RTEMS  5.1
rtems_nvdisk Struct Reference
uint32_t flags
uint32_t block_size
uint32_t block_count
rtems_nvdisk_device_ctl * devices
uint32_t device_count
uint32_t cs_pages
rtems_mutex lock
uint32_t info_level
The NV disk control structure for a single disk. There is one for each minor disk in the system.
Field Documentation
◆ block_count
uint32_t rtems_nvdisk::block_count
The number of available blocks.
◆ block_size
uint32_t rtems_nvdisk::block_size
The block size for this disk.
◆ cs_pages
uint32_t rtems_nvdisk::cs_pages
The num of pages of checksums.
◆ device_count
uint32_t rtems_nvdisk::device_count
The number of NV devices.
◆ devices
rtems_nvdisk_device_ctl* rtems_nvdisk::devices
The NV devices for this disk.
◆ flags
uint32_t rtems_nvdisk::flags
configuration flags.
◆ info_level
uint32_t rtems_nvdisk::info_level
The info trace level.
◆ lock
rtems_mutex rtems_nvdisk::lock
Mutex for threading protection.
