SPI bus control.
 More...
#include <spi.h>
| int(*  | transfer )(spi_bus *bus, const spi_ioc_transfer *msgs, uint32_t msg_count) |
|   | Transfers SPI messages.  More...
| int(*  | setup )(spi_bus *bus) |
|   | Checks if maximum speed and bits per word are in a valid range for the device.  More...
| void(*  | destroy )(spi_bus *bus) |
|   | Destroys the bus.  More...
rtems_recursive_mutex  | mutex |
|   | Mutex to protect the bus access.
uint32_t  | max_speed_hz |
|   | Maximum Speed in Hz.
uint32_t  | speed_hz |
|   | Indicates the speed of the current device message.
bool  | cs_change |
|   | Indicates if chip select must be set high after transfer.
uint8_t  | cs |
|   | Indicates which device is selected by chip select.
uint8_t  | bits_per_word |
|   | Indicates the bits per word used on the device.
bool  | lsb_first |
|   | Indicates if LSB is supposed to be transmitted first.
uint32_t  | mode |
|   | Current mode.
uint16_t  | delay_usecs |
|   | Indicates the delay between transfers on different chip select devices.
◆ destroy
          | void(* spi_bus::destroy) (spi_bus *bus) |
Destroys the bus.
- Parameters
◆ setup
          | int(* spi_bus::setup) (spi_bus *bus) |
- Parameters
- Return values
    | 0 | Successful operation.  |
    | negative | Negative error number in case of an error.  |
◆ transfer
- Parameters
    | [in] | bus | The bus control.  |
    | [in] | msgs | The messages to transfer.  |
    | [in] | msg_count | The count of messages to transfer. It must be positive. |
- Return values
- cpukit/include/dev/spi/spi.h
