wiseman_txdesc_t | sc_txdescs [NTXDESC] |
wiseman_rxdesc_t | sc_rxdescs [NRXDESC] |
struct mbuf * | txs_mbuf [NTXDESC] |
struct mbuf * | rxs_mbuf [NRXDESC] |
struct wm_softc * | next_module |
volatile unsigned int | if_errsts [IF_ERR_BUFSZE] |
unsigned int | if_err_ptr1 |
unsigned int | if_err_ptr2 |
int | txs_firstdesc |
int | txs_lastdesc |
int | txs_ndesc |
unsigned | sc_membase |
unsigned | sc_memsize |
char | dv_xname [16] |
void * | sc_sdhook |
struct arpcom | arpcom |
int | sc_flags |
int | sc_bus_speed |
int | sc_flowflags |
void * | sc_ih |
int | sc_ee_addrbits |
rtems_id | daemonTid |
rtems_id | daemonSync |
int | txq_next |
uint32_t | txq_nactive |
uint32_t | txq_fi |
uint32_t | txq_free |
uint32_t | sc_txctx_ipcs |
uint32_t | sc_txctx_tucs |
int | sc_rxptr |
int | sc_rxdiscard |
int | sc_rxlen |
uint32_t | sc_ctrl |
uint32_t | sc_ctrl_ext |
uint32_t | sc_icr |
uint32_t | sc_tctl |
uint32_t | sc_rctl |
uint32_t | sc_tipg |
uint32_t | sc_fcrtl |
uint32_t | sc_pba |
int | sc_mchash_type |
struct { |
volatile unsigned long rxInterrupts |
volatile unsigned long txInterrupts |
unsigned long linkInterrupts |
unsigned long length_errors |
unsigned long frame_errors |
unsigned long crc_errors |
unsigned long rxOvrRunInterrupts |
unsigned long rxSeqErr |
unsigned long rxC_ordered |
unsigned long ghostInterrupts |
unsigned long linkStatusChng |
| } | stats |
- bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c
