RTEMS  5.1
rtems_flashdisk Struct Reference
rtems_device_major_number major
rtems_device_minor_number minor
uint32_t flags
uint32_t compact_segs
uint32_t avail_compact_segs
uint32_t block_size
rtems_fdisk_block_ctl * blocks
uint32_t block_count
uint32_t unavail_blocks
uint32_t starvation_threshold
uint32_t erased_blocks
rtems_fdisk_device_ctl * devices
uint32_t device_count
rtems_fdisk_segment_ctl_queue available
rtems_fdisk_segment_ctl_queue used
rtems_fdisk_segment_ctl_queue erase
rtems_fdisk_segment_ctl_queue failed
rtems_mutex lock
uint8_t * copy_buffer
uint32_t info_level
uint32_t starvations
The virtual block table holds the mapping for blocks as seen by the disk drivers to the device, segment and page numbers of the physical device.
Field Documentation
◆ avail_compact_segs
uint32_t rtems_flashdisk::avail_compact_segs
The number of segments when compaction occurs when writing.
◆ available
rtems_fdisk_segment_ctl_queue rtems_flashdisk::available
The queue of segments with available pages.
◆ block_count
uint32_t rtems_flashdisk::block_count
The number of avail. blocks.
◆ block_size
uint32_t rtems_flashdisk::block_size
The block size for this disk.
◆ blocks
rtems_fdisk_block_ctl* rtems_flashdisk::blocks
The block to segment-page mappings.
◆ compact_segs
uint32_t rtems_flashdisk::compact_segs
Max segs to compact at once.
◆ copy_buffer
uint8_t* rtems_flashdisk::copy_buffer
Copy buf used during compacting
◆ device_count
uint32_t rtems_flashdisk::device_count
The number of flash devices.
◆ devices
rtems_fdisk_device_ctl* rtems_flashdisk::devices
The flash devices for this disk.
◆ erase
rtems_fdisk_segment_ctl_queue rtems_flashdisk::erase
The list of segments to be erased.
◆ erased_blocks
uint32_t rtems_flashdisk::erased_blocks
The number of erased blocks.
◆ failed
rtems_fdisk_segment_ctl_queue rtems_flashdisk::failed
The list of segments that failed when being erased.
◆ flags
uint32_t rtems_flashdisk::flags
configuration flags.
◆ info_level
uint32_t rtems_flashdisk::info_level
The info trace level.
◆ lock
rtems_mutex rtems_flashdisk::lock
Mutex for threading protection.
◆ major
rtems_device_major_number rtems_flashdisk::major
The driver's major number.
◆ minor
rtems_device_minor_number rtems_flashdisk::minor
The driver's minor number.
◆ starvation_threshold
uint32_t rtems_flashdisk::starvation_threshold
Erased blocks starvation threshold.
◆ starvations
uint32_t rtems_flashdisk::starvations
Erased blocks starvations counter.
◆ unavail_blocks
uint32_t rtems_flashdisk::unavail_blocks
The number of unavail blocks.
◆ used
rtems_fdisk_segment_ctl_queue rtems_flashdisk::used
The list of segments with all pages used.
