    RTEMS
    5.1
#include <tms570_selftest_parity.h>
Data Fields | |
| unsigned char | esm_prim_grp |
| unsigned char | esm_prim_chan |
| unsigned char | esm_sec_grp |
| unsigned char | esm_sec_chan |
| int | fail_code |
| volatile uint32_t * | ram_loc |
| volatile uint32_t * | par_loc |
| uint32_t | par_xor |
| volatile uint32_t * | par_cr_reg |
| uint32_t | par_cr_test |
| volatile uint32_t * | par_st_reg |
| uint32_t | par_st_clear |
| tms570_selftest_par_fnc_t * | partest_fnc |
| volatile void * | fnc_data |
Decriptor specifying registers addresses and values used to test that parity protection is working for given hardware module/peripheral. It is used during initial chip self-tests.
| unsigned char tms570_selftest_par_desc::esm_prim_chan |
ESM primary signalling channel number.
| unsigned char tms570_selftest_par_desc::esm_prim_grp |
ESM primary signalling group number.
| unsigned char tms570_selftest_par_desc::esm_sec_chan |
ESM optional/alternative signalling channel.
| unsigned char tms570_selftest_par_desc::esm_sec_grp |
ESM optional/alternative signalling group.
| int tms570_selftest_par_desc::fail_code |
Error code reported to bsp_selftest_fail_notification() in the case of the test failure.
| volatile void* tms570_selftest_par_desc::fnc_data |
Pointer to the base of tested peripheral registers. It is required by some test functions (CAN and MibSPI)
| volatile uint32_t* tms570_selftest_par_desc::par_cr_reg |
Address of module parity test control register.
| uint32_t tms570_selftest_par_desc::par_cr_test |
Mask of bit which cause switch to a test mode.
| volatile uint32_t* tms570_selftest_par_desc::par_loc |
Address of mapping of parity bits into CPU address space.
| uint32_t tms570_selftest_par_desc::par_st_clear |
Optional value which is written to status register to clear error.
| volatile uint32_t* tms570_selftest_par_desc::par_st_reg |
Optional module parity status register which.
| uint32_t tms570_selftest_par_desc::par_xor |
Bitmask used to alter parity to cause intentional parity failure.
| tms570_selftest_par_fnc_t* tms570_selftest_par_desc::partest_fnc |
Function which specialized for given kind of peripheral/module mechanism testing.
| volatile uint32_t* tms570_selftest_par_desc::ram_loc |
Address of memory protected by parity.
 1.8.15
