RTEMS  5.1
rtems_rtl_data Struct Reference
#include <rtl.h>
rtems_recursive_mutex lock
rtems_rtl_alloc_data allocator
rtems_chain_control objects
rtems_chain_control pending
const char * paths
rtems_rtl_symbols globals
rtems_rtl_archives archives
rtems_rtl_unresolved unresolved
rtems_rtl_obj * base
rtems_rtl_obj_cache symbols
rtems_rtl_obj_cache strings
rtems_rtl_obj_cache relocs
rtems_rtl_obj_comp decomp
int last_errno
char last_error [64]
The global RTL data. This structure is allocated on the heap when the first call to the RTL is made and never released.
The global symbol table is a hash table held in this structure and the actual symbols are part of the object's structure. If this is a problem we could look at a hash table per object file.
Field Documentation
◆ allocator
rtems_rtl_alloc_data rtems_rtl_data::allocator
The allocator data.
◆ archives
rtems_rtl_archives rtems_rtl_data::archives
Archive search and loader.
◆ base
rtems_rtl_obj* rtems_rtl_data::base
Base object file.
◆ decomp
rtems_rtl_obj_comp rtems_rtl_data::decomp
The decompression compressor.
◆ globals
rtems_rtl_symbols rtems_rtl_data::globals
Global symbol table.
◆ last_errno
int rtems_rtl_data::last_errno
Last error number.
◆ last_error
char rtems_rtl_data::last_error[64]
Last error string.
◆ lock
rtems_recursive_mutex rtems_rtl_data::lock
The RTL lock
◆ objects
rtems_chain_control rtems_rtl_data::objects
List if loaded object files.
◆ paths
const char* rtems_rtl_data::paths
Search paths for archives.
◆ pending
rtems_chain_control rtems_rtl_data::pending
Listof object files needing work.
◆ relocs
rtems_rtl_obj_cache rtems_rtl_data::relocs
Relocations object file cache.
◆ strings
rtems_rtl_obj_cache rtems_rtl_data::strings
Strings object file cache.
◆ symbols
rtems_rtl_obj_cache rtems_rtl_data::symbols
Symbols object file cache.
◆ unresolved
rtems_rtl_unresolved rtems_rtl_data::unresolved
Unresolved symbols.
