RTEMS
5.1
Telnet configuration structure. More...
#include <telnetd.h>
Data Fields | |
| rtems_telnetd_command | command |
| Function invoked for each Telnet connection. More... | |
| void * | arg |
| Argument for command function. | |
| rtems_task_priority | priority |
| Task priority. More... | |
| size_t | stack_size |
| Task stack size. More... | |
| rtems_shell_login_check_t | login_check |
| Login check function. More... | |
| bool | keep_stdio |
| This is an obsolete configuration option. More... | |
| uint16_t | client_maximum |
| Maximum number of clients which can connect to the system at a time. More... | |
| uint16_t | port |
| Server port number in host byte order. More... | |
| uint16_t rtems_telnetd_config_table::client_maximum |
Use 0 for the default value.
| rtems_telnetd_command rtems_telnetd_config_table::command |
The first parameter contains the device name. The second parameter contains the argument pointer of this configuration table.
| bool rtems_telnetd_config_table::keep_stdio |
It must be set to false, otherwise rtems_telnetd_start() will do nothing and returns with a status of RTEMS_NOT_IMPLEMENTED.
| rtems_shell_login_check_t rtems_telnetd_config_table::login_check |
Method used for login checks. Use NULL to disable a login check.
| uint16_t rtems_telnetd_config_table::port |
| rtems_task_priority rtems_telnetd_config_table::priority |
Task priority.
| size_t rtems_telnetd_config_table::stack_size |
Task stack size.
1.8.15
