RTEMS  5.1
cpu.h
1
9 /*
10  * Copyright (c) 2018.
11  * Amaan Cheval <amaan.cheval@gmail.com>
12  *
13  * Redistribution and use in source and binary forms, with or without
14  * modification, are permitted provided that the following conditions
15  * are met:
16  * 1. Redistributions of source code must retain the above copyright
17  * notice, this list of conditions and the following disclaimer.
18  * 2. Redistributions in binary form must reproduce the above copyright
19  * notice, this list of conditions and the following disclaimer in the
20  * documentation and/or other materials provided with the distribution.
21  *
22  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
23  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
26  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
27  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
28  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
29  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
30  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
31  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
32  * SUCH DAMAGE.
33  */
34
35 #ifndef _RTEMS_SCORE_CPU_H
36 #define _RTEMS_SCORE_CPU_H
37
38 #ifdef __cplusplus
39 extern "C" {
40 #endif
41
42 #include <rtems/score/basedefs.h>
43 #include <rtems/score/cpu_asm.h>
44 #include <rtems/score/x86_64.h>
45
46 #define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE
47 #define CPU_ISR_PASSES_FRAME_POINTER FALSE
48 #define CPU_HARDWARE_FP FALSE
49 #define CPU_SOFTWARE_FP FALSE
50 #define CPU_ALL_TASKS_ARE_FP FALSE
51 #define CPU_IDLE_TASK_IS_FP FALSE
52 #define CPU_USE_DEFERRED_FP_SWITCH FALSE
53 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
54 #define CPU_STACK_GROWS_UP FALSE
55
56 #define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED(64)
57 #define CPU_CACHE_LINE_BYTES 64
58 #define CPU_MODES_INTERRUPT_MASK 0x00000001
59 #define CPU_MAXIMUM_PROCESSORS 32
60
61 #define CPU_EFLAGS_INTERRUPTS_ON 0x00003202
62 #define CPU_EFLAGS_INTERRUPTS_OFF 0x00003002
63
64 #ifndef ASM
65
66 typedef struct {
67  uint64_t rflags;
68
73  uint64_t rbx;
74  void *rsp;
75  void *rbp;
76  uint64_t r12;
77  uint64_t r13;
78  uint64_t r14;
79  uint64_t r15;
80
81  // XXX: FS segment descriptor for TLS
82
83 #ifdef RTEMS_SMP
84  volatile bool is_executing;
85 #endif
87
88 #define _CPU_Context_Get_SP( _context ) \
89  (_context)->rsp
90
91 /*
92  * Caller-saved registers for interrupt frames
93  */
94 typedef struct {
103  uint64_t rax;
104  uint64_t rcx;
105  uint64_t rdx;
106  uint64_t rsi;
107  uint64_t r8;
108  uint64_t r9;
109  uint64_t r10;
110  uint64_t r11;
111
112  /*
113  * This holds the rsp just before _ISR_Handler is called; it's needed because
114  * in the handler, we align the stack to make further calls, and we're not
115  * sure how alignment may move the stack-pointer around, leaving no way to get
116  * back to the stack, and therefore the interrupt frame.
117  */
118  uint64_t saved_rsp;
119
120  /* XXX:
121  * - FS segment selector for TLS
122  * - x87 status word?
123  * - MMX?
124  * - XMM?
125  */
127
128 #endif /* !ASM */
129
130 #define CPU_INTERRUPT_FRAME_SIZE 72
131
132 /*
133  * When SMP is enabled, percpuasm.c has a similar assert, but since we use the
134  * interrupt frame regardless of SMP, we'll confirm it here.
135  */
136 #ifndef ASM
137  RTEMS_STATIC_ASSERT(
140  );
141 #endif
142
143 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
144 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
145 #define CPU_STACK_MINIMUM_SIZE (1024*4)
146 #define CPU_SIZEOF_POINTER 8
147 #define CPU_ALIGNMENT 8
148 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
149 #define CPU_STACK_ALIGNMENT 16
150 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
151
152 /*
153  * ISR handler macros
154  */
155
156 #ifndef ASM
157
158 #define _CPU_Initialize_vectors()
159
160 #define _CPU_ISR_Enable(_level) \
161 { \
162  amd64_enable_interrupts(); \
163  _level = 0; \
164  (void) _level; /* Prevent -Wunused-but-set-variable */ \
165 }
166
167 #define _CPU_ISR_Disable(_level) \
168 { \
169  amd64_enable_interrupts(); \
170  _level = 1; \
171  (void) _level; /* Prevent -Wunused-but-set-variable */ \
172 }
173
174 #define _CPU_ISR_Flash(_level) \
175 { \
176  amd64_enable_interrupts(); \
177  amd64_disable_interrupts(); \
178  _level = 1; \
179  (void) _level; /* Prevent -Wunused-but-set-variable */ \
180 }
181
183 {
184  return (level & EFLAGS_INTR_ENABLE) != 0;
185 }
186
187 RTEMS_INLINE_ROUTINE void _CPU_ISR_Set_level(uint32_t new_level)
188 {
189  if ( new_level ) {
190  amd64_disable_interrupts();
191  }
192  else {
193  amd64_enable_interrupts();
194  }
195 }
196
198 {
199  uint64_t rflags;
200
201  __asm__ volatile ( "pushf; \
202  popq %0"
203  : "=rm" (rflags)
204  );
205
206  uint32_t level = (rflags & EFLAGS_INTR_ENABLE) ? 0 : 1;
207  return level;
208 }
209
210 /* end of ISR handler macros */
211
212 /* Context handler macros */
213 #define _CPU_Context_Destroy( _the_thread, _the_context ) \
214  { \
215  }
216
218  Context_Control *the_context,
219  void *stack_area_begin,
220  size_t stack_area_size,
221  uint32_t new_level,
222  void (*entry_point)( void ),
223  bool is_fp,
224  void *tls_area
225 );
226
227 #define _CPU_Context_Restart_self( _the_context ) \
228  _CPU_Context_restore( (_the_context) );
229
230 #define _CPU_Context_Initialize_fp( _destination ) \
231  { \
232  *(*(_destination)) = _CPU_Null_fp_context; \
233  }
234
235 /* end of Context handler macros */
236
237 /* Fatal Error manager macros */
238
239 #define _CPU_Fatal_halt( _source, _error ) \
240  { \
241  }
242
243 /* end of Fatal Error manager macros */
244
245 /* Bitfield handler macros */
246
247 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
248
249 #if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
250 #define _CPU_Bitfield_Find_first_bit( _value, _output ) \
251  { \
252  (_output) = 0; /* do something to prevent warnings */ \
253  }
254 #endif
255
256 /* end of Bitfield handler macros */
257
258 #if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
259 #define _CPU_Priority_Mask( _bit_number ) \
260  ( 1 << (_bit_number) )
261 #endif
262
263 #if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
264 #define _CPU_Priority_bits_index( _priority ) \
265  (_priority)
266 #endif
267
268 /* end of Priority handler macros */
269
270 /* functions */
271
272 void _CPU_Initialize(void);
273
274 void *_CPU_Thread_Idle_body( uintptr_t ignored );
275
277  Context_Control *run,
278  Context_Control *heir
279 );
280
282  Context_Control *new_context
284
285 typedef struct {
286  uint32_t processor_state_register;
287  uint32_t integer_registers [1];
288  double float_registers [1];
290
292
293 static inline uint32_t CPU_swap_u32(
294  uint32_t value
295 )
296 {
297  uint32_t byte1, byte2, byte3, byte4, swapped;
298
299  byte4 = (value >> 24) & 0xff;
300  byte3 = (value >> 16) & 0xff;
301  byte2 = (value >> 8) & 0xff;
302  byte1 = value & 0xff;
303
304  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
305  return swapped;
306 }
307
308 #define CPU_swap_u16( value ) \
309  (((value&0xff) << 8) | ((value >> 8)&0xff))
310
311 typedef uint32_t CPU_Counter_ticks;
312
313 uint32_t _CPU_Counter_frequency( void );
314
315 CPU_Counter_ticks _CPU_Counter_read( void );
316
317
318 static inline CPU_Counter_ticks _CPU_Counter_difference(
319  CPU_Counter_ticks second,
320  CPU_Counter_ticks first
321 )
322 {
323  return second - first;
324 }
325
326 #ifdef RTEMS_SMP
327  *
328  uint32_t _CPU_SMP_Initialize( void );
329
330  bool _CPU_SMP_Start_processor( uint32_t cpu_index );
331
332  void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
333
334  void _CPU_SMP_Prepare_start_multitasking( void );
335
336  static inline uint32_t _CPU_SMP_Get_current_processor( void )
337  {
338  return 123;
339  }
340
341  void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
342
343  static inline void _CPU_SMP_Processor_event_broadcast( void )
344  {
345  __asm__ volatile ( "" : : : "memory" );
346  }
347
348  static inline void _CPU_SMP_Processor_event_receive( void )
349  {
350  __asm__ volatile ( "" : : : "memory" );
351  }
352
353  static inline bool _CPU_Context_Get_is_executing(
354  const Context_Control *context
355  )
356  return context->is_executing;
357  }
358
359  static inline void _CPU_Context_Set_is_executing(
361  bool is_executing
362  )
363  {
364  }
365
366 #endif /* RTEMS_SMP */
367
368 typedef uintptr_t CPU_Uint32ptr;
369
370 #ifdef __cplusplus
371 }
372 #endif
373
374 #endif /* ASM */
375
376 #endif /* _RTEMS_SCORE_CPU_H */
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
void _CPU_ISR_Set_level(uint32_t level)
Sets the hardware interrupt level by the level value.
Definition: cpu.c:57
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Thread register context.
Definition: cpu.h:194
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
CPU initialization.
Definition: cpu.c:45
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
uint64_t rax
Definition: cpu.h:103
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
unsigned context
Definition: tlb.h:108
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
Basic Definitions.
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
uint64_t rbx
Definition: cpu.h:73
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
Definition: cpuimpl.h:78
