGR_PINMUX_GENERALIO2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO2_OFST))
7186/* The address of the ALT_SYSMGR_PINMUX_GENERALIO3 register for the ALT_SYSMGR_PINMUX instance. */
7187#define ALT_SYSMGR_PINMUX_GENERALIO3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO3_OFST))
7188/* The address of the ALT_SYSMGR_PINMUX_GENERALIO4 register for the ALT_SYSMGR_PINMUX instance. */
7189#define ALT_SYSMGR_PINMUX_GENERALIO4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO4_OFST))
7190/* The address of the ALT_SYSMGR_PINMUX_GENERALIO5 register for the ALT_SYSMGR_PINMUX instance. */
7191#define ALT_SYSMGR_PINMUX_GENERALIO5_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO5_OFST))
7192/* The address of the ALT_SYSMGR_PINMUX_GENERALIO6 register for the ALT_SYSMGR_PINMUX instance. */
7193#define ALT_SYSMGR_PINMUX_GENERALIO6_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO6_OFST))
7194/* The address of the ALT_SYSMGR_PINMUX_GENERALIO7 register for the ALT_SYSMGR_PINMUX instance. */
7195#define ALT_SYSMGR_PINMUX_GENERALIO7_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO7_OFST))
7196/* The address of the ALT_SYSMGR_PINMUX_GENERALIO8 register for the ALT_SYSMGR_PINMUX instance. */
7197#define ALT_SYSMGR_PINMUX_GENERALIO8_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO8_OFST))
7198/* The address of the ALT_SYSMGR_PINMUX_GENERALIO9 register for the ALT_SYSMGR_PINMUX instance. */
7199#define ALT_SYSMGR_PINMUX_GENERALIO9_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO9_OFST))
7200/* The address of the ALT_SYSMGR_PINMUX_GENERALIO10 register for the ALT_SYSMGR_PINMUX instance. */
7201#define ALT_SYSMGR_PINMUX_GENERALIO10_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO10_OFST))
7202/* The address of the ALT_SYSMGR_PINMUX_GENERALIO11 register for the ALT_SYSMGR_PINMUX instance. */
7203#define ALT_SYSMGR_PINMUX_GENERALIO11_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO11_OFST))
7204/* The address of the ALT_SYSMGR_PINMUX_GENERALIO12 register for the ALT_SYSMGR_PINMUX instance. */
7205#define ALT_SYSMGR_PINMUX_GENERALIO12_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO12_OFST))
7206/* The address of the ALT_SYSMGR_PINMUX_GENERALIO13 register for the ALT_SYSMGR_PINMUX instance. */
7207#define ALT_SYSMGR_PINMUX_GENERALIO13_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO13_OFST))
7208/* The address of the ALT_SYSMGR_PINMUX_GENERALIO14 register for the ALT_SYSMGR_PINMUX instance. */
7209#define ALT_SYSMGR_PINMUX_GENERALIO14_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO14_OFST))
7210/* The address of the ALT_SYSMGR_PINMUX_GENERALIO15 register for the ALT_SYSMGR_PINMUX instance. */
7211#define ALT_SYSMGR_PINMUX_GENERALIO15_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO15_OFST))
7212/* The address of the ALT_SYSMGR_PINMUX_GENERALIO16 register for the ALT_SYSMGR_PINMUX instance. */
7213#define ALT_SYSMGR_PINMUX_GENERALIO16_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO16_OFST))
7214/* The address of the ALT_SYSMGR_PINMUX_GENERALIO17 register for the ALT_SYSMGR_PINMUX instance. */
7215#define ALT_SYSMGR_PINMUX_GENERALIO17_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO17_OFST))
7216/* The address of the ALT_SYSMGR_PINMUX_GENERALIO18 register for the ALT_SYSMGR_PINMUX instance. */
7217#define ALT_SYSMGR_PINMUX_GENERALIO18_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO18_OFST))
7218/* The address of the ALT_SYSMGR_PINMUX_GENERALIO19 register for the ALT_SYSMGR_PINMUX instance. */
7219#define ALT_SYSMGR_PINMUX_GENERALIO19_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO19_OFST))
7220/* The address of the ALT_SYSMGR_PINMUX_GENERALIO20 register for the ALT_SYSMGR_PINMUX instance. */
7221#define ALT_SYSMGR_PINMUX_GENERALIO20_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO20_OFST))
7222/* The address of the ALT_SYSMGR_PINMUX_GENERALIO21 register for the ALT_SYSMGR_PINMUX instance. */
7223#define ALT_SYSMGR_PINMUX_GENERALIO21_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO21_OFST))
7224/* The address of the ALT_SYSMGR_PINMUX_GENERALIO22 register for the ALT_SYSMGR_PINMUX instance. */
7225#define ALT_SYSMGR_PINMUX_GENERALIO22_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO22_OFST))
7226/* The address of the ALT_SYSMGR_PINMUX_GENERALIO23 register for the ALT_SYSMGR_PINMUX instance. */
7227#define ALT_SYSMGR_PINMUX_GENERALIO23_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO23_OFST))
7228/* The address of the ALT_SYSMGR_PINMUX_GENERALIO24 register for the ALT_SYSMGR_PINMUX instance. */
7229#define ALT_SYSMGR_PINMUX_GENERALIO24_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO24_OFST))
7230/* The address of the ALT_SYSMGR_PINMUX_GENERALIO25 register for the ALT_SYSMGR_PINMUX instance. */
7231#define ALT_SYSMGR_PINMUX_GENERALIO25_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO25_OFST))
7232/* The address of the ALT_SYSMGR_PINMUX_GENERALIO26 register for the ALT_SYSMGR_PINMUX instance. */
7233#define ALT_SYSMGR_PINMUX_GENERALIO26_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO26_OFST))
7234/* The address of the ALT_SYSMGR_PINMUX_GENERALIO27 register for the ALT_SYSMGR_PINMUX instance. */
7235#define ALT_SYSMGR_PINMUX_GENERALIO27_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO27_OFST))
7236/* The address of the ALT_SYSMGR_PINMUX_GENERALIO28 register for the ALT_SYSMGR_PINMUX instance. */
7237#define ALT_SYSMGR_PINMUX_GENERALIO28_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO28_OFST))
7238/* The address of the ALT_SYSMGR_PINMUX_GENERALIO29 register for the ALT_SYSMGR_PINMUX instance. */
7239#define ALT_SYSMGR_PINMUX_GENERALIO29_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO29_OFST))
7240/* The address of the ALT_SYSMGR_PINMUX_GENERALIO30 register for the ALT_SYSMGR_PINMUX instance. */
7241#define ALT_SYSMGR_PINMUX_GENERALIO30_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO30_OFST))
7242/* The address of the ALT_SYSMGR_PINMUX_GENERALIO31 register for the ALT_SYSMGR_PINMUX instance. */
7243#define ALT_SYSMGR_PINMUX_GENERALIO31_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO31_OFST))
7244/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO0 register for the ALT_SYSMGR_PINMUX instance. */
7245#define ALT_SYSMGR_PINMUX_MIXED1IO0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO0_OFST))
7246/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO1 register for the ALT_SYSMGR_PINMUX instance. */
7247#define ALT_SYSMGR_PINMUX_MIXED1IO1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO1_OFST))
7248/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO2 register for the ALT_SYSMGR_PINMUX instance. */
7249#define ALT_SYSMGR_PINMUX_MIXED1IO2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO2_OFST))
7250/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO3 register for the ALT_SYSMGR_PINMUX instance. */
7251#define ALT_SYSMGR_PINMUX_MIXED1IO3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO3_OFST))
7252/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO4 register for the ALT_SYSMGR_PINMUX instance. */
7253#define ALT_SYSMGR_PINMUX_MIXED1IO4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO4_OFST))
7254/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO5 register for the ALT_SYSMGR_PINMUX instance. */
7255#define ALT_SYSMGR_PINMUX_MIXED1IO5_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO5_OFST))
7256/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO6 register for the ALT_SYSMGR_PINMUX instance. */
7257#define ALT_SYSMGR_PINMUX_MIXED1IO6_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO6_OFST))
7258/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO7 register for the ALT_SYSMGR_PINMUX instance. */
7259#define ALT_SYSMGR_PINMUX_MIXED1IO7_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO7_OFST))
7260/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO8 register for the ALT_SYSMGR_PINMUX instance. */
7261#define ALT_SYSMGR_PINMUX_MIXED1IO8_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO8_OFST))
7262/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO9 register for the ALT_SYSMGR_PINMUX instance. */
7263#define ALT_SYSMGR_PINMUX_MIXED1IO9_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO9_OFST))
7264/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO10 register for the ALT_SYSMGR_PINMUX instance. */
7265#define ALT_SYSMGR_PINMUX_MIXED1IO10_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO10_OFST))
7266/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO11 register for the ALT_SYSMGR_PINMUX instance. */
7267#define ALT_SYSMGR_PINMUX_MIXED1IO11_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO11_OFST))
7268/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO12 register for the ALT_SYSMGR_PINMUX instance. */
7269#define ALT_SYSMGR_PINMUX_MIXED1IO12_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO12_OFST))
7270/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO13 register for the ALT_SYSMGR_PINMUX instance. */
7271#define ALT_SYSMGR_PINMUX_MIXED1IO13_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO13_OFST))
7272/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO14 register for the ALT_SYSMGR_PINMUX instance. */
7273#define ALT_SYSMGR_PINMUX_MIXED1IO14_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO14_OFST))
7274/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO15 register for the ALT_SYSMGR_PINMUX instance. */
7275#define ALT_SYSMGR_PINMUX_MIXED1IO15_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO15_OFST))
7276/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO16 register for the ALT_SYSMGR_PINMUX instance. */
7277#define ALT_SYSMGR_PINMUX_MIXED1IO16_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO16_OFST))
7278/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO17 register for the ALT_SYSMGR_PINMUX instance. */
7279#define ALT_SYSMGR_PINMUX_MIXED1IO17_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO17_OFST))
7280/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO18 register for the ALT_SYSMGR_PINMUX instance. */
7281#define ALT_SYSMGR_PINMUX_MIXED1IO18_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO18_OFST))
7282/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO19 register for the ALT_SYSMGR_PINMUX instance. */
7283#define ALT_SYSMGR_PINMUX_MIXED1IO19_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO19_OFST))
7284/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO20 register for the ALT_SYSMGR_PINMUX instance. */
7285#define ALT_SYSMGR_PINMUX_MIXED1IO20_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO20_OFST))
7286/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO21 register for the ALT_SYSMGR_PINMUX instance. */
7287#define ALT_SYSMGR_PINMUX_MIXED1IO21_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO21_OFST))
7288/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO0 register for the ALT_SYSMGR_PINMUX instance. */
7289#define ALT_SYSMGR_PINMUX_MIXED2IO0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO0_OFST))
7290/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO1 register for the ALT_SYSMGR_PINMUX instance. */
7291#define ALT_SYSMGR_PINMUX_MIXED2IO1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO1_OFST))
7292/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO2 register for the ALT_SYSMGR_PINMUX instance. */
7293#define ALT_SYSMGR_PINMUX_MIXED2IO2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO2_OFST))
7294/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO3 register for the ALT_SYSMGR_PINMUX instance. */
7295#define ALT_SYSMGR_PINMUX_MIXED2IO3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO3_OFST))
7296/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO4 register for the ALT_SYSMGR_PINMUX instance. */
7297#define ALT_SYSMGR_PINMUX_MIXED2IO4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO4_OFST))
7298/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO5 register for the ALT_SYSMGR_PINMUX instance. */
7299#define ALT_SYSMGR_PINMUX_MIXED2IO5_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO5_OFST))
7300/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO6 register for the ALT_SYSMGR_PINMUX instance. */
7301#define ALT_SYSMGR_PINMUX_MIXED2IO6_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO6_OFST))
7302/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO7 register for the ALT_SYSMGR_PINMUX instance. */
7303#define ALT_SYSMGR_PINMUX_MIXED2IO7_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO7_OFST))
7304/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX48 register for the ALT_SYSMGR_PINMUX instance. */
7305#define ALT_SYSMGR_PINMUX_GPLINMUX48_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX48_OFST))
7306/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX49 register for the ALT_SYSMGR_PINMUX instance. */
7307#define ALT_SYSMGR_PINMUX_GPLINMUX49_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX49_OFST))
7308/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX50 register for the ALT_SYSMGR_PINMUX instance. */
7309#define ALT_SYSMGR_PINMUX_GPLINMUX50_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX50_OFST))
7310/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX51 register for the ALT_SYSMGR_PINMUX instance. */
7311#define ALT_SYSMGR_PINMUX_GPLINMUX51_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX51_OFST))
7312/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX52 register for the ALT_SYSMGR_PINMUX instance. */
7313#define ALT_SYSMGR_PINMUX_GPLINMUX52_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX52_OFST))
7314/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX53 register for the ALT_SYSMGR_PINMUX instance. */
7315#define ALT_SYSMGR_PINMUX_GPLINMUX53_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX53_OFST))
7316/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX54 register for the ALT_SYSMGR_PINMUX instance. */
7317#define ALT_SYSMGR_PINMUX_GPLINMUX54_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX54_OFST))
7318/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX55 register for the ALT_SYSMGR_PINMUX instance. */
7319#define ALT_SYSMGR_PINMUX_GPLINMUX55_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX55_OFST))
7320/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX56 register for the ALT_SYSMGR_PINMUX instance. */
7321#define ALT_SYSMGR_PINMUX_GPLINMUX56_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX56_OFST))
7322/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX57 register for the ALT_SYSMGR_PINMUX instance. */
7323#define ALT_SYSMGR_PINMUX_GPLINMUX57_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX57_OFST))
7324/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX58 register for the ALT_SYSMGR_PINMUX instance. */
7325#define ALT_SYSMGR_PINMUX_GPLINMUX58_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX58_OFST))
7326/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX59 register for the ALT_SYSMGR_PINMUX instance. */
7327#define ALT_SYSMGR_PINMUX_GPLINMUX59_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX59_OFST))
7328/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX60 register for the ALT_SYSMGR_PINMUX instance. */
7329#define ALT_SYSMGR_PINMUX_GPLINMUX60_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX60_OFST))
7330/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX61 register for the ALT_SYSMGR_PINMUX instance. */
7331#define ALT_SYSMGR_PINMUX_GPLINMUX61_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX61_OFST))
7332/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX62 register for the ALT_SYSMGR_PINMUX instance. */
7333#define ALT_SYSMGR_PINMUX_GPLINMUX62_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX62_OFST))
7334/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX63 register for the ALT_SYSMGR_PINMUX instance. */
7335#define ALT_SYSMGR_PINMUX_GPLINMUX63_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX63_OFST))
7336/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX64 register for the ALT_SYSMGR_PINMUX instance. */
7337#define ALT_SYSMGR_PINMUX_GPLINMUX64_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX64_OFST))
7338/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX65 register for the ALT_SYSMGR_PINMUX instance. */
7339#define ALT_SYSMGR_PINMUX_GPLINMUX65_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX65_OFST))
7340/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX66 register for the ALT_SYSMGR_PINMUX instance. */
7341#define ALT_SYSMGR_PINMUX_GPLINMUX66_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX66_OFST))
7342/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX67 register for the ALT_SYSMGR_PINMUX instance. */
7343#define ALT_SYSMGR_PINMUX_GPLINMUX67_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX67_OFST))
7344/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX68 register for the ALT_SYSMGR_PINMUX instance. */
7345#define ALT_SYSMGR_PINMUX_GPLINMUX68_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX68_OFST))
7346/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX69 register for the ALT_SYSMGR_PINMUX instance. */
7347#define ALT_SYSMGR_PINMUX_GPLINMUX69_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX69_OFST))
7348/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX70 register for the ALT_SYSMGR_PINMUX instance. */
7349#define ALT_SYSMGR_PINMUX_GPLINMUX70_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX70_OFST))
7350/* The address of the ALT_SYSMGR_PINMUX_GPLMUX0 register for the ALT_SYSMGR_PINMUX instance. */
7351#define ALT_SYSMGR_PINMUX_GPLMUX0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX0_OFST))
7352/* The address of the ALT_SYSMGR_PINMUX_GPLMUX1 register for the ALT_SYSMGR_PINMUX instance. */
7353#define ALT_SYSMGR_PINMUX_GPLMUX1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX1_OFST))
7354/* The address of the ALT_SYSMGR_PINMUX_GPLMUX2 register for the ALT_SYSMGR_PINMUX instance. */
7355#define ALT_SYSMGR_PINMUX_GPLMUX2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX2_OFST))
7356/* The address of the ALT_SYSMGR_PINMUX_GPLMUX3 register for the ALT_SYSMGR_PINMUX instance. */
7357#define ALT_SYSMGR_PINMUX_GPLMUX3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX3_OFST))
7358/* The address of the ALT_SYSMGR_PINMUX_GPLMUX4 register for the ALT_SYSMGR_PINMUX instance. */
7359#define ALT_SYSMGR_PINMUX_GPLMUX4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX4_OFST))
7360/* The address of the ALT_SYSMGR_PINMUX_GPLMUX5 register for the ALT_SYSMGR_PINMUX instance. */
7361#define ALT_SYSMGR_PINMUX_GPLMUX5_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX5_OFST))
7362/* The address of the ALT_SYSMGR_PINMUX_GPLMUX6 register for the ALT_SYSMGR_PINMUX instance. */
7363#define ALT_SYSMGR_PINMUX_GPLMUX6_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX6_OFST))
7364/* The address of the ALT_SYSMGR_PINMUX_GPLMUX7 register for the ALT_SYSMGR_PINMUX instance. */
7365#define ALT_SYSMGR_PINMUX_GPLMUX7_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX7_OFST))
7366/* The address of the ALT_SYSMGR_PINMUX_GPLMUX8 register for the ALT_SYSMGR_PINMUX instance. */
7367#define ALT_SYSMGR_PINMUX_GPLMUX8_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX8_OFST))
7368/* The address of the ALT_SYSMGR_PINMUX_GPLMUX9 register for the ALT_SYSMGR_PINMUX instance. */
7369#define ALT_SYSMGR_PINMUX_GPLMUX9_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX9_OFST))
7370/* The address of the ALT_SYSMGR_PINMUX_GPLMUX10 register for the ALT_SYSMGR_PINMUX instance. */
7371#define ALT_SYSMGR_PINMUX_GPLMUX10_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX10_OFST))
7372/* The address of the ALT_SYSMGR_PINMUX_GPLMUX11 register for the ALT_SYSMGR_PINMUX instance. */
7373#define ALT_SYSMGR_PINMUX_GPLMUX11_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX11_OFST))
7374/* The address of the ALT_SYSMGR_PINMUX_GPLMUX12 register for the ALT_SYSMGR_PINMUX instance. */
7375#define ALT_SYSMGR_PINMUX_GPLMUX12_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX12_OFST))
7376/* The address of the ALT_SYSMGR_PINMUX_GPLMUX13 register for the ALT_SYSMGR_PINMUX instance. */
7377#define ALT_SYSMGR_PINMUX_GPLMUX13_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX13_OFST))
7378/* The address of the ALT_SYSMGR_PINMUX_GPLMUX14 register for the ALT_SYSMGR_PINMUX instance. */
7379#define ALT_SYSMGR_PINMUX_GPLMUX14_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX14_OFST))
7380/* The address of the ALT_SYSMGR_PINMUX_GPLMUX15 register for the ALT_SYSMGR_PINMUX instance. */
7381#define ALT_SYSMGR_PINMUX_GPLMUX15_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX15_OFST))
7382/* The address of the ALT_SYSMGR_PINMUX_GPLMUX16 register for the ALT_SYSMGR_PINMUX instance. */
7383#define ALT_SYSMGR_PINMUX_GPLMUX16_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX16_OFST))
7384/* The address of the ALT_SYSMGR_PINMUX_GPLMUX17 register for the ALT_SYSMGR_PINMUX instance. */
7385#define ALT_SYSMGR_PINMUX_GPLMUX17_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX17_OFST))
7386/* The address of the ALT_SYSMGR_PINMUX_GPLMUX18 register for the ALT_SYSMGR_PINMUX instance. */
7387#define ALT_SYSMGR_PINMUX_GPLMUX18_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX18_OFST))
7388/* The address of the ALT_SYSMGR_PINMUX_GPLMUX19 register for the ALT_SYSMGR_PINMUX instance. */
7389#define ALT_SYSMGR_PINMUX_GPLMUX19_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX19_OFST))
7390/* The address of the ALT_SYSMGR_PINMUX_GPLMUX20 register for the ALT_SYSMGR_PINMUX instance. */
7391#define ALT_SYSMGR_PINMUX_GPLMUX20_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX20_OFST))
7392/* The address of the ALT_SYSMGR_PINMUX_GPLMUX21 register for the ALT_SYSMGR_PINMUX instance. */
7393#define ALT_SYSMGR_PINMUX_GPLMUX21_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX21_OFST))
7394/* The address of the ALT_SYSMGR_PINMUX_GPLMUX22 register for the ALT_SYSMGR_PINMUX instance. */
7395#define ALT_SYSMGR_PINMUX_GPLMUX22_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX22_OFST))
7396/* The address of the ALT_SYSMGR_PINMUX_GPLMUX23 register for the ALT_SYSMGR_PINMUX instance. */
7397#define ALT_SYSMGR_PINMUX_GPLMUX23_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX23_OFST))
7398/* The address of the ALT_SYSMGR_PINMUX_GPLMUX24 register for the ALT_SYSMGR_PINMUX instance. */
7399#define ALT_SYSMGR_PINMUX_GPLMUX24_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX24_OFST))
7400/* The address of the ALT_SYSMGR_PINMUX_GPLMUX25 register for the ALT_SYSMGR_PINMUX instance. */
7401#define ALT_SYSMGR_PINMUX_GPLMUX25_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX25_OFST))
7402/* The address of the ALT_SYSMGR_PINMUX_GPLMUX26 register for the ALT_SYSMGR_PINMUX instance. */
7403#define ALT_SYSMGR_PINMUX_GPLMUX26_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX26_OFST))
7404/* The address of the ALT_SYSMGR_PINMUX_GPLMUX27 register for the ALT_SYSMGR_PINMUX instance. */
7405#define ALT_SYSMGR_PINMUX_GPLMUX27_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX27_OFST))
7406/* The address of the ALT_SYSMGR_PINMUX_GPLMUX28 register for the ALT_SYSMGR_PINMUX instance. */
7407#define ALT_SYSMGR_PINMUX_GPLMUX28_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX28_OFST))
7408/* The address of the ALT_SYSMGR_PINMUX_GPLMUX29 register for the ALT_SYSMGR_PINMUX instance. */
7409#define ALT_SYSMGR_PINMUX_GPLMUX29_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX29_OFST))
7410/* The address of the ALT_SYSMGR_PINMUX_GPLMUX30 register for the ALT_SYSMGR_PINMUX instance. */
7411#define ALT_SYSMGR_PINMUX_GPLMUX30_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX30_OFST))
7412/* The address of the ALT_SYSMGR_PINMUX_GPLMUX31 register for the ALT_SYSMGR_PINMUX instance. */
7413#define ALT_SYSMGR_PINMUX_GPLMUX31_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX31_OFST))
7414/* The address of the ALT_SYSMGR_PINMUX_GPLMUX32 register for the ALT_SYSMGR_PINMUX instance. */
7415#define ALT_SYSMGR_PINMUX_GPLMUX32_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX32_OFST))
7416/* The address of the ALT_SYSMGR_PINMUX_GPLMUX33 register for the ALT_SYSMGR_PINMUX instance. */
7417#define ALT_SYSMGR_PINMUX_GPLMUX33_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX33_OFST))
7418/* The address of the ALT_SYSMGR_PINMUX_GPLMUX34 register for the ALT_SYSMGR_PINMUX instance. */
7419#define ALT_SYSMGR_PINMUX_GPLMUX34_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX34_OFST))
7420/* The address of the ALT_SYSMGR_PINMUX_GPLMUX35 register for the ALT_SYSMGR_PINMUX instance. */
7421#define ALT_SYSMGR_PINMUX_GPLMUX35_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX35_OFST))
7422/* The address of the ALT_SYSMGR_PINMUX_GPLMUX36 register for the ALT_SYSMGR_PINMUX instance. */
7423#define ALT_SYSMGR_PINMUX_GPLMUX36_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX36_OFST))
7424/* The address of the ALT_SYSMGR_PINMUX_GPLMUX37 register for the ALT_SYSMGR_PINMUX instance. */
7425#define ALT_SYSMGR_PINMUX_GPLMUX37_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX37_OFST))
7426/* The address of the ALT_SYSMGR_PINMUX_GPLMUX38 register for the ALT_SYSMGR_PINMUX instance. */
7427#define ALT_SYSMGR_PINMUX_GPLMUX38_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX38_OFST))
7428/* The address of the ALT_SYSMGR_PINMUX_GPLMUX39 register for the ALT_SYSMGR_PINMUX instance. */
7429#define ALT_SYSMGR_PINMUX_GPLMUX39_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX39_OFST))
7430/* The address of the ALT_SYSMGR_PINMUX_GPLMUX40 register for the ALT_SYSMGR_PINMUX instance. */
7431#define ALT_SYSMGR_PINMUX_GPLMUX40_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX40_OFST))
7432/* The address of the ALT_SYSMGR_PINMUX_GPLMUX41 register for the ALT_SYSMGR_PINMUX instance. */
7433#define ALT_SYSMGR_PINMUX_GPLMUX41_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX41_OFST))
7434/* The address of the ALT_SYSMGR_PINMUX_GPLMUX42 register for the ALT_SYSMGR_PINMUX instance. */
7435#define ALT_SYSMGR_PINMUX_GPLMUX42_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX42_OFST))
7436/* The address of the ALT_SYSMGR_PINMUX_GPLMUX43 register for the ALT_SYSMGR_PINMUX instance. */
7437#define ALT_SYSMGR_PINMUX_GPLMUX43_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX43_OFST))
7438/* The address of the ALT_SYSMGR_PINMUX_GPLMUX44 register for the ALT_SYSMGR_PINMUX instance. */
7439#define ALT_SYSMGR_PINMUX_GPLMUX44_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX44_OFST))
7440/* The address of the ALT_SYSMGR_PINMUX_GPLMUX45 register for the ALT_SYSMGR_PINMUX instance. */
7441#define ALT_SYSMGR_PINMUX_GPLMUX45_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX45_OFST))
7442/* The address of the ALT_SYSMGR_PINMUX_GPLMUX46 register for the ALT_SYSMGR_PINMUX instance. */
7443#define ALT_SYSMGR_PINMUX_GPLMUX46_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX46_OFST))
7444/* The address of the ALT_SYSMGR_PINMUX_GPLMUX47 register for the ALT_SYSMGR_PINMUX instance. */
7445#define ALT_SYSMGR_PINMUX_GPLMUX47_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX47_OFST))
7446/* The address of the ALT_SYSMGR_PINMUX_GPLMUX48 register for the ALT_SYSMGR_PINMUX instance. */
7447#define ALT_SYSMGR_PINMUX_GPLMUX48_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX48_OFST))
7448/* The address of the ALT_SYSMGR_PINMUX_GPLMUX49 register for the ALT_SYSMGR_PINMUX instance. */
7449#define ALT_SYSMGR_PINMUX_GPLMUX49_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX49_OFST))
7450/* The address of the ALT_SYSMGR_PINMUX_GPLMUX50 register for the ALT_SYSMGR_PINMUX instance. */
7451#define ALT_SYSMGR_PINMUX_GPLMUX50_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX50_OFST))
7452/* The address of the ALT_SYSMGR_PINMUX_GPLMUX51 register for the ALT_SYSMGR_PINMUX instance. */
7453#define ALT_SYSMGR_PINMUX_GPLMUX51_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX51_OFST))
7454/* The address of the ALT_SYSMGR_PINMUX_GPLMUX52 register for the ALT_SYSMGR_PINMUX instance. */
7455#define ALT_SYSMGR_PINMUX_GPLMUX52_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX52_OFST))
7456/* The address of the ALT_SYSMGR_PINMUX_GPLMUX53 register for the ALT_SYSMGR_PINMUX instance. */
7457#define ALT_SYSMGR_PINMUX_GPLMUX53_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX53_OFST))
7458/* The address of the ALT_SYSMGR_PINMUX_GPLMUX54 register for the ALT_SYSMGR_PINMUX instance. */
7459#define ALT_SYSMGR_PINMUX_GPLMUX54_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX54_OFST))
7460/* The address of the ALT_SYSMGR_PINMUX_GPLMUX55 register for the ALT_SYSMGR_PINMUX instance. */
7461#define ALT_SYSMGR_PINMUX_GPLMUX55_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX55_OFST))
7462/* The address of the ALT_SYSMGR_PINMUX_GPLMUX56 register for the ALT_SYSMGR_PINMUX instance. */
7463#define ALT_SYSMGR_PINMUX_GPLMUX56_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX56_OFST))
7464/* The address of the ALT_SYSMGR_PINMUX_GPLMUX57 register for the ALT_SYSMGR_PINMUX instance. */
7465#define ALT_SYSMGR_PINMUX_GPLMUX57_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX57_OFST))
7466/* The address of the ALT_SYSMGR_PINMUX_GPLMUX58 register for the ALT_SYSMGR_PINMUX instance. */
7467#define ALT_SYSMGR_PINMUX_GPLMUX58_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX58_OFST))
7468/* The address of the ALT_SYSMGR_PINMUX_GPLMUX59 register for the ALT_SYSMGR_PINMUX instance. */
7469#define ALT_SYSMGR_PINMUX_GPLMUX59_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX59_OFST))
7470/* The address of the ALT_SYSMGR_PINMUX_GPLMUX60 register for the ALT_SYSMGR_PINMUX instance. */
7471#define ALT_SYSMGR_PINMUX_GPLMUX60_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX60_OFST))
7472/* The address of the ALT_SYSMGR_PINMUX_GPLMUX61 register for the ALT_SYSMGR_PINMUX instance. */
7473#define ALT_SYSMGR_PINMUX_GPLMUX61_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX61_OFST))
7474/* The address of the ALT_SYSMGR_PINMUX_GPLMUX62 register for the ALT_SYSMGR_PINMUX instance. */
7475#define ALT_SYSMGR_PINMUX_GPLMUX62_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX62_OFST))
7476/* The address of the ALT_SYSMGR_PINMUX_GPLMUX63 register for the ALT_SYSMGR_PINMUX instance. */
7477#define ALT_SYSMGR_PINMUX_GPLMUX63_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX63_OFST))
7478/* The address of the ALT_SYSMGR_PINMUX_GPLMUX64 register for the ALT_SYSMGR_PINMUX instance. */
7479#define ALT_SYSMGR_PINMUX_GPLMUX64_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX64_OFST))
7480/* The address of the ALT_SYSMGR_PINMUX_GPLMUX65 register for the ALT_SYSMGR_PINMUX instance. */
7481#define ALT_SYSMGR_PINMUX_GPLMUX65_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX65_OFST))
7482/* The address of the ALT_SYSMGR_PINMUX_GPLMUX66 register for the ALT_SYSMGR_PINMUX instance. */
7483#define ALT_SYSMGR_PINMUX_GPLMUX66_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX66_OFST))
7484/* The address of the ALT_SYSMGR_PINMUX_GPLMUX67 register for the ALT_SYSMGR_PINMUX instance. */
7485#define ALT_SYSMGR_PINMUX_GPLMUX67_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX67_OFST))
7486/* The address of the ALT_SYSMGR_PINMUX_GPLMUX68 register for the ALT_SYSMGR_PINMUX instance. */
7487#define ALT_SYSMGR_PINMUX_GPLMUX68_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX68_OFST))
7488/* The address of the ALT_SYSMGR_PINMUX_GPLMUX69 register for the ALT_SYSMGR_PINMUX instance. */
7489#define ALT_SYSMGR_PINMUX_GPLMUX69_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX69_OFST))
7490/* The address of the ALT_SYSMGR_PINMUX_GPLMUX70 register for the ALT_SYSMGR_PINMUX instance. */
7491#define ALT_SYSMGR_PINMUX_GPLMUX70_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX70_OFST))
7492/* The address of the ALT_SYSMGR_PINMUX_NANDUSEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7493#define ALT_SYSMGR_PINMUX_NANDUSEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_NANDUSEFPGA_OFST))
7494/* The address of the ALT_SYSMGR_PINMUX_RGMII1USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7495#define ALT_SYSMGR_PINMUX_RGMII1USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_RGMII1USEFPGA_OFST))
7496/* The address of the ALT_SYSMGR_PINMUX_I2C0USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7497#define ALT_SYSMGR_PINMUX_I2C0USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_I2C0USEFPGA_OFST))
7498/* The address of the ALT_SYSMGR_PINMUX_RGMII0USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7499#define ALT_SYSMGR_PINMUX_RGMII0USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_RGMII0USEFPGA_OFST))
7500/* The address of the ALT_SYSMGR_PINMUX_I2C3USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7501#define ALT_SYSMGR_PINMUX_I2C3USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_I2C3USEFPGA_OFST))
7502/* The address of the ALT_SYSMGR_PINMUX_I2C2USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7503#define ALT_SYSMGR_PINMUX_I2C2USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_I2C2USEFPGA_OFST))
7504/* The address of the ALT_SYSMGR_PINMUX_I2C1USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7505#define ALT_SYSMGR_PINMUX_I2C1USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_I2C1USEFPGA_OFST))
7506/* The address of the ALT_SYSMGR_PINMUX_SPIM1USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7507#define ALT_SYSMGR_PINMUX_SPIM1USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_SPIM1USEFPGA_OFST))
7508/* The address of the ALT_SYSMGR_PINMUX_SPIM0USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7509#define ALT_SYSMGR_PINMUX_SPIM0USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_SPIM0USEFPGA_OFST))
7510/* The base address byte offset for the start of the ALT_SYSMGR_PINMUX component. */
7511#define ALT_SYSMGR_PINMUX_OFST 0x400
7512/* The start address of the ALT_SYSMGR_PINMUX component. */
7513#define ALT_SYSMGR_PINMUX_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_PINMUX_OFST))
7514/* The lower bound address range of the ALT_SYSMGR_PINMUX component. */
7515#define ALT_SYSMGR_PINMUX_LB_ADDR ALT_SYSMGR_PINMUX_ADDR
7516/* The upper bound address range of the ALT_SYSMGR_PINMUX component. */
7517#define ALT_SYSMGR_PINMUX_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + 0x400) - 1))
7518
7519
7520/* The base address byte offset for the start of the ALT_SYSMGR component. */
7521#define ALT_SYSMGR_OFST 0xffd08000
7522/* The start address of the ALT_SYSMGR component. */
7523#define ALT_SYSMGR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SYSMGR_OFST))
7524/* The lower bound address range of the ALT_SYSMGR component. */
7525#define ALT_SYSMGR_LB_ADDR ALT_SYSMGR_ADDR
7526/* The upper bound address range of the ALT_SYSMGR component. */
7527#define ALT_SYSMGR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_ADDR) + 0x4000) - 1))
7528
7529
7530/*
7531 * Component Instance : dmanonsecure
7532 *
7533 * Instance dmanonsecure of component ALT_DMANONSECURE.
7534 *
7535 *
7536 */
7537/* The address of the ALT_DMANONSECURE_REG register for the ALT_DMANONSECURE instance. */
7538#define ALT_DMANONSECURE_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_DMANONSECURE_ADDR) + ALT_DMANONSECURE_REG_OFST))
7539/* The base address byte offset for the start of the ALT_DMANONSECURE component. */
7540#define ALT_DMANONSECURE_OFST 0xffe00000
7541/* The start address of the ALT_DMANONSECURE component. */
7542#define ALT_DMANONSECURE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_DMANONSECURE_OFST))
7543/* The lower bound address range of the ALT_DMANONSECURE component. */
7544#define ALT_DMANONSECURE_LB_ADDR ALT_DMANONSECURE_ADDR
7545/* The upper bound address range of the ALT_DMANONSECURE component. */
7546#define ALT_DMANONSECURE_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_DMANONSECURE_ADDR) + 0x4) - 1))
7547
7548
7549/*
7550 * Component Instance : dmasecure
7551 *
7552 * Instance dmasecure of component ALT_DMASECURE.
7553 *
7554 *
7555 */
7556/* The address of the ALT_DMASECURE_REG register for the ALT_DMASECURE instance. */
7557#define ALT_DMASECURE_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_DMASECURE_ADDR) + ALT_DMASECURE_REG_OFST))
7558/* The base address byte offset for the start of the ALT_DMASECURE component. */
7559#define ALT_DMASECURE_OFST 0xffe01000
7560/* The start address of the ALT_DMASECURE component. */
7561#define ALT_DMASECURE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_DMASECURE_OFST))
7562/* The lower bound address range of the ALT_DMASECURE component. */
7563#define ALT_DMASECURE_LB_ADDR ALT_DMASECURE_ADDR
7564/* The upper bound address range of the ALT_DMASECURE component. */
7565#define ALT_DMASECURE_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_DMASECURE_ADDR) + 0x4) - 1))
7566
7567
7568/*
7569 * Component Instance : spis0
7570 *
7571 * Instance spis0 of component ALT_SPIS.
7572 *
7573 *
7574 */
7575/* The address of the ALT_SPIS_CTLR0 register for the ALT_SPIS0 instance. */
7576#define ALT_SPIS0_CTLR0_ADDR ALT_SPIS_CTLR0_ADDR(ALT_SPIS0_ADDR)
7577/* The address of the ALT_SPIS_SPIENR register for the ALT_SPIS0 instance. */
7578#define ALT_SPIS0_SPIENR_ADDR ALT_SPIS_SPIENR_ADDR(ALT_SPIS0_ADDR)
7579/* The address of the ALT_SPIS_MWCR register for the ALT_SPIS0 instance. */
7580#define ALT_SPIS0_MWCR_ADDR ALT_SPIS_MWCR_ADDR(ALT_SPIS0_ADDR)
7581/* The address of the ALT_SPIS_TXFTLR register for the ALT_SPIS0 instance. */
7582#define ALT_SPIS0_TXFTLR_ADDR ALT_SPIS_TXFTLR_ADDR(ALT_SPIS0_ADDR)
7583/* The address of the ALT_SPIS_RXFTLR register for the ALT_SPIS0 instance. */
7584#define ALT_SPIS0_RXFTLR_ADDR ALT_SPIS_RXFTLR_ADDR(ALT_SPIS0_ADDR)
7585/* The address of the ALT_SPIS_TXFLR register for the ALT_SPIS0 instance. */
7586#define ALT_SPIS0_TXFLR_ADDR ALT_SPIS_TXFLR_ADDR(ALT_SPIS0_ADDR)
7587/* The address of the ALT_SPIS_RXFLR register for the ALT_SPIS0 instance. */
7588#define ALT_SPIS0_RXFLR_ADDR ALT_SPIS_RXFLR_ADDR(ALT_SPIS0_ADDR)
7589/* The address of the ALT_SPIS_SR register for the ALT_SPIS0 instance. */
7590#define ALT_SPIS0_SR_ADDR ALT_SPIS_SR_ADDR(ALT_SPIS0_ADDR)
7591/* The address of the ALT_SPIS_IMR register for the ALT_SPIS0 instance. */
7592#define ALT_SPIS0_IMR_ADDR ALT_SPIS_IMR_ADDR(ALT_SPIS0_ADDR)
7593/* The address of the ALT_SPIS_ISR register for the ALT_SPIS0 instance. */
7594#define ALT_SPIS0_ISR_ADDR ALT_SPIS_ISR_ADDR(ALT_SPIS0_ADDR)
7595/* The address of the ALT_SPIS_RISR register for the ALT_SPIS0 instance. */
7596#define ALT_SPIS0_RISR_ADDR ALT_SPIS_RISR_ADDR(ALT_SPIS0_ADDR)
7597/* The address of the ALT_SPIS_TXOICR register for the ALT_SPIS0 instance. */
7598#define ALT_SPIS0_TXOICR_ADDR ALT_SPIS_TXOICR_ADDR(ALT_SPIS0_ADDR)
7599/* The address of the ALT_SPIS_RXOICR register for the ALT_SPIS0 instance. */
7600#define ALT_SPIS0_RXOICR_ADDR ALT_SPIS_RXOICR_ADDR(ALT_SPIS0_ADDR)
7601/* The address of the ALT_SPIS_RXUICR register for the ALT_SPIS0 instance. */
7602#define ALT_SPIS0_RXUICR_ADDR ALT_SPIS_RXUICR_ADDR(ALT_SPIS0_ADDR)
7603/* The address of the ALT_SPIS_ICR register for the ALT_SPIS0 instance. */
7604#define ALT_SPIS0_ICR_ADDR ALT_SPIS_ICR_ADDR(ALT_SPIS0_ADDR)
7605/* The address of the ALT_SPIS_DMACR register for the ALT_SPIS0 instance. */
7606#define ALT_SPIS0_DMACR_ADDR ALT_SPIS_DMACR_ADDR(ALT_SPIS0_ADDR)
7607/* The address of the ALT_SPIS_DMATDLR register for the ALT_SPIS0 instance. */
7608#define ALT_SPIS0_DMATDLR_ADDR ALT_SPIS_DMATDLR_ADDR(ALT_SPIS0_ADDR)
7609/* The address of the ALT_SPIS_DMARDLR register for the ALT_SPIS0 instance. */
7610#define ALT_SPIS0_DMARDLR_ADDR ALT_SPIS_DMARDLR_ADDR(ALT_SPIS0_ADDR)
7611/* The address of the ALT_SPIS_IDR register for the ALT_SPIS0 instance. */
7612#define ALT_SPIS0_IDR_ADDR ALT_SPIS_IDR_ADDR(ALT_SPIS0_ADDR)
7613/* The address of the ALT_SPIS_SPI_VER_ID register for the ALT_SPIS0 instance. */
7614#define ALT_SPIS0_SPI_VER_ID_ADDR ALT_SPIS_SPI_VER_ID_ADDR(ALT_SPIS0_ADDR)
7615/* The address of the ALT_SPIS_DR register for the ALT_SPIS0 instance. */
7616#define ALT_SPIS0_DR_ADDR ALT_SPIS_DR_ADDR(ALT_SPIS0_ADDR)
7617/* The base address byte offset for the start of the ALT_SPIS0 component. */
7618#define ALT_SPIS0_OFST 0xffe02000
7619/* The start address of the ALT_SPIS0 component. */
7620#define ALT_SPIS0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SPIS0_OFST))
7621/* The lower bound address range of the ALT_SPIS0 component. */
7622#define ALT_SPIS0_LB_ADDR ALT_SPIS0_ADDR
7623/* The upper bound address range of the ALT_SPIS0 component. */
7624#define ALT_SPIS0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SPIS0_ADDR) + 0x80) - 1))
7625
7626
7627/*
7628 * Component Instance : spis1
7629 *
7630 * Instance spis1 of component ALT_SPIS.
7631 *
7632 *
7633 */
7634/* The address of the ALT_SPIS_CTLR0 register for the ALT_SPIS1 instance. */
7635#define ALT_SPIS1_CTLR0_ADDR ALT_SPIS_CTLR0_ADDR(ALT_SPIS1_ADDR)
7636/* The address of the ALT_SPIS_SPIENR register for the ALT_SPIS1 instance. */
7637#define ALT_SPIS1_SPIENR_ADDR ALT_SPIS_SPIENR_ADDR(ALT_SPIS1_ADDR)
7638/* The address of the ALT_SPIS_MWCR register for the ALT_SPIS1 instance. */
7639#define ALT_SPIS1_MWCR_ADDR ALT_SPIS_MWCR_ADDR(ALT_SPIS1_ADDR)
7640/* The address of the ALT_SPIS_TXFTLR register for the ALT_SPIS1 instance. */
7641#define ALT_SPIS1_TXFTLR_ADDR ALT_SPIS_TXFTLR_ADDR(ALT_SPIS1_ADDR)
7642/* The address of the ALT_SPIS_RXFTLR register for the ALT_SPIS1 instance. */
7643#define ALT_SPIS1_RXFTLR_ADDR ALT_SPIS_RXFTLR_ADDR(ALT_SPIS1_ADDR)
7644/* The address of the ALT_SPIS_TXFLR register for the ALT_SPIS1 instance. */
7645#define ALT_SPIS1_TXFLR_ADDR ALT_SPIS_TXFLR_ADDR(ALT_SPIS1_ADDR)
7646/* The address of the ALT_SPIS_RXFLR register for the ALT_SPIS1 instance. */
7647#define ALT_SPIS1_RXFLR_ADDR ALT_SPIS_RXFLR_ADDR(ALT_SPIS1_ADDR)
7648/* The address of the ALT_SPIS_SR register for the ALT_SPIS1 instance. */
7649#define ALT_SPIS1_SR_ADDR ALT_SPIS_SR_ADDR(ALT_SPIS1_ADDR)
7650/* The address of the ALT_SPIS_IMR register for the ALT_SPIS1 instance. */
7651#define ALT_SPIS1_IMR_ADDR ALT_SPIS_IMR_ADDR(ALT_SPIS1_ADDR)
7652/* The address of the ALT_SPIS_ISR register for the ALT_SPIS1 instance. */
7653#define ALT_SPIS1_ISR_ADDR ALT_SPIS_ISR_ADDR(ALT_SPIS1_ADDR)
7654/* The address of the ALT_SPIS_RISR register for the ALT_SPIS1 instance. */
7655#define ALT_SPIS1_RISR_ADDR ALT_SPIS_RISR_ADDR(ALT_SPIS1_ADDR)
7656/* The address of the ALT_SPIS_TXOICR register for the ALT_SPIS1 instance. */
7657#define ALT_SPIS1_TXOICR_ADDR ALT_SPIS_TXOICR_ADDR(ALT_SPIS1_ADDR)
7658/* The address of the ALT_SPIS_RXOICR register for the ALT_SPIS1 instance. */
7659#define ALT_SPIS1_RXOICR_ADDR ALT_SPIS_RXOICR_ADDR(ALT_SPIS1_ADDR)
7660/* The address of the ALT_SPIS_RXUICR register for the ALT_SPIS1 instance. */
7661#define ALT_SPIS1_RXUICR_ADDR ALT_SPIS_RXUICR_ADDR(ALT_SPIS1_ADDR)
7662/* The address of the ALT_SPIS_ICR register for the ALT_SPIS1 instance. */
7663#define ALT_SPIS1_ICR_ADDR ALT_SPIS_ICR_ADDR(ALT_SPIS1_ADDR)
7664/* The address of the ALT_SPIS_DMACR register for the ALT_SPIS1 instance. */
7665#define ALT_SPIS1_DMACR_ADDR ALT_SPIS_DMACR_ADDR(ALT_SPIS1_ADDR)
7666/* The address of the ALT_SPIS_DMATDLR register for the ALT_SPIS1 instance. */
7667#define ALT_SPIS1_DMATDLR_ADDR ALT_SPIS_DMATDLR_ADDR(ALT_SPIS1_ADDR)
7668/* The address of the ALT_SPIS_DMARDLR register for the ALT_SPIS1 instance. */
7669#define ALT_SPIS1_DMARDLR_ADDR ALT_SPIS_DMARDLR_ADDR(ALT_SPIS1_ADDR)
7670/* The address of the ALT_SPIS_IDR register for the ALT_SPIS1 instance. */
7671#define ALT_SPIS1_IDR_ADDR ALT_SPIS_IDR_ADDR(ALT_SPIS1_ADDR)
7672/* The address of the ALT_SPIS_SPI_VER_ID register for the ALT_SPIS1 instance. */
7673#define ALT_SPIS1_SPI_VER_ID_ADDR ALT_SPIS_SPI_VER_ID_ADDR(ALT_SPIS1_ADDR)
7674/* The address of the ALT_SPIS_DR register for the ALT_SPIS1 instance. */
7675#define ALT_SPIS1_DR_ADDR ALT_SPIS_DR_ADDR(ALT_SPIS1_ADDR)
7676/* The base address byte offset for the start of the ALT_SPIS1 component. */
7677#define ALT_SPIS1_OFST 0xffe03000
7678/* The start address of the ALT_SPIS1 component. */
7679#define ALT_SPIS1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SPIS1_OFST))
7680/* The lower bound address range of the ALT_SPIS1 component. */
7681#define ALT_SPIS1_LB_ADDR ALT_SPIS1_ADDR
7682/* The upper bound address range of the ALT_SPIS1 component. */
7683#define ALT_SPIS1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SPIS1_ADDR) + 0x80) - 1))
7684
7685
7686/*
7687 * Component Instance : spim0
7688 *
7689 * Instance spim0 of component ALT_SPIM.
7690 *
7691 *
7692 */
7693/* The address of the ALT_SPIM_CTLR0 register for the ALT_SPIM0 instance. */
7694#define ALT_SPIM0_CTLR0_ADDR ALT_SPIM_CTLR0_ADDR(ALT_SPIM0_ADDR)
7695/* The address of the ALT_SPIM_CTLR1 register for the ALT_SPIM0 instance. */
7696#define ALT_SPIM0_CTLR1_ADDR ALT_SPIM_CTLR1_ADDR(ALT_SPIM0_ADDR)
7697/* The address of the ALT_SPIM_SPIENR register for the ALT_SPIM0 instance. */
7698#define ALT_SPIM0_SPIENR_ADDR ALT_SPIM_SPIENR_ADDR(ALT_SPIM0_ADDR)
7699/* The address of the ALT_SPIM_MWCR register for the ALT_SPIM0 instance. */
7700#define ALT_SPIM0_MWCR_ADDR ALT_SPIM_MWCR_ADDR(ALT_SPIM0_ADDR)
7701/* The address of the ALT_SPIM_SER register for the ALT_SPIM0 instance. */
7702#define ALT_SPIM0_SER_ADDR ALT_SPIM_SER_ADDR(ALT_SPIM0_ADDR)
7703/* The address of the ALT_SPIM_BAUDR register for the ALT_SPIM0 instance. */
7704#define ALT_SPIM0_BAUDR_ADDR ALT_SPIM_BAUDR_ADDR(ALT_SPIM0_ADDR)
7705/* The address of the ALT_SPIM_TXFTLR register for the ALT_SPIM0 instance. */
7706#define ALT_SPIM0_TXFTLR_ADDR ALT_SPIM_TXFTLR_ADDR(ALT_SPIM0_ADDR)
7707/* The address of the ALT_SPIM_RXFTLR register for the ALT_SPIM0 instance. */
7708#define ALT_SPIM0_RXFTLR_ADDR ALT_SPIM_RXFTLR_ADDR(ALT_SPIM0_ADDR)
7709/* The address of the ALT_SPIM_TXFLR register for the ALT_SPIM0 instance. */
7710#define ALT_SPIM0_TXFLR_ADDR ALT_SPIM_TXFLR_ADDR(ALT_SPIM0_ADDR)
7711/* The address of the ALT_SPIM_RXFLR register for the ALT_SPIM0 instance. */
7712#define ALT_SPIM0_RXFLR_ADDR ALT_SPIM_RXFLR_ADDR(ALT_SPIM0_ADDR)
7713/* The address of the ALT_SPIM_SR register for the ALT_SPIM0 instance. */
7714#define ALT_SPIM0_SR_ADDR ALT_SPIM_SR_ADDR(ALT_SPIM0_ADDR)
7715/* The address of the ALT_SPIM_IMR register for the ALT_SPIM0 instance. */
7716#define ALT_SPIM0_IMR_ADDR ALT_SPIM_IMR_ADDR(ALT_SPIM0_ADDR)
7717/* The address of the ALT_SPIM_ISR register for the ALT_SPIM0 instance. */
7718#define ALT_SPIM0_ISR_ADDR ALT_SPIM_ISR_ADDR(ALT_SPIM0_ADDR)
7719/* The address of the ALT_SPIM_RISR register for the ALT_SPIM0 instance. */
7720#define ALT_SPIM0_RISR_ADDR ALT_SPIM_RISR_ADDR(ALT_SPIM0_ADDR)
7721/* The address of the ALT_SPIM_TXOICR register for the ALT_SPIM0 instance. */
7722#define ALT_SPIM0_TXOICR_ADDR ALT_SPIM_TXOICR_ADDR(ALT_SPIM0_ADDR)
7723/* The address of the ALT_SPIM_RXOICR register for the ALT_SPIM0 instance. */
7724#define ALT_SPIM0_RXOICR_ADDR ALT_SPIM_RXOICR_ADDR(ALT_SPIM0_ADDR)
7725/* The address of the ALT_SPIM_RXUICR register for the ALT_SPIM0 instance. */
7726#define ALT_SPIM0_RXUICR_ADDR ALT_SPIM_RXUICR_ADDR(ALT_SPIM0_ADDR)
7727/* The address of the ALT_SPIM_ICR register for the ALT_SPIM0 instance. */
7728#define ALT_SPIM0_ICR_ADDR ALT_SPIM_ICR_ADDR(ALT_SPIM0_ADDR)
7729/* The address of the ALT_SPIM_DMACR register for the ALT_SPIM0 instance. */
7730#define ALT_SPIM0_DMACR_ADDR ALT_SPIM_DMACR_ADDR(ALT_SPIM0_ADDR)
7731/* The address of the ALT_SPIM_DMATDLR register for the ALT_SPIM0 instance. */
7732#define ALT_SPIM0_DMATDLR_ADDR ALT_SPIM_DMATDLR_ADDR(ALT_SPIM0_ADDR)
7733/* The address of the ALT_SPIM_DMARDLR register for the ALT_SPIM0 instance. */
7734#define ALT_SPIM0_DMARDLR_ADDR ALT_SPIM_DMARDLR_ADDR(ALT_SPIM0_ADDR)
7735/* The address of the ALT_SPIM_IDR register for the ALT_SPIM0 instance. */
7736#define ALT_SPIM0_IDR_ADDR ALT_SPIM_IDR_ADDR(ALT_SPIM0_ADDR)
7737/* The address of the ALT_SPIM_SPI_VER_ID register for the ALT_SPIM0 instance. */
7738#define ALT_SPIM0_SPI_VER_ID_ADDR ALT_SPIM_SPI_VER_ID_ADDR(ALT_SPIM0_ADDR)
7739/* The address of the ALT_SPIM_DR register for the ALT_SPIM0 instance. */
7740#define ALT_SPIM0_DR_ADDR ALT_SPIM_DR_ADDR(ALT_SPIM0_ADDR)
7741/* The address of the ALT_SPIM_RX_SMPL_DLY register for the ALT_SPIM0 instance. */
7742#define ALT_SPIM0_RX_SMPL_DLY_ADDR ALT_SPIM_RX_SMPL_DLY_ADDR(ALT_SPIM0_ADDR)
7743/* The base address byte offset for the start of the ALT_SPIM0 component. */
7744#define ALT_SPIM0_OFST 0xfff00000
7745/* The start address of the ALT_SPIM0 component. */
7746#define ALT_SPIM0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SPIM0_OFST))
7747/* The lower bound address range of the ALT_SPIM0 component. */
7748#define ALT_SPIM0_LB_ADDR ALT_SPIM0_ADDR
7749/* The upper bound address range of the ALT_SPIM0 component. */
7750#define ALT_SPIM0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SPIM0_ADDR) + 0x100) - 1))
7751
7752
7753/*
7754 * Component Instance : spim1
7755 *
7756 * Instance spim1 of component ALT_SPIM.
7757 *
7758 *
7759 */
7760/* The address of the ALT_SPIM_CTLR0 register for the ALT_SPIM1 instance. */
7761#define ALT_SPIM1_CTLR0_ADDR ALT_SPIM_CTLR0_ADDR(ALT_SPIM1_ADDR)
7762/* The address of the ALT_SPIM_CTLR1 register for the ALT_SPIM1 instance. */
7763#define ALT_SPIM1_CTLR1_ADDR ALT_SPIM_CTLR1_ADDR(ALT_SPIM1_ADDR)
7764/* The address of the ALT_SPIM_SPIENR register for the ALT_SPIM1 instance. */
7765#define ALT_SPIM1_SPIENR_ADDR ALT_SPIM_SPIENR_ADDR(ALT_SPIM1_ADDR)
7766/* The address of the ALT_SPIM_MWCR register for the ALT_SPIM1 instance. */
7767#define ALT_SPIM1_MWCR_ADDR ALT_SPIM_MWCR_ADDR(ALT_SPIM1_ADDR)
7768/* The address of the ALT_SPIM_SER register for the ALT_SPIM1 instance. */
7769#define ALT_SPIM1_SER_ADDR ALT_SPIM_SER_ADDR(ALT_SPIM1_ADDR)
7770/* The address of the ALT_SPIM_BAUDR register for the ALT_SPIM1 instance. */
7771#define ALT_SPIM1_BAUDR_ADDR ALT_SPIM_BAUDR_ADDR(ALT_SPIM1_ADDR)
7772/* The address of the ALT_SPIM_TXFTLR register for the ALT_SPIM1 instance. */
7773#define ALT_SPIM1_TXFTLR_ADDR ALT_SPIM_TXFTLR_ADDR(ALT_SPIM1_ADDR)
7774/* The address of the ALT_SPIM_RXFTLR register for the ALT_SPIM1 instance. */
7775#define ALT_SPIM1_RXFTLR_ADDR ALT_SPIM_RXFTLR_ADDR(ALT_SPIM1_ADDR)
7776/* The address of the ALT_SPIM_TXFLR register for the ALT_SPIM1 instance. */
7777#define ALT_SPIM1_TXFLR_ADDR ALT_SPIM_TXFLR_ADDR(ALT_SPIM1_ADDR)
7778/* The address of the ALT_SPIM_RXFLR register for the ALT_SPIM1 instance. */
7779#define ALT_SPIM1_RXFLR_ADDR ALT_SPIM_RXFLR_ADDR(ALT_SPIM1_ADDR)
7780/* The address of the ALT_SPIM_SR register for the ALT_SPIM1 instance. */
7781#define ALT_SPIM1_SR_ADDR ALT_SPIM_SR_ADDR(ALT_SPIM1_ADDR)
7782/* The address of the ALT_SPIM_IMR register for the ALT_SPIM1 instance. */
7783#define ALT_SPIM1_IMR_ADDR ALT_SPIM_IMR_ADDR(ALT_SPIM1_ADDR)
7784/* The address of the ALT_SPIM_ISR register for the ALT_SPIM1 instance. */
7785#define ALT_SPIM1_ISR_ADDR ALT_SPIM_ISR_ADDR(ALT_SPIM1_ADDR)
7786/* The address of the ALT_SPIM_RISR register for the ALT_SPIM1 instance. */
7787#define ALT_SPIM1_RISR_ADDR ALT_SPIM_RISR_ADDR(ALT_SPIM1_ADDR)
7788/* The address of the ALT_SPIM_TXOICR register for the ALT_SPIM1 instance. */
7789#define ALT_SPIM1_TXOICR_ADDR ALT_SPIM_TXOICR_ADDR(ALT_SPIM1_ADDR)
7790/* The address of the ALT_SPIM_RXOICR register for the ALT_SPIM1 instance. */
7791#define ALT_SPIM1_RXOICR_ADDR ALT_SPIM_RXOICR_ADDR(ALT_SPIM1_ADDR)
7792/* The address of the ALT_SPIM_RXUICR register for the ALT_SPIM1 instance. */
7793#define ALT_SPIM1_RXUICR_ADDR ALT_SPIM_RXUICR_ADDR(ALT_SPIM1_ADDR)
7794/* The address of the ALT_SPIM_ICR register for the ALT_SPIM1 instance. */
7795#define ALT_SPIM1_ICR_ADDR ALT_SPIM_ICR_ADDR(ALT_SPIM1_ADDR)
7796/* The address of the ALT_SPIM_DMACR register for the ALT_SPIM1 instance. */
7797#define ALT_SPIM1_DMACR_ADDR ALT_SPIM_DMACR_ADDR(ALT_SPIM1_ADDR)
7798/* The address of the ALT_SPIM_DMATDLR register for the ALT_SPIM1 instance. */
7799#define ALT_SPIM1_DMATDLR_ADDR ALT_SPIM_DMATDLR_ADDR(ALT_SPIM1_ADDR)
7800/* The address of the ALT_SPIM_DMARDLR register for the ALT_SPIM1 instance. */
7801#define ALT_SPIM1_DMARDLR_ADDR ALT_SPIM_DMARDLR_ADDR(ALT_SPIM1_ADDR)
7802/* The address of the ALT_SPIM_IDR register for the ALT_SPIM1 instance. */
7803#define ALT_SPIM1_IDR_ADDR ALT_SPIM_IDR_ADDR(ALT_SPIM1_ADDR)
7804/* The address of the ALT_SPIM_SPI_VER_ID register for the ALT_SPIM1 instance. */
7805#define ALT_SPIM1_SPI_VER_ID_ADDR ALT_SPIM_SPI_VER_ID_ADDR(ALT_SPIM1_ADDR)
7806/* The address of the ALT_SPIM_DR register for the ALT_SPIM1 instance. */
7807#define ALT_SPIM1_DR_ADDR ALT_SPIM_DR_ADDR(ALT_SPIM1_ADDR)
7808/* The address of the ALT_SPIM_RX_SMPL_DLY register for the ALT_SPIM1 instance. */
7809#define ALT_SPIM1_RX_SMPL_DLY_ADDR ALT_SPIM_RX_SMPL_DLY_ADDR(ALT_SPIM1_ADDR)
7810/* The base address byte offset for the start of the ALT_SPIM1 component. */
7811#define ALT_SPIM1_OFST 0xfff01000
7812/* The start address of the ALT_SPIM1 component. */
7813#define ALT_SPIM1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SPIM1_OFST))
7814/* The lower bound address range of the ALT_SPIM1 component. */
7815#define ALT_SPIM1_LB_ADDR ALT_SPIM1_ADDR
7816/* The upper bound address range of the ALT_SPIM1 component. */
7817#define ALT_SPIM1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SPIM1_ADDR) + 0x100) - 1))
7818
7819
7820/*
7821 * Component Instance : scanmgr
7822 *
7823 * Instance scanmgr of component ALT_SCANMGR.
7824 *
7825 *
7826 */
7827/* The address of the ALT_SCANMGR_STAT register for the ALT_SCANMGR instance. */
7828#define ALT_SCANMGR_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SCANMGR_ADDR) + ALT_SCANMGR_STAT_OFST))
7829/* The address of the ALT_SCANMGR_EN register for the ALT_SCANMGR instance. */
7830#define ALT_SCANMGR_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SCANMGR_ADDR) + ALT_SCANMGR_EN_OFST))
7831/* The address of the ALT_SCANMGR_FIFOSINGLEBYTE register for the ALT_SCANMGR instance. */
7832#define ALT_SCANMGR_FIFOSINGLEBYTE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SCANMGR_ADDR) + ALT_SCANMGR_FIFOSINGLEBYTE_OFST))
7833/* The address of the ALT_SCANMGR_FIFODOUBLEBYTE register for the ALT_SCANMGR instance. */
7834#define ALT_SCANMGR_FIFODOUBLEBYTE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SCANMGR_ADDR) + ALT_SCANMGR_FIFODOUBLEBYTE_OFST))
7835/* The address of the ALT_SCANMGR_FIFOTRIPLEBYTE register for the ALT_SCANMGR instance. */
7836#define ALT_SCANMGR_FIFOTRIPLEBYTE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SCANMGR_ADDR) + ALT_SCANMGR_FIFOTRIPLEBYTE_OFST))
7837/* The address of the ALT_SCANMGR_FIFOQUADBYTE register for the ALT_SCANMGR instance. */
7838#define ALT_SCANMGR_FIFOQUADBYTE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SCANMGR_ADDR) + ALT_SCANMGR_FIFOQUADBYTE_OFST))
7839/* The base address byte offset for the start of the ALT_SCANMGR component. */
7840#define ALT_SCANMGR_OFST 0xfff02000
7841/* The start address of the ALT_SCANMGR component. */
7842#define ALT_SCANMGR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SCANMGR_OFST))
7843/* The lower bound address range of the ALT_SCANMGR component. */
7844#define ALT_SCANMGR_LB_ADDR ALT_SCANMGR_ADDR
7845/* The upper bound address range of the ALT_SCANMGR component. */
7846#define ALT_SCANMGR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SCANMGR_ADDR) + 0x20) - 1))
7847
7848
7849/*
7850 * Component Instance : rom
7851 *
7852 * Instance rom of component ALT_ROM.
7853 *
7854 *
7855 */
7856/* The base address byte offset for the start of the ALT_ROM component. */
7857#define ALT_ROM_OFST 0xfffd0000
7858/* The start address of the ALT_ROM component. */
7859#define ALT_ROM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_ROM_OFST))
7860/* The lower bound address range of the ALT_ROM component. */
7861#define ALT_ROM_LB_ADDR ALT_ROM_ADDR
7862/* The upper bound address range of the ALT_ROM component. */
7863#define ALT_ROM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_ROM_ADDR) + 0x10000) - 1))
7864
7865
7866/*
7867 * Component Instance : mpuscu
7868 *
7869 * Instance mpuscu of component ALT_MPUSCU.
7870 *
7871 *
7872 */
7873/* The address of the ALT_MPUSCU_REG register for the ALT_MPUSCU instance. */
7874#define ALT_MPUSCU_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_MPUSCU_ADDR) + ALT_MPUSCU_REG_OFST))
7875/* The base address byte offset for the start of the ALT_MPUSCU component. */
7876#define ALT_MPUSCU_OFST 0xfffec000
7877/* The start address of the ALT_MPUSCU component. */
7878#define ALT_MPUSCU_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_MPUSCU_OFST))
7879/* The lower bound address range of the ALT_MPUSCU component. */
7880#define ALT_MPUSCU_LB_ADDR ALT_MPUSCU_ADDR
7881/* The upper bound address range of the ALT_MPUSCU component. */
7882#define ALT_MPUSCU_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_MPUSCU_ADDR) + 0x4) - 1))
7883
7884
7885/*
7886 * Component Instance : mpul2
7887 *
7888 * Instance mpul2 of component ALT_MPUL2.
7889 *
7890 *
7891 */
7892/* The address of the ALT_MPUL2_REG register for the ALT_MPUL2 instance. */
7893#define ALT_MPUL2_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_MPUL2_ADDR) + ALT_MPUL2_REG_OFST))
7894/* The base address byte offset for the start of the ALT_MPUL2 component. */
7895#define ALT_MPUL2_OFST 0xfffef000
7896/* The start address of the ALT_MPUL2 component. */
7897#define ALT_MPUL2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_MPUL2_OFST))
7898/* The lower bound address range of the ALT_MPUL2 component. */
7899#define ALT_MPUL2_LB_ADDR ALT_MPUL2_ADDR
7900/* The upper bound address range of the ALT_MPUL2 component. */
7901#define ALT_MPUL2_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_MPUL2_ADDR) + 0x4) - 1))
7902
7903
7904/*
7905 * Component Instance : ocram
7906 *
7907 * Instance ocram of component ALT_OCRAM.
7908 *
7909 *
7910 */
7911/* The base address byte offset for the start of the ALT_OCRAM component. */
7912#define ALT_OCRAM_OFST 0xffff0000
7913/* The start address of the ALT_OCRAM component. */
7914#define ALT_OCRAM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_OCRAM_OFST))
7915/* The lower bound address range of the ALT_OCRAM component. */
7916#define ALT_OCRAM_LB_ADDR ALT_OCRAM_ADDR
7917/* The upper bound address range of the ALT_OCRAM component. */
7918#define ALT_OCRAM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_OCRAM_ADDR) + 0x10000) - 1))
7919
7920
7921/*
7922 * Address Space : ALT_HPS
7923 *
7924 * Address Map
7925 *
7926 * Address Range | Component
7927 * :------------------------|:-----------------
7928 * 0x00000000 - 0xfbffffff | Undefined
7929 * 0xfc000000 - 0xfc000003 | ALT_STM
7930 * 0xfc000004 - 0xfeffffff | Undefined
7931 * 0xff000000 - 0xff000003 | ALT_DAP
7932 * 0xff000004 - 0xff1fffff | Undefined
7933 * 0xff200000 - 0xff3fffff | ALT_LWFPGASLVS
7934 * 0xff400000 - 0xff47ffff | ALT_LWH2F
7935 * 0xff480000 - 0xff4fffff | Undefined
7936 * 0xff500000 - 0xff507fff | ALT_H2F
7937 * 0xff508000 - 0xff5fffff | Undefined
7938 * 0xff600000 - 0xff67ffff | ALT_F2H
7939 * 0xff680000 - 0xff6fffff | Undefined
7940 * 0xff700000 - 0xff701fff | ALT_EMAC0
7941 * 0xff702000 - 0xff703fff | ALT_EMAC1
7942 * 0xff704000 - 0xff7043ff | ALT_SDMMC
7943 * 0xff704400 - 0xff704fff | Undefined
7944 * 0xff705000 - 0xff7050ff | ALT_QSPI
7945 * 0xff705100 - 0xff705fff | Undefined
7946 * 0xff706000 - 0xff706fff | ALT_FPGAMGR
7947 * 0xff707000 - 0xff707fff | ALT_ACPIDMAP
7948 * 0xff708000 - 0xff70807f | ALT_GPIO0
7949 * 0xff708080 - 0xff708fff | Undefined
7950 * 0xff709000 - 0xff70907f | ALT_GPIO1
7951 * 0xff709080 - 0xff709fff | Undefined
7952 * 0xff70a000 - 0xff70a07f | ALT_GPIO2
7953 * 0xff70a080 - 0xff7fffff | Undefined
7954 * 0xff800000 - 0xff87ffff | ALT_L3
7955 * 0xff880000 - 0xff8fffff | Undefined
7956 * 0xff900000 - 0xff9fffff | ALT_NANDDATA
7957 * 0xffa00000 - 0xffafffff | ALT_QSPIDATA
7958 * 0xffb00000 - 0xffb3ffff | ALT_USB0
7959 * 0xffb40000 - 0xffb7ffff | ALT_USB1
7960 * 0xffb80000 - 0xffb807ff | ALT_NAND
7961 * 0xffb80800 - 0xffb8ffff | Undefined
7962 * 0xffb90000 - 0xffb90003 | ALT_FPGAMGRDATA
7963 * 0xffb90004 - 0xffbfffff | Undefined
7964 * 0xffc00000 - 0xffc001ff | ALT_CAN0
7965 * 0xffc00200 - 0xffc00fff | Undefined
7966 * 0xffc01000 - 0xffc011ff | ALT_CAN1
7967 * 0xffc01200 - 0xffc01fff | Undefined
7968 * 0xffc02000 - 0xffc020ff | ALT_UART0
7969 * 0xffc02100 - 0xffc02fff | Undefined
7970 * 0xffc03000 - 0xffc030ff | ALT_UART1
7971 * 0xffc03100 - 0xffc03fff | Undefined
7972 * 0xffc04000 - 0xffc040ff | ALT_I2C0
7973 * 0xffc04100 - 0xffc04fff | Undefined
7974 * 0xffc05000 - 0xffc050ff | ALT_I2C1
7975 * 0xffc05100 - 0xffc05fff | Undefined
7976 * 0xffc06000 - 0xffc060ff | ALT_I2C2
7977 * 0xffc06100 - 0xffc06fff | Undefined
7978 * 0xffc07000 - 0xffc070ff | ALT_I2C3
7979 * 0xffc07100 - 0xffc07fff | Undefined
7980 * 0xffc08000 - 0xffc080ff | ALT_SPTMR0
7981 * 0xffc08100 - 0xffc08fff | Undefined
7982 * 0xffc09000 - 0xffc090ff | ALT_SPTMR1
7983 * 0xffc09100 - 0xffc1ffff | Undefined
7984 * 0xffc20000 - 0xffc3ffff | ALT_SDR
7985 * 0xffc40000 - 0xffcfffff | Undefined
7986 * 0xffd00000 - 0xffd000ff | ALT_OSC1TMR0
7987 * 0xffd00100 - 0xffd00fff | Undefined
7988 * 0xffd01000 - 0xffd010ff | ALT_OSC1TMR1
7989 * 0xffd01100 - 0xffd01fff | Undefined
7990 * 0xffd02000 - 0xffd020ff | ALT_L4WD0
7991 * 0xffd02100 - 0xffd02fff | Undefined
7992 * 0xffd03000 - 0xffd030ff | ALT_L4WD1
7993 * 0xffd03100 - 0xffd03fff | Undefined
7994 * 0xffd04000 - 0xffd041ff | ALT_CLKMGR
7995 * 0xffd04200 - 0xffd04fff | Undefined
7996 * 0xffd05000 - 0xffd050ff | ALT_RSTMGR
7997 * 0xffd05100 - 0xffd07fff | Undefined
7998 * 0xffd08000 - 0xffd0bfff | ALT_SYSMGR
7999 * 0xffd0c000 - 0xffdfffff | Undefined
8000 * 0xffe00000 - 0xffe00003 | ALT_DMANONSECURE
8001 * 0xffe00004 - 0xffe00fff | Undefined
8002 * 0xffe01000 - 0xffe01003 | ALT_DMASECURE
8003 * 0xffe01004 - 0xffe01fff | Undefined
8004 * 0xffe02000 - 0xffe0207f | ALT_SPIS0
8005 * 0xffe02080 - 0xffe02fff | Undefined
8006 * 0xffe03000 - 0xffe0307f | ALT_SPIS1
8007 * 0xffe03080 - 0xffefffff | Undefined
8008 * 0xfff00000 - 0xfff000ff | ALT_SPIM0
8009 * 0xfff00100 - 0xfff00fff | Undefined
8010 * 0xfff01000 - 0xfff010ff | ALT_SPIM1
8011 * 0xfff01100 - 0xfff01fff | Undefined
8012 * 0xfff02000 - 0xfff0201f | ALT_SCANMGR
8013 * 0xfff02020 - 0xfffcffff | Undefined
8014 * 0xfffd0000 - 0xfffdffff | ALT_ROM
8015 * 0xfffe0000 - 0xfffebfff | Undefined
8016 * 0xfffec000 - 0xfffec003 | ALT_MPUSCU
8017 * 0xfffec004 - 0xfffeefff | Undefined
8018 * 0xfffef000 - 0xfffef003 | ALT_MPUL2
8019 * 0xfffef004 - 0xfffeffff | Undefined
8020 * 0xffff0000 - 0xffffffff | ALT_OCRAM
8021 */
8022
8023#ifdef __ASSEMBLY__
8024#define ALT_CAST(type, ptr) ptr
8025#else /* __ASSEMBLY__ */
8026#define ALT_CAST(type, ptr) ((type) (ptr))
8027#endif /* __ASSEMBLY__ */
8028#ifdef __cplusplus
8029}
8030#endif /* __cplusplus */
8031#endif /* __ALTERA_HPS_H__ */
8032
