    RTEMS
    5.1
Go to the documentation of this file.   19 #define TX4925_REG_BASE 0xFF1F0000    25 #define TX4925_CFG_CCFG 0xE000          26 #define TX4925_CFG_REVID 0xE004         27 #define TX4925_CFG_PCFG 0xE008          28 #define TX4925_CFG_TOEA 0xE00C          29 #define TX4925_CFG_PDNCTR 0xE010        30 #define TX4925_CFG_GARBP 0xE018         31 #define TX4925_CFG_TOCNT 0xE020         32 #define TX4925_CFG_DRQCTR 0xE024            33 #define TX4925_CFG_CLKCTR 0xE028            34 #define TX4925_CFG_GARBC 0xE02C         35 #define TX4925_CFG_RAMP 0xE030          38 #define SELCHI  0x00100000    39 #define SELTMR0 0x00000200    46 #define TX4925_TIMER0_BASE 0xF000    47 #define TX4925_TIMER1_BASE 0xF100    48 #define TX4925_TIMER2_BASE 0xF200    50 #define TX4925_TIMER_TCR  0x00              51 #define TX4925_TIMER_TISR 0x04              52 #define TX4925_TIMER_CPRA 0x08              53 #define TX4925_TIMER_CPRB 0x0C              54 #define TX4925_TIMER_ITMR 0x10              55 #define TX4925_TIMER_CCDR 0x20              56 #define TX4925_TIMER_PGMR 0x30              57 #define TX4925_TIMER_WTMR 0x40              58 #define TX4925_TIMER_TRR  0xF0              61 #define TIMER_CLEAR_ENABLE_MASK     0x1    62 #define TIMER_INT_ENABLE_MASK   0x8000    79 #define TX4925_IRQCTL_DEN 0xF600            80 #define TX4925_IRQCTL_DM0 0xF604            81 #define TX4925_IRQCTL_DM1 0xF608            82 #define TX4925_IRQCTL_LVL0 0xF610           83 #define TX4925_IRQCTL_LVL1 0xF614           84 #define TX4925_IRQCTL_LVL2 0xF618           85 #define TX4925_IRQCTL_LVL3 0xF61C           86 #define TX4925_IRQCTL_LVL4 0xF620           87 #define TX4925_IRQCTL_LVL5 0xF624           88 #define TX4925_IRQCTL_LVL6 0xF628           89 #define TX4925_IRQCTL_LVL7 0xF62C           90 #define TX4925_IRQCTL_MSK 0xF640            91 #define TX4925_IRQCTL_EDC 0xF660            92 #define TX4925_IRQCTL_PND 0xF680            93 #define TX4925_IRQCTL_CS 0xF6A0             94 #define TX4925_IRQCTL_FLAG0 0xF510          95 #define TX4925_IRQCTL_FLAG1 0xF514          96 #define TX4925_IRQCTL_POL 0xF518            97 #define TX4925_IRQCTL_RCNT 0xF51C           98 #define TX4925_IRQCTL_MASKINT 0xF520        99 #define TX4925_IRQCTL_MASKEXT 0xF524       101 #define TX4925_REG_READ( _base, _register ) \   102   *((volatile uint32_t *)((_base) + (_register)))   104 #define TX4925_REG_WRITE( _base, _register, _value ) \   105   *((volatile uint32_t *)((_base) + (_register))) = (_value)
