RTEMS  5.1
Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
termiostypes.h File Reference
#include <rtems/libio.h>
#include <rtems/assoc.h>
#include <rtems/chain.h>
#include <rtems/thread.h>
#include <sys/ioccom.h>
#include <stdint.h>
#include <termios.h>
struct  ttywakeup
struct  rtems_termios_rawbuf
struct  rtems_termios_device_context
 Termios device context. More...
struct  rtems_termios_device_handler
 Termios device handler. More...
struct  rtems_termios_device_flow
 Termios device flow control handler. More...
struct  rtems_termios_device_node
 Termios device node for installed devices. More...
struct  rtems_termios_tty
struct  rtems_termios_linesw
#define RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER(name)
 Initializer for static initialization of Termios device contexts. More...
#define TTYDISC   0 /* termios tty line discipline */
#define TABLDISC   3 /* tablet discipline */
#define SLIPDISC   4 /* serial IP discipline */
#define PPPDISC   5 /* PPP discipline */
#define MAXLDISC   8
#define RTEMS_IO_SNDWAKEUP   _IOW('t', 11, struct ttywakeup ) /* send tty wakeup */
#define RTEMS_IO_RCVWAKEUP   _IOW('t', 12, struct ttywakeup ) /* recv tty wakeup */
#define OLCUC   0x00000100 /* map lower case to upper case on output */
#define IUCLC   0x00004000 /* map upper case to lower case on input */
#define RTEMS_TERMIOS_NUMBER_BAUD_RATES   25
typedef struct rtems_termios_device_context rtems_termios_device_context
typedef struct rtems_termios_device_node rtems_termios_device_node
typedef struct rtems_termios_tty rtems_termios_tty
typedef uint32_t rtems_termios_baud_t
enum  rtems_termios_device_mode { TERMIOS_POLLED, TERMIOS_IRQ_DRIVEN, TERMIOS_TASK_DRIVEN, TERMIOS_IRQ_SERVER_DRIVEN }
void rtems_termios_device_lock_acquire_default (rtems_termios_device_context *ctx, rtems_interrupt_lock_context *lock_context)
void rtems_termios_device_lock_release_default (rtems_termios_device_context *ctx, rtems_interrupt_lock_context *lock_context)
RTEMS_INLINE_ROUTINE void rtems_termios_device_context_initialize (rtems_termios_device_context *context, const char *name)
 Initializes a device context. More...
rtems_status_code rtems_termios_device_install (const char *device_file, const rtems_termios_device_handler *handler, const rtems_termios_device_flow *flow, rtems_termios_device_context *context)
 Installs a Termios device. More...
RTEMS_INLINE_ROUTINE void * rtems_termios_get_device_context (const rtems_termios_tty *tty)
 Returns the device context of an installed Termios device. More...
RTEMS_INLINE_ROUTINE void rtems_termios_device_lock_acquire (rtems_termios_device_context *context, rtems_interrupt_lock_context *lock_context)
 Acquires the device lock. More...
RTEMS_INLINE_ROUTINE void rtems_termios_device_lock_release (rtems_termios_device_context *context, rtems_interrupt_lock_context *lock_context)
 Releases the device lock. More...
void rtems_termios_set_best_baud (struct termios *term, uint32_t baud)
 Sets the best baud value in the Termios control. More...
void rtems_termios_rxirq_occured (struct rtems_termios_tty *tty)
void rtems_termios_puts (const void *buf, size_t len, struct rtems_termios_tty *tty)
speed_t rtems_termios_number_to_baud (rtems_termios_baud_t baud)
 Converts the Integral Baud value baud to the Termios Control Flag Representation. More...
rtems_termios_baud_t rtems_termios_baud_to_number (speed_t baud)
 Converts the baud flags to an integral baud value. More...
int rtems_termios_baud_to_index (rtems_termios_baud_t termios_baud)
 Convert Bxxx Constant to Index.
int rtems_termios_set_initial_baud (struct rtems_termios_tty *tty, rtems_termios_baud_t baud)
 Sets the initial baud in the Termios context tty. More...
int rtems_termios_kqfilter (rtems_libio_t *iop, struct knote *kn)
 Termios kqueue() filter filesystem node handler. More...
int rtems_termios_mmap (rtems_libio_t *iop, void **addr, size_t len, int prot, off_t off)
 Termios mmap() filter filesystem node handler. More...
int rtems_termios_poll (rtems_libio_t *iop, int events)
 Termios poll() filesystem node handler. More...
struct rtems_termios_linesw rtems_termios_linesw []
int rtems_termios_nlinesw
const rtems_assoc_t rtems_termios_baud_table []
 RTEMS Termios Baud Table.
rtems_mutex rtems_termios_ttyMutex
RTEMS termios device support internal data structures
◆ RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER
#define RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER (   name)
Value:
rtems_termios_device_lock_acquire_default, \
rtems_termios_device_lock_release_default \
#define RTEMS_INTERRUPT_LOCK_INITIALIZER(_name)
Initializer for static initialization of interrupt locks.
Definition: intr.h:253
Parameters
nameThe name for the interrupt lock. It must be a string. The name is only used if profiling is enabled.
Typedef Documentation
◆ rtems_termios_device_context
◆ rtems_termios_device_node
See also
rtems_termios_device_install().
◆ rtems_termios_baud_to_number()
rtems_termios_baud_t rtems_termios_baud_to_number ( speed_t  baud)
Return values
0Invalid baud value or a baud value of B0.
otherIntegral baud value.
◆ rtems_termios_device_context_initialize()
RTEMS_INLINE_ROUTINE void rtems_termios_device_context_initialize ( rtems_termios_device_context *  context,
const char *  name
Parameters
[in]contextThe Termios device context.
[in]nameThe name for the interrupt lock. This name must be a string persistent throughout the life time of this lock. The name is only used if profiling is enabled.
◆ rtems_termios_device_install()
rtems_status_code rtems_termios_device_install ( const char *  device_file,
const rtems_termios_device_handler *  handler,
const rtems_termios_device_flow *  flow,
The installed Termios device may be removed via unlink().
Parameters
[in]device_fileThe device file path.
[in]handlerThe device handler. It must be persistent throughout the installed time of the device.
[in]flowThe device flow control handler. The device flow control handler are optional and may be NULL. If present must be persistent throughout the installed time of the device.
[in]contextThe device context. It must be persistent throughout the installed time of the device.
Return values
RTEMS_SUCCESSFULSuccessful operation.
RTEMS_NO_MEMORYNot enough memory to create a device node.
RTEMS_UNSATISFIEDCreation of the device file failed.
RTEMS_INCORRECT_STATETermios is not initialized.
See also
rtems_termios_get_device_context().
◆ rtems_termios_device_lock_acquire()
RTEMS_INLINE_ROUTINE void rtems_termios_device_lock_acquire ( rtems_termios_device_context *  context,
rtems_interrupt_lock_context *  lock_context
Parameters
[in]lock_contextThe local interrupt lock context for an acquire and release pair.
◆ rtems_termios_device_lock_release()
RTEMS_INLINE_ROUTINE void rtems_termios_device_lock_release ( rtems_termios_device_context *  context,
Parameters
◆ rtems_termios_get_device_context()
RTEMS_INLINE_ROUTINE void* rtems_termios_get_device_context ( const rtems_termios_tty *  tty)
Parameters
[in]ttyThe Termios control.
◆ rtems_termios_kqfilter()
int rtems_termios_kqfilter ( rtems_libio_t *  iop,
struct knote *  kn
Real implementation is provided by libbsd.
◆ rtems_termios_mmap()
int rtems_termios_mmap ( rtems_libio_t *  iop,
void **  addr,
size_t  len,
int  prot,
off_t  off
◆ rtems_termios_number_to_baud()
speed_t rtems_termios_number_to_baud ( rtems_termios_baud_t  baud)
Return values
B0Invalid baud value or a baud value of 0.
otherBaud constant according to baud.
◆ rtems_termios_poll()
int rtems_termios_poll ( rtems_libio_t *  iop,
int  events
◆ rtems_termios_set_best_baud()
void rtems_termios_set_best_baud ( struct termios *  term,
uint32_t  baud
The valid Termios baud values are between 0 and 460800. The Termios baud value is chosen which minimizes the difference to the value specified.
Parameters
[in]termThe Termios attributes.
[in]baudThe current baud setting of the device.
◆ rtems_termios_set_initial_baud()
int rtems_termios_set_initial_baud ( struct rtems_termios_tty *  tty,
Return values
0Successful operation.
-1Invalid baud value.
