RTEMS  5.1
#include <bdpart.h>
rtems_bdpart_format_type type
struct {
   uint32_t   disk_id
   bool   dos_compatibility
} mbr
struct {
   uuid_t   disk_id
} gpt
Disk format description.
Field Documentation
◆ disk_id [1/2]
uint32_t rtems_bdpart_format::disk_id
Disk ID in MBR at offset 440.
◆ disk_id [2/2]
uuid_t rtems_bdpart_format::disk_id
Disk ID in GPT header.
◆ dos_compatibility
bool rtems_bdpart_format::dos_compatibility
This option is used for partition table creation and validation checks before a write to the disk. It ensures that the first primary partition and the logical partitions start at head one and sector one under the virtual one head and 63 sectors geometry. Each begin and end of a partition will be aligned to the virtual cylinder boundary.
◆ gpt
struct { ... } rtems_bdpart_format::gpt
GPT format fields.
◆ mbr
struct { ... } rtems_bdpart_format::mbr
MBR format fields.
◆ type
rtems_bdpart_format_type rtems_bdpart_format::type
Format type.
The documentation for this union was generated from the following file:
