#define  | TX4925_REG_BASE   0xFF1F0000 |
#define  | TX4925_CFG_CCFG   0xE000		/* Chip Configuration Register */ |
#define  | TX4925_CFG_REVID   0xE004		/* Chip Revision ID Register */ |
#define  | TX4925_CFG_PCFG   0xE008		/* Pin Configuration Register */ |
#define  | TX4925_CFG_TOEA   0xE00C		/* TimeOut Error Access Address Register */ |
#define  | TX4925_CFG_PDNCTR   0xE010	/* Power Down Control Register */ |
#define  | TX4925_CFG_GARBP   0xE018		/* GBUS Arbiter Priority Register */ |
#define  | TX4925_CFG_TOCNT   0xE020		/* Timeout Count Register */ |
#define  | TX4925_CFG_DRQCTR   0xE024		/* DMA Request Control Register */ |
#define  | TX4925_CFG_CLKCTR   0xE028		/* Clock Control Register */ |
#define  | TX4925_CFG_GARBC   0xE02C		/* GBUS Arbiter Control Register */ |
#define  | TX4925_CFG_RAMP   0xE030		/* Register Address Mapping Register */ |
#define  | SELCHI   0x00100000 |
#define  | SELTMR0   0x00000200 |
#define  | TX4925_TIMER0_BASE   0xF000 |
#define  | TX4925_TIMER1_BASE   0xF100 |
#define  | TX4925_TIMER2_BASE   0xF200 |
#define  | TX4925_TIMER_TCR   0x00			/* Timer Control Register */ |
#define  | TX4925_TIMER_TISR   0x04			/* Timer Interrupt Status Register */ |
#define  | TX4925_TIMER_CPRA   0x08			/* Compare Register A */ |
#define  | TX4925_TIMER_CPRB   0x0C			/* Compare Register B */ |
#define  | TX4925_TIMER_ITMR   0x10			/* Interval Timer Mode Register */ |
#define  | TX4925_TIMER_CCDR   0x20			/* Divide Cycle Register */ |
#define  | TX4925_TIMER_PGMR   0x30			/* Pulse Generator Mode Register */ |
#define  | TX4925_TIMER_WTMR   0x40			/* Reserved Register */ |
#define  | TX4925_TIMER_TRR   0xF0			/* Timer Read Register */ |
#define  | TIMER_CLEAR_ENABLE_MASK   0x1 |
#define  | TIMER_INT_ENABLE_MASK   0x8000 |
#define  | FFI   0x1 |
#define  | TPIAE   0x4000 |
#define  | TPIBE   0x8000 |
#define  | TIIS   0x1 |
#define  | TPIAS   0x2 |
#define  | TPIBS   0x4 |
#define  | TWIS   0x8 |
#define  | TX4925_IRQCTL_DEN   0xF600		/* Interrupt Detection Enable Register */ |
#define  | TX4925_IRQCTL_DM0   0xF604		/* Interrupt Detection Mode Register 0 */ |
#define  | TX4925_IRQCTL_DM1   0xF608		/* Interrupt Detection Mode Register 1 */ |
#define  | TX4925_IRQCTL_LVL0   0xF610		/* Interrupt Level Register 0 */ |
#define  | TX4925_IRQCTL_LVL1   0xF614		/* Interrupt Level Register 1 */ |
#define  | TX4925_IRQCTL_LVL2   0xF618		/* Interrupt Level Register 2 */ |
#define  | TX4925_IRQCTL_LVL3   0xF61C		/* Interrupt Level Register 3 */ |
#define  | TX4925_IRQCTL_LVL4   0xF620		/* Interrupt Level Register 4 */ |
#define  | TX4925_IRQCTL_LVL5   0xF624		/* Interrupt Level Register 5 */ |
#define  | TX4925_IRQCTL_LVL6   0xF628		/* Interrupt Level Register 6 */ |
#define  | TX4925_IRQCTL_LVL7   0xF62C		/* Interrupt Level Register 7 */ |
#define  | TX4925_IRQCTL_MSK   0xF640		/* Interrupt Mask Register */ |
#define  | TX4925_IRQCTL_EDC   0xF660		/* Interrupt Edge Detection Clear Register */ |
#define  | TX4925_IRQCTL_PND   0xF680		/* Interrupt Pending Register */ |
#define  | TX4925_IRQCTL_CS   0xF6A0			/* Interrupt Current Status Register */ |
#define  | TX4925_IRQCTL_FLAG0   0xF510		/* Interrupt Request Flag Register 0 */ |
#define  | TX4925_IRQCTL_FLAG1   0xF514		/* Interrupt Request Flag Register 1 */ |
#define  | TX4925_IRQCTL_POL   0xF518		/* Interrupt Request Polarity Control Register */ |
#define  | TX4925_IRQCTL_RCNT   0xF51C		/* Interrupt Request Control Register */ |
#define  | TX4925_IRQCTL_MASKINT   0xF520	/* Interrupt Request Internal Interrupt Mask Register */ |
#define  | TX4925_IRQCTL_MASKEXT   0xF524	/* Interrupt Request External Interrupt Mask Register */ |
#define  | TX4925_REG_READ(_base,  _register)   *((volatile uint32_t *)((_base) + (_register))) |
#define  | TX4925_REG_WRITE(_base,  _register,  _value)   *((volatile uint32_t *)((_base) + (_register))) = (_value) |
MIPS Tx4925 specific information
